CYNTEC CO., LTD.
乾坤科技股份有限公司
DOCUMENT
: CMLS136E-000
REVISION
: A8
PAGE
: 1 OF 4
Power Choke Coil CMLS136E MS type
Features
High performance (Isat) realized by metal dust core.
Low profile:Thickness max. 6.5mm
Low loss realized with low DCR
Capable of corresponding high frequency (1MHz)
100% lead (Pb) free meet RoHS standard
Application
DC/DC converter for CPU in Notebook PC
Thin type on-board power supply module for exchanger
VRM for server
Outline Dimensions
A'
L
A
B
W
B'
L
13.45 0.35
W
12.6 0.2
T
6.3 0.2
A
2.0 0.5
A’
2.5 0.1
4.0 0.5
B
H
Dimensions (mm)
Code R68 / 1R0 / 1R3 / 1R5 4R7 / 5R6 / 6R8 /8R2
1R8 / 2R2 / 3R3
100 / 150 / 220
T
5.0 0.5
6.0 0.2
0 ~ +0.15
B’
H
Recommend Land Pattern Dimensions
The customer shall determine the land dimensions shown below after confirming and safety.
B
A
C
A
5.0
B
8.0
C
14.6
Unit : mm
Dec., 2018
CYNTEC CO., LTD.
乾坤科技股份有限公司
DOCUMENT
: CMLS136E-000
REVISION
: A8
PAGE
: 2 OF 4
Specifications
L0
Inductance
( H )
@ (0A)
Typical
CMLS136E-R68MS
0.68
CMLS136E-1R0MS
Heat Rating Current
DC Amps. Idc ( A )
Saturation Current
DC Amps. Isat ( A )
Maximum
Typical
Maximum
Typical
Maximum
1.45
1.68
35.0
32.0
75.0
70.0
1.0
1.80
2.15
31.0
28.0
53.0
50.0
CMLS136E-1R3MS
1.3
2.2
2.5
28.5
27.5
52.0
49.0
CMLS136E-1R5MS
1.5
2.3
2.6
28.0
27.0
51.0
48.0
CMLS136E-1R8MS
1.8
2.7
3.1
25.0
24.0
49.0
47.0
CMLS136E-2R2MS
2.2
3.49
4.20
22.5
21.5
46.0
42.0
CMLS136E-3R3MS
3.3
3.75
4.40
22.0
20.0
42.0
40.0
CMLS136E-4R7MS
4.7
7.8
8.5
16.0
15.0
30.0
26.0
CMLS136E-5R6MS
5.6
9.0
10.5
14.0
12.5
28.0
24.0
CMLS136E-6R8MS
6.8
11.5
13.5
12.5
11.0
26.0
22.0
CMLS136E-8R2MS
8.2
14.0
16.0
11.5
10.0
21.0
19.0
CMLS136E-100MS
10.0
16.0
18.5
11.0
9.0
20.0
18.0
CMLS136E-150MS
15.0
32.0
37.0
8.5
7.5
15.0
13.0
CMLS136E-220MS
22.0
38.0
44.0
6.5
5.8
11.5
10.0
Part Number
Rdc ( m)
* :If you require another part number please contact with us.
**:Inductance Tolerance 20%
Note 1.: All test data is referenced to 25℃ ambient.
Note 2.: Test Condition:100KHz, 1.0Vrms
Note 3.: Idc : DC current (A) that will cause an approximate △T of 40℃
Note 4.: Isat : DC current (A) that will cause L0 to drop approximately 30%
Note 5.: Operating Temperature Range -55℃ to + 125℃
Note 6.: The part temperature (ambient + temp rise) should not exceed 125℃ under the worst case operating
conditions. Circuit design, component placement, PCB trace size and thickness, airflow and other cooling
provision all affect the part temperature. Part temperature should be verified in the end application.
Note 7.: The rated current as listed is either the saturation current or the heating current depending on which value
is lower.
Dec., 2018
CYNTEC CO., LTD.
