W83627DHG-P(FA5B07D)
    NUVOTON(新唐)
    MQFP128
    ICI/OCONTROLLER128-QFP
W83627DHG-P(FA5B07D) 数据手册
W83627DHG-P W83627DHG-PT NUVOTON LPC I/O Date: July 09, 2009 Version: 1.94 W83627DHG-P/W83627DHG-PT TABLE OF CONTENTS – 1. 2. 3. 4. 5. GENERAL DESCRIPTION ......................................................................................................... 1 FEATURES ................................................................................................................................. 2 BLOCK DIAGRAM ...................................................................................................................... 5 PIN LAYOUT............................................................................................................................... 6 PIN DESCRIPTION..................................................................................................................... 7 5.1 LPC Interface ........................................................................................................................ 8 5.2 FDC Interface........................................................................................................................ 8 5.3 Multi-Mode Parallel Port........................................................................................................ 9 5.4 Serial Port & Infrared Port Interface.................................................................................... 12 5.5 KBC Interface...................................................................................................................... 14 5.6 Serial Peripheral Interface .................................................................................................. 15 5.7 Hardware Monitor Interface ................................................................................................ 16 5.8 PECI Interface..................................................................................................................... 17 5.9 SST Interface ...................................................................................................................... 17 5.10 Advanced Configuration and Power Interface .................................................................... 18 5.11 SMBus Interface ................................................................................................................. 19 5.12 General Purpose I/O Port ................................................................................................... 19 5.12.1 5.12.2 5.12.3 5.12.4 5.12.5 5.12.6 5.12.7 GPIO Power Source ..................................................................................................................19 GPIO-2 Interface .......................................................................................................................19 GPIO-3 Interface .......................................................................................................................20 GPIO-4 Interface .......................................................................................................................21 GPIO-5 Interface .......................................................................................................................21 GPIO-6 Interface .......................................................................................................................22 GPIO-4 with WDTO# / SUSLED Multi-function..........................................................................22 5.13 Particular ACPI Function pins ............................................................................................. 22 5.14 POWER PINS ..................................................................................................................... 22 6. ACPI GLUE LOGIC................................................................................................................... 24 7. CONFIGURATION REGISTER ACCESS PROTOCOL ........................................................... 27 7.1 Configuration Sequence ..................................................................................................... 28 7.1.1 7.1.2 7.1.3 7.1.4 8. Enter the Extended Function Mode.............................................................................................29 Configure the Configuration Registers ........................................................................................29 Exit the Extended Function Mode ...............................................................................................29 Software Programming Example.................................................................................................29 HARDWARE MONITOR ........................................................................................................... 31 8.1 General Description ............................................................................................................ 31 8.2 Access Interfaces................................................................................................................ 32 8.2.1 8.2.2 8.3 Analog Inputs ...................................................................................................................... 35 8.3.1 8.3.2 8.3.3 8.4 LPC Interface ..............................................................................................................................32 I2C interface ................................................................................................................................34 Voltages Over 2.048 V or Less Than 0 V ....................................................................................35 Voltage Detection........................................................................................................................36 Temperature Sensing..................................................................................................................36 SST Command Summary ................................................................................................... 38 8.4.1 8.4.2 Command Summary ...................................................................................................................38 Combination Sensor Data Format...............................................................................................39 -I- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 8.5 8.6 PECI.................................................................................................................................... 40 Fan Speed Measurement and Control................................................................................ 44 8.6.1 8.6.2 8.6.3 8.7 Interrupt Detection .............................................................................................................. 58 8.7.1 8.7.2 8.7.3 8.7.4 9. Fan Speed Measurement............................................................................................................44 Fan Speed Control ......................................................................................................................45 SMART FANTM Control ...............................................................................................................46 SMI# Interrupt Mode ...................................................................................................................58 OVT# Interrupt Mode ..................................................................................................................62 Caseopen Detection....................................................................................................................64 BEEP Alarm Function .................................................................................................................64 HARDWARE MONITOR REGISTER SET................................................................................ 66 9.1 Address Port (Port x5h) ...................................................................................................... 66 9.2 Data Port (Port x6h) ............................................................................................................ 66 9.3 SYSFANOUT PWM Output Frequency Configuration Register - Index 00h (Bank 0) ....... 66 9.4 SYSFANOUT Output Value Select Register - Index 01h (Bank 0)..................................... 67 9.5 CPUFANOUT0 PWM Output Frequency Configuration Register - Index 02h (Bank 0) ..... 68 9.6 CPUFANOUT0 Output Value Select Register - Index 03h (Bank 0) .................................. 68 9.7 FAN Configuration Register I - Index 04h (Bank 0) ............................................................ 69 9.8 SYSTIN Target Temperature Register/ SYSFANIN Target Speed Register - Index 05h (Bank 0) ........................................................................................................................................... 69 9.9 CPUTIN Target Temperature Register/ CPUFANIN0 Target Speed Register - Index 06h (Bank 0) ........................................................................................................................................... 70 9.10 Tolerance of Target Temperature or Target Speed Register - Index 07h (Bank 0) ........... 70 9.11 SYSFANOUT Stop Value Register - Index 08h (Bank 0) ................................................... 70 9.12 CPUFANOUT0 Stop Value Register - Index 09h (Bank 0)................................................. 71 9.13 SYSFANOUT Start-up Value Register - Index 0Ah (Bank 0) ............................................. 71 9.14 CPUFANOUT0 Start-up Value Register - Index 0Bh (Bank 0)........................................... 71 9.15 SYSFANOUT Stop Time Register - Index 0Ch (Bank 0).................................................... 72 9.16 CPUFANOUT0 Stop Time Register - Index 0Dh (Bank 0) ................................................. 72 9.17 Fan Output Step Down Time Register - Index 0Eh (Bank 0).............................................. 72 9.18 Fan Output Step Up Time Register - Index 0Fh (Bank 0) .................................................. 73 9.19 AUXFANOUT PWM Output Frequency Configuration Register - Index 10h (Bank 0) ....... 73 9.20 AUXFANOUT Output Value Select Register - Index 11h (Bank 0) .................................... 74 9.21 FAN Configuration Register II - Index 12h (Bank 0) ........................................................... 74 9.22 AUXTIN Target Temperature Register/ AUXFANIN0 Target Speed Register - Index 13h (Bank 0) ........................................................................................................................................... 75 9.23 Tolerance of Target Temperature or Target Speed Register - Index 14h (Bank 0) ........... 76 9.24 AUXFANOUT Stop Value Register - Index 15h (Bank 0)................................................... 76 9.25 AUXFANOUT Start-up Value Register - Index 16h (Bank 0) ............................................. 76 9.26 AUXFANOUT Stop Time Register - Index 17h (Bank 0) .................................................... 77 9.27 OVT# Configuration Register - Index 18h (Bank 0) ............................................................ 77 9.28 Reserved Registers - Index 19h ~ 1Fh (Bank 0) ................................................................ 77 9.29 Value RAM ⎯ Index 20h ~ 3Fh (Bank 0) ........................................................................... 78 9.30 Configuration Register - Index 40h (Bank 0) ...................................................................... 79 9.31 Interrupt Status Register 1 - Index 41h (Bank 0) ................................................................ 80 9.32 Interrupt Status Register 2 - Index 42h (Bank 0) ................................................................ 80 9.33 SMI# Mask Register 1 - Index 43h (Bank 0)....................................................................... 81 -II- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 9.34 SMI# Mask Register 2 - Index 44h (Bank 0)....................................................................... 81 9.35 Interrupt Status Register 4 - Index 45h (Bank 0) ................................................................ 82 9.36 SMI# Mask Register 3 - Index 46h (Bank 0)....................................................................... 82 9.37 Fan Divisor Register I - Index 47h (Bank 0)........................................................................ 83 9.38 Serial Bus Address Register - Index 48h (Bank 0) ............................................................. 83 9.39 CPUFANOUT0/AUXFANOUT Monitor Temperature Source Select Register - Index 49h (Bank 0) ........................................................................................................................................... 84 9.40 CPUFANOUT1 Monitor Temperature Source Select Register - Index 4Ah (Bank 0)......... 85 9.41 Fan Divisor Register II - Index 4Bh (Bank 0) ...................................................................... 86 9.42 SMI#/OVT# Control Register - Index 4Ch (Bank 0)............................................................ 86 9.43 FAN IN/OUT Control Register - Index 4Dh (Bank 0) .......................................................... 87 9.44 Register 50h ~ 5Fh Bank Select Register - Index 4Eh (Bank 0) ........................................ 88 9.45 Nuvoton Vendor ID Register - Index 4Fh (Bank 0)............................................................. 89 9.46 Reserved Register - Index 50h ~ 55h (Bank 0) .................................................................. 89 9.47 BEEP Control Register 1 - Index 56h (Bank 0)................................................................... 90 9.48 BEEP Control Register 2 - Index 57h (Bank 0)................................................................... 91 9.49 Chip ID - Index 58h (Bank 0) .............................................................................................. 92 9.50 Diode Selection Register - Index 59h (Bank 0)................................................................... 92 9.51 Reserved Register - Index 5Ah ~ 5Ch (Bank 0) ................................................................. 92 9.52 VBAT Monitor Control Register - Index 5Dh (Bank 0) ........................................................ 92 9.53 Critical Temperature and Current Mode Enable Register - Index 5Eh (Bank 0) ................ 94 9.54 Reserved Register - Index 5Fh (Bank 0) ............................................................................ 94 9.55 CPUFANOUT1 PWM Output Frequency Configuration Register - Index 60h (Bank 0) ..... 95 9.56 CPUFANOUT1 Output Value Select Register - Index 61h (Bank 0) .................................. 95 9.57 FAN Configuration Register III - Index 62h (Bank 0) .......................................................... 96 9.58 Target Temperature Register/CPUFANIN1 Target Speed Register - Index 63h (Bank 0). 96 9.59 CPUFANOUT1 Stop Value Register - Index 64h (Bank 0)................................................. 97 9.60 CPUFANOUT1 Start-up Value Register - Index 65h (Bank 0) ........................................... 97 9.61 CPUFANOUT1 Stop Time Register - Index 66h (Bank 0).................................................. 97 9.62 CPUFANOUT0 Maximum Output Value Register - Index 67h (Bank 0)............................. 98 9.63 CPUFANOUT0 Output Step Value Register - Index 68h (Bank 0)..................................... 98 9.64 CPUFANOUT1 Maximum Output Value Register - Index 69h (Bank 0)............................. 98 9.65 CPUFANOUT1 Output Step Value Register - Index 6Ah (Bank 0) .................................... 98 9.66 SYSFANOUT Critical Temperature register - Index 6Bh (Bank 0) ..................................... 99 9.67 CPUFANOUT0 Critical Temperature Register - Index 6Ch (Bank 0) ................................. 99 9.68 AUXFANOUT Critical Temperature Register - Index 6Dh (Bank 0) ................................... 99 9.69 CPUFANOUT1 Critical Temperature Register - Index 6Eh (Bank 0) ............................... 100 9.70 FANCTRL5 SMART FANTM III+ Temperature 1 Register (T1) – Index 6Fh (Bank 0) ...... 100 9.71 FANCTRL5 SMART FANTM III+ Temperature 2 Register (T2) – Index 70h (Bank 0) ...... 100 9.72 FANCTRL5 SMART FANTM III+ Temperature 3 Register (T3) – Index 71h (Bank 0) ...... 101 9.73 FANCTRL5 SMART FANTM III+ DC/PWM 1 Register - Index 72h (Bank 0)..................... 101 9.74 FANCTRL5 SMART FANTM III+ DC/PWM 2 Register - Index 73h (Bank 0)..................... 101 9.75 FANCTRL5 SMART FANTM III+ DC/PWM 3 Register - Index 74h (Bank 0)..................... 102 9.76 SMART FANTM III+-1 input source & output FAN select Register - Index 75h (Bank 0) .. 102 9.77 SYSTIN SMI# Shut-down mode High Limit Temperature Register - Index 76h (Bank 0) 103 9.78 SYSTIN SMI# Shut-down mode Low Limit Temperature Register - Index 77h (Bank 0) . 103 -III- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 9.79 9.80 9.81 9.82 9.83 9.84 9.85 9.86 9.87 9.88 9.89 9.90 CPUTIN SMI# Shut-down mode High Limit Temperature Register - Index 78h (Bank 0) 103 CPUTIN SMI# Shut-down mode Low Limit Temperature Register - Index 79h (Bank 0). 104 AUXTIN SMI# Shut-down mode High Limit Temperature Register - Index 7Ah (Bank 0) 104 AUXTIN SMI# Shut-down mode Low Limit Temperature Register - Index 7Bh (Bank 0) 104 Temperature selection Register - Index 7Ch (Bank 0) ..................................................... 105 Temperature Register - Index 7Dh (Bank 0)..................................................................... 105 CPUTIN Temperature Sensor Temperature (High Byte) Register - Index 50h (Bank 1) . 106 CPUTIN Temperature Sensor Temperature (Low Byte) Register - Index 51h (Bank 1) .. 106 CPUTIN Temperature Sensor Configuration Register - Index 52h (Bank 1).................... 106 CPUTIN Temperature Sensor Hysteresis (High Byte) Register - Index 53h (Bank 1) ..... 107 CPUTIN Temperature Sensor Hysteresis (Low Byte) Register - Index 54h (Bank 1) ...... 107 CPUTIN Temperature Sensor Over-temperature (High Byte) Register - Index 55h (Bank1) 108 9.91 CPUTIN Temperature Sensor Over-temperature (Low Byte) Register - Index 56h (Bank 1) 108 9.92 FANCTRL6 SMART FANTM III+ Temperature 1 Register (T1) – Index 58h (Bank 1) ...... 108 9.93 FANCTRL6 SMART FANTM III+ Temperature 2 Register (T2) – Index 59h (Bank 1) ...... 109 9.94 FANCTRL6 SMART FANTM III+ Temperature 3 Register (T3) – Index 5Ah (Bank 1) ...... 109 9.95 FANCTRL6 SMART FANTM III+ DC/PWM 1 Register - Index 5Bh (Bank 1) .................... 109 9.96 FANCTRL6 SMART FANTM III+ DC/PWM 2 Register - Index 5Ch (Bank 1) .................... 110 9.97 FANCTRL6 SMART FANTM III+ DC/PWM 3 Register - Index 5Dh (Bank 1) .................... 110 9.98 FANCTRL6 SMART FANTM III+ input source & output FAN select Register - Index 5Eh (Bank 1) ......................................................................................................................................... 110 9.99 AUXTIN Temperature Sensor Temperature (High Byte) Register - Index 50h (Bank 2).. 111 9.100 AUXTIN Temperature Sensor Temperature (Low Byte) Register - Index 51h (Bank 2) 111 9.101 AUXTIN Temperature Sensor Configuration Register - Index 52h (Bank 2).............. 112 9.102 AUXTIN Temperature Sensor Hysteresis (High Byte) Register - Index 53h (Bank 2) 112 9.103 AUXTIN Temperature Sensor Hysteresis (Low Byte) Register - Index 54h (Bank 2) 113 9.104 AUXTIN Temperature Sensor Over-temperature (High Byte) Register - Index 55h (Bank 2) 113 9.105 AUXTIN Temperature Sensor Over-temperature (Low Byte) Register - Index 56h (Bank 2) 113 9.106 Interrupt Status Register 3 - Index 50h (Bank 4) ........................................................ 114 9.107 SMI# Mask Register 4 - Index 51h (Bank 4)............................................................... 114 9.108 Reserved Register - Index 52h (Bank 4) .................................................................... 114 9.109 BEEP Control Register 3 - Index 53h (Bank 4) .......................................................... 115 9.110 SYSTIN Temperature Sensor Offset Register - Index 54h (Bank 4).......................... 115 9.111 CPUTIN Temperature Sensor Offset Register - Index 55h (Bank 4) ......................... 116 9.112 AUXTIN Temperature Sensor Offset Register - Index 56h (Bank 4).......................... 116 9.113 Reserved Register - Index 57h-58h (Bank 4) ............................................................. 116 9.114 Real Time Hardware Status Register I - Index 59h (Bank 4) ..................................... 116 9.115 Real Time Hardware Status Register II - Index 5Ah (Bank 4).................................... 117 9.116 Real Time Hardware Status Register III - Index 5Bh (Bank 4)................................... 118 9.117 Reserved Register - Index 5Ch ~ 5Fh (Bank 4) ......................................................... 119 9.118 Value RAM 2 ⎯ Index 50h-59h (Bank 5) ................................................................... 119 9.119 SYSFANIN SPEED HIGH-BYTE VALUE (RPM) - Index 50h (Bank 6)...................... 119 -IV- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 9.120 SYSFANIN SPEED LOW-BYTE VALUE (RPM) - Index 51h (Bank 6)....................... 120 9.121 CPUFANIN0 SPEED HIGH-BYTE VALUE (RPM) - Index 52h (Bank 6) ................... 120 9.122 CPUFANIN0 SPEED LOW-BYTE VALUE (RPM) - Index 53h (Bank 6) .................... 120 9.123 AUXFANIN0 SPEED HIGH-BYTE VALUE (RPM) - Index 54h (Bank 6).................... 121 9.124 AUXFANIN0 SPEED LOW-BYTE VALUE (RPM) - Index 55h (Bank 6) .................... 121 9.125 CPUFANIN1 SPEED HIGH-BYTE VALUE (RPM) - Index 56h (Bank 6) ................... 121 9.126 CPUFANIN1 SPEED LOW-BYTE VALUE (RPM) - Index 57h (Bank 6) .................... 122 9.127 AUXFANIN1 SPEED HIGH-BYTE VALUE (RPM) - Index 58h (Bank 6).................... 122 9.128 AUXFANIN1 SPEED LOW-BYTE VALUE (RPM) - Index 59h (Bank 6) .................... 122 9.129 FANOUT Configure register of PECI Error - Index 5Ah (Bank 6)............................... 123 9.130 FANCTRL2 pre-configured register for PECI error - Index 5Bh (Bank 6) .................. 123 9.131 FANCTRL3 pre-configured register for PECI error - Index 5Ch (Bank 6) .................. 123 9.132 FANCTRL4 pre-configured register for PECI error - Index 5Dh (Bank 6) .................. 124 9.133 FANCTRL5 pre-configured register for PECI error - Index 5Eh (Bank 6) .................. 124 9.134 FANCTRL6 pre-configured register for PECI error - Index 5Fh (Bank 6)................... 125 10. SERIAL PERIPHERAL INTERFACE ...................................................................................... 126 10.1 Using the SPI Interface via the LPC ................................................................................. 126 11. FLOPPY DISK CONTROLLER ............................................................................................... 129 11.1 FDC Functional Description .............................................................................................. 129 11.1.1 11.1.2 11.1.3 11.1.4 11.1.5 11.1.6 11.2 Register Descriptions........................................................................................................ 140 11.2.1 11.2.2 11.2.3 11.2.4 11.2.5 11.2.6 11.2.7 11.2.8 11.2.9 12. FIFO (Data) .............................................................................................................................129 Data Separator ........................................................................................................................130 Write Precompensation ...........................................................................................................130 Perpendicular Recording Mode ...............................................................................................130 FDC Core ................................................................................................................................131 FDC Commands ......................................................................................................................131 Status Register A (SA Register) (Read base address + 0)......................................................140 Status Register B (SB Register) (Read base address + 1)......................................................141 Digital Output Register (DO Register) (Write base address + 2) .............................................142 Tape Drive Register (TD Register) (Read base address + 3)..................................................143 Main Status Register (MS Register) (Read base address + 4) ................................................144 Data Rate Register (DR Register) (Write base address + 4) ...................................................144 FIFO Register (R/W base address + 5) ...................................................................................146 Digital Input Register (DI Register) (Read base address + 7)..................................................148 Configuration Control Register (CC Register) (Write base address + 7) .................................150 UART PORT ........................................................................................................................... 151 12.1 Universal Asynchronous Receiver/Transmitter (UART A, UART B)................................. 151 12.2 Register Description.......................................................................................................... 151 12.2.1 12.2.2 12.2.3 12.2.4 12.2.5 12.2.6 12.2.7 12.2.8 12.2.9 UART Control Register (UCR) (Read/Write)............................................................................151 UART Status Register (USR) (Read/Write) .............................................................................154 Handshake Control Register (HCR) (Read/Write) ...................................................................154 Handshake Status Register (HSR) (Read/Write).....................................................................155 UART FIFO Control Register (UFR) (Write only).....................................................................156 Interrupt Status Register (ISR) (Read only) .............................................................................156 Interrupt Control Register (ICR) (Read/Write)..........................................................................157 Programmable Baud Generator (BLL/BHL) (Read/Write)........................................................158 User-defined Register (UDR) (Read/Write) .............................................................................158 -V- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 13. PARALLEL PORT ................................................................................................................... 159 13.1 Printer Interface Logic....................................................................................................... 159 13.2 Enhanced Parallel Port (EPP)........................................................................................... 160 13.2.1 13.2.2 13.2.3 13.2.4 13.2.5 13.2.6 13.2.7 13.3 Extended Capabilities Parallel (ECP) Port........................................................................ 163 13.3.1 13.3.2 13.3.3 13.3.4 13.3.5 13.3.6 13.3.7 13.3.8 13.3.9 13.3.10 13.3.11 13.3.12 13.3.13 13.3.14 13.3.15 14. KB Control Register .................................................................................................................174 Port 92 Control Register ..........................................................................................................175 POWER MANAGEMENT EVENT........................................................................................... 176 15.1 Power Control Logic.......................................................................................................... 177 15.1.1 15.1.2 15.2 15.3 15.4 PSON# Logic...........................................................................................................................177 AC Power Failure Resume ......................................................................................................178 Wake Up the System by Keyboard and Mouse ................................................................ 179 15.2.1 15.2.2 Waken up by Keyboard events................................................................................................179 Waken up by Mouse events ....................................................................................................180 Resume Reset Logic......................................................................................................... 181 PWROK Generation.......................................................................................................... 181 15.4.1 16. ECP Register and Bit Map.......................................................................................................164 Data and ecpAFifo Port ...........................................................................................................165 Device Status Register (DSR) .................................................................................................165 Device Control Register (DCR)................................................................................................165 CFIFO (Parallel Port Data FIFO) Mode = 010 .........................................................................166 ECPDFIFO (ECP Data FIFO) Mode = 011 ..............................................................................166 TFIFO (Test FIFO Mode) Mode = 110.....................................................................................166 CNFGA (Configuration Register A) Mode = 111......................................................................166 CNFGB (Configuration Register B) Mode = 111......................................................................166 ECR (Extended Control Register) Mode = all .....................................................................167 ECP Pin Descriptions..........................................................................................................168 ECP Operation....................................................................................................................169 FIFO Operation...................................................................................................................170 DMA Transfers....................................................................................................................170 Programmed I/O (NON-DMA) Mode ...................................................................................170 KEYBOARD CONTROLLER................................................................................................... 171 14.1 Output Buffer..................................................................................................................... 171 14.2 Input Buffer........................................................................................................................ 171 14.3 Status Register ................................................................................................................. 172 14.4 Commands........................................................................................................................ 172 14.5 Hardware GATEA20/Keyboard Reset Control Logic........................................................ 174 14.5.1 14.5.2 15. Data Port (Data Swapper) .......................................................................................................160 Printer Status Buffer ................................................................................................................161 Printer Control Latch and Printer Control Swapper..................................................................161 EPP Address Port....................................................................................................................162 EPP Data Port 0-3 ...................................................................................................................162 EPP Pin Descriptions ..............................................................................................................162 EPP Operation.........................................................................................................................162 The Relation among PWROK/PWROK2, ATXPGD and FTPRST#.........................................182 SERIALIZED IRQ.................................................................................................................... 185 16.1 Start Frame ....................................................................................................................... 185 16.2 IRQ/Data Frame................................................................................................................ 186 -VI- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 17. 18. 19. 20. 21. 22. 16.3 Stop Frame ....................................................................................................................... 187 WATCHDOG TIMER............................................................................................................... 188 GENERAL PURPOSE I/O....................................................................................................... 189 VID INPUTS AND OUTPUTS ................................................................................................. 190 19.1 VID Input Detection........................................................................................................... 190 19.2 VID Output Control............................................................................................................ 190 PCI RESET BUFFERS ........................................................................................................... 191 CONFIGURATION REGISTER............................................................................................... 192 21.1 Chip (Global) Control Register.......................................................................................... 192 21.2 Logical Device 0 (FDC)..................................................................................................... 199 21.3 Logical Device 1 (Parallel Port)......................................................................................... 202 21.4 Logical Device 2 (UART A) ............................................................................................... 203 21.5 Logical Device 3 (UART B) ............................................................................................... 204 21.6 Logical Device 5 (Keyboard Controller) ............................................................................ 206 21.7 Logical Device 6 (Serial Peripheral Interface) .................................................................. 208 21.8 Logical Device 7 (GPIO6) ................................................................................................. 209 21.9 Logical Device 8 (WDTO# & PLED) ................................................................................. 211 21.10 Logical Device 9 (GPIO2, GPIO3, GPIO4, GPIO5).................................................... 213 21.11 Logical Device A (ACPI) ............................................................................................. 219 21.12 Logical Device B (Hardware Monitor) ......................................................................... 227 21.13 Logical Device C (PECI, SST) .................................................................................... 229 SPECIFICATIONS .................................................................................................................. 235 22.1 Absolute Maximum Ratings .............................................................................................. 235 22.2 Hardware Monitor Ratings ................................................................................................ 235 22.3 DC CHARACTERISTICS.................................................................................................. 235 22.4 AC CHARACTERISTICS .................................................................................................. 247 22.4.1 22.4.2 22.4.3 22.4.4 22.4.5 22.4.6 22.4.7 22.4.8 22.4.9 22.4.10 22.4.11 22.4.12 22.4.13 23. 24. 25. 26. Power On / Off Timing .............................................................................................................247 AC Power Failure Resume Timing ..........................................................................................248 VSBGATE# Timing ..................................................................................................................251 Clock Input Timing ...................................................................................................................251 PECI and SST Timing..............................................................................................................253 SPI Timing ...............................................................................................................................254 SMBus Timing .........................................................................................................................255 Floppy Disk Drive Timing.........................................................................................................255 UART/Parallel Port ..................................................................................................................257 Parallel Port Mode Parameters...........................................................................................259 Parallel Port ........................................................................................................................260 KBC Timing Parameters .....................................................................................................267 GPIO Timing Parameters....................................................................................................270 22.5 LPC Timing ....................................................................................................................... 272 TOP MARKING SPECIFICATIONS........................................................................................ 273 ORDERING INFORMATION................................................................................................... 274 PACKAGE SPECIFICATION .................................................................................................. 275 REVISION HISTORY .............................................................................................................. 276 -VII- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT List of Figures Figure 3-1 W83627DHG-P Block Diagram ....................................................................................... 5 Figure 4-1 Pin Layout for W83627DHG-P......................................................................................... 6 Figure 7-1 Structure of the Configuration Register ......................................................................... 27 Figure 7-2 Devices of I/O Base Address......................................................................................... 28 Figure 7-3 Configuration Register ................................................................................................... 28 Figure 7-4 Chip (Global) Control Registers..................................................................................... 30 Figure 8-1 LPC Bus' Reads from / Writes to Internal Registers...................................................... 33 Figure 8-2 Serial Bus Write to Internal Address Register Followed by the Data Byte .................... 34 Figure 8-3 Serial Bus Read from Internal Address Register........................................................... 34 Figure 8-4 Analog Inputs and Application Circuit of the W83627DHG-P........................................ 35 Figure 8-5 Monitoring Temperature from Thermistor...................................................................... 37 Figure 8-6 Monitoring Temperature from Thermal Diode (Voltage Mode)...................................... 37 Figure 8-7 Monitoring Temperature from Thermal Diode (Current Mode)...................................... 38 Figure 8-8 PECI Temperature......................................................................................................... 41 Figure 8-9 Temperature and Fan Speed Relation after Tbase Offsets .......................................... 42 Figure 8-10 Block Diagram for PECI 1.0......................................................................................... 43 Figure 8-11 FANOUT and Corresponding Temperature Sensors in SMART FANTM I, III, and III+.47 Figure 8-12 Mechanism of Thermal CuriseTM Mode (PWM Duty Cycle) ........................................ 49 Figure 8-13 Mechanism of Thermal CuriseTM Mode (DC Output Value) ........................................ 49 Figure 8-14 Mechanism of Fan Speed CruiseTM Mode................................................................... 50 Figure 8-15 Setting of SMART FANTM III ........................................................................................ 53 Figure 8-16 SMART FANTM III Mechanism (Current Temp. > Target Temp. + Tol.) ...................... 53 Figure 8-17 SMART FANTM III Mechanism (Current Temp. < Target Temp. - Tol.) ....................... 54 Figure 8-18 SMART FANTM III+ Mechanism ................................................................................... 56 Figure 8-19 SMI Mode of Voltage and Fan Inputs .......................................................................... 58 Figure 8-20 SMI Mode of SYSTIN I ................................................................................................ 60 Figure 8-21 SMI Mode of SYSTIN II ............................................................................................... 61 Figure 8-22 SMI Mode of CPUTIN .................................................................................................. 62 Figure 8-23 OVT# Modes of Temperature Inputs ........................................................................... 63 Figure 8-24 Caseopen Mechanism ................................................................................................. 64 Figure 14-1 Keyboard and Mouse Interface.................................................................................. 171 Figure 15-1 Power Control Mechanism......................................................................................... 177 Figure 15-2 Power Sequence from S5 to S0, then Back to S5..................................................... 178 Figure 15-3 The previous state is “on” - 3VCC falls to 2.6V and SUSB# keeps at 2.0V .............. 179 Figure 15-4 The previous state is “off” - 3VCC falls to 2.6V and SUSB# keeps at 0.8V .............. 179 Figure 15-5 Mechanism of Resume Reset Logic.......................................................................... 181 Figure 15-6 .................................................................................................................................... 181 Figure 15-7 .................................................................................................................................... 183 Figure 15-8 .................................................................................................................................... 183 Figure 15-9 .................................................................................................................................... 184 -VIII- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT List of Tables Table 8-1 Temperature Data Format .............................................................................................. 36 Table 8-2 SST Command Summary ............................................................................................... 38 Table 8-3 Typical Temperature Values ........................................................................................... 39 Table 8-4 Fan Divisor Definition...................................................................................................... 44 Table 8-5 Divisor, RPM, and Count Relation .................................................................................. 44 Table 8-6 Display Registers - at SMART FANTM I Mode ................................................................ 50 Table 8-7 Relative Registers - at Thermal CruiseTM Mode ............................................................. 51 Table 8-8 Relative Registers-at Fan Speed CruiseTM Mode ........................................................... 51 Table 8-9 Display Register - in SMART FANTM III Mode ................................................................ 55 Table 8-10 Relative Register - in SMART FANTM III Control Mode................................................. 55 Table 8-11 Display Registers - in SMART FANTM III+ Mode........................................................... 57 Table 10-1 Base Address Setting ................................................................................................. 126 Table 10-2 SPI Address Map ........................................................................................................ 126 Table 10-3 MODE ......................................................................................................................... 127 Table 11-1 The Delays of the FIFO............................................................................................... 129 Table 11-2 FDC Registers............................................................................................................. 140 Table 12-1 Register Summary for UART ...................................................................................... 153 Table 13-1 Pin Descriptions for SPP, EPP, and ECP Modes ....................................................... 159 Table 13-2 EPP Register Addresses ............................................................................................ 160 Table 13-3 Address and Bit Map for SPP and EPP Modes .......................................................... 160 Table 13-4 ECP Mode Description................................................................................................ 163 Table 13-5 ECP Register Addresses ............................................................................................ 164 Table 13-6 Bit Map of the ECP Registers ..................................................................................... 164 Table 14-1 Bit Map of Status Register .......................................................................................... 172 Table 14-2 KBC Command Sets................................................................................................... 172 Table 15-1 Bit Map of Logical Device A, CR[E4h], Bits[6:5] ......................................................... 178 Table 15-2 Definitions of Mouse Wake-Up Events ....................................................................... 180 Table 15-3 Timing and Voltage Parameters of RSMRST# ........................................................... 181 Table 15-4 ..................................................................................................................................... 182 Table 15-5 Bit Map of Logical Device A, CR[E6h], Bits[3:1] ......................................................... 182 Table 15-6 ..................................................................................................................................... 183 Table 16-1 SERIRQ Sampling Periods ......................................................................................... 