ESP32-S3-WROOM-1U-N8R8
    ESPRESSIF(乐鑫)
    MODULE_18X19.2MM_SM
    WiFi及蓝牙模块置 ESP32-S3 Xtensa® 双核 32 位 LX7 微处理器 ROM:384KB SRAM:512KB RTC SRAM:16KB
ESP32-S3-WROOM-1U-N8R8 数据手册
ESP32­S3­WROOM­1 ESP32­S3­WROOM­1U Datasheet 2.4 GHz Wi­Fi (802.11 b/g/n) and Bluetooth® 5 (LE) module Built around ESP32­S3 series of SoCs, Xtensa® dual­core 32­bit LX7 microprocessor Flash up to 16 MB, PSRAM up to 8 MB 36 GPIOs, rich set of peripherals On­board PCB antenna ESP32­S3­WROOM­1 ESP32­S3­WROOM­1U Version 1.1 Espressif Systems Copyright © 2022 www.espressif.com 1 Module Overview 1 Module Overview Note: Check the link or the QR code to make sure that you use the latest version of this document: https://www.espressif.com/documentation/esp32-s3-wroom-1_wroom-1u_datasheet_en.pdf 1.1 Features LED PWM, USB 1.1 OTG, USB Serial/JTAG CPU and On­Chip Memory controller, MCPWM, SDIO host, GDMA, TWAI® • ESP32-S3 series of SoCs embedded, Xtensa® controller (compatible with ISO 11898-1), ADC, dual-core 32-bit LX7 microprocessor, up to 240 touch sensor, temperature sensor, timers and MHz watchdogs • 384 KB ROM Integrated Components on Module • 512 KB SRAM • 16 KB SRAM in RTC • 40 MHz crystal oscillator • Up to 8 MB PSRAM • Up to 16 MB Quad SPI flash Wi­Fi Antenna Options • On-board PCB antenna (ESP32-S3-WROOM-1) • 802.11 b/g/n • External antenna via a connector • Bit rate: 802.11n up to 150 Mbps (ESP32-S3-WROOM-1U) • A-MPDU and A-MSDU aggregation Operating Conditions • 0.4 µs guard interval support • Operating voltage/Power supply: 3.0 ~ 3.6 V • Center frequency range of operating channel: 2412 ~ 2484 MHz • Operating ambient temperature: – 65 °C version: –40 ~ 65 °C Bluetooth • Bluetooth LE: Bluetooth 5, Bluetooth mesh – 85 °C version: –40 ~ 85 °C • Speed: 125 Kbps, 500 Kbps, 1 Mbps, 2 Mbps – 105 °C version: –40 ~ 105 °C • Advertising extensions Certification • Multiple advertisement sets • RF certification: See certificates for • Channel selection algorithm #2 ESP32-S3-WROOM-1 and • Internal co-existence mechanism between Wi-Fi ESP32-S3-WROOM-1U and Bluetooth to share the same antenna • Green certification: RoHS/REACH Peripherals Test • GPIO, SPI, LCD interface, Camera interface, • HTOL/HTSL/uHAST/TCT/ESD UART, I2C, I2S, remote control, pulse counter, Espressif Systems 2 ESP32-S3-WROOM-1 & WROOM-1U Datasheet v1.1 Submit Documentation Feedback 1 Module Overview 1.2 Description ESP32-S3-WROOM-1 and ESP32-S3-WROOM-1U are two powerful, generic Wi-Fi + Bluetooth LE MCU modules that are built around the ESP32-S3 series of SoCs. On top of a rich set of peripherals, the acceleration for neural network computing and signal processing workloads provided by the SoC make the modules an ideal choice for a wide variety of application scenarios related to AI and Artificial Intelligence of Things (AIoT), such as wake word detection, speech commands recognition, face detection and recognition, smart home, smart appliances, smart control panel, smart speaker, etc. ESP32-S3-WROOM-1 comes with a PCB antenna. ESP32-S3-WROOM-1U comes with an external antenna connector. A wide selection of module variants are available for customers as shown in Table 1 and 2. Among the module variants, those embed ESP32-S3R8 operate at –40 ~ 65 °C ambient temperature, ESP32-S3-WROOM-1-H4 and ESP32-S3-WROOM-1U-H4 operate at –40 ~ 105 °C ambient temperature, and other module variants operate at –40 ~ 85 °C ambient temperature. Please note that for R8 series modules (8-line PSRAM embedded), if the PSRAM ECC function is enabled, the maximum ambient temperature can be improved to 85 °C, while the usable size of PSRAM will be reduced by 1/16. Table 1: ESP32­S3­WROOM­1 Series Comparison1 Ambient Temp.3 Size4 (°C) (mm) Flash2 PSRAM ESP32-S3-WROOM-1-N4 4 MB (Quad SPI) - –40 ~ 85 ESP32-S3-WROOM-1-N8 8 MB (Quad SPI) - –40 ~ 85 ESP32-S3-WROOM-1-N16 16 MB (Quad SPI) - –40 ~ 85 ESP32-S3-WROOM-1-H4 4 MB (Quad SPI) - –40 ~ 105 ESP32-S3-WROOM-1-N4R2 4 MB (Quad SPI) 2 MB (Quad SPI) –40 ~ 85 ESP32-S3-WROOM-1-N8R2 8 MB (Quad SPI) 2 MB (Quad SPI) –40 ~ 85 ESP32-S3-WROOM-1-N16R2 16 MB (Quad SPI) 2 MB (Quad SPI) –40 ~ 85 ESP32-S3-WROOM-1-N4R8 4 MB (Quad SPI) 8 MB (Octal SPI) –40 ~ 65 ESP32-S3-WROOM-1-N8R8 8 MB (Quad SPI) 8 MB (Octal SPI) –40 ~ 65 ESP32-S3-WROOM-1-N16R8 16 MB (Quad SPI) 8 MB (Octal SPI) –40 ~ 65 Ordering Code 1 18.0 x 25.5 x 3.1 This table shares the same notes presented in Table 2 below. Table 2: ESP32­S3­WROOM­1U Series Comparison Ambient Temp.3 Size4 (°C) (mm) Flash2 PSRAM ESP32-S3-WROOM-1U-N4 4 MB (Quad SPI) - –40 ~ 85 ESP32-S3-WROOM-1U-N8 8 MB (Quad SPI) - –40 ~ 85 ESP32-S3-WROOM-1U-N16 16 MB (Quad SPI) - –40 ~ 85 ESP32-S3-WROOM-1U-H4 4 MB (Quad SPI) - –40 ~ 105 ESP32-S3-WROOM-1U-N4R2 4 MB (Quad SPI) 2 MB (Quad SPI) –40 ~ 85 ESP32-S3-WROOM-1U-N8R2 8 MB (Quad SPI) 2 MB (Quad SPI) –40 ~ 85 ESP32-S3-WROOM-1U-N16R2 16 MB (Quad SPI) 2 MB (Quad SPI) –40 ~ 85 ESP32-S3-WROOM-1U-N4R8 4 MB (Quad SPI) 8 MB (Octal SPI) –40 ~ 65 ESP32-S3-WROOM-1U-N8R8 8 MB (Quad SPI) 8 MB (Octal SPI) –40 ~ 65 ESP32-S3-WROOM-1U-N16R8 16 MB (Quad SPI) 8 MB (Octal SPI) –40 ~ 65 Ordering Code Espressif Systems 3 18.0 x 19.2 x 3.2 ESP32-S3-WROOM-1 & WROOM-1U Datasheet v1.1 Submit Documentation Feedback 1 Module Overview 2 The modules use flash integrated in the chip’s package. 3 Ambient temperature specifies the recommended temperature range of the environment immediately outside the Espressif module. 