HSM6056
N-Ch 60V Fast Switching MOSFETs
Description
Product Summary
Advanced Trench MOS Technology
Low Gate Charge
Low RDS(ON)
100% EAS Guaranteed
Green Device Available
60
V
RDS(ON),typ
7.2
mΩ
ID
15
A
SOP-8 Pin Configuration
Application
VDS
Motor Control.
DC/DC Converter.
Synchronous rectifier applications.
Absolute Maximum Ratings
Symbol
Parameter
Rating
Units
VDS
Drain-Source Voltage
60
V
VGS
Gate-Source Voltage
ID@TC=25℃
ID@TC=100℃
IDM
±20
V
Continuous Drain
Current1
15
A
Continuous Drain
Current1
11
A
56
A
26.5
mJ
23
A
3.1
W
Pulsed Drain
Current2
EAS
Single Pulse Avalanche Energy
IAS
Avalanche Current
PD@TA=25℃
Total Power Dissipation
3
4
TSTG
Storage Temperature Range
-55 to 150
TJ
Operating Junction Temperature Range
-55 to 150
Thermal Data
Symbol
Parameter
RθJA
Thermal Resistance Junction-Ambient
RθJC
Junction-Case1
www.hs-semi.cn
Thermal Resistance
Ver 2.0
Typ.
1
Max.
Unit
75
℃/W
40
℃/W
1
HSM6056
Electrical Characteristics (TJ=25 ℃, unless otherwise noted)
Symbol
Parameter
Min.
Typ.
Max.
Unit
VGS=0V , ID=250uA
60
V
VGS=10V , ID=15A
7.2
8.5
VGS=4.5V , ID=10A
11.5
14.5
VGS=VDS , ID =250uA
1.2
2.3
VDS=48V , VGS=0V , TJ=25℃
1
VDS=48V , VGS=0V , TJ=55℃
5
Gate-Source Leakage Current
VGS=±20V , VDS=0V
±100
nA
Rg
Gate Resistance
VDS=0V , VGS=0V , f=1MHz
1.3
Qg
Total Gate Charge (4.5V)
15
Qgs
Gate-Source Charge
3.5
Qgd
Gate-Drain Charge
4.2
BVDSS
Drain-Source Breakdown Voltage
RDS(ON)
Static Drain-Source On-Resistance2
VGS(th)
IDSS
IGSS
Gate Threshold Voltage
Drain-Source Leakage Current
Conditions
VDS=30V , VGS=10V , ID=15A
m
V
uA
nC
7
Rise Time
VDD=30V , VGS=10V , RG=3.3,
4.5
Turn-Off Delay Time
ID=15A
26
Fall Time
5
Ciss
Input Capacitance
1270
Coss
Output Capacitance
478
Crss
Reverse Transfer Capacitance
40
Min.
Typ.
Max.
Unit
VG=VD=0V , Force Current
5
A
VGS=0V , IS=A , TJ=25℃
1
V
Td(on)
Tr
Td(off)
Tf
Turn-On Delay Time
VDS=30V , VGS=0V , f=1MHz
ns
pF
Diode Characteristics
Symbol
IS
VSD
Parameter
Continuous Source
Diode Forward
Current1,5
Voltage2
Conditions
Note :
1.The data tested by surface mounted on a 1 inch 2 FR-4 board with 2OZ copper.
2.The data tested by pulsed , pulse width ≦ 300us , duty cycle ≦ 2%
3.The EAS data shows Max. rating . The test condition is V DD=25V,VGS=10V,L=0.1mH,IAS=23A
4.The power dissipation is limited by 150℃ junction temperature
5.The data is theoretically the same as ID and IDM , in real applications , should be limited by total power dissipation.
www.hs-semi.cn
Ver 2.0
2
HSM6056
Typical Characteristics
Fig.1 Typical Output Characteristics
Fig.2 On-Resistance vs. Gate-Source
Voltage
Fig.3 Source Drain Forword Characteristicsdiode
Fig.5 Normalized VGS(th) vs. TJ
www.hs-semi.cn
Fig.4 Gate-Charge Characteristics
Fig.6 Normalized RDSON vs. TJ
Ver 2.0
3
HSM6056
Fig.7 Capacitance
Fig.8 Safe Operating Area
Fig.9 Normalized Maximum Transient Thermal Impedance
EAS=
VDS
90%
BVDSS
1
L x IAS2 x
2
BVDSS
BVDSS-VDD
VDD
IAS
10%
VGS
Td(on)
Tr
Ton
Td(off)
Tf
Toff
VGS
Fig.10 Switching Time Waveform
www.hs-semi.cn
Fig.11 Unclamped Inductive Switching Waveform
Ver 2.0
4
HSM6056
Ordering Information
Part Number
HSM6056
www.hs-semi.cn
Package code
SOP-8
Ver 2.0
Packaging
2500/Tape&Reel
5
很抱歉,暂时无法提供与“HSM6056”相匹配的价格&库存,您可以联系我们找货
