NSI6602B-DSWR
NSI6602B-DSWR
    NOVOSENSE(纳芯微)
    SOP16_300MIL
    高可靠性隔离双通道栅极驱动器 SOP16_300MIL
NSI6602B-DSWR 数据手册
NSi6602 High Reliability Isolated Dual-Channel Gate Driver Datasheet (EN) 1.3 Product Overview NSI6602 is a family of high reliability isolated dualchannel gate driver ICs which can be designed to drive power transistor up to 2MHz switching frequency. Each output could source 4A and sink 6A peak current with fast 25ns propagation delay and 5ns maximum delay matching. The NSI6602 provides 2500Vrms isolation per UL1577 in 5*5mm LGA13 package, 3000Vrms isolation in SOIC-16 narrow package, and 5700Vrms isolation in SOIC-16 or SOIC-14 wide package. System robustness is supported by 150kV/us typical common-mode transient immunity (CMTI). The driver operates with a maximum supply voltage of 28V, while the input-side accepts from 2.7V to 5V supply voltage. Under voltage lock-out (UVLO) protection is supported by all the power supply voltage pins. Safety Regulatory Approvals  UL recognition:  LGA13: 2500Vrms for 1 minute per UL1577  SOP16/SOP14(300mil): 5700Vrms for 1 minute per UL1577  SOP16(150mil): 3000Vrms for 1 minute per UL1577  DIN VDE V 0884-11:2017-01  CSA component notice 5A With all these excellent features, NSI6602 is suitable for high reliability, power density and efficiency switching power system.  CQC certification per GB4943.1-2011 Key Features  Isolated DC-DC and AC-to-DC power supplies in server, telecom, and industry  Isolated dual channel driver  DC-to-AC solar inverters  Input side supply voltage: 2.7V to 5.5V  Motor drives and EV charging  Driver side supply voltage: up to 25V with UVLO  UPS and battery chargers  4A peak source and 6A peak sink output Functional Block Diagram  High CMTI: ±150kV/us typical Applications  25ns typical propagation delay  5ns maximum delay matching  6ns maximum pulse width distortion  Programmable deadtime  Accepts minimum input pulse width 20ns  Operation temperature: -40℃~125℃ Copyright © 2020, NOVOSENSE Figure 0.1 NSI6602 Block Diagram Page 1 NSi6602 Datasheet (EN) 1.3 INDEX 1. PIN CONFIGURATION AND FUNCTIONS................................................................................................................................... 3 2. ABSOLUTE MAXIMUM RATINGS.............................................................................................................................................. 4 3. RECOMMENDED OPERATING CONDITIONS............................................................................................................................. 5 4. THERMAL INFORMATION......................................................................................................................................................... 5 5. SPECIFICATIONS........................................................................................................................................................................ 5 5.1. 5.2. 5.3. 5.4. 6. ELECTRICAL CHARACTERISTICS.......................................................................................................................................... 5 SWITCHING CHARACTERISTICS.......................................................................................................................................... 7 TYPICAL PERFORMANCE CHARACTERISTICS......................................................................................................................7 PARAMETER MEASUREMENT INFORMATION..................................................................................................................11 HIGH VOLTAGE FEATURE DESCRIPTION..................................................................................................................................14 6.1. 