DESCRIPTION: POWER / SIGNAL - SOLDER CUP - MALE - MACHINED
SPECIFICATIONS:
ELECTRICAL:
INSULATOR RESISTANCE:
DIELECTRIC WITHSTANDING:
OPERATING TEMPERATURE:
POWER CONTACT RESISTANCE:
SIGNAL CONTACT RESISTANCE:
POWER PINS:
SIGNAL PINS:
2.732 [69.40]
±0.010 [±0.25]
2.500 [63.50]
±0.010 [±0.25]
2.181 [55.40]
±0.010 [±0.25]
1.787 [45.40]
Ø 0.120 [Ø3.05]
2-PLACES
1.226 [31.14]
MECHANICAL:
CONTACT INSERTION FORCE:
CONTACT SEPARATOR FORCE:
MATERIALS:
A1
A2
1 2 3
4 5
6 7
8 9 A3
0.492 [12.50]
±0.010 [±0.25]
10 11 12 13 14 15 16 17
0.112
[2.84]
10°
0.109 [2.77]
4.5 Kg Max.
0.3Kg Min.
COPPER ALLOY
PBT UL94V-0 RATED, BLK
230°C PROCESS TEMP.
STEEL
CONTACTS:
INSULATOR:
A4
5 G OHMS Min.
1,000VAC r.m.s.
-55° C ~ +125° C
2.0 mOhms MAX.
10 mOhms MAX.
SEE PART NUMBER BELOW
5 AMPS
SHELL:
FINISH:
NICKEL
FULL GOLD FLASH
SHELL:
CONTACTS:
0.327 [8.30]
±0.010 [±0.25]
0.433 [11.00]
0.240 [6.10]
680M21WA4PLYY1
2 = 20 AMP
4 = 40 AMP
0.031 [0.80]
±0.008 [±0.30]
SEE SHEET 2
FOR DETAILS
RoHS COMPLIANT
N
C
THESE DRAWINGS AND SPECIFICATIONS ARE
THE PROPERTY OF NorComp AND SHALL NOT
BE REPRODUCED, COPIED OR USED AS THE
BASIS FOR THE MANUFACTURE OR SALE OF
APPARATUS WITHOUT WRITTEN PERMISSION.
M. SIGMON
DATE:
03/18/2013
= NO HARDWARE
= 0.098" CN SOLDER SIDE
= 0.236" CN SOLDER SIDE
= 0.236" CN MATING SIDE
1 = GOLD FLASH
*CONTACT NORCOMP FOR MORE OPTIONS
UNITS = inch [mm]
DRAWN:
2
3
DO NOT SCALE FROM DRAWING
NorComp
SCALE:
SHEET
NTS
DWG NO.
REV
OF
1
2
680M21WA4PLYY1
5
HARDWARE OPTIONS
CLINCH NUTS HAVE #4-40 INTERNAL THREADS THRU
1 ..... 0.098" SOLDER SIDE
0 ..... NO HARDWARE
2 ..... 0.236" SOLDER SIDE
3 ..... 0.236" MATING SIDE
NOTE:
SIGNAL AND POWER CONTACTS
COME PRE-LOADED INTO INSULATORS
0.394
[10.00]
0.138 [3.50]
Ø 0.061 [1.55]
0.045
[1.14]
0.045
[1.14]
N
C
Ø 0.142 [3.60]
0.045
[1.14]
Ø 0.217 [5.50]
SIGNAL CONTACTS
ACCEPTS UP TO 20 AWG WIRE
Ø 0.181 [4.60]
INSIDE
DIAMETER
Ø 0.106 [2.70]
INSIDE
DIAMETER
Ø 0.03 [0.91]
INSIDE
DIAMETER
RoHS COMPLIANT
0.394
[10.00]
20 AMP POWER CONTACTS
ACCEPTS UP TO 12 AWG WIRE
UNITS = inch [mm]
DRAWN:
M. SIGMON
DATE:
03/18/2013
40 AMP POWER CONTACTS
ACCEPTS UP TO 8 AWG WIRE
NorComp
SCALE:
SHEET
NTS
DWG NO.
REV
OF
2
2
680M21WA4PLYY1
5
很抱歉,暂时无法提供与“680M21WA4PL211”相匹配的价格&库存,您可以联系我们找货
