SFX836UYA02
SFX836UYA02
    WISOL(威盛)
    SMD
    SFX836UYA02
SFX836UYA02 数据手册
SPECIFICATION Surface Acoustic Wave Filter USER USER PART No. SEMCO PART No. SFX836UYA02 DOC. No. SMS-51-L-SFT D0-91 DATE Aug REVISION 000 07, 2014 WISOL Park. Doo-Cheol Moon. Gil-Sub Byun, Kyung-Su ISSUED APPROVED APPROVED BY BY (R&D) BY (QC) User ISSUED CHECKED APPROVED BY BY BY WISOL CO., LTD. 531-7, Gajang-ro, Osan-si, Gyeonggi-do, KOREA, 447-210 http://www.wisol.co.kr Surface Acoustic Wave Filter UMTS B5 DPX - Tx 836.5MHz UMTS B5 DPX - Rx 881.5MHz SFX836UYA02 3 1.8×1.4×0.58mm 8pin lay-out Version: 000 A TABLE OF CONTENTS 1. REVISION HISTORY ..................................................................................................................................... 3 2. DEFINITION .................................................................................................................................................. 4 3. PRECAUTIONS ............................................................................................................................................. 4 4. OUTLINE DRAWING & DIMENSIONS.......................................................................................................... 5 5. MARKING ...................................................................................................................................................... 6 6. PERFORMANCE ........................................................................................................................................... 7 6-1. MAXIMUM RATINGS .......................................................................................................................... 7 6-2. ELECTRICAL CHARACTERISTICS ................................................................................................... 7 7. RELIABILITY ............................................................................................................................................... 13 7-1. ENGINEERING SAMPLE FLOW CHART ......................................................................................... 13 7-2. TEST ITEM & CONDITION ............................................................................................................... 14 8. REFLOW CONDITION ................................................................................................................................ 15 9. RECOMMENDED PCB DIMENSIONS ....................................................................................................... 15 10. CAUTION ................................................................................................................................................... 16 11. PACKING ................................................................................................................................................... 17 11-1. DIMENSIONS.................................................................................................................................. 17 11-2. REELING QUANTITY ..................................................................................................................... 