6.2. 6.3. 7. INSULATION CHARACTERISTICS....................................................................................................................................... 14 SAFETY-LIMITING VALUES................................................................................................................................................15 SAFETY-RELATED CERTIFICATIONS................................................................................................................................... 18 FUNCTION DESCRIPTION........................................................................................................................................................ 19 7.1. OVERVIEW........................................................................................................................................................................19 7.2. VDDI, VDDA/B, AND UNDER VOLTAGE LOCK OUT (UVLO)...............................................................................................19 7.3. TRUTH TABLES..................................................................................................................................................................20 7.4. PROGRAMMABLE DEADTIME (DT) PIN............................................................................................................................20 7.4.1. TYING THE DT PIN TO VDDI...................................................................................................................................... 20 7.4.2. DT PIN LEFT OPEN OR CONNECTED TO A PROGRAMMING RESISTOR BETWEEN DT AND GND PINS......................20 8. APPLICATION NOTE.................................................................................................................................................................22 8.1. 8.2. 8.3. 9. TYPICAL APPLICATION CIRCUIT........................................................................................................................................ 22 ESD PROTECTION............................................................................................................................................................. 21 LAYOUT CONSIDERATIONS...............................................................................................................................................22 PACKAGE INFORMATION........................................................................................................................................................ 23 10. ORDERING INFORMATION..................................................................................................................................................27 11. DOCUMENTATION SUPPORT.............................................................................................................................................. 27 12. TAPE AND REEL INFORMATION.......................................................................................................................................... 28 13. REVISION HISTORY.............................................................................................................................................................. 30 Copyright © 2020, NOVOSENSE Page 2 NSi6602 Datasheet (EN) 1.3 1. Pin Configuration and Functions Figure 1.1 NSI6602 LGA13 Package Figure 1.2 NSI6602 SOW16/SOP16 Package Figure 1.3 NSI6602 SOW14 Package Copyright © 2020, NOVOSENSE Page 3 NSi6602 Datasheet (EN) 1.3 Table 1.1 NSI6602A Pin Configuration and Description PIN NO. SYMBOL FUNCTION LGA13 SOP16 SOP14 1 4 4 GND Input-side ground reference. 