186 -IX- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 1. GENERAL DESCRIPTION The W83627DHG-P is a member of Nuvoton's Super I/O product line. This family features the LPC (Low Pin Count) interface. This interface is more economical than its ISA counterpart, in that it has approximately forty pins fewer, yet still provides as great performance. In addition, the improvement allows even more efficient operation of software, BIOS and device drivers. In addition to providing an LPC interface for I/O, the W83627DHG-P monitors several critical parameters in PC hardware, including power supply voltages, fan speeds, and temperatures. In terms of temperature monitoring, the W83627DHG-P adopts the Current Mode (dual current source) approach. The W83627DHG-P also supports the Smart Fan control system, including SMART FANTM I, SMART FANTM III and SMART FANTM III+, which makes the system more stable and user-friendly. The W83627DHG-P supports four -- 360K, 720K, 1.2M, 1.44M, or 2.88M -- disk drive types and data transfer rates of 250 Kb/s, 300 Kb/s, 500 Kb/s, 1 Mb/s, and 2 Mb/s. The disk drive adapter supports the functions of floppy disk drive controller (compatible with the industry standard 82077/ 765), data separator, write pre-compensation circuit, decode logic, data rate selection, clock generator, drive interface control logic, and interrupt and DMA logic. Such a wide range of functions integrated into one W83627DHG-P greatly reduces the number of required components to interface with floppy disk drives. The W83627DHG-P provides two high-speed serial communication ports (UARTs), one of which provides IR functions IrDA 1.0 (SIR for 1.152K bps). Each UART includes a 16-byte send/receive FIFO, a programmable baud rate generator, complete modem-control capability, and a processor interrupt system. Both UARTs support legacy speeds up to 115.2K bps as well as even higher baud rates of 230K, 460K, or 921K bps to support higher speed modems. The W83627DHG-P supports the PC-compatible printer port (SPP), the bi-directional printer port (BPP), the enhanced parallel port (EPP) and the extended capabilities port (ECP). The W83627DHG-P provides a bridge of the Low Pin Count interface to Serial Peripheral Interface (SPI) that supports up to 8M bits serial flash ROM. The W83627DHG-P provides flexible I/O control functions through a set of 40 general purpose I/O (GPIO) ports. These GPIO ports may serve as simple I/O ports or may be individually configured to provide alternative functions. The W83627DHG-P supports the SST (Simple Serial Transport) interface and Intel® PECI (Platform Environment Control Interface). The W83627DHG-P fully complies with the Microsoft© PC98, PC99 and PC2001 System Design Guides and meets the requirements of ACPI. The configuration registers inside the W83627DHG-P support mode selection, function enable and disable, and power-down selection. Furthermore, the configurable PnP features are compatible with the plug-and-play feature in Windows 95/98/2000/XPTM, making the allocation of the system resources more efficient than ever. One special characteristic of the Super I/O product line is the separation of the power supply in normal operation from that in standby operation. Please pay attention to the layout of these two power supplies to avoid short circuits. Otherwise, the feature will not function. In addition to W83627DHG-P, there is W83627DHG-PT. W83627DHG-PT is exactly the same as W83627DHG-P, except the IC operation temperature. W83627DHG-PT supports industrial standard, which means the IC operating temperature ranges from -40℃ to 85℃. W83627DHG-P supports commercial standard, which means the IC operating temperature ranges from 0℃ to 70℃. -1- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 2. FEATURES General y y y y y y y y Comply with LPC specification 1.1 version Support LDRQ# (LPC DMA), SERIRQ (Serialized IRQ) Integrated hardware monitor functions Compliant with Microsoft PC98/PC99/PC2001 System Design Guide Support DPM (Device Power Management), ACPI (Advanced Configuration and Power Interface) Programmable configuration settings Single 24- or 48-MHz clock input Support selective pins of 5 V tolerance FDC y y y y y y y y y y y y y Variable write pre-compensation with track-selection capability Support vertical recording format DMA-enable logic 16-byte data FIFOs Support floppy disk drives and tape drives Detect all overrun and underrun conditions Built-in address mark detection circuit to simplify the read electronics FDD anti-virus functions with software write protect and FDD-write enable signal (write data signal forced to be inactive) Support 3.5-inch or 5.25-inch floppy disk drives Compatible with industry standard 82077 360K / 720K / 1.2M / 1.44M / 2.88M formats 250K, 300K, 500K, 1M, 2M bps data transfer rate Support 3-mode FDD and its Windows driver UART y y y y y Two high-speed, 16550-compatible UARTs with 16-byte send / receive FIFOs Fully programmable serial-interface characteristics: --- 5, 6, 7 or 8-bit characters --- Even, odd or no parity bit generation/detection --- 1, 1.5 or 2 stop-bit generation Internal diagnostic capabilities: --- Loop-back controls for communications link fault isolation --- Break, parity, overrun, framing error simulation 16 Programmable baud rate generator allows division of clock source by any value from 1 to (2 1) Maximum baud rate for clock source 24 MHz is 1.5 M bps. -2- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT Parallel Port y y y y y y Compatible with IBM parallel port Support PS/2-compatible bi-directional parallel port Support Enhanced Parallel Port (EPP) - Compatible with IEEE 1284 specification Support Extended Capabilities Port (ECP) - Compatible with IEEE 1284 specification Enhanced printer port back-drive current protection Extension FDD mode support disk drive B; and Extension 2FDD mode support disk drives A and B through parallel port Keyboard Controller • 8042-based keyboard controller • Asynchronous Access to two data registers and one status register • Software-compatible with 8042 • Support PS/2 mouse • Support Port 92 • Support both interrupt and polling modes • Fast Gate A20 and Hardware Keyboard Reset • 12MHz operating frequency Hardware Monitor Functions y y y y y y y y y y y y y y y Smart Fan control system, supporting the functions of SMART FANTM I -- “Thermal CruiseTM” and “Speed CruiseTM” modes, SMART FANTM III and SMART FANTM III+ Programmable threshold temperature to speed fan fully while current temperature exceeds this threshold in the Thermal CruiseTM mode Three thermal inputs from the different combinations of remote thermistors, and the thermal diode output Support Current Mode (dual current source) temperature sensing method Nine voltage inputs (CPUVCORE, VIN[0..3] and 3VCC, AVCC , 3VSB, VBAT) Five fan-speed monitoring inputs Four fan-speed controls Dual mode for fan control (PWM and DC) Built-in case open detection circuit Programmable hysteresis and setting points for all monitored items Over-temperature indicator output Issue SMI#, OVT# to activate system protection Nuvoton Hardware DoctorTM support Eight VID inputs / outputs Provide I2C interface to read / write registers Serial Peripheral Interface y y Support up to 8M bits SPI Flash Memory with clock up to 33 MHz Support Mode 0 and Mode 3 -3- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT Infrared • Support IrDA version 1.0 SIR protocol with maximum baud rate up to 115.2K bps • Support SHARP ASK-IR protocol with maximum baud rate up to 57,600 bps General Purpose I/O Ports y y y 40 programmable general purpose I/O ports GPIO port 4 supports the optional functions of Watchdog Timer Out and Suspend LED Output GP30, GP31 and GP35 can distinguish whether the input pins undergo any transitions by reading the registers. All of the 3 GPIOs can assert PSOUT# or PME# to wake up the system if each of them undergoes any transition. OnNow Functions y y y Keyboard Wake-Up by programmable keys Mouse Wake-Up by programmable buttons OnNow Wake-Up from all of the ACPI sleeping states (S1-S5) Simple Serial Transport™ Interface y y SST temperature and voltage Combination Sensor command support Support SST 0.9 Specification PECI Interface y y Support PECI 1.0 and 1.1a Specifications Support 4 CPU addresses and 2 domains per CPU address Package y y 128-pin QFP Pb-free/RoHS -4- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 3. BLOCK DIAGRAM LRESET#, PCICLK, LFRAME#, LAD [3:0], LDRQ#, SERIRQ LPC Interface SST SST Interface FDC SMBus Interface UARTA General-purpose I/O pins GPIO UARTB IR Hardware Monitor channel and Vref HM Keyboard/Mouse data and clock KBC Floppy drive interface signals SCL SDA VID I/O pins Serial Peripheral Interface PRT UARTA interface signals UARTB interface signals Infrared interface signals Printer port interface signals ACPI VID PECI Interface SPI PECI W83627DHG-P Figure 3-1 W83627DHG-P Block Diagram -5- Publication Release Date: July 09, 2009 Version 1.94 AVCC 3VSB 3VCC W83627DHG-P -63VCC VTT 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 CPUTIN SYSTIN CPUDPECISB Vtt PECI NC PECI_REQ# AUXFANIN0 CPUFANIN0 SYSFANIN SST CPUFANOUT0 SYSFANOUT (FAN_SET)PLED BEEP/SO GP21/CPUFANIN1 GP20/CPUFANOUT1 VID7 VID6 VID5 VID4 VID3 VID2 VID1 VID0 DRVDEN0 GP23/SCK INDEX# MOA# SMI#/OVT# DSA# AUXFANOUT DIR# STEP# WD# WE# 3VCC TRAK0# WP# RDATA# HEAD# DSKCHG# IOCLK GP22/SCE VSS PCICLK LDRQ# SERIRQ LAD3 LAD2 LAD1 LAD0 3VCC LFRAME# LRESET# SLCT PE BUSY ACK# PD7 PD6 PD5 PD4 102 101 100 99 98 97 96 95 94 93 92 91 90 89 88 87 86 85 84 83 82 81 80 79 78 77 76 75 74 73 72 71 70 69 68 67 66 65 AUXTIN VREF CPUVCORE VIN0 VIN1 VIN2 VIN3 AVCC RSTOUT0# RSTOUT1# GP30/PWROK2 GP31/VSBGATE# GP32/RSTOUT2#/SCL GP33/RSTOUT3#/SDA GP34/RSTOUT4# GP35/ATXPGD PME# GP40/RIB# GP41/DCDB# GP42/SOUTB/IRTX(FAN_SE2) GP43/SINB/IRRX GP44/DTRB# GP45/RTSB# GP46/DSRB# GP47/CTSB# GP50/WDTO#(EN_GTL) CASEOPEN# RSMRST#/GP51 VBAT SUSB#/GP52 PSON#/GP53 PWROK/GP54 GP55/SUSLED(EN_ACPI) GP36/FTPRST# PSIN#/GP56 PSOUT#/GP57 MDAT/GP24 MCLK/GP25 W83627DHG-P/W83627DHG-PT 4. PIN LAYOUT VBAT 3VSB 3VSB VBAT 3VCC 64 63 62 61 60 59 58 57 56 55 54 53 52 51 50 49 48 47 46 45 44 43 42 41 40 39 GP37/SUSC# KDAT/GP26 KCLK/GP27 3VSB KBRST# GA20M SI/AUXFANIN1 RIA#/GP60 DCDA#/GP61 VSS SOUTA/GP62(PENKBC) SINA/GP63 DTRA#/GP64(PENROM) RTSA#/GP65(HEFRAS) DSRA#/GP66 CTSA#/GP67 3VCC STB# AFD# ERR# INIT# SLIN# PD0 PD1 PD2 PD3 Figure 4-1 Pin Layout for W83627DHG-P Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 5. PIN DESCRIPTION Note: Please refer to Section 22.3 DC AOUT AIN INcd CHARACTERISTICS for details. - Analog output pin - Analog input pin - CMOS-level input pin with internal pull-down resistor INcs - CMOS-level, Schmitt-trigger input pin INcsu - CMOS-level, Schmitt-trigger input pin with internal pull-up resistor INt - TTL-level input pin INtd - TTL-level input pin with internal pull-down resistor INts - TTL-level, Schmitt-trigger input pin INtp3 - 3.3V, TTL-level input pin INtsp3 - 3.3V TTL level Schmitt-trigger input pin INtu - TTL-level input pin with internal pull-up resistor I/O8 - bi-directional pin with 8-mA source-sink capability I/O8t - TTL-level, bi-directional pin with 8-mA source-sink capability I/O12 - bi-directional pin with 12-mA source-sink capability I/O12t - TTL-level, bi-directional pin with 12-mA source-sink capability I/O12ts - Schmitt-trigger, bi-directional pin with 12-mA source-sink capability I/O12tp3 - 3.3V, TTL-level, bi-directional pin with 12-mA source-sink capability I/OD8t - TTL-level, bi-directional pin. Open-drain output with 8-mA sink capability I/OD12 - Bi-directional pin. Open-drain output with 12-mA sink capability I/OD12t - TTL-level bi-directional pin. Open-drain output with 12-mA sink capability I/OD12cs - CMOS-level, bi-directional, Schmitt-trigger pin. Open-drain output with 12-mA sink capability I/OD12ts - TTL-level, bi-directional, Schmitt-trigger pin. Open-drain output with 12-mA sink capability I/OD12tp3 - 3.3V, TTL-level, bi-directional pin. Open-drain output with 12-mA sink capability I/OD16t - TTL-level, bi-directional pin. Open-drain output with 16-mA sink capability I/OD16ts - Schmitt-trigger, bi-directional pin. Open-drain output with 16-mA sink capability I/OD16cs - CMOS-level, Schmitt-trigger, bi-directional pin. Open-drain output with 16-mA sink capability I/OD24t - TTL-level, bi-directional pin. Open-drain output with 24-mA sink capability O12p3 - 3.3V output pin with 12-mA source-sink capability O12tp3 - 3.3V, TTL-level output pin with 12-mA source-sink capability O8 - TTL-level output pin with 8-mA source-sink capability O12 - TTL-level output pin with 12-mA source-sink capability O24 - TTL-level output pin with 24-mA source-sink capability OD8 - Open-drain output pin with 8-mA sink capability OD12 - Open-drain output pin with 12-mA sink capability OD24 - Open-drain output pin with 24-mA sink capability IV3 I/OV3 - Bi-direction pin with source capability of 6 mA and sink capability of 1 mA - Bi-direction pin with source capability of 6 mA and sink capability of 1 mA -7- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 5.1 LPC Interface SYMBOL PIN I/O DESCRIPTION IOCLK 18 INtp3 System clock input, either 24MHz or 48MHz. The actual frequency must be specified in the register. The default value is 48MHz. PME# 86 OD12p3 PCICLK 21 INtsp3 PCI-clock 33-MHz input. LDRQ# 22 O12p3 Encoded DMA Request signal. SERIRQ 23 I/OD12tp3 LAD[3:0] 2427 I/O12tp3 These signal lines communicate address, control, and data information over the LPC bus between a host and a peripheral. LFRAME# 29 INtsp3 Indicates the start of a new cycle or the termination of a broken cycle. LRESET# 30 INtsp3 Reset signal. It can be connected to the PCIRST# signal on the host. 5.2 Generated PME event. Serialized IRQ input / output. FDC Interface SYMBOL PIN I/O DESCRIPTION DRVDEN0 1 OD24 Drive Density Select bit 0. INDEX# 3 INcs This Schmitt-trigger input from the disk drive is active-low when the head is positioned over the beginning of a track marked by an index hole. This input pin needs to connect a pulled-up 1-KΩ resistor to 5V for Floppy Drive compatibility. MOA# 4 OD24 Motor A On. When set to 0, this pin activates disk drive A. This is an open-drain output. DSA# 6 OD24 Drive Select A. When set to 0, this pin activates disk drive A. This is an open-drain output. DIR# 8 OD24 Direction of the head step motor. An open-drain output. Logic 1 = outward motion Logic 0 = inward motion STEP# 9 OD24 Step output pulses. This active-low open-drain output produces a pulse to move the head to another track. WD# 10 OD24 Write data. This logic-low open-drain writes pre-compensation serial data to the selected FDD. An open-drain output. WE# 11 OD24 Write enable. An open-drain output. TRAK0# 13 INcs Track 0. This Schmitt-trigger input from the disk drive is active-low when the head is positioned over the outermost track. This input pin needs to connect a pulled-up 1-KΩ resistor to 5V for Floppy Drive compatibility. WP# 14 INcs Write protected. This active-low Schmitt input from the disk drive indicates that the diskette is write-protected. This input pin needs to connect a pulled-up 1-KΩ resistor to 5V for Floppy Drive compatibility. -8- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT SYMBOL PIN I/O DESCRIPTION RDATA# 15 INcs The read-data input signal from the FDD. This input pin needs to connect a pulled-up 1-KΩ resistor to 5V for Floppy Drive compatibility. HEAD# 16 OD24 Head selection. This open-rain output determines which disk drive head is active. Logic 1 = side 0 Logic 0 = side 1 DSKCHG# 17 INcs Diskette change. This signal is active-low at power-on and whenever the diskette is removed. This input pin needs to connect a pulled-up 1KΩ resistor to 5V for Floppy Drive compatibility. 5.3 Multi-Mode Parallel Port SYMBOL PIN I/O DESCRIPTION SLCT 31 INts PRINTER MODE: An active-high input on this pin indicates that the printer is selected. See the description of the parallel port for the definition of this pin in ECP and EPP modes. EXTENSION FDD MODE: This pin is for Extension FDD B; its function is the same as the WE# pin of FDC. EXTENSION 2FDD MODE: This pin is for Extension FDD A and B; its function is the same as the WE# pin of FDC. WE2# PE OD12 32 INts WD2# OD12 BUSY MOB2# 33 INts OD12 PRINTER MODE: An active-high input on this pin indicates that the printer has detected the end of the paper. See the description of the parallel port for the definitions of this pin in ECP and EPP modes. EXTENSION FDD MODE: This pin is for Extension FDD B; its function is the same as the WD# pin of FDC. EXTENSION 2FDD MODE This pin is for Extension FDD A and B; its function is the same as the WD# pin of FDC PRINTER MODE: An active-high input indicates that the printer is not ready to receive data. See the description of the parallel port for the definitions of this pin in ECP and EPP modes. EXTENSION FDD MODE: This pin is for Extension FDD B; its function is the same as the MOB# pin of FDC. EXTENSION 2FDD MODE: This pin is for Extension FDD A and B; its function is the same as the MOB# pin of FDC. -9- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT SYMBOL PIN I/O DESCRIPTION ACK# 34 INts PRINTER MODE: ACK# An active-low input on this pin indicates that the printer has received data and is ready to accept more data. See the descriptions of the parallel port for the definition of this pin in ECP and EPP modes. EXTENSION FDD MODE: This pin is for Extension FDD B; its function is the same as the DSB# pin of FDC. EXTENSION 2FDD MODE: This pin is for Extension FDD A and B; its function is the same as the DSB# pin of FDC. DSB2# ERR# OD12 45 HEAD2# SLIN# OD12 43 STEP2# INIT# DIR2# INts OD12 OD12 44 OD12 OD12 PRINTER MODE: ERR# An active-low input on this pin indicates that the printer has encountered an error condition. See the description of the parallel port for the definitions of this pin in ECP and EPP modes. EXTENSION FDD MODE: This pin is for Extension FDD B; its function is the same as the HEAD# pin of FDC. EXTENSION 2FDD MODE: This pin is for Extension FDD A and B; its function is the same as the HEAD# pin of FDC. PRINTER MODE: SLIN# Output line for detection of printer selection. See the description of the parallel port for the definitions of this pin in ECP and EPP modes. EXTENSION FDD MODE: This pin is for Extension FDD B; its function is the same as the STEP# pin of FDC. EXTENSION 2FDD MODE: This pin is for Extension FDD A and B; its function is the same as the STEP# pin of FDC. PRINTER MODE: INIT# Output line for the printer initialization. See the description of the parallel port for the definitions of this pin in ECP and EPP modes. EXTENSION FDD MODE: This pin is for Extension FDD B; its function is the same as the DIR# pin of FDC. EXTENSION 2FDD MODE: This pin is for Extension FDD A and B; its function is the same as the DIR# pin of FDC. -10- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT SYMBOL PIN I/O DESCRIPTION AFD# 46 OD12 OD12 PRINTER MODE: AFD# An active-low output from this pin causes the printer to auto feed a line after a line is printed. See the description of the parallel port for the definitions of this pin in ECP and EPP modes. EXTENSION FDD MODE: This pin is for Extension FDD B; its function is the same as the DRVDEN0# pin of FDC. EXTENSION 2FDD MODE: This pin is for Extension FDD A and B; its function is the same as the DRVDEN0# pin of FDC. PRINTER MODE: STB# An active-low output is used to latch the parallel data into the printer. See the description of the parallel port for the definitions of this pin in ECP and EPP modes. DRVDEN02 STB# 47 OD12 PD0 42 I/O12t s INDEX2# INts PD1 41 I/O12t s TRAK02# INts PD2 40 I/O12t s WP2# INts PRINTER MODE: PD0 Parallel port data bus bit 0. See the description of the parallel port for the definitions of this pin in ECP and EPP modes. EXTENSION FDD MODE: This pin is for Extension FDD B; its function is the same as the INDEX# pin of FDC. EXTENSION 2FDD MODE: This pin is for Extension FDD A and B; its function is the same as the INDEX# pin of FDC. PRINTER MODE: PD1 Parallel port data bus bit 1. See the description of the parallel port for the definitions of this pin in ECP and EPP modes. EXTENSION FDD MODE: This pin is for Extension FDD B; its function is the same as the TRAK0# pin of FDC. EXTENSION 2FDD MODE: This pin is for Extension FDD A and B; its function is the same as the TRAK0# pin of FDC. PRINTER MODE: PD2 Parallel port data bus bit 2. See the description of the parallel port for the definitions of this pin in ECP and EPP modes. EXTENSION FDD MODE: This pin is for Extension FDD B; its function is the same as the WP# pin of FDC. EXTENSION 2FDD MODE: This pin is for Extension FDD A and B; its function is the same as the WP# pin of FDC. -11- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT SYMBOL PIN I/O DESCRIPTION PD3 39 I/O12t PRINTER MODE: PD3 Parallel port data bus bit 3. See the description of the parallel port for the definitions of this pin in ECP and EPP modes. EXTENSION FDD MODE: This pin is for Extension FDD B; its function is the same as the RDATA# pin of FDC. EXTENSION 2FDD MODE: This pin is for Extension FDD A and B; its function is the same as the RDATA# pin of FDC. s RDATA2# INts PD4 38 I/O12t s DSKCHG2# INts PD5 37 I/O12t PD6 36 I/O12t s s MOA2# OD12 PD7 35 I/O12t s DSA2# OD12 5.4 PRINTER MODE: PD4 Parallel port data bus bit 4. See the description of the parallel port for the definition of this pin in ECP and EPP modes. EXTENSION FDD MODE: This pin is for Extension FDD B; its function is the same as the DSKCHG# pin of FDC. EXTENSION 2FDD MODE: This pin is for Extension FDD A and B; its function is the same as the DSKCHG# pin of FDC. PRINTER MODE: PD5 Parallel port data bus bit 5. See the description of the parallel port for the definitions of this pin in ECP and EPP modes. EXTENSION FDD MODE: This pin is a tri-state output. EXTENSION 2FDD MODE:MOA2# This pin is a tri-state output. PRINTER MODE: PD6 Parallel port data bus bit 6. See the description of the parallel port for the definitions of this pin in ECP and EPP modes. EXTENSION FDD MODE: This pin is a tri-state output. EXTENSION 2FDD MODE: This pin is for Extension FDD A; its function is the same as the MOA# pin of FDC PRINTER MODE: PD7 Parallel port data bus bit 7. See the description of the parallel port for the definitions of this pin in ECP and EPP modes. EXTENSION FDD MODE: This pin is a tri-state output. EXTENSION 2FDD MODE: This pin is for Extension FDD A; its function is the same as the DSA# pin of FDC. Serial Port & Infrared Port Interface SYMBOL PIN I/O DESCRIPTION -12- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT SYMBOL RIA# PIN 57 GP60 DCDA# I/O DESCRIPTION INt Ring Indicator. An active-low signal indicates that a ring signal is being received from the modem or the data set. I/OD12t 56 INt General-purpose I/O port 6 bit 0. Data Carrier Detection. An active-low signal indicates the modem or data set has detected a data carrier. GP61 I/OD12t SOUTA O8 UART A Serial Output. This pin is used to transmit serial data out to the communication link. INt During power on reset, this pin is pulled down internally and is defined as PENKBC, and the power-on values are shown at CR24 bit 2. The PCB layout should reserve space for a 1-kΩ resistor to pull down this pin to ensure the disabling of KBC, and a 1-kΩ resistor is recommended to pull the pin up If wish to enable KBC. I/O8 General-purpose I/O port 6 bit 2. INt Serial Input. This pin is used to receive serial data through the communication link. PENKBC 54 GP62 SINA 53 General-purpose I/O port 6 bit 1. GP63 I/OD12t DTRA# O8 UART A Data Terminal Ready. An active-low signal informs the modem or data set that the controller is ready to communicate. INt During power-on reset, this pin is pulled down internally and is defined as PENROM disabled, and the power-on values are shown at CR24 bit 1 (ENROM). The PCB layout should reserve space for a 1-kΩ resistor to pull down this pin to ensure the disabling of SPI interface, and a 1-kΩ resistor is recommended to pull the pin up if wish to enable ROM. GP64 I/O8 General-purpose I/O port 6 bit 4. RTSA# O8 UART A Request To Send. An active-low signal informs the modem or data set that the controller is ready to send data. INt During power-on reset, this pin is pulled down internally and is defined as HEFRAS, which provides the power-on value for CR26 bit 6 (HEFRAS). The PCB layout should reserve space for a 1-kΩ resistor to pull down this pin so as to ensure the selection of I/O port’s configuration address to 2EH, and a 1-kΩ resistor is recommended to pull it up if 4EH is selected as I/O port′s configuration address. PENROM HEFRAS 52 51 GP65 DSRA# I/O8 50 GP66 CTSA# INt I/OD12t 49 INt General-purpose I/O port 6 bit 3. General-purpose I/O port 6 bit 5. Data Set Ready. An active-low signal indicates the modem or data set is ready to establish a communication link and transfer data to the UART. General-purpose I/O port 6 bit 6. Clear To Send. This is the modem-control input. The function of these pins can be tested by reading bit 4 of the handshake status register. -13- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT SYMBOL PIN GP67 RIB# I/O I/OD12t 85 INt GP40* I/OD12t DCDB# INt 84 GP41*** I/OD12t FAN_SET2 SOUTB INt 83 O12 General-purpose I/O port 6 bit 7. Ring Indicator. An active-low signal indicates that a ring signal is being received from the modem or the data set. General-purpose I/O port 4 bit 0. Data Carrier Detection. An active-low signal indicates the modem or data set has detected a data carrier. General-purpose I/O port 4 bit 1. Determines the initial FAN speed. Power-on configuration for 2 fan speeds, 50% or 100%. When VCC is on, this pin needs a pulled-up or a pulled-down resistor to decide whether the fan speed is 50% or 100%. Only CPUFANOUT1 is supported. UART B Serial Output. This pin is used to transmit serial data out to the communication link. IR Transmitter output. IRTX GP42* I/O12t SINB IRRX DESCRIPTION 82 INt I/OD12t DTRB# O12 GP44* I/OD12t RTSB# O12 80 GP45*** I/OD12t DSRB# INt 79 GP46* I/OD12t CTSB# INt 78 GP47*** Serial Input. This pin is used to receive serial data through the communication link. IR Receiver input. GP43*** 81 General-purpose I/O port 4 bit 2. Note: This pin changes to input state during internal PWROK from low to high, then goes back to the previous setting state. (Please see the AP Note 1 of W83627DHG-P) I/OD12t General-purpose I/O port 4 bit 3. UART B Data Terminal Ready. An active-low signal informs the modem or data set that the controller is ready to communicate. General-purpose I/O port 4 bit 4. UART B Request To Send. An active-low signal informs the modem or data set that the controller is ready to send data. General-purpose I/O port 4 bit 5. Data Set Ready. An active-low signal indicates the modem or data set is ready to establish a communication link and transfer data to the UART. General-purpose I/O port 4 bit 6. Clear To Send. This is the modem-control input. The function of these pins can be tested by reading bit 4 of the handshake status register. General-purpose I/O port 4 bit 7. Note: Regarding the * sign, please see 5.12.7 GPIO-4 with WDTO# / SUSLED Multi-function for detailed information. 5.5 KBC Interface SYMBOL PIN I/O DESCRIPTION GA20M 59 O12 Gate A20 output. This pin is high after system reset. (KBC P21) -14- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT SYMBOL PIN I/O DESCRIPTION KBRST# 60 O12 Keyboard reset. This pin is high after system reset. (KBC P20) KCLK GP27 KDAT GP26 MCLK GP25 MDAT GP24 5.6 62 63 65 66 I/OD16ts Keyboard Clock. I/OD16t General-purpose I/O port 2 bit 7. I/OD16ts Keyboard Data. I/OD16t General-purpose I/O port 2 bit 6. I/OD16ts PS2 Mouse Clock. I/OD16t General-purpose I/O port 2 bit 5. I/OD16ts PS2 Mouse Data. I/OD16t General-purpose I/O port 2 bit 4. Serial Peripheral Interface The SPI employs a master-slave model and typically has three signal lines: serial data input line (SI), serial data output line (SO), and serial clock line (SCK). Different slaves are addressed on the bus by chip select signals from the master. The data bits are first shifted in/out the most significant bit (MSB). The data are often shifted simultaneously out from the output pin and into the input pin. Among the parameters, only the communication lines and the clock edge are defined by the SPI. The others differ from device to device. SPI Operation To initiate the data transfer between the W83627DHG-P and a slave device, SCE# must go low. This synchronizes the slave device with the W83627DHG-P. Data can now be transferred between the W83627DHG-P and the slave device in one of two modes: the data is sampled either on the rising or the falling edge of the clock. In a slave device, a logic low is received on the SCE# line and the clock input is at the SCK pin, which synchronizes the slave with the W83627DHG-P. Data is then received serially at the SI pin. During a write cycle, data is shifted out to the SO pin on clocks from the W83627DHG-P. SYMBOL SCE# GP22 SCK GP23 PIN 19 2 SO I/O O12 I/OD12t O12 I/OD12t SI AUXFANIN1 58 Serial flash ROM interface chip selection. General-purpose I/O port 2 bit 2. Clock output for serial flash. General-purpose I/O port 2 bit 3. O8 Transfer commands, addresses or data to serial flash. This pin is connected to SI of serial flash. OD8 Beep function for hardware monitor. This pin is low after system reset. INts Receive data from serial flash. This pin is connected to SO of serial flash. 118 BEEP DESCRIPTION I/O12ts 0 to +3 V amplitude fan tachometer input. -15- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 5.7 Hardware Monitor Interface SYMBOL PIN BEEP I/O DESCRIPTION OD8 Beep function for hardware monitor. This pin is low after system reset. O8 Transfer commands, address or data to serial flash. This pin is connected to SI of serial flash. 118 SO CASEOPEN# 76 INt CASE OPEN detection. An active-low input from an external device when the case is open. This signal can be latched if pin VBAT is connected to the battery, even if the W83627DHG-P is turned off. Pulling up a 2-MΩ resistor to VBAT is recommended if not in use. VIN3 96 AIN Analog Inputs for voltage measurement (Range: 0 to 2.048 V) VIN2 97 AIN Analog Inputs for voltage measurement (Range: 0 to 2.048 V) VIN1 98 AIN Analog Inputs for voltage measurement (Range: 0 to 2.048 V) VIN0 99 AIN Analog Inputs for voltage measurement (Range: 0 to 2.048 V) CPUVCORE 100 AIN Analog Inputs for voltage measurement (Range: 0 to 2.048 V) VREF 101 AOUT AUXTIN 102 AIN The input of temperature sensor 3. It is used for temperature sensing. CPUTIN 103 AIN The input of temperature sensor 2. It is used for CPU temperature sensing. SYSTIN 104 AIN The input of temperature sensor 1. It is used for system temperature sensing. OD12 The output of over temperature Shutdown. This pin indicates the temperature is over the temperature limit. (Default after LRESET#) OD12 System Management Interrupt channel output. I/O12 VID input detection, also with output control. I/O12ts 0 to +3 V amplitude fan tachometer input. OVT# 5 SMI# VID7 VID6 VID5 VID4 VID3 VID2 VID1 VID0 121 122 123 124 125 126 127 128 AUXFANIN1 SI 58 INts Reference Voltage (2.048 V). Receive data from serial flash. This pin is connected to SO of serial flash.. -16- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT SYMBOL PIN AUXFANIN0 111 CPUFANIN0 112 SYSFANIN 113 CPUFANIN1 GP21 119 AUXFANOUT 7 CPUFANOUT0 115 SYSFANOUT 116 CPUFANOUT1 120 GP20 FAN_SET 117 PLED 5.8 I/O DESCRIPTION I/O12ts 0 to +3 V amplitude fan tachometer input. I/O12ts 0 to +3 V amplitude fan tachometer input. (Default) I/OD12t General-purpose I/O port 2 bit 1. AOUT/ OD12/ O12 DC/PWM fan output control. CPUFANOUT0 and AUXFANOUT are default PWM mode, CPUFANOUT1 and SYSFANOUT are default DC mode. AOUT/ O12/ OD12 DC/PWM fan output control. (Default) CPUFANOUT0 and AUXFANOUT are default PWM mode, CPUFANOUT1 and SYSFANOUT are default DC mode. I/OD12t General-purpose I/O port 2 bit 0. INtd Determines the initial FAN speed. Power on configuration for 2 fan speeds, 50% or 100%. During power-on reset, this pin is pulled down internally and the fan speed is 50%. Only CPUFANOUT0 is supported. O12 Power LED output. Drive high 3.3 V after strapping. PECI Interface SYMBOL PIN I/O PECI_REQ# 110 OD12 INTEL® CPU PECI interface. PECI 108 I/OV3 INTEL® CPU PECI interface. Connect to CPU. Vtt 107 Power PECISB 106 I/OV3 5.9 DESCRIPTION INTEL® CPU Vtt Power. This pin is connected to GND if the PECI function is not in use. INTEL® CPU PECI interface. Connect to ICH8. SST Interface SYMBOL PIN I/O SST 114 I/OV4 DESCRIPTION Simple Serial Transport (SST) Interface. -17- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 5.10 Advanced Configuration and Power Interface The Advanced Configuration and Power Interface (ACPI) is an interface that allows OS-directed Power Management (OSPM). The ACPI replaces the APM (Advanced Power Management), MPS (Multiprocessor Specification), and PnP BIOS Specification. In addition to power management, the ACPI supports the functions of thermal management, state management, and speed control, as well as the global system states and different device power states. Two of the primary states that the W83627DHG-P supports are the S0 (working) and S3 (suspend to RAM) states. S0 is a full-power state, in which the computer is actively used. S3 is a sleeping state, in which the processor is powered down, but the memory, where the last procedural state is stored, is still active. By employing the ACPI, the system conserves more energy through transiting unused devices into lower power states, including placing the entire system in a low-power state when possible. SYMBOL PSIN# PIN 68 I/O INtu GP56 I/OD12t PSOUT# OD12 67 GP57 RSMRST# GP51 SUSB# GP52 PSON# GP53 PWROK GP54 I/OD12t 75 73 72 71 OD12 I/OD12t INt I/OD12t OD12 I/OD12t OD12 I/OD12t DESCRIPTION Panel Switch Input. This pin is active-low with an internal pulledup resistor. General-purpose I/O port 5 bit 6. Panel Switch Output. This signal is used to wake-up the system from S3/S5 state. General-purpose I/O port 5 bit 7. Resume reset signal output. General-purpose I/O port 5 bit 1. System S3 state input. General-purpose I/O port 5 bit 2. Power supply on-off output. General-purpose I/O port 5 bit 3. This pin generates the PWROK signal while 3VCC comes in. General-purpose I/O port 5 bit 4. RSTOUT0# 94 OD12 PCI Reset Buffer 0. RSTOUT1# 93 O12 PCI Reset Buffer 1. O12 PCI Reset Buffer 2. (Default) RSTOUT2# GP32 90 I/OD12t General-purpose I/O port 3 bit 2. SCL INts Serial Bus clock. RSTOUT3# O12 PCI Reset Buffer 3. (Default) GP33 89 SDA RSTOUT4# GP34 88 I/OD12t General-purpose I/O port 3 bit 3. I/OD12ts Serial bus bi-directional Data. O12 PCI Reset Buffer 4. (Default) I/OD12t General-purpose I/O port 3 bit 4. -18- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 5.11 SMBus Interface SYMBOL PIN I/O RSTOUT2# O12 90 GP32 I/OD12t DESCRIPTION PCI Reset Buffer 2. (Default) General-purpose I/O port 3 bit 2. SCL INts Serial Bus clock. RSTOUT3# O12 PCI Reset Buffer 3. (Default) 89 GP33 SDA I/OD12t General-purpose I/O port 3 bit 3. I/OD12ts Serial bus bi-directional Data. 5.12 General Purpose I/O Port 5.12.1 GPIO Power Source SYMBOL POWER SOURCE GPIO port 2 (Bit0-3) 3VCC GPIO port 2 (Bit4-7) 3VSB GPIO port 3 3VSB GPIO port 4 3VSB GPIO port 5 3VSB GPIO port 6 3VCC 5.12.2 GPIO-2 Interface SYMBOL PIN GP20 CPUFANOUT1 GP21 CPUFANIN1 GP22 SCE# GP23 SCK GP24 MDAT GP25 MCLK 120 119 19 2 66 65 I/O DESCRIPTION I/OD12t General-purpose I/O port 2 bit 0. AOUT/ OD12/ O12 DC/PWM fan output control. (Default) CPUFANOUT0 and AUXFANOUT are default PWM mode, CPUFANOUT1 and SYSFANOUT are default DC mode. I/OD12t General-purpose I/O port 2 bit 1. I/O12ts 0 to +3 V amplitude fan tachometer input. (Default) I/OD12t General-purpose I/O port 2 bit 2. O12 I/OD12t O12 Serial flash ROM interface chip selection. General-purpose I/O port 2 bit 3. Clock output for serial flash. I/OD16t General-purpose I/O port 2 bit 4. I/OD16ts PS2 Mouse Data. I/OD16t General-purpose I/O port 2 bit 5. I/OD16ts PS2 Mouse Clock. -19- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT SYMBOL GP26 KDAT GP27 KCLK PIN I/O 63 62 DESCRIPTION I/OD16t General-purpose I/O port 2 bit 6. I/OD16ts Keyboard Data. I/OD16t General-purpose I/O port 2 bit 7. I/OD16ts Keyboard Clock. 5.12.3 GPIO-3 Interface SYMBOL GP30 PWROK2 PIN 92 GP31 VSBGATE# I/OD12t OD12 I/OD12t 91 GP32 RSTOUT2# I/O O12 I/OD12t 90 DESCRIPTION General-purpose I/O port 3 bit 0. This pin generates the PWROK2 signal while 3VCC comes in. General-purpose I/O port 3 bit 1. Switch 3VSB power to memory when in S3 state. The default is disabled while the particular ACPI functions are enabled. The control bit is at Logical Device A, CR [E4h] bit 4. General-purpose I/O port 3 bit 2. O12 PCI Reset Buffer 2. (Default) SCL INts Serial Bus clock. GP33 I/OD12t RSTOUT3# 89 SDA GP34 RSTOUT4# 88 GP35 ATXPGD GP36 FTPRST# GP37 SUSC# O12 PCI Reset Buffer 3. (Default) I/OD12ts Serial bus bi-directional Data. I/OD12t General-purpose I/O port 3 bit 4. O12 I/OD12t 87 INt I/OD12t 69 64 General-purpose I/O port 3 bit 3. INt I/OD12t INt PCI Reset Buffer 4. (Default) General-purpose I/O port 3 bit 5. ATX power good input signal. It is connected to the PWROK signal from the power supply for PWROK/PWROK2 generation. The default is enabled. General-purpose I/O port 3 bit 6. Connect to the reset button. This pin has internal de-bounce circuit whose de-bounce time is at least 32 mS. General-purpose I/O port 3 bit 7. SLP_S5# input. -20- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 5.12.4 GPIO-4 Interface See 5.4 Serial Port & Infrared Port Interface 5.12.5 GPIO-5 Interface SYMBOL PIN GP50 EN_GTL 77 WDTO# GP51 RSMRST# GP52 SUSB# GP53 PSON# GP54 PWROK 75 73 72 71 GP55 EN_ACPI 70 SUSLED GP56 PSIN# General-purpose I/O port 5 bit 0. (Default after strapping) INcu During VSB power reset (RSMRST#), this pin is pulled high internally and is defined as VID transition voltage level (GTL or TTL), and the value is shown at CR2C bit 3. The PCB layout should reserve space for a 1-kΩ resistor to pull down this pin if TTL is the selected VID level. O12 Watchdog Timer output signal. I/OD12t OD12 I/OD12t INt I/OD12t OD12 I/OD12t General-purpose I/O port 5 bit 1. Resume reset signal output. General-purpose I/O port 5 bit 2. System S3 state input. General-purpose I/O port 5 bit 3. Power supply on-off output. General-purpose I/O port 5 bit 4. OD12 This pin generates the PWROK signal while 3VCC comes in. I/O12t General-purpose I/O port 5 bit 5. (Default) INcd During VSB power reset (RSMRST#), this pin is pulled down internally and is defined as EN_ACPI (enabling particular ACPI functions), which provides the value for CR2C bit 4 (EN_ACPI). The PCB layout should reserve space for a 1-kΩ resistor to pull down this pin to ensure successful disabling of particular ACPI functions, and a 1-kΩ resistor is recommended to pull the pin up if wish to enable particular ACPI functions. O12 Suspended LED output. INtu I/OD12t 67 DESCRIPTION I/O12t I/OD12t 68 GP57 PSOUT# I/O OD12 General-purpose I/O port 5 bit 6. Panel Switch Input. This pin is active-low with an internal pulled-up resistor. General-purpose I/O port 5 bit 7. Panel Switch Output. This signal is used to wake-up the system from S3/S5 state. -21- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 5.12.6 GPIO-6 Interface See 5.4 Serial Port & Infrared Port Interface 5.12.7 GPIO-4 with WDTO# / SUSLED Multi-function SYMBOL GPxx* WDTO# GPxx*** SUSLED PIN --- I/O DESCRIPTION I/OD12t This GPxx* can serve as GPIO or the Watchdog Timer output signals. OD12 I/OD12t --- This GPxx*** can serve as GPIO or Suspend-LED output signals. OD12 5.13 Particular ACPI Function pins SYMBOL SUSC# GP37 PIN 64 I/O INt I/OD12t DESCRIPTION SLP_S5# input. General-purpose I/O port 3 bit 7 INcd During VSB power reset (RSMRST#), this pin is pulled down internally and is defined as EN_ACPI (enabling particular ACPI functions), which provides the value for CR2C bit 4 (EN_ACPI). The PCB layout should reserve space for a 1-kΩ resistor to pull down this pin to ensure successful disabling of particular ACPI functions, and a 1-kΩ resistor is recommended to pull the pin up if wish to enable particular ACPI functions. GP55 I/O12t General-purpose I/O port 5 bit 5. SUSLED O12 Suspended LED output. VSBGATE# O12 Switch 3VSB power to memory when in S3 state. The default is disabled while the particular ACPI functions are enabled. The control bit is at Logical Device A, CR [E4h] bit 4. EN_ACPI 70 91 I/OD12t GP31 PWROK2 GP30 ATXPGD 92 87 OD12 I/OD12t INt GP35 I/OD12 FTPRST# INt 69 I/OD12 GP36 General-purpose I/O port 3 bit 1. This pin generates the PWROK2 signal while 3VCC comes in. General-purpose I/O port 3 bit 0. ATX power good input signal. It is connected to the PWROK signal from the power supply for PWROK/PWROK2 generation. The default is enabled. General-purpose I/O port 3 bit 5. Connect to the reset button. This pin has internal de-bounce circuit whose de-bounce time is at least 32 mS. General-purpose I/O port 3 bit 6. 5.14 POWER PINS SYMBOL PIN 3VSB 61 DESCRIPTION +3.3 V stand-by power supply for the digital circuits. -22- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT SYMBOL PIN DESCRIPTION VBAT 74 3VCC 12,28,48 AVCC 95 Analog +3.3 V power input. Internally supply power to all analog circuits. CPUD(AGND) 105 Analog ground. The ground reference for all analog input. Internally connected to all analog circuits. VSS 20,55 Vtt 107 +3 V on-board battery for the digital circuits. +3.3 V power supply for driving 3 V on host interface. Ground. INTEL® CPU Vtt power. -23- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 6. ACPI GLUE LOGIC SYMBOL PIN DESCRIPTION SUSC# 64 SLP_S5# input. FTPRST# 69 Connect to the reset button. This pin has internal de-bounce circuit whose de-bounce time is at least 32 mS. VSBGATE# 91 Switch 3VSB power to memory when in S3 state. PWROK 71 This pin generates the PWRGD signals while 3VCC is present. ATXPGD 87 ATX power good input signal. It is connected to the PWROK signal from the power supply for PWROK/PWRGD generation. The default is enabled. t1 RSMRST# 3VSB V1 V2 FTPRST# TL PWROK t3 TL 3VCC -24- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT VSBGATE# t5 t4 3VCC PSON# t7 t6 SUSB# t8 SUSC# S3 S0 t9 RSTOUTx# S0 t10 LRESET# 3VCC 3VCC V3 Internal PWROK t2 PWROK -25- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT ATXPGD (if enable) PWROK_2 / PWROK Internal PWROK 3VCC V4 PWROK2 PWROK TIMING PARAMETER MIN MAX UNIT t1 Valid 3VSB to RSMRST# inactive 100 200 mS t2 Valid 3VCC to PWROK/PWRGD active 300 500 mS t3 FTPRST# active to PWROK/PWRGD active 28 39 mS t4 SUSB# active to VSBGATE# active 0 80 nS t5 PSON# active to VSBGATE# inactive 90 142 mS t6 SUSB# inactive to PSON# active 0 80 nS t7 SUSB# active to PSON# inactive 28 39 mS t8 SUSB# minimal Low Time 40 - mS t9 LRESET# active to RSTOUTx# active 0 80 nS t10 LRESET# inactive to RSTOUTx# inactive 0 80 nS DC V1 PARAMETER 3VSB Valid Voltage V2 3VSB Ineffective Voltage V3 3VCC Valid Voltage V4 3VCC Ineffective Voltage MIN TYPICAL MAX UNIT - - 3.0 Volt 2.4 - - Volt - - 3.0 Volt 2.4 - - Volt Note: 1. The values above are the worst-case results of R&D simulation. 2. The length of TL level is based on the length of the low level of FTPRST# -26- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 7. CONFIGURATION REGISTER ACCESS PROTOCOL The W83627DHG-P uses Super I/O protocol to access configuration registers to set up different types of configurations. The W83627DHG-P has totally twelve Logical Devices (from Logical Device 0 to Logical Device C with the exception of Logical Device 4 for backward compatibility) corresponding to twelve individual functions: FDC (Logical Device 0), Parallel Port (Logical Device 1), UARTA (Logical Device 2), UARTB (Logical Device 3), Keyboard Controller (Logical Device 5), SPI (Serial Peripheral Interface, Logical Device 6), GPIO6 (Logical Device 7), WDTO# & PLED (Logical Device 8), GPIO2, 3, 4, 5 (Logical Device 9), ACPI (Logical Device A), Hardware Monitor (Logical Device B), and PECI & SST (Logical Device C). Each Logical Device has its own configuration registers (above CR30). The host can access those registers by writing an appropriate Logical Device Number into the Logical Device select register at CR7. Please note that GPIO1 is not defined in the W83627DHG-P. Logical Device No. Logical Device Control #0 Logical Device Configuration One Per Logical Device #1 #2 #C Figure 7-1 Structure of the Configuration Register LOGICAL DEVICE NUMBER FUNCTION I/O BASE ADDRESS 0 FDC 100h ~ FF8h 1 Parallel Port 100h ~ FF8h 2 UART A 100h ~ FF8h 3 UART B 100h ~ FF8h 4 Reserved 5 Keyboard Controller 100h ~ FFFh 6 Serial Peripheral Interface 100h ~ FF8h 7 GPIO 6 100h ~ FFFh 8 WDTO# & PLED Reserved 9 GPIO 2, 3, 4, 5 Reserved A ACPI Reserved -27- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT LOGICAL DEVICE NUMBER FUNCTION I/O BASE ADDRESS B Hardware Monitor 100h ~ FFEh C PECI & SST Reserved Figure 7-2 Devices of I/O Base Address 7.1 Configuration Sequence Power-on Reset Any other I/O transition cycle Wait for key string I/O Write to 2Eh N Is the data “87h”? Y Any other I/O transition cycle Check Pass key I/O Write to 2Eh N Is the data “87h”? Y Extended Function Mode Figure 7-3 Configuration Register To program the W83627DHG-P configuration registers, the following configuration procedures must be followed in sequence: (1). Enter the Extended Function Mode. (2). Configure the configuration registers. (3). Exit the Extended Function Mode. -28- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 7.1.1 Enter the Extended Function Mode To place the chip into the Extended Function Mode, two successive writes of 0x87 must be applied to Extended Function Enable Registers (EFERs, i.e. 2Eh or 4Eh). 7.1.2 Configure the Configuration Registers The chip selects the Logical Device and activates the desired Logical Devices through Extended Function Index Register (EFIR) and Extended Function Data Register (EFDR). The EFIR is located at the same address as the EFER, and the EFDR is located at address (EFIR+1). First, write the Logical Device Number (i.e. 0x07) to the EFIR and then write the number of the desired Logical Device to the EFDR. If accessing the Chip (Global) Control Registers, this step is not required. Secondly, write the address of the desired configuration register within the Logical Device to the EFIR and then write (or read) the desired configuration register through the EFDR. 7.1.3 Exit the Extended Function Mode To exit the Extended Function Mode, writing 0xAA to the EFER is required. Once the chip exits the Extended Function Mode, it is in the normal running mode and is ready to enter the configuration mode. 7.1.4 Software Programming Example The following example is written in Intel 8086 assembly language. It assumes that the EFER is located at 2Eh, so the EFIR is located at 2Eh and the EFDR is located at 2Fh. If the HEFRAS (CR26 bit 6) is set, 2Eh can be directly replaced by 4Eh and 2Fh replaced by 4Fh. ;----------------------------------------------------; Enter the Extended Function Mode ;----------------------------------------------------MOV DX, 2EH MOV AL, 87H OUT DX, AL OUT DX, AL ;----------------------------------------------------------------------------; Configure Logical Device 1, Configuration Register CRF0 ;----------------------------------------------------------------------------MOV DX, 2EH MOV AL, 07H OUT DX, AL ; point to Logical Device Number Reg. MOV DX, 2FH MOV AL, 01H OUT DX, AL ; select Logical Device 1 ; MOV DX, 2EH -29- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT MOV AL, F0H OUT DX, AL ; select CRF0 MOV DX, 2FH MOV AL, 3CH OUT DX, AL ; update CRF0 with value 3CH ;---------------------------------------------------------------------------; Exit the Extended Function Mode ;---------------------------------------------------------------------------MOV DX, 2EH MOV AL, AAH OUT DX, AL Figure 7-4 Chip (Global) Control Registers INDEX R/W DEFAULT VALUE DESCRIPTION 02h Write Only 07h R/W 00h Logical Device 20h Read Only B0h Chip ID, MSB 21h Read Only 7xh Chip ID, LSB 22h R/W FFh Device Power Down 23h R/W 00h Immediate Power Down 24h R/W 0100_0ss0b Global Option 25h R/W 00h Interface Tri-state Enable 26h R/W 0s000000b Global Option Software Reset 27h Reserved 28h R/W 50h Global Option 29h R/W 00h Multi-function Pin Selection 2Ah R/W 00h SPI Configuration 2Bh Reserved 2Ch R/W E2h Multi-function Pin Selection 2Dh R/W 21h Multi-function Pin Selection 2Eh R/W 00h Reserved 2Fh R/W 00h Reserved S: Strapping; x: chip version. -30- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 8. HARDWARE MONITOR 8.1 General Description The W83627DHG-P monitors several critical parameters in PC hardware, including power supply voltages, fan speeds, and temperatures, all of which are very important for a high-end computer system to work stably and properly. The W83627DHG-P can simultaneously monitor all of the following inputs: • Nine analog voltage inputs (four intrinsic monitor VBAT, 3VSB, 3VCC and AVCC power; five externally monitored power) • Five fan tachometer inputs • Three remote temperatures, by thermistor or from the CPU thermal-diode output (voltage or Current Mode) • One case-open detection signal. These inputs are converted to digital values using a built-in, eight-bit analog-to-digital converter (ADC). In response to these inputs, the W83627DHG-P can generate the following outputs: • Four PWM (pulse width modulation) or DC fan outputs for the fan speed control • Beep tone output for warnings • SMI# • OVT# signals for system protection events The W83627DHG-P provides hardware access to all monitored parameters through the LPC or I2C interface and software access through application software, such as Nuvoton’s Hardware DoctorTM, or BIOS. In addition, the W83627DHG-P can generate pop-up warnings or beep tones when a parameter goes outside of a user-specified range. The rest of this section introduces the various features of the W83627DHG-P hardware-monitor capability. These features are divided into the following sections: • • • • • • • Access Interfaces Analog Inputs Fan Speed Measurement and Control Smart Fan Control SMI# interrupt mode OVT# interrupt mode Registers and Value RAM -31- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 8.2 Access Interfaces The W83627DHG-P provides two interfaces, LPC and I2C, for the microprocessor to read or write the internal registers of the hardware monitor. 8.2.1 LPC Interface This interface uses the LPC bus to access the index and data ports. These two ports are located at the 16-bit port specified in CR60 and CR61, plus 5h and 6h, respectively. If the 16-bit port value is 290h, so the default index and data port addresses are 295h and 296h, respectively. The structure of the internal registers is shown in the following figure. -32- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT Smart Fan Configuration Registers 00h-1Fh Monitor Value Registers 20h~3Fh BANK 0 FANOUT Critical Temperature 6Bh~6Eh Configuration Register 40h Interrupt Status Registers 41h, 42h BANK 1 CPUTIN Temperature Control/Status Registers 50h~56h SMI# Mask Registers 43h, 44h, 46h Fan Divisor Register I 47h LPC Bus Serial Bus Address 48h Port 5h BANK 2 AUXTIN Temperature Control/Status Registers 50h~56h BANK 4 Interrupt Status & SMI# Mask Registers 50h~51h FANOUTs Source Select Register Index Register 49h, 4Ah BANK 4 Fan Divisor Register II Beep Control Registers 4Bh 53h SMI#/OVT# Control Register 4Ch Fan IN /OUT Control Register 54h~56h 4Dh Bank Select for 50h~5Fh Registers. 