18 11-3. TAPING STRUCTURE .................................................................................................................... 18 11-4. INNER BOX(Reel Packing) STRUCTURE ...................................................................................... 19 11-5. OUTER BOX STRUCTURE ............................................................................................................ 20 12. TAPE SPECIFICATIONS .......................................................................................................................... 21 13. RoHS DATA ............................................................................................................................................... 22 SMS-51-L-SFT D0-91 Page 2/27 Aug 07, 2014 Surface Acoustic Wave Filter UMTS B5 DPX - Tx 836.5MHz UMTS B5 DPX - Rx 881.5MHz SFX836UYA02 3 1.8×1.4×0.58mm 8pin lay-out Version: 000 1. REVISION HISTORY 000 Aug 07, 2014 SMS-51-L-SFT D0-91 All Page Make specification Page 3/27 Aug 07, 2014 Surface Acoustic Wave Filter SFX836UYA02 UMTS B5 DPX - Tx 836.5MHz UMTS B5 DPX - Rx 881.5MHz 3 1.8×1.4×0.58mm 8pin lay-out Version: 000 2. DEFINITION 2-1. PART No. S F X 836 U YA 0 2 ① ② ③ ④ ⑤ No. ⑥ EXPLANATION ① SAW Filter ② Design Type ③ Center Frequency: ④ Input/Output 50ohm/ 100ohm//8.2nH, mirror Type ⑤ Package size: 1.8×1.4mm² ⑥ Design Revision (02 : Molding Type) TX 836.5MHz (824~849MHz) 2-2. APPLICATION : UMTS B5 DPX 3. PRECAUTIONS 3-1. This device should not be used in any type of fluid such as water, oil, organic solvent, etc. 3-2. This is a hermetic device. MSL(Moisture Sensitive Level) is the '2a' level. 3-3. Ultrasonic cleaning shall be avoided. 3-4. Isopropyl Alcohol and Ethyl Alcohol can be used for cleaning. Contact us before using other cleaning solvents than above 3-5. This is an electrostatic sensitive device. Please avoid static voltage during operation and storage. 3-6. Sudden change of temperature shall be avoided, deterioration of the characteristics can occur. 3-7. If any malfunction due to designing or manufacturing which is out of specification occurs within one year after the products have been delivered, the maker should exchange the defective products. SMS-51-L-SFT D0-91 Page 4/27 Aug 07, 2014 Surface Acoustic Wave Filter SFX836UYA02 UMTS B5 DPX - Tx 836.5MHz UMTS B5 DPX - Rx 881.5MHz 3 1.8×1.4×0.58mm 8pin lay-out Version: 000 4. OUTLINE DRAWING & DIMENSIONS [Unit: mm] 1.8±0.1 7 5 1.4±0.1 x EX X O X 1 0.58±0.05 3 8 0.625±0.05 0.25±0.05 0.25±0.05 1 6 2 3 4 0.075±0.065 0.075±0.065 0.35±0.05 5 7 0.35±0.05 6 No. Function 1,8 Rx Output 3 Tx Input 6 Antenna 2, 4, 5, 7 GND 0.3±0.05 SMS-51-L-SFT D0-91 Page 5/27 Aug 07, 2014 Surface Acoustic Wave Filter SFX836UYA02 UMTS B5 DPX - Tx 836.5MHz UMTS B5 DPX - Rx 881.5MHz 3 1.8×1.4×0.58mm 8pin lay-out Version: 000 5. MARKING x E X X ○ X 5-1. x E X X X - The 1st, 2nd character 'xE' indicates the model name of SAW Filter “SFX836UYA02”. - The 3rd character 'X' indicates the year and the month of manufacture. Year Month 1 2 3 4 5 6 7 8 9 10 11 12 2013 P Q R S T U V W X Y Z a 2014 1 2 3 4 5 6 7 8 9 A B C 2015 D E F G H I J K L M N O 2016 P Q R S T U V W X Y Z a ※ This rotates by the 3 years. - The th th 4 ,5 character 'X' indicates Lot No. 