2 1 1 INA TTL/CMOS compatible input signal for channel A with internal pull down to GND. It is recommended to connect this pin to GND if not used. 3 2 2 INB TTL/CMOS compatible input signal for channel B with internal pull down to GND. It is recommended to connect this pin to GND if not used. 4, 7 3, 8 3, 8 VDDI Input-side supply voltage. It is recommended to place a bypass capacitor from this pin to GND as close as possible. 5 5 5 DISABLE Disables the isolator inputs and driver outputs if asserted high, enables if asserted low or left open. It is recommended to connect this pin to GND if not used. 6 6 6 DT Programmable deadtime. Connect DT to VDDI allows the outputs to overlap. Place a 1kΩ to 200kΩ resistor (RDT) between DT and GND to adjusts deadtime following: tDT (ns) = 10 x RDT (kΩ). It is recommended to parallel a low ESR capacitor, e.g., 2.2nF or above. 8 9 9 GNDB Ground for output channel B 9 10 10 OUTB Output gate driver for channel B 10 11 11 VDDB Supply voltage for channel B 11 14 12 GNDA Ground for output channel A 12 15 13 OUTA Output gate driver for channel A 13 16 14 VDDA Supply voltage for channel A / 7,12,13 7 NC Not connected 2. Absolute Maximum Ratings Parameters Input Side Supply Voltage Output Side Supply Voltage Input Signal Voltage Output Signal Voltage Copyright © 2020, NOVOSENSE Symbol Min Max VDDI to GNDI -0.3 6 V VDDA to GNDA, VDDB to GNDB -0.3 30 V INA, INB, DIS, DT to GNDI -0.3 VVDDI+0.3 V INA, INB, DIS, DT to GNDI, Transient for 50ns -5 VVDDI+0.3 V OUTA to GNDA, OUTB to GNDB -0.3 OUTA to GNDA, OUTB to GNDB, Transient for 200ns -2 VVDDA+0.3 VVDDB+0.3 VVDDA+0.3 VVDDB+0.3 Unit V V Page 4 NSi6602 Datasheet (EN) 1.3 Parameters Channel A to Channel B Voltage Symbol Min Max Unit GNDA to GNDB in LGA13 package 700 V GNDA to GNDB in SOP16&SOW16 package 1500 V GNDA to GNDB in SOW14 package 1850 V Junction Temperature TJ -40 150 ℃ Storage Temperature Tstg -65 150 ℃ HBM (all pins) -4000 4000 V CDM -1500 1500 V Electrostatic discharge 3. Recommended Operating Conditions Parameters Symbol Min Max Unit Input Side Supply Voltage VDDI to GNDI 3 5.5 V Driver Side Supply Voltage VDDA to GNDA, VDDB to GNDB 7 25 V Input Signal Voltage INA, INB, DIS, DT 0 VVDDI V Junction Temperature TJ -40 150 ℃ Ambient Temperature Ta -40 125 ℃ Comments 4. Thermal Information Parameters Symbol LGA13 Junction-to-ambient thermal resistance1) RJA 209.5 Junction-to-case(top) thermal resistance2) RJC(top) Junction-to-top characterization parameter3) Junction-to-board characterization parameter3) SOW16/ SOP16 Unit 97.0 150.5 ℃/W 48.4 23.3 21.2 ℃/W ΨJT 41.8 35.8 52.3 ℃/W ΨJB 31.9 39.0 55.6 ℃/W SOW14 1) Standard JESD51-3 Low Effective Thermal Conductivity Test Board (1s) in an environment described in JESD51-2a. 2) Standard JESD51-3 Low Effective Thermal Conductivity Test Board (1s) by transient dual interface test method described in JESD51-14. 3) Obtained by Simulating in an environment described in JESD51-2a. 5. Specifications 5.1. Electrical Characteristics VDDI=3.3V or 5V, VDDA=VDDB=12V for NSI6602A/B, VDDA=VDDB=15V for NSI6602C, Ta=-40℃ to 125℃. Unless otherwise noted, Typical values are at Ta=25℃ Parameter Copyright © 2020, NOVOSENSE Symbol Min Typ Max Unit Comments Page 5 NSi6602 Datasheet (EN) 1.3 Parameter Symbol Min Typ Max 2 Unit Comments Input Side Supply VDDI Quiescent Current IVDDIQ 0.75 VDDI Operation Current IVDDI 1.8 mA INA=0, INB=0 mA Input frequency 500kHz, COUTA/B=15pF VDDI