4 For details, refer to Section 7.1 Physical Dimensions. At the core of the modules is an ESP32-S3 series of SoC *, an Xtensa® 32-bit LX7 CPU that operates at up to 240 MHz. You can power off the CPU and make use of the low-power co-processor to constantly monitor the peripherals for changes or crossing of thresholds. ESP32-S3 integrates a rich set of peripherals including SPI, LCD, Camera interface, UART, I2C, I2S, remote control, pulse counter, LED PWM, USB Serial/JTAG controller, MCPWM, SDIO host, GDMA, TWAI® controller (compatible with ISO 11898-1), ADC, touch sensor, temperature sensor, timers and watchdogs, as well as up to 45 GPIOs. It also includes a full-speed USB 1.1 On-The-Go (OTG) interface to enable USB communication. Note: * For more information on ESP32-S3 series of SoCs, please refer to ESP32-S3 Series Datasheet. Espressif Systems 4 ESP32-S3-WROOM-1 & WROOM-1U Datasheet v1.1 Submit Documentation Feedback 1 Module Overview 1.3 Applications • Generic Low-power IoT Sensor Hub • Smart Building • Generic Low-power IoT Data Loggers • Industrial Automation • Cameras for Video Streaming • Smart Agriculture • Over-the-top (OTT) Devices • Audio Applications • USB Devices • Health Care Applications • Speech Recognition • Wi-Fi-enabled Toys • Image Recognition • Mesh Network • Wearable Electronics • Home Automation • Retail & Catering Applications Espressif Systems 5 ESP32-S3-WROOM-1 & WROOM-1U Datasheet v1.1 Submit Documentation Feedback Contents Contents 1 Module Overview 2 1.1 Features 2 1.2 Description 3 1.3 Applications 5 2 Block Diagram 8 3 Pin Definitions 9 3.1 Pin Layout 9 3.2 Pin Description 10 3.3 Strapping Pins 11 4 Electrical Characteristics 14 4.1 Absolute Maximum Ratings 14 4.2 Recommended Operating Conditions 14 4.3 DC Characteristics (3.3 V, 25 °C) 14 4.4 Current Consumption Characteristics 15 4.5 Wi-Fi RF Characteristics 15 4.5.1 Wi-Fi RF Standards 16 4.5.2 Wi-Fi RF Transmitter (TX) Specifications 16 4.5.3 Wi-Fi RF Receiver (RX) Specifications 17 4.6 Bluetooth LE Radio 18 4.6.1 Bluetooth LE RF Transmitter (TX) Specifications 18 4.6.2 Bluetooth LE RF Receiver (RX) Specifications 20 5 Module Schematics 23 6 Peripheral Schematics 25 7 Physical Dimensions and PCB Land Pattern 26 7.1 Physical Dimensions 26 7.2 Recommended PCB Land Pattern 27 7.3 Dimensions of External Antenna Connector 29 8 Product Handling 30 8.1 Storage Conditions 30 8.2 Electrostatic Discharge (ESD) 30 8.3 Reflow Profile 30 8.4 Ultrasonic Vibration 31 9 Related Documentation and Resources 32 Revision History Espressif Systems 33 6 ESP32-S3-WROOM-1 & WROOM-1U Datasheet v1.1 Submit Documentation Feedback List of Tables and Figures List of Tables 1 ESP32-S3-WROOM-1 Series Comparison 3 2 ESP32-S3-WROOM-1U Series Comparison 3 3 Pin Definitions 10 4 JTAG Signal Source Selection 12 5 Strapping Pins 12 6 The Default Value for VDD_SPI Voltage 13 7 Parameter Descriptions of Setup and Hold Times for the Strapping Pin 13 8 Absolute Maximum Ratings 14 9 Recommended Operating Conditions 14 10 DC Characteristics (3.3 V, 25 °C) 14 11 Current Consumption Depending on RF Modes 15 12 Current Consumption Depending on Work Modes 15 13 Wi-Fi RF Standards 16 14 TX Power with Spectral Mask and EVM Meeting 802.11 Standards 16 15 TX EVM Test 16 16 RX Sensitivity 17 17 Maximum RX Level 18 18 RX Adjacent Channel Rejection 18 19 Bluetooth LE Frequency 18 20 Transmitter Characteristics - Bluetooth LE 1 Mbps 18 21 Transmitter Characteristics - Bluetooth LE 2 Mbps 19 22 Transmitter Characteristics - Bluetooth LE 125 Kbps 19 23 Transmitter Characteristics - Bluetooth LE 500 Kbps 20 24 Receiver Characteristics - Bluetooth LE 1 Mbps 20 25 Receiver Characteristics - Bluetooth LE 2 Mbps 21 26 Receiver Characteristics - Bluetooth LE 125 Kbps 21 27 Receiver Characteristics - Bluetooth LE 500 Kbps 22 List of Figures 1 ESP32-S3-WROOM-1 Block Diagram 8 2 ESP32-S3-WROOM-1U Block Diagram 8 3 Pin Layout (Top View) 9 4 Setup and Hold Times for the Strapping Pin 13 5 ESP32-S3-WROOM-1 Schematics 23 6 ESP32-S3-WROOM-1U Schematics 24 7 Peripheral Schematics 25 8 ESP32-S3-WROOM-1 Physical Dimensions 26 9 ESP32-S3-WROOM-1U Physical Dimensions 26 10 ESP32-S3-WROOM-1 Recommended PCB Land Pattern 27 11 ESP32-S3-WROOM-1U Recommended PCB Land Pattern 28 12 Dimensions of External Antenna Connector 29 13 Reflow Profile 30 Espressif Systems 7 ESP32-S3-WROOM-1 & WROOM-1U Datasheet v1.1 Submit Documentation Feedback 2 Block Diagram 2 Block Diagram ESP32-S3-WROOM-1 40 MHz Crystal 3V3 Antenna ESP32-S3 ESP32-S3R2 ESP32-S3R8 EN RF Matching GPIOs SPICS0 SPICLK SPID SPIQ SPIHD SPIWP VDD_SPI PSRAM(opt.) (QSPI/OSPI) QSPI Flash Figure 1: ESP32­S3­WROOM­1 Block Diagram ESP32-S3-WROOM-1U 40 MHz Crystal 3V3 EN Antenna ESP32-S3 ESP32-S3R2 ESP32-S3R8 RF Matching GPIOs SPICS0 SPICLK SPID SPIQ SPIHD SPIWP VDD_SPI PSRAM(opt.) (QSPI/OSPI) QSPI Flash Figure 2: ESP32­S3­WROOM­1U Block Diagram Espressif Systems 8 ESP32-S3-WROOM-1 & WROOM-1U Datasheet v1.1 Submit Documentation Feedback 3 Pin Definitions 3 Pin Definitions 3.1 Pin Layout The pin diagram below shows the approximate location of pins on the module. For the actual diagram drawn to scale, please refer to Figure 7.1 Physical Dimensions. The pin diagram is applicable for ESP32-S3-WROOM-1 and ESP32-S3-WROOM-1U, but the latter has no keepout zone. Keepout Zone GND 35 IO42 IO7 7 GND 41 GND GND 34 IO41 IO15 8 GND GND GND 33 IO40 IO16 9 32 IO39 IO17 10 31 IO38 IO18 11 30 IO37 IO8 12 29 IO36 IO19 13 28 IO35 IO20 14 27 IO0 26 GND IO45 GND 25 6 IO48 IO6 24 RXD0 IO47 36 23 5 IO21 IO5 22 TXD0 IO14 37 21 4 IO13 IO4 20 IO2 IO12 38 19 3 IO11 EN 18 IO1 IO10 39 17 2 IO9 3V3 16 GND IO46 40 15 1 IO3 GND Figure 3: Pin Layout (Top View) Espressif Systems 9 ESP32-S3-WROOM-1 & WROOM-1U Datasheet v1.1 Submit Documentation Feedback 3 Pin Definitions 3.2 Pin Description The module has 41 pins. See pin definitions in Table 3. For explanations of pin names and function names, as well as configurations of peripheral pins, please refer to ESP32-S3 Series Datasheet. Table 3: Pin Definitions Type a Function Name No. GND 1 P GND 3V3 2 P Power supply High: on, enables the chip. EN 3 I Low: off, the chip powers off. Note: Do not leave the EN pin floating. IO4 4 I/O/T RTC_GPIO4, GPIO4, TOUCH4, ADC1_CH3 IO5 5 I/O/T RTC_GPIO5, GPIO5, TOUCH5, ADC1_CH4 IO6 6 I/O/T RTC_GPIO6, GPIO6, TOUCH6, ADC1_CH5 IO7 7 I/O/T