Radiocrafts
Embedded Wireless Solutions
RC11XXHP-RC232
High Power Multi-Channel RF Transceiver Module
Product Description
The RC11XXHP-RC232 RF Transceiver Modules are compact surface-mounted high
performance modules for GFSK operation with embedded protocol. The modules are completely
shielded and pre-certified for operation under the European and Indian radio regulations.
Applications
• Home and building automation
• AMR, Automatic Meter Reading
• Radio modems
• Alarm and security systems
• Point-of-sales terminals
• Bar code scanners
• Telemetry stations
• Fleet management
Features
• High Power, long range (3-5 km Line-Of-Sight)
• Completely Shielded module for SMD mounting
• Embedded RC232™ protocol with Addressing and Error check
• Two-wire UART interface for easy RS232/422/485 wire replacement (handshake optional)
• No external components
• No configuration required for single-channel use
• Pin compatible with the low cost family RC11XX (including –MBUS and –KNX versions) and
2.4 GHz versions RC2500/2500HP from Radiocrafts
• Close to pin compatible with RC12XX narrowband family from Radiocrafts
(available modules for China, Japan and Korea)
• 12.7 x 25.4 x 3.7 mm compact module for SMD mounting
• 3.0 – 3.3 V supply voltage, ultra low power modes
• Designed for EX compliance
Quick Reference Data
Parameter
RC1170HP-RC232 RC1180HP-RC232 RC1190HP-RC232 Unit
Frequency bands
865.0 – 867.0
868.0 – 870.0
902-928
MHz
Number of channels
15
3 (HP)*, 18 (LP)*
51
Data rate
1.2 – 100
1.2 – 76.8
1.2 – 76.8
kbit/s
Max output power
27
27
27
dBm
Sensitivity
-109
-109
-109
dBm
Supply voltage
3.0 – 3.3
3.0 – 3.3
3.0 – 3.3
Volt
Current consumption,
24 / 560
24 / 560
24 / 560
mA
RX / TX
Typ. 3.4
Typ. 3.4
Typ. 3.4
uA
SLEEP
Temperature range
-40 to +85
-40 to +85
-40 to +85
C
©2019 Radiocrafts AS
RC11XXHP-RC232 Data Sheet (rev. 1.11)
Page 1 of 28
Radiocrafts
RC11XXHP-RC232
Conforms with
G.S.R.
564(E)/168(E)
(India)
Module status
Full production
EU RED directive
(EN300220,
EN301489,
EN60950)
Full production
Full production
*HP: High Power, LP: Low Power
Typical application circuit
3.0 – 3.3 V
To actuator or
from sensor or
towards
RS232/422/485/
USB driver
Optional
GND
CTS
RTS
CONFIG
TXD
RXD
GND
GND
VCC
RESET
NC
GND
RF
GND
Antenna
NC
See page 19 for additional schematic information regarding recommended Reset and Power
supply filtering, and how to include a firmware upgrade connector.
Quick Product Introduction
How do I transmit data?
Send your data to the RXD pin on the module. Use the UART format with settings (19200, 8, 1,
N, no flow control). Up to 1018 of payload bytes are buffered in the module (total 1024 including
header bytes). The module will transmit the data when
• the max packet length is reached
• the unique end character is sent
• the modem timeout limit is reached
The packet length, end character and timeout limit are configurable in-circuit.
How do I receive data?
Any received data packet with correct address and check sum will be sent on the TXD pin using
the same UART format as for transmit.
What about the antenna?
In most cases a simple quarter wavelength wire or a PCB track will do. Connect a piece of wire to
the RF pin with length corresponding to the quarter of a wavelength. For space limited products,
contact Radiocrafts and we will recommend the best antenna solution for your application.
How do I change the RF channel or any other parameter?
To change configurable parameters, assert the CONFIG pin, and send the command string using
the same serial interface as for transmitting data. Parameters can be changed permanently and
stored in non-volatile memory in the module.
Page 2 of 28
Radiocrafts
RC11XXHP-RC232
RCTools
RCTools is a powerful and easy to use PC suite that helps you during test, development and
deployment of the RC11XXHP-RC232. Visit www.radiocrafts.com for a free download and full
documentation.
Page 3 of 28
Radiocrafts
RC11XXHP-RC232
Pin Assignment
30
GND
29
28
27
26
25
24
23
1
14
GND
CTS/RXTX
2
13
VCC
RTS/SLEEP
3
12
CONFIG
4
11
NC
TXD
5
10
GND
RXD
6
9
GND
7
8
15
16
17
18
19
RESET
RF
GND
22
Pin Description
Pin no Pin name
1
GND
Pin type
2
Output
3
CTS/RXTX
RTS/SLEEP Input
4
CONFIG
Input
5
6
TXD
RXD
Output
Input
Description
System ground
UART Clear to Send or UART
RXTX
UART Request to Send. Can be set
low to enter Sleep mode if RTS
handshake is not in use.
Configuration Enable. Active low.
Should normally be set high.
UART TX Data
UART RX Data.
Equivalent circuit
GND
VCC
Input:
20k
VCC
Output:
Use external max 8k2 kohm pull-up
resistor if connected to an open
collector output from a host MCU or
other high impedance circuitry like
level shifters.
7
8
GND
GND
System ground
System ground
GND
Page 4 of 28
Radiocrafts
Pin no Pin name
9
RF
Pin type
RC11XXHP-RC232
Description
RF I/O connection to antenna
Equivalent circuit
RF
10k
10
GND
11
12
NC
RESET
System ground
Input
GND
Not connected
Main reset (active low). Should
normally be left open. Internal 12
kΩ pull-up resistor.
VCC
12k
RESET
13
VCC
Supply voltage input. Internally
regulated.
1.8 V
VREG
VCC
2u2
14
GND
System ground
15-22
RESERVED
23-30
RESERVED
Test pins or pins reserved for future
use. Do not connect!
GND
Note 1: For UART communication the TXD and RXD are used for serial data, and CTS and RTS for flow control
(optional).
Note 2: The internal pull-ups on CONFIG and RTS/SLEEP pin are disabled in Sleep mode to minimise the sleep current.