UVLO Rising Threshold VVDDI_ON 2.35 2.55 2.75 V VDDI UVLO Falling Threshold VVDDI_OFF 2.15 2.35 2.55 V VDDI UVLO Hysteresis VVDDI_HYS 0.2 V Output Side Supply Output Side Supply Voltage VVDDA, VVDDB VDDA/B Quiescent Current, per Channel IVDDAQ, IVDDBQ 1.6 VDDA/B Operation Current, per Channel IVDDA, IVDDB 3.2 25 V Minimum defined by UVLO 2.5 mA INA=0, INB=0, VDDx=12V for 6V,8V UVLO; VDDx=15V for 13V UVLO mA 100pF, 500kHz, VDDx=12V for 6V,8V UVLO; VDDx=15V for 13V UVLO NSI6602A (6V) VDDA/B UVLO Rising Threshold VVDDA_ON, VVDDB_ON 5.7 6.15 6.5 V VDDA/B UVLO Falling Threshold VVDDA_OFF, VVDDB_OFF 5.4 5.85 6.2 V VDDA/B UVLO Hysteresis VVDDA_HYS, VVDDB_HYS VDDA/B UVLO Rising Threshold VVDDA_ON, VVDDB_ON 8.1 8.5 8.9 V VDDA/B UVLO Falling Threshold VVDDA_OFF, VVDDB_OFF 7.6 8.0 8.4 V VDDA/B UVLO Hysteresis VVDDA_HYS, VVDDB_HYS VDDA/B UVLO Rising Threshold VVDDA_ON, VVDDB_ON 12.7 13.2 13.7 V VDDA/B UVLO Falling Threshold VVDDA_OFF, VVDDB_OFF 11.7 12.2 12.7 V VDDA/B UVLO Hysteresis VVDDA_HYS, VVDDB_HYS 1 V Input Pin Pull Down Resistance, INA, INB, RINA_PD, RINB_PD 100 kΩ Input Pin Pull Down Resistance, DIS (EN) RDIS_PD 100 kΩ Logic High Input Threshold VINA_H, VINB_H, VDIS_H 1.7 Logic Low Input Threshold VINA_L, VINB_L, VDIS_L 0.3 V 0.5 NSI6602B (8V) V NSI6602C (13V) Input Side Characteristic Input Hysteresis VINA_HYS, VINB_HYS, VDIS_HYS 0.8 2 V 1.1 V 0.6 V Output Side Characteristic Copyright © 2020, NOVOSENSE Page 6 NSi6602 Datasheet (EN) 1.3 Parameter Symbol Min Typ Logic High Output Voltage VVDDA-VOUTA_H, VVDDB-VOUTB_H 0.34 Logic Low Output Voltage VOUTA_L, VOUTB_L 55 Output Sink Resistance ROUTA_L, ROUTB_L Output Source Resistance Max Unit Comments V Iout = 100mA mV Iout = -100mA 0.55 Ω Iout = 100mA ROUTA_H, ROUTB_H 3.4 Ω Iout = -100mA Peak Output Sink Current IOUTA-, IOUTB- 6 A Peak Output Source Current IOUTA+, IOUTB+ 4 A 5.2. Switching Characteristics VDDI=3.3V or 5V, VDDA=VDDB=12V for NSI6602A/B, VDDA=VDDB=15V for NSI6602C, Ta=-40℃ to 125℃. Parameter Minimum Pulse Width Propagation Delay Symbol Min tPWmin tPDHL, tPDLH 10 Typ Max Unit 10 15 ns 25 35 ns Comments COUTA/B = 0 pF Pulse Width Distortion |tPDLH-tPDHL| tPWD 6 ns Channel to Channel Delay Matching tDMLH, tDMHL 5 ns 200 240 ns tDT(ns)=10*R(kΩ); Test for R = 20kΩ Programmed Deadtime tDT Output Rise Time (20% to 80%) tR 7 16 ns COUTA/B=1.8nF, verified by design Output Fall Time (90% to 10%) tF 6 12 ns COUTA/B=1.8nF, verified by design Shutdown Time from Disable True tDIS 40 ns Recovery Time from Disable False tEN 40 ns VDDI Power-up Time Delay 160 tstart_VDDI 8.5 15 us INA or INB tied to VDDI tstart_VDDA, tstart_VDDB 18 30 us INA or INB tied to VDDI (Time from VDDI = VDDI_ON to OUTA/B = INA/B) VDDA/B Power-up Time Delay (Time from VDDA/B = 2V to OUTA/B = INA/B) Common Mode Transient Immunity CMTI COUTA/B=1.8nF 100 150 kV/us verified by design 5.3. Typical Performance Characteristics VDDI = 3.3 V, VDDA=VDDB=12V for NSI6602A/B, VDDA=VDDB=15V for NSI6602C, TA = 25℃. Output has no load unless otherwise noted. Copyright © 2020, NOVOSENSE Page 7 NSi6602 Datasheet (EN) 1.3 Figure 5.1 VDDI Quiescent Current vs Temperature Figure 5.2 VDDI Operating Current vs Temperature Figure 5.3 VDDA/B Quiescent Current vs Temperature Figure 5.4 VDDA/B Operating Current vs Temperature Figure 5.5 VDDA/B Quiescent Current vs Supply Voltage Figure 5.6 Output Resistance vs Temperature Copyright © 2020, NOVOSENSE Page 8 NSi6602 Datasheet (EN) 1.3 Figure 5.7 Typical Rise Time & Fall Time vs Temperature Figure 5.8 Output Peak Current vs VDDA/B Supply Voltage Figure 5.9 VDDI UVLO Threshold vs Temperature Figure 5.10 VDDI UVLO