RTC_GPIO7, GPIO7, TOUCH7, ADC1_CH6 IO15 8 I/O/T RTC_GPIO15, GPIO15, U0RTS, ADC2_CH4, XTAL_32K_P IO16 9 I/O/T RTC_GPIO16, GPIO16, U0CTS, ADC2_CH5, XTAL_32K_N IO17 10 I/O/T RTC_GPIO17, GPIO17, U1TXD, ADC2_CH6 IO18 11 I/O/T RTC_GPIO18, GPIO18, U1RXD, ADC2_CH7, CLK_OUT3 IO8 12 I/O/T RTC_GPIO8, GPIO8, TOUCH8, ADC1_CH7, SUBSPICS1 IO19 13 I/O/T RTC_GPIO19, GPIO19, U1RTS, ADC2_CH8, CLK_OUT2, USB_D­ IO20 14 I/O/T RTC_GPIO20, GPIO20, U1CTS, ADC2_CH9, CLK_OUT1, USB_D+ IO3 15 I/O/T RTC_GPIO3, GPIO3, TOUCH3, ADC1_CH2 IO46 16 I/O/T GPIO46 IO9 17 I/O/T RTC_GPIO9, GPIO9, TOUCH9, ADC1_CH8, FSPIHD, SUBSPIHD IO10 18 I/O/T IO11 19 I/O/T IO12 20 I/O/T IO13 21 I/O/T IO14 22 I/O/T IO21 23 I/O/T RTC_GPIO21, GPIO21 IO47 24 I/O/T SPICLK_P_DIFF,GPIO47, SUBSPICLK_P_DIFF IO48 25 I/O/T SPICLK_N_DIFF,GPIO48, SUBSPICLK_N_DIFF IO45 26 I/O/T GPIO45 RTC_GPIO10, GPIO10, TOUCH10, ADC1_CH9, FSPICS0, FSPIIO4, SUBSPICS0 RTC_GPIO11, GPIO11, TOUCH11, ADC2_CH0, FSPID, FSPIIO5, SUBSPID RTC_GPIO12, GPIO12, TOUCH12, ADC2_CH1, FSPICLK, FSPIIO6, SUBSPICLK RTC_GPIO13, GPIO13, TOUCH13, ADC2_CH2, FSPIQ, FSPIIO7, SUBSPIQ RTC_GPIO14, GPIO14, TOUCH14, ADC2_CH3, FSPIWP, FSPIDQS, SUBSPIWP 27 I/O/T RTC_GPIO0, GPIO0 IO35 b 28 I/O/T SPIIO6, GPIO35, FSPID, SUBSPID IO36 b 29 I/O/T SPIIO7, GPIO36, FSPICLK, SUBSPICLK IO0 Cont’d on next page Espressif Systems 10 ESP32-S3-WROOM-1 & WROOM-1U Datasheet v1.1 Submit Documentation Feedback 3 Pin Definitions Table 3 – cont’d from previous page Name a No. Type 30 I/O/T SPIDQS, GPIO37, FSPIQ, SUBSPIQ IO38 31 I/O/T GPIO38, FSPIWP, SUBSPIWP IO39 32 I/O/T MTCK, GPIO39, CLK_OUT3, SUBSPICS1 IO40 33 I/O/T MTDO, GPIO40, CLK_OUT2 IO41 34 I/O/T MTDI, GPIO41, CLK_OUT1 IO42 35 I/O/T MTMS, GPIO42 RXD0 36 I/O/T U0RXD, GPIO44, CLK_OUT2 TXD0 37 I/O/T U0TXD, GPIO43, CLK_OUT1 IO2 38 I/O/T RTC_GPIO2, GPIO2, TOUCH2, ADC1_CH1 IO1 39 I/O/T RTC_GPIO1, GPIO1, TOUCH1, ADC1_CH0 GND 40 P GND EPAD 41 P GND IO37 a b Function P: power supply; I: input; O: output; T: high impedance. Pin functions in bold font are the default pin functions. For pin 28 ∼ 30, the default function is decided by eFuse bit. b In module variants that have embedded OSPI PSRAM, i.e., that embed ESP32-S3R8, pins IO35, IO36, and IO37 connect to the OSPI PSRAM and are not available for other uses. 3.3 Strapping Pins Note: The content below is excerpted from Section Strapping Pins in ESP32-S3 Series Datasheet. For the strapping pin mapping between the chip and modules, please refer to Chapter 5 Module Schematics. ESP32-S3 has four strapping pins: • GPIO0 • GPIO45 • GPIO46 • GPIO3 Software can read the values of corresponding bits from register “GPIO_STRAPPING”. During the chip’s system reset (power-on-reset, RTC watchdog reset, brownout reset, analog super watchdog reset, and crystal clock glitch detection reset), the latches of the strapping pins sample the voltage level as strapping bits of “0” or “1”, and hold these bits until the chip is powered down or shut down. GPIO0, GPIO45 and GPIO46 are connected to the chip’s internal weak pull-up/pull-down during the chip reset. Consequently, if they are unconnected or the connected external circuit is high-impedance, the internal weak pull-up/pull-down will determine the default input level of these strapping pins. GPIO3 is floating by default. Its strapping value can be configured to determine the source of the JTAG signal inside the CPU, as shown in Table 5. In this case, the strapping value is controlled by the external circuit that cannot be in a high impedance state. Table 4 shows more configuration combinations of EFUSE_DIS_USB_JTAG, EFUSE_DIS_PAD_JTAG, and EFUSE_STRAP_JTAG_SEL that determine the JTAG signal source. Espressif Systems 11 ESP32-S3-WROOM-1 & WROOM-1U Datasheet v1.1 Submit Documentation Feedback 3 Pin Definitions Table 4: JTAG Signal Source Selection EFUSE_STRAP_JTAG_SEL EFUSE_DIS_USB_JTAG EFUSE_DIS_PAD_JTAG JTAG Signal Source 1 0 0 Refer to Table 5 0 0 0 USB Serial/JTAG controller don’t care 0 1 USB Serial/JTAG controller don’t care 1 0 On-chip JTAG pins don’t care 1 1 N/A To change the strapping bit values, users can apply the external pull-down/pull-up resistances, or use the host MCU’s GPIOs to control the voltage level of these pins when powering on ESP32-S3. After reset, the strapping pins work as normal-function pins. Refer to Table 5 for a detailed configuration of the strapping pins. Table 5: Strapping Pins VDD_SPI Voltage Pin Default 3.3 V GPIO45 Pull-down 0 1.8 V 1 Booting Mode 1 Pin Default SPI Boot Download Boot GPIO0 Pull-up 1 0 GPIO46 Pull-down Don’t care 0 Enabling/Disabling ROM Messages Print During Booting 2 Pin Default Enabled Disabled GPIO46 Pull-down See the 2nd note See the 2nd note JTAG Signal Selection Pin Default GPIO3 N/A EFUSE_DIS_USB_JTAG = 0, EFUSE_DIS_PAD_JTAG = 0, EFUSE_STRAP_JTAG_SEL=1 0: JTAG signal from on-chip JTAG pins 1: JTAG signal from USB Serial/JTAG controller Note: 1. The strapping combination of GPIO46 = 1 and GPIO0 = 0 is invalid and will trigger unexpected behavior. 2. By default, the ROM boot messages are printed over UART0 (U0TXD pin) and USB Serial/JTAG controller together. The ROM code printing can be disabled through configuration register and eFuse. For detailed information, please refer to Chapter Chip Boot Control in ESP32-S3 Technical Reference Manual. VDD_SPI voltage is determined either by the strapping value of GPIO45 or by EFUSE_VDD_SPI_TIEH. When EFUSE_VDD_SPI_FORCE is 0, VDD_SPI voltage is determined by the strapping value of GPIO45; when EFUSE_VDD_SPI_FORCE is 1, VDD_SPI voltage is determined by EFUSE_VDD_SPI_TIEH. Please refer to the following table for default configurations: Espressif Systems 12 ESP32-S3-WROOM-1 & WROOM-1U Datasheet v1.1 Submit Documentation Feedback 3 Pin Definitions Table 6: The Default Value for VDD_SPI Voltage Chip Variant EFUSE_VDD_SPI_FORCE EFUSE_VDD_SPI_TIEH VDD_SPI Voltage ESP32-S3 0 0 