4Eh Port 6h Data Register BANK 4 Temperature Offset Registers Winbond Vendor ID BANK 4 Read Time Status Registers 59h~5Bh 4Fh BANK 0 BEEP Control Registers 56h~57h BANK 0 Chip ID Register BANK 5 Monitor Value Registers 50h~5Ch 58h BANK 0 Temperature Sensor Type Configuration & Fan Divisor Registers 59h,5Dh BANK 0 Critical Temperature and Current Mode enable 5Eh BANK 0 Smart Fan Configuration Registers 60h~6Ah Figure 8-1 LPC Bus' Reads from / Writes to Internal Registers -33- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 8.2.2 I2C interface This interface uses the I2C Serial Bus to access the internal registers. The W83627DHG-P has a programmable serial-bus address that is controlled by index 48h. The two timing diagrams below illustrate how to use the I2C interface to write to an internal register and how to read the value in an internal register, respectively. (a) Serial bus write to internal address register followed by the data byte 0 7 8 0 7 8 SCL SDA 0 1 Start By Master 0 1 1 0 1 R/W D7 Ack by 627DHG Frame 1 Serial Bus Address Byte D6 D5 D4 D3 D2 D1 D0 Ack by 627DHG Frame 2 Internal Index Register Byte 0 7 8 SCL (Continued) SDA (Continued) D7 D6 D5 D4 D3 D2 D1 D0 Ack Ack byby 784R 627DHG Stop by Master Frame 3 Data Byte Figure 8-2 Serial Bus Write to Internal Address Register Followed by the Data Byte (b) Serial bus read from a register 0 7 8 0 7 8 SCL 0 SDA 1 0 Start By Master 1 1 0 1 R/W D7 Ack by 627DHG Frame 1 Serial Bus Address Byte D6 D5 D4 D3 D2 D1 D0 Ack by 627DHG Frame 2 Internal Index Register Byte 0 0 0 Repeat start by Master 7 1 0 1 1 0 1 8 0 R/W D7 Ack by 627DHG Frame 3 Serial Bus Address Byte 7 D6 D5 D4 D3 D2 D1 8 D0 Ack by Master Frame 4 Data Byte Stop by Master 0 Figure 8-3 Serial Bus Read from Internal Address Register -34- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 8.3 Analog Inputs The maximum input voltage on analog pins is 2.048 V because the 8-bit ADC has an 8-mV LSB. Usually, the voltage ports of CPU Vcore (pin 100), battery (pin 74), 3VSB (pin 61), 3VCC (pin 12), and AVCC (pin 95) can be directly connected to their respective analog pins, as illustrated in the figure below. Pin 95 AVCC Power Inputs Pin 74 VBAT Pin 61 3VSB Pin 12 3VCC Pin 100 CPUVCORE R1 VIN0 V0 Pin 99 R2 Positive Voltage Input Pin 97 VIN2 Pin 96 VIN3 R3 Negative Voltage Input VIN1 V1 8-bit ADC with 8mV LSB Pin 98 R4 RTHM 10K@25 C, beta=3435K R 10K, 1% VREF AUXTIN CPUTIN R 15K, 1% SYSTIN Pin 101 Pin 102 Pin 103 Pin 104 CPUD+ CAP,2200p CPUD-(AGND) Pin 105 CPUD(AGND) Figure 8-4 Analog Inputs and Application Circuit of the W83627DHG-P As illustrated in the figure above, other connections may require some external circuits. The rest of this section provides more information about voltages outside the range of the 8-bit ADC, CPU Vcore voltage detection, and temperature sensing 8.3.1 Voltages Over 2.048 V or Less Than 0 V Input voltages greater than 2.048 V should be reduced by external resistors to keep the input voltages in the proper range. For example, input voltage V0 (+12 V) should be reduced before it is connected to VIN0 according to the following equation: VIN 0 = V 0 × R2 R1 + R2 R1 and R2 can be set to 56 KΩ and 10 KΩ, respectively, to reduce V0 from +12 V to less than 2.048 V. -35- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT The W83627DHG-P uses the same approach. Pins 12 and 95 provide two functions. One, these pins are connected to VCC at +3.3 V to supply internal (digital / analog) power to the W83627DHG-P. Two, these pins monitor VCC. The W83627DHG-P has two internal, 34-KΩ serial resistors that reduce the ADC-input voltage to 1.65 V. Vin = VCC × 34 KΩ ≅ 1.65V , where VCC is set to 3.3V 34 KΩ + 34 KΩ Pin 61 is implemented likewise to monitor its +3.3 V stand-by power supply. Negative voltages are handled similarly, though the equation looks a little more complicated. For example, negative voltage V1 (-12V) can be reduced according to the following equation: VIN1 = (V 1 − 2.048) × R4 + 2.048, whereV 1 = −12 R3 + R 4 R3 and R4 can be set to 232 KΩ and 10 KΩ, respectively, to reduce negative input voltage V1 from – 12 V to less than 2.048 V. Both of these solutions are illustrated in the figure above. 8.3.2 Voltage Detection The data format for voltage detection is an eight-bit value, and each unit represents an interval of 8 mV. Detected Voltage = Reading * 0.008 V If the source voltage was reduced, the detected voltage value may have to be scaled up accordingly. 8.3.3 Temperature Sensing The data format for sensor SYSTIN is 8-bit, two's-complement, and the data format for sensors CPUTIN and AUXTIN is 9-bit, two's-complement. This is illustrated in the table below. Table 8-1 Temperature Data Format 8-BIT DIGITAL OUTPUT TEMPERATURE 8-BIT BINARY 8-BIT HEX 9-BIT DIGITAL OUTPUT 9-BIT BINARY 9-BIT HEX +125°C 0111,1101 7Dh 0,1111,1010 0FAh +25°C 0001,1001 19h 0,0011,0010 032h +1°C 0000,0001 01h 0,0000,0010 002h +0.5°C - - 0,0000,0001 001h +0°C 0000,0000 00h 0,0000,0000 000h -0.5°C - - 1,1111,1111 1FFh -1°C 1111,1111 FFh 1,1111,1110 1FFh -25°C 1110,0111 E7h 1,1100,1110 1CEh -55°C 1100,1001 C9h 1,1001,0010 192h Eight-bit temperature data is read from Index [27h]. For nine-bit temperature data, the 8 MSB are read from Bank1 / Bank2 Index [50h], and the LSB is read from Bank1 / Bank2 Index [51h], bit 7. There are two sources of temperature data: external thermistors or thermal diodes. -36- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 8.3.3.1. Monitor Temperature From Thermistor External thermistors should have a β value of 3435K and a resistance of 10 KΩ at 25°C. As illustrated in the schematic below, the thermistor is connected in series with a 10-KΩ resistor and then connects to VREF (pin 101). R THM 10K@25 C, beta=3435K R 10K, 1% VREF Pin 101 AUXTIN Pin 102 CPUTIN Pin 103 SYSTIN Pin 104 W83627DHG-P Figure 8-5 Monitoring Temperature from Thermistor 8.3.3.2. Monitor Temperature from Thermal Diode (Voltage Mode) The thermal diode D- pin is connected to CPUD- (pin 105), and the D+ pin is connected to the temperature sensor pin in the W83627DHG-P. A 15-KΩ resistor is connected to VREF to supply the bias current for the diode, and the 2200-pF, bypass capacitor is added to filter high-frequency noise. VREF R=15K,1% W83627DHG-P D+ Therminal Diode C=2200pF D- (SYSTIN) CPUTIN (AUXTIN) CPUD-(AGND) AGND Figure 8-6 Monitoring Temperature from Thermal Diode (Voltage Mode) -37- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 8.3.3.3. Monitor Temperature from Thermal Diode (Current Mode) The W83627DHG-P can also sense the diode temperature through Current Mode and the circuit is shown in the following figure. W83627DHG-P (SYSTIN) CPUTIN (AUXTIN) D+ Thermal Diode C=2200pF D- CPUD-(AGND) AGND Figure 8-7 Monitoring Temperature from Thermal Diode (Current Mode) The pin of processor D- is connected to CPUD- (pin 105) and the pin D+ is connected to temperature sensor pin in the W83627DHG-P. A bypass capacitor C=2200pF should be added to filter the high frequency noise. 8.4 SST Command Summary The W83627DHG-P is equipped with a built-in voltage and temperature sensor which uses the Simple Serial Transport (SST) interface. The sensor provides a means for an analog signal to travel over a digital bus enabling remote voltage and temperature sensing in areas previously not monitored in the PC. SST is a self-clocked, one-wire bus for data transfer. The bus requires no additional control lines. In addition, SST also includes variable data transfer rate established with every message. Therefore, it is comparatively flexible. The W83627DHG-P has a programmable SST address defined at Logical Device C CR [F1h]. The default address is 0x48h which is within the range of 0x48h-0x4ah defined in the SST specification. 8.4.1 Command Summary The W83627DHG-P supports SST commands as shown in the following table: Table 8-2 SST Command Summary COMMAND DESCRIPTION GetIntTemp() Returns the 2-byte temperature data values for pin SYSTIN (Pin 104) GetExtTemp() Returns the 2-byte temperature data values for pin CPUTIN (Pin 103) GetAllTemps() Returns the 4-byte temperature data values for both SYSTIN and CPUTIN GetVolt12V() Returns the 2-byte voltage data values for pin VIN0 (Pin 99). This pin should be connected to +12V power through scaling resistors Refer to 8.4.2.2 Voltage Data Format. GetVolt5V() Returns the 2-byte voltage data values for pin VIN1 (Pin 98). This pin should be connected to +5V power through scaling resistors Refer to -38- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT COMMAND DESCRIPTION 8.4.2.2 Voltage Data Format. GetVolt3p3V() Returns the 2-byte voltage data values for pin 3VCC (Pin 12, 28, 48).This pin should be connected to +3.3V power directly Refer to 8.4.2.2 Voltage Data Format. GetVolt2p5V() Returns the 2-byte voltage data values for pin VIN2 (Pin 97). This pin should be connected to +2.5V power through scaling resistors. Refer to 8.4.2.2 Voltage Data Format. GetVoltVccp() Returns the 2-byte voltage data values of CPUVCORE (Pin 100). This pin should be connected to CPU power supply directly. The CPU power supply voltage must not be higher than 2.048 volt GetAllVoltages() Returns a 10-byte voltage data value containing all the above listed five (5) voltages 8.4.2 Combination Sensor Data Format 8.4.2.1. Temperature Data Format The W83627DHG-P temperature data format of both CPUTIN and SYSTIN is 16-bit two’s-complement binary value. It represents multiple of 1/64°C in the temperature reading. Table 1 shows some typical temperature values in 16-bit two’s complement format. Table 8-3 Typical Temperature Values TEMPERATURE 16-BIT DIGITAL OUTPUT (TWO’S COMPLEMENT) 16-BIT BINARY 16-BIT HEX +80°C 0001 0100 0000 0000 1400h +79.5°C 0001 0011 1110 0000 13E0h +1°C 0000 0000 0100 0000 0010h +0°C 0000 0000 0000 0000 0000h -1°C 1111 1111 1100 0000 FFC0h -5°C 1111 1110 1100 0000 FEC0h 8.4.2.2. Voltage Data Format The W83627DHG-P can return five (5) voltage values through the SST interface. The voltage data format is 16-bit two’s-complement binary. The relation between the 2-byte data and the monitored voltage is listed below: 1) CPUVCORE (pin 100) = Decimal[2-byte data by GetVoltVccp() ] / 1024 volts -39- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 2) 3VCC (pin 12) = Decimal[2-byte data by GetVolt3p3V()] / 1024 volts 3) “+12V” = Decimal[2-byte data by GetVolt12V()] / 1024 / ((R1+R2) / R2) volts VIN0 (pin 99) is connected as shown below:. R2 +12V R1 150K 1% 10K 1% VIN0 4) “+5VCC” = Decimal[2-byte data by GetVolt5V()] / 1024 / ((R3+R4) / R4) volts VIN1 (pin 98) is connected as shown below: R3 5VCC VIN1 30K 1% R4 10K 1% 5) “+2.5V” = Decimal[2-byte data by GetVolt2p5V()] / 1024 / ((R5+R6) / R6) volts VIN2 (pin 97) is connected as shown below: R5 2.5V VIN2 10K 1% R6 10K 1% 8.5 PECI PECI (Platform Environment Control Interface) is a new digital interface to read the CPU temperature of Intel® CPUs. With a bandwidth ranging from 2 Kbps to 2 Mbps, PECI uses a single wire for selfclocking and data transfer. By interfacing to the Digital Thermal Sensor (DTS) in the Intel® CPU, PECI reports a negative temperature (in counts) relative to the processor’s temperature at which the thermal control circuit (TCC) is activated. At the TCC Activation temperature, the Intel CPU will operate at reduced performance to prevent the device from thermal damage. PECI is one of the temperature sensing methods that the W83627DHG-P supports. The W83627DHG-P contains a PECI master and reads the CPU PECI temperature. The CPU is a PECI client. The PECI temperature values returning from the CPU are in “counts” which are approximately linear in relation to changes in temperature in degrees centigrade. However, this linearity is approximate and cannot be guaranteed over the entire range of PECI temperatures. For further information, refer to the PECI specification. All references to “temperature” in this section are in “counts” instead of “°C”. Figure 8-8 shows a typical fan speed (PWM duty cycle) and PECI temperature relationship. -40- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT Fan Speed (PWM Duty Cycle) Tcontrol TCC Activation Duty1 Duty2 -20 -10 0 PECI Temperature (counts) Figure 8-8 PECI Temperature In this illustration, when PECI temperature is -20, the PWM duty cycle for fan control is at Duty2. When CPU is getting hotter and the PECI temperature is -10, the PWM duty cycle is at Duty1. At TControl PECI temperature, the recommendation from Intel is to operate the CPU fan at full speed. Therefore Duty1 is 100% if this recommendation is followed. The value of TControl can be obtained by reading the related Machine Specific Register (MSR) in the Intel CPU. The TControl MSR address is usually in the BIOS Writer’s guide for the CPU family in question. Refer to the relevant CPU documentation from Intel for more information. In this example, TControl is -10. When the PECI temperature is below -20, the duty cycle is fixed at Duty2 to maintain a minimum (and constant) RPM for the CPU fan. W83627DHG-P’s fan control circuit can only accept positive real-time temperature inputs and limits setting (in Smart Fan ™ mode). The device provides offset registers to ‘shift’ the negative PECI readings to positive values otherwise the fan control circuit will not function properly. The offset registers are the TBase registers located at Logical Device C, CR [E1h] ~ CR [E4h]. These registers should be programmed with (positive) values so that the resultant value (Tbase + PECI) is always positive. The unit of the TBase register contents is “count” to match that of PECI values. The resultant value (TBase + PECI) should not be interpreted as the “temperature” (whether in count or °C) of the PECI client (CPU). Figure 8-9 shows the temperature/fan speed relationship after Tbase offsets are applied (based on Figure 8-8). This view is from the perspective of the W83627DHG-P fan control circuit. -41- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT Fan Speed (PWM Duty Cycle) Tbase = 100 Tcontrol TCC Activation Duty1 85 = (-15 + 100) (PECI = -15) Duty2 80 = (-20 + 100) (PECI = -20) 90 = (-10 + 100) (PECI = -10) (PECI = 0) Temperature (as seen by the W83627DHG-P fan control circuit) Figure 8-9 Temperature and Fan Speed Relation after Tbase Offsets Assuming TBase is set to 100 and the PECI temperature is -15 , the real-time temperature value to the fan control circuit will be 85 (-15 + 100). The value of 55 (hex) will appear in the relevant real-time temperature register. While using Smart Fan control function of W83627DHG-P, BIOS/software must include Tbase in determining the thresholds (limits). In this example, assuming TControl is -10 and Tbase is set to 100 (1) , the threshold temperature value corresponding to the “100% fan duty cycle” event is 90 (-10+100). The value of 5A (hex) should be written to the relevant threshold register. (1) TControl is typically -10 to -20 for PECI-enabled CPUs. Base on that, a value of 85 ~100 for Tbase could be set for proper operation of the fan control circuit. This recommendation is applicable for most designs. In general, the concept presented in this section could be used to determine the optimum value of TControl to match the specific application. -42- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT W83627DHG-P CPU PECISB PECI PECI PECI Host (Programmable Pass-through) Fan Control LPC ICH8 Fan Control PECI Host Figure 8-10 Block Diagram for PECI 1.0 The W83627DHG-P provides a PECISB pin that can be connected to a PECI host (e.g. chipset), so the W83627DHG-P becomes a bridge between that PECI host and the PECI client (e.g. CPU with PECI function). The bridge can pass the CPU PECI signals by programming Configure Register at Logical Device C, CR [E5h] Bit 0. An illustration is provided below (ICH8 is the alternative PECI host). -43- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 8.6 Fan Speed Measurement and Control This section is divided into two parts, one to measure the speed and one to control the speed. 8.6.1 Fan Speed Measurement The W83627DHG-P can measure fan speed for fans equipped with tachometer outputs. The tachometer signals should be set to TTL-level, and the maximum input voltage cannot exceed +3.3 V. If the tachometer signal exceeds +3.3 V, an external trimming circuit should be added to reduce the voltage accordingly. The fan speed counter is read from Bank0 Index 28h, 29h, 2Ah, and 3Fh and Bank5 Index 53h. The fan speed can then be evaluated by the following equation: RPM = 1.35 × 10 6 Count × Divisor The default divisor is 2 and is specified at Bank0 Index 47h, bits 7 ~ 4; Index 4Bh, bits 7 ~ 6; Index 4Ch, bit 7; Index 59h, bit 7 and bits 3 ~ 2; and Index 5Dh, bits 5 ~ 7. There are three bits for each divisor, and the corresponding divisor is listed in the table below. Table 8-4 Fan Divisor Definition BIT 2 BIT 1 BIT 0 FAN DIVISOR BIT 2 BIT 1 BIT 0 FAN DIVISOR 0 0 0 1 1 0 0 16 0 0 1 2 1 0 1 32 0 1 0 4 1 1 0 64 0 1 1 8 1 1 1 128 The following table provides some examples of the relationship between divisor, RPM, and count. Table 8-5 Divisor, RPM, and Count Relation DIVISOR NOMINAL RPM TIME PER REVOLUTION COUNTS 70% RPM TIME FOR 70% 1 8800 6.82 ms 153 6160 9.84 ms 2 (default) 4400 13.64 ms 153 3080 19.48 ms 4 2200 27.27 ms 153 1540 38.96 ms 8 1100 54.54 ms 153 770 77.92 ms 16 550 109.08 ms 153 385 155.84 ms 32 275 218.16 ms 153 192 311.68 ms 64 137 436.32 ms 153 96 623.36 ms 128 68 872.64 ms 153 48 1246.72 ms -44- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 8.6.2 Fan Speed Control The W83627DHG-P has four output pins for fan control, each of which offers PWM duty cycle and DC voltage to control the fan speed. The output type (PWM or DC) of each pin is configured by Bank0 Index 04h, bits 1 ~ 0; Index 12h, bit 0; and Index 62h, bit 6. For PWM, the duty cycle is programmed by eight-bit registers at Bank0 Index 01h, Index 03h, Index 11h and Index 61h. The duty cycle can be calculated using the following equation: Dutycycle(%) = Programmed 8 - bit Register Value × 100% 255 The default duty cycle is FFh, or 100%. The PWM clock frequency is programmed at Bank0 Index 00h, Index 02h, Index 10h and Index 60h. For DC, the W83627DHG-P has a six bit digital-to-analog converter (DAC) that produces 0 to 3.3 Volts DC. The analog output is programmed at Bank0 Index 01h, Index 03h, Index 11h and Index 61h. The analog output can be calculated using the following equation: OUTPUT Voltage (V) = AVCC × Programmed 6 - bit Register Value ` 64 The default value is 111111YY, or nearly 3.3 V, and Y is a reserved bit. -45- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 8.6.3 SMART FANTM Control The W83627DHG-P supports two SMART FANTM I features — Thermal CruiseTM mode and Fan Speed CruiseTM mode, SMART FANTM III features, and SMART FANTM III+ features. Each of these is discussed in the following sections. Each fan output and corresponding temperature sensor is illustrated in the figure below. SYSTIN SMART FANTM I SYSFANOUT FANCTRL1 FANCTRL2 pre-configure FANOUT (Bank6, Idx5B) CPUTIN(Def.) 8'h00 PECI1 PECI2 PECI3 PECI4 SMART FANTM I CPUFANOUT0 SMART FANTM III PECI ERROR FANCTRL2 CPUFANOUT0 TEMP_SEL (Bank0, Idx49[2:0]) SYSTIN CPUTIN AUXTIN 8'h00 PECI1 PECI2 PECI3 PECI4(Def.) FANCTRL6 SMART FANTM III+ FAN_SEL[0] (Bank1, Idx5E[4]) FANCTRL6 SMART FANTM III+ FAN_SEL[1] (Bank1, Idx5E[5]) FANCTRL6 pre-configure FANOUT (Bank6, Idx5F) SMART FANTM III+ FANCTRL6 PECI ERROR FANCTRL6 SMART FANTM III+ TEMP_SEL (Bank1, Idx5E[3:1]) -46- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT FANCTRL3 pre-configure FANOUT (Bank6, Idx5C) AUXTIN(Def.) 8'h00 PECI1 PECI2 PECI3 PECI4 AUXFANOUT SMART FANTM I PECI ERROR FANCTRL3 FANCTRL5 SMART FANTM III+ FAN_SEL[0] (Bank0, Idx75[4]) AUXFANOUT TEMP_SEL (Bank0, Idx49[6:4]) FANCTRL4 pre-configure FANOUT (Bank6, Idx5D) SYSTIN(Def.) CPUTIN AUXTIN 8'h00 PECI1 PECI2 PECI3 PECI4 SMART FANTM I FANCTRL4 CPUFANOUT1 TEMP_SEL (Bank0, Idx4A[7:5]) SYSTIN CPUTIN AUXTIN 8'h00 PECI1 PECI2 PECI3 PECI4(Def.) CPUFANOUT1 SMART FANTM III PECI ERROR FANCTRL5 SMART FANTM III+ FAN_SEL[1] (Bank0, Idx75[5]) FANCTRL5 pre-configure FANOUT (Bank6, Idx5E) SMART FANTM III+ FANCTRL5 PECI ERROR FANCTRL5 SMART FANTM III+ TEMP_SEL (Bank0, Idx75[3:1]) Figure 8-11 FANOUT and Corresponding Temperature Sensors in SMART FANTM I, III, and III+ -47- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 8.6.3.1. Thermal CruiseTM Mode Four pairs of temperature sensors and fan outputs in Thermal CruiseTM mode: • SYSTIN and SYSFANOUT • CPUFANOUT0 and the temperature sensor selected by Bank0 Index 49h, bits 2 ~ 0 • AUXFANOUT and the temperature sensor selected by Bank0 Index 49h, bits 6 ~ 4 • CPUFANOUT1 and the temperature sensor selected by Bank0 Index 4Ah, bits 7 ~ 5 Thermal CruiseTM mode controls the fan speed to keep the temperature in a specified range. First, this range is defined in BIOS by a temperature and the interval (e.g., 55 °C ± 3 °C). As long as the current temperature remains below the low end of this range (i.e., 52 °C), the fan is off. Once the temperature exceeds the low end, the fan turns on at a speed defined in BIOS (e.g., 20% output). Thermal CruiseTM mode then controls the fan output according to the current temperature. Three conditions may occur: (1) If the temperature still exceeds the high end, fan output increases slowly. If the fan is operating at full speed but the temperature still exceeds the high end, a warning message is issued to protect the system. (2) If the temperature falls below the high end (i.e., 58 °C) but remains above the low end (e.g., 52 °C), fan output remains the same. (3) If the temperature falls below the low end (e.g., 52 °C), fan output decreases slowly to zero or to a specified “stop value”. This stop value is enabled by Bank0 Index 12h, bits 3 ~ 5, and the value itself is specified in Bank0 Index 08h, Index 09h, Index 15h, and Index 64h. The fan remains at the stop value for the period of time defined in Bank0 Index 0Ch, Index 0Dh, Index 17h, and Index 66h. In general, Thermal CruiseTM mode means • if the current temperature is higher than the high end, increase the fan speed; • if the current temperature is lower than the low end, decrease the fan speed; • otherwise, keep the fan speed the same. The following figures illustrate two examples of Thermal CruiseTM mode. -48- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT A Tolerance Target Temperature B C D 58°C 55°C Tolerance 52°C PWM Duty Cycle (%) 100 Fan Start = 20% Fan Stop = 10% Fan Start = 20% 50 0 Stop Time Figure 8-12 Mechanism of Thermal CuriseTM Mode (PWM Duty Cycle) A Tolerance Target Temperature B C D 58°C 55°C Tolerance 52°C (V) DC 3.3 Fan Start = 0.62V Fan Stop = 0.31V Fan Start = 0.62V Output Voltage 1.65 0 Stop Time Figure 8-13 Mechanism of Thermal CuriseTM Mode (DC Output Value) -49- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 8.6.3.2. Fan Speed CruiseTM Mode Four pairs of fan input sensors and fan outputs in Fan Speed CruiseTM mode. • SYSFANIN and SYSFANOUT • CPUFANIN0 and the temperature sensor selected by Bank0 Index 49h, bits 2 ~ 0 • AUXFANOUT and the temperature sensor selected by Bank0 Index 49h, bits 6 ~ 4 • CPUFANOUT1 and the temperature sensor selected by Bank0 Index 4Ah, bits 7 ~ 5 Fan Speed CruiseTM mode keeps the fan speed in a specified range. First, this range is defined in BIOS by a fan speed count (the amount of time between clock input signals, not the number of clock input signals in a period of time) and an interval (e.g., 160 ± 10). As long as the fan speed count is in the specified range, fan output remains the same. If the fan speed count is higher than the high end (e.g., 170), fan output increases to make the count lower. If the fan speed count is lower than the low end (e.g., 150), fan output decreases to make the count higher. One example is illustrated in this figure. A Count 170 C 160 150 Fan output (%) 100 50 0 Figure 8-14 Mechanism of Fan Speed CruiseTM Mode The following tables show current temperatures, fan output values and the relative control registers at Thermal CruiseTM and Fan Speed CruiseTM mode. Table 8-6 Display Registers - at SMART FANTM I Mode DESCRIPTION REGISTER ADDRESS REGISTER NAME ATTRIBUTE BIT DATA Current CPU Temperature Bank1 Index 50h ,51h CPUTIN Temperature Sensor Read only 8 MSB, 1°C bit 7, 0.5 °C Current SYS Temperature Bank 0 Index 27h SYSTIN Temperature Sensor Read only 8 MSB, 1°C Current AUX Temperature Bank2 Index 50h,51h AUXTIN Temperature Sensor Read only 8 MSB, 1°C bit 7, 0.5 °C Current CPUFANOUT0 Output Value Bank0 Index 03h CPUFANOUT0 Output Value Select 80h / FFh by strapping bits 7~0 CPUFANOUT0 Value Current SYSFANOUT Bank0 Index 01h SYSFANOUT Output Value Select FFh bits 7~0 SYSFANOUT Value -50- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT REGISTER ADDRESS REGISTER NAME Current AUXFANOUT Output Value Bank0 Index 11h AUXFANOUT Output Value Select FFh bits 7~0 AUXFANOUT Value Current CPUFANOUT1 Output Value Bank0 Index 61h CPUFANOUT1 Output Value Select 80h / FFh by strapping bits 7~0 CPUFANOUT1 Value DESCRIPTION ATTRIBUTE BIT DATA Output Value Table 8-7 Relative Registers - at Thermal CruiseTM Mode THERMALTM CRUISE MODE STARTUP VALUE STOP VALUE KEEP MIN. FAN OUTPUT VALUE STOP TIME TARGET TEMPERATURE TOLERANCE SYSFANOUT Bank0, 05h Bank0, 07h Bit0-3 Bank0, 0Ah Bank0, 08h Bank0, 12h, Bit5 Bank0, 0Ch CPUFANOUT0 Bank0, 06h Bank0, 07h, Bit4-7 Bank0, 0Bh Bank0, 09h Bank0, 12h, Bit4 Bank0, 0Dh AUXFANOUT Bank0, 13h Bank0, 14h, Bit0-3 Bank0, 16h Bank0, 15h Bank0, 12h, Bit3 Bank0, 17h CPUFANOUT1 Bank0, 63h Bank0, 62h, Bit0-3 Bank0, 65h Bank0, 64h Bank0, 12h, Bit6 Bank0, 66h STEPDOWN TIME STEPUP TIME Bank0, 0Eh Bank0, 0Fh Table 8-8 Relative Registers-at Fan Speed CruiseTM Mode SPEED CRUISETM MODE TARGET-SPEED COUNT TOLERANCE KEEP MIN. FAN OUTPUT VALUE SYSFANOUT Bank0, Index 05h Bank0, Index 07h, bits 0-3 Bank0, Index 12h, Bit5 CPUFANOUT0 Bank0, Index 06h Bank0, Index 07h, bits 4-7 Bank0, Index 12h, Bit4 AUXFANOUT Bank0, Index 13h Bank0, Index 14h, bits 0-3 Bank0, Index 12h, Bit3 CPUFANOUT1 Bank0, Index 63h Bank0, Index 62h, bits 0-3 Bank0, Index 12h, Bit6 -51- STEPDOWN TIME Bank0, Index 0Eh STEPUP TIME Bank0, Index 0Fh Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 8.6.3.3. SMART FANTM III SMART FANTM III controls the fan speed so that the temperature meets the target temperature set in BIOS or application software. There are only two pairs of fan outputs and temperature sensors in SMART FANTM III mode. • CPUFANOUT0 and the temperature sensor selected by Bank0 Index 49h, bits 2 ~ 0 • CPUFANOUT1 and the temperature sensor selected by Bank0 Index 4Ah, bits 7 ~ 5 CPUTIN PECI_Agent1 PECI_Agent2 PECI_Agent3 PECI_Agent4 Pin 115 CPUFANOUT0 SYSTIN AUXTIN CPUTIN PECI_Agent1 PECI_Agent2 PECI_Agent3 PECI_Agent4 Pin 120 CPUFANOUT1 The algorithm is as follows: (1) The target temperature, temperature tolerance, maximum and minimum fan outputs and step are set. (2) The following figure shows the initial conditions. If the current temperature is within (Target Temperature ± Temperature Tolerance), the fan speed remains constant. -52- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT Setting Fan output (DC / PWM) Tolerance Max. Fan Output Min. Fan Output Tar. - Tol. Tar. + Tol. Temperature Figure 8-15 Setting of SMART FANTM III (3) If the current temperature is higher than (Target Temperature + Temperature Tolerance), fan speed rises one step. The step is the value in the CPUFANOUT Output Value Select Register, Bank0 Index 03h or Index 61h. In addition, the target temperature shifts to (Target Temperature + Temperature Tolerance), creating a new target temperature, named Target Temperature 1 in this figure. Current Temp. > Target Temp. + Fan output (DC / PWM) Tol. Tolerance Max. Fan Output Step Fan Initial Output Value Min. Fan Output Tar Tar 1 Tar 3 Tar 2 Tar 5 Temperature Tar 4 Figure 8-16 SMART FANTM III Mechanism (Current Temp. > Target Temp. + Tol.) If the current temperature rises higher than (Target Temperature 1 + Temperature Tolerance), the fan speed will rise one step, and the target temperature will shift to (Target Temperature 1 + -53- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT Temperature Tolerance), or Target Temperature 2. This process repeats whenever the current temperature is higher than (Target Temperature X ± Temperature Tolerance) or until the fan speed reaches its maximum speed. (4) If the current temperature falls below (Target Temperature - Temperature Tolerance), the fan speed falls one step. The step is the value in the CPUFANOUT Output Value Select Register, Bank0 Index 03h or Index 61h. In addition, the target temperature shifts to (Target Temperature - Temperature Tolerance), creating a new target temperature named Target Temperature 1.This is illustrated in the figure below. Current Temp. < Target Temp. - Tol. Fan output (DC / PWM) Tolerance Max. Fan Output Fan Initial Output Value Step Min. Fan Output Tar 3 Tar Tar 2 Temperature Tar 1 Figure 8-17 SMART FANTM III Mechanism (Current Temp. < Target Temp. - Tol.) If the current temperature falls lower than (Target Temperature 1 - Temperature Tolerance), the fan speed is reduced one step again, and the target temperature shifts to (Target Temperature 1 - Temperature Tolerance), or Target Temperature 2. This process repeats whenever the current temperature is lower than (Target Temperature X - Temperature Tolerance) or until the fan speed reaches its minimum speed. (5) If the current temperature is always lower than (Target Temperature X - Temperature Tolerance), the fan speed decreases slowly to zero or to a specified stop value. The stop value is enabled by register Bank0 Index 12h, bit 4 and bit 6, and the stop value is specified in Bank0 Index 09h and Index 64h. The fan remains at the stop value for the period of time defined in Bank0 Index 0Dh and Index 66h. -54- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT The following tables show current temperatures, fan output values and the relative control registers at SMART FANTM III mode. Table 8-9 Display Register - in SMART FANTM III Mode DESCRIPTION REGISTER ADDRESS REGISTER NAME ATTRIBUTE BIT DATA Current CPU Temperature Bank1 Index 50h ,51h CPUTIN Temperature Sensor Read only 8 MSB, 1°C bit 7, 0.5 °C Current SYS Temperature Bank 0 Index 27h SYSTIN Temperature Sensor Read only 8 MSB, 1°C Current AUX Temperature Bank2 Index 50h,51h AUXTIN Temperature Sensor Read only 8 MSB, 1°C bit 7, 0.5 °C Current CPUFANOUT0 Output Value Bank0 Index 03h CPUFANOUT0 Output Value Select 80h / FFh by strapping bits 7~0 CPUFANOUT0 Value Current CPUFANOUT1 Output Value Bank0 Index 61h CPUFANOUT1 Output Value Select 80h / FFh by strapping bits 7~0 CPUFANOUT1 Value Table 8-10 Relative Register - in SMART FANTM III Control Mode TOLERANCE STOP VALUE (MIN. FAN OUTPUT) MAX. FAN OUTPUT STOP TIME Bank0, Index 06h Bank0, Index 07h, bits 4-7 Bank0, Index 09h Bank0, Index 67h Bank0, Index 0Dh Bank0, Index 63h Bank0, Index 62h, bits 0-3 Bank0, Index 64h Bank0, Index 69h Bank0, Index 66h SMART FANTM III MODE OUTPUT STEP STEP DOWN TIME STEP UP TIME KEEP MIN. FAN OUTPUT VALUE INITIAL VALUE CPUFANOUT0 Bank0, Index 68h Bank0, Index 0Eh Bank0, Index 0Fh Bank0, Index 12h, bit 4 Bank0, Index 03h CPUFANOUT1 Bank0, Index 6Ah Bank0, Index 12h, bit 6 Bank0, Index 03h SMART FANTM III MODE TARGET TEMPERATURE CPUFANOUT0 CPUFANOUT1 -55- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 8.6.3.4. SMART FANTM III+ SMART FANTM III+ offers 2 slopes to control the fan speed. There are four fan outputs and temperature sensors in SMART FANTM III+ mode. • The temperature sensor is selected by Bank0 Index 75h, bits 3~1 & Bank1 Index 5Eh, bits 3~1. • The fan output (SYSFANOUT, CPUFANOUT0, AUXFANOUT & CPUFANOUT1) is selected by Bank0 Index 75, bits 5~4 & Bank1 Index 5Eh, bit 5~4. The 2 slopes can be obtained by setting PWM1~PWM3 and Temperature1~Temperature3 through the registers. When the temperature changes, FAN Output will calculate the DC/PWM output based on the current slope. For example, in the following figure, T1~T3 are the temperature set and DC/PWM1 ~ DC/PWM3 are the fan output set. Assume Tx and Ty are the current temperature and DC/PWMx and DC/PWMy are the fan outputs, then The slope: (DC / PWM 2) − (DC / PWM 1) (T 2 − T1) (DC / PWM 3) − (DC / PWM 2) Y= (T 3 − T 2) X = Fan Output: DC / PWMx = (DC / PWM 1) + (Tx − T 1) ⋅ X DC / PWMy = (DC / PWM 2 ) + (Ty − T 2 ) ⋅ Y Fan output (DC/PWM) DC/PWM3 DC/PWMy DC/PWM2 DC/PWMx DC/PWM1 Temperature T1 Tx T2 Ty T3 Figure 8-18 SMART FANTM III+ Mechanism -56- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT Table 8-11 Display Registers - in SMART FANTM III+ Mode DESCRIPTION REGISTER ADDRESS REGISTER NAME ATTRIBUTE FANCTRL5 SMART FANTM III + Temperature 1 Bank0 Index 6Fh FANCTRL5 SMART FANTM III + Temperature 1 Read / Write FANCTRL5 SMART FANTM III + Temperature 2 Bank0 Index 70h FANCTRL5 SMART FANTM III + Temperature 2 Read / Write FANCTRL5 SMART FANTM III + Temperature 3 Bank0 Index 71h FANCTRL5 SMART FANTM III + Temperature 3 Read / Write FANCTRL5 SMART FANTM III + DC/PWM 1 Bank0 Index 72h FANCTRL5 SMART FANTM III + DC/PWM 1 Read / Write FANCTRL5 SMART FANTM III + DC/PWM 2 Bank0 Index 73h FANCTRL5 SMART FANTM III + DC/PWM 2 Read / Write FANCTRL5 SMART FANTM III + DC/PWM 3 Bank0 Index 74h FANCTRL5 SMART FANTM III + DC/PWM 3 Read / Write FANCTRL5 SMART FANTM III + input source & output FAN select Bank0 Index 75h, bit5-1 FANCTRL5 SMART FANTM III + input source & output FAN select Read / Write FANCTRL6 SMART FANTM III + Temperature 1 Bank1 Index 58h FANCTRL6 SMART FANTM III + Temperature 1 Read / Write FANCTRL6 SMART FANTM III + Temperature 2 Bank1 Index 59h FANCTRL6 SMART FANTM III + Temperature 2 Read / Write FANCTRL6 SMART FANTM III + Temperature 3 Bank1 Index 5Ah FANCTRL6 SMART FANTM III + Temperature 3 Read / Write FANCTRL6 SMART FANTM III + DC/PWM 1 Bank1 Index 5Bh FANCTRL6 SMART FANTM III + DC/PWM 1 Read / Write FANCTRL6 SMART FANTM III + DC/PWM 2 Bank1 Index 5Ch FANCTRL6 SMART FANTM III + DC/PWM 2 Read / Write FANCTRL6 SMART FANTM III + DC/PWM 3 Bank1 Index 5Dh FANCTRL6 SMART FANTM III + DC/PWM 3 Read / Write FANCTRL6 SMART FANTM III + input source & output FAN select Bank1 Index 5Eh, bit5-1 FANCTRL6 SMART FANTM III + input source & output FAN select Read / Write -57- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 8.7 Interrupt Detection 8.7.1 SMI# Interrupt Mode The SMI#/OVT# pin (pin 5) is a multi-function pin. It can be in SMI# mode or in OVT# mode by setting Configuration Register CR [29h], bit 6 to one or zero, respectively. In SMI# mode, it can monitor voltages, fan counts, or temperatures. 8.7.1.1. Voltage SMI# Mode The SMI# pin can create an interrupt if a voltage exceeds a specified high limit or falls below a specified low limit. This interrupt must be reset by reading all the interrupt status registers, or subsequent events do not generate interrupts. This mode is illustrated in the following figure. High limit Fan Count limit Low limit SMI# * * * SMI# * * * *Interrupt Reset when Interrupt Status Registers are read Figure 8-19 SMI Mode of Voltage and Fan Inputs 8.7.1.2. Fan SMI# Mode The SMI# pin can create an interrupt if a fan count crosses a specified fan limit (rises above it or falls below it). This interrupt must be reset by reading all the interrupt status registers, or subsequent events do not generate interrupts. This mode is illustrated in the figure above. -58- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 8.7.1.3. Temperature SMI# Mode The SMI# pin can create interrupts that depend on the temperatures measured by SYSTIN, CPUTIN, and AUXTIN. These interrupts are divided into two parts, one for SYSTIN and the other for CPUTIN / AUXTIN. 8.7.1.3.1. Temperature Sensor 1 (SYSTIN) SMI# Interrupt The SMI# pin has four interrupt modes with SYSTIN. (1) Shut-down Interrupt Mode This mode is enabled by setting THYST (Temperature Hysteresis) lower than TOL and setting Bank0 Index 40h, bit 4 to 1. In this mode, the SMI# pin can create an interrupt when the current temperature rises above TOL or Shut-down mode high limit temperature, and when the current temperature falls below THYST or Shut-down mode low limit temperature. Once the temperature rises above TOL, however, and generates an interrupt, this mode does not generate additional interrupts, even if the temperature remains above TOL, until the temperature falls below THYST. This interrupt must be reset by reading all the interrupt status registers, or subsequent events do not generate interrupts, except the first time current temperature rises above Shut-down mode high limit temperature. This is illustrated in the following figure. Shut-down mode High Limit Temperature Shut-down mode Low Limit Temperature TOL THTST SMI# * * * * * * * * Interrupt Reset when Interrupt Status Registers are read Shut-down Interrupt Mode (2) Comparator Interrupt Mode This mode is enabled by setting THYST (Temperature Hysteresis) to 127°C. In this mode, the SMI# pin can create an interrupt as long as the current temperature exceeds TO (Over Temperature). This interrupt can be reset by reading all the interrupt status registers, or subsequent events do not generate interrupts. If the interrupt is reset, the SMI# pin continues to create interrupts until the temperature goes below TO. This is illustrated in the figure below. -59- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT THYST 127'C TOI TOI THYST SMI# * * * SMI# * * * * *Interrupt Reset when Interrupt Status Registers are read Comparator Interrupt Mode Two-Time Interrupt Mode Figure 8-20 SMI Mode of SYSTIN I (3) Two-Time Interrupt Mode This mode is enabled by setting THYST (Temperature Hysteresis) lower than TO and setting Bank0 Index 4Ch, bit 5 to zero. In this mode, the SMI# pin can create an interrupt when the current temperature rises above TO or when the current temperature falls below THYST. Once the temperature rises above TO, however, and generates an interrupt, this mode does not generate additional interrupts, even if the temperature remains above TO, until the temperature falls below THYST. This interrupt must be reset by reading all the interrupt status registers, or subsequent events do not generate interrupts. This is illustrated in the figure above. (4) One-Time Interrupt Mode This mode is enabled by setting THYST (Temperature Hysteresis) lower than TO and setting Bank0 Index 4Ch, bit 5 to one. In this mode, the SMI# pin can create an interrupt when the current temperature rises above TO. Once the temperature rises above TO, however, and generates an interrupt, this mode does not generate additional interrupts, even if the temperature remains above TO, until the temperature falls below THYST. This interrupt must be reset by reading all the interrupt status registers, or subsequent events do not generate interrupts. This is illustrated in the following figure. -60- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT TOI THYST SMI# * * *Interrupt Reset when Interrupt Status Registers are read One-Time Interrupt Mode Figure 8-21 SMI Mode of SYSTIN II 8.7.1.3.2. Temperature Sensor 2 (CPUTIN) And Sensor 3 (AUXTIN) SMI# Interrupt The SMI# pin has three interrupt modes with CPUTIN / AUXTIN. (1) Shut-down Interrupt Mode This mode is enabled by setting Bank0 Index 4Ch, bit 6 to zero and Bank0 Index 40h, bit 6-5 to one. In this mode, the SMI# pin can create an interrupt when the current temperature rises above TOL or Shut-down mode high limit temperature, and when the current temperature falls below THYST or Shut-down mode low limit temperature. Once the temperature rises above TOL, however, and generates an interrupt, this mode does not generate additional interrupts, even if the temperature remains above TOL, until the temperature falls below THYST. This interrupt must be reset by reading all the interrupt status registers, or subsequent events do not generate interrupts, except the first time current temperature rises above Shut-down mode high limit temperature. This is illustrated in the following figure. Shut-down mode High Limit Temperature Shut-down mode Low Limit Temperature TOL THTST SMI# * * * * * * * * Interrupt Reset when Interrupt Status Registers are read Shut-down Interrupt Mode -61- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT (2) Comparator Interrupt Mode This mode is enabled by setting Bank0 Index 4Ch, bit 6, to one. In this mode, the SMI# pin can create an interrupt when the current temperature exceeds TO (Over Temperature) and continues to create interrupts until the temperature falls below THYST. This interrupt can be reset by reading all the interrupt status registers, or subsequent events do not generate interrupts. This is illustrated in the figure below. TOI TOI THYST THYST SMI# * * * * SMI# * * * * *Interrupt Reset when Interrupt Status Registers are read Comparator Interrupt Mode Two-Time Interrupt Mode Figure 8-22 SMI Mode of CPUTIN (3) Two-Times Interrupt Mode This mode is enabled by setting Bank0 Index 4Ch, bit 6, to zero. In this mode, the SMI# pin can create an interrupt when the current temperature rises above TO or when the current temperature falls below THYST. Once the temperature rises above TO, however, and generates an interrupt, this mode does not generate additional interrupts, even if the temperature remains above TO, until the temperature falls below THYST. This interrupt must be reset by reading all the interrupt status registers, or subsequent events do not generate interrupts. This is illustrated in the figure above. 8.7.2 OVT# Interrupt Mode The SMI#/OVT# pin is a multi-function pin. It can be in SMI# mode or in OVT# mode by setting Configuration Register CR [29h], bit 6 to one or zero, respectively. In OVT# mode, it can monitor temperatures, and it is enabled or disabled for SYSTIN, CPUTIN, and AUXTIN by Bank0 Index 18h, bit 6; Bank0 Index 4Ch, bit 3; and Bank0 Index 4Ch, bit4. The OVT# pin has two interrupt modes, comparator and interrupt. The modes are illustrated in this figure. -62- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT To THYST OVT# (Comparator Mode; default) OVT# (Interrupt Mode) * * * *Interrupt Reset when Temperature sensor registers are read Figure 8-23 OVT# Modes of Temperature Inputs If Bank0 Index 18h, bit 4, Bank1 Index 52h, bit 1, and Bank2 Index 52h, bit1 are set to zero, the OVT# pin is in comparator mode. In comparator mode, the OVT# pin can create an interrupt once the current temperature exceeds TO and continues to create interrupts until the temperature falls below THYST. The OVT# pin is asserted once the temperature has exceeded TO and has not yet fallen below THYST. If Bank0 Index 18h, bit 4, Bank1 Index 52h, bit1, and Bank2 Index 52h, bit 1 are set to one, the OVT# pin is in interrupt mode. In interrupt mode, the OVT# pin can create an interrupt once the current temperature rises above TO or when the temperature falls below THYST. Once the temperature rises above TO, however, and generates an interrupt, this mode does not generate additional interrupts, even if the temperature remains above TO, until the temperature falls below THYST. This interrupt must be reset by reading all the interrupt status registers. The OVT# pin is asserted when an interrupt is generated and remains asserted until the interrupt is reset. -63- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 8.7.3 Caseopen Detection The purpose of Caseopen function is used to detect whether the computer case is opened. This feature must be able to function even when there is no 3VSB power. Consequently, the power source for the circuit is from either Pin 74 (VBAT) or Pin 61 (3VSB). 3VSB is the default power source. If there is no 3VSB power, the power source is VBAT. This is designed to save power consumption of the battery. When the case is closed, the signal of Pin 76 must be pulled high by an externally pulled-up 2MΩ resistor that is connected to Pin 74. Once the case is opened, the signal will be changed from high to low. Meanwhile, the detection circuit inside the IC latches the signal. As a result, the interrupt status and the real-time status can be read at the registers next time when the computer is booted. The status will not be cleared unless Bank 0, Index 46h, bit 7, or CR [E6h] bit 5 at Logical Device A is set to “1” first and then to “0”. CASEOPEN# CASEOPEN CLEAR CASEOPEN STATUS Figure 8-24 Caseopen Mechanism 8.7.4 BEEP Alarm Function The W83627DHG-P provides an alarm output function at the BEEP/SO pin. The BEEP/SO pin is a multi-function pin and can be configured as BEEP output, if Configuration Register CR [24h], bit 1 is set to zero. The BEEP outputs a warning tone when one of the monitored parameters in the following events is out of the preset range. z z z z z Any voltage input of the nine pins (CPUVCORE, VIN[0..3], 3VCC, AVCC , 3VSB and VBAT) is out of the allowed range; Any temperature input of the three pins (SYSTIN, CPUTIN and AUXTIN) exceeds the limit; Any fan input of the five pins (SYSFANIN, CPUFANIN0, AUXFANIN0, CPUFANIN1 and AUXFANIN1) exceeds the limit; CASEOPEN# input pin is sampled low; User-defined bit (Bank 4, Index 53h, bit 5) is written to 1. -64- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT Whether the BEEP alarm function is enabled or disabled is determined by the control bit at Hardware Monitor Device, Bank 0, Index 57h, bit 7. Also, each event has their individual enable bit at Hardware Monitor Device, Bank 0, Index 56h bit [7:0], Index 57h bit [6:0] and Bank 4, Index 53h, bit [1:0]. BEEP/SO is an open-drain output pin and its default state is low. When the BEEP alarm function is activated, this pin repeatedly outputs 600 Hz square wave for 0.5 second and 1.2 KHz square wave for 0.5 second in turn until the enable bit or the abnormal event is cleared. -65- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 9. HARDWARE MONITOR REGISTER SET The base address of the Address Port and Data Port is specified in registers CR [60h] and CR [61h] of Device B, the hardware monitor device. CR [60h] is the high byte, and CR [61h] is the low byte. The Address Port and Data Port are located at the base address, plus 5h and 6h, respectively. For example, if CR [60h] is 02h and CR [61h] is 90h, the Address Port is at 0x295h, and the Data Port is at 0x296h. 9.1 Address Port (Port x5h) Attribute: Size: Bit 6:0 Read/write , Bit 7: Reserved 8 bits BIT 7 6 5 4 3 2 1 0 NAME Reserved A6 A5 A4 A3 A2 A1 A0 DEFAULT 0 00h (Address Pointer) BIT DESCRIPTION 7 Reserved. 6-0 9.2 Read/Write. Data Port (Port x6h) Attribute: Size: Read/Write 8 bits 7 BIT 6 5 4 2 1 0 0 0 0 0 Data NAME DEFAULT 0 0 0 0 BIT DESCRIPTION 7-0 9.3 3 Data to be read from or to be written to Value RAM and Register. SYSFANOUT PWM Output Frequency Configuration Register - Index 00h (Bank 0) Attribute: Size: Read/Write 8 bits BIT 7 NAME PWM_CLK_SEL1 DEFAULT 0 6 5 4 3 2 1 0 1 0 0 PWM_SCALE1 0 0 0 -66- 0 Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT The register is meaningful only when SYSFANOUT is programmed for PWM output (i.e., Bank0 Index 04h, bit 0 is 0). BIT DESCRIPTION 7 SYSFANOUT PWM Input Clock Source Select. This bit selects the clock source for PWM output frequency. 0: The clock source is 24 MHz. 1: The clock source is 180 KHz. 6-0 SYSFANOUT PWM Pre-Scale divider. The clock source for PWM output is divided by this seven-bit value to calculate the actual PWM output frequency. PWM output frequency = Input Clock 1 ∗ Pre_Scale Divider 256 The maximum value of the divider is 127 (7Fh), and it should not be set to 0. 9.4 SYSFANOUT Output Value Select Register - Index 01h (Bank 0) Attribute: Size: BIT Read/Write 8 bits 7 6 5 4 2 1 0 1 1 1 SYSFANOUT VALUE NAME DEFAULT 3 1 1 FUNCTION MODE PWM Output (Bank 0, Index 04h, bit 0 is 0) 7 DESCRIPTION DEFAULT DC Voltage Output (Bank 0, Index 04h, bit 0 is 1) 1 DESCRIPTION 1 6 1 5 4 3 2 1 0 The PWM duty cycle is equal to this 8-bit value, divided by 255, times 100%. FFh creates a duty cycle of 100%, and 00h creates a duty cycle of 0%. 1 1 1 1 1 1 SYSFANOUT voltage control. The output voltage is calculated according to this equation: 1 1 Reserved FANOUT OUTPUT Voltage = AVCC * 64 DEFAULT 1 1 1 -67- 1 1 1 Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 9.5 CPUFANOUT0 PWM Output Frequency Configuration Register - Index 02h (Bank 0) Attribute: Size: Read/Write 8 bits BIT 7 6 NAME PWM_CLK_SEL2 DEFAULT 0 5 4 3 2 1 0 1 0 0 PWM_SCALE2 0 0 0 0 BIT DESCRIPTION 7 CPUFANOUT0 PWM Input Clock Source Select. This bit selects the clock source for PWM output. 0: The clock source is 24 MHz. 1: The clock source is 180 KHz. 6-0 CPUFANOUT0 PWM Pre-Scale divider. The clock source for PWM output is divided by the seven-bit value to calculate the actual PWM output frequency. PWM output frequency = Input Clock 1 ∗ Pre_Scale Divider 256 The maximum value of the divider is 127 (7Fh), and it should not be set to 0. The register is meaningful only when CPUFANOUT0 is programmed for PWM output. 9.6 CPUFANOUT0 Output Value Select Register - Index 03h (Bank 0) Attribute: Size: BIT Read/Write 8 bits 7 6 5 4 3 2 NAME CPUFANOUT0 VALUE DEFAULT Strap by FAN_SET (Pin 117) FUNCTION MODE PWM Output (Bank 0, Index 04h, bit 1 is 0) 7 DESCRIPTION DEFAULT DC Voltage Output (Bank 0, Index 04h, bit 1 is 1) DESCRIPTION 6 5 3 2 0 1 0 CPUFANOUT0 PWM Duty Cycle. The PWM duty cycle is equal to this 8-bit value, divided by 255, times 100%. FFh creates a duty cycle of 100%, and 00h creates a duty cycle of 0%. Strap by FAN_SET (Pin 117) CPUFANOUT0 Voltage Control. The output voltage is calculated according to this equation: OUTPUT Voltage = DEFAULT 4 1 AVCC * FANOUT 64 Reserved Strap by FAN_SET (Pin 117) -68- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 9.7 FAN Configuration Register I - Index 04h (Bank 0) Attribute: Size: Read/Write 8 bits 7 BIT 6 RESERVED NAME 0 DEFAULT 5 4 3 CPUFANOUT0_MODE 0 0 2 SYSFANOUT_MODE 0 0 BIT 1 0 CPUFANOUT0_SEL SYSFANOUT_SEL 0 1 0 DESCRIPTION 7-6 Reserved. 5-4 CPUFANOUT0 Mode Control. Bits 54 0 0: CPUFANOUT0 is in Manual Mode. (Default) 0 1: CPUFANOUT0 is in Thermal CruiseTM Mode. 1 0: CPUFANOUT0 is in Fan Speed CruiseTM Mode. 1 1: CPUFANOUT0 is in SMART FANTM III Mode. 3-2 SYSFANOUT Mode Control. Bits 32 0 0: SYSFANOUT is in Manual Mode. (Default) 0 1: SYSFANOUT is in Thermal CruiseTM Mode. 1 0: SYSFANOUT is in Fan Speed CruiseTM Mode. 1 1: Reserved. 1 CPUFANOUT0 Output Mode Selection. 0: CPUFANOUT0 pin produces a PWM output duty cycle. (Default) 1: CPUFANOUT0 pin produces DC output. 0 SYSFANOUT Output Mode Selection. 0: SYSFANOUT pin produces a PWM duty cycle output. 