Hysteresis vs Temperature Figure 5.11 6V VDDA/B UVLO Threshold vs Temperature Figure 5.12 6V VDDA/B UVLO Hysteresis vs Temperature Copyright © 2020, NOVOSENSE Page 9 NSi6602 Datasheet (EN) 1.3 Figure 5.13 8V VDDA/B UVLO Threshold vs Temperature Figure 5.14 8V VDDA/B UVLO Hysteresis vs Temperature Figure 5.15 INA/INB/DIS Threshold vs Temperature Figure 5.16 INA/INB/DIS Hysteresis vs Temperature Figure 5.17 Propagation Delay vs Temperature Figure 5.18 Propagation Delay vs VDDA/B Copyright © 2020, NOVOSENSE Page 10 NSi6602 Datasheet (EN) 1.3 Figure 5.19 Propagation Delay Matching vs Temperature Figure 5.20 Pulse Width Distortion vs Temperature Figure 5.21 Disable & Enable Time vs Temperature Figure 5.22 Deadtime (RDT=20kΩ) vs Temperature 5.4. Parameter Measurement Information Figure 5.23 Propagation Delay and Channel to Channel Delay Match Time, connect DT to VDDI Copyright © 2020, NOVOSENSE Page 11 NSi6602 Datasheet (EN) 1.3 Figure 5.24 Channel to Channel Delay Match Test Circuit Figure 5.25 Disable Time and Enable Time Figure 5.26 Deadtime, Determined by RDT Copyright © 2020, NOVOSENSE Page 12 NSi6602 Datasheet (EN) 1.3 Figure 5.27 Common-Mode Transient Immunity Test Circuit Copyright © 2020, NOVOSENSE Page 13 NSi6602 Datasheet (EN) 1.3 6. High Voltage Feature Description 6.1. Insulation Characteristics Description Test Condition Symbol Value Unit LGA 13 SOW16/14 SOP16 Min. External Air Gap (Clearance) CLR 3.5 8 4 mm Min. External Tracking (Creepage) CPG 3.5 8 4 mm Distance through the Insulation DTI 32 CTI >600 Comparative Tracking Index DIN EN 60112 (VDE 0303-11) Material Group IEC 60112 um V I Installation Classification per DIN VDE 0110 For Rated Mains Voltage ≤ 150Vrms I to III I to IV I to IV For Rated Mains Voltage ≤ 300Vrms I to II I to IV I to III For Rated Mains Voltage ≤ 600Vrms I I to IV I to II For Rated 1000Vrms / I to III / Mains Voltage ≤ Insulation Specification per DIN VDE V 0884-11:2017-011) Climatic Category 40/125/21 Pollution Degree per DIN VDE 0110, Table 1 Maximum Working Isolation Voltage AC voltage 2 VIOWM 560 1000 700 VRMS 792 1414 990 VDC VIORM 792 1414 990 Vpeak Vpd (m) 1188 / 1485 Vpeak Vpd (m) / 2652 / Vpeak Vini. a = VIOTM, Vpd(m) = VIORM × 1.3, V pd (m) 1030 / 1287 Vpeak tini = 60 sec, tm = 10 sec, qpd ≤ 5 pC Vini. a = VIOTM, Vpd(m) = VIORM × 1.6, V pd (m) / 2263 / Vpeak tini = 60 sec, tm = 10 sec, qpd ≤ 5 pC V pd (m) 950 1697 1188 Vpeak DC voltage Maximum Voltage Repetitive Isolation Input to Output Test Voltage, Method B1 Vini. b = VIOTM, Vpd(m) = VIORM × 1.5, tini = tm = 1 sec, qpd ≤ 5 pC, 100% production test Vini. b = VIOTM, Vpd(m) = VIORM × 1.875, tini = tm =1 sec, qpd≤ 5 pC, 100% production test Input to Output Test Voltage, Method A. After Environmental Tests Subgroup 1 Input to Output Test Voltage, Method A. After Input and Output Safety Test Copyright © 2020, NOVOSENSE Vini. a = VIOTM, Vpd(m) = VIORM × 1.2, Page 14 NSi6602 Datasheet (EN) 1.3 Description Test Condition Symbol Maximum Transient Isolation Voltage tini = 60 sec, tm = 10 sec, qpd ≤ 5 pC t = 60 sec VIOTM 3535 8000 4242 Vpeak Maximum Surge Isolation Voltage Test method per IEC62368-1, VIOSM 3500 / 6000 Vpeak / 6250 / Vpeak Subgroup 2 and Subgroup 3 Value Unit 1.2/50us waveform, VTEST = 1.3 × VIOSM Test method per IEC62368-1, 1.2/50us waveform, VTEST = 1.6 × VIOSM Isolation Resistance VIO = 500 V, Tamb = TS RIO VIO = 500 V, 100 ℃ ≤ Tamb ≤ 125 ℃ Isolation Capacitance f = 1MHz CIO VTEST = 1.2 × VISO, t = 1 sec, VISO >109 Ω >1011 Ω 1.2 pF Insulation Specification per UL1577 Withstand Isolation Voltage 2500 5700 3000 Vrms 100% production test 1) This coupler is suitable for “safe electrical insulation” only within the safety ratings. Compliance with the safety ratings shall be ensured by means of suitable protective circuits. 