Determined by GPIO45 ESP32-S3R2 1 1 Force to 3.3 V ESP32-S3R8 1 1 Force to 3.3 V ESP32-S3R8V 1 0 Force to 1.8 V ESP32-S3FN8 1 1 Force to 3.3 V ESP32-S3FH4R2 1 1 Force to 3.3 V Figure 4 shows the setup and hold times for the strapping pin before and after the CHIP_PU signal goes high. Details about the parameters are listed in Table 7. tSU CHIP_PU tHD VIL_nRST VIH Strapping pin Figure 4: Setup and Hold Times for the Strapping Pin Table 7: Parameter Descriptions of Setup and Hold Times for the Strapping Pin Parameter Description tSU Setup time before CHIP_PU goes from low to high 0 tHD Hold time after CHIP_PU goes high 3 Espressif Systems Min (ms) 13 ESP32-S3-WROOM-1 & WROOM-1U Datasheet v1.1 Submit Documentation Feedback 4 Electrical Characteristics 4 Electrical Characteristics 4.1 Absolute Maximum Ratings Stresses above those listed in Absolute Maximum Ratings may cause permanent damage to the device. These are stress ratings only and functional operation of the device at these or any other conditions beyond those indicated under Recommended Operating Conditions is not implied. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability. Table 8: Absolute Maximum Ratings Symbol Parameter Min Max Unit VDD33 Power supply voltage –0.3 3.6 V TST ORE Storage temperature –40 105 °C 4.2 Recommended Operating Conditions Table 9: Recommended Operating Conditions Symbol Parameter Min Typ Max VDD33 IV DD Power supply voltage 3.0 3.3 3.6 V Current delivered by external power supply 0.5 — — A 65 °C version TA Operating ambient temperature Unit 65 85 °C version –40 — 105 °C version 85 °C 105 4.3 DC Characteristics (3.3 V, 25 °C) Table 10: DC Characteristics (3.3 V, 25 °C) Symbol Parameter CIN Pin capacitance VIH Min — High-level input voltage 0.75 × VDD 1 Typ Max Unit 2 — pF — 1 VDD + 0.3 V 1 VIL Low-level input voltage –0.3 — 0.25 × VDD IIH High-level input current — — 50 nA Low-level input current — — 50 nA — — IIL VOH VOL 2 2 High-level output voltage 0.8 × VDD Low-level output voltage 1 V V 1 — — 0.1 × VDD V — 40 — mA — 28 — mA 1 IOH IOL High-level source current (VDD = 3.3 V, VOH >= 2.64 V, PAD_DRIVER = 3) Low-level sink current (VDD1 = 3.3 V, VOL = 0.495 V, PAD_DRIVER = 3) RP U Internal weak pull-up resistor — 45 — kΩ RP D Internal weak pull-down resistor — 45 — kΩ Cont’d on next page Espressif Systems 14 ESP32-S3-WROOM-1 & WROOM-1U Datasheet v1.1 Submit Documentation Feedback 4 Electrical Characteristics Table 10 – cont’d from previous page Symbol VIH_nRST VIL_nRST Parameter Chip reset release voltage (EN voltage is within the specified range) Min Typ Max Unit 0.75 × VDD1 — VDD1+ 0.3 V –0.3 — 0.25 × VDD1 V Chip reset voltage (EN voltage is within the specified range) 1 VDD is the I/O voltage for pins of a particular power domain. 2 VOH and VOL are measured using high-impedance load. 4.4 Current Consumption Characteristics With the use of advanced power-management technologies, the module can switch between different power modes. For details on different power modes, please refer to Section Low Power Management in ESP32-S3 Series Datasheet. Table 11: Current Consumption Depending on RF Modes Work mode Description TX Active (RF working) RX 1 Peak (mA) 802.11b, 1 Mbps, @20.5 dBm 355 802.11g, 54 Mbps, @18 dBm 297 802.11n, HT20, MCS 7, @17.5 dBm 286 802.11n, HT40, MCS 7, @17 dBm 285 802.11b/g/n, HT20 95 802.11n, HT40 97 The current consumption measurements are taken with a 3.3 V supply at 25 °C of ambient temperature at the RF port. All transmitters’ measurements are based on a 100% duty cycle. 2 The current consumption figures for in RX mode are for cases when the peripherals are disabled and the CPU idle. Note that the data in Table 12 only applies to the module variants that embed the chip variant ESP32-S3. Table 12: Current Consumption Depending on Work Modes Work mode Light-sleep Deep-sleep Power off 1 Typ2 Description — — 1 Unit µA RTC memory and RTC peripherals are powered on. 8 µA RTC memory is powered on. RTC peripherals are powered off. 7 µA CHIP_PU is set to low level. The chip is powered off. 1 µA Please refer to the current consumption of the chip, and add corresponding PSRAM consumption values, e.g., 140 µA for 8 MB 8-line PSRAM (3.3 V), 200 µA for 8 MB 8-line PSRAM (1.8 V) and 40 µA for 2 MB 4-line PSRAM (3.3 V). 2 Please refer to ESP32-S3 Series Datasheet if there are any inconsistencies. 4.5 Wi­Fi RF Characteristics Espressif Systems 15 ESP32-S3-WROOM-1 & WROOM-1U Datasheet v1.1 Submit Documentation Feedback 4 Electrical Characteristics 4.5.1 Wi­Fi RF Standards Table 13: Wi­Fi RF Standards Name Description Center frequency range of operating channel 1 2412 ~ 2484 MHz Wi-Fi wireless standard IEEE 802.11b/g/n 11b: 1, 2, 5.5 and 11 Mbps 20 MHz Data rate 11n: MCS0-7, 72.2 Mbps (Max) 40 MHz 11n: MCS0-7, 150 Mbps (Max) PCB antenna, external antenna via the connector 2 Antenna type 1 11g: 6, 9, 12, 18, 24, 36, 48, 54 Mbps Device should operate in the center frequency range allocated by regional regulatory authorities. Target center frequency range is configurable by software. 2 For the modules that use external antennas, the output impedance is 50 Ω. For other modules without external antennas, the output impedance is irrelevant. 4.5.2 Wi­Fi RF Transmitter (TX) Specifications Target TX power is configurable based on device or certification requirements. The default characteristics are provided in Table 14. Table 14: TX Power with Spectral Mask and EVM Meeting 802.11 Standards Min Typ Max (dBm) (dBm) (dBm) 802.11b, 1 Mbps — 20.5 — 802.11b, 11 Mbps — 20.5 — 802.11g, 6 Mbps — 20.0 — 802.11g, 54 Mbps — 18.0 — 802.11n, HT20, MCS 0 — 19.0 — 802.11n, HT20, MCS 7 — 17.5 — 802.11n, HT40, MCS 0 — 18.5 — 802.11n, HT40, MCS 7 — 17.0 — Rate Table 15: TX EVM Test Rate Min Typ SL1 (dB) (dB) (dB) 802.11b, 1 Mbps, @20.5 dBm — –24.5 –10 802.11b, 11 Mbps, @20.5 dBm — –24.5 –10 802.11g, 6 Mbps, @20 dBm — –23.0 –5 802.11g, 54 Mbps, @18 dBm — –29.5 –25 802.11n, HT20, MCS 0, @19 dBm — –24.0 –5 802.11n, HT20, MCS 7, @17.5 dBm — –30.5 –27 Cont’d on next page Espressif Systems 16 ESP32-S3-WROOM-1 & WROOM-1U Datasheet v1.1 Submit Documentation Feedback 4 Electrical Characteristics Table 15 – cont’d from previous page Rate Min Typ SL1 (dB) (dB) (dB) 802.11n, HT40, MCS 0, @18.5 dBm — –25.0 –5 802.11n, HT40, MCS 7, @17 dBm — –30.0 –27 1 SL stands for standard limit value. 