RC1180-MPC1
RC1180-MPC1
    RADIOCRAFTS
    Module
    WIRELESS M-BUS 868
RC1180-MPC1 数据手册
Radiocrafts Embedded Wireless Solutions RC1xxx-MPC1 Wireless M-Bus RF Transceiver Module (EN 13757-4:2013) with Pulse Counter inputs Product Description The MPC1 Wireless M-Bus module is a stand-alone Wireless M-Bus module with Pulse counter, Tamper and Install inputs. The module communicates with the Radiocrafts MBUS3/MBUS4 modules and automatically at configurable intervals, transmit EN137574:2013 packets containing pulse counter values. The MPC1 module automatically wakes up from sleep, detects and counts pulses from the two pulse inputs. The module also support Over The Air (OTA) configuration for easy configuration of a stand-alone module not having a host controller connected to the UART. Applications  Water, gas, electricity meters with pulse output Features  2 pulse inputs with programmable pull-up.  Tamper input  Install input  OTA (Over The Air configuration)  Encryption  Configurable TX intervals  Embedded Wireless M-Bus protocol supporting EN EN13757-4:2013 mode T (868 MHz, -MBUS3) and mode N (169 MHz, -MBUS4)  12.7 x 25.4 x 3.3 mm compact module for SMD mounting  Ultra low power modes for extended battery lifetime  Completely Shielded module for SMD mounting  No external components Quick module overview The MPC1 protocol is running in same module as RC1180-MBUS3 for 868 MHz and RC1701HP-MBUS4 for 169 MHz. For hardware and RF performance details please see RC1701HP-MBUS4/RC1180-MBUS3 data sheet. Module RC1180-MPC1 RC1701HP-MPC1 RC1701-MPC1 Frequency band 868 MHz 169 MHz 169 MHz Max output Power +10 dBm +27 dBm +14 dBm MPC1 Embedded Protocol The MPC1 protocol is described in details in the MPC1 User Manual. 2015 Radiocrafts AS RC1xxx-MPC1 Shortform Datasheet (rev. 1.0) Page 1 of 3 Radiocrafts Embedded Wireless Solutions RC1xxx-MPC1 Pin Assignment Pin 31-42 is not available for RC1180-MPC1. Pin Description Pin no 1 2 3 4 5 6 7 8 9 10 11 12 13 14 17 18 27 28 29 30 41 15-16 19-26 31-40 42 Pin name GND CTS RTS CONFIG TXD RXD GND GND RF GND VDD Reset VCC GND INSTALL TAMPER PULSE1 PULSE2 STATUS LED1 STATUS LED0 VCC_PA I/O I/O I/O I/O 2015 Radiocrafts AS Description System ground UART Clear to Send / RXTX control (RS485) UART Request to Send Configuration Enable. Active low. UART TX Data UART RX Data System ground System ground RF I/O connection to antenna System ground Not Connected, Internal Regulator Output RESET_N. Active Low Supply voltage input. Internally regulated. System ground Pull to ground to start installation message transmission Tamper input Interrupt pulse counter Interrupt pulse counter LED output for status LED output for status Supply voltage for high power variant (RC1701HP-MPC1). For future use and test status pin, Do not connect For future use and test status pin, Do not connect For future use and test status pin, Do not connect For future use and test status pin, Do not connect RC1xxx-MPC1 Shortform Datasheet (rev. 1.0) Page 2 of 3 Radiocrafts Embedded Wireless Solutions RC1xxx-MPC1 Mechanical Drawing Mechanical Dimensions The module size is 12.7 x 25.4 x 3.3 mm © 2015 Radiocrafts AS. All rights reserved. Radiocrafts AS, Sandakerveien 64, NO-0484 OSLO, NORWAY E-mail: sales@radiocrafts.com Web site: www.radiocrafts.com Phone: (+47) 4000 5195 Fax: (+47) 22 71 29 15 2015 Radiocrafts AS RC1xxx-MPC1 Shortform Datasheet (rev. 1.0) Page 3 of 3
RC1180-MPC1 价格&库存
很抱歉,暂时无法提供与“RC1180-MPC1”相匹配的价格&库存,您可以联系我们找货