6.2. Safety-Limiting Values Basic isolation safety-limiting values as outlined in VDE-0884-11 of NSI6602x-xLAR (LGA13) Description Safety Supply Power Safety Supply Current Test Condition Side Value Input 12 mW Driver A, Driver B 293 mW Total 598 mW RθJA = 209.5 ℃ / W1), VDDA/B = 12V, TJ = 150 ℃ , TA = 25 ℃ Driver A, Driver B 24.4 mA RθJA = 209.5 ℃ / W1), VDDA/B = 25V, TJ = 150 ℃ , TA = 25 ℃ Driver A, Driver B 11.7 mA 150 ℃ RθJA = 209.5 ℃/W1), TJ = 150 ℃, TA = 25 ℃ Safety Temperature2) Unit 1) Calculate with the junction-to-air thermal resistance, RθJA, of LGA13 package (Thermal Information Table) which is that of a device installed on a low effective thermal conductivity test board (1s) according to JESD51-3. 2) The maximum safety temperature has the same value as the maximum junction temperature (TJ) specified for the device. Copyright © 2020, NOVOSENSE Page 15 NSi6602 Datasheet (EN) 1.3 Figure 6.1 NSI6602x-DLAR Thermal Derating Curve, Dependence of Safety Limiting Values with Case Temperature per DIN VDE V 0884-11 Reinforced isolation safety-limiting values as outlined in VDE-0884-11 of NSI6602x-xSWxR (SOW16/SOW14) Description Safety Supply Power Safety Supply Current Test Condition Side Value Input 12 mW Driver A, Driver B 638 mW Total 1288 mW RθJA = 97 ℃/ W1), VDDA/B = 12V, TJ = 150 ℃, TA = 25 ℃ Driver A, Driver B 53.1 mA RθJA = 97 ℃/ W1), VDDA/B = 25V, TJ = 150 ℃, TA = 25 ℃ Driver A, Driver B 25.5 mA 150 ℃ RθJA = 97 ℃/W1), TJ = 150 ℃, TA = 25 ℃ Safety Temperature2) Unit 1) Calculate with the junction-to-air thermal resistance, RθJA, of SOW16/SOW14 package (Thermal Information Table) which is that of a device installed on a low effective thermal conductivity test board (1s) according to JESD51-3. 2) The maximum safety temperature has the same value as the maximum junction temperature (TJ) specified for the device. Figure 6.2 NSI6602x-DSWR Thermal Derating Curve, Dependence of Safety Limiting Values with Case Temperature per DIN VDE V 0884-11 Basic isolation safety-limiting values as outlined in VDE-0884-11 of NSI6602x-xSPNR (SOP16) Description Copyright © 2020, NOVOSENSE Test Condition Side Value Unit Page 16 NSi6602 Safety Supply Power Safety Supply Current Datasheet (EN) 1.3 Input 12 mW Driver A, Driver B 409 mW Total 830 mW RθJA = 150.5 ℃/ W1), VDDA/B = 12V, TJ = 150 ℃, TA = 25 ℃ Driver A, Driver B 34.0 mA RθJA = 150.5 ℃/ W1), VDDA/B = 25V, TJ = 150 ℃, TA = 25 ℃ Driver A, Driver B 16.3 mA 150 ℃ RθJA = 150.5 ℃/W1), TJ = 150 ℃, TA = 25 ℃ Safety Temperature2) 1) Calculate with the junction-to-air thermal resistance, RθJA, of SOP16 package (Thermal Information Table) which is that of a device installed on a low effective thermal conductivity test board (1s) according to JESD51-3. 2) The maximum safety temperature has the same value as the maximum junction temperature (TJ) specified for the device. Figure 6.3 NSI6602x-DSWR Thermal Derating Curve, Dependence of Safety Limiting Values with Case Temperature per DIN VDE V 0884-11 Copyright © 2020, NOVOSENSE Page 17 NSi6602 Datasheet (EN) 1.3 6.3. Safety-Related Certifications The NSI6602x-xLAR(LGA13) are approved or pending approval by the organizations listed in table. CUL UL1577 Component Recognition Program Single Protection, 2500Vrms Isolation voltage VDE CQC Approved under CSA Component Acceptance Notice 5A DIN VDE V 0884-11: 201701 Certified by CQC11-4715432012 Single Protection,2500Vrms Isolation voltage Basic