4.5.3 Wi­Fi RF Receiver (RX) Specifications Table 16: RX Sensitivity Min Typ Max (dBm) (dBm) (dBm) 802.11b, 1 Mbps — –98.2 — 802.11b, 2 Mbps — –95.6 — 802.11b, 5.5 Mbps — –92.8 — 802.11b, 11 Mbps — –88.5 — 802.11g, 6 Mbps — –93.0 — 802.11g, 9 Mbps — –92.0 — 802.11g, 12 Mbps — –90.8 — 802.11g, 18 Mbps — –88.5 — 802.11g, 24 Mbps — –85.5 — 802.11g, 36 Mbps — –82.2 — 802.11g, 48 Mbps — –78.0 — 802.11g, 54 Mbps — –76.2 — 802.11n, HT20, MCS 0 — –93.0 — 802.11n, HT20, MCS 1 — –90.6 — 802.11n, HT20, MCS 2 — –88.4 — 802.11n, HT20, MCS 3 — –84.8 — 802.11n, HT20, MCS 4 — –81.6 — 802.11n, HT20, MCS 5 — –77.4 — 802.11n, HT20, MCS 6 — –75.6 — 802.11n, HT20, MCS 7 — –74.2 — 802.11n, HT40, MCS 0 — –90.0 — 802.11n, HT40, MCS 1 — –87.5 — 802.11n, HT40, MCS 2 — –85.0 — 802.11n, HT40, MCS 3 — –82.0 — 802.11n, HT40, MCS 4 — –78.5 — 802.11n, HT40, MCS 5 — –74.4 — 802.11n, HT40, MCS 6 — –72.5 — 802.11n, HT40, MCS 7 — –71.2 — Rate Espressif Systems 17 ESP32-S3-WROOM-1 & WROOM-1U Datasheet v1.1 Submit Documentation Feedback 4 Electrical Characteristics Table 17: Maximum RX Level Min Typ Max (dBm) (dBm) (dBm) 802.11b, 1 Mbps — 5 — 802.11b, 11 Mbps — 5 — 802.11g, 6 Mbps — 5 — 802.11g, 54 Mbps — 0 — 802.11n, HT20, MCS 0 — 5 — 802.11n, HT20, MCS 7 — 0 — 802.11n, HT40, MCS 0 — 5 — 802.11n, HT40, MCS 7 — 0 — Rate Table 18: RX Adjacent Channel Rejection Rate Min Typ Max (dB) (dB) (dB) 802.11b, 1 Mbps — 35 — 802.11b, 11 Mbps — 35 — 802.11g, 6 Mbps — 31 — 802.11g, 54 Mbps — 14 — 802.11n, HT20, MCS 0 — 31 — 802.11n, HT20, MCS 7 — 13 — 802.11n, HT40, MCS 0 — 19 — 802.11n, HT40, MCS 7 — 8 — 4.6 Bluetooth LE Radio Table 19: Bluetooth LE Frequency Parameter Center frequency of operating channel Min Typ Max (MHz) (MHz) (MHz) 2402 — 2480 4.6.1 Bluetooth LE RF Transmitter (TX) Specifications Table 20: Transmitter Characteristics ­ Bluetooth LE 1 Mbps Parameter RF transmit power Carrier frequency offset and drift Description Min RF power control range Typ Max Unit –25.00 0 20.00 dBm Gain control step — 3.00 — dB Max |fn |n=0, 1, 2, ..k — 2.50 — kHz Max |f0 − fn | — 2.00 — kHz Max |fn − fn−5 | — 1.40 — kHz Cont’d on next page Espressif Systems 18 ESP32-S3-WROOM-1 & WROOM-1U Datasheet v1.1 Submit Documentation Feedback 4 Electrical Characteristics Table 20 – cont’d from previous page Parameter Description Modulation characteristics In-band spurious emissions Min Typ Max Unit |f1 − f0 | — 1.00 — kHz ∆ f 1avg — 249.00 — kHz — 198.00 — kHz ∆ f 2avg /∆ f 1avg — 0.86 — — ±2 MHz offset — –37.00 — dBm ±3 MHz offset — –42.00 — dBm >±3 MHz offset — –44.00 — dBm Min ∆ f 2max (for at least 99.9% of all ∆ f 2max ) Table 21: Transmitter Characteristics ­ Bluetooth LE 2 Mbps Parameter Description Min RF power control range RF transmit power Carrier frequency offset and drift Modulation characteristics In-band spurious emissions Typ Max Unit –25.00 0 20.00 Gain control step — 3.00 — dB Max |fn |n=0, 1, 2, ..k — 2.50 — kHz Max |f0 − fn | — 2.00 — kHz Max |fn − fn−5 | — 1.40 — kHz |f1 − f0 | — 1.00 — kHz ∆ f 1avg — 499.00 — kHz — 416.00 — kHz ∆ f 2avg /∆ f 1avg — 0.89 — — ±4 MHz offset — –42.00 — dBm ±5 MHz offset — –44.00 — dBm >±5 MHz offset — –47.00 — dBm Min ∆ f 2max (for at least 99.9% of all ∆ f 2max ) dBm Table 22: Transmitter Characteristics ­ Bluetooth LE 125 Kbps Parameter RF transmit power Carrier frequency offset and drift Modulation characteristics Description Min RF power control range Espressif Systems Max Unit –25.00 0 20.00 Gain control step — 3.00 — dB Max |fn |n=0, 1, 2, ..k — 0.80 — kHz Max |f0 − fn | — 1.00 — kHz |fn − fn−3 | — 0.30 — kHz |f0 − f3 | — 1.00 — kHz ∆ f 1avg — 248.00 — kHz — 222.00 — kHz ±2 MHz offset — –37.00 — dBm ±3 MHz offset — –42.00 — dBm >±3 MHz offset — –44.00 — dBm Min ∆ f 1max (for at least 99.9% of all∆ f 1max ) In-band spurious emissions Typ 19 dBm ESP32-S3-WROOM-1 & WROOM-1U Datasheet v1.1 Submit Documentation Feedback 4 Electrical Characteristics Table 23: Transmitter Characteristics ­ Bluetooth LE 500 Kbps Parameter Description Min RF power control range RF transmit power Carrier frequency offset and drift Modulation characteristics Max Unit –25.00 0 20.00 Gain control step — 3.00 — dB Max |fn |n=0, 1, 2, ..k — 0.80 — kHz Max |f0 − fn | — 1.00 — kHz |fn − fn−3 | — 0.85 — kHz |f0 − f3 | — 0.34 — kHz ∆ f 2avg — 213.00 — kHz — 196.00 — kHz ±2 MHz offset — –37.00 — dBm ±3 MHz offset — –42.00 — dBm >±3 MHz offset — –44.00 — dBm Min ∆ f 2max (for at least 99.9% of all ∆ f 2max ) In-band spurious emissions Typ dBm 4.6.2 Bluetooth LE RF Receiver (RX) Specifications Table 24: Receiver Characteristics ­ Bluetooth LE 1 Mbps Parameter Description Sensitivity @30.8% PER — — –96.5 — dBm Maximum received signal @30.8% PER — — 8 — dBm Co-channel C/I F = F0 MHz — 8 — dB F = F0 + 1 MHz — 4 — dB F = F0 – 1 MHz — 4 — dB F = F0 + 2 MHz — –23 — dB F = F0 – 2 MHz — –23 — dB F = F0 + 3 MHz — –34 — dB F = F0 – 3 MHz — –34 — dB F > F0 + 3 MHz — –36 — dB F > F0 – 3 MHz — –37 — dB — — –36 — dB F = Fimage + 1 MHz — –39 — dB F = Fimage – 1 MHz — –34 — dB 30 MHz ~ 2000 MHz — –12 — dBm 2003 MHz ~ 2399 MHz — –18 — dBm 2484 MHz ~ 2997 MHz — –16 — dBm 3000 MHz ~ 12.75 GHz — –10 — dBm — — –29 — dBm Adjacent channel selectivity C/I Image frequency Adjacent channel to image frequency Out-of-band blocking performance Intermodulation Espressif Systems 20 Min Typ Max Unit ESP32-S3-WROOM-1 & WROOM-1U Datasheet v1.1 Submit Documentation Feedback 4 