ESP32-C6-WROOM-1-N8
ESP32-C6-WROOM-1-N8
    ESPRESSIF(乐鑫)
    MODULE_25.5X18MM_SM
    802.15.4,蓝牙,WiFi 蓝牙 v5.0,Zigbee® RF 收发器模块 2.4GHz PCB 印制线 表面贴装型
ESP32-C6-WROOM-1-N8 数据手册
ESP32-C6-WROOM-1 ESP32-C6-WROOM-1U Datasheet Module that supports 2.4 GHz Wi-Fi 6 (802.11 ax), Bluetooth® 5 (LE), Zigbee and Thread (802.15.4) Built around ESP32-C6 series of SoCs, 32-bit RISC-V single-core microprocessor Flash up to 16 MB 23 GPIOs, rich set of peripherals On-board PCB antenna or external antenna connector ESP32-C6-WROOM-1 ESP32-C6-WROOM-1U Pre-release v0.6 Espressif Systems Copyright © 2023 www.espressif.com 1 Module Overview 1 Module Overview Note: Check the link or the QR code to make sure that you use the latest version of this document: https://espressif.com/documentation/esp32-c6-wroom-1-wroom-1u_datasheet_en.pdf 1.1 Features – 20 MHz and 40 MHz bandwidth CPU and On-Chip Memory – Data rate up to 150 Mbps • ESP32-C6 embedded, 32-bit RISC-V single-core microprocessor, up to 160 MHz – Wi-Fi Multimedia (WMM) • ROM: 320 KB – TX/RX A-MPDU, TX/RX A-MSDU • HP SRAM: 512 KB – Immediate Block ACK • LP SRAM: 16 KB – Fragmentation and defragmentation – Transmit opportunity (TXOP) Wi-Fi – Automatic Beacon monitoring (hardware • 1T1R in 2.4 GHz band TSF) • Operating frequency: 2412 ~ 2484 MHz – 4 × virtual Wi-Fi interfaces • IEEE 802.11ax-compliant – Simultaneous support for Infrastructure BSS – 20 MHz-only non-AP mode in Station mode, SoftAP mode, Station + SoftAP mode, and promiscuous mode – MCS0 ~MCS9 Note that when ESP32-C6 scans in Station – Uplink and downlink OFDMA, especially mode, the SoftAP channel will change along suitable for simultaneous connections in with the Station channel high-density environments – 802.11mc FTM – Downlink MU-MIMO (multi-user, multiple input, multiple output) to increase network Bluetooth capacity – Beamformee that improves signal quality • Bluetooth LE: Bluetooth 5.3 certified – Channel quality indication (CQI) • Bluetooth mesh – DCM (dual carrier modulation) to improve • High power mode (20 dBm) link robustness • Speed: 125 Kbps, 500 Kbps, 1 Mbps, 2 Mbps – Spatial reuse to maximize parallel • Advertising extensions transmissions • Multiple advertisement sets – Target wake time (TWT) that optimizes • Channel selection algorithm #2 power saving mechanisms • Fully compatible with IEEE 802.11b/g/n protocol Espressif Systems • LE power control 2 ESP32-C6-WROOM-1 & WROOM-1U Datasheet v0.6 Submit Documentation Feedback 1 Module Overview • Internal co-existence mechanism between Wi-Fi Note: and Bluetooth to share the same antenna * Please refer to ESP32-C6 Series Datasheet for detailed information about the module peripherals. IEEE 802.15.4 Integrated Components on Module • Compliant with IEEE 802.15.4-2015 protocol • 40 MHz crystal oscillator • OQPSK PHY in 2.4 GHz band • SPI flash • Data rate: 250 Kbps Antenna Options • Thread 1.3 • On-board PCB antenna (ESP32-C6-WROOM-1) • Zigbee 3.0 • External antenna via a connector (ESP32-C6-WROOM-1U) Peripherals Operating Conditions • GPIO, SPI, parallel IO interface, UART, I2C, I2S, RMT (TX/RX), pulse counter, LED PWM, USB Serial/JTAG controller, MCPWM, SDIO2.0 slave controller, GDMA, TWAI® controller, on-chip debug functionality via JTAG, event task matrix, ADC, temperature sensor, general-purpose timers, watchdog timers, etc. • Operating voltage/Power supply: 3.0 ~ 3.6 V • Operating ambient temperature: – 85 °C version module: –40 ~ 85 °C – 105 °C version module: –40 ~ 105 °C 1.2 Description ESP32-C6-WROOM-1 and ESP32-C6-WROOM-1U are two powerful, general-purpose Wi-Fi, IEEE 802.15.4, and Bluetooth LE modules. The rich set of peripherals and high performance make the module an ideal choice for smart homes, industrial automation, health care, consumer electronics, etc. ESP32-C6-WROOM-1 comes with a PCB antenna. ESP32-C6-WROOM-1U comes with a connector for an external antenna. They both feature an external SPI flash up to 16 MB. Both ESP32-C6-WROOM-1 and ESP32-C6-WROOM-1U come in two versions: • 85 °C version • 105 °C version The two versions only vary in maximum ambient temperature and flash part number. In this datasheet unless otherwise stated, ESP32-C6-WROOM-1 refers to the ESP32-C6-WROOM-1 module in 85 °C and 105 °C versions, and ESP32-C6-WROOM-1U refers to the ESP32-C6-WROOM-1U module in 85 °C and 105 °C versions. Espressif Systems 3 ESP32-C6-WROOM-1 & WROOM-1U Datasheet v0.6 Submit Documentation Feedback 1 Module Overview The series comparison for the two modules is as follows: Table 1: ESP32-C6-WROOM-1 (ANT) Series Comparison1 Ordering Code ESP32-C6-WROOM-1-N4 ESP32-C6-WROOM-1-H4 Flash Size2 (°C) (mm) –40 ∼ 85 4 MB (Quad SPI) ESP32-C6-WROOM-1-N8 8 MB (Quad SPI) ESP32-C6-WROOM-1-N16 16 MB (Quad SPI) 1 Ambient Temp.1 –40 ∼ 105 18.0 × 25.5 × 3.2 –40 ∼ 85 This table shares the same notes presented in Table 2 below. Table 2: ESP32-C6-WROOM-1U (CONN) Series Comparison Ordering Code ESP32-C6-WROOM-1U-N4 ESP32-C6-WROOM-1U-H4 Flash Size2 (°C) (mm) –40 ∼ 85 4 MB (Quad SPI) –40 ∼ 105 ESP32-C6-WROOM-1U-N8 8 MB (Quad SPI) ESP32-C6-WROOM-1U-N16 16 MB (Quad SPI) 1 Ambient Temp.1 18.0 × 19.2 × 3.2 –40 ∼ 85 Ambient temperature specifies the recommended temperature range of the environment immediately outside the Espressif module. 2 For details, refer to Section 8.1 Physical Dimensions. At the core of the modules is ESP32-C6, a 32-bit RISC-V single-core processor. ESP32-C6 integrates a rich set of peripherals including SPI, parallel IO interface, UART, I2C, I2S, RMT (TX/RX), LED PWM, USB Serial/JTAG controller, MCPWM, SDIO2.0 slave controller, GDMA, TWAI® controller, on-chip debug functionality via JTAG, event task matrix, as well as up to 23 GPIOs, etc. Note: * For more information on ESP32-C6, please refer to ESP32-C6 Series Datasheet. 