乾坤科技股份有限公司
: A8
PAGE
: 3 OF 4
1.00
40
0.28
INDUCTANCE(μH)
0.14
TEMP. RISE(℃)
0.60
40
0.40
INDUCTANCE(μH)
0.20
10 15 20 25 30 35 40 45 50 55 60 65 70
5
10
15
DC BIAS(Amps)
1.20
100
1.80
80
1.50
60
0.90
0.60
INDUCTANCE(μH)
0.30
TEMP. RISE(℃)
40
INDUCTANCE(μH)
1.50
TEMP. RISE(℃)
CMLS136E-1R3MS
1.80
10
15
30
35
40
45
50
55
80
60
40
INDUCTANCE(μH)
0.30
TEMP. RISE(℃)
80
2.25
60
40
INDUCTANCE(μH)
0.40
TEMP. RISE(℃)
10
15
30
35
40
45
50
10
15
20 25 30 35
DC BIAS(Amps)
80
60
40
0.90
INDUCTANCE(μH)
0.45
TEMP. RISE(℃)
5.00
40
TEMP. RISE(℃)
0.00
36
42
INDUCTANCE(μH)
80
INDUCTANCE(μH)
18
24
DC BIAS(Amps)
100
1.35
6.00
60
12
55
1.80
100
2.10
6
50
CMLS136E-2R2MS
TEMP. RISE(℃)
2.80
4
8
12
16
28
32
36
40
44
48
DC BIAS(Amps)
3.50
0.70
40
0.00
55
CMLS136E-3R3MS
1.40
DC BIAS(Amps)
4.20
60
100
0.60
2.70
1.20
0.80
55
0.90
100
INDUCTANCE(μH)
1.60
50
1.20
TEMP. RISE(℃)
2.00
45
0.00
60
CMLS136E-1R8MS
25 30 35 40
DC BIAS(Amps)
CMLS136E-1R5MS
DC BIAS(Amps)
2.40
TEMP. RISE(℃)
100
CMLS136E-4R7MS
80
4.00
60
3.00
2.00
INDUCTANCE(μH)
1.00
TEMP. RISE(℃)
40
TEMP. RISE(℃)
5
80
0.80
0.00
TEMP. RISE(℃)
60
CMLS136E-1R0MS
TEMP. RISE(℃)
80
0.42
0.00
INDUCTANCE(μH)
REVISION
TEMP. RISE(℃)
1.20
INDUCTANCE(μH)
INDUCTANCE(μH)
0.56
100
TEMP. RISE(℃)
CMLS136E-R68MS
0.70
INDUCTANCE(μH)
: CMLS136E-000
Current Characteristic
0.84
INDUCTANCE(μH)
DOCUMENT
8
12
16
28
32
36
DC BIAS(Amps)
Dec., 2018
TEMP. RISE(℃)
60
6
8
CMLS136E-8R2MS
9.60
8.00
6.40
INDUCTANCE(μH)
1.60
TEMP. RISE(℃)
12.0
80
10.0
8
CMLS136E-150MS
12.0
60
9.0
6.0
INDUCTANCE(μH)
3.0
TEMP. RISE(℃)
40
4
6
8
10
12
DC BIAS(Amps)
14
16
18
15
DC BIAS(Amps)
25
30
CMLS136E-100MS
100
80
8.0
60
6.0
40
4.0
INDUCTANCE(μH)
2.0
TEMP. RISE(℃)
6
9
12
15
DC BIAS(Amps)
18
21
24
CMLS136E-220MS
27.0
80
15.0
TEMP. RISE(℃)
0.0
10 12 14 16 18 20 22 24 26 28
DC BIAS(Amps)
INDUCTANCE(μH)
4
18.0
INDUCTANCE(μH)
100
40
0.00
2
1.60
3.20
40
INDUCTANCE(μH)
0.00
4.80
DC BIAS(Amps)
INDUCTANCE(μH)
2
TEMP. RISE(℃)
INDUCTANCE(μH)
4.80
100
80
40
1.00
CMLS136E-6R8MS
TEMP. RISE(℃)
2.00
: 4 OF 4
100
22.5
80
18.0
60
INDUCTANCE(μH)
13.5
TEMP. RISE(℃)
40
9.0
0.0
TEMP. RISE(℃)
INDUCTANCE(μH)
PAGE
6.40
60
3.00
: A8
80
INDUCTANCE(μH)
4.00
REVISION
8.00
TEMP. RISE(℃)
INDUCTANCE(μH)
5.00
: CMLS136E-000
100
TEMP. RISE(℃)
CMLS136E-5R6MS
6.00
DOCUMENT
TEMP. RISE(℃)
CYNTEC CO., LTD.
乾坤科技股份有限公司
2
3
4
5
6
7
8
9
DC BIAS(Amps)
10
11
12
13
Dec., 2018
很抱歉,暂时无法提供与“CMLS136E-101MS”相匹配的价格&库存,您可以联系我们找货