Electrical Characteristics Table 25: Receiver Characteristics ­ Bluetooth LE 2 Mbps Parameter Description Sensitivity @30.8% PER — — –92 — dBm Maximum received signal @30.8% PER — — 3 — dBm Co-channel C/I F = F0 MHz — 8 — dB F = F0 + 2 MHz — 4 — dB F = F0 – 2 MHz — 4 — dB F = F0 + 4 MHz — –27 — dB F = F0 – 4 MHz — –27 — dB F = F0 + 6 MHz — –38 — dB F = F0 – 6 MHz — –38 — dB F > F0 + 6 MHz — –41 — dB F > F0 – 6 MHz — –41 — dB — — –27 — dB F = Fimage + 2 MHz — –38 — dB F = Fimage – 2 MHz — 4 — dB 30 MHz ~ 2000 MHz — –15 — dBm 2003 MHz ~ 2399 MHz — –21 — dBm 2484 MHz ~ 2997 MHz — –21 — dBm 3000 MHz ~ 12.75 GHz — –9 — dBm — — –29 — dBm Adjacent channel selectivity C/I Image frequency Adjacent channel to image frequency Out-of-band blocking performance Intermodulation Min Typ Max Unit Table 26: Receiver Characteristics ­ Bluetooth LE 125 Kbps Parameter Description Sensitivity @30.8% PER — — –103.5 — dBm Maximum received signal @30.8% PER — — 8 — dBm Co-channel C/I F = F0 MHz — 4 — dB F = F0 + 1 MHz — 1 — dB F = F0 – 1 MHz — 2 — dB F = F0 + 2 MHz — –26 — dB F = F0 – 2 MHz — –26 — dB F = F0 + 3 MHz — –36 — dB F = F0 – 3 MHz — –39 — dB F > F0 + 3 MHz — –42 — dB F > F0 – 3 MHz — –43 — dB — — –42 — dB F = Fimage + 1 MHz — –43 — dB F = Fimage – 1 MHz — –36 — dB Adjacent channel selectivity C/I Image frequency Adjacent channel to image frequency Espressif Systems 21 Min Typ Max Unit ESP32-S3-WROOM-1 & WROOM-1U Datasheet v1.1 Submit Documentation Feedback 4 Electrical Characteristics Table 27: Receiver Characteristics ­ Bluetooth LE 500 Kbps Parameter Description Sensitivity @30.8% PER — — –100 — dBm Maximum received signal @30.8% PER — — 8 — dBm Co-channel C/I F = F0 MHz — 4 — dB F = F0 + 1 MHz — 1 — dB F = F0 – 1 MHz — 0 — dB F = F0 + 2 MHz — –24 — dB F = F0 – 2 MHz — –24 — dB F = F0 + 3 MHz — –37 — dB F = F0 – 3 MHz — –39 — dB F > F0 + 3 MHz — –38 — dB F > F0 – 3 MHz — –42 — dB — — –38 — dB F = Fimage + 1 MHz — –42 — dB F = Fimage – 1 MHz — –37 — dB Adjacent channel selectivity C/I Image frequency Adjacent channel to image frequency Espressif Systems 22 Min Typ Max Unit ESP32-S3-WROOM-1 & WROOM-1U Datasheet v1.1 Submit Documentation Feedback 5 Module Schematics This is the reference design of the module. 5 4 3 2 1 C4 D TBD VDD33 R1 10nF GND GPIO46 GPIO45 U0RXD 499 U0TXD GPIO42 GPIO41 GPIO40 GPIO39 GPIO38 GND CHIP_PU GPIO4 GPIO5 GPIO6 GPIO7 GPIO15 GPIO16 GPIO17 GPIO18 GPIO8 GPIO19 GPIO20 1 2 3 4 5 6 7 8 9 10 11 12 13 14 R4 GND L1 GND GND 2.0nH(0.1nH) C10 C GND RF_ANT 1 2 L2 GND TBD L3 C11 C12 TBD TBD TBD PCB_ANT GND GND C5 TBD B GND CHIP_PU GPIO0 GPIO1 GPIO2 GPIO3 GPIO4 GPIO5 GPIO6 GPIO7 GPIO8 GPIO9 1 2 3 4 5 6 7 8 9 10 11 12 13 14 LNA_IN VDD3P3 VDD3P3 CHIP_PU GPIO0 GPIO1 GPIO2 GPIO3 GPIO4 GPIO5 GPIO6 GPIO7 GPIO8 GPIO9 The values of L3, C5, C11, L2 and C12 vary with the actual PCB board. NC: No component. VDD33 VDD33 56 55 54 53 52 51 50 49 48 47 46 45 44 43 15 16 17 18 19 20 21 22 23 24 25 26 27 28 U1 GND ESP32-S3 ESP32-S3R2 ESP32-S3R8 42 41 40 39 38 37 36 35 34 33 32 31 30 29 GPIO37 GPIO36 GPIO35 R16 R15 R10 0 0 0 R14 R13 0 0 ESP32-S3-WROOM-1(pin-out) GPIO47 GPIO48 SPID SPIQ SPICLK SPICS0 SPIWP SPIHD C13 C14 VDD_SPI 0.1uF 1uF GND C 15 16 17 18 19 20 21 22 23 24 25 26 0.1uF GPIO37 GPIO36 GPIO35 GPIO34 GPIO33 SPICLK_P SPICLK_N SPID SPIQ SPICLK SPICS0 SPIWP SPIHD VDD_SPI GPIO1 GPIO2 U0TXD U0RXD GPIO42 GPIO41 GPIO40 GPIO39 GPIO38 GPIO37 GPIO36 GPIO35 GPIO0 VDD_SPI SPICS0 1 SPICLK 6 SPIHD 7 /CS DI CLK /HOLD U2 GND DO /WP 5 SPID 2 SPIQ 3 SPIWP B FLASH-3V3 GND GPIO15 GPIO16 GPIO17 GPIO18 GPIO19 GPIO20 GPIO21 C15 0.1uF GPIO10 GPIO11 GPIO12 GPIO13 GPIO14 ESP32-S3-WROOM-1 & WROOM-1U Datasheet v1.1 GND LNA_IN 41 40 39 38 37 36 35 34 33 32 31 30 29 28 27 8 GND 0.1uF EPAD GND IO1 IO2 TXD0 RXD0 IO42 IO41 IO40 IO39 IO38 IO37 IO36 IO35 IO0 GND 3V3 EN IO4 IO5 IO6 IO7 IO15 IO16 IO17 IO18 IO8 IO19 IO20 GPIO3 GPIO46 GPIO9 GPIO10 GPIO11 GPIO12 GPIO13 GPIO14 GPIO21 GPIO47 GPIO48 GPIO45 GND ANT1 0.1uF VDDA VDDA XTAL_P XTAL_N GPIO46 GPIO45 U0RXD U0TXD MTMS MTDI VDD3P3_CPU MTDO MTCK GPIO38 1uF C9 GPIO10 GPIO11 GPIO12 GPIO13 GPIO14 VDD3P3_RTC XTAL_32K_P XTAL_32K_N GPIO17 GPIO18 GPIO19 GPIO20 GPIO21 SPICS1 10uF C8 57 C7 GND C6 ESP32-S3-WROOM-1 IO3 IO46 IO9 IO10 IO11 IO12 IO13 IO14 IO21 IO47 IO48 IO45 1uF 0 C2 VDD33 23 Submit Documentation Feedback R3 C3 D1 ESD 10K(NC) GND 40MHz(±10ppm) The value of R4 varies with the actual PCB board. VDD33 GND U3 The values of C1 and C4 vary with the selection of the crystal. VDD33 VDD33 2 XIN 1 TBD VDD C1 D GND GND GND Y1 4 4 GND 3 GND GND XOUT Espressif Systems 5 Module Schematics GND A A Figure 5: ESP32­S3­WROOM­1 Schematics Title Size A4 Date: 5 4 3 2 Page Name Rev V1.3 Friday, March 04, 2022 Sheet Confidential and Proprietary 2 1 of 2 5 4 3 2 1 C4 D VDD33 3 R1 1uF 10nF GND GND L1 GND 2.0nH(0.1nH) GND C10 C 3 L2 GND TBD ANT1 C11 C12 CONN TBD TBD GND GND GND The values of C11, L2 and C12 vary with the actual PCB board. NC: No component. LNA_IN CHIP_PU GPIO0 GPIO1 GPIO2 GPIO3 GPIO4 GPIO5 GPIO6 GPIO7 GPIO8 GPIO9 1 2 3 4 5 6 7 8 9 10 11 12 13 14 LNA_IN VDD3P3 VDD3P3 CHIP_PU GPIO0 GPIO1 GPIO2 GPIO3 GPIO4 GPIO5 GPIO6 GPIO7 GPIO8 GPIO9 56 55 54 53 52 51 50 49 48 47 46 45 44 43 15 16 17 18 19 20 21 22 23 24 25 26 27 28 VDD33 ESP32-S3 ESP32-S3R2 ESP32-S3R8 GPIO37 GPIO36 GPIO35 R16 R15 R10 0 0 0 R14 R13 0 0 ESP32-S3-WROOM-1U(pin-out) GPIO47 GPIO48 SPID SPIQ SPICLK SPICS0 SPIWP SPIHD C13 C14 VDD_SPI 0.1uF 1uF GND C 15 16 17 18 19 20 21 22 23 24 25 26 GND 42 41 40 39 38 37 36 35 34 33 32 31 30 29 GPIO1 GPIO2 U0TXD U0RXD GPIO42 GPIO41 GPIO40 GPIO39 GPIO38 GPIO37 GPIO36 GPIO35 GPIO0 VDD_SPI SPICS0 1 SPICLK 6 SPIHD 7 /CS DI CLK /HOLD U2 GND DO /WP 5 SPID 2 SPIQ 3 SPIWP B FLASH-3V3 GND GPIO15 GPIO16 GPIO17 GPIO18 GPIO19 GPIO20 GPIO21 C15 0.1uF GPIO10 GPIO11 GPIO12 GPIO13 GPIO14 ESP32-S3-WROOM-1 & WROOM-1U Datasheet v1.1 U1 VDD33 0.1uF GPIO37 GPIO36 GPIO35 GPIO34 GPIO33 SPICLK_P