1.3 Applications • Smart Home • POS machines • Industrial Automation • Service robot • Health Care • Audio Devices • Consumer Electronics • Generic Low-power IoT Sensor Hubs • Smart Agriculture • Generic Low-power IoT Data Loggers Espressif Systems 4 ESP32-C6-WROOM-1 & WROOM-1U Datasheet v0.6 Submit Documentation Feedback Contents Contents 1 Module Overview 2 1.1 Features 2 1.2 Description 3 1.3 Applications 4 2 Block Diagram 9 3 Pin Definitions 10 3.1 Pin Layout 10 3.2 Pin Description 10 3.3 Strapping Pins 11 3.3.1 SDIO Sampling and Driving Clock Edge Control 13 3.3.2 Chip Boot Mode Control 13 3.3.3 ROM Messages Printing Control 13 3.3.4 JTAG Signal Source Control 14 4 Electrical Characteristics 15 4.1 Absolute Maximum Ratings 15 4.2 Recommended Operating Conditions 15 4.3 DC Characteristics (3.3 V, 25 °C) 15 4.4 Current Consumption Characteristics 16 4.4.1 Current Consumption in Active Mode 16 4.4.2 Current Consumption in Other Modes 17 5 RF Characteristics 18 5.1 Wi-Fi Radio (2.4 GHz/5 GHz) 18 5.1.1 Wi-Fi RF Transmitter (TX) Characteristics 18 5.1.2 Wi-Fi RF Receiver (RX) Characteristics 19 5.2 5.3 Bluetooth 5 (LE) Radio 21 5.2.1 Bluetooth LE RF Transmitter (TX) Characteristics 21 5.2.2 Bluetooth LE RF Receiver (RX) Characteristics 22 802.15.4 Radio 24 5.3.1 802.15.4 RF Transmitter (TX) Characteristics 25 5.3.2 802.15.4 RF Receiver (RX) Characteristics 25 6 Module Schematics 26 7 Peripheral Schematics 28 8 Physical Dimensions and PCB Land Pattern 29 8.1 Physical Dimensions 29 8.2 Recommended PCB Land Pattern 30 8.3 Dimensions of External Antenna Connector 32 Espressif Systems 5 ESP32-C6-WROOM-1 & WROOM-1U Datasheet v0.6 Submit Documentation Feedback Contents 9 Product Handling 33 9.1 Storage Conditions 33 9.2 Electrostatic Discharge (ESD) 33 9.3 Soldering Profile 33 9.3.1 33 9.4 Reflow Profile Ultrasonic Vibration 34 10 Related Documentation and Resources 35 Revision History 36 Espressif Systems 6 ESP32-C6-WROOM-1 & WROOM-1U Datasheet v0.6 Submit Documentation Feedback List of Tables List of Tables 1 ESP32-C6-WROOM-1 (ANT) Series Comparison 4 2 ESP32-C6-WROOM-1U (CONN) Series Comparison 4 3 Pin Definitions 10 4 Default Configuration of Strapping Pins 12 5 Description of Timing Parameters for the Strapping Pins 12 6 SDIO Input Sampling Edge/Output Driving Edge Control 13 7 Boot Mode Control 13 8 ROM Messages Printing Control 14 9 JTAG Signal Source Control 14 10 Absolute Maximum Ratings 15 11 Recommended Operating Conditions 15 12 DC Characteristics (3.3 V, 25 °C) 15 13 Current Consumption for Wi-Fi (2.4 GHz) in Active Mode 16 14 Current Consumption for Bluetooth LE in Active Mode 16 15 Current Consumption for 802.15.4 in Active Mode 16 16 Current Consumption in Modem-sleep Mode 17 17 Current Consumption in Low-Power Modes 17 18 Wi-Fi RF Characteristics 18 19 TX Power with Spectral Mask and EVM Meeting 802.11 Standards 18 20 TX EVM Test 18 21 RX Sensitivity 19 22 Maximum RX Level 20 23 RX Adjacent Channel Rejection 20 24 Bluetooth LE RF Characteristics 21 25 Bluetooth LE - Transmitter Characteristics - 1 Mbps 21 26 Bluetooth LE - Transmitter Characteristics - 2 Mbps 21 27 Bluetooth LE - Transmitter Characteristics - 125 Kbps 22 28 Bluetooth LE - Transmitter Characteristics - 500 Kbps 22 29 Bluetooth LE - Receiver Characteristics - 1 Mbps 22 30 Bluetooth LE - Receiver Characteristics - 2 Mbps 23 31 Bluetooth LE - Receiver Characteristics - 125 Kbps 24 32 Bluetooth LE - Receiver Characteristics - 500 Kbps 24 33 802.15.4 RF Characteristics 24 34 802.15.4 Transmitter Characteristics - 250 Kbps 25 35 802.15.4 Receiver Characteristics - 250 Kbps 25 Espressif Systems 7 ESP32-C6-WROOM-1 & WROOM-1U Datasheet v0.6 Submit Documentation Feedback List of Figures List of Figures 1 ESP32-C6-WROOM-1 Block Diagram 9 2 ESP32-C6-WROOM-1U Block Diagram 9 3 Pin Layout (Top View) 10 4 Visualization of Timing Parameters for the Strapping Pins 13 5 ESP32-C6-WROOM-1 Schematics 26 6 ESP32-C6-WROOM-1U Schematics 27 7 Peripheral Schematics 28 8 ESP32-C6-WROOM-1 Physical Dimensions 29 9 ESP32-C6-WROOM-1U Physical Dimensions 29 10 ESP32-C6-WROOM-1 Recommended PCB Land Pattern 30 11 ESP32-C6-WROOM-1U Recommended PCB Land Pattern 31 12 Dimensions of External Antenna Connector 32 13 Reflow Profile 33 Espressif Systems 8 ESP32-C6-WROOM-1 & WROOM-1U Datasheet v0.6 Submit Documentation Feedback 2 Block Diagram 2 Block Diagram 40 MHz Crystal 3V3 Antenna RF Matching ESP32-C6 GPIOs SPICS0 SPICLK SPID SPIQ SPIHD SPIWP VDD_SPI EN GND QSPI Flash Figure 1: ESP32-C6-WROOM-1 Block Diagram 40 MHz Crystal 3V3 Antenna RF Matching GND ESP32-C6 GPIOs SPICS0 SPICLK SPID SPIQ SPIHD SPIWP VDD_SPI EN QSPI Flash Figure 2: ESP32-C6-WROOM-1U Block Diagram Espressif Systems 9 ESP32-C6-WROOM-1 & WROOM-1U Datasheet v0.6 Submit Documentation Feedback 3 Pin Definitions 3 Pin Definitions 3.1 Pin Layout The pin diagram below shows the approximate location of pins on the module. For the actual diagram drawn to scale, please refer to Figure 8.1 Physical Dimensions. The pin diagram is applicable for ESP32-C6-WROOM-1 and ESP32-C6-WROOM-1U, but the latter has no keepout zone. Keepout Zone GND 1 28 GND 3V3 2 27 IO2 EN 3 26 IO3 IO4 4 25 TXD0 24 RXD0 23 IO15 GND GND GND GND 29 GND GND GND GND GND 5 IO5 6 IO6 IO7 7 22 NC IO0 8 21 IO23 IO1 9 20 IO22 IO8 10 19 IO21 IO10 11 18 IO20 IO11 12 17 IO19 IO12 13 16 IO18 IO13 14 15 IO9 Figure 3: Pin Layout (Top View) Pin Layout (Top View) 3.2 Pin Description The module has 29 pins. See pin definitions in Table 3 Pin Definitions. For peripheral pin configurations, please refer to ESP32-C6 Series Datasheet. Table 3: Pin Definitions Name No. GND 1 Type1 Function P Ground Cont’d on next page Espressif Systems 10 ESP32-C6-WROOM-1 & WROOM-1U Datasheet v0.6 Submit Documentation Feedback 3 Pin Definitions Table 3 – cont’d from previous page Name 1 No. Type 3V3 2 P EN 3 I Function Power supply High: on, enables the chip. Low: off, the chip powers off. Note: Do not leave the EN pin floating. IO4 4 I/O/T MTMS, GPIO4, LP_GPIO4, LP_UART_RXD, ADC1_CH4, FSPIHD IO5 5 