1: SYSFANOUT pin produces DC output. (Default) 9.8 SYSTIN Target Temperature Register/ SYSFANIN Target Speed Register Index 05h (Bank 0) Attribute: Size: Read/Write 8 bits FUNCTION MODE TM Thermal Cruise Fan Speed CruiseTM 7 DESCRIPTION Reserved DEFAULT 0 DESCRIPTION DEFAULT 6 5 4 3 2 1 0 SYSTIN Target Temperature 0 0 0 0 0 0 0 0 0 0 0 0 SYSFANIN Target Speed 0 0 -69- 0 Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 9.9 CPUTIN Target Temperature Register/ CPUFANIN0 Target Speed Register Index 06h (Bank 0) Attribute: Size: BIT Read/Write 8 bits 7 6 NAME DEFAULT 5 4 3 2 1 0 0 0 CPUTIN Target Temperature / CPUFANIN0 Target Speed 0 0 0 FUNCTION MODE 7 TM Thermal Cruise or SMART FANTM III DESCRIPTION DESCRIPTION 0 6 Reserved 0 5 4 3 2 1 0 CPUTIN Target Temperature 0 DEFAULT Fan Speed CruiseTM 0 0 0 0 0 0 0 0 0 0 0 0 0 CPUFANIN0 Target Speed 0 DEFAULT 0 0 9.10 Tolerance of Target Temperature or Target Speed Register - Index 07h (Bank 0) Attribute: Size: Read/Write 8 bits FUNCTION MODE 7 TM Thermal Cruise or SMART FANTM III Fan Speed CruiseTM DESCRIPTION DEFAULT DESCRIPTION DEFAULT 6 5 4 Tolerance of CPUTIN Target Temperature 0 0 0 Tolerance of Target Speed 0 0 0 CPUFANIN0 0 0 3 2 1 0 Tolerance of SYSTIN Target Temperature 0 0 0 Tolerance of Target Speed 0 0 0 SYSFANIN 0 0 9.11 SYSFANOUT Stop Value Register - Index 08h (Bank 0) Attribute: Size: BIT Read/Write 8 bits 7 6 5 3 2 1 0 0 0 1 SYSFANOUT STOP VALUE NAME DEFAULT 4 0 0 0 0 -70- 0 Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT In Thermal CruiseTM mode, the SYSFANOUT value decreases to this eight-bit value if the temperature stays below the lowest temperature limit. This value should not be zero. Please note that Stop Value does not mean that the fan really stops. It means that if the temperature keeps below low temperature limit, then the fan speed keeps on decreasing until reaching a minimum value, and this is Stop Value. 9.12 CPUFANOUT0 Stop Value Register - Index 09h (Bank 0) Attribute: Size: BIT Read/Write 8 bits 7 6 5 3 2 1 0 0 0 1 CPUFANOUT0 STOP VALUE NAME DEFAULT 4 0 0 0 0 0 InThermal CruiseTM mode or SMART FANTM III mode, the CPUFANOUT0 value decreases to this eightbit value if the temperature stays below the lowest temperature limit. This value should not be zero. Please note that Stop Value does not mean that the fan really stops. It means that if the temperature keeps below low temperature limit, then the fan speed keeps on decreasing until reaching a minimum value, and this is Stop Value. 9.13 SYSFANOUT Start-up Value Register - Index 0Ah (Bank 0) Attribute: Size: BIT Read/Write 8 bits 7 6 5 3 2 1 0 0 0 1 SYSFANOUT START-UP VALUE NAME DEFAULT 4 0 0 0 0 0 In Thermal CruiseTM mode, SYSFANOUT value increases from zero to this eight-bit register value to provide a minimum value to turn on the fan. 9.14 CPUFANOUT0 Start-up Value Register - Index 0Bh (Bank 0) Attribute: Size: BIT Read/Write 8 bits 7 6 5 3 2 1 0 0 0 1 CPUFANOUT0 START-UP VALUE NAME DEFAULT 4 0 0 0 0 0 In Thermal CruiseTM mode, CPUFANOUT0 value increases from zero to this eight-bit register value to provide a minimum value to turn on the fan. -71- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 9.15 SYSFANOUT Stop Time Register - Index 0Ch (Bank 0) Attribute: Size: BIT Read/Write 8 bits 7 6 5 3 2 1 0 1 0 0 SYSFANOUT STOP TIME NAME DEFAULT 4 0 0 1 1 1 In Thermal CruiseTM mode, if the stop value is enabled, this register determines the amount of time it takes the SYSFANOUT value to fall from the stop value to zero. (1)For PWM output: The units are intervals of 0.1 seconds. The default time is 6 seconds. (2)For DC output: The units are intervals of 0.4 seconds. The default time is 24 seconds. 9.16 CPUFANOUT0 Stop Time Register - Index 0Dh (Bank 0) Attribute: Size: BIT Read/Write 8 bits 7 6 5 NAME DEFAULT 4 3 2 1 0 1 0 0 CPUFANOUT0 STOP TIME 0 0 1 1 1 In Thermal CruiseTM mode or SMART FANTM III mode, this register determines the amount of time it takes the CPUFANOUT0 value to fall from the stop value to zero. (1)For PWM output: The units are intervals of 0.1 seconds. The default time is 6 seconds. (2)For DC output: The units are intervals of 0.4 seconds. The default time is 24 seconds. 9.17 Fan Output Step Down Time Register - Index 0Eh (Bank 0) Attribute: Size: BIT Read/Write 8 bits 7 6 5 3 2 1 0 0 1 0 FANOUT VALUE STEP DOWN TIME NAME DEFAULT 4 0 0 0 0 1 In SMART FANTM mode, this register determines the amount of time it takes FANOUT to decrease its value by one step. (1)For PWM output: The units are intervals of 0.1 seconds. The default time is 1 seconds. (2)For DC output: The units are intervals of 0.4 seconds. The default time is 4 seconds. -72- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 9.18 Fan Output Step Up Time Register - Index 0Fh (Bank 0) Attribute: Size: Read/Write 8 bits 7 BIT 6 5 4 3 2 1 0 0 1 0 FANOUT VALUE STEP UP TIME NAME DEFAULT 0 0 0 0 1 In SMART FANTM mode, this register determines the amount of time it takes FANOUT to increase its value by one step. (1)For PWM output: The units are intervals of 0.1 second. The default time is 1 second. (2)For DC output: The units are intervals of 0.4 second. The default time is 4 seconds. 9.19 AUXFANOUT PWM Output Frequency Configuration Register - Index 10h (Bank 0) Attribute: Size: Read/Write 8 bits BIT 7 NAME PWM_CLK_SEL3 DEFAULT 0 6 5 4 3 2 1 0 1 0 0 PWM_SCALE3 0 0 0 0 BIT DESCRIPTION 7 AUXFANOUT PWM Input Clock Source Select. This bit selects the clock source of PWM output frequency. 0: The clock source is 24 MHz. 1: The clock source is 180 KHz. 6-0 AUXFANOUT PWM Pre-Scale Divider. The clock source for PWM output is divided by this seven-bit value to calculate the actual PWM output frequency. PWM output frequency = Input Clock 1 ∗ Pre_Scale Divider 256 The maximum value of the divider is 127 (7Fh), and it should be set to 0. The register is only meaningful when AUXFANOUT is programmed for PWM output(i.e., Bank0 Index 12h, bit 0 is 0). -73- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 9.20 AUXFANOUT Output Value Select Register - Index 11h (Bank 0) Attribute: Size: Read/Write 8 bits 7 BIT 6 5 4 3 2 1 0 1 1 1 AUXFANOUT Value NAME 1 DEFAULT 1 1 FUNCTION MODE PWM Output (Bank 0, Index 12h, bit 0 is 0) 7 DESCRIPTION DESCRIPTION 6 1 5 4 3 2 1 0 AUXFANOUT PWM Duty Cycle. The PWM duty cycle is equal to this 8-bit value, divided by 255, times 100%. FFh creates a duty cycle of 100%, and 00h creates a duty cycle of 0%. 1 DEFAULT DC Output (Bank 0, Index 12h, bit 0 is 1) 1 1 1 1 1 1 1 AUXFANOUT Voltage Control. The output voltage is calculated according to this equation: 1 Reserved FANOUT OUTPUT Voltage = AVCC * 64 DEFAULT 1 1 1 1 1 1 9.21 FAN Configuration Register II - Index 12h (Bank 0) Attribute: Size: Read/Write 8 bits BIT 7 6 5 4 3 NAME RESERVED CPUFANOUT1 _MIN_VALUE SYSFANOUT _MIN_VALUE CPUFANOUT0 _MIN_VALUE AUXFANOUT _MIN_VALUE DEFAULT 0 0 0 0 0 BIT 2 1 AUXFANOUT _MODE 0 0 AUXFANOUT _SEL 0 0 DESCRIPTION 7 RESERVED. 6 CPUFANOUT1_MINT_VALUE. 0: CPUFANOUT1 value decreases to zero when the temperature goes below the target range. 1: CPUFANOUT1 value decreases to the value specified in Index 64h when the temperature goes below the target range. 5 SYSFANOUT_MIN_VALUE. 0: SYSFANOUT value decreases to zero when the temperature goes below the target range. -74- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT BIT DESCRIPTION 1: SYSFANOUT value decreases to the value specified in Index 08h when the temperature goes below the target range. 4 CPUFANOUT0_MIN_VALUE. 0: CPUFANOUT0 value decreases to zero when the temperature goes below the target range. 1: CPUFANOUT0 value decreases to the value specified in Index 09h when the temperature goes below the target range. 3 AUXFANOUT_MIN_VALUE. 0: AUXFANOUT value decreases to zero when the temperature goes below the target range. 1: AUXFANOUT value decreases to the value specified in Index 17h when the temperature goes below the target range. 2-1 0 AUXFANOUT_MODE. Bits 21 0 0: AUXFANOUT is in Manual Mode. (Default) 0 1: AUXFANOUT is in Thermal CruiseTM Mode. 1 0: AUXFANOUT is in Fan Speed CruiseTM Mode. 1 1: Reserved and no function. AUXFANOUT_SEL. 0: AUXFANOUT pin produces a PWM output duty cycle. (Default) 1: AUXFANOUT pin produces DC output. 9.22 AUXTIN Target Temperature Register/ AUXFANIN0 Target Speed Register Index 13h (Bank 0) Attribute: Size: Read/Write 8 bits 7 BIT 6 5 3 2 1 0 0 0 AUXTIN Target Temperature / AUXFANIN0 Target Speed NAME 0 DEFAULT 0 FUNCTION MODE TM Thermal Cruise Fan Speed CruiseTM 4 0 0 7 DESCRIPTION Reserved DEFAULT 0 DESCRIPTION DEFAULT 0 6 0 5 4 3 2 1 0 AUXTIN Target Temperature 0 0 0 0 0 0 0 0 0 0 0 0 AUXFANIN0 Target Speed 0 0 -75- 0 Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 9.23 Tolerance of Target Temperature or Target Speed Register - Index 14h (Bank 0) Attribute: Size: Read/Write 8 bits FUNCTION MODE 7 TM Thermal Cruise DESCRIPTION DEFAULT Fan Speed CruiseTM DESCRIPTION DEFAULT 6 5 4 Reserved 0 2 1 0 Tolerance of AUXTIN Target Temperature 0 0 0 Reserved 0 3 0 0 0 Tolerance of Target Speed 0 0 0 0 0 0 AUXFANIN0 0 0 9.24 AUXFANOUT Stop Value Register - Index 15h (Bank 0) Attribute: Size: BIT Read/Write 8 bits 7 6 5 3 2 1 0 0 0 1 AUXFANOUT STOP VALUE NAME DEFAULT 4 0 0 0 0 0 In Thermal CruiseTM mode, the AUXFANOUT value decreases to this eight-bit value if the temperature stays below the lowest temperature limit. This value should not be zero. Please note that Stop Value does not mean that the fan really stops. It means that if the temperature keeps below low temperature limit, then the fan speed keeps on decreasing until reaching a minimum value, and this is Stop Value. 9.25 AUXFANOUT Start-up Value Register - Index 16h (Bank 0) Attribute: Size: BIT Read/Write 8 bits 7 6 5 3 2 1 0 0 0 1 AUXFANOUT START-UP VALUE NAME DEFAULT 4 0 0 0 0 0 In Thermal CruiseTM mode, the AUXFANOUT value increases from zero to this eight-bit register value to provide a minimum value to turn on the fan. -76- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 9.26 AUXFANOUT Stop Time Register - Index 17h (Bank 0) Attribute: Size: Read/Write 8 bits 7 BIT 6 5 4 3 2 1 0 1 0 0 AUXFANOUT STOP TIME NAME DEFAULT 0 0 1 1 1 In Thermal CruiseTM mode, if the stop value is enabled, this register determines the amount of time it takes the AUXFANOUT value to fall from the stop value to zero. (1) For PWM output, The units are intervals of 0.1 second. The default time is 6 seconds. (2) For DC output, The units are intervals of 0.4 second. The default time is 24 seconds. 9.27 OVT# Configuration Register - Index 18h (Bank 0) Attribute: Size: Read/Write 8 bits BIT 7 6 5 4 NAME RESERVED DIS_OVT1 RESERVED OVT1_MODE DEFAULT 0 1 0 0 BIT 3 2 1 RESERVED 0 0 1 1 DESCRIPTION 7 RESERVED. 6 DIS_OVT1. 0: Enable SYSTIN OVT# output. 1: Disable temperature sensor SYSTIN over-temperature (OVT#) output. (Default) 5 RESERVED. 4 OVT1_MODE. 0: Compare Mode. (Default) 1: Interrupt Mode. 3-0 0 RESERVED. 9.28 Reserved Registers - Index 19h ~ 1Fh (Bank 0) -77- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 9.29 Value RAM ⎯ Index 20h ~ 3Fh (Bank 0) ADDRESS A6-A0 DESCRIPTION 20h CPUVCORE reading 21h VIN0 reading 22h AVCC reading 23h 3VCC reading 24h VIN1 reading 25h VIN2 reading 26h VIN3 reading 27h SYSTIN temperature sensor reading 28h SYSFANIN reading Note: This location stores the number of counts of the internal clock per revolution. 29h CPUFANIN0 reading Note: This location stores the number of counts of the internal clock per revolution. 2Ah AUXFANIN0 reading Note: This location stores the number of counts of the internal clock per revolution. 2Bh CPUVCORE High Limit 2Ch CPUVCORE Low Limit 2Dh VIN0 High Limit 2Eh VIN0 Low Limit 2Fh AVCC High Limit 30h AVCC Low Limit 31h 3VCC High Limit 32h 3VCC Low Limit 33h VIN1 High Limit 34h VIN1 Low Limit 35h VIN2 High Limit 36h VIN2 Low Limit 37h VIN3 High Limit 38h VIN3 Low Limit 39h SYSTIN temperature sensor High Limit 3Ah SYSTIN temperature sensor Hysteresis Limit 3Bh SYSFANIN Fan Count Limit Note: It is the number of counts of the internal clock for the Limit of the fan speed. -78- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT ADDRESS A6-A0 DESCRIPTION 3Ch CPUFANIN0 Fan Count Limit Note: It is the number of counts of the internal clock for the Limit of the fan speed. 3Dh AUXFANIN0 Fan Count Limit Note: It is the number of counts of the internal clock for the Limit of the fan speed. 3Eh CPUFANIN1 Fan Count Limit Note: It is the number of counts of the internal clock for the Limit of the fan speed. 3Fh CPUFANIN1 reading Note: This location stores the number of counts of the internal clock per revolution. 9.30 Configuration Register - Index 40h (Bank 0) Attribute: Size: Read/Write 8 bits BIT 7 6 5 4 3 2 1 0 NAME INITIALIZATION EN_WS2 EN_WS1 EN_WS INT_CLEAR RESERVED SMI#ENABLE START DEFAULT 0 0 0 0 0 0 1 1 BIT DESCRIPTION 7 Initialization. A one restores the power-on default values to some registers. This bit clears itself since the power-on default of this bit is zero. 6 EN_WS2. 1: SMI# output type of temperature AUXTIN is Shut-down Interrupt Mode. 0: SMI# output type is in Shut-down Interrupt Mode. (Default) 5 EN_WS1. 1: SMI# output type of temperature CPUTIN is Shut-down Interrupt Mode. 0: SMI# output type is in Shut-down Interrupt Mode. (Default) 4 EN_WS. 1: SMI# output type of temperature SYSTIN is Shut-down Interrupt Mode. 0: SMI# output type is in Shut-down Interrupt Mode. (Default) 3 INT_Clear. A one disables the SMI# output without affecting the contents of Interrupt Status Registers. The device will stop monitoring. It will resume upon clearing of this bit. 2 Reserved. 1 SMI#Enable. A one enables the SMI# Interrupt output. 0 Start. A one enables startup of monitoring operations. A zero puts the part in standby mode. Note: Unlike the “INT_Clear” bit, the outputs of interrupt pins will not be cleared if the user writes a zero to this location after an interrupt has occurred. -79- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 9.31 Interrupt Status Register 1 - Index 41h (Bank 0) Attribute: Size: Read Only 8 bits BIT 7 6 5 4 3 2 1 0 NAME CPUFANIN0 SYSFANIN CPUTIN SYSTIN 3VCC AVCC VIN0 CPUVCORE DEFAULT 0 0 0 0 0 0 0 0 BIT DESCRIPTION 7 CPUFANIN0. A one indicates the fan count limit of CPUFANIN0 has been exceeded. 6 SYSFANIN. A one indicates the fan count limit of SYSFANIN has been exceeded. 5 CPUTIN. A one indicates the high limit of CPUTIN temperature has been exceeded. 4 SYSTIN. A one indicates the high limit of SYSTIN temperature has been exceeded. 3 3VCC. A one indicates the high or low limit of 3VCC has been exceeded. 2 AVCC. A one indicates the high or low limit of AVCC has been exceeded. 1 VIN0. A one indicates the high or low limit of VIN0 has been exceeded. 0 CPUVCORE. A one indicates the high or low limit of CPUVCORE has been exceeded. 9.32 Interrupt Status Register 2 - Index 42h (Bank 0) Attribute: Size: Read Only 8 bits BIT 7 6 5 4 3 2 1 0 NAME TAR2 TAR1 AUXTIN CASEOPEN AUXFANIN0 VIN2 VIN3 VIN1 DEFAULT 0 0 0 0 0 0 0 0 BIT DESCRIPTION 7 TAR2. A one indicates that the CPUTIN temperature has been over the target temperature for three minutes at full fan speed in Thermal CruiseTM mode. 6 TAR1. A one indicates that the SYSTIN temperature has been over the target temperature for three minutes at full fan speed in Thermal CruiseTM mode. 5 AUXTIN. A one indicates the high limit of AUXTIN temperature has been exceeded. 4 CASEOPEN. A one indicates the case has been opened. 3 AUXFANIN0. A one indicates the fan count limit of AUXFANIN0 has been exceeded. 2 VIN2. A one indicates the high or low limit of VIN2 has been exceeded. 1 VIN3. A one indicates the high or low limit of VIN3 has been exceeded. 0 VIN1. A one indicates the high or low limit of VIn1 has been exceeded. -80- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 9.33 SMI# Mask Register 1 - Index 43h (Bank 0) Attribute: Size: Read/Write 8 bits BIT 7 6 5 4 3 2 1 0 NAME CPUFANIN0 SYSFANIN CPUTIN SYSTIN 3VCC AVCC VIN0 CPUVCORE DEFAULT 1 1 1 1 1 1 1 1 BIT DESCRIPTION 7 CPUFANIN0 A one disables the corresponding interrupt 6 SYSFANIN 5 CPUTIN 4 SYSTIN status bit for the SMI interrupt. (See Interrupt Status Register 1 – Index 41h (Bank0)) 3 3VCC 2 AVCC 1 VIN0 0 CPUVCORE 9.34 SMI# Mask Register 2 - Index 44h (Bank 0) Attribute: Size: Read/Write 8 bits BIT 7 6 5 4 3 2 1 0 NAME TAR2 TAR1 AUXTIN CASEOPEN AUXFANIN0 VIN2 VIN3 VIN1 DEFAULT 1 1 1 1 1 1 1 1 BIT DESCRIPTION 7 TAR2 6 TAR1 5 AUXTIN 4 CASEOPEN 3 AUXFANIN0 2 VIN2 1 VIN3 0 VIN1 A one disables the corresponding interrupt status bit for the interrupt. (See Interrupt Status Register 2 – Index 42h (Bank0)) -81- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 9.35 Interrupt Status Register 4 - Index 45h (Bank 0) Attribute: Size: Read Only 8 bits 7 BIT 6 5 3 Reserved. NAME DEFAULT 0 0 0 BIT 7-3 4 0 0 2 1 0 Shut_AUX Shut_CPU Shut_SYS 0 0 0 DESCRIPTION Reserved. 2 Shut_AUX. A one indicates the SMI# Shut-down mode high limit of AUXTIN temperature has been exceeded. 1 Shut_CPU. A one indicates the SMI# Shut-down mode high limit of CPUTIN temperature has been exceeded. 0 Shut_SYS. A one indicates the SMI# Shut-down mode high limit of SYSTIN temperature has been exceeded. 9.36 SMI# Mask Register 3 - Index 46h (Bank 0) Attribute: Size: Read/Write 8 bits BIT 7 6 5 4 3 2 1 0 NAME CASEOPEN CLEAR RESERVED Shut_AUX Shut_CPU Shut_SYS AUXFANIN1 CPUFANIN1 RESERVED DEFAULT 0 0 1 1 1 1 1 1 BIT DESCRIPTION 7 CASEOPEN Clear Control. Write 1 to this bit will clear CASEOPEN status. This bit will not be self cleared. Please write 0 after the event is cleared. The function is the same as LDA, CR [E6h], bit 5. 6 Reserved. 5 Shut_AUX A one disables the corresponding interrupt 4 Shut_CPU 3 Shut_SYS status bit for the SMI interrupt. (See Interrupt Status Register 4 – Index 45h (Bank 0)). 2 AUXFANIN1. A one disables the corresponding interrupt 1 CPUFANIN1. status bit for the SMI interrupt. (See Interrupt Status Register 3 – Index 50h (Bank 4)). 0 Reserved. -82- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 9.37 Fan Divisor Register I - Index 47h (Bank 0) Attribute: Size: Read/Write 8 bits BIT 7 6 5 4 3 2 1 0 NAME CPUFANIN0 DIV_B1 CPUFANIN0 DIV_B0 SYSFANIN DIV_B1 SYSFANIN DIV_B0 FANOPV4 FANINC4 FANOPV5 FANINC5 DEFAULT 0 1 0 1 0 1 0 1 BIT DESCRIPTION CPUFANIN0 Divisor, bits 1-0. (See VBAT Monitor Control Register – Index 5Dh (Bank 0)) 7 CPUFANIN0 DIV_B1. 6 CPUFANIN0 DIV_B0. 5 SYSFANIN DIV_B1. 4 SYSFANIN DIV_B0. 3 FANOPV4. CPUFANIN1 output value, only if bit 2 is set to zero. Otherwise, this bit has no meaning. 1: Pin 119 (CPUFANIN1) generates a logic-high signal. 0: Pin 119 generates a logic-low signal. (Default) 2 FANINC4. CPUFANIN1 Input Control. 1: Pin 119 (CPUFANIN1) acts as a FAN tachometer input. (Default) 0: Pin 119 acts as a FAN control signal, and the output value is set by register bit 3. 1 FANOPV5. AUXFANIN1 output value, only if bit 0 is set to zero. Otherwise, this bit has no meaning. 1: Pin 58 (AUXFANIN1) generates a logic-high signal. 0: Pin 58 generates a logic-low signal. (Default) 0 FANINC5. AUXFANIN1 Input Control. 1: Pin 58 (AUXFANIN1) acts as a FAN tachometer input. (Default) 0: Pin 58 acts as a FAN control signal, and the output value is set by bit 1. SYSFANIN Divisor, bits 1-0. (See VBAT Monitor Control Register – Index 5Dh (Bank0)) 9.38 Serial Bus Address Register - Index 48h (Bank 0) Attribute: Size: Read/Write 8 bits BIT 7 NAME RESERVED DEFAULT 0 6 7 4 3 2 1 0 1 0 1 SERIAL BUS ADDR. 0 BIT 6-0 5 1 0 1 DESCRIPTION RESERVED. (Read only) SERIAL BUS ADDR. Serial Bus address . -83- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 9.39 CPUFANOUT0/AUXFANOUT Monitor Temperature Source Select Register Index 49h (Bank 0) Attribute: Size: Read/Write 8 bits BIT 7 6 5 4 3 2 1 0 NAME RESERVED AUXFANOUT AUXFANOUT AUXFANOUT RESERVED CPUFANOUT0 CPUFANOUT0 CPUFANOUT TEMP_SEL[2] TEMP_SEL[1] TEMP_SEL[0] TEMP_SEL[2] TEMP_SEL[1] TEMP_SEL[0] DEFAULT 0 0 0 0 0 0 0 BIT 0 DESCRIPTION 7 RESERVED. 6 AUXFANOUT TEMP_SEL[2]. 5 AUXFANOUT TEMP_SEL[1]. 4 AUXFANOUT TEMP_SEL[0]. 3 RESERVED. 2 CPUFANOUT0 TEMP_SEL[2]. AUXFANOUT Temperature Source Select. Bits 654 0 0 0: Select AUXTIN as AUXFANOUT monitor source (Default). Please be noted that the temperature source / reading in the Bank 2, Index 50 and 51, AUXTIN Temperature Sensor is AUXTIN when this is selected. 0 0 1: Reserved. 0 1 0: Select PECI Agent 1 as AUXFANOUT monitor source. Please be noted that the temperature source / reading in the Bank 2, Index 50 and 51, AUXTIN Temperature Sensor is PECI Agent 1 when this is selected. 0 1 1: Select PECI Agent 2 as AUXFANOUT monitor source. Please be noted that the temperature source / reading in the Bank 2, Index 50 and 51, AUXTIN Temperature Sensor is PECI Agent 2 when this is selected. 1 0 0: Select PECI Agent 3 as AUXFANOUT monitor source. Please be noted that the temperature source / reading in the Bank 2, Index 50 and 51, AUXTIN Temperature Sensor is PECI Agent 3 when this is selected. 1 0 1: Select PECI Agent 4 as AUXFANOUT monitor source. Please be noted that the temperature source / reading in the Bank 2, Index 50 and 51, AUXTIN Temperature Sensor is PECI Agent 4 when this is selected. CPUFANOUT0 Temperature Source Select. Bits 210 0 0 0: Select CPUTIN as CPUFANOUT0 monitor -84- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT BIT DESCRIPTION 1 CPUFANOUT0 TEMP_SEL[1]. 0 CPUFANOUT0 TEMP_SEL[0]. source (Default). Please be noted that the temperature source / reading in the Bank 1, Index 50 and 51, CPUTIN Temperature Sensor is CPUTIN when this is selected. 0 0 1: Reserved. 0 1 0: Select PECI Agent 1 as CPUFANOUT0 monitor source. Please be noted that the temperature source / reading in the Bank 1, Index 50 and 51, CPUTIN Temperature Sensor is PECI Agent 1 when this is selected. 0 1 1: Select PECI Agent 2 as CPUFANOUT0 monitor source. Please be noted that the temperature source / reading in the Bank 1, Index 50 and 51, CPUTIN Temperature Sensor is PECI Agent 2 when this is selected. 1 0 0: Select PECI Agent 3 as CPUFANOUT0 monitor source. Please be noted that the temperature source / reading in the Bank 1, Index 50 and 51, CPUTIN Temperature Sensor is PECI Agent 3 when this is selected. 1 0 1: Select PECI Agent 4 as CPUFANOUT0 monitor source. Please be noted that the temperature source / reading in the Bank 1, Index 50 and 51, CPUTIN Temperature Sensor is PECI Agent 4 when this is selected. 9.40 CPUFANOUT1 Monitor Temperature Source Select Register - Index 4Ah (Bank 0) Attribute: Size: Read/Write 8 bits BIT 7 6 5 NAME CPUFANOUT1 TEMP_SEL[2] CPUFANOUT1 TEMP_SEL[1] CPUFANOUT1 TEMP[0] DEFAULT 0 0 0 BIT 7 4 3 2 1 0 0 0 RESERVED 0 0 0 DESCRIPTION CPUFANOUT1 TEMP_SEL[2]. CPUFANOUT1 Temperature Source Select Bits 765 0 0 0: Select SYSTIN as CPUFANOUT1 monitor source. (Default) -85- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT BIT DESCRIPTION 6 CPUFANOUT1 TEMP_SEL[1]. 5 CPUFANOUT1 TEMP_SEL[0]. 4-0 0 0 1: Select CPUTIN as CPUFANOUT1 monitor source. 0 1 0: Select AUXTIN as CPUFANOUT1 monitor source. 0 1 1: Reserved. 1 0 0: Select PECI Agent 1 as CPUFANOUT1 monitor source. 1 0 1: Select PECI Agent 2 as CPUFANOUT1 monitor source. 1 1 0: Select PECI Agent 3 as CPUFANOUT1 monitor source. 1 1 1: Select PECI Agent 4 as CPUFANOUT1 monitor source. RESERVED. 9.41 Fan Divisor Register II - Index 4Bh (Bank 0) Attribute: Size: Read/Write 8 bits BIT 7 6 NAME AUXFANIN0 DIV_B1 AUXFANIN0 DIV_B0 DEFAULT 0 1 BIT 5 4 3 2 ADCOVSEL 0 0 1 0 RESERVED 0 1 0 0 DESCRIPTION 7 AUXFANIN0 DIV_B1. 6 AUXFANIN0 DIV_B0. 5-4 ADCOVSEL. A/D Converter Clock Input select. Bits 54 0 0: ADC clock select 22.5 KHz. (Default) 0 1: ADC clock select 5.6 KHz. (22.5K/4) 1 0: ADC clock select 1.4 KHz. (22.5/16) 1 1: ADC clock select 0.35 KHz. (22.5/64) 3-2 RESERVED. These two bits should be set to 01h, the default value. 1-0 RESERVED. 9.42 SMI#/OVT# Control Register - Index 4Ch (Bank 0) Attribute: Size: Read/Write 8 bits -86- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT BIT 7 6 5 4 3 2 NAME CPUFANIN1 DIV_B2 T2T3_INT MODE EN_T1 _ONE DIS_ OVT3 DIS_ OVT2 OVTPOL DEFAULT 0 0 0 1 0 0 BIT 1 0 RESERVED 0 0 DESCRIPTION 7 CPUFANIN1 DIV_B2. CPUFANIN1 Divisor bit 2. 6 T2T3_INT MODE. 1: SMI# output type of Temperature CPUTIN / AUXTIN is in Comparator Interrupt mode. 0: SMI# output type is in Two-Times Interrupt mode. (Default) 5 EN_T1_ONE. 1: SMI# output type of temperature SYSTIN is One-Time Interrupt mode. 0: SMI# output type is Two-Times Interrupt mode. (Default) 4 DIS_OVT3. 1: Disable temperature sensor AUXTIN over-temperature (OVT) output. (Default) 0: Enable AUXTIN OVT output through pin OVT#. 3 DIS_OVT2. 1: Disable temperature sensor CPUTIN over-temperature (OVT) output. 0: Enable CPUTIN OVT output through pin OVT#. (Default) 2 OVTPOL. Over-temperature polarity. 1: OVT# active high. 0: OVT# active low. (Default) 1-0 RESERVED. 9.43 FAN IN/OUT Control Register - Index 4Dh (Bank 0) Attribute: Size: Read/Write 8 bits 7 BIT RESERVED NAME DEFAULT 1 BIT 7-6 6 0 5 4 3 2 1 0 FANOPV3 FANINC3 FANOPV2 FANINC2 FANOPV1 FANINC1 0 1 0 1 0 1 DESCRIPTION RESERVED. 5 FANOPV3. AUXFANIN0 output value, only if bit 4 is set to zero. 1: Pin 111 (AUXFANIN0) generates a logic-high signal. 0: Pin 111 generates a logic-low signal. (Default) 4 FANINC3. AUXFANIN0 Input Control. -87- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT BIT DESCRIPTION 1: Pin 111 (AUXFANIN0) acts as a FAN tachometer input. (Default) 0: Pin 111 acts as a FAN control signal, and the output value is set by bit 5. 3 FANOPV2. CPUFANIN0 output value, only if bit 2 is set to zero. 1: Pin 112 (CPUFANIN0) generates a logic-high signal. 0: Pin 112 generates a logic-low signal. (Default) 2 FANINC2. CPUFANIN0 Input Control. 1: Pin 112 (CPUFANIN0) acts as a FAN tachometer input. (Default) 0: Pin 112 acts as a FAN control signal, and the output value is set by bit 3. 1 FANOPV1. SYSFANIN output value, only if bit 0 is set to zero. 1: Pin 113 (SYSFANIN) generates a logic-high signal. 0: Pin 113 generates a logic-low signal. (Default) 0 FANINC1. SYSFANIN Input Control. 1: Pin 113 (SYSFANIN) acts as a FAN tachometer input. (Default) 0: Pin 113 acts as a FAN control signal, and the output value is set by bit 1. 9.44 Register 50h ~ 5Fh Bank Select Register - Index 4Eh (Bank 0) Attribute: Size: Read/Write 8 bits BIT 7 6 5 4 3 2 1 0 NAME HBACS RESERVED EN_AUXFANIN1 EN_CPUFANIN1 RESERVED BANKSEL2 BANKSEL1 BANKSEL0 _BP _BP DEFAULT 1 0 0 0 0 0 0 BIT 0 DESCRIPTION 7 HBACS. High Byte Access. 1: Access Index 4Fh high-byte register. (Default) 0: Access Index 4Fh low-byte register. 6 RESERVED. 5 EN_AUXFANIN1_BP. BEEP output control for AUXFANIN1 if the monitored value exceeds the threshold value. 1: Enable BEEP output. 0: Disable BEEP output. (Default) 4 EN_CPUFANIN1_BP. BEEP output control for CPUFANIN1 if the monitored value exceeds the threshold value. 1: Enable BEEP output. 0: Disable BEEP output. (Default) 3 RESERVED. This bit should be set to 0. 2 BANKSEL2. 1 BANKSEL1. 0 BANKSEL0. Bank Select for Index Ports 0x50h ~ 0x5Fh. The three-bit binary value corresponds to the bank number. For example, “010” selects Bank 2. -88- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 9.45 Nuvoton Vendor ID Register - Index 4Fh (Bank 0) Attribute: Size: Read Only 16 bits 15 BIT 14 13 12 11 10 9 8 VIDH NAME DEFAULT 0 1 0 1 1 1 0 0 BIT 7 6 5 4 3 2 1 0 0 0 1 1 VIDL NAME DEFAULT BIT 1 0 1 0 DESCRIPTION 15-8 Vendor ID High-Byte, if Index 4Eh, bit 7 is 1. Default 5Ch. 7-0 Vendor ID Low-Byte, if Index 4Eh, bit 7 is 0. Default A3h. 9.46 Reserved Register - Index 50h ~ 55h (Bank 0) -89- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 9.47 BEEP Control Register 1 - Index 56h (Bank 0) Attribute: Size: Read/Write 8 bits BIT 7 6 5 4 3 2 1 0 NAME EN_ CPUFANIN0 _BP EN_ SYSFANIN _BP EN_ CPUTIN _BP EN_ SYSTIN _BP EN_ 3VCC _BP EN_ AVCC _BP EN_ VIN0 _BP EN_ CPUVCORE _BP DEFAULT 0 0 0 0 0 0 0 0 BIT DESCRIPTION 7 EN_CPUFANIN0_BP. BEEP output control for CPUFANIN0 if the monitored value exceeds the threshold value. 1: Enable BEEP output. 0: Disable BEEP output. (Default) 6 EN_SYSFANIN_BP. BEEP output control for SYSFANIN if the monitored value exceeds the threshold value. 1: Enable BEEP output. 0: Disable BEEP output. (Default) 5 EN_CPUTIN_BP. BEEP output control fro temperature CPUTIN if the monitored value exceeds the threshold value. 1: Enable BEEP output. 0: Disable BEEP output. (Default) 4 EN_SYSTIN_BP. BEEP output control for temperature SYSTIN if the monitored value exceeds the threshold value. 1: Enable BEEP output. 0: Disable BEEP output. (Default) 3 EN_3VCC_BP. BEEP output control for 3VCC if the monitored value exceeds the threshold value. 1: Enable BEEP output. 0: Disable BEEP output. (Default) 2 EN_AVCC_BP. BEEP output control for AVCC if the monitored value exceeds the threshold value. 1: Enable BEEP output. 0: Disable BEEP output. (Default) 1 EN_VIN0_BP. BEEP output control for VIN0 if the monitored value exceeds the threshold value. 1: Enable BEEP output. 0: Disable BEEP output. (Default) 0 EN_CPUVCORE_BP. BEEP output control for CPUVCORE if the monitored value exceeds the threshold value. 1: Enable BEEP output. 0: Disable BEEP output. (Default) -90- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 9.48 BEEP Control Register 2 - Index 57h (Bank 0) Attribute: Size: Read/Write 8 bits BIT 7 6 5 4 3 2 1 0 NAME EN_GBP EN_ VIN4_BP EN_ AUXTIN _BP EN_ CASEOPEN _BP EN_ AUXFANIN0 _BP EN_VIN3 _BP EN_VIN2 _BP EN_VIN1 _BP DEFAULT 1 0 0 0 0 0 0 0 BIT DESCRIPTION 7 EN_GBP. Global BEEP control. 1: Enable global BEEP output. (Default) 0: Disable all BEEP output. 6 EN_VIN4_BP. BEEP output control for VIN4 if the monitored value exceeds the limit value. 1: Enable BEEP output. 0: Disable BEEP output. (Default) 5 EN_AUXTIN_BP. BEEP output control for temperature AUXTIN if the monitored value exceeds the threshold value. 1: Enable BEEP output. 0: Disable BEEP output. (Default) 4 EN_CASEOPEN_BP. BEEP output control for CASEOPEN if the case has been opened. 1: Enable BEEP output. 0: Disable BEEP output. (Default) 3 EN_AUXFANIN0_BP. BEEP output control for AUXFANIN0 if the monitored value exceeds the threshold value. 1: Enable BEEP output. 0: Disable BEEP output. (Default) 2 EN_VIN3_BP. BEEP output control for VIN3 if the monitored value exceeds the threshold value. 1: Enable BEEP output. 0: Disable BEEP output. (Default) 1 EN_VIN2_BP. BEEP output control for VIN2 if the monitored value exceeds the threshold value. 1: Enable BEEP output. 0: Disable BEEP output. (Default) 0 EN_VIN1_BP. BEEP output control for VIN1 if the monitored value exceeds the threshold value. 1: Enable BEEP output. 0: Disable BEEP output. (Default) -91- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 9.49 Chip ID - Index 58h (Bank 0) Attribute: Size: Read Only 8 bits 7 BIT 6 5 4 2 1 0 0 0 0 1 CHIPID NAME DEFAULT 1 1 0 0 BIT 7-0 3 DESCRIPTION CHIPID. Nuvoton Chip ID number. Default C1h. 9.50 Fan Divisor Selection Register - Index 59h (Bank 0) Attribute: Size: Read/Write 8 bits BIT 7 NAME AUXFANIN1 DIV_B2 DEFAULT 0 6 5 4 RESERVED 1 1 3 2 1 0 AUXFANIN1 DIV_B1 AUXFANIN1 DIV_B0 CPUFANIN1 DIV_B1 CPUFANIN1 DIV_B0 0 0 0 0 1 BIT DESCRIPTION 7 AUXFANIN1 DIV_B2. AUXFANIN1 Divisor, bit 2. (See VBAT Monitor Control Register – Index 5Dh (Bank 0)) 6~4 3 AUXFANIN1 DIV_B1. 2 AUXFANIN1 DIV_B0. 1 CPUFANIN1 DIV_B1 0 CPUFANIN1 DIV_B0 AUXFANIN1 Divisor, bits 1-0. (See VBAT Monitor Control Register – Index 5Dh (Bank 0)) CPUFANIN1 Divisor, bits 1-0. (See VBAT Monitor Control Register – Index 5Dh (Bank 0)) 9.51 Reserved Register - Index 5Ah ~ 5Ch (Bank 0) 9.52 VBAT Monitor Control Register - Index 5Dh (Bank 0) Attribute: Size: BIT Read/Write 8 bits 7 6 5 4 -92- 3 2 1 0 Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT NAME AUXFANIN0 DIV_B2 CPUFANIN0 DIV_B2 SYSFANIN DIV_B2 RESERVED DIODES3 DIODES2 DIODES1 EN_ VBAT _MNT DEFAULT 0 0 0 0 0 1 0 0 BIT DESCRIPTION 7 AUXFANIN0 DIV_B2. AUXFANIN0 Divisor, bit 2. 6 CPUFANIN0 DIV_B2. CPUFANIN0 Divisor, bit 2. 5 SYSFANIN DIV_B2. SYSFANIN Divisor, bit 2. 4 RESERVED. 3 DIODES3. Sensor Type Selection for AUXTIN. 1: Diode sensor. 0: Thermistor sensor. 2 DIODES2. Sensor Type Selection for CPUTIN. 1: Diode sensor. 0: Thermistor sensor. 1 DIODES1. Sensor Type Selection for SYSTIN. 1: Diode Sensor. 0: Thermistor sensor. 0 EN_VBAT_MNT. 1: Enable battery voltage monitor. When this bit changes from zero to one, it takes one monitor cycle time to update the VBAT reading value register. 0: disable battery voltage monitor. Fan divisor table: BIT 2 BIT 1 BIT 0 FAN DIVISOR BIT 2 BIT 1 BIT 0 FAN DIVISOR 0 0 0 1 1 0 0 16 0 0 1 2 1 0 1 32 0 1 0 4 1 1 0 64 0 1 1 8 1 1 1 128 -93- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 9.53 Critical Temperature and Current Mode Enable Register - Index 5Eh (Bank 0) Attribute: Size: Read/Write 8 bits BIT 7 6 5 4 3 2 1 0 NAME EN_ EN_ EN_ EN_ EN_ EN_ EN_ RESERVED CPUFANOUT1 AUXFANOUT CPUFANOUT SYSFANOUT AUXTIN CPUTIN CRITICAL TEMP CRITICAL TEMP CRITICAL TEMP CRITICAL TEMP CURRENT MODE CURRENT MODE SYSTIN CURRENT MODE 0 0 0 0 0 1 0 DEFAULT BIT 0 DESCRIPTION 7 EN_CPUFANOUT1 CRITICAL TEMP. 1: Enable CPUFANOUT1 critical temperature protection. 0: Disable CPUFANOUT1 critical temperature protection. (Default) 6 EN_AUXFANOUT CRITICAL TEMP. 1: Enable AUXFANOUT critical temperature protection. 0: Disable AUXFANOUT critical temperature protection. (Default) 5 EN_CPUFANOUT CRITICAL TEMP. 1: Enable CPUFANOUT0 critical temperature protection. 0: Disable CPUFANOUT0 critical temperature protection. (Default) 4 EN_SYSFANOUT CRITICAL TEMP. 1: Enable SYSFANOUT critical temperature protection. 0: Disable SYSFANOUT critical temperature protection. (Default) 3 EN_AUXTIN CURRENT MODE. (To enable the current mode, please also set Bank0, Index 5Dh, Bit 3 to ‘1’) 1: Temperature sensing of AUXTIN by Current Mode. 0: Temperature sensing of AUXTIN depends on the setting of Index 5Dh. (Default) 2 EN_CPUTIN CURRENT MODE. (To enable the current mode, please also set Bank0, Index 5Dh, Bit 2 to ‘1’) 1: Temperature sensing of CPUTIN by Current Mode. (Default) 0: Temperature sensing of CPUTIN depends on the setting of Index 5Dh. 1 EN_SYSTIN CURRENT MODE. (To enable the current mode, please also set Bank0, Index 5Dh, Bit 1 to ‘1’) 1: Temperature sensing of SYSTIN by Current Mode. 0: Temperature sensing of SYSTIN depends on the setting of Index 5Dh. (Default) 0 RESERVED. 9.54 Reserved Register - Index 5Fh (Bank 0) -94- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 9.55 CPUFANOUT1 PWM Output Frequency Configuration Register - Index 60h (Bank 0) Attribute: Size: Read/Write 8 bits BIT 7 NAME PWM_CLK_SEL4 6 DEFAULT 0 5 4 3 2 1 0 1 0 0 PWM_SCALE4 0 0 0 0 BIT DESCRIPTION 7 PWM_CLK_SEL4. CPUFANOUT1 PWM Input Clock Source Select. This bit selects the clock source for PWM output. 0: The clock source is 24 MHz. 1: The clock source is 180 KHz. 6-0 PWM_SCALE4. CPUFANOUT1 PWM Pre-Scale Divider. The clock source of PWM output is divided by this seven-bit value to calculate the actual PWM output frequency. PWM output frequency = Input Clock 1 ∗ Pre_Scale Divider 256 The maximum value of the divider is 127 (7Fh), and it should not be set to 0. The register is only meaningful when CPUFANOUT1 is programmed for PWM output. 9.56 CPUFANOUT1 Output Value Select Register - Index 61h (Bank 0) Attribute: Size: BIT Read/Write 8 bits 7 6 5 4 3 2 NAME CPUFANOUT1 Value DEFAULT Strap by FAN_SET2 (Pin 83) FUNCTION MODE PWM Output (Bank 0, Index 62h, bit 6 is 0) 7 DESCRIPTION DEFAULT DC Output (Bank 0, Index 62h, bit 6 is 1) DESCRIPTION 6 5 4 3 2 0 1 0 CPUFANOUT1 PWM Duty Cycle. The PWM duty cycle is equal to this 8-bit value, divided by 255, times 100%. FFh creates a duty cycle of 100%, and creates a duty cycle of 0%. Strap by FAN_SET2 (Pin 83) CPUFANOUT1 Voltage Control. The output voltage is calculated according to this equation: FANOUT OUTPUT Voltage = AVCC * 64 DEFAULT 1 Reserved Strap by FAN_SET2 (Pin 83) -95- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 9.57 FAN Configuration Register III - Index 62h (Bank 0) Attribute: Size: Read/Write 8 bits BIT 7 6 NAME RESERVED CPUFANOUT1 _SEL DEFAULT 0 1 5 4 3 CPUFANOUT1_MODE 0 BIT 2 1 0 TARGET TEMPERATURE TOLERANCE / CPUFANIN1 TARGET SPEED TOLERANCE 0 0 0 0 0 DESCRIPTION 7 RESERVED. 6 CPUFANOUT1_SEL. CPUFANOUT1 Output Mode Selection. 0: CPUFANOUT1 pin produces a PWM output duty cycle. 1: CPUFANOUT1 pin produces DC output. (Default) 5-4 CPUFANOUT1_MODE. CPUFANOUT1 Mode Control. Bits 54 0 0: CPUFANOUT1 is in Manual Mode. (Default) 0 1: CPUFANOUT1 is in Thermal CruiseTM Mode. 1 0: CPUFANOUT1 is in Fan Speed CruiseTM Mode. 1 1: CPUFANOUT1 is in SMART FANTM III Mode. 3-0 In Thermal CruiseTM mode or SMART FANTM III Mode: Tolerance of select temperature source Target Temperature. In Fan Speed CruiseTM mode: Tolerance of CPUFANIN1 Target Speed. 9.58 Target Temperature Register/CPUFANIN1 Target Speed Register - Index 63h (Bank 0) Attribute: Size: BIT Read/Write 8 bits 7 6 5 3 2 1 0 0 0 0 Target Temperature / Target Speed NAME DEFAULT 4 0 0 FUNCTION MODE TM 0 0 7 Thermal Cruise or SMART FANTM III mode DESCRIPTION Reserved DEFAULT 0 Fan Speed CruiseTM DESCRIPTION DEFAULT 0 6 5 4 3 2 1 0 Target Temperature of select temperature source. 0 0 0 0 0 0 0 0 0 0 0 0 CPUFANIN1 Target Speed 0 0 -96- 0 Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 9.59 CPUFANOUT1 Stop Value Register - Index 64h (Bank 0) Attribute: Size: BIT Read/Write 8 bits 7 6 5 3 2 1 0 0 0 1 CPUFANOUT1 STOP VALUE NAME DEFAULT 4 0 0 0 0 0 In Thermal CruiseTM mode, the CPUFANOUT1 value decreases to this eight-bit value if the temperature stays below the lowest temperature limit. This value should not be zero. Please note that Stop Value does not mean that the fan really stops. It means that if the temperature keeps below low temperature limit, then the fan speed keeps on decreasing until reaching a minimum value, and this is Stop Value. 9.60 CPUFANOUT1 Start-up Value Register - Index 65h (Bank 0) Attribute: Size: BIT Read/Write 8 bits 7 6 5 3 2 1 0 0 0 1 CPUFANOUT1 START-UP VALUE NAME DEFAULT 4 0 0 0 0 0 In Thermal CruiseTM mode, CPUFANOUT1 value increases from zero to this eight-bit register value to provide a minimum value to turn on the fan. 9.61 CPUFANOUT1 Stop Time Register - Index 66h (Bank 0) Attribute: Size: BIT Read/Write 8 bits 7 6 5 3 2 1 0 1 0 0 CPUFANOUT1 STOP TIME NAME DEFAULT 4 0 0 1 1 1 In Thermal CruiseTM mode or SMART FANTM III mode, if the stop value is enabled, this register determines the amount of time it takes the CPUFANOUT1 value to fall from the stop value to zero. (1)For PWM output: The units are intervals of 0.1 second. The default time is 6 seconds. (2)For DC output: The units are intervals of 0.4 second. The default time is 24 seconds. -97- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 9.62 CPUFANOUT0 Maximum Output Value Register - Index 67h (Bank 0) Attribute: Size: BIT Read/Write 8 bits 7 6 5 3 2 1 0 1 1 1 CPUFANOUT0 MAX. VALUE NAME DEFAULT 4 1 1 1 1 1 In SMART FANTM III mode, the CPUFANOUT0 value increases to this value. This value cannot be zero, and it cannot be lower than the CPUFANOUT0 Stop value. 9.63 CPUFANOUT0 Output Step Value Register - Index 68h (Bank 0) Attribute: Size: BIT Read/Write 8 bits 7 6 5 NAME DEFAULT 4 3 2 1 0 0 0 1 CPUFANOUT0 STEP 0 0 0 0 0 In SMART FANTM III mode, the CPUFANOUT0 value decreases or increases by this eight-bit value, when needed. 9.64 CPUFANOUT1 Maximum Output Value Register - Index 69h (Bank 0) Attribute: Size: BIT Read/Write 8 bits 7 6 5 3 2 1 0 1 1 1 CPUFANOUT1 MAX. VALUE NAME DEFAULT 4 1 1 1 1 1 In SMART FANTM III mode, the CPUFANOUT1 value increases to this value. This value cannot be zero, and it cannot be lower than the CPUFANOUT1 Stop value. 9.65 CPUFANOUT1 Output Step Value Register - Index 6Ah (Bank 0) Attribute: Size: BIT Read/Write 8 bits 7 6 5 3 2 1 0 0 0 1 CPUFANOUT1 STEP NAME DEFAULT 4 0 0 0 0 0 In SMART FANTM III mode, the CPUFANOUT1 value decreases or increases by this eight-bit value, when needed. -98- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 9.66 SYSFANOUT Critical Temperature register - Index 6Bh (Bank 0) Attribute: Size: BIT Read/Write 8 bits 7 6 NAME DEFAULT 5 4 3 2 1 0 1 1 SYSFANOUT THRESHOLD TEMPERATURE 1 1 1 1 1 1 In Thermal CruiseTM mode, when the function of SYSFANOUT temperature sensing is enabled, and the monitored temperature exceeds the threshold temperature, the SYSFANOUT will work at full speed. 9.67 CPUFANOUT0 Critical Temperature Register - Index 6Ch (Bank 0) Attribute: Size: BIT Read/Write 8 bits 7 6 4 3 2 1 0 1 1 CPUFANOUT0 CRITICAL TEMPERATURE NAME DEFAULT 5 1 1 1 1 1 1 In Thermal CruiseTM mode, when the function of CPUFANOUT0 temperature sensing is enabled, and the monitored temperature exceeds the threshold temperature, the CPUFANOUT0 will work at full speed. 9.68 AUXFANOUT Critical Temperature Register - Index 6Dh (Bank 0) Attribute: Size: BIT Read/Write 8 bits 7 6 4 3 2 1 0 1 1 AUXFANOUT CRITICAL TEMPERATURE NAME DEFAULT 5 1 1 1 1 1 1 In Thermal CruiseTM mode, when the function of AUXFANOUT temperature sensing is enabled, and the monitored temperature exceeds the threshold temperature, the AUXFANOUT will work at full speed. -99- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 9.69 CPUFANOUT1 Critical Temperature Register - Index 6Eh (Bank 0) Attribute: Size: Read/Write 8 bits 7 BIT 6 5 4 3 2 1 0 1 1 CPUFANOUT1 CRITICAL TEMPERATURE NAME DEFAULT 1 1 1 1 1 1 In Thermal CruiseTM mode, when the function of CPUFANOUT1 temperature sensing is enabled, and the monitored temperature exceeds the threshold temperature, the CPUFANOUT1 will work at full speed. 9.70 FANCTRL5 SMART FANTM III+ Temperature 1 Register (T1) – Index 6Fh (Bank 0) Attribute: Size: Read/Write 8 bits 7 BIT 6 5 SMART FAN NAME DEFAULT 0 0 0 BIT 7-0 4 3 IV 2 1 0 0 0 0 III+ Temperature 1 0 0 DESCRIPTION SMART FAN TM III+ Temperature 1 Register (T1). 9.71 FANCTRL5 SMART FANTM III+ Temperature 2 Register (T2) – Index 70h (Bank 0) Attribute: Size: Read/Write 8 bits 7 BIT 6 5 SMART FAN NAME DEFAULT 0 0 BIT 7-0 4 0 3 TM 2 1 0 0 0 0 III+ Temperature 2 0 0 DESCRIPTION SMART FAN TM III+ Temperature 2 Register (T2). -100- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 9.72 FANCTRL5 SMART FANTM III+ Temperature 3 Register (T3) – Index 71h (Bank 0) Attribute: Size: Read/Write 8 bits 7 BIT 6 5 SMART FAN NAME DEFAULT 0 0 0 BIT 7-0 4 3 TM 2 1 0 0 0 0 III+-1 Temperature 3 0 0 DESCRIPTION SMART FAN TM III+-1 Temperature 3 Register (T3). 9.73 FANCTRL5 SMART FANTM III+ DC/PWM 1 Register - Index 72h (Bank 0) Attribute: Size: Read/Write 8 bits 7 BIT 6 5 SMART FAN NAME DEFAULT 0 0 0 BIT 7-0 4 3 TM 0 2 1 0 0 0 0 III+ DC/PWM 1 0 DESCRIPTION SMART FAN TM III+ DC/PWM 1 Register. 9.74 FANCTRL5 SMART FANTM III+ DC/PWM 2 Register - Index 73h (Bank 0) Attribute: Size: Read/Write 8 bits 7 BIT 6 5 SMART FAN NAME DEFAULT 0 0 BIT 7-0 4 0 0 3 TM 2 1 0 0 0 0 III+ DC/PWM 2 0 DESCRIPTION SMART FAN TM III+ DC/PWM 2 Register. -101- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 9.75 FANCTRL5 SMART FANTM III+ DC/PWM 3 Register - Index 74h (Bank 0) Attribute: Size: Read/Write 8 bits 7 BIT 6 5 4 SMART FAN NAME DEFAULT 0 0 0 BIT 7-0 0 3 TM 2 1 0 0 0 0 III+ DC/PWM 3 0 DESCRIPTION SMART FAN TM III+ DC/PWM 3 Register. 9.76 SMART FANTM III+-1 input source & output FAN select Register - Index 75h (Bank 0) Attribute: Size: Read/Write 8 bits 7 BIT 6 NAME Reserved Reserved DEFAULT 0 0 5 4 TM SMART FAN III+-1 FAN_SEL 0 BIT 0 3 2 SMART FAN 1 TM 1 III+-1 TEMP_SEL 1 1 0 Reserved 0 DESCRIPTION 7-6 Reserved. 5-4 SMART FANTM III+-1 FAN_SEL. Bits 54 0 0: SMART FAN TM I Æ AUXFANOUT SMART FAN TM I or III Æ CPUFANOUT1 0 1: SMART FAN TM III+ Æ AUXFANOUT SMART FAN TM I or III Æ CPUFANOUT1 1 0: SMART FAN TM I Æ AUXFANOUT SMART FAN TM III+ Æ CPUFANOUT1 1 1: SMART FAN TM III+ Æ AUXFANOUT SMART FAN TM III+ Æ CPUFANOUT1 3-1 SMART FANTM III+-1 TEMP_SEL . Bits 321 0 0 0: SYS Temperature 0 0 1: CPU Temperature 0 1 0: AUX Temperature 0 1 1: PECI1 1 0 0: PECI2 1 0 1: PECI3 1 1 0: PECI4 -102- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT BIT DESCRIPTION 1 1 1: Reserved (Default) 0 Reserved. 9.77 SYSTIN SMI# Shut-down mode High Limit Temperature Register - Index 76h (Bank 0) Attribute: Size: Read/Write 8 bits 7 BIT 6 5 NAME DEFAULT 0 0 0 BIT 7-0 4 3 2 1 0 0 0 SYSTIN SMI# Shut-down mode High Limit Temperature 0 0 0 DESCRIPTION SYSTIN SMI# Shut-down mode High Limit Temperature. 9.78 SYSTIN SMI# Shut-down mode Low Limit Temperature Register - Index 77h (Bank 0) Attribute: Size: Read/Write 8 bits 7 BIT 6 5 3 2 1 0 0 0 SYSTIN SMI# Shut-down mode Low Limit Temperature NAME DEFAULT 0 0 0 BIT 7-0 4 0 0 0 DESCRIPTION SYSTIN SMI# Shut-down mode Low Limit Temperature. 9.79 CPUTIN SMI# Shut-down mode High Limit Temperature Register - Index 78h (Bank 0) Attribute: Size: Read/Write 8 bits 7 BIT 6 DEFAULT 7-0 4 3 2 1 0 0 0 CPUTIN SMI# Shut-down mode High Limit Temperature NAME BIT 5 0 0 0 0 0 0 DESCRIPTION CPUTIN SMI# Shut-down mode High Limit Temperature. -103- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 9.80 CPUTIN SMI# Shut-down mode Low Limit Temperature Register - Index 79h (Bank 0) Attribute: Size: Read/Write 8 bits 7 BIT 6 5 NAME DEFAULT 0 0 0 BIT 7-0 4 3 2 1 0 0 0 CPUTIN SMI# Shut-down mode Low Limit Temperature 0 0 0 DESCRIPTION CPUTIN SMI# Shut-down mode Low Limit Temperature. 9.81 AUXTIN SMI# Shut-down mode High Limit Temperature Register - Index 7Ah (Bank 0) Attribute: Size: Read/Write 8 bits 7 BIT 6 5 3 2 1 0 0 0 AUXTIN SMI# Shut-down mode High Limit Temperature NAME DEFAULT 0 0 0 BIT 7-0 4 0 0 0 DESCRIPTION AUXTIN SMI# Shut-down mode High Limit Temperature. 9.82 AUXTIN SMI# Shut-down mode Low Limit Temperature Register - Index 7Bh (Bank 0) Attribute: Size: Read/Write 8 bits 7 BIT 6 DEFAULT 7-0 4 3 2 1 0 0 0 AUXTIN SMI# Shut-down mode Low Limit Temperature NAME BIT 5 0 0 0 0 0 0 DESCRIPTION AUXTIN SMI# Shut-down mode Low Limit Temperature. -104- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 9.83 Temperature selection Register - Index 7Ch (Bank 0) Attribute: Size: Read/Write 8 bits 7 BIT 6 5 Reserved NAME DEFAULT 0 0 4 3 MNTEMP2_SEL MNTEMP1_SEL 0 0 0 BIT 7-5 1 0 Tread_SEL 0 0 0 DESCRIPTION Reserved. 4 MNTEMP2_SEL. 0: CPUTIN Temperature (Default) 1: PECI1 3 MNTEMP1_SEL. 0: SYSTIN Temperature (Default) 1: PECI1 2-0 2 Tread_SEL. (see Temperature Register – Index 7Dh (Bank 0)) Bits 210 0 0 0: SYSTIN Temperature (Default) 0 0 1: CPUTIN Temperature 0 1 0: AUXTIN Temperature 0 1 1: Reserved 1 0 0: PECI1 1 0 1: PECI2 1 1 0: PECI3 1 1 1: PECI4 9.84 Temperature Register - Index 7Dh (Bank 0) Attribute: Size: Read Only 8 bits 7 BIT 6 5 DEFAULT 7-0 3 2 1 0 0 0 0 Temperature Register NAME BIT 4 0 0 0 0 0 DESCRIPTION Temperature Register. (see Temperature selection Register – Index 7C (Bank 0)) -105- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 9.85 CPUTIN Temperature Sensor Temperature (High Byte) Register - Index 50h (Bank 1) Attribute: Size: Read Only 8 bits 7 BIT 6 5 4 3 2 1 0 TEMP NAME DEFAULT BIT DESCRIPTION 7-0 TEMP. Temperature of the CPUTIN sensor. The nine-bit value is in units of 0.5°C. Note: The temperature source / reading is affected by the register value at Bank0, Index 49, bit [2:0]. Please refer to Chapter 9.39 for detail information. 9.86 CPUTIN Temperature Sensor Temperature (Low Byte) Register - Index 51h (Bank 1) Attribute: Size: Read Only 8 bits BIT 7 NAME TEMP 6 5 4 3 2 1 0 RESERVED DEFAULT BIT DESCRIPTION 7 TEMP. Temperature of the CPUTIN sensor. The nine-bit value is in units of 0.5°C. 6-0 RESERVED. Note: The temperature source / reading is affected by the register value at Bank0, Index 49, bit [2:0]. Please refer to Chapter 9.39 for detail information. 9.87 CPUTIN Temperature Sensor Configuration Register - Index 52h (Bank 1) Attribute: Size: Read/Write 8 bits 7 BIT 6 5 4 RESERVED NAME DEFAULT 0 0 3 FAULT 0 BIT 0 0 2 1 0 RESERVED OVTMOD STOP 0 0 0 DESCRIPTION 7-5 RESERVED. These bits should be set to zero. 4-3 FAULT. Number of faults to detect before setting OVT# output. This avoids false strapping due to noise. 2 RESERVED. This bit should be set to zero. 1 OVTMOD. OVT# Mode Select. -106- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT BIT DESCRIPTION 0: Compare mode. (Default) 1: Interrupt mode. 0 STOP. 0: Monitor CPUTIN. 1: Stop monitoring CPUTIN. 9.88 CPUTIN Temperature Sensor Hysteresis (High Byte) Register - Index 53h (Bank 1) Attribute: Size: Read/Write 8 bits 7 BIT 6 5 4 3 2 1 0 0 1 1 THYST NAME DEFAULT 0 1 0 0 1 BIT DESCRIPTION 7-0 THYST. Hysteresis temperature bits 8-1. The nine-bit value is in units of 0.5°C, and the default is 75°C. 9.89 CPUTIN Temperature Sensor Hysteresis (Low Byte) Register - Index 54h (Bank 1) Attribute: Size: Read/Write 8 bits BIT 7 NAME THYST DEFAULT 0 BIT 7 6-0 6 5 4 3 2 1 0 0 0 0 RESERVED 0 0 0 0 DESCRIPTION THYST. Hysteresis temperature bit 0. The nine-bit value is in units of 0.5°C. RESERVED. -107- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 9.90 CPUTIN Temperature Sensor Over-temperature (High Byte) Register - Index 55h (Bank1) Attribute: Size: Read/Write 8 bits 7 BIT 6 5 4 3 2 1 0 0 0 0 0 TOVF NAME DEFAULT 0 1 0 1 BIT DESCRIPTION 7-0 TOVF. Over-temperature bits 8-1. The nine-bit value is in units of 0.5°C, and the default is 80°C. 9.91 CPUTIN Temperature Sensor Over-temperature (Low Byte) Register - Index 56h (Bank 1) Attribute: Size: Read/Write 8 bits BIT 7 NAME TOVF DEFAULT 0 6 5 6-0 3 2 1 0 0 0 0 RESERVED 0 0 BIT 7 4 0 0 DESCRIPTION TOVF. Over-temperature bit 0. The nine-bit value is in units of 0.5°C. RESERVED. 9.92 FANCTRL6 SMART FANTM III+ Temperature 1 Register (T1) – Index 58h (Bank 1) Attribute: Size: Read/Write 8 bits 7 BIT 6 5 NAME DEFAULT 0 0 BIT 7-0 4 SMART FAN 0 3 TM 2 1 0 0 0 0 III+ Temperature 1 0 0 DESCRIPTION SMART FAN TM III+ Temperature 1 Register (T1). -108- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 9.93 FANCTRL6 SMART FANTM III+ Temperature 2 Register (T2) – Index 59h (Bank 1) Attribute: Size: Read/Write 8 bits 7 BIT 6 5 NAME DEFAULT 0 0 0 BIT 7-0 4 SMART FAN 3 TM 2 1 0 0 0 0 III+ Temperature 2 0 0 DESCRIPTION SMART FAN TM III+ Temperature 2 Register (T2). 9.94 FANCTRL6 SMART FANTM III+ Temperature 3 Register (T3) – Index 5Ah (Bank 1) Attribute: Size: Read/Write 8 bits 7 BIT 6 5 SMART FAN NAME DEFAULT 0 0 0 BIT 7-0 4 3 TM 2 1 0 0 0 0 III+ Temperature 3 0 0 DESCRIPTION SMART FAN TM III+ Temperature 3 Register (T3). 