SBR-160-RGBW-R41-RE102
    LUMINUS(朗明纳斯)
    BIG CHIP LED HB MODULE RGB WHT
SBR-160-RGBW-R41-RE102 数据手册
SBM-160 LED Binning and Labeling Introduction Table of Contents This document describes the binning and labeling nomenclature for PhlatLight LED products as well as the orderable bin kits for each part. Table of Products ................................................ 2 With each build of parts, there is a distribution of performance in both flux and wavelength or chromaticity. In order to guarentee specific performance for customers, each device is measured and subsequently grouped into flux and wavelength or chromaticity bins. Each individual package or reel of parts contains only one combination of flux and wavelength or chromaticity bin. Furthermore, bins are combined into orderable bin kits comprising of a selection of flux and wavelength or chromaticity bins to ease the ordering process. Shipping and Labeling Nomenclature ......................... 3 Bin Kit Ordering Nomenclature ................................ 4 White Flux Binning Structure................................... 5 White Chromaticity Binning Structure ........................ 6 SBM-160 Bin Kit Codes........................................... 8 www.luminus.com © 2011 Luminus Devices, Inc. - All Rights Reserved Last Update 04-27-2011 PDS-001792 Rev 01 SBM-160 Binning and Labeling Table of Products Product Ordering Part Number Description SBM-160-RGBW SBM-160-RGBW-H 41-X X 1 2 3 PhlatLight SBM-160 surface mount device consisting of four 4 mm2 LED mounted on a ceramic substrate. SBR-160-RGBW SBR-160-RGBW-R 41-X X 1 2 3 PhlatLight SBR-160 evaluation module s consisting of a SBM160 urface mount device mounted on an Aluminum star board. © 2011 Luminus Devices, Inc. - All Rights Reserved Page 2 SBM-160 Binning and Labeling PhlatLight Shipping and Labeling Nomenclature All PhlatLight products are packaged and labeled with their respective bin as outlined in the following pages. Each package or reel will only contain one bin. The part number designation is as follows: ABC DEFG H45 IJK Chip Area Color Package Configuration Flux Bin Package Config Chip Area C - Chip quantity. “M” denotes multi-chip and “R” denotes prototype board D E F G- Color. “RGBW” denotes red Green blue white Flux Bin Wavelength/ Chromaticity Bin B - Lens type. “B” denotes window (no lens). 1 2 3 - Total LED chip area (mm2) x 10. “160” denotes 16 mm2. Wavelength/ Chromaticity Bin L6 A - Package type. “S” denotes surface mount Color Product Family Product Family 123 H 4 5 - Package configuration (for internal use). I J K - Flux bin L 6 - Wavelength / Chromaticity bin Example: The part number SBM-160-RGBW-H41-WEA-G4 refers to a RGBW, SBM-160 emitter, with a flux range of 510-550 lumens and a chromaticity value within the box defined by the four points (0.313, 0.338), (0.321, 0.348), (0.322, 0.336), (0.312, 0.328). © 2011 Luminus Devices, Inc. - All Rights Reserved Page 3 SBM-160 Binning and Labeling PhlatLight Bin Kit Ordering Nomenclature All PhlatLight White products are sold in sets of flux and chromaticity bins called bin kits. Each bin kit specifies a minimum flux bin and a specific selection of chromaticity bins. The ordering part number designation is as follows: ABC DEFG H45 Chip Area Color Package Configuration Chip Area C - Chip quantity. “M” denotes multi-chip and “R” denotes prototype board D E F G- Color. “RGBW” denotes red Green blue white Package Config Bin Kit B - Lens type. “B” denotes window (no lens). 1 2 3 - Total LED chip area (mm2) x 10. “160” denotes 16 mm2. Bin Kit IJ678 A - Package type. “S” denotes surface mount Color Product Family Product Family 123 H 4 5 - Package configuration (for internal use). I J - Flux bin kit code 6 7 8 - Wavelength / Chromaticity bin kit code Example: The ordering part number SBM-160-RGBW-H41-RE101 refers to a bin kit containing a minimum flux value of 510 lumens and falling in the F4, F3, G4, G3, EF, and DG chromaticity bins. © 2011 Luminus Devices, Inc. - All Rights Reserved Page 4 SBM-160 Binning and Labeling PhlatLight White Flux Binning Structure All white PhlatLight LEDs are tested for luminous flux and placed into one of the following flux bins. Not all flux bins are currently available for each product, so consult the specific product datasheet for the list of available flux bins for the specific product. White Flux Bins Flux Bin Code (FF) Composite Bin Code Minimum Luminous Flux Maximum Luminous Flux