I/O/T MTDI, GPIO5, LP_GPIO5, LP_UART_TXD, ADC1_CH5, FSPIWP IO6 6 I/O/T MTCK, GPIO6, LP_GPIO6, LP_I2C_SDA, ADC1_CH6, FSPICLK IO7 7 I/O/T MTDO, GPIO7, LP_GPIO7, LP_I2C_SCL, FSPID IO0 8 I/O/T GPIO0, XTAL_32K_P, LP_GPIO0, LP_UART_DTRN, ADC1_CH0 IO1 9 I/O/T GPIO1, XTAL_32K_N, LP_GPIO1, LP_UART_DSRN, ADC1_CH1 IO8 10 I/O/T GPIO8 IO10 11 I/O/T GPIO10 IO11 12 I/O/T GPIO11 IO12 13 I/O/T GPIO12, USB_D- IO13 14 I/O/T GPIO13, USB_D+ IO9 15 I/O/T GPIO9 IO18 16 I/O/T GPIO18, SDIO_CMD, FSPICS2 IO19 17 I/O/T GPIO19, SDIO_CLK, FSPICS3 IO20 18 I/O/T GPIO20, SDIO_DATA0, FSPICS4 IO21 19 I/O/T GPIO21, SDIO_DATA1, FSPICS5 IO22 20 I/O/T GPIO22, SDIO_DATA2 IO23 21 I/O/T GPIO23, SDIO_DATA3 NC 22 — IO15 23 I/O/T GPIO15 RXD0 24 I/O/T U0RXD, GPIO17, FSPICS1 TXD0 25 I/O/T U0TXD, GPIO16, FSPICS0 IO3 26 I/O/T GPIO3, LP_GPIO3, LP_UART_CTSN, ADC1_CH3 IO2 27 I/O/T GPIO2, LP_GPIO2, LP_UART_RTSN, ADC1_CH2, FSPIQ GND 28 P Ground EPAD 29 P Ground 1 NC P: power supply; I: input; O: output; T: high impedance. 3.3 Strapping Pins Note: The content below is excerpted from ESP32-C6 Series Datasheet > Section Strapping Pins. For the strapping pin mapping between the chip and modules, please refer to Chapter 6 Module Schematics. At each startup or reset, a chip requires some initial configuration parameters, such as in which boot mode to load the chip, etc. These parameters are passed over via the strapping pins. After reset, the strapping pins operate as regular IO pins. The parameters controlled by the given strapping pins at chip reset are as follows: Espressif Systems 11 ESP32-C6-WROOM-1 & WROOM-1U Datasheet v0.6 Submit Documentation Feedback 3 Pin Definitions • SDIO sampling and driving clock edge – MTMS and MTDI • Chip boot mode – GPIO8 and GPIO9 • ROM code printing to UART – GPIO8 • JTAG signal source – GPIO15 GPIO9 is connected to the chip’s internal weak pull-up resistor at chip reset. This resistor determines the default bit value of GPIO9. Also, the resistor determines the bit value if GPIO9 is connected to an external high-impedance circuit. Table 4: Default Configuration of Strapping Pins Strapping Pin Default Configuration Bit Value MTMS Floating – MTDI Floating – GPIO8 Floating – GPIO9 Pull-up 1 GPIO15 Floating – To change the bit values, the strapping pins should be connected to external pull-down/pull-up resistances. If the ESP32-C6 is used as a device by a host MCU, the strapping pin voltage levels can also be controlled by the host MCU. All strapping pins have latches. At system reset, the latches sample the bit values of their respective strapping pins and store them until the chip is powered down or shut down. The states of latches cannot be changed in any other way. It makes the strapping pin values available during the entire chip operation, and the pins are freed up to be used as regular IO pins after reset. Regarding the timing requirements for the strapping pins, there are such parameters as setup time and hold time. For more information, see Table 5 and Figure 4. Table 5: Description of Timing Parameters for the Strapping Pins Parameter tSU Description Min (ms) Setup time is the time reserved for the power rails to stabilize before the CHIP_PU pin is pulled high to activate the chip. 0 Hold time is the time reserved for the chip to read the strapping pin tH values after CHIP_PU is already high and before these pins start 3 operating as regular IO pins. Espressif Systems 12 ESP32-C6-WROOM-1 & WROOM-1U Datasheet v0.6 Submit Documentation Feedback 3 Pin Definitions tSU tH VIL_nRST CHIP_PU VIH Strapping pin Figure 4: Visualization of Timing Parameters for the Strapping Pins 3.3.1 SDIO Sampling and Driving Clock Edge Control The strapping pin MTMS and MTDI can be used to decide on which clock edge to sample signals and drive output lines. See Table 6 SDIO Input Sampling Edge/Output Driving Edge Control. Table 6: SDIO Input Sampling Edge/Output Driving Edge Control MTMS MTDI Edge behavior – (Floating) – (Floating) 0 0 Falling edge sampling, falling edge output 0 1 Falling edge sampling, rising edge output 1 0 Rising edge sampling, falling edge output 1 1 Rising edge sampling, rising edge output Default Configuration 3.3.2 Chip Boot Mode Control GPIO8 and GPIO9 control the boot mode after the reset is released. See Table 7 Boot Mode Control Boot Mode Control. Table 7: Boot Mode Control Boot Mode GPIO8 GPIO9 Default Configuration – (Floating) 1 (Pull-up) SPI Boot (default) Any value 1 1 0 0 0 Download Boot Invalid combination 1 1 This combination triggers unexpected behavior and should be avoided. 3.3.3 ROM Messages Printing Control During boot process the messages by the ROM code can be printed to: Espressif Systems 13 ESP32-C6-WROOM-1 & WROOM-1U Datasheet v0.6 Submit Documentation Feedback 3 Pin Definitions • USB Serial/JTAG controller. For this, EFUSE_DIS_USB_SERIAL_JTAG_ROM_PRINT should be 0 and USB Serial/JTAG controller should be enabled. • UART0. For this, set EFUSE_DIS_USB_SERIAL_JTAG_ROM_PRINT to 1. In this case, EFUSE_UART_PRINT_CONTROL and GPIO8 control ROM messages printing as shown in Table 8 ROM Messages Printing Control. Table 8: ROM Messages Printing Control eFuse1 GPIO8 ROM Code Printing 0 Ignored Always enabled 1 2 3 1 0 Enabled 1 Disabled 0 Disabled 1 Enabled Ignored Always disabled eFuse: EFUSE_UART_PRINT_CONTROL 3.3.4 JTAG Signal Source Control The strapping pin GPIO15 can be used to control the source of JTAG signals during the early boot process. This pin does not have any internal pull resistors and the strapping value must be controlled by the external circuit that cannot be in a high impedance state. As Table 9 shows, GPIO15 is used in combination with EFUSE_DIS_PAD_JTAG, EFUSE_DIS_USB_JTAG, and EFUSE_JTAG_SEL_ENABLE. Table 9: JTAG Signal Source Control eFuse 1a eFuse 2b eFuse 3c GPIO15 0 0 0 Ignored 1 JTAG Signal Source USB Serial/JTAG Controller 0 JTAG pins MTDI, MTCK, MTMS, and MTDO 1 USB Serial/JTAG Controller 0 1 Ignored Ignored JTAG pins MTDI, MTCK, MTMS, and MTDO 1 0 Ignored Ignored USB Serial/JTAG Controller 1 1 Ignored Ignored JTAG is disabled a eFuse 1: EFUSE_DIS_PAD_JTAG b eFuse 2: EFUSE_DIS_USB_JTAG c eFuse 3: EFUSE_JTAG_SEL_ENABLE Espressif Systems 14 ESP32-C6-WROOM-1 & WROOM-1U Datasheet v0.6 Submit Documentation Feedback 4 Electrical Characteristics 4 Electrical Characteristics The values presented in this section are preliminary and may change with the final release of this datasheet. 