9.95 FANCTRL6 SMART FANTM III+ DC/PWM 1 Register - Index 5Bh (Bank 1) Attribute: Size: Read/Write 8 bits 7 BIT 6 5 SMART FAN NAME DEFAULT 0 0 BIT 7-0 4 0 0 3 IV 2 1 0 0 0 0 III+ DC/PWM 1 0 DESCRIPTION SMART FAN TM III+ DC/PWM 1 Register. -109- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 9.96 FANCTRL6 SMART FANTM III+ DC/PWM 2 Register - Index 5Ch (Bank 1) Attribute: Size: Read/Write 8 bits 7 BIT 6 5 SMART FAN NAME DEFAULT 0 0 0 BIT 7-0 4 3 TM 0 2 1 0 0 0 0 III+ DC/PWM 2 0 DESCRIPTION SMART FAN TM III+ DC/PWM 2 Register. 9.97 FANCTRL6 SMART FANTM III+ DC/PWM 3 Register - Index 5Dh (Bank 1) Attribute: Size: Read/Write 8 bits 7 BIT 6 5 SMART FAN NAME DEFAULT 0 0 0 BIT 7-0 4 0 3 TM 2 1 0 0 0 0 III+ DC/PWM 3 0 DESCRIPTION SMART FAN TM III+ DC/PWM 3 Register. 9.98 FANCTRL6 SMART FANTM III+ input source & output FAN select Register Index 5Eh (Bank 1) Attribute: Size: Read/Write 8 bits 7 BIT 6 NAME Reserved Reserved DEFAULT 0 0 BIT 5 4 TM SMART FAN III+ FAN_SEL 0 0 3 2 SMART FAN 1 TM 1 III+ TEMP_SEL 1 1 0 Reserved 0 DESCRIPTION 7-6 Reserved. 5-4 SMART FANTM III+ FAN_SEL. Bits 54 0 0: SMART FAN TM I Æ SYSFANOUT SMART FAN TM I or III Æ CPUFANOUT0 0 1: SMART FAN TM III+ Æ SYSFANOUT SMART FAN TM I or III Æ CPUFANOUT0 -110- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT BIT DESCRIPTION 1 0: SMART FAN I Æ SYSFANOUT SMART FAN TM III+ Æ CPUFANOUT0 1 1: SMART FAN TM III+ Æ SYSFANOUT SMART FAN TM III+ Æ CPUFANOUT0 TM 3-1 0 SMART FANTM III+ TEMP_SEL. Bits 321 0 0 0: SYS Temperature 0 0 1: CPU Temperature 0 1 0: AUX Temperature 0 1 1: Reserved 1 0 0: PECI1 1 0 1: PECI2 1 1 0: PECI3 1 1 1: PECI4 (Default) Reserved. 9.99 AUXTIN Temperature Sensor Temperature (High Byte) Register - Index 50h (Bank 2) Attribute: Size: Read Only 8 bits 7 BIT 6 5 4 3 2 1 0 TEMP NAME DEFAULT BIT DESCRIPTION 7-0 TEMP. Temperature of the AUXTIN sensor. The nine-bit value is in units of 0.5°C. Note: The temperature source / reading is affected by the register value at Bank0, Index 49, bit [6:4]. Please refer to Chapter 9.39 for detail information. 9.100 AUXTIN Temperature Sensor Temperature (Low Byte) Register Index 51h (Bank 2) Attribute: Size: Read Only 8 bits BIT 7 NAME TEMP 6 5 4 3 2 1 0 RESERVED DEFAULT BIT DESCRIPTION 7 TEMP. Temperature of the AUXTIN sensor. The nine-bit value is in units of -111- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT BIT DESCRIPTION ° 0.5 C. 6-0 RESERVED. Note: The temperature source / reading is affected by the register value at Bank0, Index 49, bit [6:4]. Please refer to Chapter 9.39 for detail information. 9.101 AUXTIN Temperature Sensor Configuration Register - Index 52h (Bank 2) Attribute: Size: Read/Write 8 bits 7 BIT 6 5 4 3 RESERVED NAME DEFAULT 0 0 FAULT 0 BIT 0 0 2 1 0 RESERVED OVTMOD STOP 0 0 0 DESCRIPTION 7-5 RESERVED. These bits should be set to zero. 4-3 FAULT. Number of faults to detect before setting OVT# output. This avoids false strapping due to noise. 2 RESERVED. 1 OVTMOD. OVT# mode select. 0: Compare Mode. (Default) 1: Interrupt Mode. 0 STOP. 0: Monitor AUXTIN. 1: Stop monitoring AUXTIN. 9.102 AUXTIN Temperature Sensor Hysteresis (High Byte) Register - Index 53h (Bank 2) Attribute: Size: Read/Write 8 bits 7 BIT 6 5 4 3 2 1 0 0 1 1 THYST NAME DEFAULT 0 1 0 0 1 BIT DESCRIPTION 7-0 THYST. Hysteresis temperature, bits 8-1. The nine-bit value is in units of 0.5°C, and the default is 75°C. -112- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 9.103 AUXTIN Temperature Sensor Hysteresis (Low Byte) Register - Index 54h (Bank 2) Attribute: Size: Read/Write 8 bits BIT 7 NAME THYST DEFAULT 0 6 5 6-0 3 2 1 0 0 0 0 RESERVED 0 0 BIT 7 4 0 0 DESCRIPTION THYST. Hysteresis temperature, bit 0. The nine-bit value is in units of 0.5°C. RESERVED. 9.104 AUXTIN Temperature Sensor Over-temperature (High Byte) Register Index 55h (Bank 2) Attribute: Size: Read/Write 8 bits 7 BIT 6 5 4 3 2 1 0 0 0 0 0 TOVF NAME DEFAULT 0 1 0 1 BIT DESCRIPTION 7-0 TOVF. Over-temperature, bits 8-1. The nine-bit value is in units of 0.5°C, and the default is 80°C. 9.105 AUXTIN Temperature Sensor Over-temperature (Low Byte) Register Index 56h (Bank 2) Attribute: Size: Read/Write 8 bits BIT 7 NAME TOVF DEFAULT 0 BIT 7 6-0 6 5 4 3 2 1 0 0 0 0 RESERVED 0 0 0 0 DESCRIPTION TOVF. Over-temperature, bit 0. The nine-bit value is in units of 0.5°C. RESERVED. -113- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 9.106 Interrupt Status Register 3 - Index 50h (Bank 4) Attribute: Size: Read Only 8 bits 7 BIT 6 RESERVED NAME DEFAULT 0 5 4 3 2 1 0 AUXFANIN1 CPUFANIN1 RESERVED TAR3 VBAT 3VSB 0 0 0 0 0 0 0 BIT 7-6 DESCRIPTION RESERVED. 5 AUXFANIN1. A one indicates the fan count limit of AUXFANIN1 has been exceeded. 4 CPUFANIN1. A one indicates the fan count limit of CPUFANIN1 has been exceeded. 3 RESERVED. 2 TAR3. A one indicates that the AUXTIN temperature has been over the target temperature for three minutes at full fan speed in Thermal CruiseTM mode. 1 VBAT. A one indicates the high or low limit of VBAT has been exceeded. 0 3VSB. A one indicates the high or low limit of 3VSB has been exceeded. 9.107 SMI# Mask Register 4 - Index 51h (Bank 4) Attribute: Size: Read/Write 8 bits 7 BIT 0 DEFAULT BIT 4 3-2 1 0 9.108 5 RESERVED NAME 7-5 6 0 4 3 TAR3 0 1 2 RESERVED 0 0 1 0 VBAT 3VSB 1 1 DESCRIPTION RESERVED. TAR3. A one disables the corresponding interrupt status bit for the SMI interrupt. (See Interrupt Status Register 3 – Index 50h (Bank 4)). RESERVED. VBAT. A one disables the corresponding interrupt 3VSB. status bit for the SMI interrupt. (See Interrupt Status Register 3 – Index 50h (Bank 4)). Reserved Register - Index 52h (Bank 4) -114- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 9.109 BEEP Control Register 3 - Index 53h (Bank 4) Attribute: Size: Read/Write 8 bits 7 BIT 6 RESERVED NAME DEFAULT 0 0 5 EN_ USER_BP 0 BIT 7-6 5 4-2 4 3 2 RESERVED 0 0 0 1 0 EN_ VBAT_BP EN_ 3VSB_BP 0 0 DESCRIPTION RESERVED. EN_USER_BP. User-defined BEEP output function. 0: BEEP is activated. (Default) 1: BEEP is not activated. RESERVED. 1 EN_VBAT_BP. BEEP output control for VBAT if the monitored value exceeds the threshold value. 0: Disable BEEP output. (Default) 1: Enable BEEP output. 0 EN_3VSB_BP. BEEP output control for 3VSB if the monitored value exceeds the threshold value. 0: Disable BEEP output. (Default) 1: Enable BEEP output. 9.110 SYSTIN Temperature Sensor Offset Register - Index 54h (Bank 4) Attribute: Size: Read/Write 8 bits 7 BIT 6 5 4 3 2 1 0 0 0 0 OFFSET NAME DEFAULT 0 0 0 0 0 BIT DESCRIPTION 7-0 OFFSET SYSTIN Temperature Offset Value. The value in this register is added to the monitored value so that the read value will be the sum of the monitored value and this offset value. -115- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 9.111 CPUTIN Temperature Sensor Offset Register - Index 55h (Bank 4) Attribute: Size: Read/Write 8 bits 7 BIT 6 5 4 3 2 1 0 0 0 0 OFFSET NAME DEFAULT 0 0 0 0 0 BIT DESCRIPTION 7-0 OFFSET. CPUTIN Temperature Offset Value. The value in this register will be added to the monitored value so that the read value is the sum of the monitored value and this offset value. 9.112 AUXTIN Temperature Sensor Offset Register - Index 56h (Bank 4) Attribute: Size: Read/Write 8 bits 7 BIT 6 5 4 3 2 1 0 0 0 0 OFFSET NAME DEFAULT 0 0 0 0 0 BIT DESCRIPTION 7-0 OFFSET. AUTIN Temperature Offset Value. The value in this register is added to the monitored value so that the reading value is the sum of the monitored value and this offset value. 9.113 Reserved Register - Index 57h-58h (Bank 4) 9.114 Real Time Hardware Status Register I - Index 59h (Bank 4) Attribute: Size: Read Only 8 bits BIT 7 6 5 4 3 2 1 0 NAME CPUFANIN0 _STS SYSFANIN _STS CPUTIN _STS SYSTIN _STS 3VCC _STS AVCC _STS VIN0 _STS CPUVCORE _STS DEFAULT 0 0 0 0 0 0 0 0 BIT 7 DESCRIPTION CPUFANIN0_STS. CPUFANIN0 Status. 1: The fan speed count is over the threshold value. -116- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT BIT DESCRIPTION 0: The fan speed count is in the allowed range. 6 SYSFANIN_STS. SYSFANIN Status. 1: The fan speed count is over the threshold value. 0: The fan speed count is in the allowed range. 5 CPUTIN_STS. CPUTIN Temperature Sensor Status. 1: The temperature exceeds the over-temperature value. 0: The temperature is under the hysteresis value. 4 SYSTIN_STS. SYSTIN Temperature Sensor Status. 1: The temperature exceeds the over-temperature value. 0: The temperature is under the hysteresis value. 3 3VCC_STS. 3VCC Voltage Status. 1: The 3VCC voltage is over or under the allowed range. 0: The 3VCC voltage is in the allowed range. 2 AVCC_STS. AVCC Voltage Status. 1: The AVCC voltage is over or under the allowed range. 0: The 3VCC voltage is in the allowed range. 1 VIN0_STS. VIN0 Voltage Status. 1: The VIN0 voltage is over or under the allowed range. 0: The VIN0 voltage is in the allowed range. 0 CPUVCORE_STS. CPUVCORE Voltage Status. 1: The CPUVCORE voltage is over or under the allowed range. 0: The CPUVCORE voltage is in the allowed range. 9.115 Attribute: Size: Real Time Hardware Status Register II - Index 5Ah (Bank 4) Read Only 8 bits BIT 7 6 5 4 3 2 1 0 NAME TAR2 _STS TAR1 _STS AUXTIN _STS CASEOPEN _STS AUXFANIN0 _STS CPUFANIN1 _STS TAR4 _STS VIN1 _STS DEFAULT 0 0 0 0 0 0 0 0 BIT DESCRIPTION 7 TAR2_STS. Smart Fan of CPUFANIN0 Warning Status. 1: The selected temperature has been over the target temperature for three minutes at full fan speed in the Thermal CruiseTM mode. 0: The selected temperature has not reached the warning range. 6 TAR1_STS. Smart Fan of SYSFANIN Warning Status. 1: The SYSTIN temperature has been over the target temperature for three minutes at full fan speed in the Thermal CruiseTM mode. 0: The SYSTIN temperature has not reached the warning range. 5 AUXTIN_STS. AUXTIN Temperature Sensor Status. 1: The temperature exceeds the over-temperature value. 0: The temperature is under the hysteresis value. -117- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT BIT DESCRIPTION 4 CASEOPEN_STS. CASEOPEN Status. 1: CASEOPEN is detected and latched. 0: CASEOPEN is not latched. 3 AUXFANIN0_STS. AUXFANIN0 Status. 1: The fan speed count is over the threshold value. 0: The fan speed count is in the allowed range. 2 CPUFANIN1_STS. CPUFANIN1 Status. 1: The fan speed count is over the threshold value. 0: The fan speed count is in the allowed range. 1 TAR4_STS. Smart Fan of CPUFANIN1 Warning Status. 1: The selected temperature has been over the target temperature for three minutes at full fan speed in Thermal CruiseTM mode. 0: The selected temperature has not reached the warning range. 0 VIN1_STS. VIN1 Voltage Status. 1: The VIN1 voltage is over or under the allowed range. 0: The VIN1 voltage is in the allowed range. 9.116 Attribute: Size: Real Time Hardware Status Register III - Index 5Bh (Bank 4) Read Only 8 bits BIT 7 6 5 4 3 2 1 0 NAME AUXFANIN1 _STS RESERVED VIN2 _STS VIN3 _STS RESERVED TAR3 _STS VBAT _STS VSB _STS DEFAULT 0 0 0 0 0 0 0 0 BIT DESCRIPTION 7 AUXFANIN1_STS. AIXFANIN1 Status. 1: The fan speed count is over the threshold value. 0: The fan speed count is in the allowed range. 6 RESERVED. 5 VIN2_STS. VIN2 Voltage Status. 1: The VIN2 voltage is over or under the allowed range. 0: The VIN2 voltage is in the allowed range. 4 VIN3_STS. VIN3 Voltage Status. 1: The VIN3 voltage is over or under the allowed range. 0: The VIN3 voltage is in the allowed range. 3 RESERVED. 2 TAR3_STS. Smart Fan of AUXFANIN Warning Status. 1: The selected temperature has been over the target temperature for three minutes at full fan speed in Thermal CruiseTM mode. 0: The selected temperature has not reached the warning range. 1 VBAT_STS. VBAT Voltage Status. -118- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT BIT DESCRIPTION 1: The VBAT voltage is over or under the allowed range. 0: The VBAT voltage is in the allowed range. 0 VSB_STS. 3VSB Voltage Status. 1: The 3VSB voltage is over or under the allowed range. 0: The 3VSB voltage is in the allowed range. 9.117 Reserved Register - Index 5Ch ~ 5Fh (Bank 4) 9.118 Value RAM 2 ⎯ Index 50h-59h (Bank 5) ADDRESS A6-A0 DESCRIPTION 50h 3VSB reading 51h VBAT reading. The reading is meaningless unless EN_VBAT_MN (Bank0 Index 5Dh, bit0) is set. 52h Reserved 53h AUXFANIN1 reading Note: This location stores the number of counts of the internal clock per revolution. 54h 3VSB High Limit 55h 3VSB Low Limit 56h VBAT High Limit 57h VBAT Low Limit 58h Reserved 59h Reserved 5Ah Reserved 5Bh Reserved 5Ch AUXFANIN1 Fan Count Limit Note: It is the number of counts of the internal clock for the Low Limit of the fan speed. 9.119 Attribute: Size: BIT SYSFANIN SPEED HIGH-BYTE VALUE (RPM) - Index 50h (Bank 6) Read/Write 8 bits 7 6 BIT 4 3 2 1 0 0 0 SYSFANIN SPEED HIGH-BYTE VALUE NAME DEFAULT 5 0 0 0 0 0 0 DESCRIPTION -119- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT BIT 7-0 DESCRIPTION SYSFANIN SPEED HIGH-BYTE VALUE. 9.120 SYSFANIN SPEED LOW-BYTE VALUE (RPM) - Index 51h (Bank 6) Attribute: Size: Read/Write 8 bits 7 BIT 6 5 DEFAULT 0 0 0 BIT 0 0 0 0 0 0 CPUFANIN0 SPEED HIGH-BYTE VALUE (RPM) - Index 52h (Bank 6) Read/Write 8 bits 7 BIT 6 5 4 3 2 1 0 0 0 CPUFANIN0 SPEED HIGH-BYTE VALUE NAME DEFAULT 0 0 0 BIT 0 0 0 DESCRIPTION CPUFANIN0 SPEED HIGH-BYTE VALUE. 9.122 CPUFANIN0 SPEED LOW-BYTE VALUE (RPM) - Index 53h (Bank 6) Attribute: Size: Read/Write 8 bits 7 BIT 6 5 4 3 2 1 0 0 0 CPUFANIN0 SPEED LOW-BYTE VALUE NAME DEFAULT 7-0 1 SYSFANIN SPEED LOW-BYTE VALUE. Attribute: Size: BIT 2 DESCRIPTION 9.121 7-0 3 SYSFANIN SPEED LOW-BYTE VALUE NAME 7-0 4 0 0 0 0 0 0 DESCRIPTION CPUFANIN0 SPEED LOW-BYTE VALUE. -120- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 9.123 AUXFANIN0 SPEED HIGH-BYTE VALUE (RPM) - Index 54h (Bank 6) Attribute: Size: Read/Write 8 bits 7 BIT 6 5 DEFAULT 0 0 0 BIT 0 0 0 0 0 0 AUXFANIN0 SPEED LOW-BYTE VALUE (RPM) - Index 55h (Bank 6) Read/Write 8 bits 7 BIT 6 5 4 3 2 1 0 0 0 AUXFANIN0 SPEED LOW-BYTE VALUE NAME DEFAULT 0 0 0 BIT 0 0 0 DESCRIPTION AUXFANIN0 SPEED LOW-BYTE VALUE. 9.125 CPUFANIN1 SPEED HIGH-BYTE VALUE (RPM) - Index 56h (Bank 6) Attribute: Size: Read/Write 8 bits 7 BIT 6 5 4 3 2 1 0 0 0 CPUFANIN1 SPEED HIGH-BYTE VALUE NAME DEFAULT 7-0 1 AUXFANIN0 SPEED HIGH-BYTE VALUE. Attribute: Size: BIT 2 DESCRIPTION 9.124 7-0 3 AUXFANIN0 SPEED HIGH-BYTE VALUE NAME 7-0 4 0 0 0 0 0 0 DESCRIPTION CPUFANIN1 SPEED HIGH-BYTE VALUE. -121- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 9.126 CPUFANIN1 SPEED LOW-BYTE VALUE (RPM) - Index 57h (Bank 6) Attribute: Size: Read/Write 8 bits 7 BIT 6 5 DEFAULT 0 0 0 BIT 0 0 0 0 0 0 AUXFANIN1 SPEED HIGH-BYTE VALUE (RPM) - Index 58h (Bank 6) Read/Write 8 bits 7 BIT 6 5 4 3 2 1 0 0 0 AUXFANIN1 SPEED HIGH-BYTE VALUE NAME DEFAULT 0 0 0 BIT 0 0 0 DESCRIPTION AUXFANIN1 SPEED HIGH-BYTE VALUE. 9.128 AUXFANIN1 SPEED LOW-BYTE VALUE (RPM) - Index 59h (Bank 6) Attribute: Size: Read/Write 8 bits 7 BIT 6 5 4 3 2 1 0 0 0 AUXFANIN1 SPEED LOW-BYTE VALUE NAME DEFAULT 7-0 1 CPUFANIN1 SPEED LOW-BYTE VALUE. Attribute: Size: BIT 2 DESCRIPTION 9.127 7-0 3 CPUFANIN1 SPEED LOW-BYTE VALUE NAME 7-0 4 0 0 0 0 0 0 DESCRIPTION AUXFANIN1 SPEED LOW-BYTE VALUE. -122- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 9.129 FANOUT Configure register of PECI Error - Index 5Ah (Bank 6) Attribute: Size: Read/Write 8 bits 7 BIT 6 5 4 3 2 Reserved. NAME 0 DEFAULT 0 1 0 PECI Error Condition 0 0 BIT 1 1 0 1 DESCRIPTION 7-3 Reserved. 2-0 PECI Error Condition Bits 210 0 0 0 : FANOUT keeps at its current value 1 1 1 : FANOUT will be set to the pre-configured value when PECI error. 9.130 FANCTRL2 pre-configured fan output value for PECI error - Index 5Bh (Bank 6) Attribute: Size: Read/Write 8 bits 7 BIT 6 5 4 3 2 1 0 1 1 FANCTRL2 pre-configured fan output value NAME 1 DEFAULT 1 FUNCTION MODE 1 7 DESCRIPTION PWM Output DEFAULT DESCRIPTION DC Output 1 6 1 5 1 4 3 2 1 0 FANCTRL2 PWM Duty Cycle. The PWM duty cycle is equal to this 8-bit value, divided by 255, times 100%. FFh creates a duty cycle of 100%, and 00h creates a duty cycle of 0%. 1 1 1 1 1 1 FANCTRL2 Voltage Control. The output voltage is calculated according to this equation: 1 1 Reserved FANOUT OUTPUT Voltage = AVCC * 64 DEFAULT 1 1 1 1 1 1 9.131 FANCTRL3 pre-configured fan output value for PECI error - Index 5Ch (Bank 6) Attribute: Read/Write -123- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT Size: 8 bits 7 BIT 6 5 4 3 2 1 0 1 1 FANCTRL3 pre-configured fan output value NAME 1 DEFAULT 1 FUNCTION MODE 1 7 DESCRIPTION PWM Output DEFAULT DESCRIPTION DC Output 1 6 1 5 1 4 3 2 1 0 FANCTRL3 PWM Duty Cycle. The PWM duty cycle is equal to this 8-bit value, divided by 255, times 100%. FFh creates a duty cycle of 100%, and 00h creates a duty cycle of 0%. 1 1 1 1 1 1 1 FANCTRL3 Voltage Control. The output voltage is calculated according to this equation: 1 Reserved FANOUT OUTPUT Voltage = AVCC * 64 DEFAULT 1 1 1 1 1 1 9.132 FANCTRL4 pre-configured fan output value for PECI error - Index 5Dh (Bank 6) Attribute: Size: Read/Write 8 bits BIT 7 6 4 3 2 1 0 1 1 FANCTRL4 pre-configured fan output value NAME DEFAULT 5 1 1 FUNCTION MODE 1 7 DESCRIPTION PWM Output DEFAULT DESCRIPTION DC Output 1 6 1 5 1 4 3 2 1 0 FANCTRL4 PWM Duty Cycle. The PWM duty cycle is equal to this 8-bit value, divided by 255, times 100%. FFh creates a duty cycle of 100%, and 00h creates a duty cycle of 0%. 1 1 1 1 1 1 FANCTRL4 Voltage Control. The output voltage is calculated according to this equation: 1 1 Reserved FANOUT OUTPUT Voltage = AVCC * 64 DEFAULT 1 1 1 1 1 1 9.133 FANCTRL5 pre-configured fan output value for PECI error - Index 5Eh (Bank 6) -124- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT Attribute: Size: Read/Write 8 bits 7 BIT 6 5 4 3 2 1 0 1 1 FANCTRL5 pre-configured fan output value NAME 1 DEFAULT 1 FUNCTION MODE 1 7 DESCRIPTION PWM Output DEFAULT DESCRIPTION DC Output 1 6 1 5 1 4 3 2 1 0 FANCTRL5 PWM Duty Cycle. The PWM duty cycle is equal to this 8-bit value, divided by 255, times 100%. FFh creates a duty cycle of 100%, and 00h creates a duty cycle of 0%. 1 1 1 1 1 1 1 FANCTRL5 Voltage Control. The output voltage is calculated according to this equation: 1 Reserved FANOUT OUTPUT Voltage = AVCC * 64 DEFAULT 1 1 1 1 1 1 9.134 FANCTRL6 pre-configured fan output value for PECI error - Index 5Fh (Bank 6) Attribute: Size: Read/Write 8 bits BIT 7 6 4 3 2 1 0 1 1 FANCTRL6 pre-configured fan output value NAME DEFAULT 5 1 1 FUNCTION MODE 1 7 DESCRIPTION PWM Output DEFAULT DESCRIPTION DC Output 1 6 1 5 1 4 3 2 1 0 FANCTRL6 PWM Duty Cycle. The PWM duty cycle is equal to this 8-bit value, divided by 255, times 100%. FFh creates a duty cycle of 100%, and 00h creates a duty cycle of 0%. 1 1 1 1 1 1 FANCTRL6 Voltage Control. The output voltage is calculated according to this equation: 1 1 Reserved FANOUT OUTPUT Voltage = AVCC * 64 DEFAULT 1 1 1 -125- 1 1 1 Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 10. SERIAL PERIPHERAL INTERFACE The W83627DHG-P provides a bridge of the Low Pin Count (LPC) Interface to Serial Peripheral Interface (SPI). The signals in the SPI are transmitted through Pin 2 (SCK), Pin 19 (SCE#), Pin 58 (SI), and Pin 118 (SO). In the Super I/O (W83627DHG-P), these 4 pins are multi-functional. The SPI functions are activated through strapping. Pin 52 determines whether to enable or disable the SPI functions. In the Super I/O (W83627DHG-P), the SPI functions are activated when Pin 52 is pulled-up to the power source. The function status can be seen/read at CR [24h], bit 1. The SPI is primarily used to store the BIOS ROM. When booting the computer, the memory read instructions or timing sequences are transmitted from the CPU, the South Bridge, the LPC bus to the Super I/O (W83627DHG-P). After receiving the instruction, the Super I/O (W83627DHG-P) generates and transmits the correct instructions and memory addresses to the SPI which responds with the corresponding data of the addresses. The data are placed to the LPC bus by the Super I/O (W83627DHG-P) and returned to the South Bridge. All of the data are read in this manner. By setting the registers shown at Table 10.3, the Super I/O (W83627DHG-P) supports all the instructions given, such as erase, read, program, to SPI flash. For more details, please see Table 10-2 SPI Address Map. To make it more user-friendly, regularly used SPI instructions/functions can be generated via the LPC I/O read/write commands. That is, the flash devices with SPI can be programmed, erased, or read on the motherboard. 10.1 Using the SPI Interface via the LPC z The allowed range is 8 bytes above the base address. The base address is configured at Configuration Register CR62h and CR63h in Logical Device 6. For example, if 03h is written to Configuration Register CR62h, and F8h to Configuration Register CR63h, 03F8h ~ 03FFh is the allowed range. Table 10-1 Base Address Setting LOGICAL DEVICE CONFIGURATION REGISTER BIT FUNCTION 6 62 7:0 High byte of Base Address 63 7:0 Low byte of Base Address z Functions and Definitions The functions and definitions of the 8 bytes are shown in the following table. Table 10-2 SPI Address Map Address Bit Function Description Base+0 7:0 CMD Commands or instructions of each SPI device 7:4 MODE Mode execution. Please see Table 10-3 MODE for the details of each mode. -126- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT Address Base+1 Bit Function Description 3:0 ADD2 Address [19:16] Base+2 7:0 ADD1 Address [15:8] Base+3 7:0 ADD0 Address [7:0] Base+4 7:0 DATA0 Data byte 0 Base+5 7:0 DATA1 Data byte 1 Base+6 7:0 DATA2 Data byte 2 Base+7 7:0 DATA3 Data byte 3 Usages z Write SPI instructions to Base+0. Set up the addresses and the data in Base+2 ~ Base+7. Implement the instruction by setting the instruction mode in Base+1. „ Accessing SPI Devices Take erasing the SPI for example, first write the “Chip Erase” instruction to Base+0 and 1Xh§1 to Base+1 (Bit3~Bit0 of Base +1 is the parameter of address [19:16].). The instruction modes are listed in the table below. For Mode 1, only a one-byte instruction is generated. For Mode 2, in addition to a one-byte instruction, a one-byte parameter, which is set up in Base+4 in advance, is also generated. §1 The “X” of 1X stands for the parameters of the address [19:16] (A19~A16, the most significant byte (MSB) of the address). Table 10-3 MODE MODE DEFINITION FUNCTION COMMAND EXAMPLE 1 CMD Command only Chip Enable, Write Enable, Write Disable 2 CMD_Da(1) Command with 1byte data write Write Status Register 3 CMD_Da(2) Command with 2bytes data read Read ID (Atmel®) 4 CMD_Add(3) Command with 3 bytes address Block Erase, Sector Erase 5 CMD_Ad(3)_Da(1)_W Command with 3bytes address and 1byte data read Byte Program (1 byte) 6 CMD_Ad(3)_Da(4)_W Command with 3bytes address and 4bytes data write Page Program (4 bytes) 7 CMD_Ad(4)_Da(4)_R Command with 3bytes and a dummy byte address and 4byte data read FAST READ (4 bytes) 8 CMD_Ad(3)_Da(1)_R Command with 3bytes address and 1byte data read READ, Read Status Read ID (ST/SST®) 9 CMD_Ad(3)_Da(2)_R Command with 3bytes address and Read ID (Nuvoton ®) -127- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT MODE DEFINITION FUNCTION COMMAND EXAMPLE 2bytes data read a CMD_Ad(3)_Da(3)_R Command with 3bytes address and 3bytes data read b CMD_Ad(3)_Da(4)_R Command with 3bytes address and 4 bytes data read Read ID (PMC®) „ Reading Data From SPI Devices First, write the “Read” instruction to Base+0. Then write the addresses to Base+2 ~ Base+3. Last, write 8X to Base+1. „ Programming SPI Devices First, write the “Byte Program” instruction to Base+0. Then write the addresses into Base+2 ~ Base+3 and parameters to Base+4. Last, write 5X to Base+1. For correct programming, make sure the state of the device is ready and write enabled. * For more details, please see the Programming Guide of the W83627DHG-P. -128- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 11. FLOPPY DISK CONTROLLER 11.1 FDC Functional Description The floppy disk controller (FDC) of the W83627DHG-P integrates all of the logic required for floppy disk control. The FDC implements a FIFO which provides better system performance in multi-master systems, and the digital data separator supports data rates up to 2 M bits/sec. The FDC includes the following blocks: Precompensation, Data Rate Selection, Digital Data Separator, FIFO, and FDC Core. The rest of this section discusses these blocks through the following topics: FIFO, Data Separator, Write Precompensation, Perpendicular Recording mode, FDC core, FDC commands, and FDC registers. 11.1.1 FIFO (Data) The FIFO is 16 bytes in size and has programmable threshold values. All command parameter information and disk data transfers go through the FIFO. Data transfers are governed by the RQM (Request for Master) and DIO (Data Input/Output) bits in the Main Status Register. The FIFO is defaulted to disabled mode after any form of reset, which maintains PC/AT hardware compatibility. The default values can be changed through the configure command. The advantage of the FIFO is that it lets the system have a larger DMA latency without causing disk errors. The following tables give several examples of the delays with the FIFO. The data are based upon the following formula: DELAY = THRESHOLD # x (1 / DATA RATE) * 8 - 1.5 μs Table 11-1 The Delays of the FIFO FIFO THRESHOLD MAXIMUM DELAY UNTIL SERVICING AT 500K BPS 1 Byte Data Rate 1 x 16μs - 1.5 μs = 14.5 μs 2 Byte 2 x 16 μs - 1.5 μs = 30.5 μs 8 Byte 8 x 16 μs - 1.5 μs = 6.5 μs 15 Byte 15 x 16 μs - 1.5 μs = 238.5 μs FIFO THRESHOLD MAXIMUM DELAY UNTIL SERVICING AT 1M BPS 1 Byte Data Rate 1 x 8 μs - 1.5 μs = 6.5 μs 2 Byte 2 x 8 μs - 1.5 μs = 14.5 μs 8 Byte 8 x 8 μs - 1.5 μs = 62.5 μs 15 Byte 15 x 8 μs - 1.5 μs = 118.5 μs -129- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT At the start of a command, the FIFO is always disabled, and command parameters must be sent based upon the RQM and DIO bit settings in the Main Status Register. When the FDC enters the command execution phase, it clears the FIFO off any data to ensure that invalid data are not transferred. An overrun or underrun terminates the current command and data transfer. Disk writes complete the current sector by generating a 00 pattern and valid CRC. Reads require the host to remove the remaining data so that the result phase may be entered. DMA transfers are enabled by the specify command and are initiated by the FDC when the LDRQ pin is activated during a data transfer command. 11.1.2 Data Separator The function of the data separator is to lock onto incoming serial read data. When a lock is achieved, the serial front-end logic in the chip is provided with a clock that is synchronized with the read data. The synchronized clock, called the Data Window, is used to internally sample the serial data portion of the bit cell, and the alternate state samples the clock portion. Serial-to-parallel conversion logic separates the read data into clock and data bytes. The Digital Data Separator (DDS) has three parts: control logic, error adjustment, and speed tracking. The control logic generates RDD and RWD for every pulse input, and any data pulse input is synchronized and then adjusted immediately by error adjustment. A digital integrator keeps track of the speed changes in the input data stream. 11.1.3 Write Precompensation The write precompensation logic minimizes bit shifts in the RDDATA stream from the disk drive. Shifting of bits is a known phenomenon in magnetic media and depends on the disk media and the floppy drive. The FDC monitors the bit stream that is being sent to the drive. The data patterns that require precompensation are well known, so, depending on the pattern, the bit is shifted either early or late, relative to the surrounding bits. 11.1.4 Perpendicular Recording Mode The FDC is also capable of interfacing directly to perpendicular recording floppy drives. Perpendicular recording differs from the traditional longitudinal method in that the magnetic bits are oriented vertically. This scheme packs more data bits into the same area. FDCs with perpendicular recording drives can read standard 3.5" floppy disks and can read and write perpendicular media. Some manufacturers offer drives that can read and write standard and perpendicular media in a perpendicular media drive. A single command puts the FDC into perpendicular mode. All other commands operate as they normally do. Perpendicular mode requires a 1 Mbps data rate for the FDC, and, at this data rate, the FIFO manages the host interface bottleneck due to the high speed of data transfer to and from the disk. -130- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 11.1.5 FDC Core The W83627DHG-P FDC is capable of performing twenty commands. Each command is initiated by a multi-byte transfer from the microprocessor, and the result may be a multi-byte transfer back to the microprocessor. Each command consists of three phases: command, execution, and result. Command The microprocessor issues all required information to the controller to perform a specific operation. Execution The controller performs the specified operation. Result After the operation is completed, status information and other housekeeping information are provided to the microprocessor. The next section introduces each of the commands. 11.1.6 FDC Commands Command Symbol Descriptions: C: Cylinder Number 0 - 256 D: Data Pattern DIR: Step Direction DIR = 0: step out DIR = 1: step in DS0: Disk Drive Select 0 DS1: Disk Drive Select 1 DTL: Data Length EC: Enable Count EFIFO: Enable FIFO EIS: Enable Implied Seek EOT: End of Track FIFOTHR: FIFO Threshold GAP: Gap Length Selection GPL: Gap Length H: Head Number HDS: Head Number Select HLT: Head Load Time HUT: Head Unload Time LOCK: Lock EFIFO, FIFOTHR, and PTRTRK bits to prevent being affected by software reset MFM: MFM or FM Mode MT: Multitrack N: The number of data bytes written in a sector NCN: New Cylinder Number ND: Non-DMA Mode OW: Overwritten PCN: Present Cylinder Number -131- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT POLL: PRETRK: R: RCN: R/W: SC: SK: SRT: ST0: ST1: ST2: ST3: WG: Polling Disable Precompensation Start Track Number Record Relative Cylinder Number Read/Write Sectors per Cylinder Skip deleted data address mark Step Rate Time Status Register 0 Status Register 1 Status Register 2 Status Register 3 Write gate alters timing of WE (1) Read Data PHASE R/W D7 D6 Command W MT MFM W 0 0 D5 D4 D3 D2 SK 0 0 1 0 0 0 D1 D0 1 0 Command codes HDS DS1 DS0 W W ---------------------- C --------------------------------------------- H ------------------------ W W ---------------------- R --------------------------------------------- N ------------------------ W W -------------------- EOT ------------------------------------------ GPL ----------------------- W -------------------- DTL ----------------------- Execution Result REMARKS Sector ID information prior to command execution Data transfer between the FDD and system R R R -------------------- ST0 ------------------------------------------ ST1 ------------------------------------------ ST2 ----------------------- Status information after command execution R R R R ---------------------- C --------------------------------------------- H --------------------------------------------- R --------------------------------------------- N ------------------------ Sector ID information after command execution -132- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT (2) Read Deleted Data PHASE R/W D7 D6 Command W MT MFM W 0 0 D5 D4 D3 D2 D1 D0 SK 0 1 1 0 0 0 0 0 Command codes HDS DS1 DS0 W W ---------------------- C --------------------------------------------- H ------------------------ W W ---------------------- R --------------------------------------------- N ------------------------ W W -------------------- EOT ------------------------------------------ GPL ----------------------- W -------------------- DTL ----------------------- Execution Result REMARKS Sector ID information prior to command execution Data transfer between the FDD and system R R R -------------------- ST0 ------------------------------------------ ST1 ------------------------------------------ ST2 ----------------------- Status information after command execution R R R R ---------------------- C --------------------------------------------- H --------------------------------------------- R --------------------------------------------- N ------------------------ Sector ID information after command execution -133- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT (3) Read A Track D7 PHASE R/W Command W 0 W 0 D6 MFM 0 D5 D4 D3 D2 D1 D0 0 0 0 0 1 0 0 0 0 Command codes HDS DS1 DS0 W W ---------------------- C --------------------------------------------- H ------------------------ W W ---------------------- R --------------------------------------------- N ------------------------ W W -------------------- EOT ------------------------------------------ GPL ----------------------- W -------------------- DTL ----------------------- Sector ID information prior to command execution Execution Result REMARKS Data transfer between the FDD and system; FDD reads contents of all cylinders from index hole to EOT R R R -------------------- ST0 ------------------------------------------ ST1 ------------------------------------------ ST2 ----------------------- Status information after command execution R R R R ---------------------- C --------------------------------------------- H --------------------------------------------- R --------------------------------------------- N ------------------------ Sector ID information after command execution (4) Read ID PHASE Command R/W W W D7 0 0 D6 MFM 0 D5 D4 D3 0 0 0 0 1 0 D2 D1 D0 0 1 0 HDS DS1 DS0 Execution Result REMARKS Command codes The first correct ID information on the cylinder is stored in the Data Register R R R R R R R -------------------- ST0 ------------------------------------------ ST1 ------------------------------------------ ST2 -------------------------------------------- C --------------------------------------------- H --------------------------------------------- R --------------------------------------------- N ------------------------ -134- Status information after command execution Disk status after the command has been completed Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT (5) Verify PHASE Command R/W W W W W W W W W D7 D6 D5 D4 D3 D2 D1 D0 MT MFM SK 1 0 1 1 0 EC 0 0 0 0 HDS DS1 DS0 ---------------------- C --------------------------------------------- H --------------------------------------------- R --------------------------------------------- N ------------------------------------------- EOT ------------------------------------------ GPL ------------------------------------------ DTL/SC ------------------- Execution Result REMARKS Command codes Sector ID information prior to command execution No data transfer takes place Status information after command execution -------------------- ST0 ------------------------------------------ ST1 ------------------------------------------ ST2 -------------------------------------------- C --------------------------------------------- H --------------------------------------------- R --------------------------------------------- N ------------------------ R R R R R R R Sector ID information after command execution (6) Version PHASE R/W D7 D6 D5 D4 D3 D2 D1 D0 REMARKS Command W 0 0 0 1 0 0 0 0 Command code Result R 1 0 0 1 0 0 0 0 Enhanced controller -135- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT (7) Write Data PHASE Command R/W D7 D6 D5 D4 D3 D2 D1 D0 1 0 1 W MT MFM 0 0 0 W 0 0 0 0 0 Command codes HDS DS1 DS0 W W ---------------------- C --------------------------------------------- H ------------------------ Sector ID information prior to Command execution W W ---------------------- R --------------------------------------------- N ------------------------ W W -------------------- EOT ------------------------------------------ GPL ----------------------- W -------------------- DTL ----------------------- Execution Result REMARKS Data transfer between the FDD and the system R R R -------------------- ST0 ------------------------------------------ ST1 ------------------------------------------ ST2 ----------------------- Status information after Command execution R R R R ---------------------- C --------------------------------------------- H --------------------------------------------- R --------------------------------------------- N ------------------------ Sector ID information after Command execution (8) Write Deleted Data PHASE R/W Command W W D7 D6 D5 D4 D3 D2 D1 D0 MT MFM 0 0 1 0 0 1 0 0 0 0 0 Command codes HDS DS1 DS0 W W ---------------------- C --------------------------------------------- H ------------------------ Sector ID information prior to command execution W W ---------------------- R --------------------------------------------- N ------------------------ W W W -------------------- EOT ------------------------------------------ GPL ------------------------------------------ DTL ----------------------- Execution Result REMARKS Data transfer between the FDD and the system R R R -------------------- ST0 ------------------------------------------ ST1 ------------------------------------------ ST2 ----------------------- Status information after command execution R R R R ---------------------- C --------------------------------------------- H --------------------------------------------- R --------------------------------------------- N ------------------------ Sector ID information after command execution -136- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT (9) Format A Track PHASE Command R/W D7 D6 D5 D4 D3 D2 D1 D0 1 0 1 W 0 MFM 0 0 1 W 0 0 0 0 0 REMARKS Command codes HDS DS1 DS0 W W ---------------------- N -------------------------------------------- SC ----------------------- Bytes per Sector Sectors per Cylinder W W --------------------- GPL ------------------------------------------ D ------------------------ Gap 3 Filler Byte Execution for Each Sector: (Repeat) W W W W ---------------------- C --------------------------------------------- H --------------------------------------------- R --------------------------------------------- N ------------------------ Input Sector Parameters Result R R R -------------------- ST0 ------------------------------------------ ST1 ------------------------------------------ ST2 ----------------------- Status information after command execution R R R R ---------------- Undefined ---------------------------------- Undefined ---------------------------------- Undefined ---------------------------------- Undefined ------------------- (10) Recalibrate PHASE R/W Command W W D7 D6 D5 D4 D3 D2 D1 D0 0 0 0 0 0 1 1 1 0 0 0 0 0 0 REMARKS Command codes DS1 DS0 Execution Head retracted to Track 0 Interrupt (11) Sense Interrupt Status PHASE R/W Command W Result R R D7 0 D6 0 D5 D4 D3 D2 D1 D0 0 0 1 0 0 0 ---------------- ST0 ---------------------------------------- PCN ------------------------- REMARKS Command code Status information at the end of each seek operation (12) Specify PHASE Command R/W D7 D6 0 D5 0 D4 D3 D2 D1 D0 0 0 0 1 1 W 0 W W | ---------SRT ----------- | --------- HUT ---------- | |------------ HLT ----------------------------------| ND -137- REMARKS Command codes Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT (13) Seek PHASE R/W Command Execution D7 W 0 W W 0 D6 0 D5 D4 D3 D2 D1 D0 0 0 1 1 1 1 REMARKS Command codes 0 0 0 0 HDS DS1 DS0 -------------------- NCN ----------------------- R Head positioned over proper cylinder on the diskette (14) Configure PHASE Command R/W D7 D6 D5 D4 D3 D2 D1 D0 0 0 1 0 0 1 1 W 0 W W W 0 0 0 0 0 0 0 0 0 EIS EFIFO POLL | ------ FIFOTHR ----| | --------------------PRETRK ----------------------- | Execution REMARKS Configure information Internal registers written (15) Relative Seek PHASE Command R/W D7 D6 DIR D5 D4 D3 D2 D1 D0 0 0 1 1 1 1 W 1 W W 0 0 0 0 0 HDS DS1 DS0 | -------------------- RCN ---------------------------- | REMARKS Command codes (16) Dumpreg PHASE R/W Command W Result R R R R R R R R R R D7 0 D6 0 D5 0 D4 D3 D2 D1 D0 0 1 1 1 0 REMARKS Registers placed in FIFO ----------------------- PCN-Drive 0------------------------------------------ PCN-Drive 1 ----------------------------------------- PCN-Drive 2------------------------------------------ PCN-Drive 3 --------------------------SRT ------------------ | --------- HUT ------------------ HLT -----------------------------------| ND ------------------------ SC/EOT ---------------------LOCK 0 D3 D2 D1 D0 GAP WG 0 EIS EFIFO POLL | ------ FIFOTHR ------------------------------PRETRK ------------------------- (17) Perpendicular Mode PHASE Command R/W W W D7 0 OW D6 0 0 D5 0 D3 D4 D3 1 D2 0 D1 D2 D1 D0 0 1 0 D0 GAP WG -138- REMARKS Command Code Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT (18) Lock PHASE R/W Command W Result R D7 D6 LOCK 0 0 0 D5 D4 D3 D2 D1 D0 0 1 0 1 0 0 0 LOCK 0 0 0 0 D3 D2 D1 D0 REMARKS Command Code (19) Sense Drive Status PHASE R/W Command W W Result R D7 0 0 D6 0 0 D5 D4 0 0 0 0 0 1 0 0 0 HDS DS1 DS0 ---------------- ST3 ------------------------- REMARKS Command Code Status information about the disk drive (20) Invalid PHASE R/W D7 D6 D5 D4 D3 D2 D1 D0 Command W ------------- Invalid Codes ----------------- Result R -------------------- ST0 ---------------------- -139- REMARKS Invalid codes (no operationFDC goes to standby state) ST0 = 80h Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 11.2 Register Descriptions There are several status, data, and control registers in the W83627DHG-P. These registers are defined below, and the rest of this section provides more details about each one of them. Table 11-2 FDC Registers ADDRESS REGISTER OFFSET READ WRITE base address + 0 base address + 1 base address + 2 base address + 3 base address + 4 base address + 5 base address + 7 SA REGISTER SB REGISTER DO REGISTER TD REGISTER DR REGISTER DT (FIFO) REGISTER CC REGISTER TD REGISTER MS REGISTER DT (FIFO) REGISTER DI REGISTER 11.2.1 Status Register A (SA Register) (Read base address + 0) Along with the SB register, the SA register is used to monitor several disk-interface pins in PS/2 and Model 30 modes. In PS/2 mode, the bit definitions for this register are as follows: BIT 7 6 5 4 3 2 1 0 NAME INIT PEDNDING RESERVED STEP TRAK0# HEAD INDEX# WP# DIR DEFAULT 0 0 NA 1 NA 1 1 NA BIT DESCRIPTION 7 INIT PENDING. This bit indicates the value of the floppy disk interrupt output. 6 RESERVED. 5 STEP. This bit indicates the complement of the STEP# output. 4 TRAK0#. This bit indicates the value of the TRAK0# input. 3 HEAD. This bit indicates the complement of the HEAD# output. 0: Side 0. 1: Side 1. 2 INDEX#. This bit indicates the value of INDEX# output. 1 WP#. 0: The disk is write-protected. 1: The disk is not write-protected. 0 DIR. This bit indicates the direction of head movement. 0: Outward direction. 1: Inward direction. -140- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT In PS/2 Model 30 mode, the bit definitions for this register are as follows: BIT 7 6 5 4 3 2 1 0 NAME INIT PENDING DRQ STEP F/F TRAK0# HEAD# INDEX WP DIR# DEFAULT 0 0 NA 0 NA 0 0 NA BIT DESCRIPTION 7 INIT PENDING. This bit indicates the value of the floppy disk interrupt output. 6 DRQ. This bit indicates the value of the DRQ output pin. 5 STEP F/F. This bit indicates the complement of the latched STEP# output. 4 TRAK0. This bit indicates the complement of the TRAK0# input. 3 HEAD#. This bit indicates the value of the HEAD# value. 0: Side 1. 1: Side 0. 2 INDEX. This bit indicates the complement of the INDEX output. 1 WP. 0: The disk is not write-protected. 1: The disk is write-protected. 0 DIR#. This bit indicates the direction of head movement. 0: Inward direction. 1: Outward direction. 11.2.2 Status Register B (SB Register) (Read base address + 1) Along with the SA register, the SB register is used to monitor several disk interface pins in PS/2 and Model 30 modes. In PS/2 mode, the bit definitions for this register are as follows: 7 BIT 6 NAME DEFAULT 1 BIT 7-6 1 5 4 3 2 1 0 DRIVE SEL0 WDATA TOGGLE RDATA TOGGLE WE RESERVED MOT EN A 0 0 0 0 0 0 DESCRIPTION RESERVED. 5 DRIVE SEL0. This bit indicates the status of the DO REGISTER, bit 0 (drive-select bit 0). 4 WDATA TOGGLE. This bit changes state on every rising edge of the WD# output pin. 3 RDATA TOGGLE. This bit changes state on every rising edge of the RDATA# output pin. 2 WE. This bit indicates the complement of the WE# output pin. 1 RESERVED. 0 MOT EN A. This bit indicates the complement of the MOA# output pin. -141- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT In PS/2 Model 30 mode, the bit definitions for this register are as follows: 7 BIT 6 RESERVED NAME DEFAULT 0 1 5 4 3 2 DSA# WD F/F RDATA F/F WE F/F 1 0 0 0 BIT 7-6 1 0 RESERVED 1 1 DESCRIPTION RESERVED. 5 DSA#. This bit indicates the status of the DSA# output pin. 4 WD F/F. This bit indicates the complement of the WD# output pin, which is latched on every rising edge of the WD# output pin. 3 RDATA F/F. This bit indicates the complement of the latched RDATA# output pin. 2 1-0 WE F/F. This bit indicates the complement of the latched WE# output pin. RESERVED. 11.2.3 Digital Output Register (DO Register) (Write base address + 2) The Digital Output Register is a write-only register that controls drive motors, drive selection, DRQ/IRQ enable, and FDC reset. The bit definitions are as follows: 7 BIT 6 NAME DEFAULT 0 0 BIT 7-5 5 RESERVED 0 4 3 2 MOTOR ENABLE A DMA & INT ENABLE FDC RESET 0 0 0 1 0 0 DESCRIPTION RESERVED. 4 MOTOR ENABLE A. Motor A on when active high. 3 DMA & INT ENABLE. An active high signal enables DRQ/IRQ. 2 FDC RESET. Floppy Disk Controller Reset. An active low signal resets the FDC. 1-0 0 DRIVE SELECT DRIVE SELECT. Bits 10 0 0: Select Drive A. 0 1: Reserved. 1 0: Reserved. 1 1: Reserved. -142- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 11.2.4 Tape Drive Register (TD Register) (Read base address + 3) This register is used to assign a particular drive number to the tape drive support mode of the data separator. This register also holds the media ID, drive type, and floppy boot drive information for the floppy disk drive. In normal floppy mode, this register only has bits 0 and 1, and the bit definitions are as follows: 7 BIT 6 5 4 3 2 RESERVED NAME NA DEFAULT NA NA NA BIT NA NA 1 0 TAPE SEL 1 TAPE SEL 0 0 0 DESCRIPTION 7-2 RESERVED. 1 TAPE SEL 1. 0 TAPE SEL 0. If the three-mode FDD function is enabled (EN3MODE = 1 in LD0 CRF0, Bit 0), the bit definitions are as follows: BIT 7 6 5 4 3 2 1 0 NAME MEDIA ID1 MEDIA ID0 DRIVE TYPE ID1 DRIVE TYPE ID0 FLOPPY BOOT DRIVE 1 FLOPPY BOOT DRIVE 0 TAPE SEL1 TAPE SEL0 DEFAULT 0 0 1 1 0 0 0 0 BIT DESCRIPTION 7 MEDIA ID1. 6 MEDIA ID0. 5 DRIVE TYPE ID1. 4 DRIVE TYPE ID0. 3 FLOPPY BOOT DRIVE 1. 2 FLOPPY BOOT DRIVE 0. 1 TAPE SEL 1. 0 TAPE SEL 0. These two bits are read-only. These two bits reflect the value of LD0, CR [F1h], bits 5 and 4. These two bits reflect two of the bits in LD0, CR [F2h]. Which two bits are reflected depends on the last drive selection in the DO register. These two bits reflect the value of LD0, CR [F1h], bits 7 and 8. These two bits assign a logical drive number to the tape drive. Drive 0 is not available as a tape drive and is reserved for the floppy disk boot drive. TAPE SEL 1 TAPE SEL 0 DRIVE SELECTED 0 0 0 1 None 1 -143- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT TAPE SEL 1 TAPE SEL 0 DRIVE SELECTED 1 1 0 1 2 3 11.2.5 Main Status Register (MS Register) (Read base address + 4) The Main Status Register is used to control the flow of data between the microprocessor and the controller. The bit definitions for this register are as follows: BIT 7 6 5 4 NAME RQM DIO NON-DMA MODE CB DEFAULT 0 NA NA NA 3 2 1 RESERVED NA NA 0 FDD 0 BUSY NA NA BIT DESCRIPTION 7 RQM. Request for Master. A high on this bit indicates Data Register is ready to send or receive data to or from the processor. 6 DIO. Data Input/Output. If DIO= HIGH, the transfer is from Data Register to the processor. If DIO=LOW, the transfer is from the processor to Data Register. 5 NON-DMA MODE. The FDC is in the non-DMA mode. This bit is set only during the execution phase in the non-DMA mode. Transition to LOW state indicates execution phase has ended. 4 CB. FDC Busy. A read or write command is in the process when CB = HIGH. 3-1 0 RESERVED. FDD0 BUSY. (D0B = 1). FDD number 0 is in the SEEK mode. 11.2.6 Data Rate Register (DR Register) (Write base address + 4) The Data Rate Register is used to set the transfer rate and write precompensation. However, in PCAT and PS/2 Model 30 and PS/2 modes, the data rate is controlled by the CC register, not by the DR register. As a result, the real data rate is determined by the most recent write to either the DR or CC register. The bit definitions for this register are as follows: BIT 7 6 5 4 3 2 1 0 NAME S/W RESET POWER DOWN RESERVED PRECOMP 2 PRECOMP 1 PRECOMP 0 DRATE 1 DRATE 0 DEFAULT 0 0 0 0 0 0 1 0 BIT DESCRIPTION 7 S/W RESET. This bit is the software reset bit. 6 POWER DOWN. 0: The FDC is in the normal mode. 1: The FDC is in the power-down mode. 5 RESERVED. 4 PRECOMP 2. These three bits select the value of write -144- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT BIT DESCRIPTION 3 PRECOMP 1. 2 PRECOMP 0. 1 DRATE 1. 0 DRATE 0. PRECOMP 2 1 0 0 0 0 0 0 1 0 1 0 0 1 1 1 0 0 1 0 1 1 1 0 1 1 1 precompensation. The following tables show the precompensation values for every combination of these bits. These two bits select the data rate of the FDC and reduced write-current control. Bits 10 0 0: 500 KB/S (MFM), 250 KB/S (FM), RWC# = 1 0 1: 300 KB/S (MFM), 150 KB/S (FM), RWC# = 0 1 0: 250 KB/S (MFM), 125 KB/S (FM), RWC# = 0 1 1: 1 MB/S (MFM), Illegal (FM), RWC# = 1 The 2 MB/S data rate for the tape drive is only supported by setting DRATE1 and DRATE0 to 01, as well as setting DRT1 and DRT0 (CR [F4h] and CR [F5h] for logical device 0) to 10. Please see the functional description of CR [F4h] or CR [F5h] and the data rate table for individual data-rate settings. PRECOMPENSATION DELAY 250K - 1 Mbps Default Delays 41.67 ns 83.34 ns 125.00 ns 166.67 ns 208.33 ns 250.00 ns 0.00 ns (disabled) 2 Mbps Tape drive Default Delays 20.8 ns 41.17 ns 62.5ns 83.3 ns 104.2 ns 125.00 ns 0.00 ns (disabled) DATA RATE DEFAULT PRECOMPENSATION DELAYS 250 KB/S 300 KB/S 500 KB/S 1 MB/S 2 MB/S 125 ns 125 ns 125 ns 41.67ns 20.8 ns -145- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 11.2.7 FIFO Register (R/W base address + 5) The FIFO register consists of four status registers in a stack, and only one register is presented to the data bus at a time. The FIFO register stores data, commands, and parameters, and it provides diskdrive status information. In addition, data bytes pass through the data register to program or obtain results after a command. In the W83627DHG-P, this register is disabled after reset. The FIFO can enable it and change its values through the configure command. Status Register 0 (ST0) BIT NAME 7 6 IC BIT 7-6 5 4 3 2 1 0 SE EC NR HD US1 DRIVE SELECT US0 DRIVE SELECT DESCRIPTION IC. Interrupt Code. Bits 76 0 0: Normal termination of command. 