Insulation at GB4943.1-2011 Basic insulation VIORM=792VPEAK VIOSM=3500VPEAK VIOTM=3535VPEAK File (pending) File (pending) File (pending) File (pending) The NSI6602x-xSWxR(SOW16/SOW14) are approved or pending approval by the organizations listed in table. CUL UL 1577 Component Recognition Program Single Protection, 5700Vrms Isolation voltage VDE CQC Approved under CSA Component Acceptance Notice 5A DIN VDE V 0884-11: 201701 Certified by CQC11-4715432012 Single Protection, 5700Vrms Isolation voltage Reinforced insulation at GB4943.1-2011 Reinforced insulation VIORM=1414VPEAK VIOSM=6250VPEAK VIOTM=8000VPEAK E500602 E500602 Certification No. 40052820 CQC20001264939 The NSI6602x-xSPNR(SOP16) are approved or pending approval by the organizations listed in table. CUL UL 1577 Component Recognition Program Single Protection, 3000Vrms Isolation voltage VDE CQC Approved under CSA Component Acceptance Notice 5A DIN VDE V 0884-11(VDE V 0884-11):2017-01 Certified by CQC11-4715432012 Single Protection, 3000Vrms Isolation voltage Reinforced insulation at GB4943.1-2011 Basic insulation VIORM=990VPEAK VIOSM=6000VPEAK VIOTM=4242VPEAK File (pending) Copyright © 2020, NOVOSENSE File (pending) File (pending) File (pending) Page 18 NSi6602 Datasheet (EN) 1.3 7. Function Description 7.1. Overview NSI6602 is a high reliability dual channel isolated gate driver which could be designed in variety switching power and motor drive topologies. NSI6602 has some useful protections, such as under voltage lock-out (UVLO) for both input and output supply, a disable pin, dead-time control, default low output as input is floating. The functional circuit block diagram is shown as below: Figure 7.1 Functional Block Diagram 7.2. Under Voltage Lock Out (UVLO) The NSI6602 has an internal under voltage lock out (UVLO) protection on both input and output supply circuit blocks. The driver output is held low by an active clamp circuit when the supply voltage of VDDI or VDDA/VDDB is lower than VVDD_ON at power-up status or lower than VVDD_OFF after power-up, regardless of the status of the input pins. The VDDI and VDDA/B ULVO protections have hysteresis (VVDD_HYS) to prevent chatter noise from VDD supply and allow small drops in supply power which are usually happened in startup. Copyright © 2020, NOVOSENSE Page 19 NSi6602 Datasheet (EN) 1.3 7.3. Input and Output Logic Table When the device is power up, setting the DIS pin high can shut down both outputs simultaneously. Left open or grounding the DIS pin can allow the device operating normally. Table 7.1 Output status vs. Input and Power status VDDI status VDDA/B status DIS PU PU PU IN OUT NOTE1) A B A B L or O L H L H PU L or O H L H L PU PU L or O H H H H DT pin is pulled to VDDI. PU PU L or O H H L L DT is left open or programmed with RDT. PU PU L or O L L L L PU PU L or O O O L L PU PU H X X L L PU PD X X X L L PD PU X X X L L 1) If Deadtime function is used, output transits to high after the deadtime expires. PD= Power Down; PU= Power Up; H= Logic High; L= Logic Low; O= Left Open; X= Irrelevant. 7.4. Programmable Deadtime (DT pin) 7.4.1.Pulling the DT Pin to VDDI This allows outputs match inputs completely and no deadtime is asserted. 7.4.2.DT Pin Left Open or Connected to a Programming Resistor between DT and GND Pins If the DT pin is left open, the deadtime duration (tDT) is set to
NSI6602B-DSWR 价格&库存
很抱歉,暂时无法提供与“NSI6602B-DSWR”相匹配的价格&库存,您可以联系我们找货
NSI6602B-DSWR
    • 1+5.95840
    • 100+4.77120
    • 1000+4.41280
    库存:2521
    NSI6602B-DSWR
    • 1+4.97000
    • 30+4.79250
    • 100+4.43750
    • 500+4.08250
    • 1000+3.90500
    库存:392