4.1 Absolute Maximum Ratings Stresses above those listed in Table 10 Absolute Maximum Ratings may cause permanent damage to the device. These are stress ratings only and functional operation of the device at these or any other conditions beyond those indicated under Table 11 Recommended Operating Conditions is not implied. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability. Table 10: Absolute Maximum Ratings Symbol Parameter Min Max Unit VDD33 Power supply voltage –0.3 3.6 V TST ORE Storage temperature –40 105 °C 4.2 Recommended Operating Conditions Table 11: Recommended Operating Conditions Symbol Parameter Min Typ Max Unit VDD33 Power supply voltage 3.0 3.3 3.6 V IV DD Current delivered by external power supply 0.5 — — A TA Operating ambient temperature –40 — 85 °C version 105 °C version 85 °C 105 4.3 DC Characteristics (3.3 V, 25 °C) Table 12: DC Characteristics (3.3 V, 25 °C) Symbol Parameter CIN Pin capacitance VIH Min — High-level input voltage 0.75 × VDD 1 Typ Max Unit 2 — pF — 1 VDD + 0.3 V 1 VIL Low-level input voltage –0.3 — 0.25 × VDD IIH High-level input current — — 50 nA Low-level input current — — 50 nA — — IIL VOH VOL 2 2 High-level output voltage 0.8 × VDD Low-level output voltage 1 V V 1 — — 0.1 × VDD V — 40 — mA — 28 — mA — 45 — kΩ 1 IOH IOL RP U High-level source current (VDD = 3.3 V, VOH >= 2.64 V, PAD_DRIVER = 3) Low-level sink current (VDD1 = 3.3 V, VOL = 0.495 V, PAD_DRIVER = 3) Pull-up resistor Espressif Systems 15 ESP32-C6-WROOM-1 & WROOM-1U Datasheet v0.6 Submit Documentation Feedback 4 Electrical Characteristics RP D VIH_nRST VIL_nRST Pull-down resistor — Chip reset release voltage 0.75 × VDD Chip reset voltage 1 –0.3 1 VDD is the I/O voltage for pins of a particular power domain. 2 VOH and VOL are measured using high-impedance load. 45 — — 1 — kΩ VDD + 0.3 0.25 × VDD V 1 V 4.4 Current Consumption Characteristics 4.4.1 Current Consumption in Active Mode The current consumption measurements are taken with a 3.3 V supply at 25 °C ambient temperature. TX current consumption is rated at a 100% duty cycle. RX current consumption is rated when the peripherals are disabled and the CPU idle. Table 13: Current Consumption for Wi-Fi (2.4 GHz) in Active Mode Work Mode RF Condition TX Active (RF working) RX Description Peak (mA) 802.11b, 1 Mbps, DSSS @ 20.5 dBm 382 802.11g, 54 Mbps, OFDM @ 19.0 dBm 316 802.11n, HT20, MCS7 @ 18.0 dBm 295 802.11n, HT40, MCS7 @ 17.5 dBm 280 802.11ax, MCS9 @ 15.5 dBm 251 802.11b/g/n, HT20 78 802.11n, HT40 82 802.11ax, HE20 78 Table 14: Current Consumption for Bluetooth LE in Active Mode Work Mode RF Condition TX Active (RF working) RX Description Peak (mA) Bluetooth LE @ 20.0 dBm 322 Bluetooth LE @ 9.0 dBm 190 Bluetooth LE @ 0 dBm 130 Bluetooth LE @ –24.0 dBm 90 Bluetooth LE 73 Table 15: Current Consumption for 802.15.4 in Active Mode Work Mode RF Condition TX Active (RF working) RX Espressif Systems Description Peak (mA) 802.15.4 @ 20.0 dBm 316 802.15.4 @ 12.0 dBm 190 802.15.4 @ 0 dBm 120 802.15.4 @ –24.0 dBm 84 802.15.4 73 16 ESP32-C6-WROOM-1 & WROOM-1U Datasheet v0.6 Submit Documentation Feedback 4 Electrical Characteristics Note: The content below is excerpted from Section Current Consumption in Other Modes in ESP32-C6 Series Datasheet. 4.4.2 Current Consumption in Other Modes Table 16: Current Consumption in Modem-sleep Mode Typ (mA) CPU Frequency Mode (MHz) Description 160 Modem-sleep2,3 80 1 All Peripherals All Peripherals Clocks Disabled Clocks Enabled1 CPU is running 27 38 CPU is idle 17 28 CPU is running 19 30 CPU is idle 14 25 In practice, the current consumption might be different depending on which peripherals are enabled. 2 In Modem-sleep mode, Wi-Fi is clock gated. 3 In Modem-sleep mode, the consumption might be higher when accessing flash. Table 17: Current Consumption in Low-Power Modes Mode Description Typ (µA) CPU and wireless communication modules are powered down, peLight-sleep ripheral clocks are disabled, and all GPIOs are high-impedance CPU, wireless communication modules and peripherals are powered down, and all GPIOs are high-impedance 180 35 Deep-sleep RTC timer and LP memory are powered on 7 Power off CHIP_PU is set to low level, the chip is powered off 1 Espressif Systems 17 ESP32-C6-WROOM-1 & WROOM-1U Datasheet v0.6 Submit Documentation Feedback 5 RF Characteristics 5 RF Characteristics This section contains tables with RF characteristics of the Espressif product. The RF data is measured at the antenna port, where RF cable is connected, including the front-end loss. The external antennas used for the tests on the modules with external antenna connectors have an impedance of 50 Ω. Devices should operate in the center frequency range allocated by regional regulatory authorities. The target center frequency range and the target transmit power are configurable by software. See ESP RF Test Tool and Test Guide for instructions. Unless otherwise stated, the RF tests are conducted with a 3.3 V (±5%) supply at 25 ºC ambient temperature. 