Page 5 of 28
Radiocrafts
RC11XXHP-RC232
Block Diagram
GND
GND
CTS/RXTX
RTS/SLEEP
VCC
Voltage Regulator
Communication
controller
RESET
CONFIG
NC
TXD/SCL
GND
RF Transceiver
RXD/SDA
PA
RF
GND
GND
Circuit Description
The module contains a communication controller with embedded RC232™ protocol software, a
high performance RF transceiver with an internal voltage regulator and a Power Amplifier.
The communication controller handles the radio packet protocol, the UART interface and controls
the RF transceiver. Data to be sent by the host is received at the RXD pin and buffered in the
communication controller. The data packet is then assembled with preamble, start-of-frame
delimiter (SOF), address information and CRC check sum before it is transmitted on RF. The
preamble and SOF is always used. The address and CRC are optional.
The RF transceiver modulates the data to be transmitted on RF frequency, and demodulates data
that are received.
Received data are checked for correct address and CRC by the communication controller. If the
address matches the modules own address, and no CRC errors were detected, the data packet is
sent to the host on the TXD line after removing the header.
The asynchronous UART interface consists of RXD and TXD. Optionally CTS, RTS can be used
for hardware handshake flow control. RXTX can be used to control the direction of an RS485
driver circuit.
When the CONFIG pin is asserted the communication controller interprets data received on the
RXD pin as configuration commands. There are commands to change the radio channel, the
output power, the destination address etc. Permanent changes of the configuration is also
possible and are then stored in internal non-volatile memory.
The RF protocol and the configuration commands are described in detail in the RC232™ User
Manual.
The supply voltage is connected to the VCC pin. The module contains an internal voltage
regulator for the transceiver.
Page 6 of 28
Radiocrafts
RC11XXHP-RC232
RC232™ Embedded Protocol
The module offers a buffered packet radio in the RC232™ embedded protocol. Using the
buffered packet radio mode, all data to be sent is stored in the module before they are transmitted
by the RF circuitry. Likewise, when data is received they are stored in the module before they are
sent to the host. This allows the communication controller to add address information and to do
error check of the data. In buffered mode the UART interface is used to communicate with the
host.
The embedded protocol, configuration commands and configuration memory is described in the
RC232™ User Manual. This protocol is used in a wide range of RF modules available from
Radiocrafts. Please refer to the latest revision available on Radiocrafts web-site.
Power Management
The module can be set in SLEEP mode in order to reduce the power consumption.
The low power SLEEP mode is entered by using the SLEEP command ‘Z’ after the module is set
in configuration mode, or by pulling RTS/SLEEP pin low. The SLEEP pin is default off and must
be enabled in configuration memory before use. In sleep mode the module will not receive or
detect incoming data, neither from the host (UART port) nor from the RF transceiver. The module
is awakened from the SLEEP mode by a positive edge on the CONFIG pins if the module was set
in SLEEP mode using the ‘Z’ command. The module is awakened by a positive edge on the
RTS/SLEEP pin if this pin were used to enter SLEEP mode. CONFIG must be high when
awakening the module to avoid setting the module directly in configuration mode. UART data on
RXD to the module should be avoided in sleep mode.
All configuration settings and RAM values are retained during Sleep. The pull-ups on RTS/SLEEP
and CONFIG pin are disabled during sleep mode in order to minimise the sleep current
consumption.
If the module is shut completely off, all configuration settings in non-volatile memory is restored,
but values in RAM are overwritten with default settings.
Enter SLEEP Mode Using RTS/SLEEP pin
RTS/SLEEP
MODE
IDLE
SLEEP
IDLE
Enter SLEEP Mode Using CONFIG and Z Comand
CONFIG
UART Comand
MODE
Z
IDLE
CONFIG
SLEEP
IDLE
Page 7 of 28
Radiocrafts
RC11XXHP-RC232
Timing Information
The figure and table below shows the timing information for the module when changing between
different operating states.
The IDLE state is the normal state where the module search for preamble on the air and wait for
a character to be received on the UART. RXD is the state when receiving characters from the
host filling up the internal buffer. TX state is when the data is transmitted on the air. RX state is
when data is received from the air after preamble detection. TXD is the state where the received
data is sent to the host on the UART.
CONFIG is the state entered by asserting the CONFIG pin and used during parameter
configuration, while MEMORY CONFIG is the sub-state entered by the ‘M’ command where the
configuration memory is being programmed. Note the limitation on maximum number of write
cycles using the ‘M’ command, see Electrical Specifications.
tTXD
tTXD-IDLE
tRX-TXD
RX
IDLE
TXD
Preamble detected
First character on
UART TXD
tRXD-CTS
IDLE
RXD
First character on
UART RXD
tPACKET_TIMEOUT
IDLE
Last character on
UART TXD
tTX
tTX-IDLE
tRXD-TX
TX
IDLE
Last character on
UART RXD
Page 8 of 28
Radiocrafts
RC11XXHP-RC232
tOFF-IDLE
OFF
IDLE
tRESET-IDLE
RESET
IDLE
tSLEEP-IDLE
SLEEP
IDLE
tCONFIG-PROMPT
IDLE
tC-CONFIG
CONFIG
MEMORY CONFIG
’M’
Symbol
tRX-TXD
Value
180 us
tTXD
Min 590 us
tTXD-IDLE
900 us
TRXD-CTS
20 us
tRXD-TX
960 us
TTX-IDLE
960 us
tOFF-IDLE
tRESET-IDLE
tSLEEP-IDLE
tCONFIG-
3.2 ms
3.0 ms
1.28 ms
590 us
IDLE
’X’
’C’
CONFIG
set low
CONFIG
tCONFIG-IDLE
CONFIG
tCONFIG-IDLE
tMEMORY-CONFIG
CONFIG
0xFF
IDLE
’X’
Description / Note
Time from last byte is received from the air until first character is sent
on the UART
tTXD = # bytes received x 590 us/char (10 bits at 19.2 kBd + 70 us delay
per character)
Time from last character is sent on the UART until module is in IDLE
mode (ready for RXD and RX)
Time from last character is received by the UART (including any
timeout) until CTS is activated
timeout) until the module sends the first byte on the air.