SPICLK_N SPID SPIQ SPICLK SPICS0 SPIWP SPIHD VDD_SPI 41 40 39 38 37 36 35 34 33 32 31 30 29 28 27 8 RF_ANT 1 2 GND EPAD GND IO1 IO2 TXD0 RXD0 IO42 IO41 IO40 IO39 IO38 IO37 IO36 IO35 IO0 GND 3V3 EN IO4 IO5 IO6 IO7 IO15 IO16 IO17 IO18 IO8 IO19 IO20 GPIO3 GPIO46 GPIO9 GPIO10 GPIO11 GPIO12 GPIO13 GPIO14 GPIO21 GPIO47 GPIO48 GPIO45 GND 0.1uF VDDA VDDA XTAL_P XTAL_N GPIO46 GPIO45 U0RXD U0TXD MTMS MTDI VDD3P3_CPU MTDO MTCK GPIO38 GND 0.1uF GPIO10 GPIO11 GPIO12 GPIO13 GPIO14 VDD3P3_RTC XTAL_32K_P XTAL_32K_N GPIO17 GPIO18 GPIO19 GPIO20 GPIO21 SPICS1 1uF C9 24 Submit Documentation Feedback 10uF C8 57 C7 GND C6 B GPIO46 GPIO45 U0RXD 499 U0TXD GPIO42 GPIO41 GPIO40 GPIO39 GPIO38 CHIP_PU GPIO4 GPIO5 GPIO6 GPIO7 GPIO15 GPIO16 GPIO17 GPIO18 GPIO8 GPIO19 GPIO20 1 2 3 4 5 6 7 8 9 10 11 12 13 14 R4 VDD33 GND ESP32-S3-WROOM-1U IO3 IO46 IO9 IO10 IO11 IO12 IO13 IO14 IO21 IO47 IO48 IO45 C2 0 R3 C3 D1 ESD 10K(NC) GND 40MHz(±10ppm) The value of R4 varies with the actual PCB board. VDD33 GND U3 The values of C1 and C4 vary with the selection of the crystal. VDD33 VDD33 VDD TBD 2 XIN 1 TBD GND C1 D GND 4 GND Y1 GND XOUT 4 GND GND A A Figure 6: ESP32­S3­WROOM­1U Schematics Title Size A4 Page Name Rev V1.4 Confidential and Proprietary Internal pull-up resistor (R1) for IO45 is not populated in the module, as the flash in the module works at 3.3 VDate: by default (output Please make sure IO45 is Friday, March 04, 2022by VDD_SPI). 2 of 2 Sheet 5 4 not pulled high when the module is powered up by external circuit. 3 2 1 5 Module Schematics Espressif Systems GND 6 Peripheral Schematics 6 Peripheral Schematics This is the typical application circuit of the module connected with peripheral components (for example, power supply, antenna, reset button, JTAG interface, and UART interface). VDD33 GND GND VDD33 JP1 0.1uF GND 1 R2 NC GND 2 GND C4 12pF(NC) X1 32.768KHz(NC) GND C7 JP3 1 2 1 2 USB OTG 12pF(NC) EN IO4 IO5 IO6 X1: ESR = Max. 70 KΩ IO7 IO15 R3 0(NC) IO16 R5 0(NC) IO17 IO18 IO8 IO19 IO20 C2 USB_DUSB_D+ C6 TBD TBD TBD R6 R4 0 0 C5 NC: No component. 1 2 3 4 UART JP2 GND TMS TDI TDO TCK 1 2 3 4 GND 1 2 3 4 JTAG JP4 2 1 2 1 Boot Option SW1 U1 R7 TBD C8 GNDGND 1 2 3 4 IO1 IO2 RXD0 TXD0 IO42 IO41 IO40 IO39 IO38 IO37 IO36 IO35 IO0 IO3 IO46 IO9 IO10 IO11 IO12 IO13 IO14 IO21 IO47 IO48 IO45 22uF GND R1 15 16 17 18 19 20 21 22 23 24 25 26 C3 IO3 IO46 IO9 IO10 IO11 IO12 IO13 IO14 IO21 IO47 IO48 IO45 C1 ESP32-S3-WROOM-1/ESP32-S3-WROOM-1U 41 EPAD 40 1 GND 39 2 GND IO1 38 3 3V3 IO2 37 4 EN TXD0 36 5 IO4 RXD0 35 6 IO5 IO42 34 7 IO6 IO41 33 8 IO7 IO15 IO40 32 9 IO16 IO39 31 10 IO38 30 11 IO17 IO37 29 12 IO18 IO36 28 13 IO8 IO35 27 14 IO19 IO20 IO0 0 EN 0.1uF GND Figure 7: Peripheral Schematics • Soldering the EPAD to the ground of the base board is not a must, however, it can optimize thermal performance. If you choose to solder it, please apply the correct amount of soldering paste. • To ensure that the power supply to the ESP32-S3 chip is stable during power-up, it is advised to add an RC delay circuit at the EN pin. The recommended setting for the RC delay circuit is usually R = 10 kΩ and C = 1 µF. However, specific parameters should be adjusted based on the power-up timing of the module and the power-up and reset sequence timing of the chip. For ESP32-S3’s power-up and reset sequence timing diagram, please refer to Section Power Scheme in ESP32-S3 Series Datasheet. 5 4 Espressif Systems 3 25 ESP32-S3-WROOM-1 & WROOM-1U Datasheet v1.1 Submit Documentation Feedback 2 7 Physical Dimensions and PCB Land Pattern ESP32-S3-WROOM-1 Dimensions 7 Physical Dimensions and PCB Land Pattern Unit: mm ESP32-S3-WROOM-1 Dimensions 7.1 Physical Dimensions 18±0.15 3.1±0.15 0.8 6 Unit: mm 3.1±0.15 0.8 0.9 0.5 15.8 Top View 13.97 40 x 0.45 3.7 0.9 10.29 3.7 7.5 3.7 40 x 0.9 1 1.05 Ø 0. 5 13.97 40 x 0.45 17.6 1.27 40 x Ø0.55 0.9 0.5 2.015 1.27 3.7 40 x 0.85 7.5 0.9 10.29 1.05 15.8 40 x 0.9 17.6 Ø 0. 5 40 x Ø0.55 1.5 25.5±0.15 16.51 1.5 40 x 0.9 25.5±0.15 16.51 6 40 x 0.9 1.27 18±0.15 Bottom View Side View 1.27 2.015 40 x 0.85 1 Top View Side View ESP32-S3-WROOM-1U Dimensions Bottom View Figure 8: ESP32­S3­WROOM­1 Physical Dimensions ESP32-S3-WROOM-1U Dimensions Unit: mm 18±0.15 3.2±0.15 0.8 3 Unit: mm 2.46 3 40 x Ø0.55 3.2±0.15 0.8 3.7 13.97 1.08 40 x 0.45 Figure Note: Top View 0.9 2.015 1.27 3.7 40 x 0.85 7.5 10.29 40 x 0.9 0. 5 Top View 1.1 13.1 17.5 15.65 13.97 1.08 40 x 0.45 7.5 3.7 0.9 40 x Ø0.55 0.9 0.5 10.29 40 x 0.9 1.1 2.46 13.1 Ø 0. 5 10.75 17.5 15.65 Ø 19.2±0.15 19.2±0.15 16.51 16.51 40 x 0.9 1.5 40 x1.5 0.9 1.27 1.27 18±0.15 3.7 0.9 0.5 10.75 Bottom View Side View 9: ESP32­S3­WROOM­1U Physical Dimensions 1.27 2.015 40 x 0.85 Bottom View Side View For information about tape, reel, and product marking, please refer to Espressif Module Package Information. Espressif Systems 26 ESP32-S3-WROOM-1 & WROOM-1U Datasheet v1.1 Submit Documentation Feedback 7 Physical Dimensions and PCB Land Pattern 7.2 Recommended PCB Land Pattern Unit: mm Via for thermal pad Copper Antenna Area 40 x1.5 40 25.5 0.9 0.5 7.50 1.27 10.29 1.5 0.5 3.7 0.9 3.7 40 x0.9 1 16.51 6 7.49 18 15 26 0.5 1.27 2.015 2.015 17.5 Figure 10: ESP32­S3­WROOM­1 Recommended PCB Land Pattern Espressif Systems 27 ESP32-S3-WROOM-1 & WROOM-1U Datasheet v1.1 Submit Documentation Feedback 7 Physical Dimensions and PCB Land Pattern Unit: mm Via for thermal pad Copper 18 40 x1.5 40 1.19 15 0.5 1.27 19.2 10.29 7.5 0.90 3.7 40 x0.9 0.9 0.5 3.7 1.5 0.5 16.51 1 26 1.27 2.015 2.015 17.5 Figure 11: ESP32­S3­WROOM­1U Recommended PCB Land Pattern Espressif Systems 28 ESP32-S3-WROOM-1 & WROOM-1U Datasheet v1.1 Submit Documentation Feedback 7 Physical Dimensions and PCB Land Pattern 7.3 Dimensions of External Antenna Connector ESP32-S3-WROOM-1U uses the first generation external antenna connector as shown in Figure 12. This connector is compatible with the following connectors: • U.FL Series connector from Hirose • MHF I connector from I-PEX • AMC connector from Amphenol Unit: mm Figure 12: Dimensions of External Antenna Connector Espressif Systems 29 ESP32-S3-WROOM-1 & WROOM-1U Datasheet v1.1 Submit Documentation Feedback 8 Product Handling 8 Product Handling 8.1 Storage Conditions The products sealed in moisture barrier bags (MBB) should be stored in a non-condensing atmospheric environment of < 40 °C and /90%RH. The module is rated at the moisture sensitivity level (MSL) of 3. After unpacking, the module must be soldered within 168 hours with the factory conditions 25±5 °C and /60%RH. If the above conditions are not met, the module needs to be baked. 