5.1 Wi-Fi Radio (2.4 GHz/5 GHz) Table 18: Wi-Fi RF Characteristics Name Description Center frequency range of operating channel 2412 ~ 2484 MHz Wi-Fi wireless standard IEEE 802.11b/g/n/ax 5.1.1 Wi-Fi RF Transmitter (TX) Characteristics Table 19: TX Power with Spectral Mask and EVM Meeting 802.11 Standards Min Typ Max (dBm) (dBm) (dBm) 802.11b, 1 Mbps, DSSS — 20.5 — 802.11b, 11 Mbps, CCK — 20.5 — 802.11g, 6 Mbps, OFDM — 20.0 — 802.11g, 54 Mbps, OFDM — 19.0 — 802.11n, HT20, MCS0 — 19.0 — 802.11n, HT20, MCS7 — 18.0 — 802.11n, HT40, MCS0 — 18.5 — 802.11n, HT40, MCS7 — 17.5 — 802.11ax, HE20, MCS0 — 19.0 — 802.11ax, HE20, MCS9 — 15.5 — Rate Table 20: TX EVM Test1 Rate Min Typ Limit (dB) (dB) (dB) 802.11b, 1 Mbps, DSSS — –25.0 –10.0 802.11b, 11 Mbps, CCK — –25.0 –10.0 Cont’d on next page Espressif Systems 18 ESP32-C6-WROOM-1 & WROOM-1U Datasheet v0.6 Submit Documentation Feedback 5 RF Characteristics Table 20 – cont’d from previous page Rate Min Typ Limit (dB) (dB) (dB) 802.11g, 6 Mbps, OFDM — –24.0 –5.0 802.11g, 54 Mbps, OFDM — –28.0 –25.0 802.11n, HT20, MCS0 — –27.5 –5.0 802.11n, HT20, MCS7 — –30.0 –27.0 802.11n, HT40, MCS0 — –27.0 –5.0 802.11n, HT40, MCS7 — –29.5 –27.0 802.11ax, HE20, MCS0 — –27.0 –5.0 802.11ax, HE20, MCS9 — –34.0 –32.0 1 EVM is measured at the corresponding typical TX power provided in Table 19 TX Power with Spectral Mask and EVM Meeting 802.11 Standards above. 5.1.2 Wi-Fi RF Receiver (RX) Characteristics For RX tests, the PER (packet error rate) limit is 8% for 802.11b, and 10% for 802.11g/n/ax. Table 21: RX Sensitivity Min Typ Max (dBm) (dBm) (dBm) 802.11b, 1 Mbps, DSSS — –99.2 — 802.11b, 2 Mbps, DSSS — –96.8 — 802.11b, 5.5 Mbps, CCK — –93.6 — 802.11b, 11 Mbps, CCK — –90.0 — 802.11g, 6 Mbps, OFDM — –94.0 — 802.11g, 9 Mbps, OFDM — –93.0 — 802.11g, 12 Mbps, OFDM — –92.4 — 802.11g, 18 Mbps, OFDM — –90.0 — 802.11g, 24 Mbps, OFDM — –86.8 — 802.11g, 36 Mbps, OFDM — –83.0 — 802.11g, 48 Mbps, OFDM — –78.8 — 802.11g, 54 Mbps, OFDM — –77.6 — 802.11n, HT20, MCS0 — –93.6 — 802.11n, HT20, MCS1 — –92.0 — 802.11n, HT20, MCS2 — –89.4 — 802.11n, HT20, MCS3 — –86.0 — 802.11n, HT20, MCS4 — –82.8 — 802.11n, HT20, MCS5 — –78.6 — 802.11n, HT20, MCS6 — –77.0 — 802.11n, HT20, MCS7 — –75.4 — 802.11n, HT40, MCS0 — –91.0 — 802.11n, HT40, MCS1 — –89.6 — Rate Cont’d on next page Espressif Systems 19 ESP32-C6-WROOM-1 & WROOM-1U Datasheet v0.6 Submit Documentation Feedback 5 RF Characteristics Table 21 – cont’d from previous page Min Typ Max (dBm) (dBm) (dBm) 802.11n, HT40, MCS2 — –87.0 — 802.11n, HT40, MCS3 — –83.4 — 802.11n, HT40, MCS4 — –80.4 — 802.11n, HT40, MCS5 — –76.2 — 802.11n, HT40, MCS6 — –74.6 — 802.11n, HT40, MCS7 — –73.2 — 802.11ax, HE20, MCS0 — –93.8 — 802.11ax, HE20, MCS1 — –91.0 — 802.11ax, HE20, MCS2 — –88.0 — 802.11ax, HE20, MCS3 — –85.6 — 802.11ax, HE20, MCS4 — –82.0 — 802.11ax, HE20, MCS5 — –78.0 — 802.11ax, HE20, MCS6 — –76.6 — 802.11ax, HE20, MCS7 — –74.4 — 802.11ax, HE20, MCS8 — –70.8 — 802.11ax, HE20, MCS9 — –68.6 — Rate Table 22: Maximum RX Level Min Typ Max (dBm) (dBm) (dBm) 802.11b, 1 Mbps, DSSS — 5 — 802.11b, 11 Mbps, CCK — 5 — 802.11g, 6 Mbps, OFDM — 5 — 802.11g, 54 Mbps, OFDM — 0 — 802.11n, HT20, MCS0 — 5 — 802.11n, HT20, MCS7 — 0 — 802.11n, HT40, MCS0 — 5 — 802.11n, HT40, MCS7 — 0 — 802.11ax, HE20, MCS0 — 5 — 802.11ax, HE20, MCS9 — 0 — Rate Table 23: RX Adjacent Channel Rejection Rate Min Typ Max (dB) (dB) (dB) 802.11b, 1 Mbps, DSSS — 38 — 802.11b, 11 Mbps, CCK — 38 — 802.11g, 6 Mbps, OFDM — 31 — 802.11g, 54 Mbps, OFDM — 20 — Cont’d on next page Espressif Systems 20 ESP32-C6-WROOM-1 & WROOM-1U Datasheet v0.6 Submit Documentation Feedback 5 RF Characteristics Table 23 – cont’d from previous page Rate Min Typ Max (dB) (dB) (dB) 802.11n, HT20, MCS0 — 31 — 802.11n, HT20, MCS7 — 16 — 802.11n, HT40, MCS0 — 28 — 802.11n, HT40, MCS7 — 10 — 802.11ax, HE20, MCS0 — 25 — 802.11ax, HE20, MCS9 — 2 — 5.2 Bluetooth 5 (LE) Radio Table 24: Bluetooth LE RF Characteristics Name Description Center frequency range of operating channel 2402 ~ 2480 MHz RF transmit power range –24.0 ~ 20.0 dBm 5.2.1 Bluetooth LE RF Transmitter (TX) Characteristics Table 25: Bluetooth LE - Transmitter Characteristics - 1 Mbps Parameter Description Carrier frequency offset and drift Modulation characteristics Min Max Unit Max. |fn |n=0, 1, 2, 3, ...k — 1.3 — kHz Max. |f0 − fn |n=2, 3, 4, ...k — 1.5 — kHz Max. |fn − fn−5 |n=6, 7, 8, ...k — 0.9 — kHz |f1 − f0 | — 0.6 — kHz ∆ F 1avg — 249.9 — kHz — 212.1 — kHz ∆ F 2avg /∆ F 1avg — 0.88 — — ± 2 MHz offset — –29 — dBm ± 3 MHz offset — –36 — dBm > ± 3 MHz offset — –39 — dBm Min. ∆ F 2max (for at least 99.9% of all ∆ F 2max ) In-band emissions Typ Table 26: Bluetooth LE - Transmitter Characteristics - 2 Mbps Parameter Carrier frequency offset and drift Description Min Max Unit Max. |fn |n=0, 1, 2, 3, ...k — 2.2 — kHz Max. |f0 − fn |n=2, 3, 4, ...k — 1.1 — kHz Max. |fn − fn−5 |n=6, 7, 8, ...k — 1.1 — kHz |f1 − f0 | — 0.5 — kHz ∆ F 1avg — 499.4 — kHz Cont’d on next page Modulation characteristics Espressif Systems Typ 21 ESP32-C6-WROOM-1 & WROOM-1U Datasheet v0.6 Submit Documentation Feedback 5 RF Characteristics Table 26 – cont’d from previous page Parameter Description Min Min. ∆ F 2max (for at least Max Unit — 443.5 — kHz ∆ F 2avg /∆ F 1avg — 0.95 — — ± 4 MHz offset — –40 — dBm ± 5 MHz offset — –41 — dBm > ± 5 MHz offset — –42 — dBm 99.9% of all ∆ F 2max ) In-band emissions Typ Table 27: Bluetooth LE - Transmitter Characteristics - 125 Kbps Parameter Description Carrier frequency offset and drift Modulation characteristics Min Max Unit Max. |fn |n=0, 1, 2, 3, ...k — 0.7 — kHz Max. |f0 − fn |n=1, 2, 3, ...k — 0.3 — kHz |f0 − f3 | — 0.1 — kHz Max. |fn − fn−3 |n=7, 8, 9, ...k — 0.4 — kHz ∆ F 1avg — 250.0 — kHz — 238.0 — kHz ± 2 MHz offset — –29 — dBm ± 3 MHz offset — –36 — dBm > ± 3 MHz offset — –39 — dBm Min. ∆ F 1max (for at least 99.9% of all ∆ F 1max ) In-band emissions Typ Table 28: Bluetooth LE - Transmitter Characteristics - 500 Kbps Parameter Description Carrier frequency offset and drift Modulation characteristics Min Max Unit Max. |fn |n=0, 1, 2, 3, ...k — 0.5 — kHz Max. |f0 − fn |n=1, 2, 3, ...k — 0.3 — kHz |f0 − f3 | — 0.1 — kHz Max. |fn − fn−3 |n=7, 8, 9, ...k — 0.4 — kHz ∆ F 2avg — 230.7 — kHz — 217.6 — kHz ± 2 MHz offset — –28 — dBm ± 3 MHz offset — –36 — dBm > ± 