0 1: Abnormal termination of command. 1 0: Invalid command issue. 1 1: Abnormal termination because the ready signal from FDD changes state during command execution. 5 SE. Seek Mode. 1: Seek end. 0: Seek error. 4 EC. Equipment Check. 1: When a fault signal is received form the FDD or the track. 0: The signal fails to occur after 77 step pulses. 3 NR. Not Ready. 0: Drive is not ready. 1: Drive is ready. 2 HD. Head Address. 0: Head selected. 1: Head selected. 1 US1 DRIVE SELECT. 0 US0 DRIVE SELECT. Drive Select. Bits 10 0 0: Drive A selected. 0 1: Reserved. 1 0: Reserved. 1 1: Reserved. -146- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT Status Register 1 (ST1) BIT 7 6 5 4 3 2 1 0 NAME EN RESERVED DE OR RESERVED ND NW MAM BIT DESCRIPTION 7 EN. End of track. 1 when the FDC tries to access a sector beyond the final sector of a cylinder 6 RESERVED. This bit is always 0. 5 DE. Data Error. 1 when the FDC detects a CRC error in either the ID field or the data filed. 4 OR. Over Run. 1 if the FDC is not served by the host system within a certain time interval during data transfer. 3 RESERVED. This bit is always 0. 2 ND (No Data). 1 if the specified sector cannot be found during execution of a read, write or verify data. 1 NW. Not Writable. 1 if a write protect signal is detected from the diskette drive during execution of write data. 0 MAM. Missing Address Mark. 1 when the FDC cannot detect the data address mark or the data address mark has been deleted. Status Register 2 (ST2) BIT 7 6 5 4 3 2 1 0 NAME RESERVED CM DD WC SH SN BC MD BIT DESCRIPTION 7 RESERVED. This bit is always 0. 6 CM. Control Mark. 1: During execution of the read data or scan command. 0: No error. 5 DD. Data Error in the Data Field. 1: If the FDC detects a CRC error in the data field. 0: No error. 4 WC. Wrong Cylinder. 1 indicates wrong cylinder. 3 SH. Scan Equal Hit. 1: During execution of the Scan command, if the equal condition is satisfied. 0: No error. 2 SN. Scan Not Satisfied. 1: During execution of the Scan command. 0: No error. 1 BC. Bad Cylinder. 1: Bad Cylinder. -147- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT BIT DESCRIPTION 0: No error. 0 MD. Missing Address Mark in Data Field. 1: If the FDC cannot find a data address mark (or the address mark has been deleted) when reading data from the media. 0: No error. Status Register 3 (ST3) BIT 7 6 5 4 3 2 1 0 NAME FT WP RY T0 TS HD US1 US0 BIT DESCRIPTION 7 FT. Fault. 6 WP. Write Protected. 5 RY. Ready. 4 T0. Track 0. 3 TS. Two-Side. 2 HD. Head Address. 1 US1. Unit Select 1. 0 US0. Unit Select 0. 11.2.8 Digital Input Register (DI Register) (Read base address + 7) The Digital Input Register is an 8-bit, read-only register used for diagnostic purposes. In PC/XT or PC/AT mode, only bit 7 is checked by the BIOS. When the register is read, bit 7 shows the complement of DSKCHG#, while the other bits remain in tri-state. The bit definitions are as follows: BIT 7 NAME DSKCHG DEFAULT 0 BIT 7 6-0 6 5 4 3 2 1 0 NA NA NA RESERVED NA NA NA NA DESCRIPTION DSKCHG. RESERVED. Reserved for the hard disk controller. During a read of this register, these bits are in tri-state. -148- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT In PS/2 mode, the bit definitions are as follows: BIT 7 NAME DSKCHG DEFAULT 0 6 5 6-3 3 RESERVED 1 1 BIT 7 4 1 1 2 1 0 DRATE1 DRATE0 HIGH DENS# 1 0 1 DESCRIPTION DSKCHG. This bit indicates the complement of the DSKCHG# input. RESERVED. These bits are always logic 1 during a read. These two bits select the data rate of the FDC. See DR register bits 1 and 0 (Data Rate Register (DR Register) (Write base address + 4)) for how the settings correspond to individual data rates. 2 DRATE1. 1 DRATE0. 0 HIGH DENS#. 0: 500 KB/S or 1 MB/S data rate (high-density FDD). 1: 250 KB/S or 300 KB/S data rate. In PS/2 Model 30 mode, the bit definitions are as follows: BIT 7 NAME DSKCHG# DEFAULT 1 BIT 7 6-4 6 5 4 RESERVED 0 0 0 3 2 1 0 DMAEN NOPREC DRATE1 DRATE0 0 0 1 0 DESCRIPTION DSKCHG#. This bit indicates the status of the DSKCHG# input. RESERVED. These bits are always a logic 0 during a read. 3 DMAEN. This bit indicates the value of DO register, bit 3. 2 NOPREC. This bit indicates the value of the NOPREC bit in the CC REGISTER. 1 DRATE1. 0 DRATE0. These two bits select the data rate of the FDC. See DR register bits 1 and 0 (Data Rate Register (DR Register) (Write base address + 4)) for how the settings correspond to individual data rates. -149- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 11.2.9 Configuration Control Register (CC Register) (Write base address + 7) This register is used to control the data rate. In PC/AT and PS/2 mode, the bit definitions are as follows: 7 BIT 6 5 3 2 RESERVED NAME DEFAULT NA NA NA BIT 7-2 4 NA NA NA 1 0 DRATE1 DRATE0 1 0 DESCRIPTION RESERVED. These bits should be set to 0. 1 DRATE1. 0 DRATE0. These two bits select data rate of the FDC. See DR register bits 1 and 0 (Data Rate Register (DR Register) (Write base address + 4)) for how the settings correspond to individual data rates. In the PS/2 Model 30 mode, the bit definitions are as follows: 7 BIT 6 4 3 RESERVED NAME DEFAULT NA BIT 7-3 5 NA NA NA NA 2 1 0 NOPREC DRATE1 DRATE0 0 1 0 DESCRIPTION RESERVED. These bits should be set to 0. 2 NOPREC. This bit disables the precompensation function. It can be set by the software. 1 DRATE1. 0 DRATE0. These two bits select the data rate of the FDC. See DR register bits 1 and 0 (Data Rate Register (DR Register) (Write base address + 4)) for how the settings correspond to individual data rates. -150- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 12. UART PORT 12.1 Universal Asynchronous Receiver/Transmitter (UART A, UART B) The UARTs are used to convert parallel data into serial format for transmission and to convert serial data into parallel format during reception. The serial data format is a start bit, followed by five to eight data bits, a parity bit (if programmed) and one, one-and-a-half (five-bit format only) or two stop bits. The UARTs are capable of handling divisors of 1 to 65535 and producing a 16x clock for driving the internal transmitter logic. Provisions are also included to use this 16x clock to drive the receiver logic. The UARTs also support the MIDI data rate. Furthermore, the UARTs also include a complete modem control capability and 16-byte FIFOs for reception and transmission to reduce the number of interrupts presented to the CPU. 12.2 Register Description 12.2.1 UART Control Register (UCR) (Read/Write) The UART Control Register defines and controls the protocol for asynchronous data communication, including data length, stop bit, parity, and baud rate selection. BIT 7 6 5 4 3 2 1 0 NAME BDLAB SSE PBFE EPE PBE MSBE DLS1 DLS0 DEFAULT 0 0 0 0 0 0 0 0 BIT DESCRIPTION 7 BDLAB. Baudrate Divisor Latch Access Bit. When this bit is set to logical 1, designers can access the divisor (in 16-bit binary format) from the divisor latches of the baud-rate generator during a read or write operation. When this bit is set to logical 0, the Receiver Buffer Register, the Transmitter Buffer Register, and the Interrupt Control Register can be accessed. 6 SSE. Set Silence Enable. A logical 1 forces the Serial Output (SOUT) to a silent state (a logical 0). Only IRTX is affected by this bit; the transmitter is not affected. 5 PBFE. Parity Bit Fixed Enable. When PBE and PBFE of UCR are both set to logical 1, (1) If EPE is logical 1, the parity bit is fixed at logical 0 when transmitting and checking. (2) If EPE is logical 0, the parity bit is fixed at logical 1 when transmitting and checking. 4 EPE. Even Parity Enable. When PBE is set to logical 1, this bit counts the number of logical 1’s in the data word bits and determines the parity bit. When this bit is set to logical 1, the parity bit is set to logical 1 if an even number of logical 1’s are sent or checked. When the bit is set to logical 0, the parity bit is logical 1 if an odd number of logic 1’s are sent or checked. 3 PBE. Parity Bit Enable. When this bit is set to logical 1, the transmitter inserts a stop bit between the last data bit and the stop bit of the SOUT, and the receiver checks the parity bit in the same position. 2 MSBE. Multiple Stop Bits Enable. This bit defines the number of stop bits in each serial character that is transmitted or received. (1) If MSBE is set to logical 0, one stop bit is sent and checked. (2) If MSBE is set to logical 1 and the data length is 5 bits, one-and-a-half stop bits are sent and checked. (3) If MSBE is set to logical 1 and the data length is 6, 7 or 8 bits, two stop bits are sent -151- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT BIT DESCRIPTION and checked. 1 DLS1. Data Length Select Bit 1. 0 DLS0. Data Length Select Bit 0. These two bits define the number of data bits that are sent or checked in each serial character. DLS1 DLS0 DATA LENGTH 0 0 5 bits 0 1 6 bits 1 0 7 bits 1 1 8 bits The following table identifies the remaining UART registers. Each one is described separately in the following sections. -152- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT Table 12-1 Register Summary for UART Bit Number Register Address Base 0 1 2 3 4 5 6 7 +0 BDLAB = 0 Receiver Buffer Register (Read Only) RBR RX Data Bit 0 RX Data Bit 1 RX Data Bit 2 RX Data Bit 3 RX Data Bit 4 RX Data Bit 5 RX Data Bit 6 RX Data Bit 7 +0 BDLAB = 0 Transmitter Buffer Register (Write Only) TBR TX Data Bit 0 TX Data Bit 1 TX Data Bit 2 TX Data Bit 3 TX Data Bit 4 TX Data Bit 5 TX Data Bit 6 TX Data Bit 7 +1 Interrupt Control Register BDLAB = 0 ICR RBR Data Ready Interrupt Enable (ERDRI) TBR Empty Interrupt Enable (ETBREI) USR Interrupt Enable (EUSRI) HSR Interrupt Enable (EHSRI) 0 0 0 0 FIFOs Enabled ** FIFOs Enabled ** +2 Interrupt Status Register (Read Only) ISR "0" if Interrupt Pending Interrupt Status Bit (0) Interrupt Status Bit (1) Interrupt Status Bit (2)** 0 0 +2 UART FIFO Control Register (Write Only) UFR FIFO Enable RCVR FIFO Reset XMIT FIFO Reset DMA Mode Select Reserved Reversed +3 UART Control Register UCR Data Length Select Bit 0 (DLS0) Data Length Select Bit 1 (DLS1) Multiple Stop Bits Enable (MSBE) Parity Bit Enable (PBE) Even Parity Enable (EPE) Parity Bit Fixed Enable PBFE) Set Silence Enable (SSE) Baudrate Divisor Latch Access Bit (BDLAB) +4 Handshake Control Register HCR Data Terminal Ready (DTR) Request to Send (RTS) Loopback RI Input IRQ Enable Internal Loopback Enable 0 0 0 +5 UART Status Register USR RBR Data Ready (RDR) Overrun Error (OER) Parity Bit Error (PBER) No Stop Bit Error (NSER) Silent Byte Detected (SBD) TBR Empty (TBRE) TSR Empty (TSRE) RX FIFO Error Indication (RFEI) ** +6 Handshake Status Register HSR CTS Toggling (TCTS) DSR Toggling (TDSR) RI Falling Edge (FERI) DCD Toggling (TDCD) Clear to Send (CTS) Data Set Ready (DSR) Ring Indicator (RI) Data Carrier Detect (DCD) +7 User Defined Register UDR Bit 0 Bit 1 Bit 2 Bit 3 Bit 4 Bit 5 Bit 6 Bit 7 +0 BDLAB = 1 Baudrate Divisor Latch Low BLL Bit 0 Bit 1 Bit 2 Bit 3 Bit 4 Bit 5 Bit 6 Bit 7 +1 BDLAB = 1 Baudrate Divisor Latch High BHL Bit 8 Bit 9 Bit 10 Bit 11 Bit 12 Bit 13 Bit 14 Bit 15 RX RX Interrupt Interrupt Active Level Active Level (LSB) (MSB) *: Bit 0 is the least significant bit. The least significant bit is the first bit serially transmitted or received. **: These bits are always 0 in 16450 Mode. -153- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 12.2.2 UART Status Register (USR) (Read/Write) This 8-bit register provides information about the status of data transfer during communication. BIT 7 6 5 4 3 2 1 0 NAME RFEI TSRE TBRE SBD NSER PBER OER RDR DEFAULT 0 1 1 0 0 0 0 0 BIT DESCRIPTION 7 RFEI. RX FIFO Error Indication. In 16450 mode, this bit is always set to logical 0. In 16550 mode, this bit is set to logical 1 when there is at least one parity-bit error and no stop-bit error or silent-byte detected in the FIFO. In 16550 mode, this bit is cleared to logical 0 by reading from the USR if there are no remaining errors left in the FIFO. 6 TSRE. Transmitter Shift Register Empty. In 16450 mode, this bit is set to logical 1 when TBR and TSR are both empty. In 16550 mode, it is set to logical 1 when the transmit FIFO and TSR are both empty. Otherwise, this bit is set to logical 0. 5 TBRE. Transmitter Buffer Register Empty. In 16450 mode, when a data character is transferred from TBR to TSR, this bit is set to logical 1. If ETREI or ICR is high, an interrupt is generated to notify the CPU to write the next data. In 16550 mode, this bit is set to logical 1 when the transmit FIFO is empty. It is set to logical 0 when the CPU writes data into TBR or the FIFO. 4 SBD. Silent Byte Detected. This bit is set to logical 1 to indicate that received data are kept in silent state for the time it takes to receive a full word, which includes the start bit, data bits, parity bit, and stop bits. In 16550 mode, it indicates the same condition for the data on the top of the FIFO. When the CPU reads USR, it sets this bit to logical 0. 3 NSER. No Stop Bit Error. This bit is set to logical 1 to indicate that the received data have no stop bit. In 16550 mode, it indicates the same condition for the data on the top of the FIFO. When the CPU reads USR, it sets this bit to logical 0. 2 PBER. Parity Bit Error. This bit is set to logical 1 to indicate that the received data has the wrong parity bit. In 16550 mode, it indicates the same condition for the data on the top of the FIFO. When the CPU reads USR, it sets this bit to logical 0. 1 OER. Overrun Error. This bit is set to logical 1 to indicate that the received data have been overwritten by the next received data before they are read by the CPU. In 16550 mode, it indicates the same condition, instead of FIFO full. When the CPU reads USR, it sets this bit to logical 0. 0 RDR. RBR Data Ready. This bit is set to logical 1 to indicate that the received data are ready to be read by the CPU in the RBR or FIFO. When no data are left in the RBR or FIFO, the bit is set to logical 0. 12.2.3 Handshake Control Register (HCR) (Read/Write) This register controls pins used with handshaking peripherals such as modems and also controls the diagnostic mode of the UART. BIT 7 NAME DEFAULT 6 5 RESERVED 0 0 0 4 3 2 1 0 INTERNAL LOOPBACK ENABLE IRQ ENABLE LOOPBACK RI INPUT RTS DTR 0 0 0 0 0 -154- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT BIT 7-5 DESCRIPTION RESERVED. 4 INTERNAL LOOPBACK ENABLE. When this bit is set to logical 1, the UART enters diagnostic mode, as follows: (1) SOUT is forced to logical 1, and SIN is isolated from the communication link. (2) The modem output pins are set to their inactive state. (3) The modem input pins are isolated from the communication link and connect internally as DTR(bit 0 of HCR) →DSR#, RTS (bit 1 of HCR) →CTS#, Loopback RI input (bit 2 of HCR) → RI# and IRQ enable (bit 3 of HCR) →DCD#. Aside from the above connections, the UART operates normally. This method allows the CPU to test the UART in a convenient way. 3 IRQ ENABLE. The UART interrupt output is enabled by setting this bit to logical 1. In diagnostic mode, this bit is internally connected to the modem control input DCD#. 2 LOOPBACK RI INPUT. This bit is only used in the diagnostic mode. In diagnostic mode, this bit is internally connected to the modem control input RI#. 1 RTS. Request to Send. This bit controls the RTS# output. The value of this bit is inverted and output to RTS#. 0 DTR. Data Terminal Ready. This bit controls the DTR# output. The value of this bit is inverted and output to DTR#. 12.2.4 Handshake Status Register (HSR) (Read/Write) This register reflects the current state of the four input pins used with handshake peripherals such as modems and records changes on these pins. BIT 7 6 5 4 3 2 1 0 NAME DCD RI DSR CTS TDCD FERI TDSR TCTS DEFAULT NA NA NA NA NA NA NA NA BIT DESCRIPTION 7 DCD. Data Carrier Detect. This bit is the opposite of the DCD# input. This bit is equivalent to bit 3 of HCR in the loopback mode. 6 RI. Ring Indicator. This bit is the opposite of the RI# input. This bit is equivalent to bit 2 of HCR in the loopback mode. 5 DSR. Data Set Ready. This bit is the opposite of the DSR# input. This bit is equivalent to bit 0 of HCR in the loopback mode. 4 CTS. Clear to Send. This bit is the opposite of the CTS# input. This bit is equivalent to bit 1 of HCR in the loopback mode. 3 TDCD. DCD# Toggling. This bit indicates that the DCD# pin has changed state after HSR was read by the CPU. 2 FERI. RI Falling Edge. This bit indicates that the RI# pin has changed from low to high after HSR was read by the CPU. 1 TDSR. DSR# Toggling. This bit indicates that the DSR# pin has changed state after HSR was read by the CPU. 0 TCTS. CTS# Toggling. This bit indicates that the CTS# pin has changed state after HSR was read by the CPU. -155- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 12.2.5 UART FIFO Control Register (UFR) (Write only) This register is used to control the FIFO functions of the UART. BIT 7 6 NAME RX IAL (MSB) RXIAL (LSB) DEFAULT 0 0 5 4 RESREVED NA 3 2 1 0 DMA MODE SELECT TRANSMITTER FIFO RESET RECEIVER FIFO RESET FIFO ENABLE 0 0 0 0 NA BIT DESCRIPTION 7 RX IAL (MSB). RX INTERRUPT ACTIVE LEVEL. 6 RX IAL (LSB). RX INTERRUPT ACTIVE LEVEL. 5-4 These two bits are used to set the active level of the receiver FIFO interrupt. The active level is the number of bytes that must be in the receiver FIFO to generate an interrupt. RESERVED. 3 DMA MODE SELECT. When this bit is set to logical 1, the DMA mode changes from mode 0 to mode 1 if UFR bit 0 = 1. 2 TRANSMITTER FIFO RESET. Setting this bit to logical 1 resets the TX FIFO counter logic to its initial state. This bit is automatically cleared afterwards. 1 RECEIVER FIFO RESET. Setting this bit to logical 1 resets the RX FIFO counter logic to its initial state. This bit is automatically cleared afterwards. 0 FIFO ENABLE. This bit enables 16550 mode. This bit should be set to logical 1 before the other UFR bits are programmed. BIT 7 BIT 6 RX FIFO INTERRUPT ACTIVE LEVEL (BYTES) 0 0 01 0 1 04 1 0 08 1 1 14 12.2.6 Interrupt Status Register (ISR) (Read only) This register reflects the UART interrupt status. 7 BIT FIFOS ENABLED NAME DEFAULT BIT 6 0 0 5 4 RESERVED 0 3 2 1 0 INTERRUPT STATUS BIT2 INTERRUPT STATUS BIT1 INTERRUPT STATUS BIT0 0 IF INTERRUPT PENDING 0 0 0 1 0 DESCRIPTION 7-6 FIFOS ENABLED. These two bits are set to logical 1 when UFR, bit 0 = 1. 5-4 RESERVED. These two bits are always logical 0. -156- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT BIT DESCRIPTION 3 INTERRUPT STATUS BIT2. In 16450 mode, this bit is logical 0. In 16550 mode, bit 3 and 2 are set to logical 1 when a time-out interrupts is pending. See the table below. 2 INTERRUPT STATUS BIT1. 1 INTERRUPT STATUS BIT0. 0 0 IF INTERRUPT PENDING. This bit is logical 1 if there is no interrupt pending. If one of the interrupt sources has occurred, this bit is set to logical 0. These two bits identify the priority level of the pending interrupt, as shown in the table below. ISR INTERRUPT SET AND FUNCTION Bit 3 Bit 2 Bit 1 Bit 0 Interrupt priority Interrupt Type 0 0 0 1 - 0 1 1 0 First UART Receive Status 1. OER = 1 2. PBER =1 3. NSER = 1 4. SBD = 1 Read USR 0 1 0 0 Second RBR Data Ready 1. RBR data ready 2. FIFO interrupt active level reached 1. Read RBR 2. Read RBR until FIFO data under active level 1 1 0 0 Second FIFO Data Timeout Data present in RX FIFO for 4 characters period of time since last access of RX FIFO. Read RBR 0 0 1 0 Third TBR Empty TBR empty 1. Write data into TBR 2. Read ISR (if priority is third) 0 0 0 0 Fourth Handshake status 1. TCTS = 1 3. FERI = 1 - Interrupt Source Clear Interrupt No Interrupt pending - 2. TDSR = 1 4. TDCD = 1 Read HSR ** Bit 3 of ISR is enabled when bit 0 of UFR is logical 1. 12.2.7 Interrupt Control Register (ICR) (Read/Write) This 8-bit register enables and disables the five types of controller interrupts separately. A selected interrupt can be enabled by setting the appropriate bit to logical 1. The interrupt system can be totally disabled by setting bits 0 through 3 to logical 0. 7 BIT DEFAULT 7-4 5 4 RESERVED NAME BIT 6 0 0 0 3 2 1 0 EHSRI EUSRI ETBREI ERDRI 0 0 0 0 0 DESCRIPTION RESERVED. These four bits are always logical 0. 3 EHSRI. Set this bit to logical 1 to enable the handshake status register interrupt. 2 EUSRI. Set this bit to logical 1 to enable the UART status register interrupt. 1 ETBREI. Set this bit to logical 1 to enable the TBR empty interrupt. 0 ERDRI. Set this bit to logical 1 to enable the RBR data ready interrupt. -157- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 12.2.8 Programmable Baud Generator (BLL/BHL) (Read/Write) Two 8-bit registers, BLL and BHL, compose a programmable baud generator that uses 24 MHz to generate a 1.8461 MHz frequency and divide it by a divisor from 1 to (216 –1). The output frequency of the baud generator is the baud rate multiplied by 16, and this is the base frequency for the transmitter and receiver. The table below illustrates the use of the baud generator with a frequency of 1.8461 MHz. In high-speed UART mode (CR0C, bits 7 and 6), the programmable baud generator directly uses 24 MHz and the same divisor as the normal speed divisor. As a result, in high-speed mode, the data transmission rate can be as high as 1.5M bps. BAUD RATE FROM DIFFERENT PRE-DIVIDER PRE-DIV: 13 1.8461M HZ PRE-DIV: 1.0 24M HZ DECIMAL DIVISOR USED TO GENERATE 16X CLOCK ERROR PERCENTAGE 50 650 2304 ** 75 975 1536 ** 110 1430 1047 0.18% 134.5 1478.5 857 0.099% 150 1950 768 ** 300 3900 384 ** 600 7800 192 ** 1200 15600 96 ** 1800 23400 64 ** 2000 26000 58 0.53% 2400 31200 48 ** 3600 46800 32 ** 4800 62400 24 ** 7200 93600 16 ** 9600 124800 12 ** 19200 249600 6 ** 38400 499200 3 ** 57600 748800 2 ** 115200 1497600 1 ** ** Unless specified, the error percentage for all of the baud rates is 0.16%. Note: Pre-Divisor is determined by CRF0 of UART A and B. 12.2.9 User-defined Register (UDR) (Read/Write) This is a temporary register that can be accessed and defined by the user. -158- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 13. PARALLEL PORT 13.1 Printer Interface Logic The W83627DHG-P parallel port can be attached to devices that accept eight bits of parallel data at standard TTL level. The W83627DHG-P supports the IBM XT/AT compatible parallel port (SPP), the bi-directional parallel port (BPP), the Enhanced Parallel Port (EPP), and the Extended Capabilities Parallel Port (ECP) on the parallel port. The following tables show the pin definitions for different modes of the parallel port. Table 13-1 Pin Descriptions for SPP, EPP, and ECP Modes HOST CONNECTOR PIN NUMBER OF W83627DHG-P PIN ATTRIBUTE SPP EPP ECP 1 36 O nSTB nWrite nSTB, HostClk 2-9 31-26, 24-23 I/O PD PD PD 10 22 I nACK Intr nACK, PeriphClk 11 21 I BUSY nWait BUSY, PeriphAck 12 19 I PE PE PEerror, nAckReverse 13 18 I SLCT Select SLCT, Xflag 14 35 O nAFD nDStrb nAFD, HostAck 15 34 I nERR nError nFault , nPeriphRequest 2 2 2 2 2 2 1 1 2 2 16 33 O nINIT nInit nINIT , nReverseRqst 17 32 O nSLIN nAStrb nSLIN , ECPMode 1 2 Notes: n : Active Low 1. Compatible Mode 2. High Speed Mode 3. For more information, please refer to the IEEE 1284 standard. HOST CONNECTOR PIN NUMBER OF W83627DHG-P PIN ATTRIBUTE SPP 1 2 36 O nSTB 31 I/O PD0 3 30 I/O PD1 4 29 I/O PD2 5 28 I/O PD3 6 27 I/O PD4 7 26 I/O PD5 8 24 I/O PD6 9 23 I/O PD7 10 22 I nACK 11 21 I BUSY 12 19 I PE SLCT 13 18 I 14 35 O nAFD 15 34 I nERR 16 33 O nINIT -159- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT HOST CONNECTOR PIN NUMBER OF W83627DHG-P PIN ATTRIBUTE SPP 17 32 O nSLIN 13.2 Enhanced Parallel Port (EPP) The following table lists the registers used in the EPP mode and identifies the bit map of the parallel port and EPP registers. Some of the registers are used in other modes as well. Table 13-2 EPP Register Addresses A2 A1 A0 REGISTER NOTE 0 0 0 Data pot (R/W) 1 0 0 1 Printer status buffer (Read) 1 0 1 0 Printer control latch (Write) 1 0 1 0 Printer control swapper (Read) 1 0 1 1 EPP address port (R/W) 2 1 0 0 EPP data port 0 (R/W) 2 1 0 1 EPP data port 1 (R/W) 2 1 1 0 EPP data port 2 (R/W) 2 1 1 1 EPP data port 2 (R/W) 2 Notes: 1. These registers are available in all modes. 2. These registers are available only in EPP mode. Table 13-3 Address and Bit Map for SPP and EPP Modes REGISTER 7 6 5 4 3 2 1 0 Data Port (R/W) PD7 PD6 PD5 PD4 PD3 PD2 PD1 PD0 Status Buffer (Read) BUSY# ACK# PE SLCT ERROR# 1 1 TMOUT Control Swapper (Read) 1 1 1 IRQEN SLIN INIT# AUTOFD# STROBE# Control Latch (Write) 1 1 DIR IRQ SLIN INIT# AUTOFD# STROBE# EPP Address Port (R/W) PD7 PD6 PD5 PD4 PD3 PD2 PD1 PD0 EPP Data Port 0 (R/W) PD7 PD6 PD5 PD4 PD3 PD2 PD1 PD0 EPP Data Port 1 (R/W) PD7 PD6 PD5 PD4 PD3 PD2 PD1 PD0 EPP Data Port 2 (R/W) PD7 PD6 PD5 PD4 PD3 PD2 PD1 PD0 EPP Data Port 3 (R/W) PD7 PD6 PD5 PD4 PD3 PD2 PD1 PD0 Each register (or pair of registers, in some cases) is discussed below. 13.2.1 Data Port (Data Swapper) The CPU reads the contents of the printer's data latch by reading the data port. -160- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 13.2.2 Printer Status Buffer The CPU reads the printer status by reading the printer status buffer. The bit definitions are as follows: BIT 7 6 5 4 3 2 NAME BUSY# ACK# PE SLCT ERROR# DEFAULT NA NA NA NA NA 1 RESERVED 1 0 TMOUT 1 0 BIT DESCRIPTION 7 BUSY#. This signal is active during data entry, when the printer is off-line during printing, when the printer head is changing position, or in an error state. When this signal is active, the printer is busy and cannot accept data. 6 ACK#. This bit represents the current state of the printer’s ACK# signal. A logical 0 means the printer has received a character and is ready to accept another. Normally, this signal is active for approximately before 5 μs BUSY# stops. 5 PE. A logical 1 means the printer has detected the end of paper. 4 SLCT. A logical 1 means the printer is selected. 3 ERROR#. A logical 0 means the printer has encountered an error condition. 2-1 0 RESERVED. These bits are always read as logical 1. TMOUT. This bit is only valid in the EPP mode. A logical 1 indicates that a 10 μs time-out has occurred on the EPP bus. A logical 0 means that no time-out error has occurred. Writing a logical 1 to this bit clears the time-out status bit; writing a logical 0 has no effect. 13.2.3 Printer Control Latch and Printer Control Swapper The CPU reads the contents of the printer control latch by reading the printer control swapper. The bit definitions are as follows: 7 BIT NAME DEFAULT BIT 7-6 6 RESERVED 1 1 5 4 3 2 1 0 DIR IRQ ENABLE SLCT IN INIT# AUTO FD STROBE NA 0 NA NA NA NA DESCRIPTION RESERVED. These two bits are always read as logical 1. They can be written. 5 DIR. Direction Control Bit. When this bit is logical 1, the parallel port is in the input mode (read). When it is logical 0, the parallel port is in the output mode (write). This bit can be read and written. In the SPP mode, this bit is invalid and fixed at zero. 4 IRQ ENABLE. A logical 1 allows an interrupt to occur when ACK# changes from low to high. 3 SLCT IN. A logical 1 selects the printer. 2 INIT#. A logical 0 starts the printer (50 microsecond pulse, minimum). 1 AUTO FD. A logical 1 causes the printer to line-feed after a line is printed. 0 STROBE. A logical 1 generates an active-high pulse for a minimum of 0.5 μs to clock data into the printer. Valid data must be present for a minimum of 0.5 μs before and after the strobe pulse. -161- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 13.2.4 EPP Address Port The address port is available only in EPP mode. Bit definitions are as follows: BIT 7 6 5 4 3 2 1 0 NAME PD7 PD6 PD5 PD4 PD3 PD2 PD1 PD0 The contents of DB0-DB7 are buffered (non-inverting) and output to ports PD0-PD7 during a write operation. The leading edge of IOW# causes an EPP address write cycle to be performed, and the trailing edge of IOW# latches the data for the duration of the EPP write cycle. PD0-PD7 ports are read during a read operation. The leading edge of IOR# causes an EPP address read cycle to be performed and the data to be output to the host CPU. 13.2.5 EPP Data Port 0-3 These four registers are available only in EPP mode. The bit definitions for each data port are the same and as follows: BIT 7 6 5 4 3 2 1 0 NAME PD7 PD6 PD5 PD4 PD3 PD2 PD1 PD0 When any EPP data port is accessed, the contents of DB0-DB7 are buffered (non-inverting) and output to ports PD0-PD7 during a write operation. The leading edge of IOW# causes an EPP data write cycle to be performed, and the trailing edge of IOW# latches the data for the duration of the EPP write cycle. During a read operation, ports PD0-PD7 are read, and the leading edge of IOR# causes an EPP read cycle to be performed and the data to be output to the host CPU. 13.2.6 EPP Pin Descriptions EPP NAME TYPE EPP DESCRIPTION NWrite O Denotes read or write operation for address or data. PD I/O Bi-directional EPP address and data bus. Intr I Used by peripheral devices to interrupt the host. NWait I Inactivated to acknowledge that data transfer is complete. Activated to indicate that the device is ready for the next transfer. PE I Paper end; same as SPP mode. Select I Printer-select status; same as SPP mode. NDStrb O This signal is active low. It denotes a data read or write operation. Nerror I Error; same as SPP mode. Ninits O This signal is active low. When it is active, the EPP device is reset to its initial operating mode. NAStrb O This signal is active low. It denotes an address read or write operation. 13.2.7 EPP Operation -162- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT When EPP mode is selected, the PDx bus is in standard or bi-directional mode when no EPP read, write, or address cycle is being executed. In this situation, all output signals are set by the SPP Control Port and the direction is controlled by DIR of the Control Port. A watchdog timer is required to prevent system lockup. The timer indicates that more than 10 μs have elapsed from the start of the EPP cycle to the time WAIT# is deasserted. The current EPP cycle is aborted when a time-out occurs. The time-out condition is indicated in status bit 0. The EPP operates on a two-phase cycle. First, the host selects the register within the device for subsequent operations. Second, the host performs a series of read and/or write byte operations to the selected register. Four operations are supported on the EPP: Address Write, Data Write, Address Read, and Data Read. All operations on the EPP device are performed asynchronously. 13.2.7.1. EPP Version 1.9 Operation The EPP read/write operation can be completed under the following conditions: a. If nWait is active low, the read cycle (nWrite inactive high, nDStrb/nAStrb active low) or write cycle (nWrite active low, nDStrb/nAStrb active low) starts, proceeds normally, and is completed when nWait goes inactive high. b. If nWait is inactive high, the read/write cycle cannot start. It must wait until nWait changes to active low, at which time it starts as described above. 13.2.7.2. EPP Version 1.7 Operation The EPP read/write cycle can start without checking whether nWait is active or inactive. Once the read/write cycle starts; however, it does not finish until nWait changes from active low to inactive high. 13.3 Extended Capabilities Parallel (ECP) Port This port is software- and hardware-compatible with existing parallel ports, so the W83627DHG-P parallel port may be used in standard printer mode if ECP is not required. It provides an automatic high burst-bandwidth channel that supports DMA for ECP in both the forward (host-to-peripheral) and reverse (peripheral-to-host) directions. Small FIFOs are used in both forward and reverse directions to improve the maximum bandwidth requirement. The size of the FIFO is 16 bytes. The ECP port supports an automatic handshake for the standard parallel port to improve compatibility mode transfer speed. The ECP port hardware supports run-length-encoded (RLE) decompression. Compression is accomplished by counting identical bytes and transmitting an RLE byte that indicates how many times the next byte is to be repeated. RLE compression is required; the hardware support is optional. For more information about the ECP Protocol, please refer to the Extended Capabilities Port Protocol and ISA Interface Standard. The W83627DHG-P ECP supports the following modes. Table 13-4 ECP Mode Description MODE DESCRIPTION 000 SPP mode 001 PS/2 Parallel Port mode 010 Parallel Port Data FIFO mode -163- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT MODE DESCRIPTION 011 ECP Parallel Port mode 100 EPP mode (If this option is enabled in the CRF0h to select ECP/EPP mode) 101 Reserved 110 Test mode 111 Configuration mode The mode selection bits are bits 7-5 of the Extended Control Register. 13.3.1 ECP Register and Bit Map The next two tables list the registers used in the ECP mode and provide a bit map of the parallel port and ECP registers. Table 13-5 ECP Register Addresses NAME ADDRESS I/O ECP MODES FUNCTION data Base+000h R/W 000-001 ecpAFifo Base+000h R/W 011 ECP FIFO (Address) dsr Base+001h R All Status Register Data Register dcr Base+002h R/W All Control Register cFifo Base+400h R/W 010 Parallel Port Data FIFO ecpDFifo Base+400h R/W 011 ECP FIFO (DATA) tFifo Base+400h R/W 110 Test FIFO cnfgA Base+400h R 111 Configuration Register A cnfgB Base+401h R/W 111 Configuration Register B ecr Base+402h R/W All Extended Control Register Note: The base addresses are specified by CR60 and 61, which are determined by the configuration register or the hardware setting. Table 13-6 Bit Map of the ECP Registers D7 Data ecpAFifo Dsr Dcr cFifo ecpDFifo tFifo cnfgA cnfgB Ecr PD7 Addr/RLE D6 D5 D4 D3 D2 D1 D0 PD6 PD5 PD4 PD3 PD2 PD1 PD0 Address or RLE field NOTE 2 nBusy nAck PError Select nFault 1 1 1 1 1 1 Directio ackIntEn SelectIn nInit Autofd strobe 1 Parallel Port Data FIFO 2 ECP Data FIFO 2 Test FIFO 2 0 0 0 1 0 0 0 0 compress intrValue 1 1 1 1 1 1 nErrIntrEn dmaEn serviceIntr full empty MODE Notes: 1. These registers are available in all modes. 2. All FIFOs use one common 16-byte FIFO. Each register (or pair of registers, in some cases) is discussed below. -164- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 13.3.2 Data and ecpAFifo Port Modes 000 (SPP) and 001 (PS/2) (Data Port) During a write operation, the Data Register latches the contents of the data bus on the rising edge of the input, and the contents of this register are output to PD0-PD7. During a read operation, ports PD0PD7 are read and output to the host. The bit definitions are as follows: BIT 7 6 5 4 3 2 1 0 NAME PD7 PD6 PD5 PD4 PD3 PD2 PD1 PD0 Mode 011 (ECP FIFO-Address/RLE) A data byte written to this address is placed in the FIFO and tagged as an ECP Address/RLE. The hardware at the ECP port transmits this byte to the peripheral automatically. This operation is defined only for the forward direction. The bit definitions are as follows: BIT 7 NAME ADDRESS/RLE 6 5 4 3 2 1 0 ADDRESS OR RLE 13.3.3 Device Status Register (DSR) These bits are logical 0 during a read of the Printer Status Register. The bits of this status register are defined as follows: BIT 7 6 5 4 3 2 1 0 NAME nBUSY nACK PERROR SELECT nFAULT 1 1 1 BIT DESCRIPTION 7 nBUSY. This bit reflects the complement of the Busy input. 6 nACK. This bit reflects the nAck input. 5 PERROR. This bit reflects the PError input. 4 SELECT. This bit reflects the Select input. 3 nFAULT. This bit reflects the nFault input. 2-0 RESERVED. These three bits are not implemented and are always logical 1 during a read. 13.3.4 Device Control Register (DCR) The bit definitions are as follows: BIT NAME DEFAULT 7 6 RESERVED 1 1 5 4 3 2 1 0 DIRECTOR ACKINTEN SELECTIN NINIT AUTOFD STROBE NA NA NA NA NA NA -165- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT BIT 7-6 DESCRIPTION RESERVED. These two bits are always read as logical 1 and cannot be written. 5 DIRECTOR. If the mode is 000 or 010, this bit has no effect and the direction is always out. In other modes, 0: The parallel port is in the output mode. 1: The parallel port is in the input mode. 4 ACKINEN. Interrupt Request Enable. When this bit is set to logical 1, it enables interrupt requests from the parallel port to the CPU on the low-to-high transition on ACK#. 3 SELECTIN. This bit is inverted and output to the SLIN# output. 0: The printer is not selected. 1: The printer is selected. 2 NINIT. This bit is output to the INIT# output. 1 AUTOFD. This bit is inverted and output to the AFD# output. 0 STROBE. This bit is inverted and output to the STB# output. 13.3.5 CFIFO (Parallel Port Data FIFO) Mode = 010 This mode is defined only for the forward direction. Bytes written or DMAed to this FIFO are transmitted by a hardware handshake to the peripheral using the standard parallel port protocol. Transfers to the FIFO are byte-aligned. 13.3.6 ECPDFIFO (ECP Data FIFO) Mode = 011 When the direction bit is 0, bytes written or DMAed to this FIFO are transmitted by a hardware handshake to the peripheral using the ECP parallel port protocol. Transfers to the FIFO are bytealigned. When the direction bit is 1, data bytes from the peripheral are read via automatic hardware handshake from ECP into this FIFO. Reads or DMAs from the FIFO return bytes of ECP data to the system. 13.3.7 TFIFO (Test FIFO Mode) Mode = 110 Data bytes may be read, written, or DMAed to or from the system to this FIFO in any direction. Data in the tFIFO is not transmitted to the parallel port lines. However, data in the tFIFO may be displayed on the parallel port data lines. 13.3.8 CNFGA (Configuration Register A) Mode = 111 This register is a read-only register. When it is read, 10h is returned indicating an 8-bit implementation. 13.3.9 CNFGB (Configuration Register B) Mode = 111 The bit definitions are as follows: BIT 7 6 5 4 3 NAME COMPRESS INTROVALUE IRQX2 IRQX1 IRQX0 DEFAULT 0 0 0 0 0 -166- 2 1 0 RESERVED 1 1 1 Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT BIT DESCRIPTION 7 COMPRESS. This bit is read-only. It is logical 0 during a read, which means that this chip does not support hardware RLE compression. 6 INTRVALUE. Returns the value on the ISA IRQ line to determine possible conflicts. 5 IRQX2. 4 IRQX1. 3 IRQX0. 2-0 Reflects the IRQ resource assigned for the ECP port. cnfgB[5:3] IRQ Resource 000 Reflects other IRQ resources selected by PnP register (Default) 001 IRQ7 010 IRQ9 011 IRQ10 100 IRQ11 101 IRQ14 110 IRQ15 111 IRQ5 RESERVED. These bits are logical 1 during a read and can be written. 13.3.10 ECR (Extended Control Register) Mode = all This register controls the extended ECP parallel port functions. The bit definitions are follows: 7 BIT 6 5 MODE NAME DEFAULT 0 0 0 4 3 2 1 0 nERRINTREN DMAEN SERVICE INTR FULL EMPTY 1 0 1 0 1 BIT DESCRIPTION 7-5 MODE. Read/Write. These bits select the mode. Bits 765 0 0 0: Standard Parallel Port (SPP) mode. The FIFO is reset in this mode. 0 0 1: PS/2 Parallel Port mode. In addition to the functions of the SPP mode, this mode has an extra trait: Direction is able to tri-state the data lines. Furthermore, reading the data register returns the value on the data lines, not the value in the data register. 0 1 0: Parallel Port FIFO mode. This is the same as the SPP mode except that bytes are written or DMAed to the FIFO. FIFO data are automatically transmitted using the standard parallel port protocol. This mode functions only when the direction is 0. 0 1 1: ECP Parallel Port Mode. When the direction is 0 (forward direction), bytes placed into the ecpDFifo and bytes written to the ecpAFifo are placed in a single FIFO and automatically transmitted to the peripheral using the ECP Protocol. When the direction is 1 (reverse direction), bytes are moved from the ECP parallel port and packed into bytes in the ecpDFifo. 1 0 0: EPP Mode. The EPP mode is activated if the EPP mode is selected. 1 0 1: Reserved. -167- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT BIT DESCRIPTION 1 1 0: Test Mode. The FIFO may be written and read in this mode, but the data is not transmitted on the parallel port. 1 1 1: Configuration Mode. The confgA and confgB registers are accessible at 0x400 and 0x401 in this mode. 4 nERRINTREN. Read/Write (Valid only in the ECP mode) 1: Disables the interrupt generated on the asserting edge of nFault. 0: Enables the interrupt generated on the falling edge of nFault. This prevents interrupts from being lost in the time between the read and the write of the ECR. 3 DMAEN. Read/Write. 1: Enables DMA. 0: Disables DMA unconditionally. 2 SERVICE INTR. Read/Write. 1: Disables DMA and all of the service interrupts. Writing a logical 1 to this bit does not cause an interrupt. 0: Enables one of the following cases of interrupts. When one of the serviced interrupts occurs, this bit is set to logical 1 by the hardware. This bit must be reset to logical 0 to reenable the interrupts. (a) dmaEn = 1: During DMA, this bit is set to logical 1 when terminal count is reached. (b) dmaEn = 0, direction = 0: This bit is set to logical 1 whenever there are writeIntr threshold or more bytes free in the FIFO. (c) dmaEn = 0, direction = 1: This bit is set to logical 1 whenver there are readIntr threshold or more valid bytes to be read from the FIFO. 1 FULL. Read only. 1: The FIFO is completely full. It cannot accept another byte. 0: The FIFO has at least one free byte. 0 EMPTY. Read only. 1: The FIFO is completely empty. 0: The FIFO contains at least one byte of data. 13.3.11 ECP Pin Descriptions NAME NStrobe (HostClk) PD nAck (PeriphClk) TYPE DESCRIPTION O This pin loads data or address into the slave on its asserting edge during write operations. This signal handshakes with Busy. I/O These signals contain address, data or RLE data. I This signal indicates valid data driven by the peripheral when asserted. This signal handshakes with nAutoFd in reverse. I This signal deasserts to indicate that the peripheral can accept data. In the reverse direction, it indicates whether the data lines contain ECP command information or data. Normal data are transferred when Busy (PeriphAck) is high, and an 8-bit command is transferred when it is low. I This signal is used to acknowledge a change in the direction of the transfer (asserted = forward). The peripheral drives this signal low to acknowledge nReverseRequest. The host relies upon nAckReverse to determine when it is permitted to drive the data bus. Busy (PeriphAck) PError (nAckReverse) -168- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT NAME Select (Xflag) TYPE DESCRIPTION I Indicates printer on-line. O Requests a byte of data from the peripheral when it is asserted. In the forward direction, this signal indicates whether the data lines contain ECP address or data. Normal data are transferred when nAutoFd (HostAck) is high, and an 8-bit command is transferred when it is low. I Generates an error interrupt when it is asserted. This signal is valid only in the forward direction. The peripheral is permitted (but not required) to drive this pin low to request a reverse transfer during ECP mode. nInit (nReverseRequest) O This signal sets the transfer direction (asserted = reverse, deasserted = forward). This pin is driven low to place the channel in the reverse direction. nSelectIn (ECPMode) O This signal is always deasserted in ECP mode. NautoFd (HostAck) nFault (nPeriphReuqest) 13.3.12 ECP Operation The host must negotiate on the parallel port to determine if the peripheral supports the ECP protocol before ECP operation. After negotiation, it is necessary to initialize some of the port bits. (a) Set direction = 0, enabling the drivers. (b) Set strobe = 0, causing the nStrobe signal to default to the deasserted state. (c) Set autoFd = 0, causing the nAutoFd signal to default to the deasserted state. (d) Set mode = 011 (ECP Mode) ECP address/RLE bytes or data bytes may be sent automatically by writing the ecpAFifo or ecpDFifo, respectively. 13.3.12.1. Mode Switching The software must handle P1284 negotiation and all operations prior to a data transfer in SPP or PS/2 modes (000 or 001). The hardware provides an automatic control line handshake, moving data between the FIFO and the ECP port, only in the data transfer phase (mode 011 or 010). If the port is in mode 000 or 001, it may switch to any other mode. If the port is not in mode 000 or 001, it can only be switched into mode 000 or 001. The direction can only be changed in mode 001. In extended forward mode, the software should wait for the FIFO to be empty before switching back to mode 000 or 001. In ECP reverse mode, the software should wait for all the data to be read from the FIFO before changing back to mode 000 or 001. 13.3.12.2. Command/Data ECP mode allows the transfer of normal 8-bit data or 8-bit commands. In the forward direction, normal data are transferred when HostAck is high, and an 8-bit command is transferred when HostAck is low. The most significant bits of the command indicate whether it is a run-length count (for compression) or a channel address. In the reverse direction, normal data are transferred when PeriphAck is high, and an 8-bit command is transferred when PeriphAck is low. The most significant bit of the command is always zero. -169- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 13.3.12.3. Data Compression The W83627DHG-P hardware supports RLE decompression and can transfer compressed data to a peripheral. Odd (RLE) compression is not supported in the hardware, however. In order to transfer data in ECP mode, the compression count is written to ecpAFifo and the data byte is written to ecpDFifo. 13.3.13 FIFO Operation The FIFO threshold is set in LD0 CRO0, bit 6 ~ 3. All data transferred to or from the parallel port can proceed in DMA or Programmed I/O (non-DMA) mode, as indicated by the selected mode. The FIFO is used in Parallel Port FIFO mode or ECP Parallel Port Mode. After a reset, the FIFO is disabled. 13.3.14 DMA Transfers DMA transfers are always to or from the ecpDFifo, tFifo, or CFifo. DMA uses the standard PC DMA services. The ECP requests DMA transfers from the host by activating the PDRQ pin. The DMA empties or fills the FIFO using the appropriate direction and mode. When the terminal count in the DMA controller is reached, an interrupt is generated, and serviceIntr is asserted, which will disable the DMA. 13.3.15 Programmed I/O (NON-DMA) Mode The ECP and parallel port FIFOs can also be operated using interrupt-driven, programmed I/O. Programmed I/O transfers are 1. To the ecpDFifo at 400h and ecpAFifo at 000h 2. From the ecpDFifo located at 400h 3. To / from the tFifo at 400h. The host must set dmaEn and serviceIntr to 0 and also must set the direction and state accordingly in the programmed I/O transfers. The ECP requests programmed I/O transfers from the host by activating the IRQ pin. The programmed I/O empties or fills the FIFO using the appropriate direction and mode. -170- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 14. KEYBOARD CONTROLLER The W83627DHG-P KBC (8042 with licensed KB BIOS) circuit is designed to provide the functions needed to interface a CPU with a keyboard and/or a PS/2 mouse and can be used with IBM®compatible personal computers or PS/2-based systems. The controller receives serial data from the keyboard or PS/2 mouse, checks the parity of the data, and presents the data to the system as a byte of data in its output buffer. Then, the controller asserts an interrupt to the system when data are placed in its output buffer. The keyboard and PS/2 mouse are required to acknowledge all data transmissions. No transmission should be sent to the keyboard or PS/2 mouse until an acknowledgement is received for the previous data byte. KINH P17 8042 P24 KIRQ P25 MIRQ P21 GATEA20 P20 KBRST P27 KDAT P10 P26 KCLK T0 GP I/O PINS Multiplex I/O PINS MCLK P23 P12~P16 T1 MDAT P22 P11 Figure 14-1 Keyboard and Mouse Interface 14.1 Output Buffer The output buffer is an 8-bit, read-only register at I/O address 60h (Default, PnP programmable I/O address LD5-CR60 and LD5-CR61). The keyboard controller uses the output buffer to send the scan code (from the keyboard) and required command bytes to the system. The output buffer can only be read when the output buffer full bit in the register (in the status register) is logical 1. 14.2 Input Buffer The input buffer is an 8-bit, write-only register at I/O address 60h or 64h (Default, PnP programmable I/O address LD5-CR60, LD5-CR61, LD5-CR62, and LD5-CR63). Writing to address 60h sets a flag to indicate a data write; writing to address 64h sets a flag to indicate a command write. Data written to I/O address 60h is sent to the keyboard (unless the keyboard controller is expecting a data byte) through the controller's input buffer only if the input buffer full bit (in the status register) is logical 0. -171- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 14.3 Status Register The status register is an 8-bit, read-only register at I/O address 64h (Default, PnP programmable I/O address LD5-CR62 and LD5-CR63) that holds information about the status of the keyboard controller and interface. It may be read at any time. Table 14-1 Bit Map of Status Register BIT BIT FUNCTION DESCRIPTION 0 Output Buffer Full 0: Output buffer empty 1: Output buffer full 1 Input Buffer Full 0: Input buffer empty 1: Input buffer full 2 System Flag This bit may be set to 0 or 1 by writing to the system flag bit in the command byte of the keyboard controller. It defaults to 0 after a power-on reset. 