Time from last character is sent on the air until module is in IDLE mode
Time from CONFIG pin is set low until prompt (“>”)
PROMPT
tC#-CONFIG
1.1 ms
tMEMORY-
30.52 ms
CONFIG
TCONFIG-
Delay after channel-byte is sent until prompt (“>”). (For other
commands like ’M’, ’T’ there is no delay but immediate prompt)
In this period the internal flash is programmed. Do not reset, turn the
module off, or allow any power supply dips in this period as it may
cause permanent error in the Flash configuration memory. After 0xFF
the host should wait for the ‘>’ prompt before any further action is done
to ensure correct re-configuration.
1.42 ms
IDLE
tTX
Min 20 ms
TRSSI
4 ms
tTX = # bytes to send x 1.67 ms/byte (at 4.8 kbit/s) + 7 bytes preamble,
sync and length + 2 bytes address + 2 bytes CRC
Time from end of S command to start of RSSI byte received on UART
Page 9 of 28
Radiocrafts
RC11XXHP-RC232
RF Frequency, Output Power Levels and Data Rates
The following table shows the available RF channels and their corresponding frequencies,
nominal output power levels and available data rates.
Model
RC1170HP-RC232
RF channel
1: 865.100 MHz
2: 865.300 MHz
3: 865.500 MHz
4: 865.700 MHz
5: 865.900 MHz
6: 866.100 MHz
7: 866.300 MHz
8: 866.500 MHz
9: 866.700 MHz
10: 866.900 MHz
11: 867.100 MHz
12: 867.300 MHz
13: 867.500 MHz
14: 867.700 MHz
15: 867.900 MHz
Output power
1:
0 dBm
2:
10 dBm
3: 14 dBm
4: 24 dBm
5: 27 dBm
Data rate
1: 1.2 kbit/s
2: 4.8 kbit/s
3: 19.0 kbit/s
4: 32.768 kbit/s
5: 76.8 kbit/s
6: 100 kbit/s
7: For future use
RC1180HP-RC232
1: 868.050 MHz
2: 868.150 MHz
3: 868.250 MHz
4: 868.350 MHz
5: 868.450 MHz
6: 868.550 MHz
7: 868.650 MHz
8: 868.750 MHz
9: 868.850 MHz
10: 868.950 MHz
11: 869.050 MHz
12: 869.150 MHz
13: 869.525 MHz
14: 869.750 MHz
15: 869.850 MHz
16: 869.950 MHz
17: 869.475 MHz
18: 869.575 MHz
1: 902.5 MHz
Step: 500kHz
51: 927.5 MHz
1:
2:
3:
4:
5:
0 dBm
10 dBm
14 dBm
24 dBm
27 dBm
1: 1.2 kbit/s
2: 4.8 kbit/s
3: 19.0 kbit/s
4: 32.768 kbit/s
5: 76.8 kbit/s
6: NA
7: For future use
1:
2:
3:
4:
5:
0 dBm
10 dBm
14 dBm
24 dBm
27 dBm
1: 1.2 kbit/s
2: 1.2 kbit/s *)
3: 4.8 kbit/s
4: 19.2 kbit/s
5: 32.768 kbit/s
6: 76.8 kbit/s
7: 100kbit/s
8: For future use
RC1190HP-RC232
*) Higher deviation
Channel 1-16 corresponds with the channels in RC1180 (non-HP-version), and channel 13, 17
and 18 are the only channels to be used with 500mW settings in Europe. For channels 1, 6, 7, 12,
Page 10 of 28
Radiocrafts
RC11XXHP-RC232
14 and 16 the maximum RF data rate is 19.2 kbit/s due to limitations in modulation bandwidth at
the given sub band-edge. For channel 17 and 18 the maximum RF data rate is 1.2 kbit/s and +25
dBm output power due to limitations in modulation bandwidth at the 869.4-869.65 MHz bandedges. RF channel and output power level can be set using the configuration commands ‘C’ and
‘P’ respectively. The data rate can only be changed in configuration memory by using the ‘M’
command setting RF_DATA_RATE. The default RF channel and output power level can be set in
the configuration memory by using the ‘M’ command setting RF_CHANNEL and RF_POWER.
The default values are used after power ON and RESET. The default factory settings are shown
in bold in the table above.
For more details on changing the RF channel, output power or data rate, refer to the description
of the configuration commands.
The use of RF frequencies, maximum allowed RF power and duty-cycles are limited by national
regulations. The RC1180HP-RC232 is complying with the applicable directives within the
European Union when used within these limitations. The RC1170HP-RC232 is complying with the
applicable directives in India when used within the local regulations for India.
Multi-channel usage
All modules from Radiocrafts embed a high performance transceiver which can transmit and
receive on one out of several channels. It is clear that other transmitters present on the same
channel at the same time can cause interference (from bit errors until no detection of the wanted
signal) if they have a higher signal level from the non-friendly transmitter than the wanted signal
present at the receiver. To avoid this, configure the radio to use the channel with least
interference. At 868 MHz, radios are allowed to transmit only short bursts before leaving the
channel free for other radios, thus the interference can be expected to be of short duration.
Co-located radios
Precautions have to be taken in a so-called co-location (also named collocation) operation of
transceivers. This means reception and transmission at different channels at the same time with
the intention that the two channels shall be able to operate without disturbing each other.
TX
27 dBm
RX
D
A
Ch.
X
Ch.
Y
Interference
B
C
RX
TX
27 dBm
As indicated in the figure above a module B is receiving a message from A on channel X while
another module C is transmitting at the same time on another channel Y (a message intended
for module D). As any radio device has a limited suppression of signals at any other channel,
Page 11 of 28
Radiocrafts
RC11XXHP-RC232
some power of the signal at the other frequency will enter into the receiver B. Normally, the
suppression increases versus the frequency separation between the two channels. The phrase
“adjacent” means the channel next to while the definition “alternate” means the channel(s) further
apart. The ability of a receiver to reject any out-of-band interferer is named ACR, adjacent
channel rejection.