3 MHz offset — –39 — dBm Min. ∆ F 2max (for at least 99.9% of all ∆ F 2max ) In-band emissions Typ 5.2.2 Bluetooth LE RF Receiver (RX) Characteristics Table 29: Bluetooth LE - Receiver Characteristics - 1 Mbps Parameter Description Min Sensitivity @30.8% PER — — Maximum received signal @30.8% PER — — Typ Max Unit –98.0 — dBm 8 — dBm Cont’d on next page Espressif Systems 22 ESP32-C6-WROOM-1 & WROOM-1U Datasheet v0.6 Submit Documentation Feedback 5 RF Characteristics Table 29 – cont’d from previous page Parameter Description Min F = F0 MHz — 7 — dB F = F0 + 1 MHz — 4 — dB F = F0 – 1 MHz — 3 — dB F = F0 + 2 MHz — –21 — dB F = F0 – 2 MHz — –22 — dB F = F0 + 3 MHz — –28 — dB F = F0 – 3 MHz — –36 — dB F ≥ F0 + 4 MHz — –27 — dB F ≤ F0 – 4 MHz — –36 — dB Image frequency — — –26 — dB Adjacent channel to F = Fimage + 1 MHz — –29 — dB image frequency F = Fimage – 1 MHz — –28 — dB 30 MHz ~ 2000 MHz — –16 — dBm 2003 MHz ~ 2399 MHz — –24 — dBm 2484 MHz ~ 2997 MHz — –16 — dBm 3000 MHz ~ 12.75 GHz — –1 — dBm — — –27 — dBm Max Unit Co-channel Adjacent channel C/I and receiver selectivity performance Out-of-band blocking performance Intermodulation Typ Max Unit Table 30: Bluetooth LE - Receiver Characteristics - 2 Mbps Parameter Description Sensitivity @30.8% PER — — –95.0 — dBm Maximum received signal @30.8% PER — — 8 — dBm F = F0 MHz — 8 — dB F = F0 + 2 MHz — 3 — dB F = F0 – 2 MHz — 2 — dB F = F0 + 4 MHz — –23 — dB F = F0 – 4 MHz — –25 — dB F = F0 + 6 MHz — –31 — dB F = F0 – 6 MHz — –35 — dB F ≥ F0 + 8 MHz — –36 — dB F ≤ F0 – 8 MHz — –36 — dB Image frequency — — –23 — dB Adjacent channel to F = Fimage + 2 MHz — –30 — dB image frequency F = Fimage – 2 MHz — 3 — dB 30 MHz ~ 2000 MHz — –18 — dBm 2003 MHz ~ 2399 MHz — –28 — dBm 2484 MHz ~ 2997 MHz — –16 — dBm 3000 MHz ~ 12.75 GHz — –1 — dBm — — –29 — dBm Co-channel C/I and receiver Adjacent channel selectivity performance Out-of-band blocking performance Intermodulation Espressif Systems 23 Min Typ ESP32-C6-WROOM-1 & WROOM-1U Datasheet v0.6 Submit Documentation Feedback 5 RF Characteristics Table 31: Bluetooth LE - Receiver Characteristics - 125 Kbps Parameter Description Max Unit Sensitivity @30.8% PER — — –105.5 — dBm Maximum received signal @30.8% PER — — 8 — dBm F = F0 MHz — 2 — dB F = F0 + 1 MHz — –1 — dB F = F0 – 1 MHz — –3 — dB F = F0 + 2 MHz — –31 — dB F = F0 – 2 MHz — –27 — dB F = F0 + 3 MHz — –33 — dB F = F0 – 3 MHz — –42 — dB F ≥ F0 + 4 MHz — –31 — dB F ≤ F0 – 4 MHz — –48 — dB Image frequency — — –31 — dB Adjacent channel to F = Fimage + 1 MHz — –36 — dB image frequency F = Fimage – 1 MHz — –33 — dB Co-channel Adjacent channel C/I and receiver selectivity performance Min Typ Table 32: Bluetooth LE - Receiver Characteristics - 500 Kbps Parameter Description Max Unit Sensitivity @30.8% PER — — –101.5 — dBm Maximum received signal @30.8% PER — — 8 — dBm F = F0 MHz — 4 — dB F = F0 + 1 MHz — 1 — dB F = F0 – 1 MHz — –1 — dB F = F0 + 2 MHz — –23 — dB F = F0 – 2 MHz — –24 — dB F = F0 + 3 MHz — –33 — dB F = F0 – 3 MHz — –41 — dB F ≥ F0 + 4 MHz — –31 — dB F ≤ F0 – 4 MHz — –41 — dB Image frequency — — –30 — dB Adjacent channel to F = Fimage + 1 MHz — –35 — dB image frequency F = Fimage – 1 MHz — –27 — dB Co-channel Adjacent channel C/I and receiver selectivity performance Min Typ 5.3 802.15.4 Radio Table 33: 802.15.4 RF Characteristics Name Description Center frequency range of operating channel 2405 ~ 2480 MHz 1 Zigbee in the 2.4 GHz range supports 16 channels at 5 MHz spacing from channel 11 to channel 26. Espressif Systems 24 ESP32-C6-WROOM-1 & WROOM-1U Datasheet v0.6 Submit Documentation Feedback 5 RF Characteristics 5.3.1 802.15.4 RF Transmitter (TX) Characteristics Table 34: 802.15.4 Transmitter Characteristics - 250 Kbps Parameter Min RF transmit power range –24.0 — 20.0 dBm — 13% — — EVM Typ Max Unit 5.3.2 802.15.4 RF Receiver (RX) Characteristics Table 35: 802.15.4 Receiver Characteristics - 250 Kbps Parameter Description Sensitivity @1% PER — — Maximum received signal @1% PER — Adjacent channel Relative jamming level Alternate channel Espressif Systems Max Unit –104.0 — dBm — 8 — dBm F = F0 + 5 MHz — 27 — dB F = F0 – 5 MHz — 32 — dB F = F0 + 10 MHz — 47 — dB F = F0 – 10 MHz — 50 — dB 25 Min Typ ESP32-C6-WROOM-1 & WROOM-1U Datasheet v0.6 Submit Documentation Feedback 6 Module Schematics This is the reference design of the module. GND 40MHz GND XOUT C4 TBD 2 The value of R4 varies with the actual PCB board. VDD33 GND GND GPIO23 GPIO22 GPIO21 GPIO20 GPIO19 GPIO18 GND C9 10uF 1uF 0.1uF 0.1uF GND GND GND GND ANT1 C11 TBD LNA_IN C12 CHIP_EN PCB_ANT TBD ESP32-C6-WROOM-1 & WROOM-1U Datasheet v0.6 GND GND The values of C11, L2 and C12 vary with the actual PCB board. NC: No component. TBD GND GPIO0 GPIO1 GPIO2 GPIO3 GPIO4 1 2 3 4 5 6 7 8 9 10 ANT VDDA3P3 VDDA3P3 CHIP_EN VDDPST1 XTAL_32K_P XTAL_32K_N GPIO2 GPIO3 MTMS VDD33 C15 U1 0.1uF GND 3V3 EN IO4 IO5 IO6 IO7 IO0 IO1 IO8 IO10 IO11 IO12 IO13 C10 VDD33 0.1uF ESP32-C6-WROOM-1(Pin-out) U0RXD U0TXD VDDPST2 GPIO15 SPID SPICLK SPIHD VDD_SPI SPIWP SPIQ 30 29 28 27 26 25 24 23 22 21 MTDI MTCK MTDO GPIO8 GPIO9 GPIO10 GPIO11 GPIO12 GPIO13 SPICS0 L2 GND R3 499 U0RXD U0TXD R16 R15 R14 0 0 0 GPIO15 SPID SPICLK SPIHD R13 R10 0 0 SPIWP SPIQ C16 C17 0.1uF 1uF VDD_SPI ESP32-C6-QFN40 GND GND GND GPIO5 GPIO6 GPIO7 GPIO8 GPIO9 GPIO10 GPIO11 GPIO12 GPIO13 SPICS0 RF_ANT 1 2 R4 C8 40 39 38 37 36 35 34 33 32 31 GND C7 GND 0 2.0nH(0.1nH) C6 VDDA2 XTAL_P XTAL_N VDDA1 SDIO_DATA3 SDIO_DATA2 SDIO_DATA1 SDIO_DATA0 SDIO_CLK SDIO_CMD L1 R17 41 GND 11 12 13 14 15 16 17 18 19 20 VDD33 1 2 3 4 5 6 7 8 9 10 11 12 13 14 VDD_SPI R8 10K(NC) 8 10nF CHIP_EN GPIO4 GPIO5 D1 GPIO6 ESD GPIO7 GPIO0 GPIO1 GPIO8 GPIO10 GND GPIO11 GPIO12 GPIO13 ESP32-C6-WROOM-1 29 EPAD 28 GND 27 IO2 26 IO3 25 TXD0 24 RXD0 23 IO15 22 NC 21 IO23 20 IO22 19 IO21 18 IO20 17 IO19 16 IO18 15 IO9 SPICS0 1 SPICLK 6 SPIHD 7 VCC 1uF 0 C2 26 Submit Documentation Feedback C3 GND U3 /CS CLK /HOLD