CMLS136E-5R6MS
CMLS136E-5R6MS
    CYNTEC(乾坤)
    IND_13.45X12.6MM_SM
    功率电感 5.6µH ±20% IND_13.45X12.6MM_SM 6.30mm 13.45 x 12.60mm 10.5mΩ 12.5A
CMLS136E-5R6MS 数据手册
CYNTEC CO., LTD. 乾坤科技股份有限公司 DOCUMENT : CMLS136E-000 REVISION : A8 PAGE : 1 OF 4 Power Choke Coil CMLS136E MS type  Features High performance (Isat) realized by metal dust core. Low profile:Thickness max. 6.5mm Low loss realized with low DCR Capable of corresponding high frequency (1MHz) 100% lead (Pb) free meet RoHS standard  Application DC/DC converter for CPU in Notebook PC Thin type on-board power supply module for exchanger VRM for server  Outline Dimensions A' L A B W B' L 13.45  0.35 W 12.6  0.2 T 6.3  0.2 A 2.0  0.5 A’ 2.5  0.1 4.0  0.5 B H  Dimensions (mm) Code R68 / 1R0 / 1R3 / 1R5 4R7 / 5R6 / 6R8 /8R2 1R8 / 2R2 / 3R3 100 / 150 / 220 T 5.0  0.5 6.0  0.2 0 ~ +0.15 B’ H Recommend Land Pattern Dimensions The customer shall determine the land dimensions shown below after confirming and safety. B A C A 5.0 B 8.0 C 14.6 Unit : mm Dec., 2018 CYNTEC CO., LTD. 乾坤科技股份有限公司  DOCUMENT : CMLS136E-000 REVISION : A8 PAGE : 2 OF 4 Specifications L0 Inductance ( H ) @ (0A) Typical CMLS136E-R68MS 0.68 CMLS136E-1R0MS Heat Rating Current DC Amps. Idc ( A ) Saturation Current DC Amps. Isat ( A ) Maximum Typical Maximum Typical Maximum 1.45 1.68 35.0 32.0 75.0 70.0 1.0 1.80 2.15 31.0 28.0 53.0 50.0 CMLS136E-1R3MS 1.3 2.2 2.5 28.5 27.5 52.0 49.0 CMLS136E-1R5MS 1.5 2.3 2.6 28.0 27.0 51.0 48.0 CMLS136E-1R8MS 1.8 2.7 3.1 25.0 24.0 49.0 47.0 CMLS136E-2R2MS 2.2 3.49 4.20 22.5 21.5 46.0 42.0 CMLS136E-3R3MS 3.3 3.75 4.40 22.0 20.0 42.0 40.0 CMLS136E-4R7MS 4.7 7.8 8.5 16.0 15.0 30.0 26.0 CMLS136E-5R6MS 5.6 9.0 10.5 14.0 12.5 28.0 24.0 CMLS136E-6R8MS 6.8 11.5 13.5 12.5 11.0 26.0 22.0 CMLS136E-8R2MS 8.2 14.0 16.0 11.5 10.0 21.0 19.0 CMLS136E-100MS 10.0 16.0 18.5 11.0 9.0 20.0 18.0 CMLS136E-150MS 15.0 32.0 37.0 8.5 7.5 15.0 13.0 CMLS136E-220MS 22.0 38.0 44.0 6.5 5.8 11.5 10.0 Part Number Rdc ( m) * :If you require another part number please contact with us. **:Inductance Tolerance  20% Note 1.: All test data is referenced to 25℃ ambient. Note 2.: Test Condition:100KHz, 1.0Vrms Note 3.: Idc : DC current (A) that will cause an approximate △T of 40℃ Note 4.: Isat : DC current (A) that will cause L0 to drop approximately 30% Note 5.: Operating Temperature Range -55℃ to + 125℃ Note 6.: The part temperature (ambient + temp rise) should not exceed 125℃ under the worst case operating conditions. Circuit design, component placement, PCB trace size and thickness, airflow and other cooling provision all affect the part temperature. Part temperature should be verified in the end application. Note 7.: The rated current as listed is either the saturation current or the heating current depending on which value is lower. Dec., 2018 CYNTEC CO., LTD. 