Friis formula and empirical adaptations of this predicts the path loss between a transmitter and a
receiver. The path loss increases (1/R)n where R is the radius and n is between 2 and 5 and
heavily depending on the surroundings. Knowing the TX output power, the path loss between A-B
decides the amount of power entering the receiver B as well as the path loss between B-C
decides the amount of interferer power entering the same receiver. If we assume there is identical
antenna performance on A and C and they have identical output power it is clear that when the
path loss A-B equals ACR then the interferer C can be placed in immediate proximity of B.
As the path loss increases with from R2 to R5, C has to be moved further and further apart from B
as the distance A-B increases (causing lowered received friendly signal power).
At a distance when the signal power from A reaches the sensitivity level of B, C for all practical
reasons has to be so far from B that simultaneous operation has very limited practical usage.
Useful collocation operation is when we are well above the sensitivity level of B.
Another important parameter for ACR is the selected RF data rate, as this parameter defines the
receiver bandwidth and as such, the rejection of interference at a fixed frequency deviation. As
the regulatory bandwidth for 500mW operation is limited, the channels have to be close in
frequency, and it is not possible to have collocation combined with high data rate. Only data rate
1.2 kbps can be used in a collocated scenario, higher data rates must rely on a time-division
channel usage and then on channel 13 only.
The values for RC1180HP-RC232 are shown below. The RSSI value is read via the embedded
detector and performance is measured with Radiocrafts Demo Boards equipped with quarter
wave whip-antennas and inside an office building.
Conditions: Data rate setting 1.2 kbps with GFSK modulation, operation on various channels and
interferer continuously transmitting on another channel
TX, 27
dBm
Ch. 13
Ch. 17
Ch. 18
Distance to interferer at given reception levels for friendly signal
Channel 17
Channel 18
-60 dBm
-80 dBm
-100 dBm
-60 dBm
-80 dBm
-100 dBm
3m
20-25 m
N/A
3m
20-25 m
N/A
X
X
X
1m
10-12 m
N/A
1m
10-12 m
N/A
X
X
X
General recommendations:
Due to ACR versus channel bandwidth, collocation of equipment is not possible on other RF data
rates than 1.2 kbps. Practical collocation can be done if the signal strength of the friendly channel
is above -80 dBm.
Page 12 of 28
Radiocrafts
RC11XXHP-RC232
RSSI Reading
The module provides a digital Received Signal Strength Indicator (RSSI) through the ‘S’
command, or attached to received messages. The module returns an 8 bit character (one byte)
indicating the current input signal strength (followed immediately by a second character which is
the prompt (‘>’) when in command mode). The signal strength can be used as an indication of
fading margin, or as a carrier sense signal to avoid collisions.
The signal strength measure by the S command is the instantaneous value. The RSSI value
appended to a received message (RSSI_MODE = 1) is the signal strength of that received
packet.
The RSSI value increases with increased input signal strength in 0.5 dB steps. Input signal
strength is given by (typ.):
P = - RSSI / 2 [dBm]
Temperature Reading
The module provides readings of an internal digital temperature monitoring sensor (TEMP)
through the ‘U’ command. The module returns an 8 bit character (one byte) indicating the current
temperature in degrees Celsius (°C) followed immediately by a second character which is the
prompt (‘>’).
The TEMP value increases with increased temperature in 1 °C steps and accuracy of +/- 2 °C.
Temperature is given by:
T = TEMP(dec) - 128 [°C] (example: TEMP=0x98 equals +24 °C)
Power Supply voltage Reading
The module provides readings of an internal power supply voltage monitoring sensor (VCC)
through the ‘V’ command. The module returns an 8 bit character (one byte) indicating the current
power supply voltage level followed immediately by a second character which is the prompt (‘>’).
The command can be useful for battery power monitoring.
The VCC value increases with increased power supply voltage in 30 mV steps. The power supply
voltage is given by:
V = VCC(dec)*0.030 [V] (example: TEMP=0x68 equals 3.12 V)
Page 13 of 28
Radiocrafts
RC11XXHP-RC232
Module Configuration
The configuration of the module can be changed in-circuit from the host during operation, at the
time of installation of the equipment, at the manufacturing test, or even as a standalone module.
The configuration is changed sending commands on the UART interface after the module is set in
configuration mode. The configuration mode is entered by asserting the CONFIG pin (set low).
In command mode the module will respond by sending a ‘>’ prompt on the TXD pin. This
indicates that the module is ready to receive commands. The CONFIG pin can then be deasserted. Note that the CONFIG pin must be de-asserted before the Exit command (‘X’) is sent to
the module in order to return to normal operation.
After a command is executed, the module responds with the ‘>’ prompt character again indicating
it is ready for a new command. Do not send a new command before the ‘>’ prompt is received.
The time required to execute a command can vary depending on the command (see the Timing
Information section). There is no ‘>’ prompt after the ‘X’ exit command.
The parameters that are set by commands directly take immediate effect after returning to normal
operation (IDLE), but will not be stored in non-volatile memory, and will be lost in case the supply
power is turned off or if the module is reset. These parameters are for example the radio channel
and output power.
A list of commands is shown in the table below with typical values for RC1180HP-RC232.
Parameter
Channel
Command Argument in hex (decimal)
‘C’ – 0x43 RC1170HP: 0x01-0x0F(1-15)
RC1180HP: 0x01-0x12(1-18)
RC1190HP: 0x01-0x32(1-51)
Output power
‘P’ – 0x50
0x01-0x05 (1-5)
Signal Strength
(RSSI)
Destination
address
‘S’ – 0x53
Returns one byte indicating
the signal strength
0x00 – 0xFF (0-255)
‘T’ – 0x54
Temperature
‘U’ – 0x55
monitoring
Battery monitoring ‘V’ – 0x56
Memory
configuration
‘M’ – 0x4D
Memory Reset
‘@RC’
the temperature.
the power supply voltage.
(Address, Data): see list of
parameters below.
0xFF exits memory
configuration.
No arguments, but CONFIG
must be asserted low during
this command.