8.2 Electrostatic Discharge (ESD) • Human body model (HBM): ±2000 V • Charged-device model (CDM): ±500 V 8.3 Reflow Profile Temperature (℃) Solder the module in a single reflow. Peak Temp. 235 ~ 250 ℃ 250 Preheating zone 150 ~ 200 ℃ 60 ~ 120 s 217 200 Reflow zone 217 ℃ 60 ~ 90 s Cooling zone –1 ~ –5 ℃/s Soldering time > 30 s Ramp-up zone 1 ~ 3 ℃/s 100 50 25 Time (sec.) 0 0 50 100 150 200 250 Ramp-up zone — Temp.: 25 ~ 150 ℃ Time: 60 ~ 90 s Ramp-up rate: 1 ~ 3 ℃/s Preheating zone — Temp.: 150 ~ 200 ℃ Time: 60 ~ 120 s Reflow zone — Temp.: >217 ℃ 60 ~ 90 s; Peak Temp.: 235 ~ 250 ℃ Time: 30 ~ 70 s Cooling zone — Peak Temp. ~ 180 ℃ Ramp-down rate: –1 ~ –5 ℃/s Solder — Sn-Ag-Cu (SAC305) lead-free solder alloy Figure 13: Reflow Profile Espressif Systems 30 ESP32-S3-WROOM-1 & WROOM-1U Datasheet v1.1 Submit Documentation Feedback 8 Product Handling 8.4 Ultrasonic Vibration Avoid exposing Espressif modules to vibration from ultrasonic equipment, such as ultrasonic welders or ultrasonic cleaners. This vibration may induce resonance in the in-module crystal and lead to its malfunction or even failure. As a consequence, the module may stop working or its performance may deteriorate. Espressif Systems 31 ESP32-S3-WROOM-1 & WROOM-1U Datasheet v1.1 Submit Documentation Feedback 9 Related Documentation and Resources 9 Related Documentation and Resources Related Documentation • ESP32-S3 Series Datasheet – Specifications of the ESP32-S3 hardware. • ESP32-S3 Technical Reference Manual – Detailed information on how to use the ESP32-S3 memory and peripherals. • ESP32-S3 Hardware Design Guidelines – Guidelines on how to integrate the ESP32-S3 into your hardware product. • Certificates https://espressif.com/en/support/documents/certificates • Documentation Updates and Update Notification Subscription https://espressif.com/en/support/download/documents Developer Zone • ESP-IDF Programming Guide for ESP32-S3 – Extensive documentation for the ESP-IDF development framework. • ESP-IDF and other development frameworks on GitHub. https://github.com/espressif • ESP32 BBS Forum – Engineer-to-Engineer (E2E) Community for Espressif products where you can post questions, share knowledge, explore ideas, and help solve problems with fellow engineers. https://esp32.com/ • The ESP Journal – Best Practices, Articles, and Notes from Espressif folks. https://blog.espressif.com/ • See the tabs SDKs and Demos, Apps, Tools, AT Firmware. https://espressif.com/en/support/download/sdks-demos Products • ESP32-S3 Series SoCs – Browse through all ESP32-S3 SoCs. https://espressif.com/en/products/socs?id=ESP32-S3 • ESP32-S3 Series Modules – Browse through all ESP32-S3-based modules. https://espressif.com/en/products/modules?id=ESP32-S3 • ESP32-S3 Series DevKits – Browse through all ESP32-S3-based devkits. https://espressif.com/en/products/devkits?id=ESP32-S3 • ESP Product Selector – Find an Espressif hardware product suitable for your needs by comparing or applying filters. https://products.espressif.com/#/product-selector?language=en Contact Us • See the tabs Sales Questions, Technical Enquiries, Circuit Schematic & PCB Design Review, Get Samples (Online stores), Become Our Supplier, Comments & Suggestions. https://espressif.com/en/contact-us/sales-questions Espressif Systems 32 ESP32-S3-WROOM-1 & WROOM-1U Datasheet v1.1 Submit Documentation Feedback Revision History Revision History Date Version 2022-07-22 v1.1 Release notes • Update Table 1 and Table 2 • Other minor updates • Update Bluetooth LE RF data 2022-04-21 v1.0 • Update power consumption data in Table 12 • Add certification and test information • Add Table 6 and update description of ROM code printing in Section 3.3 2021-10-29 v0.6 Overall update for chip revision 1 2021-07-19 v0.5.1 Preliminary release, for chip revision 0 Espressif Systems 33 ESP32-S3-WROOM-1 & WROOM-1U Datasheet v1.1 Submit Documentation Feedback Disclaimer and Copyright Notice Information in this document, including URL references, is subject to change without notice. ALL THIRD PARTY’S INFORMATION IN THIS DOCUMENT IS PROVIDED AS IS WITH NO WARRANTIES TO ITS AUTHENTICITY AND ACCURACY. NO WARRANTY IS PROVIDED TO THIS DOCUMENT FOR ITS MERCHANTABILITY, NONINFRINGEMENT, FITNESS FOR ANY PARTICULAR PURPOSE, NOR DOES ANY WARRANTY OTHERWISE ARISING OUT OF ANY PROPOSAL, SPECIFICATION OR SAMPLE. All liability, including liability for infringement of any proprietary rights, relating to use of information in this document is disclaimed. No licenses express or implied, by estoppel or otherwise, to any intellectual property rights are granted herein. The Wi-Fi Alliance Member logo is a trademark of the Wi-Fi Alliance. The Bluetooth logo is a registered trademark of Bluetooth SIG. www.espressif.com All trade names, trademarks and registered trademarks mentioned in this document are property of their respective owners, and are hereby acknowledged. Copyright © 2022 Espressif Systems (Shanghai) Co., Ltd. All rights reserved.
ESP32-S3-WROOM-1U-N8R8 价格&库存
很抱歉,暂时无法提供与“ESP32-S3-WROOM-1U-N8R8”相匹配的价格&库存,您可以联系我们找货
  • 1+53.875851+6.50880
  • 5+49.386195+5.96640
  • 25+44.8965425+5.42400
  • 100+39.47154100+4.76860
    • 650+25.77840
    库存:5000