U2 GND VDD33 GND 1 TBD XIN C1 The values of C1 and C4 vary with the selection of the crystal. Y1 3 GND 4 GND 4 Espressif Systems 6 Module Schematics GND Figure 5: ESP32-C6-WROOM-1 Schematics DI DO /WP FLASH 5 SPID 2 SPIQ 3 SPIWP GPIO2 GPIO3 U0TXD U0RXD GPIO15 GPIO23 GPIO22 GPIO21 GPIO20 GPIO19 GPIO18 GPIO9 GND XOUT TBD VDD33 GND GND GPIO23 GPIO22 GPIO21 GPIO20 GPIO19 GPIO18 GND 0.1uF 0.1uF TBD LNA_IN ANT1 CHIP_EN CONN GND L2 D2 ESD(NC) GND C11 TBD GND ESP32-C6-WROOM-1 & WROOM-1U Datasheet v0.6 The values of C11, L2 and C12 vary with the actual PCB board. C12 TBD GPIO0 GPIO1 GPIO2 GPIO3 GPIO4 GND 1 2 3 4 5 6 7 8 9 10 ANT VDDA3P3 VDDA3P3 CHIP_EN VDDPST1 XTAL_32K_P XTAL_32K_N GPIO2 GPIO3 MTMS VDD33 C15 U1 0.1uF C10 ESP32-C6-WROOM-1U(Pin-out) U0RXD U0TXD VDDPST2 GPIO15 SPID SPICLK SPIHD VDD_SPI SPIWP SPIQ 30 29 28 27 26 25 24 23 22 21 R3 499 U0RXD U0TXD R16 R15 R14 0 0 0 GPIO15 SPID SPICLK SPIHD R13 R10 0 0 SPIWP SPIQ C16 C17 0.1uF 1uF VDD_SPI ESP32-C6-QFN40 GND NC: No component. VDD33 0.1uF MTDI MTCK MTDO GPIO8 GPIO9 GPIO10 GPIO11 GPIO12 GPIO13 SPICS0 RF_ANT GND GND GND GND GPIO5 GPIO6 GPIO7 GPIO8 GPIO9 GPIO10 GPIO11 GPIO12 GPIO13 SPICS0 3 1 GND R4 1uF 40 39 38 37 36 35 34 33 32 31 10uF GND C9 27 Submit Documentation Feedback C8 VDDA2 XTAL_P XTAL_N VDDA1 SDIO_DATA3 SDIO_DATA2 SDIO_DATA1 SDIO_DATA0 SDIO_CLK SDIO_CMD GND C7 GND 0 2.0nH(0.1nH) C6 GND 2 R17 41 L1 GND 11 12 13 14 15 16 17 18 19 20 VDD33 EPAD GND IO2 IO3 TXD0 RXD0 IO15 NC IO23 IO22 IO21 IO20 IO19 IO18 IO9 GND 3V3 EN IO4 IO5 IO6 IO7 IO0 IO1 IO8 IO10 IO11 IO12 IO13 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 VDD_SPI R8 10K(NC) 8 10nF 1 2 3 4 5 6 7 8 9 10 11 12 13 14 SPICS0 1 SPICLK 6 SPIHD 7 VCC 1uF CHIP_EN GPIO4 GPIO5 D1 GPIO6 ESD GPIO7 GPIO0 GPIO1 GPIO8 GPIO10 GPIO11 GND GPIO12 GPIO13 ESP32-C6-WROOM-1U /CS CLK /HOLD U2 DI DO GND C2 0 C3 GND U3 4 40MHz C4 2 The value of R4 varies with the actual PCB board. VDD33 GND 1 TBD XIN C1 The values of C1 and C4 vary with the selection of the crystal. Y1 3 GND 4 GND /WP FLASH GND Figure 6: ESP32-C6-WROOM-1U Schematics 5 SPID 2 SPIQ 3 SPIWP GPIO2 GPIO3 U0TXD U0RXD GPIO15 GPIO23 GPIO22 GPIO21 GPIO20 GPIO19 GPIO18 GPIO9 6 Module Schematics Espressif Systems GND 7 Peripheral Schematics 7 Peripheral Schematics This is the typical application circuit of the module connected with peripheral components (for example, power supply, antenna, reset button, JTAG interface, and UART interface). GND VDD33 VDD33 R1 TBD SW1 R2 C4 U1 C1 C2 22uF 0.1uF EN 0 0.1uF GND C3 TBD GND EN IO4 IO5 IO6 IO7 IO0 IO1 IO8 IO10 IO11 IO12 IO13 GND JP4 4 3 2 1 4 3 2 1 GND TMS TDI TCK TDO 1 2 3 4 5 6 7 8 9 10 11 12 13 14 GND ESP32-C6-WROOM-1 ESP32-C6-WROOM-1U EPAD GND IO2 IO3 TXD0 RXD0 IO15 NC IO23 IO22 IO21 IO20 IO19 IO18 IO9 GND 3V3 EN IO4 IO5 IO6 IO7 IO0 IO1 IO8 IO10 IO11 IO12 IO13 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 VDD33 IO2 IO3 TXD0 RXD0 IO15 JP1 1 2 3 4 IO23 IO22 IO21 IO20 IO19 IO18 IO9 UART GND JP2 1 2 JTAG C5 Boot Option 12pF(NC) JP3 R5 X1 32.768KHz(NC) 1 GND X1: ESR = Max. 70 KΩ R3 0(NC) R4 0(NC) R6 R7 C7 2 GND C6 USB_D+ USB_D- TBD TBD NC IO8 1 2 GND VDD33 R8 10K 1 2 3 4 TBD 2 1 C8 TBD 2 1 USB NC: No component. 12pF(NC) GND GND Figure 7: Peripheral Schematics • Soldering the EPAD to the ground of the base board is not a must, however, it can optimize thermal performance. If you choose to solder it, please apply the correct amount of soldering paste. Too much soldering paste may increase the gap between the module and the baseboard. As a result, the adhesion between other pins and the baseboard may be poor. • To ensure that the power supply to the ESP32-C6 chip is stable during power-up, it is advised to add an RC delay circuit at the EN pin. The recommended setting for the RC delay circuit is usually R = 10 kΩ and C = 1 µF. However, specific parameters should be adjusted based on the power-up timing of the module and the power-up and reset sequence timing of the chip. For ESP32-C6’s power-up and reset sequence timing diagram, please refer to ESP32-C6 Series Datasheet > Section Power Supply. Espressif Systems 28 ESP32-C6-WROOM-1 & WROOM-1U Datasheet v0.6 Submit Documentation Feedback 8 Physical Dimensions and PCB Land Pattern 8 Physical Dimensions and PCB Land Pattern 8.1 Physical Dimensions Unit: mm 3.1±0.15 0.8 0.8 0.45 12.29 1.05 0.98 28 x 0.45 7.495 3.3 0.45 0.8 0. 28 x 0.9 17.6 28 x Ø0.55 Ø 1.5 3.3 1.27 15.8 5 25.5±0.25 16.51 28 x 0.9 1.27 6 18±0.25 28 x 0.85 Top View Bottom View Side View Figure 8: ESP32-C6-WROOM-1 Physical Dimensions Unit: mm 18±0.25 3.2±0.15 0.8 12.29 7.495 3.3 0.45 0.8 28 x 0.9 1.1 13.05 17.5 28 x 0.45 0.8 0.45 2.46 28 x Ø0.55 15.65 1.5 16.51 28 x 0.9 1.27 10.75 19.2±0.25 3.3 1.27 3 28 x 0.85 1.08 Top View Bottom View Side View Figure 9: ESP32-C6-WROOM-1U Physical Dimensions Note: For information about tape, reel, and product marking, please refer to Espressif Module Packaging Information. Espressif Systems 29 ESP32-C6-WROOM-1 & WROOM-1U Datasheet v0.6 Submit Documentation Feedback 8 Physical Dimensions and PCB Land Pattern 8.2 Recommended PCB Land Pattern This section provides the following resources for your reference: • Figures for recommended PCB land patterns with all the dimensions needed for PCB design. See Figure 10 ESP32-C6-WROOM-1 Recommended PCB Land Pattern and Figure 11 ESP32-C6-WROOM-1U Recommended PCB Land Pattern. • Source files of recommended PCB land patterns to measure dimensions not covered in Figure 10. You can view the source files for ESP32-C6-WROOM-1 with Autodesk Viewer. Unit: mm Via for thermal pad Copper 3.3 1.27 3.3 25.5 28 12.29 1.5 0.8 0.45 0.45 0.8 28x0.9 1 16.51 6 Antenna Area 28x1.5 7.49 18 7.495 15 14 0.5 17.5 Figure 10: ESP32-C6-WROOM-1 Recommended PCB Land Pattern Espressif Systems 30 ESP32-C6-WROOM-1 & WROOM-1U Datasheet v0.6 Submit Documentation Feedback 8 Physical Dimensions and PCB Land Pattern Unit: mm Via for thermal pad Copper 18 28x1.5 