乾坤科技股份有限公司  : A8 PAGE : 3 OF 4 1.00 40 0.28 INDUCTANCE(μH) 0.14 TEMP. RISE(℃) 20 60 0.60 40 0.40 INDUCTANCE(μH) 0.20 0 0 10 15 20 25 30 35 40 45 50 55 60 65 70 5 10 15 20 DC BIAS(Amps) 1.20 100 1.80 80 1.50 60 0.90 0.60 INDUCTANCE(μH) 0.30 TEMP. RISE(℃) 40 20 INDUCTANCE(μH) 1.50 TEMP. RISE(℃) CMLS136E-1R3MS 1.80 0 0.00 0 5 10 15 20 25 30 35 40 45 50 55 80 60 40 INDUCTANCE(μH) 0.30 TEMP. RISE(℃) 80 2.25 60 40 INDUCTANCE(μH) 0.40 TEMP. RISE(℃) 20 0.00 0 0 5 10 15 20 25 30 35 40 45 50 10 15 20 25 30 35 DC BIAS(Amps) 80 60 40 0.90 INDUCTANCE(μH) 0.45 TEMP. RISE(℃) 5.00 40 20 TEMP. RISE(℃) 0.00 0 30 36 42 INDUCTANCE(μH) 80 INDUCTANCE(μH) 18 24 DC BIAS(Amps) 100 1.35 6.00 60 12 55 1.80 100 2.10 6 50 CMLS136E-2R2MS 20 0 0 TEMP. RISE(℃) 2.80 0 45 4 8 12 16 20 24 28 32 36 40 44 48 DC BIAS(Amps) 3.50 0.70 40 0.00 55 CMLS136E-3R3MS 1.40 20 0 5 DC BIAS(Amps) 4.20 60 100 0.60 2.70 1.20 0.80 55 0.90 100 INDUCTANCE(μH) 1.60 50 1.20 0 TEMP. RISE(℃) 2.00 45 0.00 60 CMLS136E-1R8MS 25 30 35 40 DC BIAS(Amps) CMLS136E-1R5MS DC BIAS(Amps) 2.40 20 TEMP. RISE(℃) 100 CMLS136E-4R7MS 80 4.00 60 3.00 2.00 INDUCTANCE(μH) 1.00 TEMP. RISE(℃) 40 20 0.00 TEMP. RISE(℃) 5 80 0.80 0.00 0 0 100 TEMP. RISE(℃) 60 CMLS136E-1R0MS TEMP. RISE(℃) 80 0.42 0.00 INDUCTANCE(μH) REVISION TEMP. RISE(℃) 1.20 INDUCTANCE(μH) INDUCTANCE(μH) 0.56 100 TEMP. RISE(℃) CMLS136E-R68MS 0.70 INDUCTANCE(μH) : CMLS136E-000 Current Characteristic 0.84 INDUCTANCE(μH) DOCUMENT 0 0 4 8 12 16 20 24 28 32 36 DC BIAS(Amps) Dec., 2018 TEMP. RISE(℃) 60 0 4 6 8 CMLS136E-8R2MS 9.60 8.00 6.40 INDUCTANCE(μH) 1.60 TEMP. RISE(℃) 12.0 80 10.0 20 0 6 8 CMLS136E-150MS 12.0 60 9.0 6.0 INDUCTANCE(μH) 3.0 TEMP. RISE(℃) 40 20 0.0 0 2 4 6 8 10 12 DC BIAS(Amps) 14 16 18 20 10 15 20 DC BIAS(Amps) 25 30 CMLS136E-100MS 100 80 8.0 60 6.0 40 4.0 INDUCTANCE(μH) 2.0 TEMP. RISE(℃) 20 0 3 6 9 12 15 DC BIAS(Amps) 18 21 24 CMLS136E-220MS 27.0 80 0 0 5 0 100 15.0 20 TEMP. RISE(℃) 0.0 10 12 14 16 18 20 22 24 26 28 DC BIAS(Amps) INDUCTANCE(μH) 4 18.0 INDUCTANCE(μH) 100 40 0.00 2 1.60 0 60 3.20 40 INDUCTANCE(μH) 0.00 4.80 0 3.20 10 12 14 16 18 20 22 24 26 DC BIAS(Amps) INDUCTANCE(μH) 2 TEMP. RISE(℃) 0 INDUCTANCE(μH) 4.80 20 0.00 100 80 40 1.00 CMLS136E-6R8MS TEMP. RISE(℃) 2.00 : 4 OF 4 100 22.5 80 18.0 60 INDUCTANCE(μH) 13.5 TEMP. RISE(℃) 40 9.0 20 4.5 0.0 TEMP. RISE(℃) INDUCTANCE(μH) PAGE 6.40 60 3.00 : A8 80 INDUCTANCE(μH) 4.00 REVISION 8.00 TEMP. RISE(℃) INDUCTANCE(μH) 5.00 : CMLS136E-000 100 TEMP. RISE(℃) CMLS136E-5R6MS 6.00 DOCUMENT TEMP. RISE(℃) CYNTEC CO., LTD. 乾坤科技股份有限公司 0 0 1 2 3 4 5 6 7 8 9 DC BIAS(Amps) 10 11 12 13 Dec., 2018
CMLS136E-5R6MS 价格&库存
很抱歉,暂时无法提供与“CMLS136E-5R6MS”相匹配的价格&库存,您可以联系我们找货