Note
Data is stored in volatile
memory only. For variants not
listed here, refer to the specific
data sheet.
memory only.
memory only.
Note! If ADDRESS_MODE = 8,
the T-command will take 4
address bytes as input. It will
reply with the prompt character
between each byte.
See page 13 for details
Used to enter memory
configuration menu.
Parameters changed are stored
in non-volatile memory.
Resets the configuration
memory back to factory default
values in the whole non-volatile
memory.
Page 14 of 28
Radiocrafts
RC11XXHP-RC232
Parameter
Exit command
‘X’ – 0x58 (none)
Sleep mode
‘Z’ – 0x5A
(none)
Test mode 0
‘0’ – 0x30
(none)
Test mode 1
Test mode 2
‘1’ – 0x31
‘2’ – 0x32
(none)
(none)
Test mode 3
Test Mode 4
‘3’ – 0x33
‘4’ – 0x34
(none)
(none)
Note
Exit to normal operation mode.
All changes of parameters take
effect.
CONFIG pin must be asserted
while in SLEEP mode. Exit
sleep mode by releasing
CONFIG pin.
List all configuration memory
parameters
TX carrier
TX modulated signal
PN9 sequence
TX Off, RX mode
Radio off mode
(RX and TX off)
Note: ASCII characters are written as ‘X’, hexadecimal numbers are written like 0x00, and
decimal numbers are written like 10 throughout the text. A table of ASCII characters and their
respective hex and decimal values are found in the Appendix.
Note: Test mode 2 is used to achieve 100% duty cycle. Can be used for example for certification
tests.
Commands must be sent as ASCII characters or their corresponding binary value. All arguments
must be sent as binary values to the module (not as ASCII representation for hex or decimal).
Any invalid command will be ignored and the ‘>’ prompt will be re-sent. The CONFIG line must be
de-asserted after the first ‘>’ prompt was received, but before the ‘X’ command.
To make permanent changes to default values and other parameters, the Memory Configuration
command ‘M’ is used. This command should be followed by pairs of byte being the memory
address and the new value to be stored at that address. In order to exit the Memory Configuration
mode command ‘X’ must be sent.
Example:
To select RF channel 3, send the follow sequence after asserting the CONFIG line and the ‘>’
prompt is received:
Command
Hex
Response
CONFIG asserted
‘C’
0x43
3
0x03
[A new command could be issued here]
‘X’
0x58
(none)
Comment/Note
De-assert CONFIG after ‘>’ prompt
Wait for ‘>’ prompt
Module returns to IDLE state
It is important to enter Test mode 3 before exiting the configuration mode (‘X’) if Test mode 1 or 2
has been used. This will ensure proper operation in normal mode.
Page 15 of 28
Radiocrafts
RC11XXHP-RC232
Configuration Memory
The table below shows the complete list of configurable parameters stored in non-volatile
memory. These values can be changed using the ‘M’ command. All addresses and arguments
Parameter
Radio configuration
RF_CHANNEL
RF_POWER
Description
Address
hex
Argument
dec
Default RF
channel
0x00
RC1170HP: 1-15 0x04 (4)
RC1180HP: 1-18 0x0D (13)
RC1190HP: 1-50
1-5
0x05 (5)
SLEEP_MODE
Default RF
0x01
output power
Default RF data 0x02
rate
Sleep Mode
0x04
RSSI_MODE
Append RSSI
RF_DATA_RATE
0x05
Radio packet configuration
PACKET_LENGTH_H Max packet
0x0E
length high
byte.
PACKET_LENGTH_L Max packet
0x0F
length low byte.
PACKET_TIMEOUT
PACKET_END_
CHARACTER
Time before
modem timeout and
transmitting the
buffer
0x10
0x11
RC11x0HP: 1-6
0x03 (3)
0: SLEEP pin
disabled
1: reserved
2: SLEEP pin
enabled
0x00 (0)
0-1
0x00 (0)
0x01-0x03
(0-3)
0x00
(0)
0x01-0x80
(1-128)
0x80
(128)
0x00-0xFE
(0-254)
0x00 (0): None
0x01 (1): 32 ms
0x02 (2): 48 ms
0x03 (3): 64 ms
0x7C (124): 2 s
0xF9 (249): 4 s
0x7C
(124)
0x00: Off
0x01-0xFF: On
0x00
Medium access, addressing and network management
ADDRESS_MODE
0x14
0, 2, 8
CRC_MODE
0x15
UNIQUE_ID1 (UID1)
SYSTEM_ID1 (SID1)
UNIQUE_ID2 (UID2)
SYSTEM_ID2 (SID2)
UNIQUE_ID3 (UID3)
0x19
0x1A
0x1B
0x1C
0x1D
Factory
setting
hex (dec)
See table page 10 for
details
details
details
When enabled, the module
will enter sleep mode by
asserting sleep pin low.
Do not use in combination
with enabled UART flow
control.
0: No RSSI append No
1: RSSI append
Packet length > 128 was
introduced in FW rev 1.28.
For older revisions always
use
PACKET_LENGTH_H=0.
If PACKET_LENGHT_H=0
for FW rev 1.28 and newer,
then the packet format is
backward compatible with
FW rev 1.27 and older.
None means packet timeout
is disabled (not 0 s).
Timeout value is
(PACKET_TIMOEOUT x 16
ms) + 0/16 ms min/max
0x02 (2)
0x02 (2)
0-255
0-255
0-255
0-255
0-255
Comment
0x01 (1)
0x01 (1)
0x01 (1)
0x01 (1)
0x01 (1)
0xFE (254) is max, giving
4.080 sec.
Default is 2 s = 0x7C (124)
0: No end character
1-255: Use value as end
character
0: No addressing
2: 1 byte addressing
8: 4 byte addressing (FW
rev 1.28 and newer)
Using addressing adds the
SID and DID bytes to the
radio packet.