3 Command/Data 0: Data byte 1: Command byte 4 Inhibit Switch 0: Keyboard is inhibited 1: Keyboard is not inhibited 5 Auxiliary Device Output Buffer 0: Auxiliary device output buffer empty 1: Auxiliary device output buffer full 6 General Purpose Time-out 0: No time-out error 1: Time-out error 7 Parity Error 0: Odd parity 1: Even parity (error) 14.4 Commands Table 14-2 KBC Command Sets COMMAND FUNCTION 20h Read Command Byte of Keyboard Controller 60h Write Command Byte of Keyboard Controller BIT BIT DEFINITION 7 Reserved 6 IBM Keyboard Translate Mode 5 Disable Auxiliary Device 4 Disable Keyboard 3 Reserve 2 System Flag 1 Enable Auxiliary Interrupt 0 Enable Keyboard Interrupt -172- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT COMMAND A4h FUNCTION A7h Test Password Returns 0Fah if Password is loaded Returns 0F1h if Password is not loaded Load Password Load Password until a logical 0 is received from the system Enable Password Enable the checking of keystrokes for a match with the password Disable Auxiliary Device Interface A8h Enable Auxiliary Device Interface A9h Interface Test A5h A6h BIT AAh ABh BIT DEFINITION 00 No Error Detected 01 Auxiliary Device "Clock" line is stuck low 02 Auxiliary Device "Clock" line is stuck high 03 Auxiliary Device "Data" line is stuck low 04 Auxiliary Device "Data" line is stuck low Self-test Returns 055h if self-test succeeds Interface Test BIT BIT DEFINITION 00 No Error Detected 01 Keyboard "Clock" line is stuck low 02 Keyboard "Clock" line is stuck high 03 Keyboard "Data" line is stuck low 04 Keyboard "Data" line is stuck high ADh Disable Keyboard Interface AEh Enable Keyboard Interface C0h Read Input Port (P1) and send data to the system C1h Continuously puts the lower four bits of Port1 into the STATUS register C2h Continuously puts the upper four bits of Port1 into the STATUS register D0h Send Port 2 value to the system D1h Only set / reset GateA20 line based on system data bit 1 D2h Send data back to the system as if it came from the Keyboard D3h Send data back to the system as if it came from Auxiliary Device D4h Output next received byte of data from system to Auxiliary Device E0h Reports the status of the test inputs FXh Pulse only RC (the reset line) low for 6μs if the Command byte is even -173- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 14.5 Hardware GATEA20/Keyboard Reset Control Logic The KBC includes hardware control logic to speed-up GATEA20 and KBRESET. This control logic is controlled by LD5-CRF0 as follows: 14.5.1 KB Control Register BIT 7 6 NAME KCLKS1 KCLKS0 DEFAULT 1 0 BIT 4 3 Reserved 0 0 0 2 1 0 P92EN HGA20 HKBRST# 0 0 0 DESCRIPTION 7 KCLKS1 6 KCLKS0 5-3 5 These two bits select the KBC clock rate. Bits 76 0 0: Reserved. 0 1: Reserved. 1 0: KBC clock input is 12 MHz. 1 1: Reserved. RESERVED. 2 P92EN. Port 92 Enable. 1: Enable Port 92 to control GATEA20 and KBRESET. 0: Disable Port 92 functions. 1 HGA20. Hardware GATEA20. 1: Selects hardware GATEA20 control logic to control GATE A20 signal. 0: Disable hardware GATEA20 control logic function. 0 HKBRST#. Hardware Keyboard Reset. 1: Select hardware KB RESET control logic to control KBRESET signal. 0: Disable hardware KB RESET control logic function. When the KBC receives data that follows a "D1" command, the hardware control logic sets or clears GATEA20 according to received data bit 1. Similarly, the hardware control logic sets or clears KBRESET depending on received data bit 0. When the KBC receives an "FE" command, the KBRESET is pulse low for 6μs (Min.) with a 14μs (Min.) delay. GATEA20 and KBRESET are controlled by either software or hardware logic, and they are mutually exclusive. Then, GATEA20 and KBRESET are merged with Port92 when the P92EN bit is set. -174- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 14.5.2 Port 92 Control Register BIT 7 Res. (0) NAME DEFAULT 6 0 5 4 Res. (1) 0 1 3 Res. (0) 0 0 2 1 0 Res. (1) SGA20 PLKBRST # 1 0 0 SGA20 (Special GATE A20 Control) 1: Drives GATE A20 signal to high. 0: Drives GATE A20 signal to low. PLKBRST# (Pull-Low KBRESET) A logical 1 on this bit causes KBRESET to drive low for 6 μS (Min.) with a 14 μS (Min.) delay. Before issuing another keyboard-reset command, the bit must be cleared. BIT 7-6 DESCRIPTION Res. (0) 5 Res. (1) 4-3 Res. (0) 2 Res. (1) 1 SGA20. Special GATE A20 Control. 1: Drives GATE A20 signal to high. 0: Drives GATE A20 signal to low. 0 PLKBRST#. Pull-Low KBRESET. A logical 1 on this bit causes KBRESET to drive low for 6 μS (Min.) with a 14 μS (Min.) delay. Before issuing another keyboard-reset command, the bit must e cleared. -175- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 15. POWER MANAGEMENT EVENT The PME# (pin 86) signal is connected to the South Bridge and is used to wake up the system from S1 ~ S5 sleeping states. One control bit and four registers in the W83627DHG-P are associated with the PME function. The control bit is at Logical Device A, CR [F2h], bit [0] and is for enabling or disabling the PME function. If this bit is set to “0”, the W83627DHG-P won’t output any PME signal when any of the wake-up events has occurred and is enabled. The four registers are divided into PME status registers and PME interrupt registers of wake-up events Note.1. 1) The PME status registers of wake-up event: - At Logical Device A, CR [F3h] and CR [F4h] - Each wake-up event has its own status - The PME status should be cleared by writing a “1” before enabling its corresponding bit in the PME interrupt registers 2) The PME interrupt registers of wake-up event: - At Logical Device A, CR [F6h] and CR [F7h] - Each wake-up event can be enabled / disabled individually to generate a PME# signal Note.1 PME wake-up events that the W83627DHG-P supports include: z Mouse IRQ event * z Keyboard IRQ event * z GP30, GP31, and GP35 events * z Printer IRQ event z Floppy IRQ event z UART A IRQ event z UART B IRQ event z Hardware Monitor IRQ event z WDTO# event z RIB (UARTB Ring Indicator) event Note.2 All the above support both S0 and S1 states. Events with the “*” mark also support S3 and S5 states. -176- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 15.1 Power Control Logic This chapter describes how the W83627DHG-P implements its ACPI function via these power control pins: PSIN# (Pin 68), PSOUT# (Pin 67), SUSB# (i.e. SLP_S3#; Pin 73) and PSON# (Pin 72). The following figure illustrates the relationships. PSON# 3VCC 3VSB/VBAT PSOUT# PSIN# PWRBTN# W83627DHG-P W83627DHG IOCLK 48 / 24 MHz South Bridge SUSB# PSON# Power Supply VCC ON SLP_S3# Figure 15-1 Power Control Mechanism 15.1.1 PSON# Logic 15.1.1.1. Normal Operation The PSOUT# signal will be asserted low if the PSIN# signal is asserted low. The PSOUT# signal is held low for as long as the PSIN# is held low. The South Bridge controls the SUSB# signal through the PSOUT# signal. The PSON# is directly connected to the power supply to turn on or off the power. Figure 15.2 shows the power on and off sequences. The ACPI state changes from S5 to S0, then to S5 -177- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT PSON# T3 T4 SLP_S3# (Intel Chipset) S3# (Other Chipset) PSOUT# T1 PSIN# T2 3VSB G3 S5 S0 S5 Figure 15-2 Power Sequence from S5 to S0, then Back to S5 15.1.2 AC Power Failure Resume By definition, AC power failure means that the standby power is removed. The power failure resume control logic of the W83627DHG-P is used to recover the system to a pre-defined state after AC power failure. Two control bits at Logical Device A, CR [E4h], bits [6:5] indicate the pre-defined state. The definition of these two bits is listed in the following table: Table 15-1 Bit Map of Logical Device A, CR [E4h], Bits [6:5] LOGICAL DEVICE A, CR[E4H], BITS[6:5] DEFINITION 00 System always turns off when it returns from AC power failure 01 System always turns on when it returns from AC power failure 10 System turns off / on when it returns from power failure depending on the state before the power failure. (Please see Note 1) 11 User defines the state before the power failure. (The previous state is set at CRE6 [4]. Please see Note 2) Note1. The W83627DHG-P detects the state before power failure (on or off) through the SUSB# signal and the 3VCC power. The relation is illustrated in the following two figures. -178- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 3VCC SUSB# Figure 15-3 The previous state is “on” - 3VCC falls to 2.6V and SUSB# keeps at 2.0V 3VCC SUSB# Figure 15-4 The previous state is “off” - 3VCC falls to 2.6V and SUSB# keeps at 0.8V Note 2. Logical Device A, CR[E6h] bit [4] Definition 0 User defines the state to be “on” 1 User defines the state to be “off” To ensure that VCC does not fall faster than VSB in various ATX Power Supplies, the W83627DHG-P adds the option of “user define mode” for the pre-defined state before AC power failure. BIOS can set the pre-defined state to be “On” or “Off”. According to this setting, the system is returned to the pre-defined state after the AC power recovery. 15.2 Wake Up the System by Keyboard and Mouse The W83627DHG-P generates a low pulse through the PSOUT# pin to wake up the system when it detects a key code pressed or mouse button clicked. The following sections describe how the W83627DHG-P works. 15.2.1 Waken up by Keyboard events The keyboard Wake-Up function is enabled by setting Logical Device A, CR [E0h], bit 6 to “1”. There are two keyboard events can be used for the wake-up 1) Any key – Set bit 0 at Logical Device A, CR [E0h] to “1” (Default). 2) Specific keys (Password) - Set bit 0 at Logical Device A, CR [E0h] to “0”. Three sets of specific key combinations are stored at Logical Device A. CR [E1h] is an index register to indicate which byte of key code storage (0x00h ~ 0x0Eh, 0x30h ~ 0x3Eh, 0x40h ~ 0x4Eh) is going to be read or written through CR [E2h]. According to IBM 101/102 keyboard specification, a complete -179- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT key code contains a 1-byte make code and a 2-byte break code. For example, the make code of “0” is 0x45h, and the corresponding break code is 0xF0h, 0x45h. The approach to implement Keyboard Password Wake-Up Function is to fill key codes into the password storage. Assume that we want to set “012” as the password. The storage should be filled as below. Please note that index 0x09h ~ 0x0Eh must be filled as 0x00h since the password has only three numbers. Index(CRE1)Æ 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E D a t a (CRE2)Æ 1E F0 1E 16 F0 16 45 F0 45 00 00 00 00 00 00 First-pressed key “0” Second-pressed key “1” Third-pressed key “2” 15.2.2 Waken up by Mouse events The mouse Wake-Up function is enabled by setting Logical Device A, CR [E0h], bit 5 to “1”. The following specific mouse events can be used for the wake-up: z Any button clicked or any movement z One click of the left or the right button z One click of the left button z One click of the right button z Two clicks of the left button z Two clicks of the right button. Three control bits (ENMDAT_UP, MSRKEY, MSXKEY) define the combinations of the mouse wake-up events. Please see the following table for the details. Table 15-2 Definitions of Mouse Wake-Up Events ENMDAT_UP MSRKEY (LOGICAL DEVICE A, (LOGICAL DEVICE A, CR[E6H], BIT 7) CR[E0H], BIT 4) MSXKEY (LOGICAL DEVICE A, CR[E0H], BIT 1) WAKE-UP EVENT Any button clicked or any movement. One click of the left or right button. 1 x 1 1 x 0 0 0 1 One click of the left button. 0 1 1 One click of the right button. 0 0 0 Two clicks of the left button. 0 1 0 Two clicks of the right button. -180- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 15.3 Resume Reset Logic The RSMRST# (Pin 75) signal is a reset output and is used as the 3VSB power-on reset signal for the South Bridge. When the W83627DHG-P detects the 3VSB voltage rises to “V1”, it then starts a delay – “t1” before the rising edge of RSMRST# asserting. If the 3VSB voltage falls below “V2”, the RSMRST# de-asserts immediately. Timing and voltage parameters are shown in Figure 15-5 Mechanism of Resume Reset Logic and Figure 15-3 The previous state is “on” - 3VCC falls to 2.6V and SUSB# keeps at 2.0V. t1 RSMRST# 3VSB V1 V2 Figure 15-5 Mechanism of Resume Reset Logic SYMBOL PARAMETER MIN. TYP. MAX. UNIT V1 3VSB Valid Voltage 2.4 2.6 2.75 V V2 3VSB Ineffective Voltage 2.25 2.4 2.55 V t1 Valid 3VSB to RSMRST# inactive 100 - 200 mS Table 15-3 Timing and Voltage Parameters of RSMRST# 15.4 PWROK Generation The PWROK (Pin 71) signal is an output and is used as the 3VCC power-on reset signal. When the W83627DHG-P detects the 3VCC voltage rises to “V3”, it then starts a delay – “t2” before the rising edge of PWROK asserting. If the 3VCC voltage falls below “V4”, the PWROK de-asserts immediately. Timing and voltage parameters are shown in Figure 15-6 and Table 15-4. t2 PWROK 3VCC V3 V4 Figure 15-6 -181- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT SYMBOL PARAMETER MIN. TYP. MAX. UNIT V3 3VCC Valid Voltage 2.4 2.6 2.75 V V4 3VCC Ineffective Voltage 2.25 2.4 2.55 V t2 Valid 3VCC to PWROK active 300 - 500 mS Table 15-4 Originally, the t2 timing is between 300 mS to 500 mS, but it can be changed to 200 mS to 300 mS by programming Logical Device A, CR [E6h], bit 3 to “1”. Furthermore, the W83627DHG-P provides four different extra delay time of PWROK for various demands. The four extra delay time are designed at Logical Device A, CR [E6h], bits 2~1. The following table shows the definitions of Logical Device A, CR [E6h] bits 3 ~1. Table 15-5 Bit Map of Logical Device A, CR [E6h], Bits [3:1] LOGICAL DEVICE A, CR[E6H] BIT[3:1] 3 2~1 DEFINITION PWROK_DEL (first stage) (VSB) Set the delay time when rising from PWROK_LP to PWROK_ST. 0: 300 ~ 500 mS. 1: 200 ~ 300 mS. PWROK_DEL (VSB) Set the delay time when rising from PWROK_ST to PWROK. 00: No delay time. 01: Delay 32 mS 10: 96 mS 11: Delay 250 mS For example, if Logical Device A, CR [E6h] bit 3 is set to “0” and bits 2~1 are set to “10”, the range of t2 timing is from 396 (300 + 96) mS to 596 (500 + 96) mS. 15.4.1 The Relation among PWROK/PWROK2, ATXPGD and FTPRST# PWROK and PWROK2 signals as well as ATXPGD and FTPRST# input signals are interrelated. Once the FTPRST# signal changes from high to low then to high, the PWROK and PWROK2 signals will have the same transition after 28mS ~ 39mS delay. The relation and parameter are illustrated in the following figure and table. -182- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT FTPRST# TL t3 PWROK/PWROK2 TL 3VCC Figure 15-7 Table 15-6 SYMBOL PARAMETER t3 MIN FTPRST# active to PWROK active Note. 28 MAX UNIT 39 mS 1. The values above are the worst-case results of R&D simulation 2. The length of TL level is based on the length of the low level of FTPRST# Additionally, the ATXPGD signal, too, is used to control the generation of PWROK and PWROK2. In Figure 15-8, the 3VCC voltage rises to “V3”, and then starts a delay – “t2” for PWROK and PWROK2 generation. However, ATXPGD is still inactive after t2; therefore the delay time before the rising edge of PWROK and PWROK2 are t2 plus Td. The length of Td is based on when the ATXPGD signal is active. Once 3VCC falls below “V4” or the ATXPGD signal is inactive, PWROK and PWROK2 deassert immediately. PWROK/PWROK2 are active when both 3VCC and ATXPGD are valid 3VCC V3 V4 ATXPGD(input) PWROK/PWROK2 are inactive when either 3VCC or ATXPGD is invalid t2 PWROK/PWROK2 (output) Td Figure 15-8 In Figure 15-9, the 3VCC voltage rises to “V3”, and the ATXPGD is active during t2, so PWROK and PWROK2 assert after t2. The timing of t2 starts when 3VCC voltage rises to “V3”. No matter the ATXPGD signal activation is during or after t2, PWROK and PWROK2 assert or de-assert according to the 3VCC voltage and the ATXPGD signal. -183- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 3VCC V3 V4 Ta PWROK/PWROK2 are active when both 3VCC and ATXPGD are valid ATXPGD(input) t2 PWROK/PWROK2 are inactive even when 3VCC is valid PWROK/PWROK2 (output) Figure 15-9 Timing and voltage parameters are shown in the following table. SYMBOL PARAMETER MIN. TYP. MAX. UNIT V3 3VCC Valid Voltage 2.4 2.6 2.75 V V4 3VCC Ineffective Voltage 2.25 2.4 2.55 V t2 Starting from valid 3VCC 300 - 500 mS -184- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 16. SERIALIZED IRQ The W83627DHG-P supports a serialized IRQ scheme. This allows a signal line to be used to report the parallel interrupt requests. Since more than one device may need to share the signal serial SERIRQ signal, an open drain signal scheme is employed. The clock source is the PCI clock. The serialized interrupt is transferred on the SERIRQ signal, one cycle consisting of three frames types: the Start Frame, the IRQ/Data Frame, and the Stop Frame. 16.1 Start Frame There are two modes of operation for the SERIRQ Start Frame: Quiet mode and Continuous mode. In the Quiet mode, the W83627DHG-P drives the SERIRQ signal active low for one clock, and then tristates it. This brings all the state machines of the W83627DHG-P from idle to active states. The host controller (the South Bridge) then takes over driving SERIRQ signal low in the next clock and continues driving the SERIRQ low for programmable 3 to 7 clock periods. This makes the total number of clocks low 4 to 8 clock periods. After these clocks, the host controller drives the SERIRQ high for one clock and then tri-states it. In the Continuous mode, the START Frame can only be initiated by the host controller to update the information of the IRQ/Data Frame. The host controller drives the SERIRQ signal low for 4 to 8 clock periods. Upon a reset, the SERIRQ signal is defaulted to the Continuous mode for the host controller to initiate the first Start Frame. Please see the diagram below for more details. Start Frame Timing with source sampled a low pulse on IRQ1. SL or H H IRQ0 FRAME START FRAME R T S R T IRQ1 FRAME S R T SMI# FRAME S R T PCICLK START 1 SERIRQ Drive Source H=Host Control 2 IRQ1 Host Controller SL=Slave Control None R=Recovery IRQ1 None T=Turn-around S=Sample Note: 1. The Start Frame pulse can be 4-8 clocks wide. 2. The first clock of Start Frame is driven low by the W83627DHG-P because IRQ1 of the W83627DHG-P needs an interrupt request. Then the host takes over and continues to pull the SERIRQ low. -185- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 16.2 IRQ/Data Frame Once the Start Frame has been initiated, the W83627DHG-P must start counting frames based on the rising edge of the start pulse. Each IRQ/Data Frame has three clocks: the Sample phase, the Recovery phase, and the Turn-around phase. During the Sample phase, the W83627DHG-P drives SERIRQ low if the corresponding IRQ is active. If the corresponding IRQ is inactive, then SERIRQ must be left tri-stated. During the Recovery phase, the W83627DHG-P device drives the SERIRQ high. During the Turn-around phase, the W83627DHGP device leaves the SERIRQ tri-stated. The W83627DHG-P starts to drive the SERIRQ line from the beginning of "IRQ0 FRAME" based on the rising edge of PCICLK. The IRQ/Data Frame has a specific numeral order, as shown in Table 16.1. Table 16-1 SERIRQ Sampling Periods SERIRQ SAMPLING PERIODS IRQ/DATA FRAME SIGNAL SAMPLED # OF CLOCKS PAST START EMPLOYED BY 1 IRQ0 2 Reserved 2 IRQ1 5 Keyboard 3 SMI# 8 H/W Monitor & SMI 4 IRQ3 11 UART B 5 IRQ4 14 UART A 6 IRQ5 17 - 7 IRQ6 20 FDC 8 IRQ7 23 LPT 9 IRQ8 26 - 10 IRQ9 29 - 11 IRQ10 32 - 12 IRQ11 35 - 13 IRQ12 38 Mouse 14 IRQ13 41 Reserved 15 IRQ14 44 - 16 IRQ15 47 - 17 IOCHCK# 50 - 18 INTA# 53 - 19 INTB# 56 - 20 INTC# 59 - 21 INTD# 62 - 32:22 Unassigned 95 - -186- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 16.3 Stop Frame After all IRQ/Data Frames have completed, the host controller will terminates SERIRQ with a Stop frame. Only the host controller can initiate the Stop Frame by driving SERIRQ low for 2 or 3 clocks. If the Stop Frame is low for 2 clocks, the Sample mode of next SERIRQ cycle’s Sample mode is the Quiet mode. If the Stop Frame is low for 3 clocks, the Sample mode of next SERIRQ cycle is the Continuous mode. Please see the diagram below for more details. Stop Frame Timing with Host Using 17 SERIRQ sampling period. IRQ14 FRAME S R IRQ15 FRAME T S R IOCHCK# FRAME T S R STOP FRAME T I1 R H NEXT CYCLE T PCICLK STOP SERIRQ Driver None H=Host Control IRQ15 R=Recovery None START 2 Host Controller T=Turn-around S=Sample I= Idle. Note: 1. There may be none, one or more Idle states during the Stop Frame. 2. The Start Frame pulse of next SERIRQ cycle may or may not start immediately after the turn-around clock of the Stop Frame. -187- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 17. WATCHDOG TIMER The WDTO# pin is a multi-function pin with GP50 functions and is configured to the WDTO# function, if Configuration Register CR [2Dh], bit 0 is set to zero. The Watchdog Timer of the W83627DHG-P consists of an 8-bit programmable time-out counter and a control and status register. The time-out counter ranges from 1 to 255 minutes in the minute mode, or 1 to 255 seconds in the second mode. The units of Watchdog Timer counter are selected at Logical Device 8, CR [F5h], bit [3]. The time-out value is set at Logical Device 8, CR [F6h]. Writing zero disables the Watchdog Timer function. Writing any non-zero value to this register causes the counter to load this value into the Watchdog Timer counter and start counting down. The W83627DHG-P outputs a low signal to the WDTO# pin (pin 77) when a time-out event occurs. In other words, when the value is counted down to zero, the timer stops, and the W83627DHG-P sets the WDTO# status bit in Logical Device 8, CR [F7h], bit [4], outputting a low signal to the WDTO# pin (pin 77). Writing a zero will clear the status bit and the WDTO# pin returns to high. Writing a zero will clear the status bit. This bit will also be cleared if LRESET# or PWROK# signal is asserted. Additionally, GP40 (pin 85), GP42 (pin 83), GP44 (pin 81) and GP46 (pin 79) provides an alternative WDTO# function. This function can be configured by the relative GPIO control register. Please note that the output type of WDTO# (pin 77) and GP42 (pin 83) is push-pull and that of GP40 (pin 85), GP44 (pin 81) and GP46 (pin 79) is open-drain. -188- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 18. GENERAL PURPOSE I/O The W83627DHG-P provides 40 input/output ports that can be individually configured to perform a simple basic I/O function or alternative, pre-defined function. GPIO port 6 is configured through control registers in Logical Device 7, and GPIO ports 2 ~ 5 in Logical Device 9. Users can configure each individual port to be an input or output port by programming respective bit in selection register (0 = output, 1 = input). Invert port value by setting inversion register (0 = non -inverse, 1 = inverse). Port value is read / written through data register. In addition, only GP30, GP31 and GP35 are designed to be able to assert PSOUT# or PME# signal to wake up the system if any of them has any transitions. There are about 16mS debounced circuit inside these 3 GPIOs and it can be disabled by programming respective bit (LD9, CR [FEh] bit 4~6). Users can set what kind of event type, level or edge, and polarity, rising or falling, to perform the wake-up function. The following table gives a more detailed register map on GP30, GP31 and GP35. EVENTROUTE I (PSOUT#) EVENTROUTE II (PME#) EVENT DEBOUNCED EVENT TYPE EVENT POLARITY 0: DISABLE 1: ENABLE 0: DISABLE 1: ENABLE 0 : ENABLE 1 : DISABLE 0 : EDGE 1: LEVEL 0 : RISING 1 : FALLING EVENT STATUS GP30 LDA, CR[FEh] bit4 LDA, CR[FEh] bit0 LD9, CR[FEh] bit4 LD9, CR[FEh] bit0 LD9, CR[F2h] bit0 LD9, CR[E7h] bit0 GP31 LDA, CR[FEh] bit5 LDA, CR[FEh] bit1 LD9, CR[FEh] bit5 LD9, CR[FEh] bit1 LD9, CR[F2h] bit1 LD9, CR[E7h] bit1 GP35 LDA, CR[FEh] bit6 LDA, CR[FEh] bit2 LD9, CR[FEh] bit6 LD9, CR[FEh] bit2 LD9, CR[F2h] bit5 LD9, CR[E7h] bit5 -189- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 19. VID INPUTS AND OUTPUTS The W83627DHG-P provides eight pins for VID input or output function. The default function is VID input. These pins can be configured to VID output function by setting Logical Device B, CR [F0h], bit 7 to 0. The configuration is applied to the 8 pins as a group. None of them can be individually set to input or output. 19.1 VID Input Detection The W83627DHG-P supports Intel VRM 9/10/11 and AMD VRM VID detections. H/W strapping and S/W programming can set the following three input levels. a) and b) can be set by H/W strapping or S/W programming, while c) can only be set by S/W programming. a) TTL (Vih = 2 V; Vil = 0.8V) – 1) Add a pulled-down resistor at Pin 77(EN_GTL), or 2) Set Configuration Register CR [2Ch], bit 3 to “0”; b) GTL (Vih = 0.6 V; Vil = 0.4 V) – (Default) 1) No extra pulled-up resistor needed, or 2) Set Configuration Register CR [2Ch], bit 3 to “1”; c) AMD VRM (Vih = 1.4V; Vil = 0.8V) – Set Configuration Register CR [2Ch], bit 3 to “1” and Logical Device B, CR [F0h], bit 6 to “1”. The input data can be read in the data register at Logical Device B, CR [F1h], bit 7 ~ 0. It is a read/write register where bit 7~0 corresponds to VID pin 7~0. Please note that in the input mode, writes to this register have no effect. 19.2 VID Output Control The output type of the eight VID pins is push-pull, and they drive to 3VCC (3.3V) when configured to the output mode. The output data can be set in the data register (Logical Device B, CR [F1h], bit 7 ~ 0). The written data can be read if Configuration Register CR [2Ch], bit 3 is set to “0”. -190- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 20. PCI RESET BUFFERS The W83627DHG-P has five copies of LRESET# output buffers. LRESET# is LPC Interface Reset, to which PCI Reset is connected. The five copies of LRESET# in the W83627DHG-P are designated RSTOUT0#, RSTOUT1#, RSTOUT2#, RSTOUT3# and RSTOUT4#. All of them are powered by a 3VSB power. RSTOUT0# is an open-drain output buffer of LRESET#. This signal needs an external pulled-up resistor of 3.3V or 5V. RSTOUT1#, RSTOUT2#, RSTOUT3# and RSTOUT4# are push-pull output buffers of LRESET#. Each of them outputs 3.3V, voltage and the state is low when the 3VSB power is the only power source. -191- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 21. CONFIGURATION REGISTER 21.1 Chip (Global) Control Register CR 02h. (Software Reset; Write Only) BIT READ / WRITE 7~1 Reserved. 0 Write “1” Only DESCRIPTION Software RESET. CR 07h. (Logical Device; Default 00h) BIT READ / WRITE 7~0 R/W DESCRIPTION Logical Device Number. CR 20h. (Chip ID, High Byte; Read Only) BIT READ / WRITE 7~0 Read Only DESCRIPTION Chip ID number = B0h (high byte). CR 21h. (Chip ID, Low Byte; Read Only) BIT READ / WRITE 7~0 Read Only DESCRIPTION Chip ID number = 7Xh (low byte). X is the IC version CR 22h. (Device Power Down; Default FFh) BIT READ / WRITE DESCRIPTION 7 Reserved. 6 R/W HM Power Down. 0: Powered down. 1: Not powered down. 5 R/W UARTB Power Down. 0: Powered down. 1: Not powered down. 4 R/W UARTA Power Down. 0: Powered down. 1: Not powered down. 3 R/W PRT Power Down. 0: Powered down. 1: Not powered down. FDC Power Down. 0: Powered down. 1: Not powered down. 2~1 0 Reserved. R/W CR 23h. (IPD; Default 00h) BIT READ / WRITE 7~1 Reserved. 0 R/W DESCRIPTION IPD (Immediate Power Down). When set to 1, the whole chip is put into power-down mode immediately. -192- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT s: value by strapping CR 24h. (Global Option; Default 0100_0ss0b) BIT READ / WRITE 7 R/W Select output type of CPUFANOUT1 =0 CPUFANOUT1 is Push-pull. (Default) =1 CPUFANOUT1 is Open-drain. R/W CLKSEL => Input clock rate selection =0 The clock input on pin 18 is 24 MHz. =1 The clock input on pin 18 is 48 MHz. (Default) 5 R/W Select output type of AUXFANOUT =0 AUXFANOUT is Push-pull. (Default) =1 AUXFANOUT is Open-drain. 4 R/W Select output type of SYSFANOUT =0 SYSFANOUT is Open-drain. (Default) =1 SYSFANOUT is Push-pull. 3 R/W Select output type of CPUFANOUT0 =0 CPUFANOUT0 is Open-drain. (Default) =1 CPUFANOUT0 is Push-pull. 6 2 1 Read Only R/W DESCRIPTION ENKBC => Enable keyboard controller =0 KBC is disabled after hardware reset. =1 KBC is enabled after hardware reset. This bit is read-only, and it is set or reset by a power-on strapping pin (Pin 54, SOUTA). ENROM => Enable Serial Peripheral Interface =0 ROM is disabled after hardware reset. =1 ROM is enabled after hardware reset. This bit is set or reset by a power-on strapping pin (Pin 52, DTRA#). Note 1 0 Reserved. Note1: Disable Serial Peripheral Interface Enable Serial Peripheral Interface Pin 2 Æ GP23 Pin 2 Æ SCK Pin 19 Æ GP22 Pin 19 Æ SCE Pin 58 Æ AUXFANIN1 Pin 58 Æ SI Pin 118ÆBEEP Pin 118ÆSO CR 25h. (Interface Tri-state Enable; Default 00h) BIT READ / WRITE 7~6 Reserved. DESCRIPTION 5 R/W UARTBTRI 4 R/W UARTATRI 3 R/W PRTTRI -193- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT BIT READ / WRITE 2~1 Reserved. 0 R/W DESCRIPTION FDCTRI. CR 26h. (Global Option; Default 0s000000b) BIT 7 s: value by strapping READ / WRITE DESCRIPTION Reserved. 6 R/W HEFRAS => =0 Write 87h to location 2E twice. =1 Write 87h to location 4E twice. The corresponding power-on strapping pin is RTSA# (Pin 51). 5 R/W LOCKREG => =0 Enable R/W configuration registers. =1 Disable R/W configuration registers. 4 Reserved. 3 2 1 0 R/W DSFDLGRQ => =0 Enable FDC legacy mode for IRQ and DRQ selection. Then DO register (base address + 2) bit 3 is effective when selecting IRQ. =1 Disable FDC legacy mode for IRQ and DRQ selection. Then DO register (base address + 2) bit 3 is not effective when selecting IRQ. R/W DSPRLGRQ => =0 Enable PRT legacy mode for IRQ and DRQ selection. Then DCR register (base address + 2) bit 4 is effective when selecting IRQ. =1 Disable PRT legacy mode for IRQ and DRQ selection. Then DCR register (base address + 2) bit 4 is not effective when selecting IRQ. R/W DSUALGRQ => =0 Enable UART A legacy mode for IRQ selection. Then HCR register (base address + 4) bit 3 is effective when selecting IRQ. =1 Disable UART A legacy mode for IRQ selection. Then HCR register (base address + 4) bit 3 is not effective when selecting IRQ. R/W DSUBLGRQ => =0 Enable UART B legacy mode for IRQ selection. Then HCR register (base address + 4) bit 3 is effective when selecting IRQ. =1 Disable UART B legacy mode for IRQ selection. Then HCR register (base address + 4) bit 3 is not effective when selecting IRQ. CR 27h. (Reserved) CR 28h. (Global Option; Default 50h) BIT 7 READ / WRITE DESCRIPTION Reserved. -194- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT BIT READ / WRITE DESCRIPTION 6~5 R/W Flash ROM size select = 00 1M = 01 2M = 10 4M (Default) = 11 8M 4 R/W Select to enable/disable decoding of BIOS ROM range 000E xxxxh. =0 Enable decoding of BIOS ROM range at 000E xxxxh. =1 Disable decoding of BIOS ROM range at 000E xxxxh. 3 R/W Select to enable/disable decoding of BIOS ROM range FFE xxxxx. =0 Enable decoding of BIOS ROM range at FFE xxxxx. =1 Disable decoding of BIOS ROM range at FFE xxxxx. R/W PRTMODS2 ~ 0 => = 0xx Parallel Port Mode. = 100 Reserved. = 101 External FDC Mode = 110 Reserved = 111 External two FDC Mode 2~0 CR 29h. (Multi-function Pin Selection; Default 00h) BIT READ / WRITE 7 Reserved. 6 R/W 5~4 3 DESCRIPTION Pin 5 function select = 0 OVT# = 1 SMI# Reserved. R/W Pins 49 ~ 54, 56 ~ 57 function select =0 Pins 49 ~ 54, 56 ~ 57 Æ UART A =1 Pins 49 ~ 54, 56 ~ 57 Æ GPIO6 Pin 119 ~ 120 function select 2~1 0 R/W Bit-2 Bit-1 0 0 0 1 Pin 119 ~ 120 function Pin 119 ~ 120 Æ CPUFANIN1, CPUFANOUT1 (Default) Pin 119 ~ 120 Æ GP21, GP20 Reserved. -195- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT CR 2Ah. (SPI Configuration; Default 00h) BIT 7~6 5~4 (VSB Power) READ / WRITE DESCRIPTION R/W Serial Peripheral Interface Configuration bit. (VSB) = 00 Normal read. SPI clock is 16MHz. = 01 Normal read. SPI clock is 33MHz. = 10 Normal read. SPI clock is 22MHz. = 11 Reserved. Note: These two bits are ignored when CR24, bit 1 is “0” (SPI function is disabled). R/W Serial Peripheral Interface configuration bit.(VBAT) = 00 Normal read. The clock rate is based on the setting of CR [2Ah], bits [7:6] = 01 Reserved = 10 Reserved = 11 Fast read with one dummy byte. The clock rate is 33MHz. If set to “11”, CR [2Ah], bits [7:6] must be 0. Note: These two bits are ignored when CR24, bit 1 is “0”. (SPI function is disabled) 3 R/W SDA_filter_EN: 0: Enable SDA input to a filter 1: Disable SDA input to a filter 2 R/W SCL_filter_EN: 0: Enable SCL input to a filter 1: Disable SCL input to a filter R/W Pin 89, Pin 90 function select (I2C interface) =0 {Pin 89, Pin 90} Æ set by CR2C bits [6:5]. =1 {Pin 89, Pin 90} Æ SDA, SCL. R/W KB, MS pin function select =0 KB, MS function. =1 GPIO function. (GP24, GP25, GP26 and GP27) 1 0 * Normal Read: Read 1-byte data. Fast Read: Read 4-byte data. CR 2Bh. (Reserved) CR 2Ch. (Multi-function Pin Selection; Default E2h) BIT READ / WRITE 7 R/W 6 R/W (VSB Power) DESCRIPTION Pin 88 Select =0 GP34 =1 RSTOUT4# (Default) Pin 89 Select =0 GP33 =1 RSTOUT3# (Default) Note: This bit is ignored when CR2A, bit 1 is High. -196- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT BIT 5 READ / WRITE R/W DESCRIPTION Pin 90 Select =0 GP32 =1 RSTOUT2# (Default) Note: This bit is ignored when CR2A, bit 1 is High. 4 Read Only EN_ACPI status bit =0 Particular ACPI functions are disabled. =1 Particular ACPI functions are enabled. The bit is strapped by Pin 70 (GP55). While particular ACPI functions are enabled (EN_ACPI = 1), GPIO3 pins (pins 64, 69, 87, 91 and 92) are disabled and the particular ACPI functions are activated (SUSC#, FTPRST#, ATXPGD, VSBGATE# and PWROK2) 3 R/W EN_GTL Configure bit =0 VID input voltage is TTL. =1 VID input voltage is GTL. The bit is strapped by Pin 77 (GP50).--- Internal Pull high to 3VSB. 2 R/W EN_PWRDN. (VBAT) =0 Thermal shutdown function is disabled. =1 Enable thermal shutdown function. Pins 78 ~ 85 function select Bit-1 1~0 Bit-0 0 0 0 1 1 1 0 1 R/W Pins 78 ~ 85 function Pin 82 Æ Reserved (tri-state) Pin 83 Æ Reserved (always low) Others Æ GPIO4 Pin 82 Æ IRRX Pin 83 Æ IRTX Others Æ GPIO4 Pins 78 ~ 85 Æ GPIO4 Pins 78 ~ 85 Æ UART B CR 2Dh. (Multi-function Pin Selection; default 21h) (VSB Power) BIT READ / WRITE 7 R/W Pin 67 Select (reset by RSMRST#) =0 PSOUT# =1 GPIO57 6 R/W Pin 68 Select (reset by RSMRST#) =0 PSIN# =1 GPIO56 R/W Pin 70 Select (reset by RSMRST#) =0 SUSLED =1 GPIO55 5 DESCRIPTION -197- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT BIT READ / WRITE 4 R/W Pin 71 Select (reset by RSMRST#) =0 PWROK =1 GPIO54 3 R/W Pin 72 Select (reset by RSMRST#) =0 PSON# =1 GPIO53 2 R/W Pin 73 Select (reset by RSMRST#) =0 SUSB# =1 GPIO52 R/W Pin 75 Select (reset by RSMRST#) =0 RSMRST# =1 GPIO51 R/W Pin 77 Select (reset by RSMRST#) =0 WDTO# =1 GPIO50 1 0 DESCRIPTION CR 2Eh. (Default 00h) BIT READ / WRITE 7~0 R/W DESCRIPTION Test Mode Bits: Reserved for Nuvoton. CR 2Fh. (Default 00h) BIT READ / WRITE 7~0 R/W DESCRIPTION Test Mode Bits: Reserved for Nuvoton. -198- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 21.2 Logical Device 0 (FDC) CR 30h. (Default 01h) BIT READ / WRITE 7~1 Reserved. 0 R/W DESCRIPTION 0: Logical device is inactive. 1: Activate the logical device. CR 60h, 61h. (Default 03h,F0h) BIT READ / WRITE DESCRIPTION 7~0 R/W These two registers select FDC I/O base address on 8 bytes boundary. CR 70h. (Default 06h) BIT READ / WRITE 7~4 Reserved. 3~0 R/W DESCRIPTION These bits select IRQ resource for FDC. CR 74h. (Default 02h) BIT READ / WRITE 7~3 Reserved. 2~0 R/W DESCRIPTION These bits select DRQ resource for FDC. 000: DMA0. 001: DMA1. 010: DMA2. 1xx: No DMA active. 011: DMA3. CR F0h. (Default 8Eh) BIT 7 READ / WRITE DESCRIPTION Reserved. 6 R/W This bit determines the polarity of all FDD interface signals. 0: FDD interface signals are active low. 1: FDD interface signals are active high. 5 R/W When this bit is logic 0, indicates a second drive is installed and is reflected in status register A. (PS2 mode only) 4 R/W Swap Drive 0, 1 Mode => 0: No Swap. 1: Drive and Motor select 0 and 1 are swapped. 3~2 R/W 1 R/W Interface Mode. 00: Model 30. 10: Reserved. FDC DMA Mode. 0: Burst Mode is enabled 1: Non-Burst Mode. -199- 01: PS/2. 11: AT Mode Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT BIT READ / WRITE 0 R/W DESCRIPTION Floppy Mode. 0: Normal Floppy Mode. 1: Enhanced 3-mode FDD. CR F1h. (Default 00h) BIT READ / WRITE 7~6 R/W 5~4 R/W Media ID1, Media ID0. These bits will be reflected on FDC’s Tape Drive Register bit 7, 6. 3~2 R/W Density Select. 00: Normal. 10: 1 (Forced to logic 1). 1 R/W DISFDDWR => 0: Enable FDD write. 1: Disable FDD write (forces pins WE, WD to stay high). R/W SWWP => 0: Normal, use WP to determine whether the FDD is write protected or not. 1: FDD is always write-protected. 0 DESCRIPTION Boot Floppy. 00: FDD A. 10: Reserved. 01: Reserved. 11: Reserved. 01: Normal. 11: 0 (Forced to logic 0). CR F2h. (Default FFh) BIT READ / WRITE 7~2 Reserved. 1~0 R/W DESCRIPTION FDD A Drive Type. CR F4h. (Default 00h) BIT READ / WRITE 7 Reserved. 6 R/W 5 Reserved. 4~3 2 1~0 R/W DESCRIPTION 0: Enable FDC Pre-compensation. 1: Disable FDC Pre-compensation. Data Rate Table selection (Refer to TABLE A). 00: Select regular drives and 2.88 format. 01: 3-mode drive. 10: 2 Meg Tape. 11: Reserved. Reserved. R/W Drive Type selection (Refer to TABLE B). -200- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT CR F5h. (Default 00h) BIT READ / WRITE 7~0 R/W DESCRIPTION Same as FDD0 of CR F5h. TABLE A DRIVE RATE TABLE SELECT DRTS1 0 DRTS0 0 0 1 1 0 DATA RATE SELECTED DATA RATE SELDEN DRATE1 DRATE0 MFM FM 1 1 1Meg --- 1 0 0 500K 250K 1 0 1 300K 150K 0 1 0 250K 125K 0 1 1 1Meg --- 1 0 0 500K 250K 1 0 1 500K 250K 0 1 0 250K 125K 0 1 1 1Meg --- 1 0 0 500K 250K 1 0 1 2Meg --- 0 1 0 250K 125K 0 TABLE B DTYPE0 DTYPE1 DRVDEN0 (pin 2) DRIVE TYPE 4/2/1 MB 3.5”“ 0 0 SELDEN 2/1 MB 5.25” 2/1.6/1 MB 3.5” (3-MODE) 0 1 DRATE1 1 0 SELDEN 1 1 DRATE0 -201- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 21.3 Logical Device 1 (Parallel Port) CR 30h. (Default 01h) BIT READ / WRITE 7~1 Reserved. 0 R/W DESCRIPTION *0: Logical device is inactive. 1: Activate the logical device. *: If customer need EXTFDC function, bit 0 should be 0. CR 60h, 61h. (Default 03h, 78h) BIT 7~0 READ / WRITE DESCRIPTION R/W These two registers select PRT I/O base address. on 4-byte boundary (EPP not supported) or on 8-byte boundary (all modes supported, EPP is only available when the base address is on 8-byte boundary). CR 70h. (Default 07h) BIT READ / WRITE 7~4 Reserved. 3~0 R/W DESCRIPTION These bits select IRQ resource for PRT. CR 74h. (Default 04h) BIT READ / WRITE 7~3 Reserved. 2~0 R/W DESCRIPTION These bits select DRQ resource for PRT. 000: DMA0. 001: DMA1. 010: DMA2. 1xx: No DMA active. 011: DMA3. CR F0h. (Default 3Fh) BIT 7 6~3 2~0 READ / WRITE DESCRIPTION Reserved. R/W ECP FIFO Threshold. R/W Parallel Port Mode selection (CR28 bit2 PRTMODS2 = 0). 000: Standard and Bi-direction (SPP) mode. 001: EPP – 1.9 and SPP mode. 010: ECP mode. 011: ECP and EPP – 1.9 mode. 100: Printer Mode. 101: EPP – 1.7 and SPP mode. 110: Reserved. 111: ECP and EPP – 1.7 mode. -202- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 21.4 Logical Device 2 (UART A) CR 30h. (Default 01h) BIT READ / WRITE 7~1 Reserved. 0 R/W DESCRIPTION 0: Logical device is inactive. 1: Activate the logical device. CR 60h, 61h. (Default 03h, F8h) BIT READ / WRITE DESCRIPTION 7~0 R/W These two registers select Serial Port 1 I/O base address on 8 bytes boundary. CR 70h. (Default 04h) BIT READ / WRITE 7~4 Reserved. 3~0 R/W DESCRIPTION These bits select IRQ resource for Serial Port 1. CR F0h. (Default 00h) BIT READ / WRITE 7~2 Reserved. 1~0 R/W DESCRIPTION 00: UART A clock source is 1.8462 MHz (24 MHz / 13). 01: UART A clock source is 2 MHz (24 MHz / 12). 10: UART A clock source is 24 MHz (24 MHz / 1). 11: Reserved -203- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 21.5 Logical Device 3 (UART B) CR 30h. (Default 01h) BIT READ / WRITE 7~1 Reserved. 0 R/W DESCRIPTION 0: Logical device is inactive. 1: Activate the logical device. CR 60h, 61h. (Default 02h, F8h) BIT READ / WRITE DESCRIPTION 7~0 R/W These two registers select Serial Port 2 I/O base address on eight-byte boundary. CR 70h. (Default 03h) BIT READ / WRITE 7~4 Reserved. 3~0 R/W DESCRIPTION These bits select IRQ resource for Serial Port 2. CR F0h. (Default 00h) BIT READ / WRITE 7~4 Reserved. 3 2 1~0 DESCRIPTION R/W 0: No reception delay when SIR is changed from TX mode to RX mode. 1: Reception delayed for 4 characters’ time (40 bit-time) when SIR is changed from TX mode to RX mode. R/W 0: No transmission delay when SIR is changed from RX mode to TX mode. 1: Transmission delayed for 4 characters’ time (40 bit-time) when SIR is changed from RX mode to TX mode. R/W 00: UART B clock source is 1.8462 MHz (24 MHz / 13). 01: UART B clock source is 2 MHz (24 MHz / 12). 10: UART B clock source is 24 MHz (24 MHz / 1). 11: Reserved -204- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT CR F1h. (Default 00h) BIT READ / WRITE DESCRIPTION 7 R/W Reserved. 6 R/W IRLOCSEL => IR I/O pins’ location selection. 0: Through SINB / SOUTB. 1: Through IRRX / IRTX. 5~3 R/W IRMODE => IR function mode selection. See the table below. 2 R/W IR half / full duplex function selection. 0: IR function is Full Duplex. 1: IR function is Half Duplex. 1 R/W 0: SOUTB pin of UART B function or IRTX pin of IR function in normal condition. 1: Inverse SOUTB pin of UART B function or IRTX pin of IR function. 0 R/W 0: SINB pin of UART B function or IRRX pin of IR function in normal condition. 1: Inverse SINB pin of UART B function or IRRX pin of IR function. IR MODE IR FUNCTION IRTX IRRX 00X Disable Tri-state High 010* IrDA Active pulse 1.6 μS Demodulation into SINB/IRRX 011* IrDA Active pulse 3/16 bit time Demodulation into SINB/IRRX 100 ASK-IR Inverting IRTX/SOUTB pin Routed to SINB/IRRX 101 ASK-IR 110 ASK-IR 111* ASK-IR Inverting IRTX/SOUTB & 500 KHZ clock Inverting IRTX/SOUTB Inverting IRTX/SOUTB & 500 KHZ clock Routed to SINB/IRRX Demodulation into SINB/IRRX Demodulation into SINB/IRRX Note: The notation is normal mode in the IR function. -205- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 21.6 Logical Device 5 (Keyboard Controller) CR 30h. (Default 01h) BIT READ / WRITE 7~1 Reserved. 0 R/W DESCRIPTION 0: The logical device is inactive. 1: The logical device is active. CR 60h, 61h. (Default 00h,60h) BIT READ / WRITE DESCRIPTION 7~0 R/W These two registers select the first KBC I/O base address on 1-byte boundary. CR 62h, 63h. (Default 00h,64h) BIT READ / WRITE DESCRIPTION 7~0 R/W These two registers select the second KBC I/O base address on 1 byte boundary. CR 70h. (Default 01h) BIT READ / WRITE 7~4 Reserved. 3~0 R/W DESCRIPTION These bits select IRQ resource for KINT. (Keyboard interrupt) CR 72h. (Default 0Ch) BIT READ / WRITE 7~4 Reserved. 3~0 R/W DESCRIPTION These bits select IRQ resource for MINT. (PS/2 Mouse interrupt) CR F0h. (Default83h) BIT READ / WRITE 7~6 R/W 5~3 Reserved. DESCRIPTION KBC clock rate 00: Reserve 01: Reserve 10: 12MHz 11: Reserve 2 R/W 0: Port 92 disable. 1: Port 92 enable. 1 R/W 0: Gate A20 software control. 1: Gate A20 hardware speed up. -206- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT BIT READ / WRITE 0 R/W DESCRIPTION 0: KBRST# software control. 1: KBRST# hardware speed up. -207- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 21.7 Logical Device 6 (Serial Peripheral Interface) CR 30h. (Default 00h) BIT READ / WRITE 7~1 Reserved. 0 R/W DESCRIPTION 0: Serial Peripheral Interface is inactive. 1: Activate Serial Peripheral Interface. CR 62h, 63h. (Default 00h) BIT READ / WRITE DESCRIPTION 7~0 R/W These two registers select Serial Peripheral Interface I/O base address on 1 byte boundary. -208- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 21.8 Logical Device 7 (GPIO6) CR 30h. (Default 00h) BIT READ / WRITE 7~4 Reserved. 3 2~0 R/W DESCRIPTION 0: GPIO6 is inactive. 1: GPIO6 is active. Reserved. CR F4h. (GPIO6 I/O Register; Default FFh) BIT READ / WRITE 7~0 R/W DESCRIPTION GPIO6 I/O register 0: The respective GPIO6 PIN is programmed as an output port 1: The respective GPIO6 PIN is programmed as an input port. CR F5h. (GPIO6 Data Register; Default 00h) BIT READ / WRITE R/W 7~0 Read Only DESCRIPTION GPIO6 Data register For output ports, the respective bits can be read and written by the pins. For input ports, the respective bits can be read only from pins. Write accesses will be ignored. CR F6h. (GPIO6 Inversion Register; Default 00h) BIT 7~0 READ / WRITE DESCRIPTION R/W GPIO6 Inversion register 0: The respective bit and the port value are the same. 1: The respective bit and the port value are inverted. (Applies to both input and output ports) CR F7h. (Status Register; Default 00h) BIT 7~0 READ / WRITE Read Only Read-Clear DESCRIPTION GPIO6 Event Status Bit 7-0 corresponds to GP67-GP60, respectively. 0 : No active edge(rising/falling) has been detected 1 : An active edge(rising/falling) has been detected Read the status bit clears it to 0. CR F8h. (GPIO6 Multi-function Select Register; Default 00h) BIT 7 READ / WRITE R/W DESCRIPTION 0: GPIO67 1: GPIO67 Æ PLED -209- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT BIT READ / WRITE DESCRIPTION 6 R/W 0: GPIO66 1: GPIO66 Æ PLED 5 R/W 0: GPIO65 1: GPIO65 Æ PLED 4 R/W 0: GPIO64 1: GPIO64 Æ PLED 3 R/W 0: GPIO63 1: GPIO63 Æ PLED 2 R/W 0: GPIO62 1: GPIO62 Æ PLED 1 R/W 0: GPIO61 1: GPIO61 Æ PLED 0 R/W 0: GPIO60 1: GPIO60 Æ PLED -210- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 21.9 Logical Device 8 (WDTO# & PLED) CR 30h. (Default 00h) BIT READ / WRITE 7~1 Reserved. 0 R/W DESCRIPTION 0: WDTO# and PLED are inactive. 1: Activate WDTO# and PLED. CR F5h. (WDTO#, PLED and KBC P20 Control Mode Register; Default 00h) BIT READ / WRITE DESCRIPTION R/W Select Power LED mode. 000: Power LED pin is driven high. 001: Power LED pin outputs 0.5Hz pulse with 50% duty cycle. 010: Power LED pin is driven low. 011: Power LED pin outputs 2Hz pulse with 50% duty cycle. 100: Power LED pin outputs 1Hz pulse with 50% duty cycle. 101: Power LED pin outputs 4Hz pulse with 50% duty cycle. 110: Power LED pin outputs 0.25Hz pulse with 50% duty cycle. 111: Power LED pin outputs 0.25Hz pulse with 50% duty cycle. 4 R/W WDTO# count mode is 1000 times faster. 0: Disable. 1: Enable. (If bit-3 is in Seconds Mode, the count mode is 1/1000 sec.) (If bit-3 is in Minutes Mode, the count mode is 1/1000 min.) 3 R/W Select WDTO# count mode. 0: Second Mode. 1: Minute Mode. R/W Enable the rising edge of a KBC reset (P20) to issue a time-out event. 0: Disable. 1: Enable. 1 R/W Disable / Enable the WDTO# output low pulse to the KBRST# pin (PIN60) 0: Disable. 1: Enable. 0 Reserved. 7~5 2 -211- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT CR F6h. (WDTO# Counter Register; Default 00h) BIT 7~0 READ / WRITE R/W DESCRIPTION Watch Dog Timer Time-out value. Writing a non-zero value to this register causes the counter to load the value into the Watch Dog Counter and start counting down. If CR F7h, bits 7 and 6 are set, any Mouse Interrupt or Keyboard Interrupt event causes the previouslyloaded, non-zero value to be reloaded to the Watch Dog Counter and the count down resumes. Reading this register returns the current value in the Watch Dog Counter, not the Watch Dog Timer Time-out value. 00h: Time-out Disable 01h: Time-out occurs after 1 minute only. 02h: Time-out occurs after 2 second/minutes 03h: Time-out occurs after 3 second/minutes ………………………....................................... FFh: Time-out occurs after 255 second/minutes (The deviation is approx 1 second.) CR F7h. (WDTO# Control & Status Register; Default 00h) BIT READ / WRITE DESCRIPTION 7 R/W Mouse interrupt reset enables watch-dog timer reload 0: Watchdog timer is not affected by mouse interrupt. 1: Watchdog timer is reset by mouse interrupt. 6 R/W Keyboard interrupt reset enables watch-dog timer reload 0: Watchdog timer is not affected by keyboard interrupt. 1: Watchdog timer is reset by keyboard interrupt. 5 Write “1” Only Trigger WDTO# event. This bit is self-clearing. 4 R/W Write “0” Clear WDTO# status bit 0: Watchdog timer is running. 1: Watchdog timer issues time-out event. 3~0 R/W These bits select the IRQ resource for the WDTO#. (02h for SMI# event.) -212- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 21.10 Logical Device 9 (GPIO2, GPIO3, GPIO4, GPIO5) CR 30h. (Default 00h) BIT READ / WRITE 7~4 Reserved. DESCRIPTION 3 R/W 0: GPIO5 is inactive. 1: GPIO5 is active 2 R/W 0: GPIO4 is inactive. 1: GPIO4 is active. 1 R/W 0: GPIO3 is inactive. 1: GPIO3 is active. 0 R/W 0: GPIO2 is inactive. 1: GPIO2 is active. CR E0h. (GPIO5 I/O Register; Default FFh) BIT 7~0 READ / WRITE R/W DESCRIPTION GPIO5 I/O register 0: The respective GPIO5 PIN is programmed as an output port 1: The respective GPIO5 PIN is programmed as an input port. CR E1h. (GPIO5 Data Register; Default 00h) BIT READ / WRITE R/W 7~0 Read Only DESCRIPTION GPIO5 Data register For output ports, the respective bits can be read and written by the pins. For input ports, the respective bits can only be read by the pins. Write accesses are ignored. CR E2h. (GPIO5 Inversion Register; Default 00h) BIT 7~0 READ / WRITE DESCRIPTION R/W GPIO5 Inversion register 0: The respective bit and the port value are the same. 1: The respective bit and the port value are inverted. (Applies to both input and output ports) CR E3h. (GPIO2 Register; Default FFh) BIT 7~0 READ / WRITE R/W DESCRIPTION GPIO2 I/O register 0: The respective GPIO2 PIN is programmed as an output port 1: The respective GPIO2 PIN is programmed as an input port -213- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT CR E4h. (GPIO2 Data Register; Default 00h) BIT READ / WRITE R/W 7~0 Read Only DESCRIPTION GPIO2 Data register For output ports, the respective bits can be read and written by the pins. For input ports, the respective bits can only be read by the pins. Write accesses are ignored. CR E5h. (GPIO2 Inversion Register; Default 00h) BIT 7~0 READ / WRITE DESCRIPTION R/W GPIO2 Inversion register 0: The respective bit and the port value are the same. 1: The respective bit and the port value are inverted. (Applies to both input and output ports) CR E6h. (GPIO2 Status Register; Default 00h) BIT 7~0 READ / WRITE Read Only Read-Clear DESCRIPTION GPIO2 Event Status Bit 7-0 corresponds to GP27-GP20, respectively. 