WD WDA,WDB 440 510 WE WEA,WEB 510 590 •Note: Luminus maintains a tolerance of +/- 6% on all flux measurements. © 2011 Luminus Devices, Inc. - All Rights Reserved Page 5 SBM-160 Binning and Labeling PhlatLight White Chromaticity Binning Structure All white PhlatLight LEDs are tested for chromaticity and placed into one of the following chromaticity bins. The binning structure is universally applied across the full white product line, however not all chromaticity bins are currently available for each product. Consult the specific product datasheet for the list of available chromaticity bins for the specific product. Luminus’ Standard Chromaticity Bins: 1931 CIE Curve •Note: Luminus maintains a tolerance of +/- 6% on all flux measurements. © 2011 Luminus Devices, Inc. - All Rights Reserved Page 6 SBM-160 Binning and Labeling 6500K Chromaticity Bins Bin Code (WW) DG F3* F4* G3* G4* EF DE DF CIEx CIEy 0.307 0.322 0.323 0.309 0.305 0.313 0.315 0.307 0.303 0.312 0.313 0.305 0.313 0.321 0.322 0.315 0.312 0.321 0.321 0.313 0.302 0.320 0.321 0.303 0.283 0.303 0.307 0.289 0.289 0.307 0.309 0.293 0.311 0.326 0.316 0.302 0.321 0.329 0.319 0.311 0.330 0.339 0.329 0.321 0.329 0.337 0.326 0.319 0.339 0.348 0.337 0.329 0.335 0.354 0.348 0.330 0.304 0.330 0.311 0.293 0.293 0.311 0.302 0.285 5700K Chromaticity Bins Bin Code (WW) DJ H3* H4* J3* J4* EH CIEx CIEy 0.322 0.337 0.336 0.323 0.321 0.329 0.329 0.322 0.321 0.329 0.329 0.321 0.329 0.337 0.337 0.330 0.329 0.338 0.337 0.329 0.320 0.338 0.338 0.321 0.324 0.337 0.326 0.314 0.335 0.342 0.331 0.324 0.346 0.354 0.342 0.335 0.342 0.349 0.337 0.331 0.354 0.362 0.349 0.342 0.352 0.368 0.362 0.346 © 2011 Luminus Devices, Inc. - All Rights Reserved Page 7 SBM-160 Binning and Labeling SBM-160 Bin Kit Order Codes The following tables describe the bin kit ordering codes for the SBM-160 and the flux and wavelength or chromaticity bins included in the bin kit. Each kit specifies a minimum flux and the listed wavelength or chromaticity bins. A maximum flux is not specified. Within each kit, Luminus may ship any part meeting or exceeding the minimum flux specification. Shipments will always meet the listed wavelength or chromaticity bins. For information on ordering bin kits not listed below, please contact Luminus or an official distributor. SBM-160-RGBW-H41-XX123 Color Luminous Flux Bin Kit Flux Code Minimum Flux RD 440 RGBW RE 510 Chromaticity Bins Kit Number F4, F3, G4, G3, EF, DG, DE, DF RD100 F4, F3, G4, G3, EF, DG RD101 F4, F3, G4, G3 RD102 F4, F3, G4, G3, EF, DG, DE, DF RE100 F4, F3, G4, G3, EF, DG RE101 F4, F3, G4, G3 RE102 SBR-160-RGBW-R41-XX123 Color Luminous Flux Bin Kit Flux Code Minimum Flux RD 440 RGBW RE 510 Chromaticity Bins Kit Number F4, F3, G4, G3, EF, DG, DE, DF RD100 F4, F3, G4, G3, EF, DG RD101 F4, F3, G4, G3 RD102 F4, F3, G4, G3, EF, DG, DE, DF RE100 F4, F3, G4, G3, EF, DG RE101 F4, F3, G4, G3 RE102 © 2011 Luminus Devices, Inc. - All Rights Reserved Page 8 SBM-160 Binning and Labeling The products, their specifications and other information appearing in this document are subject to change by Luminus Devices without notice. Luminus Devices assumes no liability for errors that may appear in this document, and no liability otherwise arising from the application or use of the product or information contained herein. None of the information provided herein should be considered to be a representation of the fitness or suitability of the product for any particular application or as any other form of warranty. Luminus Devices’ product warranties are limited to only such warranties as accompany a purchase contract or purchase order for such products. Nothing herein is to be construed as constituting an additional warranty. No information contained in this publication may be considered as a waiver by Luminus Devices of any intellectual property rights that Luminus Devices may have in such information. PhlatLight® is a registered trademark of Luminus Devices, Inc., all rights reserved. This product is protected by U.S. Patents 6,831,302; 7,074,631; 7,083,993; 7,084,434; 7,098,589; 7,105,861; 7,138,666; 7,166,870; 7,166,871; 7,170,100; 7,196,354; 7,211,831; 7,262,550; 7,274,043; 7,301,271; 7,341,880; 7,344,903; 7,345,416; 7,348,603; 7,388,233; 7,391,059; Patents Pending in the U.S. and other countries. www.luminus.com © 2011 Luminus Devices, Inc. - All Rights Reserved Page 9
SBR-160-RGBW-R41-RE102 价格&库存
很抱歉,暂时无法提供与“SBR-160-RGBW-R41-RE102”相匹配的价格&库存,您可以联系我们找货