0: None
2: CRC16
ADDRESS_MODE=8
UID=UID4:UID3:UID2:UID1
SID=SID4:SID3:SID2:SID1
DID=DID4:DID3:DID2:DID1
Page 16 of 28
Radiocrafts
Parameter
Description
Address
hex
SYSTEM_ID3 (SID3)
0x1E
UNIQUE_ID4 (UID4)
0x1F
SYSTEM_ID4 (SID4)
0x20
DESTINATION_ID1
0x21
(DID1)
DESTINATION_ID2
0x22
(DID2)
DESTINATION_ID3
0x23
(DID3)
DESTINATION_ID4
0x24
(DID4)
BROADCAST_
0x28
ADDRESS
Data and configuration interface, UART Serial Port
UART_BAUD_RATE
Baud rate
0x30
UART_NUMBER_OF
_BITS
UART_PARITY
0x31
UART_STOP_BITS
0x33
0x32
RC11XXHP-RC232
Argument
dec
Factory
setting
hex (dec)
Comment
0-255
0-255
0-255
0-255
0x01 (1)
0x01 (1)
0x01 (1)
0x01 (1)
BID=BID:BID:BID:BID
0-255
0x01 (1)
0-255
0x01 (1)
0-255
0x01 (1)
0-255
0xFF
(255)
0x00: Not used
0x01: 2400
0x02: 4800
0x03: 9600
0x04. 14400
0x05: 19200
0x06: 28800
0x07: 38400
0x08: 56700
0x09: 76800
0x0A: 115200
0x0B: 230400
8: 8 bits
9: 8 bits +1 parity
0: even parity
1: odd parity
1: 1 stop bit
2: 2 stop bits
0x05 (5)
ADDRESS_MODE=2
UID=UID1
SID=SID1
DID=DID1
BID=BID
BE CAREFUL
IFCHANGING AS HOST
MAY LOOSE CONTACT
WITH MODULE!
Does not take effect until
module is re-booted / reset.
0x08 (8)
0x00 (0)
0x01 (1)
BE CAREFUL IF
CHANGING AS HOST
MAY LOOSE CONTACT
WITH MODULE! Parity bit
only an option when
address 0x31=0x09 (9 bits)
UART_FLOW_CTRL
PART_NUMBER
HW_REV_NO
FW_REV_NO
UART flow
control
0x35
0x3C0x49
0x4B0x4E
0x500x53
0: None
1:CTS only
3:CTS/RTS
4:RXTX(RS485)
0x00 (0)
RCxxxxH
P-RC232
x.yz
x.yz
x, y and z; Any number 0d9d
Note: Address locations not listed should not be changed from the default value.
Antenna Connection
The antenna should be connected to the RF pin. The RF pin is matched to 50 Ohm. If the
antenna connector is placed away from the module at the motherboard, the track between the RF
pin and the connector should be a 50 Ohm transmission line.
On a two layer board made of FR4 the width of a microstrip transmission line should be 1.8 times
the thickness of the board, assuming a dielectric constant of 4.8. The line should be run at the top
of the board, and the bottom side should be a ground plane.
Example: For a 1.6 mm thick FR4 board, the width of the trace on the top side should be 1.8 x 1.6
mm = 2.88 mm.
Page 17 of 28
Radiocrafts
RC11XXHP-RC232
The simplest antenna to use is the quarter wave whip antenna. A quarter wave whip antenna
above a ground plane yields 37 Ohm impedance and a matching circuit for 50 Ohm are usually
not required.
A PCB antenna can be made as a copper track where the ground plane is removed on the back
side. The rest of the PCB board should have a ground plane as large as possible, preferably as
large as the antenna itself, to make it act as a counterweight to the antenna. If the track is shorter
than a quarter of a wavelength, the antenna should be matched to 50 ohms.
The lengths of a quarter wave antenna for different operational frequencies are given in the table
below.
Frequency
[MHz]
865-868
902.5-927.5
Length
[cm]
8.2
7.9-7.7
Page 18 of 28
Radiocrafts
RC11XXHP-RC232
PCB Layout Recommendations
The recommended layout pads for the module are shown in the figure below. All dimensions are
in thousands of an inch (mil). The circle in upper left corner is an orientation mark only, and
should not be a part of the copper pattern.
A PCB with two or more layers and with a solid ground plane in one of the inner- or bottom
layer(s) is recommended. All GND-pins of the module shall be connected to this ground plane
with vias with shortest possible routing, one via per GND-pin.
On the back side of the module there are several test pads. These test pads shall not be
connected, and the area underneath the module should be covered with solder resist. If any
routing or vias is required under the module, the routing and vias must be covered with solder
resist to prevent short circuiting of the test pads. It is recommended that vias are tented.
Reserved pins should be soldered to the pads but the pads must be left floating.
Note that Radiocrafts technical support team is available for schematic and layout review of
your design.
Page 19 of 28
Radiocrafts
RC11XXHP-RC232
Mechanical Drawing
Alignment marking: On the top side there are 8 alignment markers which align with the
corresponding pad on the bottom side.
Mechanical Dimensions
The module size is 12.7 x 25.4 x 3.7 mm.
Carrier Tape and Reel Specification
Carrier tape and reel is in accordance with EIA Specification 481.
Tape width
44 mm
Component Hole pitch
pitch
16 mm
4 mm
Reel
diameter
13”
Units per
reel
Max 1000
Page 20 of 28
Radiocrafts
RC11XXHP-RC232
Soldering Profile Recommendation
JEDEC standard IEC/JEDEC J-STD-020B (page 11 and 12), Pb-Free Assembly is
recommended.
The standard requires that the heat dissipated in the “surroundings” on the PCB is taken into
account. The peak temperature should be adjusted so that it is within the window specified in the
standard for the actual motherboard.
Aperture for paste stencil is normally areal-reduced by 20-35%. A nominal stencil thickness of
0.1 – 0.12 mm is recommended. Consult your production facility for best experience aperture
reduction.
Cleaning and welding Recommendation
Ultrasonic processes like ultrasonic cleaning and ultrasonic welding to assemble plastic
enclosures can cause deterioration or destruction of components inside the module. Please avoid
ultrasonic processes on products that include any of the RC11xxHP module variants in the
design.