5-2. O - This symbol indicates input pin 1. - This indicates the producing center ○ : China, 5-3. Marking : Laser Marking SMS-51-L-SFT D0-91 Page 6/27 Aug 07, 2014 Surface Acoustic Wave Filter UMTS B5 DPX - Tx 836.5MHz UMTS B5 DPX - Rx 881.5MHz SFX836UYA02 3 1.8×1.4×0.58mm 8pin lay-out Version: 000 6. PERFORMANCE 6-1. MAXIMUM RATINGS CHARACTERISTICS RATINGS UNITS DC Permissive Voltage 5 V Maximum Input Power 0.8 W Operating Temperature Range -20 ~ +85 ℃ Storage Temperature Range -40 ~ +85 ℃ 6-2. ELECTRICAL CHARACTERISTICS 6-2-1. TABLE Ta = -20 ~ +85℃ Item CONDITION [MHz] RATING UNIT Min. Typ.(25℃) Max. TX  ANTENNA Insertion Loss 824 ~ 849 dB 1.6 2.1 Inband Ripple 824 ~ 849 dB 0.5 1.2 VSWR 824 ~ 849 - 1.5 2.0 0 ~ 779 dB 23 28 779 ~ 804 dB 28 35 869 ~ 894 dB 46 56 925 ~ 960 dB 25 31 1574 ~ 1577 dB 33 39 1638 ~ 1708 dB 33 40 1805 ~ 1880 dB 38 43 1930 ~ 1990 dB 40 45 2110 ~ 2170 dB 38 42 2400 ~ 3000 dB 25 31 3000 ~ 6000 dB 12 17 Absolute Attenuation Termination Impedance : INPUT / ANTENNA Item CONDITION [MHz] 50Ω(//15[nH]) / 50Ω(// 8.2[nH]) RATING UNIT Min. Typ.(25℃) Max. ANTENNA  RX Insertion Loss 869 ~ 894 dB 1.7 2.3 Inband Ripple 869 ~ 894 dB 0.5 1.2 VSWR 869 ~ 894 - 1.6 2.0 SMS-51-L-SFT D0-91 Page 7/27 Aug 07, 2014 Surface Acoustic Wave Filter UMTS B5 DPX - Tx 836.5MHz UMTS B5 DPX - Rx 881.5MHz Absolute Attenuation SFX836UYA02 3 1.8×1.4×0.58mm 8pin lay-out Version: 000 0 ~ 779 dB 60 66 779 ~ 824 dB 60 64 824 ~ 849 dB 55 64 915 ~ 925 dB 22 26 925 ~ 960 dB 42 47 960 ~ 2000 dB 55 59 2000 ~ 2500 dB 53 58 2500 ~ 3000 dB 53 57 3200 ~ 6000 dB 45 55 50Ω / (// 8.2[nH]) Differential 100Ω(// 82[nH]) Termination Impedance : ANT / OUTPUT TX → RX Isolation between Rx and Tx SMS-51-L-SFT D0-91 824 ~ 849 dB 55 65 869 ~ 894 dB 53 57 Page 8/27 Aug 07, 2014 Surface Acoustic Wave Filter UMTS B5 DPX - Tx 836.5MHz UMTS B5 DPX - Rx 881.5MHz SFX836UYA02 3 1.8×1.4×0.58mm 8pin lay-out Version: 000 6-2-2. TEST FIXTURE Antenna 50Ω 8.2nH xEXX ○ X 100Ω 82nH 50Ω 15nH Rx Output Tx Input < X-ray Top View > SMS-51-L-SFT D0-91 Page 9/27 Aug 07, 2014 Surface Acoustic Wave Filter UMTS B5 DPX - Tx 836.5MHz UMTS B5 DPX - Rx 881.5MHz SFX836UYA02 3 1.8×1.4×0.58mm 8pin lay-out Version: 000 6-2-3. GRAPH Tx→Ant, Ant→Rx Transmission Characteristics Nearband 0 -20 -40 -60 -80 760 800 840 880 Frequency (MHz) 920 960 Tx Rx Isolation Charateristics Isolation -10 -20 -30 -40 -50 -60 -70 -80 -90 760 SMS-51-L-SFT D0-91 810 860 Frequency (MHz) Page 10/27 910 960 Aug 07, 2014 Surface Acoustic Wave Filter UMTS B5 DPX - Tx 836.5MHz UMTS B5 DPX - Rx 881.5MHz SFX836UYA02 3 1.8×1.4×0.58mm 8pin lay-out Version: 000 Tx Ant Wideband Transmission Charateristics TX_Fullband 0 -20 -40 -60 -80 300 2300 4300 6000 4300 6000 Frequency (MHz) Ant→Rx Full band Transmission Characteristics RX_Fullband 0 -20 -40 -60 -80 300 2300 Frequency (MHz) SMS-51-L-SFT D0-91 Page 11/27 Aug 07, 2014 Surface Acoustic Wave Filter UMTS B5 DPX - Tx 836.5MHz UMTS B5 DPX - Rx 881.5MHz SFX836UYA02 3 1.8×1.4×0.58mm 8pin lay-out Version: 000 Tx→Rx Full band Isolation Characteristics Isolation -10 -20 -30 -40 -50 -60 -70 -80 -90 300 2300 4300 6000 Frequency (MHz) SMS-51-L-SFT D0-91 Page 12/27 Aug 07, 2014 Surface Acoustic Wave Filter UMTS B5 DPX - Tx 836.5MHz UMTS B5 DPX - Rx 881.5MHz SFX836UYA02 3 1.8×1.4×0.58mm 8pin lay-out Version: 000 7. RELIABILITY 7-1. ENGINEERING SAMPLE FLOW CHART Initial Characteristics Electrical Parametric Data@25℃ Preconditioning (JESD22-A113F) Temp. Drift (n=5) Thermal Shock (n=23) Board Adhesion (n=11) Low Temp. Storage (n=23) PCT (n=23) Bending Test (n=11) High Temp. Storage (n=23) Vib ration (n=23) ESD Test (n=11) Humidity Test (n=23) Drop (n=23) ESD Limit Test (n=11) Final Electrical Data (n=74) Final Electrical Data (n=92) Final Electrical Data (n=44) SMS-51-L-SFT D0-91 Page 13/27 Aug 07, 2014 Surface Acoustic Wave Filter UMTS B5 DPX - Tx 836.5MHz UMTS B5 DPX - Rx 881.5MHz SFX836UYA02 3 1.8×1.4×0.58mm 8pin lay-out Version: 000 7-2. TEST ITEM & CONDITION CATEGORY TEST ITEM Preconditioning Environment Test JESD22A113F -20℃ → +25℃→ +85℃ High Temp. Storage +85℃ 240hr JESD22-A103C Low Temp. Storage -40℃ 240hr JESD22-A119 description High Temp. High Humidity Storage +85℃ 85%RH 240hr JESD22-A106B Thermal Shock -40℃/30min ⇔ +85℃/30min , 100cycle JESD22-A106A +121℃ 100%RH 96hr JESD22-A102C Vibration Test (Random) 20 ㎐~2000 ㎐,0.053G²/Hz or 8g's RMS,15min/plane IEC 68-2-36 Fdb Drop Test 152 ㎝ 12times Steel floor JIG(110g~150g) IEC 1178-1.4.8.9 0.5 ㎜/sec 1point push IEC 68-2-21 Ue3 0.5 ㎜/sec 3times -PCB : FR4 , PCB SIZE : 100*40 ㎜ IEC 68-2-21 Ue3 Solder Heat Resistance ±250V,C=100pF,R=1.5 ㏀,1times IEC 68-2-21 Ue3 static marginal test C=100pF,R=1.5 ㏀,1times(demand of customer) JESD22-A114F Board Adhesion Bending Test Physical Test +125℃ 24hr Baking → +60℃ 60%RH 120hr → Reflow Test(3times) REMARK Temp. Drift High Temp. Operating Mechanical Test TEST CONDITION SMS-51-L-SFT D0-91 Page 14/27 Aug 07, 2014 Surface Acoustic Wave Filter UMTS B5 DPX - Tx 836.5MHz UMTS B5 DPX - Rx 881.5MHz SFX836UYA02 3 1.8×1.4×0.58mm 8pin lay-out Version: 000 8. REFLOW CONDITION 9. RECOMMENDED PCB DIMENSIONS [UNIT : mm] [SAW, X-ray Top View] SMS-51-L-SFT D0-91 [PCB, X-ray Top View] Page 15/27 Aug 07, 2014 Surface Acoustic Wave Filter UMTS B5 DPX - Tx 836.5MHz UMTS B5 DPX - Rx 881.5MHz SFX836UYA02 3 1.8×1.4×0.58mm 8pin lay-out Version: 000 10. CAUTION Moisture Sensitivity Device Caution (MSL LEVEL=2a) 1. Calculated shelf life in sealed bag : 12 month at 〈40℃ and 〈90% relative Humidity(RH) 2. Peak package body temperature : 260℃ 3. After bag is opened, devices that will be subjected to reflow solder or other high temperature process must be (a) Mounted within : 672 hours of factory conditions ≤30℃/60% RH, or (b) Stored per J-STD-033 4. Device require bake, before mounting, if : (a) Humidity Indicator Card reads 〉60% when read at 23±5℃ (b) 3(a) or 3(b) are not met 5. If baking is required, refer to IPC/JEDEC J-STD-033 for bake procedure Note : Level and body temperature defined by IPC/JEDEC J-STD-020 Aluminum Pack (310mmΧ370mm) HIC(Humidity Indication Card) 10 to 60% RH SMS-51-L-SFT D0-91 Page 16/27 Aug 07, 2014 Surface Acoustic Wave Filter SFX836UYA02 UMTS B5 DPX - Tx 836.5MHz UMTS B5 DPX - Rx 881.5MHz 3 1.8×1.4×0.58mm 8pin lay-out Version: 000 11. PACKING 11-1. DIMENSIONS - Carrier Tape [Unit: mm] A B D0 D1 E F P0 P1 P2 t1 t2 W 1.70 +0.10 -0.10 2.1 +0.10 -0.10 Ø 1.55 +0.05 -0.05 Ø 1.00 MIN 1.75 +0.10 -0.10 3.5 +0.05 -0.05 4 +0.10 -0.10 4 +0.10 -0.10 2 +0.05 -0.05 0.25 +0.05 -0.05 0.70 +0.10 -0.10 8 +0.30 -0.30 - Reel [Unit: mm] A B C D E F G H t1 t2 W Ø 258.0 +1.0 -0.5 Ø 81.0 +1.0 -1.0 Ø 13.0 +0.5 -0.5 50.0 +0.8 -0.8 2.2 +0.3 -0.3 7.0 +0.5 -0.5 30.0 +0.8 -0.8 35.0 +1.0 -1.0 1.8 +0.5 -0.5 1.5 +0.5 -0.5 9.0 +1.0 -0.5 - The product shall be packed properly not to damaged during transportation and storage. SMS-51-L-SFT D0-91 Page 17/27 Aug 07, 2014 Surface Acoustic Wave Filter UMTS B5 DPX - Tx 836.5MHz UMTS B5 DPX - Rx 881.5MHz SFX836UYA02 3 1.8×1.4×0.58mm 8pin lay-out Version: 000 11-2. REELING QUANTITY 10 inch reel : 8,000 pcs/reel 11-3. TAPING STRUCTURE 11-3-1. The tape shall be wound around the reel in direction shown below. xEXX O X xEXX O X 11-3-2. BAR CODE LABEL SMS-51-L-SFT D0-91 ① MODEL NAME BARCODE ② SFH836AQ101 Model Name ③ RLYC12563 Reel number ④ 8000 / qAFYU Quantity / Marking Page 18/27 Aug 07, 2014 Surface Acoustic Wave Filter SFX836UYA02 UMTS B5 DPX - Tx 836.5MHz UMTS B5 DPX - Rx 881.5MHz 3 1.8×1.4×0.58mm 8pin lay-out Version: 000 1-3-3. Leader part and vacant position specifications. 11-4. INNER BOX(Reel Packing) STRUCTURE Material: Polycarbonate Material: Polyethylene + Aluminium Size: 310×370mm Material: Size: 2 Paper (D)260×(W)37×(H)265mm SMS-51-L-SFT D0-91 3 Page 19/27 Aug 07, 2014 . . Surface Acoustic Wave Filter SFX836UYA02 UMTS B5 DPX - Tx 836.5MHz UMTS B5 DPX - Rx 881.5MHz 3 1.8×1.4×0.58mm 8pin lay-out Version: 000 11-5. OUTER BOX STRUCTURE Material : Paper TYPE A SIZE(mm) a b c Inner Box # 270 240 275 6 boxes SIDE ① SIDE ② MODEL Q'TY EA USER DATE . . - SIDE is the same as front side. SMS-51-L-SFT D0-91 Page 20/27 Aug 07, 2014 Surface Acoustic Wave Filter UMTS B5 DPX - Tx 836.5MHz UMTS B5 DPX - Rx 881.5MHz SFX836UYA02 3 1.8×1.4×0.58mm 8pin lay-out Version: 000 12. TAPE SPECIFICATIONS 12-1. Tensile Strength of Carrier Tape: 4.4N/mm width 12-2. Top Cover Tape Adhesion (See the below figure) - pull of angle: 0~15 degree - speed: 300mm/min. - force: 20~70g SMS-51-L-SFT D0-91 Page 21/27 Aug 07, 2014 Surface Acoustic Wave Filter UMTS B5 DPX - Tx 836.5MHz UMTS B5 DPX - Rx 881.5MHz SFX836UYA02 3 1.8×1.4×0.58mm 8pin lay-out Version: 000 13. RoHS DATA SMS-51-L-SFT D0-91 Page 22/27 Aug 07, 2014 Surface Acoustic Wave Filter UMTS B5 DPX - Tx 836.5MHz UMTS B5 DPX - Rx 881.5MHz SMS-51-L-SFT D0-91 SFX836UYA02 3 1.8×1.4×0.58mm 8pin lay-out Page 23/27 Version: 000 Aug 07, 2014 Surface Acoustic Wave Filter UMTS B5 DPX - Tx 836.5MHz UMTS B5 DPX - Rx 881.5MHz SMS-51-L-SFT D0-91 SFX836UYA02 3 1.8×1.4×0.58mm 8pin lay-out Page 24/27 Version: 000 Aug 07, 2014 Surface Acoustic Wave Filter UMTS B5 DPX - Tx 836.5MHz UMTS B5 DPX - Rx 881.5MHz SMS-51-L-SFT D0-91 SFX836UYA02 3 1.8×1.4×0.58mm 8pin lay-out Page 25/27 Version: 000 Aug 07, 2014 Surface Acoustic Wave Filter UMTS B5 DPX - Tx 836.5MHz UMTS B5 DPX - Rx 881.5MHz SMS-51-L-SFT D0-91 SFX836UYA02 3 1.8×1.4×0.58mm 8pin lay-out Page 26/27 Version: 000 Aug 07, 2014 Surface Acoustic Wave Filter UMTS B5 DPX - Tx 836.5MHz UMTS B5 DPX - Rx 881.5MHz SMS-51-L-SFT D0-91 SFX836UYA02 3 1.8×1.4×0.58mm 8pin lay-out Page 27/27 Version: 000 Aug 07, 2014
SFX836UYA02 价格&库存
很抱歉,暂时无法提供与“SFX836UYA02”相匹配的价格&库存,您可以联系我们找货