28 12.29 19.2 1.27 3.3 0.45 0.8 28x0.9 1.5 16.51 0.8 0.45 1.19 3.3 1 7.495 15 14 0.5 17.5 Figure 11: ESP32-C6-WROOM-1U Recommended PCB Land Pattern Espressif Systems 31 ESP32-C6-WROOM-1 & WROOM-1U Datasheet v0.6 Submit Documentation Feedback 8 Physical Dimensions and PCB Land Pattern 8.3 Dimensions of External Antenna Connector ESP32-C6-WROOM-1U uses the first generation external antenna connector as shown in Figure 12 Dimensions of External Antenna Connector. This connector is compatible with the following connectors: • U.FL Series connector from Hirose • MHF I connector from I-PEX • AMC connector from Amphenol Unit: mm Figure 12: Dimensions of External Antenna Connector Espressif Systems 32 ESP32-C6-WROOM-1 & WROOM-1U Datasheet v0.6 Submit Documentation Feedback 9 Product Handling 9 Product Handling 9.1 Storage Conditions The products sealed in moisture barrier bags (MBB) should be stored in a non-condensing atmospheric environment of < 40 °C and 90%RH. The module is rated at the moisture sensitivity level (MSL) of 3. After unpacking, the module must be soldered within 168 hours with the factory conditions 25±5 °C and 60%RH. If the above conditions are not met, the module needs to be baked. 9.2 Electrostatic Discharge (ESD) • Human body model (HBM): ±2000 V • Charged-device model (CDM): ±500 V 9.3 Soldering Profile 9.3.1 Reflow Profile Temperature (℃) Solder the module in a single reflow. Peak Temp. 235 ~ 250 ℃ 250 Preheating zone 150 ~ 200 ℃ 60 ~ 120 s 217 200 Reflow zone 217 ℃ 60 ~ 90 s Cooling zone –1 ~ –5 ℃/s Soldering time > 30 s Ramp-up zone 1 ~ 3 ℃/s 100 50 25 Time (sec.) 0 0 50 100 150 200 250 Ramp-up zone — Temp.: 25 ~ 150 ℃ Time: 60 ~ 90 s Ramp-up rate: 1 ~ 3 ℃/s Preheating zone — Temp.: 150 ~ 200 ℃ Time: 60 ~ 120 s Reflow zone — Temp.: >217 ℃ 60 ~ 90 s; Peak Temp.: 235 ~ 250 ℃ Time: 30 ~ 70 s Cooling zone — Peak Temp. ~ 180 ℃ Ramp-down rate: –1 ~ –5 ℃/s Solder — Sn-Ag-Cu (SAC305) lead-free solder alloy Figure 13: Reflow Profile Espressif Systems 33 ESP32-C6-WROOM-1 & WROOM-1U Datasheet v0.6 Submit Documentation Feedback 9 Product Handling 9.4 Ultrasonic Vibration Avoid exposing Espressif modules to vibration from ultrasonic equipment, such as ultrasonic welders or ultrasonic cleaners. This vibration may induce resonance in the in-module crystal and lead to its malfunction or even failure. As a consequence, the module may stop working or its performance may deteriorate. Espressif Systems 34 ESP32-C6-WROOM-1 & WROOM-1U Datasheet v0.6 Submit Documentation Feedback 10 Related Documentation and Resources 10 Related Documentation and Resources Related Documentation • ESP32-C6 Series Datasheet – Specifications of the ESP32-C6 hardware. • ESP32-C6 Technical Reference Manual – Detailed information on how to use the ESP32-C6 memory and peripherals. • ESP32-C6 Hardware Design Guidelines – Guidelines on how to integrate the ESP32-C6 into your hardware product. • Certificates https://espressif.com/en/support/documents/certificates • Documentation Updates and Update Notification Subscription https://espressif.com/en/support/download/documents Developer Zone • ESP-IDF and other development frameworks on GitHub. https://github.com/espressif • ESP32 BBS Forum – Engineer-to-Engineer (E2E) Community for Espressif products where you can post questions, share knowledge, explore ideas, and help solve problems with fellow engineers. https://esp32.com/ • The ESP Journal – Best Practices, Articles, and Notes from Espressif folks. https://blog.espressif.com/ • See the tabs SDKs and Demos, Apps, Tools, AT Firmware. https://espressif.com/en/support/download/sdks-demos Products • ESP32-C6 Series SoCs – Browse through all ESP32-C6 SoCs. https://espressif.com/en/products/socs?id=ESP32-C6 • ESP32-C6 Series Modules – Browse through all ESP32-C6-based modules. https://espressif.com/en/products/modules?id=ESP32-C6 • ESP32-C6 Series DevKits – Browse through all ESP32-C6-based devkits. https://espressif.com/en/products/devkits?id=ESP32-C6 • ESP Product Selector – Find an Espressif hardware product suitable for your needs by comparing or applying filters. https://products.espressif.com/#/product-selector?language=en Contact Us • See the tabs Sales Questions, Technical Enquiries, Circuit Schematic & PCB Design Review, Get Samples (Online stores), Become Our Supplier, Comments & Suggestions. https://espressif.com/en/contact-us/sales-questions Espressif Systems 35 ESP32-C6-WROOM-1 & WROOM-1U Datasheet v0.6 Submit Documentation Feedback Revision History Revision History Date Version Release notes 2023-04-17 v0.6 Added information about ESP32-C6-WROOM-1U module 2023-02-16 v0.5 Preliminary release Espressif Systems 36 ESP32-C6-WROOM-1 & WROOM-1U Datasheet v0.6 Submit Documentation Feedback Disclaimer and Copyright Notice Information in this document, including URL references, is subject to change without notice. ALL THIRD PARTY’S INFORMATION IN THIS DOCUMENT IS PROVIDED AS IS WITH NO WARRANTIES TO ITS AUTHENTICITY AND ACCURACY. NO WARRANTY IS PROVIDED TO THIS DOCUMENT FOR ITS MERCHANTABILITY, NONINFRINGEMENT, FITNESS FOR ANY PARTICULAR PURPOSE, NOR DOES ANY WARRANTY OTHERWISE ARISING OUT OF ANY PROPOSAL, SPECIFICATION OR SAMPLE. All liability, including liability for infringement of any proprietary rights, relating to use of information in this document is disclaimed. No licenses express or implied, by estoppel or otherwise, to any intellectual property rights are granted herein. The Wi-Fi Alliance Member logo is a trademark of the Wi-Fi Alliance. The Bluetooth logo is a registered trademark of Bluetooth SIG. www.espressif.com All trade names, trademarks and registered trademarks mentioned in this document are property of their respective owners, and are hereby acknowledged. Copyright © 2023 Espressif Systems (Shanghai) Co., Ltd. All rights reserved.
ESP32-C6-WROOM-1-N8 价格&库存
很抱歉,暂时无法提供与“ESP32-C6-WROOM-1-N8”相匹配的价格&库存,您可以联系我们找货