Page 21 of 28
Radiocrafts
Absolute Maximum Ratings
Parameter
Min
Supply voltage, VCC
-0.3
Voltage on any pin
-0.3
Input RF level
Storage temperature
Operating temperature
-50
-40
RC11XXHP-RC232
Max
3.6
VCC+0.3V
Max 3.6V
10
150
85
Unit
V
V
dBm
C
C
Caution ! ESD sensitive device.
Precaution should be used when
handling the device in order to prevent
permanent damage.
Under no circumstances the absolute maximum ratings given above should be violated. Stress
exceeding one or more of the limiting values may cause permanent damage to the device.
T=25C, VCC = 3.3V if nothing else stated.
Parameter
Min
Operating frequency
RC1170HP
865.0
RC1180HP
868.0
RC1190HP
902
Number of channels
RC1170HP
RC1180HP
RC1190HP
Typ.
Max
Unit
867.0
870.0
928
MHz
Condition / Note
15
18
50
Input/output impedance
Ohm
50
Data rate
1.2
4.8
19.0
32.768
76.8
100
Frequency stability
Frequency stability aging
Transmit power
GFSK deviation
Channel Filter bandwidth
+/-40
1
ppm
ppm/year
dBm
5.2
58
127
540
kHz
kHz
-36
-30
dBm
Spurious emission, TX
< 1 GHz
> 1 GHz
47 – 74 MHz
87.5 – 118 MHz
174 – 230 MHz
470 – 862 MHz
Sensitivity
1.2 kbit/s
4.8 kbit/s
19.0 kbit/s
32.768 kbit/s
76.8 kbit/s
100 kbit/s
Adjacent channel rejection
kbit/s
For RC1170HP only
Including 10 years of aging.
Starting after 10 years
Depends on data rate
-54
-54
-54
-54
Measured at BER 10(-3)
-109
-106
-104
-101
-99
-97
27
dBm
For RC1170HP only
dB
Page 22 of 28
Radiocrafts
Parameter
Alternate channel selectivity
Min
Image channel rejection
Blocking / Interferer rejection /
desensitization
+/- 1 MHz
+/- 2 MHz
+/- 5 MHz
+/- 10 MHz
Saturation
Spurious emission, RX
Supply voltage
Current consumption, RX/IDLE
RC1170HP/1180HP TX
Current consumption, TX
0 dBm
10 dBm
14 dBm
25 dBm
27 dBm
Current consumption, SLEEP
Digital I/O
Input logic level, low
Input logic level, high
Output logic level, low (1µA)
Output logic level, high(-1µA)
RESET pin
UART Baud Rate tolerance
Configuration memory write
cycles
RC11XXHP-RC232
Typ.
36
Max
28
Unit
dB
dB
dB
30
35
50
60
43
49
68
72
-14
-57
3.3
3.0
Wanted signal 3 dB above
sensitivity level, CW
interferer.
Minimum numbers
corresponds to class 2
receiver requirements in
EN300220.
dBm
dBm
V
24
mA
80
530
560
3.4
mA
70 %
TBD
Condition / Note
10.0
uA
30 %
V
Apply over entire supply
voltage range
Of VCC
Of VCC
TBD
VCC
30 %
V
Minimum 250 ns pulse
width
70 %
+/- 2
1000
UART receiver and
transmitter
The guaranteed number of
write cycles using the ‘M’
command is limited
Regulatory Compliance Information
The use of RF frequencies and maximum allowed RF power is limited by national regulations.
The RC1180HP-RC232 has been designed to comply with the RED directive 2014/53/EU.
According to RED directives, it is the responsibility of Radiocrafts’ customers (i.e. RC11XXHPRC232 end user) to check that the host product (i.e. final product) is compliant with RED
essential requirements. The use of a CE marked radio module can avoid re-certification of the
final product, provided that the end user respects the recommendations given by Radiocrafts. A
Declaration of Conformity is available from Radiocrafts on request.
The relevant regulations are subject to change. Radiocrafts AS do not take responsibility for the
validity and accuracy of the understanding of the regulations referred above. Radiocrafts only
guarantee that this product meets the specifications in this document. Radiocrafts is exempt from
any responsibilities related to regulatory compliance.
Page 23 of 28
Radiocrafts
RC11XXHP-RC232
Application circuit
A typical application circuit is shown where a MCU is connected to the Radiocrafts module. In
normal cases the UART (CTS/RTS is optional) and RESET line is connected to a host MCU
running the application. CONFIG pin is needed to set the RC232 modules into configuration
mode. Pin 29/30 are LED drivers and D1/D2 can be mounted (optional) for debugging (State
information).
MCU considerations
Some additional external components is needed depending on MCU output driver properties
If the RESET is driven by a push-pull output, an additional 0 ohm series resistor (R4) shall be inserted
as shown in the figure, to allow an external programmer used for firmware upgrade to assert Reset
low. During firmware upgrade, R4 must in this case be removed.
In noisy surroundings and where RESET is not driven by a push-pull output, it is recommended to add
an external pull-up on RESET using a 5k6 resistor (R3). If the pull-up is stronger the external
programmer used for firmware upgrade will not be able to assert RESET low.
In noisy surroundings and where RXD is not driven by a push-pull output, it is recommended to add an
external pull-up on RXD using a 5k6 resistor (R3).
Page 24 of 28
Radiocrafts
RC11XXHP-RC232
Reset filter
To minimize effect of noise on the Reset-line, the RESET pin on the module (pin 12) must be
connected to an external circuitry via an RC-network. It is recommended to connect RESET to a
microcontroller I/O-pin. The reset filter should be placed as close as possible to the RESET pin of the
module.
Power Supply
Noisy external circuitry may under certain scenarios affect the transmitted signal on RX1180-RC232
and precaution should be taken for EU RED conformity. Example of circuits that can generate noise on
the RC1180-RC232 transmitted spectrum may be DC/DC converters and some level converters like
RS232 and RS485. To increase spectrum margin it is important to add an EMI filter bead (L1) on the
VCC pin of the RC1180-RC232 module. Alternatively, the RC1180-RC232 may be powered
(RC_VCC) from a separate voltage regulator. This will ensure that potential switching noise is filtered
out from the power supply (RC_VCC) to the RC1180-RC232.
Component
EMI filter bead (L1),
1500 mA
Manufacturer
Murata
Part number
Ordering code
BLM18SG331TN1
Programming Interface
For future firmware updates and possible custom variants it is recommended to include a 2x5 pins
programming connector to the module programming pins. The connector should be a 1.27 mm pitch
pin-row (same pitch in both directions), SMD or through-hole version, with the connections shown
below. RXD/TXD lines is not in use for firmware upgrade, but is included on spare pins on the
connector for debugging purposes.
Page 25 of 28
Radiocrafts
RC11XXHP-RC232
Appendix: ASCII Table
HEX
2
3
4
5
6
7
8
9
0A
0B
0C
0D
0E
0F
10
11
12
13
14
15
16
17
18
19
1A
1B
1C
1D
1E
1F
22
23
24
25
26
27
28
29
2A
2B
2C
DEC
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
2D
2E
2F
30
31
32
33
34
35
36
37
38
39
3A
3B
3C
3D
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
3E
3F
CHR
NUL
SOH
STX
ETX
EOT
ENQ
ACK
BEL
BS
HT
LF
VT
FF
CR
SO
SI
DLE
DC1
DC2
DC3
DC4
NAK
SYN
ETB
CAN
EM
SUB
ESC
FS
GS
RS
US
SP
HEX
40
41
42
43
44
45
46
47
48
49
4A
4B
4C
4D
4E
4F
50
51
52
53
54
55
56
57
58
59
5A
5B
5C
5D
5E
5F
60
61
62
63
64
65
66
67
68
69
6A
6B
6C
DEC
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
CHR
A
B
C
D
E
F
G
H
I
J
K
L
M
N
O
P
Q
R
S
T
U
V
W
X
Y
Z
_
a
b
c
d
e
f
g
h
i
j
k
l
2
3
4
5
6
7
8
9
6D
6E
6F
70
71
72
73
74
75
76
77
78
79
7A
7B
7C
7D
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
m
n
o
p
q
r
s
t
u
v
w
x
y
z
62
7E
126
63
7F
127
DEL
CTRL
^A
^B
^C
^D
^E
^F
^G
^H
^I
^J
^K
^L
^M
^N
^O
^P
^Q
^R
^S
^T
^U
^V
^W
^X
^Y
^Z
Page 26 of 28
Radiocrafts
RC11XXHP-RC232
Document Revision History
Document Revision
1.00
1.01
Changes
First Release
Added info about U, V command, corrected text concerning RSSI-readings,
new application circuit drawing
- RTS/SLEEP pin info and configuration added.
- Added channel list for RC1170HP and corrected number of channels
- Max packet length increased to 1024 bytes.
- New address mode option for 4 byte addressing
- UART number of bits and parity option added
-Clarification of data rate and output power limitations for EN300-220-2
V2.4.1 compliance
- improved application circuit (page 22-23)
- L1 filter bead details changed
- CONFIG pin info corrected
- Supply voltage range updated
- Cleaning and welding Recommendation added
- Fixed some typos in the text.
- Updated Mechanical drawing and height information. Please refer to
Hardware PCN for revision history.
- Updated regulatory compliance.
- Updated typo in supply voltage range from version 1.09
- Included information about RF channels, output powers and RF datarate
settings for RC1190HP
- Improved description of T-command
- Clarified modulation format
1.02
1.03
1.04
1.05
1.06
1.07
1.08
1.09
1.10
1.11
Product Status and Definitions
Current
Data Sheet Identification
Status
Product Status
Advance Information
Planned or under
development
Preliminary
Engineering Samples
and First Production
No Identification Noted
Full Production
Obsolete
Not in Production
X
Definition
This data sheet contains the design
specifications for product
development. Specifications may
change in any manner without notice.
This data sheet contains preliminary
data, and supplementary data will be
published at a later date. Radiocrafts
reserves the right to make changes at
any time without notice in order to
improve design and supply the best
possible product.
This data sheet contains final
specifications. Radiocrafts
changes at any time without notice
in order to improve design and
supply the best possible product.
specifications on a product that has
been discontinued by Radiocrafts.
The data sheet is printed for
reference information only.
Page 27 of 28
Radiocrafts
RC11XXHP-RC232
Disclaimer
Radiocrafts AS believes the information contained herein is correct and accurate at the time of this printing. However,
Radiocrafts AS reserves the right to make changes to this product without notice. Radiocrafts AS does not assume any
responsibility for the use of the described product; neither does it convey any license under its patent rights, or the rights
of others. The latest updates are available at the Radiocrafts website or by contacting Radiocrafts directly.
As far as possible, major changes of product specifications and functionality, will be stated in product specific Errata
Notes published at the Radiocrafts website. Customers are encouraged to check regularly for the most recent updates on
products and support tools.
Trademarks
RC232™ is a trademark of Radiocrafts AS. The RC232™ Embedded RF Protocol is used in a range of products from
Radiocrafts. The protocol handles host communication, data buffering, error check, addressing and broadcasting. It
supports point-to-point, point-to-multipoint and peer-to-peer network topologies.
All other trademarks, registered trademarks and product names are the sole property of their respective owners.
Life Support Policy
This Radiocrafts product is not designed for use in life support appliances, devices, or other systems where malfunction
can reasonably be expected to result in significant personal injury to the user, or as a critical component in any life support
device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or
system, or to affect its safety or effectiveness. Radiocrafts AS customers using or selling these products for use in such
applications do so at their own risk and agree to fully indemnify Radiocrafts AS for any damages resulting from any
improper use or sale.
Radiocrafts Technical Support
Knowledge base:
Application notes library:
Whitepapers:
Technology overview:
RF Wireless Expert Training:
https://radiocrafts.com/knowledge-base/
https://radiocrafts.com/resources/application-notes/
https://radiocrafts.com/resources/articles-white-papers/
https://radiocrafts.com/technologies/
https://radiocrafts.com/resources/rf-wireless-expert-training/
Contact Radiocrafts
Sales requests: https://radiocrafts.com/contact/
© 2019, Radiocrafts AS. All rights reserved.
Page 28 of 28