0 : No active edge(rising/falling) has been detected 1 : An active edge(rising/falling) has been detected Read the status bit clears it to 0. CR E7h. (GPIO3 Status Register; Default 00h) BIT 7~0 READ / WRITE Read Only Read-Clear DESCRIPTION GPIO3 Event Status Bit 7-0 corresponds to GP37-GP30, respectively. 0 : No active edge(rising/falling) has been detected 1 : An active edge(rising/falling) has been detected Read the status bit clears it to 0. CR E8h. (GPIO4 Status Register; Default 00h) BIT 7~0 READ / WRITE Read Only Read-Clear DESCRIPTION GPIO4 Event Status Bit 7-0 corresponds to GP47-GP40, respectively. 0 : No active edge(rising/falling) has been detected 1 : An active edge(rising/falling) has been detected Reading the status bit clears it to 0. -214- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT CR E9h. (GPIO5 Status Register; Default 00h) BIT 7 READ / WRITE Read Only Read-Clear DESCRIPTION GPIO5 Event Status Bit 7-0 corresponds to GP57-GP50, respectively. 0 : No active edge(rising/falling) has been detected 1 : An active edge(rising/falling) has been detected Reading the status bit clears it to 0. CR F0h. (GPIO3 I/O Register; Default FFh) BIT READ / WRITE 7~0 R/W DESCRIPTION GPIO3 I/O register 0: The respective GPIO3 PIN is programmed as an output port 1: The respective GPIO3 PIN is programmed as an input port. CR F1h. (GPIO3 Data Register; Default 00h) BIT READ / WRITE R/W 7~0 Read Only DESCRIPTION GPIO3 Data register For output ports, the respective bits can be read and written by the pins. For input ports, the respective bits can only be read by the pins. Write accesses are ignored. CR F2h. (GPIO3 Inversion Register; Default 00h) BIT 7~0 READ / WRITE DESCRIPTION R/W GPIO3 Inversion register 0: The respective bit and the port value are the same. 1: The respective bit and the port value are inverted. (Applies to both input and output ports) CR F3h. (Suspend LED Mode Register; Default 00h) BIT (VBAT power) READ / WRITE DESCRIPTION 7~5 R/W Select Suspend LED mode.(SUSLED) 000: Suspend LED pin is driven high. 001: Suspend LED pin outputs 0.5Hz pulse with 50% duty cycle. 010: Suspend LED is driven low. 011: Suspend LED pin outputs 2Hz pulse with 50% duty cycle. 100: Suspend LED pin outputs 1Hz pulse with 50% duty cycle. 101: Suspend LED pin outputs 4Hz pulse with 50% duty cycle. 110: Suspend LED pin outputs 0.25Hz pulse with 50% duty cycle. 111: Suspend LED pin outputs 0.25Hz pulse with 50% duty cycle. 4~0 Reserved. -215- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT CR F4h. (GPIO4 I/O Register; Default FFh) BIT READ / WRITE 7~0 R/W DESCRIPTION GPIO4 I/O register 0: The respective GPIO4 PIN is programmed as an output port 1: The respective GPIO4 PIN is programmed as an input port. CR F5h. (GPIO4 Data Register; Default 00h) BIT READ / WRITE R/W 7~0 Read Only DESCRIPTION GPIO4 Data register For output ports, the respective bits can be read and written by the pins. For input ports, the respective bits can only be read by the pins. Write accesses are ignored. CR F6h. (GPIO4 Inversion Register; Default 00h) BIT 7~0 READ / WRITE DESCRIPTION R/W GPIO4 Inversion register 0: The respective bit and the port value are the same. 1: The respective bit and the port value are inverted. (Applies to both input and output ports) CR F7h. (GPIO4 Multi-function Select Register; Default 00h) BIT READ / WRITE DESCRIPTION 7 R/W 0: GPIO47 1: GPIO47 Æ SUSLED 6 R/W 0: GPIO46 1: GPIO46 Æ WDTO# 5 R/W 0: GPIO45 1: GPIO45 Æ SUSLED 4 R/W 0: GPIO44 1: GPIO44 Æ WDTO# 3 R/W 0: GPIO43 1: GPIO43 Æ SUSLED 2 R/W 0: GPIO42 1: GPIO42 Æ WDTO# 1 R/W 0: GPIO41 1: GPIO41 Æ SUSLED 0 R/W 0: GPIO40 1: GPIO40 Æ WDTO# -216- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT CR F8h. (GPIO2 Multi-function Select Register; Default 00h) BIT READ / WRITE DESCRIPTION 7 R/W 0: GPIO27 1: GPIO27 Æ SUSLED 6 R/W 0: GPIO26 1: GPIO26 Æ SUSLED 5 R/W 0: GPIO25 1: GPIO25 Æ SUSLED 4 R/W 0: GPIO24 1: GPIO24 Æ SUSLED 3 R/W 0: GPIO23 1: GPIO23 Æ PLED 2 R/W 0: GPIO22 1: GPIO22 Æ PLED 1 R/W 0: GPIO21 1: GPIO21 Æ PLED 0 R/W 0: GPIO20 1: GPIO20 Æ PLED CR F9h. (GPIO3 Multi-function Select Register; Default 00h) BIT READ / WRITE DESCRIPTION 7 R/W 0: GPIO37 1: GPIO37 Æ SUSLED 6 R/W 0: GPIO36 1: GPIO36 Æ SUSLED 5 R/W 0: GPIO35 1: GPIO35 Æ SUSLED 4 R/W 0: GPIO34 1: GPIO34 Æ SUSLED 3 R/W 0: GPIO33 1: GPIO33 Æ SUSLED 2 R/W 0: GPIO32 1: GPIO32 Æ SUSLED 1 R/W 0: GPIO31 1: GPIO31 Æ SUSLED 0 R/W 0: GPIO30 1: GPIO30 Æ SUSLED -217- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT CR FAh. (GPIO5 Multi-function Select Register; Default 00h) BIT READ / WRITE DESCRIPTION 7 R/W 0: GPIO57 1: GPIO57 Æ SUSLED 6 R/W 0: GPIO56 1: GPIO56 Æ SUSLED 5 R/W 0: GPIO55 1: GPIO55 Æ SUSLED 4 R/W 0: GPIO54 1: GPIO54 Æ SUSLED 3 R/W 0: GPIO53 1: GPIO53 Æ SUSLED 2 R/W 0: GPIO52 1: GPIO52 Æ SUSLED 1 R/W 0: GPIO51 1: GPIO51 Æ SUSLED 0 R/W 0: GPIO50 1: GPIO50 Æ SUSLED CR FEh. (GPIO3 Input Detected Type Register; Default 00h) BIT READ / WRITE DESCRIPTION 7 R/W Reserved. 6 R/W 0: Enable GP35 input de-bouncer 1: Disable GP35 input de-bouncer 5 R/W 0: Enable GP31 input de-bouncer 1: Disable GP31 input de-bouncer 4 R/W 0: Enable GP30 input de-bouncer 1: Disable GP30 input de-bouncer 3 Reserved. 2 R/W 0: GP35 trigger type : edge 1: GP35 trigger type : level 1 R/W 0: GP31 trigger type : edge 1: GP31 trigger type : level 0 R/W 0: GP30 trigger type : edge 1: GP30 trigger type : level -218- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 21.11 Logical Device A (ACPI) (CR30, CR70 are VCC powered; CRE0~F7 are VRTC powered) CR 30h. (Default 00h) BIT READ / WRITE 7~1 Reserved. 0 R/W DESCRIPTION 0: Logical Device A CR70h function is inactive. 1: Logical Device A CR70h function is active. CR 70h. (Default 00h) BIT READ / WRITE 7~4 Reserved. 3~0 R/W DESCRIPTION These bits select the IRQ resource for PME#. CR E0h. (Default 01h) (VBAT power) BIT READ / WRITE DESCRIPTION 7 R/W DIS_PSIN => Disable the panel switch input to turn on the system power supply. 0: PSIN is wire-AND and connected to PSOUT#. 1: PSIN is blocked and cannot affect PSOUT#. 6 R/W Enable KBC wake-up 0: Disable keyboard wake-up function via PSOUT#. 1: Enable keyboard wake-up function via PSOUT#. 5 R/W Enable Mouse wake-up 0: Disable mouse wake-up function via PSOUT#. 1: Enable mouse wake-up function via PSOUT#. MSRKEY => Three keys (ENMDAT_UP, CRE6[7]; MSRKEY, CRE0[4]; MSXKEY, CRE0[1]) define the combinations of the mouse wake-up events. Please see the following table for the details. ENMDAT_UP MSRKEY 4 3 R/W MSXKEY Wake-up event 1 x 1 Any button clicked or any movement. 1 x 0 One click of left or right button. 0 0 0 0 0 1 0 1 1 1 0 0 One click of the left button. One click of the right button. Two clicks of the left button. Two clicks of the right button. Reserved. -219- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT BIT 2 1 0 READ / WRITE DESCRIPTION R/W Keyboard / Mouse swap enable 0: Normal mode. 1: Keyboard / Mouse ports are swapped. R/W MSXKEY => Three keys (ENMDAT_UP, CRE6[7]; MSRKEY, CRE0[4]; MSXKEY, CRE0[1]) define the combinations of the mouse wake-up events. Please check out the table in CRE0[4] for the detailed. R/W KBXKEY => 0: Only the pre-determined key combination in sequence can wake up the system. 1: Any character received from the keyboard can wake up the system. CR E1h. (KBC Wake-Up Index Register; Default 00h) (VSB power) BIT 7~0 READ / WRITE DESCRIPTION R/W Keyboard wake-up index register. This is the index register of CRE2, which is the access window for the keyboard’s pre-determined key key-combination characters. The first set of wake-up keys is in of 0x00 – 0x0E, the second set 0x30 – 0x3E, and the third set 0x40 – 0x4E. Incoming key combinations can be read through 0x10 – 0x1E. CR E2h. (KBC Wake-Up Data Register; Default FFh) (VSB power) BIT READ / WRITE DESCRIPTION 7~0 R/W Keyboard wake-up data register. This is the data register for the keyboard’s pre-determined keycombination characters, which is indexed by CRE1. CR E3h. (Event Status Register; Default 08h) BIT READ / WRITE 7~6 Reserved. Read Only Read-Clear 5 DESCRIPTION This status flag indicates VSB power off/on. 4 Read Only Read-Clear This bit is always 0 0: When power-loss occurs and the VSB power is on, turn on system power. 3 Read Only Read-Clear Thermal shutdown status. 0: No thermal shutdown event issued. 1: Thermal shutdown event issued. 2 Read Only Read-Clear PSIN_STS 0: No PSIN event issued. 1: PSIN event issued. -220- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT BIT READ / WRITE DESCRIPTION 1 Read Only Read-Clear MSWAKEUP_STS => The bit is latched by the mouse wake-up event. 0: No mouse wake-up event issued. 1: Mouse wake-up event issued. 0 Read Only Read-Clear KBWAKEUP_STS => The bit is latched by the keyboard wake-up event. 0: No keyboard wake-up event issued. 1: Keyboard wake-up event issued. CR E4h. (Default 00h) BIT 7 READ / WRITE DESCRIPTION Reserved R/W Power-loss control bits => (VBAT) 00: System always turns off when it returns from power-loss state. 01: System always turns on when it returns from power-loss state. 10: System turns off / on when it returns from power-loss state depending on the state before the power loss. 11: User defines the state before power loss.(i.e. the last state set of CRE6[4]) 4 R/W VSBGATE# Enable bit => 0: Disable. 1: Enable. 3 R/W 2 R/W 6~5 1~0 Keyboard wake-up options. (LRESET#) 0: Password or sequence hot keys programmed in the registers. 1: Any key. Enable the hunting mode for all wake-up events set in CRE0. This bit is cleared when any wake-up events is captured. (LRESET#) 0: Disable. 1: Enable. Reserved. CR E5h. (GPIOs Reset Source Register; Default 00)) BIT 7~ 5 4 3 2 READ / WRITE DESCRIPTION Reserved. R/W VID_MRST 0: VID reset by LRESET#. 1: VID reset by PWROK. R/W GP23_MRST 0: GP23 reset by LRESET#. 1: GP23 reset by PWROK. R/W GP22_MRST 0: GP22 reset by LRESET#. 1: GP22 reset by PWROK. -221- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT BIT 1 0 READ / WRITE DESCRIPTION R/W PWROK source selection. 0: PSON# 1: SUSB# R/W ATXPGD signal to control PWROK and PWROK2 generation 0: Enable. 1: Disable. CR E6h. (Default 1Ch) BIT READ / WRITE 7 6 R/W DESCRIPTION ENMDAT => (VSB) Three keys (ENMDAT_UP, CRE6[7]; MSRKEY, CRE0[4]; MSXKEY, CRE0[1]) define the combinations of the mouse wake-up events. Please see the table in CRE0, bit 4 for the details. Reserved. R/W CASEOPEN Clear Control. (VSB) Write 1 to this bit to clear CASEOPEN status. This bit will not clear the status itself. Please write 0 after an event is cleared. The function is the same as Index 46h bit 7 of H/W Monitor part. R/W Power-loss Last State Flag. (VBAT) 0: ON 1: OFF. 3~1 R/W PWROK_DEL (VSB) Set the delay time when rising from 3VCC to PWROK Bits 321 0 0 0: 300 ~ 600mS 0 0 1: 330 ~ 670mS 0 1 0: 390 ~ 730mS 0 1 1: 520 ~ 860mS 1 0 0: 200 ~ 300mS 1 0 1: 230 ~ 370mS 1 1 0: 290 ~ 430mS 1 1 1: 420 ~ 560mS 0 R / W-Clear PWROK_TRIG => Write 1 to re-trigger the PWROK signal from low to high. 5 4 -222- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT CR E7h. (Default 00h) BIT 7 6 5 4 3 2~1 0 READ / WRITE DESCRIPTION R/W ENKD3 => (VSB) Enable the third set of keyboard wake-up key combination. Its values are accessed through keyboard wake-up index register (CRE1) and keyboard wake-up data register (CRE2) at the index from 40h to 4eh. 0: Disable the third set of the key combinations. 1: Enable the third set of the key combinations. R/W ENKD2 => (VSB) Enable the second set of keyboard wake-up key combination. Its values are accessed through keyboard wake-up index register (CRE1) and keyboard wake-up data register (CRE2) at the index from 30h to 3eh. 0: Disable the second set of the key combinations. 1: Enable the second set of the key combinations. R/W ENWIN98KEY => (VSB) Enable Win98 keyboard dedicated key to wake-up system via PSOUT# when keyboard wake-up function is enabled. 0: Disable Win98 keyboard wake-up. 1: Enable Win98 keyboard wake-up. R/W EN_ONPSOUT (VBAT) Disable/Enable to issue a 0.5s delay PSOUT# level when system returns from power loss state and is supposed to be on as described in CRE4[6:5], logic device A. (for SiS & VIA chipsets) 0: Disable. 1: Enable. R/W Select WDTO# reset source (VSB) 0: Watchdog timer is reset by LRESET#. 1: Watchdog timer is reset by PWROK. Reserved. R/W Hardware Monitor RESET source select (VBAT) 0: PWROK. 1: LRESET#. CR E8h. (Reserved) CR E9h. (Reserved) CR F2h. (Default 7Ch) (VSB Power) BIT 7 6 READ / WRITE DESCRIPTION Reserved. R/W Enable RSTOUT4# function. 0: Disable RSTOUT4#. 1: Enable RSTOUT4#. -223- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT BIT READ / WRITE DESCRIPTION 5 R/W Enable RSTOUT3# function. 0: Disable RSTOUT3#. 1: Enable RSTOUT3#. 4 R/W Enable RSTOUT2# function. 0: Disable RSTOUT2#. 1: Enable RSTOUT2#. 3 R/W Enable RSTOUT1# function. 0: Disable RSTOUT1#. 1: Enable RSTOUT1#. 2 R/W Enable RSTOUT0# function. 0: Disable RSTOUT0#. 1: Enable RSTOUT0#. 1 Reserved. 0 R/W EN_PME => 0 : Disable PME. 1 : Enable PME. CR F3h. (Default 00h) BIT READ / WRITE 7~6 Reserved. DESCRIPTION 5 R / W-Clear PME status of the Mouse IRQ event. Write 1 to clear this status. 4 R / W-Clear PME status of the KBC IRQ event. Write 1 to clear this status. 3 R / W-Clear PME status of the PRT IRQ event. Write 1 to clear this status. 2 R / W-Clear PME status of the FDC IRQ event. Write 1 to clear this status. 1 R / W-Clear PME status of the URA IRQ event. Write 1 to clear this status. 0 R / W-Clear PME status of the URB IRQ event. Write 1 to clear this status. CR F4h. (Default 00h) BIT READ / WRITE 7~4 Reserved. DESCRIPTION 3 R / W-Clear PME status of the HM IRQ event. Write 1 to clear this status. 2 R / W-Clear PME status of the WDTO# event. Write 1 to clear this status. 1 Reserved. -224- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT BIT READ / WRITE 0 R / W-Clear DESCRIPTION PME status of the RIB event. Write 1 to clear this status. CR F6h. (Default 00h) (VSB Power) BIT READ / WRITE DESCRIPTION 7 R/W 6 Reserved. 5 R/W 0: Disable PME interrupt of the Mouse IRQ event. 1: Enable PME interrupt of the Mouse IRQ event. 4 R/W 0: Disable PME interrupt of the KBC IRQ event. 1: Enable PME interrupt of the KBC IRQ event. 3 R/W 0: Disable PME interrupt of the PRT IRQ event. 1: Enable PME interrupt of the PRT IRQ event. 2 R/W 0: Disable PME interrupt of the FDC IRQ event. 1: Enable PME interrupt of the FDC IRQ event. 1 R/W 0: Disable PME interrupt of the URA IRQ event. 1: Enable PME interrupt of the URA IRQ event. 0 R/W 0: Disable PME interrupt of the URB IRQ event. 1: Enable PME interrupt of the URB IRQ event. 0: Disable KB, MS PME interrupt of the KBC password event. 1: Enable KB, MS PME interrupt of the KBC password event. CR F7h. (Default 00h) (VSB Power) BIT READ / WRITE 7~4 Reserved. DESCRIPTION 3 R/W 0: Disable PME interrupt of the HM IRQ event. 1: Enable PME interrupt of the HM IRQ event. 2 R/W 0: Disable PME interrupt of the WDTO# event. 1: Enable PME interrupt of the WDTO# event. 1 Reserved. 0 R/W 0: Disable PME interrupt of the RIB event. 1: Enable PME interrupt of the RIB event. CR Feh. (GPIO3 Event Route Selection Register; Default 00h) BIT READ / WRITE DESCRIPTION 7 R/W Reserved. 6 R/W 0: Disable GP35 event route to PSOUT#. 1: Enable GP35 event route to PSOUT#. 5 R/W 0: Disable GP31 event route to PSOUT#. 1: Enable GP31 event route to PSOUT#. -225- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT BIT READ / WRITE 4 R/W 3 DESCRIPTION 0: Disable GP30 event route to PSOUT#. 1: Enable GP30 event route to PSOUT#. Reserved. 2 R/W 0: Disable GP35 event route to PME#. 1: Enable GP35 event route to PME#. 1 R/W 0: Disable GP31 event route to PME#. 1: Enable GP31 event route to PME#. 0 R/W 0: Disable GP30 event route to PME#. 1: Enable GP30 event route to PME#. -226- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 21.12 Logical Device B (Hardware Monitor) CR 30h. (Default 00h) BIT READ / WRITE 7~1 Reserved. 0 R/W DESCRIPTION 0: Logical device is inactive. 1: Logical device is active. CR 60h, 61h. (Default 00h, 00h) BIT READ / WRITE DESCRIPTION 7~0 R/W These two registers select the HM base address along a two-byte boundary. CR 70h. (Default 00h) BIT READ / WRITE 7~4 Reserved. 3~0 R/W DESCRIPTION These bits select the IRQ resource for HM. CR F0h. (VID Control Register; Default 81h) BIT READ / WRITE DESCRIPTION 7 R/W VID I/O Control 0: VID output mode. 1: VID input mode. 6 R/W VIDAMD input level select 0: VID is GTL level. 1: VID is AMD VRM level. 5 R/W 0: Disable AUXFANIN1 input de-bouncer. 1: Enable AUXFANIN1 input de-bouncer. 4 R/W 0: Disable CPUFANIN1 input de-bouncer. 1: Enable CPUFANIN1 input de-bouncer. 3 R/W 0: Disable AUXFANIN0 input de-bouncer. 1: Enable AUXFANIN0 input de-bouncer. 2 R/W 0: Disable CPUFANIN0 input de-bouncer. 1: Enable CPUFANIN0 input de-bouncer. 1 R/W 0: Disable SYSFANIN input de-bouncer. 1: Enable SYSFANIN input de-bouncer. 0 Reserved. -227- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT CR F1h. (VID Data Register; Default 00h) BIT READ / WRITE 7~0 R/W DESCRIPTION VID[7:0] Data Register. (For Input/Output both use) CR F2h. (FAN Strapping Status Register; Default 00h) (VCC Power) BIT READ / WRITE 7~2 Reserved. 1 0 DESCRIPTION Read Only FAN_SET2 strapping status. This bit is strapped by pin 83(SOUTB). 0: Initial speed is 100%. 1: Initial speed is 50%. Read Only FAN_SET strapping status. This bit is strapped by pin 117(PLED). 0: Initial speed is 100%. 1: Initial speed is 50%. -228- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 21.13 Logical Device C (PECI, SST) CR E0h. (Agent Configuration Register; Default 00h) BIT READ / WRITE DESCRIPTION R/W Agt4EN (Agent 4 Enable Bit) 0: Agent 4 is disabled. 1: Agent 4 is enabled. R/W Agt3EN (Agent 3 Enable Bit) 0: Agent 3 is disabled. 1: Agent 3 is enabled. 5 R/W Agt2EN (Agent 2 Enable Bit) 0: Agent 2 is disabled. 1: Agent 2 is enabled. 4 R/W Agt1EN (Agent 1 Enable Bit) 0: Agent 1 is disabled. 1: Agent 1 is enabled. 3 R/W RTD4 0: Agent 4 always returns the relative temperature from domain 0. 1: Agent 4 always returns the relative temperature from domain 1. R/W RTD3 (Agent 3 Return Domain 1 Enable Bit. Functions only when Agt3D1 is set to 1) 0: Agent 3 always returns the relative temperature from domain 0. 1: Agent 3 always returns the relative temperature from domain 1. R/W RTD2 (Agent 2 Return Domain 1 Enable Bit. Functions only when Agt2D1 is set to 1) 0: Agent 2 always returns the relative temperature from domain 0. 1: Agent 2 always returns the relative temperature from domain 1. R/W RTD1 (Agent 1 Return Domain 1 Enable Bit. Functions only when Agt1D1 is set to 1) 0: Agent 1 always returns the relative temperature from domain 0. 1: Agent 1 always returns the relative temperature from domain 1. 7 6 2 1 0 CR E1h. (Agent 1 Tbase Register; Default 48h) BIT 7 6~0 READ / WRITE DESCRIPTION Reserved R/W Agent 1 Tbase (Range: 0~127). (Note 1) -229- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT CR E2h. (Agent 2 Tbase Register; Default 48h) BIT 7 6~0 READ / WRITE DESCRIPTION Reserved R/W Agent 2 Tbase (Range: 0~127). (note 1) CR E3h. (Agent 3 Tbase Register; Default 48h) BIT 7 6~0 READ / WRITE DESCRIPTION Reserved R/W Agent 3 Tbase (Range: 0~127). (Note 1) CR E4h. (Agent 4 Tbase Register; Default 48h) BIT 7 6~0 READ / WRITE DESCRIPTION Reserved R/W Agent 4 Tbase (Range: 0~127). (Note 1) Note 1: Tbase is a temperature refernce based on the experiment of processor actual temperature. For more details, please refer to 8.5 PECI. CR E5h. (PECI Register; Default 00h) BIT READ / WRITE 7 R/W Agt4D1 (Agent 4 Domain 1 Enable Bit) 0: Agent 4 does not have domain 1. 1: Agent 4 has domain 1. 6 R/W Agt3D1 (Agent 3 Domain 1 Enable Bit) 0: Agent 3 does not have domain 1. 1: Agent 3 has domain 1. R/W Agt2D1 (Agent 2 Domain 1 Enable Bit) 0: Agent 2 does not have domain 1. 1: Agent 2has domain 1. 4 R/W Agt1D1 (Agent 1 Domain 1 Enable Bit) 0: Agent 1 does not have domain 1. 1: Agent 1 has domain 1. 3 R/W PECI_1.1°_en 0: Normal PECI transmission. (Default) 1: PECI _1.1a transmission with PECI_REQ#. 5 2 1 DESCRIPTION Reserved R/W Return High Temperature 0: The temperature of each agent is returned from domain 0 or domain 1, which is controlled by CRE0 bit 0~3. 1: Return the highest temperature in domain 0 and domain 1 of individual Agent. -230- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT BIT READ / WRITE 0 R/W DESCRIPTION PECISB_EN 0: PECI host is controlled by IO. 1: PECI host is another device (e.g. South Bridge) CR E8h. (PECI Warning Flag Register; Default 00h) BIT 7 6 5 4 3~2 1~0 READ / WRITE Read Only Read Only Read Only Read Only DESCRIPTION Agent 4 Alert Bit (When CR E8[3] is 0) 0: Agent 4 has valid FCS. 1: Agent 4 has invalid FCS in the previous 3 transactions. Agent 4 Absent Bit (When CR E8[3] is 1) 0: Agent 4 is detected. 1: Agent 4 cannot be detected. Agent 3 Alert Bit (When CR E8[3] is 0) 0: Agent 3 has valid FCS. 1: Agent 3 has invalid FCS in the previous 3 transactions. Agent 3 Absent Bit (When CR E8[3] is 1) 0: Agent 3 is detected. 1: Agent 3 cannot be detected. Agent 2 Alert Bit (When CR E8[3] is 0) 0: Agent 2 has valid FCS. 1: Agent 2 has invalid FCS in the previous 3 transactions. Agent 2 Absent Bit (When CR E8[3] is 1) 0: Agent 2 is detected. 1: Agent 2 cannot be detected. Agent 1 Alert Bit (When CR E8[3] is 0) 0: Agent 1 has valid FCS. 1: Agent 1 has invalid FCS in the previous 3 transactions. Agent 1 Absent Bit (When CR E8[3] is 1) 0: Agent 1 is detected. 1: Agent 1 cannot be detected. R/W Bank Select. These two bits are used in Bank index selection. The relative data delivered over PECI interface and PECI Agent Absent Bit can be read from the registers below by setting Bank selection. The relative data delivered over PECI interface can be read in CR EE and CR EF, and the PECI warning flag can be read in CR E8 bit 7~4. R/W PECI Speed Select. Bits 10 0 0: The PECI speed is 1.5 MHz 0 1: The PECI speed is 750 KHz 1 0: The PECI speed is 375 KHz 1 1: The PECI speed is 187 KHz -231- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT CR E9h. (Reserved) CR EAh. (PECI_1.1ª Status Register; Default 00h) BIT READ / WRITE DESCRIPTION Reserved 7 Read_Only Agent 4 Alert toggle bit (When CR E8[2] is 1) 0: PECI Alert bit never occurred. 1: PECI Alert bit occurred once. (Read clear) Reserved 6 Read_Only Agent 3 Alert toggle bit (When CR E8[2] is 1) 0: PECI Alert bit never occurred. 1: PECI Alert bit occurred once. (Read clear) Reserved 5 Read_Only Agent 2 Alert toggle bit (When CR E8[2] is 1) 0: PECI Alert bit never occurred. 1: PECI Alert bit occurred once. (Read clear) Reserved 4 Read_Only Agent 2 Alert toggle bit (When CR E8[2] is 1) 0: PECI Alert bit never occurred. 1: PECI Alert bit occurred once. (Read clear) 3~0 Read_Only Reserved. (When CR E8[2] is 0) CR ECh. (PECI_1.1a Status Register; Default 00h) BIT READ / WRITE 7~3 R/W Reserved. R/W PECI Transmission cycle time: Bits 210 0 0 0 : Finish one PECI message transmission every 0.0625sec(16Hz) 0 0 1 : Finish one PECI message transmission every 0.125sec(8Hz) 0 1 0 : Finish one PECI message transmission every 0.25sec(4Hz) 0 1 1 : Finish one PECI message transmission every 0.5sec(2Hz) 1 0 0 : Finish one PECI message transmission every 1sec(1Hz) 1 0 1 : Finish one PECI message transmission every 2sec(1/2Hz) 1 1 0 : Finish one PECI message transmission every 4sec(1/4Hz) 2~0 DESCRIPTION -232- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT CR EEh. (SST Device ID Low Byte; Default 01h) BIT READ / WRITE 7~0 R/W DESCRIPTION SST Device ID Low Byte. (Note 3) CR EFh. (SST Device ID High Byte; Default 5Ah) BIT READ / WRITE 7~0 R/W DESCRIPTION SST Device ID High Byte. (Note 3) Note 2: Vendor ID identifies the device from a specific vendor. The PCI SIG or TBA assigns the contents of this value. Note 3: This value is assigned by vendor and must be exclusive to that vendor and to the device. It will be used in conjunction with the Vendor ID to associate the correct software driver with the sensor. CR F1h. (SST Address Register; Default 48h) BIT READ / WRITE 7~0 R/W DESCRIPTION SST address CR F2h. (SST Vendor ID Low Byte; Default 50h) BIT 7~0 READ / WRITE R/W DESCRIPTION SST Vendor ID Low Byte. (Note 2) CR F3h. (SST Vendor ID High Byte; Default 10h) BIT 7~0 READ / WRITE R/W DESCRIPTION SST Vendor ID High Byte. (Note 2) CR FEh. (PECI Agent Relative High Byte Temperature Register; Default 00h) BIT 7~0 READ / WRITE DESCRIPTION Read Only This register shows the retrieved High Byte raw data from PECI interface. When Bank Select (CR E8 bit 3~2) Bits 32 =00 Agt1RelTemp (High Byte) =01 Agt2RelTemp (High Byte) =10 Agt3RelTemp (High Byte) =11 Agt4RelTemp (High Byte) -233- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT CR FFh. (PECI Agent Relative Low ByteTemperature Register; Default 00h) BIT 7~0 READ / WRITE DESCRIPTION Read Only This register shows the retrieved High Byte raw data from PECI interface. When Bank Select (CR E8 bit 3~2) Bits 32 =00 Agt1RelTemp (Low Byte) =01 Agt2RelTemp (Low Byte) =10 Agt3RelTemp (Low Byte) =11 Agt4RelTemp (Low Byte) -234- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 22. SPECIFICATIONS 22.1 Absolute Maximum Ratings SYMBOL PARAMETER 3VCC Power Supply Voltage (3.3V) Input Voltage RATING UNIT -0.3 to 3.6 V -0.3 to 3VCC+0.3 V -0.3 to 5.5 V VI Input Voltage (5V tolerance) 0 to +70 °C TA Operating Temperature -40 to +85 °C Storage Temperature -55 to +150 °C TSTG Note1: Exposure to conditions beyond those listed under Absolute Maximum Ratings may adversely affect the life and reliability of the device. Note2: Both W83627DHG-P and W83627DHG-PT supports the IC operating temperature from 0℃ to +70℃. Only W83627DHG-PT supports the IC operating temperature from -40℃ to +85℃. 22.2 Hardware Monitor Ratings (Ta = 0°C to 70°C, VDD = 3.3V ± 5%, VSS = 0V) PARAMETER SYM MIN TYP MAX. UNIT -3 ±1 +3 ℃ External Temperature Measurement Accuracy 22.3 CONDITIONS 0℃≦Ta≦70℃ DC CHARACTERISTICS (Ta = 0°C to 70°C, VDD = 3.3V ± 5%, VSS = 0V) PARAMETER RTC Battery Quiescent Current ACPI Standby Power Supply Quiescent Current SYM MIN TYP MAX. 2.4 IBAT 2.0 ISB -235- UNIT CONDITIONS μA VBAT = 2.5 V CASEOPEN Pull-Up to VBAT mA VSB = 3.3 V CASEOPEN Pull-Up to VBAT Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT PARAMETER VCC Quiescent Current Vtt Quiescent Current SYM MIN TYP MAX. 25 IVCC 1 IVTT UNIT CONDITIONS mA VSB = 3.3V VCC (AVCC) = 3.3V LRESET = High IOCLK = 48MHz CASEOPEN Pull-Up to VBAT mA VSB = 3.3V VCC (AVCC) = 3.3V VTT = 1.2V LRESET = High IOCLK = 48MHz CASEOPEN Pull-Up to VBAT I/O8t – TTL–level, bi-directional pin with 8mA source-sink capability Input Low Voltage VIL Input High Voltage VIH Output Low Voltage VOL Output High Voltage VOH Input High Leakage ILIH Input Low Leakage ILIL 0.8 2.0 V V 0.4 V IOL = 8 mA V IOH = - 8 mA +10 μA VIN = 3.3V -10 μA VIN = 0V 2.4 I/O12t – TTL-level, bi-directional pin with 12mA source-sink capability Input Low Voltage VIL Input High Voltage VIH Output Low Voltage VOL Output High Voltage VOH Input High Leakage ILIH 0.8 2.0 V V 0.4 2.4 +10 -236- V IOL = 12 mA V IOH = -12 mA μA VIN = 3.3V Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT PARAMETER Input Low Leakage SYM MIN TYP ILIL MAX. UNIT -10 μA CONDITIONS VIN = 0V I/O24t – TTL-level, bi-directional pin with 24mA source-sink capability Input Low Voltage VIL Input High Voltage VIH Output Low Voltage VOL Output High Voltage VOH Input High Leakage ILIH Input Low Leakage ILIL 0.8 2.0 V V 0.4 V IOL = 24 mA V IOH = -24 mA +10 μA VIN = 3.3V -10 μA VIN = 0V 2.4 I/O12tp3 – 3.3V TTL-level, bi-directional pin with 12mA source-sink capability Input Low Voltage VIL Input High Voltage VIH Output Low Voltage VOL Output High Voltage VOH Input High Leakage ILIH Input Low Leakage ILIL 0.8 2.0 V V 0.4 V IOL = 12 mA V IOH = -12 mA +10 μA VIN = 3.3V -10 μA VIN = 0V 2.4 I/O12ts – TTL–level, Schmitt-trigger, bi-directional pin with 12mA source-sink capability Input Low Threshold Voltage Vt- 0.5 0.8 1.1 V Input High Threshold Voltage Vt+ 1.6 2.0 2.4 V Hystersis VTH 0.5 1.2 Output Low Voltage VOL Output High Voltage VOH Input High Leakage ILIH Input Low Leakage ILIL V VCC=3.3V V IOL = 12 mA V IOH = -12 mA +10 μA VIN = 3.3V -10 μA VIN = 0V 0.4 2.4 I/O24ts – TTL–level, Schmitt-trigger, bi-directional pin with 24mA source-sink capability -237- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT PARAMETER SYM MIN TYP MAX. UNIT Input Low Threshold Voltage Vt- 0.5 0.8 1.1 V Input High Threshold Voltage Vt+ 1.6 2.0 2.4 V Hystersis VTH 0.5 1.2 Output Low Voltage VOL Output High Voltage VOH Input High Leakage ILIH Input Low Leakage ILIL CONDITIONS V VCC= 3.3V V IOL = 24 mA V IOH = -24 mA +10 μA VIN = 3.3V -10 μA VIN = 0V 0.4 2.4 I/O24tsp3 – 3.3V TTL-level, Schmitt-trigger, bi-directional pin with 24mA source-sink capability Input Low Threshold Voltage Vt- 0.5 0.8 1.1 V Input High Threshold Voltage Vt+ 1.6 2.0 2.4 V Hystersis VTH 0.5 1.2 Output Low Voltage VOL Output High Voltage VOH Input High Leakage ILIH Input Low Leakage ILIL V VCC=3.3V V IOL = 24 mA V IOH = -24 mA +10 μA VIN = 3.3V -10 μA VIN = 0V 0.4 2.4 I/OD12t – TTL–level, bi-directional pin and open-drain output with 12mA sink capability Input Low Voltage VIL Input High Voltage VIH Output Low Voltage VOL 0.4 V IOL = 12 mA Input High Leakage ILIH +10 μA VIN = 3.3V Input Low Leakage ILIL -10 μA VIN = 0V 0.8 2.0 V V I/OD16t – TTL–level, bi-directional pin and open-drain output with 16mA sink capability -238- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT PARAMETER SYM MIN TYP MAX. UNIT 0.8 V CONDITIONS Input Low Voltage VIL Input High Voltage VIH Output Low Voltage VOL 0.4 V IOL = 16 mA Input High Leakage ILIH +10 μA VIN = 3.3V Input Low Leakage ILIL -10 μA VIN = 0V 2.0 V I/OD24t – TTL–level, bi-directional pin and open-drain output with 24mA sink capability Input Low Voltage VIL Input High Voltage VIH Output Low Voltage VOL 0.4 V IOL = 24 mA Input High Leakage ILIH +10 μA VIN = 3.3V Input Low Leakage ILIL -10 μA VIN = 0V 0.8 2.0 V V I/O12tp3 – 3.3V TTL–level, bi-directional pin and open-drain output with 12mA source-sink capability Input Low Voltage VIL Input High Voltage VIH Output Low Voltage VOL Output High Voltage VOH Input High Leakage ILIH Input Low Leakage ILIL 0.8 2.0 V V 0.4 V IOL = 12 mA V IOH = -12 mA +10 μA VIN = 3.3V -10 μA VIN = 0V 2.4 I/OD16ts – TTL–level, Schmitt-trigger, bi-directional pin and open-drain output with 16mA sink capability Input Low Threshold Voltage Vt- 0.5 0.8 1.1 V Input High Threshold Voltage Vt+ 1.6 2.0 2.4 V -239- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT PARAMETER SYM MIN TYP Hystersis VTH 0.5 1.2 Output Low Voltage VOL Input High Leakage Input Low Leakage MAX. UNIT CONDITIONS V VCC=3.3V 0.4 V IOL = 16 mA ILIH +10 μA VIN = 3.3V ILIL -10 μA VIN = 0V I/OD24ts – TTL level, Schmitt-trigger, bi-directional pin and open-drain output with 24mA sink capability Input Low Threshold Voltage Vt- 0.5 0.8 1.1 V Input High Threshold Voltage Vt+ 1.6 2.0 2.4 V Hystersis VTH 0.5 1.2 Output Low Voltage VOL Input High Leakage Input Low Leakage V VCC=3.3V 0.4 V IOL = 24 mA ILIH +10 μA VIN = 3.3V ILIL -10 μA VIN = 0V I/OD12cs – CMOS–level, Schmitt-trigger, bi-directional pin and open-drain output with 12mA sink capability Input Low Threshold Voltage Vt- 0.5 0.8 1.1 V VCC = 3.3 V Input High Threshold Voltage Vt+ 1.6 2.0 2.4 V VCC = 3.3 V Hystersis VTH 0.5 1.2 V VCC = 3.3 V Output Low Voltage VOL 0.4 V IOL = 12 mA Input High Leakage ILIH +10 μA VIN = 3.3 V Input Low Leakage ILIL -10 μA VIN = 0 V I/OD16cs – CMOS–level, Schmitt-trigger, bi-directional pin and open-drain output with 16mA sink capability Input Low Threshold Voltage Vt- 0.5 0.8 -240- 1.1 V VCC = 3.3 V Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT PARAMETER SYM MIN TYP MAX. UNIT CONDITIONS Input High Threshold Voltage Vt+ 1.6 2.0 2.4 V VCC = 3.3 V Hystersis VTH 0.5 1.2 V VCC = 3.3 V Output Low Voltage VOL 0.4 V IOL = 16 mA Input High Leakage ILIH +10 μA VIN = 3.3 V Input Low Leakage ILIL -10 μA VIN = 0 V I/OD12csd – CMOS–level, Schmitt-trigger, bi-directional pin with internal pulled-down resistor and open-drain output with 12mA sink capability Input Low Threshold Voltage Vt- 0.5 0.8 1.1 V VCC = 3.3 V Input High Threshold Voltage Vt+ 1.6 2.0 2.4 V VCC = 3.3 V Hystersis VTH 0.5 1.2 V VCC = 3.3 V Output Low Voltage VOL 0.4 V IOL = 12 mA Input High Leakage ILIH +10 μA VIN = 3.3 V Input Low Leakage ILIL -10 μA VIN = 0 V I/OD12csu – CMOS–level, Schmitt-trigger, bi-directional pin with internal pulled-up resistor and open-drain output with 12mA sink capability Input Low Threshold Voltage Vt- 0.5 0.8 1.1 V VCC = 3.3 V Input High Threshold Voltage Vt+ 1.6 2.0 2.4 V VCC = 3.3 V Hystersis VTH 0.5 1.2 V VCC = 3.3 V Output Low Voltage VOL 0.4 V IOL = 12 mA Input High Leakage ILIH +10 μA VIN = 3.3 V Input Low Leakage ILIL -10 μA VIN = 0 V 0.4 V IOL = 4 mA O4 – Output pin with 4mA source-sink capability Output Low Voltage VOL -241- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT PARAMETER SYM MIN Output High Voltage VOH 2.4 TYP MAX. UNIT CONDITIONS V IOH = -4 mA V IOL = 8 mA V IOH = -8 mA V IOL = 12 mA V IOH = -12 mA V IOL = 16 mA V IOH = -16 mA V IOL = 24 mA V IOH = -24 mA V IOL = 12 mA V IOH = -12 mA V IOL = 24 mA V IOH = -24 mA 0.4 V IOL = 12 mA 0.4 V IOL = 24 mA O8 – Output pin with 8mA source-sink capability Output Low Voltage VOL Output High Voltage VOH 0.4 2.4 O12 – Output pin with 12mA source-sink capability Output Low Voltage VOL Output High Voltage VOH 0.4 2.4 O16 – Output pin with 16mA source-sink capability Output Low Voltage VOL Output High Voltage VOH 0.4 2.4 O24 – Output pin with 24mA source-sink capability Output Low Voltage VOL Output High Voltage VOH 0.4 2.4 O12p3 – 3.3V output pin with 12mA source-sink capability Output Low Voltage VOL Output High Voltage VOH 0.4 2.4 O24p3 – 3.3V output pin with 24mA source-sink capability Output Low Voltage VOL Output High Voltage VOH 0.4 2.4 OD12 – Open-drain output pin with 12mA sink capability Output Low Voltage VOL OD24 – Open-drain output pin with 24mA sink capability Output Low Voltage VOL OD12p3 – 3.3V open-drain output pin with 12mA sink capability -242- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT PARAMETER SYM Output Low Voltage VOL MIN TYP MAX. UNIT 0.4 V 0.8 V CONDITIONS IOL = 12 mA Int – TTL-level input pin Input Low Voltage VIL Input High Voltage VIH Input High Leakage ILIH +10 μA VIN = 3.3 V Input Low Leakage ILIL -10 μA VIN = 0 V 0.8 V 2.0 V Intp3 – 3.3V TTL-level input pin Input Low Voltage VIL Input High Voltage VIH Input High Leakage ILIH +10 μA VIN = 3.3V Input Low Leakage ILIL -10 μA VIN = 0 V 2.0 V Intd – TTL-level input pin with internal pulled-down resistor Input Low Voltage VIL Input High Voltage VIH Input High Leakage ILIH +10 μA VIN = 3.3 V Input Low Leakage ILIL -10 μA VIN = 0 V 0.8 V 0.8 2.0 V V Intu – TTL-level input pin with internal pulled-up resistor Input Low Voltage VIL Input High Voltage VIH Input High Leakage ILIH +10 μA VIN = 3.3 V Input Low Leakage ILIL -10 μA VIN = 0 V 2.0 V Ints – TTL–level, Schmitt-trigger input pin -243- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT PARAMETER SYM MIN TYP MAX. UNIT CONDITIONS Input Low Threshold Voltage Vt- 0.5 0.8 1.1 V VCC = 3.3 V Input High Threshold Voltage Vt+ 1.6 2.0 2.4 V VCC = 3.3 V Hystersis VTH 0.5 1.2 V VCC = 3.3 V Input High Leakage ILIH +10 μA VIN = 3.3 V Input Low Leakage ILIL -10 μA VIN = 0 V Intsp3 – 3.3 V TTL-level, Schmitt-trigger input pin Input Low Threshold Voltage Vt- 0.5 0.8 1.1 V VCC = 3.3 V Input High Threshold Voltage Vt+ 1.6 2.0 2.4 V VCC = 3.3 V Hystersis VTH 0.5 1.2 V VCC = 3.3 V Input High Leakage ILIH +10 μA VIN = 3.3 V Input Low Leakage ILIL -10 μA VIN = 0 V 0.3 VCC V Inc – CMOS-level input pin Input Low Voltage VIL Input High Voltage VIH Input High Leakage ILIH +10 μA VIN = VCC = 3.3V Input Low Leakage ILIL -10 μA VIN = 0 V V 0.7 VCC Incd – CMOS-level input pin with internal pulled-down resistor Input Low Voltage VIL Input High Voltage VIH Input High Leakage ILIH +10 μA VIN = VCC = 3.3V Input Low Leakage ILIL -10 μA VIN = 0 V Input Low Voltage VIL 0.3 VCC V 0.3 VCC 0.7 VCC V V -244- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT PARAMETER SYM MIN TYP MAX. UNIT CONDITIONS Incu – CMOS-level input pin with internal pulled-up resistor Input High Voltage VIH Input High Leakage ILIH +10 μA VIN = VCC = 3.3V Input Low Leakage ILIL -10 μA VIN = 0 V 1.7 V VCC = 3.3V V VCC = 3.3V 0.7 VCC V Incs – CMOS–level, Schmitt-trigger input pin Input Low Threshold Voltage Vt- 1.3 1.5 Hystersis VTH 1.5 2 Input High Leakage ILIH +10 μA VIN = 3.3V Input Low Leakage ILIL -10 μA VIN = 0 V Incsu – CMOS–level, Schmitt-trigger input pin with internal pulled-up resistor Input Low Threshold Voltage Vt- 0.5 0.8 1.1 V VCC = 3.3V Input High Threshold Voltage Vt+ 1.6 2.0 2.4 V VCC = 3.3V Hystersis VTH 0.5 1.2 V VCC = 3.3V Input High Leakage ILIH +10 μA VIN = 3.3V Input Low Leakage ILIL -10 μA VIN = 0 V AOUT – Analog output N.A. INV1S – VID input pin for INTEL® VRM10.0, and VRM11 design Input Low Voltage VIL Input High Voltage VIH 0.4 0.6 V V INV2S – VID input pin for AMDTMVRM design Input Low Voltage VIL Input High Voltage VIH 0.8 1.4 V V -245- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT PARAMETER SYM MIN TYP MAX. UNIT CONDITIONS I/OV3 – Bi-direction pin with source capability of 6 mA and sink capability of 1 mA for INTEL® PECI Input Low Voltage VIL 0 . 2 7 5 V t t 0 Input High Voltage VIH 0 0 Output Low Voltage VOL Output High Voltage VOH 0 Hysterisis VHys 0 . 5 5 V t t . . 0 . 7 . 5 1 V V t t 5 7 . V 2 2 5 5 t V V t t t V t V t V t V t V I/OV4 – Bi-direction pin with source capability of 6 mA and sink capability of 1 mA for INTEL® SST Input Low Threshold Voltage Vt- 0.4 0.65 V Vcc = 1.5 V Input High Threshold Voltage Vt+ 0.75 1.1 V Vcc = 1.5 V Input High Leakage ILIH +10 μA VIN = Vcc Input Low Leakage ILIL -10 μA VIN = 0V Hysteresis VTH V Vcc = 1.5 V 0.15 -246- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 22.4 AC CHARACTERISTICS 22.4.1 Power On / Off Timing PSON# T3 T4 SLP_S3# (Intel Chipset) S3# (Other Chipset) PSOUT# T1 PSIN# T2 3VSB G3 IDEAL TIMING (SEC) S5 S0 S5 T1 T2 T3 T4 64ms Over 64ms at least < 10ns 32ms -247- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 22.4.2 AC Power Failure Resume Timing Logical Device A, CR [E4h] bits [6:5] =00 means “OFF” state (“OFF” means the system is always turned off after the AC power loss recovered.) 2. 3VCC PSOUT# PSON# SUSB# RSMRST# 3VSB ACLOSS -248- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT Logical Device A, CR [E4h] bits [6:5]=01 means “ON” state. (“ON” means the system is always turned on after AC power loss recovered.) 3. 3VCC PSOUT# PSON# SUSB# RSMRST# 3VSB ACLOSS -249- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT ** What’s the definition of former state at AC power failure? 1) The previous state is “ON” 3VCC falls to 2.6V and SUSB# keeps at VIH 2.0V 3VCC SUSB# 2) The previous state is “OFF” 3VCC falls to 2.6V and SUSB# keeps at VIL 0.8V 3VCC SUSB# To ensure that VCC does not fall faster than VSB in various ATX Power Supplies, the W83627DHGP adds the option of “user define mode” for the pre-defined state before AC power failure. BIOS can set the pre-defined state for the system to be “On” or “Off”. According to this setting, the system chooses the state after the AC power recovery. Logical Device A, CR E4h BIT 6~5 READ / WRITE DESCRIPTION R/W Power-loss control bits => (VBAT) 00: System always turns off when it returns from power-loss state. 01: System always turns on when it returns from power-loss state. 10: System turns off / on when it returns from power-loss state depending on the state before the power loss. 11: User defines the state before the power loss.(The previous state is set at CRE6[4]) Logical Device A, CR E6h BIT READ / WRITE 4 R/W DESCRIPTION Power loss Last State Flag. (VBAT) 0: ON 1: OFF -250- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 22.4.3 VSBGATE# Timing VSBGATE# drives low only when SUSB# is active and Logical Device A, CR[E4h] bit 4 is set to “1" VSBGATE# VSBGATE# is reset to high after PSON# is active t2 t1 3VCC PSON# t4 t3 SUSB# SUSC# S0 SYMBOL S3 S0 PARAMETER MIN MAX UNIT t1 SUSB# active to VSBGATE# active 0 80 nS t2 PSON# active to VSBGATE# inactive 90 142 mS t3 SUSB# inactive to PSON# active 0 80 nS t4 SUSB# active to PSON# inactive 28 39 mS Note. The values above the worst-case results of R&D simulation 22.4.4 Clock Input Timing 48MHZ / 24MHZ PARAMETER MIN Cycle to cycle jitter Duty cycle 45 -251- UNIT MAX 300/500 ps 55 % Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT t1 t2 t3 PARAMETER 48MHZ / 24MHZ DESCRIPTION MIN t1 Clock cycle time t2 Clock high time/low time t3 Clock rising time/falling time (0.4V~2.4V) TYP UNIT MAX 20.8 / 41.7 ns 10 / 21 ns 8.094 / 19 3 ns Note: t2 measure from the voltage (VIH+VIL)/2=(2.0+0.8)/2=1.4V -252- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 22.4.5 PECI and SST Timing SST / PECI Logic - 1 Minimum tH1 Maximum tH1 tBIT Previous bit Next-bit SST / PECI Logic - 0 Minimum tH0 Maximum tH0 tBIT Previous bit SYMBOL tBIT MIN TYP Next-bit MAX Client 0.495 500 Originator 0.495 250 UNITS μs tH1 0.6 3/4 0.8 × tBIT tH0 0.2 1/4 0.4 × t BIT -253- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 22.4.6 SPI Timing t1 t2 SCE t3 SCK SO t4 SI t5 DESCRIPTION SYMBOL MIN TYP MAX Enable to first clock falling t1 25ns - 35ns Disable after last clock rising t2 40ns - 50ns Output hold time t3 - - 5ns Input setup time t4 5ns - - Input hold time t5 6ns - - -254- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 22.4.7 SMBus Timing TLOW TR TF SMBCLK THIGH TSU:DAT THD:STA TSU:STO TSU:STA THD:DAT SMBDAT TBUF P S S SYMBOL P PARAMETER MIN. MAX.: UNITS TBUF Bus Free Time between Stop and Start Condition 4.7 - uS THD:STA Hold time after (Repeated) Start Condition. After this period, the first clock is generated 4.0 - uS TSU:STA Repeated Start Condition setup time 4.7 - uS TSU:STO Stop Condition setup time 4.0 - uS THD:DAT Data hold time 300 - nS TSU:DAT Data setup time 250 - nS TLOW Clock low period 4.7 - uS THIGH Clock high period 4.0 50 uS TF Clock/Data Falling Time - 300 nS TR Clock/Data Rising Time - 1000 nS 22.4.8 Floppy Disk Drive Timing FDC: Data rate = 1MB, 500KB, 300KB, 250KB/sec. PARAMETER SYM. MIN. DIR# setup time to STEP# TDST 1.0/1.6 /2.0/4.0 µS DIR# hold time from STEP# TSTD 24/40 /48/96 µS STEP# pulse width TSTP 6.8/11.5 -255- TYP. (NOTE 1) 7/11.7 MAX. 7.2/11.9 UNIT µS Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT PARAMETER SYM. MIN. TYP. (NOTE 1) MAX. /13.8/27. 8 /14/28 /14.2/28. 2 NOTE 2 NOTE 2 UNIT STEP# cycle width TSC NOTE 2 INDEX# pulse width TIDX 125/250 /417/500 nS RDATA# pulse width TRD 40 nS WD# pulse width TWD 100/185 /225/475 125/210 /250/500 150/235 /275/525 mS nS Notes: 1. Typical values for T = 25°C and normal supply voltage. 2. Programmable from 0.5 mS through 32 mS as described in step rate table. (Please refer to the description of the SPECIFY command set.) Step Rate Table DATA RATE SRT 1MB/S 500KB/S 300KB/S 250KB/S 0 8 16 26.7 32 1 7.5 15 25 30 … … … … … E 1.0 2 3.33 4 F 0.5 1 1.67 2 -256- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT Floppy Disk Driving Timing TSTD DIR# TSTP TDST TSC STEP# TIDX INDEX# TRD RDATA# TWD WD# 22.4.9 UART/Parallel Port PARAMETER SYMBOL TEST CONDITIONS MIN. MAX. UNIT Delay from Stop to Set Interrupt TSINT 9/16 Delay from IOR Reset Interrupt TRINT 9 1000 nS Delay from Initial IRQ Reset to Transmit Start TIRS 1/16 8/16 Baud Rate Delay from to Reset interrupt THR 175 nS Delay from Initial IOW to interrupt TSI 16/16 Baud Rate Delay from Stop to Set Interrupt TSTI 8/16 Baud Rate Delay from IOR to Reset Interrupt TIR 8 250 nS TMWO 6 200 nS Set Interrupt Delay from Modem Input TSIM 18 250 nS Reset Interrupt Delay from IOR TRIM 9 250 nS Delay from IOR to Output Baud Divisor 9/16 N 100 pF Loading -257- Baud Rate 216-1 Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT UART Receiver Timing Receiver Timing SIN (RECEIVER INPUT DATA) START DATA BITS (5-8) PARITY STOP TSINT IRQ (INTERNAL SIGNAL) TSTI IRQ# (INTERNAL SIGNAL. READ RECEIVER BUFFER REGISTER) UART Transmitter Timing SOUT (SERIAL OUT) START DATA BITS (5-8) PARITY TIRS IRQ (INTERNAL SIGNAL) STOP (1-2) TSTI START THR TSI THR IOW# (INTERNAL SIGNAL, WRITE THR) TIR IOR# (INTERNAL SIGNAL, READ TIR) -258- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 22.4.9.1. Modem Control Timing MODEM Control Timing START IOW# (INTERNAL SIGNAL, WRITE MCR) TMWO TMWO RTS#, DTR# CTS#, DSR#, DCD# TSIM TSIM IRQ (INTERNAL SIGNAL) IOR# (INTERNAL SIGNAL READ MSR) TRIM TRIM TSIM RI# 22.4.10 Parallel Port Mode Parameters PARAMETER SYM. MIN. TYP. MAX. UNIT PD0-7, INDEX , STROBE , AUTOFD Delay from IOW t1 100 nS IRQ Delay from ACK , nFAULT t2 60 nS IRQ Delay from IOW t3 105 nS IRQ Active Low in ECP and EPP Modes t4 300 nS ERROR Active to IRQ Active t5 105 nS MAX. UNIT PARAMETER SYM. 200 MIN. TYP. PD0-7, INDEX , STROBE , AUTOFD Delay from IOW t1 100 nS IRQ Delay from ACK , nFAULT t2 60 nS IRQ Delay from IOW t3 105 nS IRQ Active Low in ECP and EPP Modes t4 300 nS ERROR Active to IRQ Active t5 105 nS -259- 200 Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 22.4.11 Parallel Port 22.4.11.1. Parallel Port Timing IOW t1 INIT, STROBE AUTOFD, SLCTIN PD ACK t2 IRQ (SPP) t3 IRQ (EPP or ECP) t4 nFAULT (ECP) ERROR (ECP) t5 t2 IRQ 22.4.11.2. t4 EPP Data or Address Read Cycle Timing Parameters PARAMETER SYM. MIN. MAX. UNIT WAIT Asserted to WRITE Deasserted t14 0 185 nS Deasserted to WRITE Modified t15 60 190 nS WAIT Asserted to PD Hi-Z t17 60 180 nS Command Asserted to PD Valid t18 0 nS Command Deasserted to PD Hi-Z t19 0 nS WAIT Deasserted to PD Drive t20 60 WRITE Deasserted to Command t21 1 PBDIR Set to Command t22 0 20 nS PD Hi-Z to Command Asserted t23 0 30 nS Asserted to Command Asserted t24 0 195 nS WAIT Deasserted to Command Deasserted t25 60 180 nS -260- 190 nS nS Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT PARAMETER SYM. MIN. MAX. UNIT Time out t26 10 12 nS PD Valid to WAIT Deasserted t27 0 nS PD Hi-Z to WAIT Deasserted t28 0 μS PARAMETER SYM. MIN. MAX. UNIT Ax Valid to IOR Asserted t1 40 nS IOCHRDY Deasserted to IOR Deasserted t2 0 nS IOR Deasserted to Ax Valid t3 10 IOR Deasserted to IOW or IOR Asserted t4 40 IOR Asserted to IOCHRDY Asserted t5 PD Valid to SD Valid 10 nS 0 24 nS t6 0 75 nS IOR Deasserted to SD Hi-Z (Hold Time) t7 0 40 μS SD Valid to IOCHRDY Deasserted t8 0 85 nS WAIT Deasserted to IOCHRDY Deasserted t9 60 160 nS PD Hi-Z to PDBIR Set t10 0 nS WRITE Deasserted to IOR Asserted t13 0 nS WAIT Asserted to WRITE Deasserted t14 0 185 nS Deasserted to WRITE Modified t15 60 190 nS IOR Asserted to PD Hi-Z t16 0 50 nS WAIT Asserted to PD Hi-Z t17 60 180 nS Command Asserted to PD Valid t18 0 nS Command Deasserted to PD Hi-Z t19 0 nS WAIT Deasserted to PD Drive t20 60 WRITE Deasserted to Command t21 1 PBDIR Set to Command t22 0 20 nS PD Hi-Z to Command Asserted t23 0 30 nS Asserted to Command Asserted t24 0 195 nS WAIT Deasserted to Command Deasserted t25 60 180 nS Time out t26 10 12 nS PD Valid to WAIT Deasserted t27 0 nS PD Hi-Z to WAIT Deasserted t28 0 μS -261- 190 nS nS Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 22.4.11.3. EPP Data or Address Read Cycle (EPP Version 1.9) EPP Data or Address Read Cycle (EPP Version 1.9) t14 t15 STB# / WRITE t17 t18 t19 t20 PD t21 t23 t25 t24 ADDRSTB DATASTB t27 t28 BUSY / WAIT 22.4.11.4. EPP Data or Address Read Cycle (EPP Version 1.7) EPP Data or Address Read Cycle (EPP Version 1.7) t14 t15 STB# / WRITE t17 t18 t19 t20 PD t21 t23 t25 t24 ADDRSTB DATASTB t27 t28 BUSY / WAIT -262- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 22.4.11.5. EPP Data or Address Write Cycle Timing Parameters PARAMETER SYM. MIN. PBDIR Low to WRITE Asserted t10 0 WAIT Asserted to WRITE Asserted t11 60 185 nS WAIT Asserted to WRITE Change t12 60 185 nS WAIT Asserted to PD Invalid t14 0 nS PD Invalid to Command Asserted t15 10 nS WAIT Asserted to Command Asserted t17 60 210 nS WAIT Deasserted to Command Deasserted t18 60 190 nS Command Asserted to WAIT Deasserted t19 0 10 μS Time out t20 10 12 μS Command Deasserted to WAIT Asserted t21 0 SYM. MIN. Ax Valid to IOW Asserted t1 40 nS SD Valid to Asserted t2 10 nS IOW Deasserted to Ax Invalid t3 10 nS WAIT Deasserted to IOCHRDY Deasserted t4 0 nS Command Asserted to WAIT Deasserted t5 10 nS IOW Deasserted to IOW or IOR Asserted t6 40 nS IOCHRDY Deasserted to IOW Deasserted t7 0 24 nS WAIT Asserted to Command Asserted t8 60 160 nS IOW Asserted to WAIT Asserted t9 0 70 nS PBDIR Low to WRITE Asserted t10 0 WAIT Asserted to WRITE Asserted t11 60 185 nS WAIT Asserted to WRITE Change t12 60 185 nS IOW Asserted to PD Valid t13 0 50 nS WAIT Asserted to PD Invalid t14 0 nS PD Invalid to Command Asserted t15 10 nS IOW to Command Asserted t16 5 35 nS WAIT Asserted to Command Asserted t17 60 210 nS WAIT Deasserted to Command Deasserted t18 60 190 nS Command Asserted to WAIT Deasserted t19 0 10 μS Time out t20 10 12 μS Command Deasserted to WAIT Asserted t21 0 PARAMETER -263- MAX. UNIT nS nS MAX. UNIT nS nS Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT PARAMETER SYM. MIN. IOW Deasserted to WRITE Deasserted and PD invalid t22 0 WRITE to Command Asserted t16 5 22.4.11.6. MAX. UNIT nS 35 nS EPP Data or Address Write Cycle (EPP Version 1.9) EPP Data or Address Write Cycle (EPP Version 1.9) t11 t10 t12 STB# / WRITE t14 PD t15 t16 t18 t17 ADDRSTB DATASTB t19 t21 BUSY / WAIT t22 PBDIR -264- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 22.4.11.7. EPP Data or Address Write Cycle (EPP Version 1.7) EPP Data or Address Write Cycle (EPP Version 1.7) t11 t10 STB# / WRITE PD t15 t16 t18 t17 DATAST ADDRSTB t19 BUSY / WAIT 22.4.11.8. Parallel Port FIFO Timing Parameters PARAMETER SYMBOL MIN. DATA Valid to nSTROBE Active t1 600 nS nSTROBE Active Pulse Width t2 600 nS DATA Hold from nSTROBE Inactive t3 450 nS BUSY Inactive to PD Inactive t4 80 nS BUSY Inactive to nSTROBE Active t5 680 nS nSTROBE Active to BUSY Active t6 -265- MAX. 500 UNIT nS Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 22.4.11.9. Parallel FIFO Timing t4 t3 PD t1 t2 t5 STB# t6 BUSY 22.4.11.10. ECP Parallel Port Forward Timing Parameters PARAMETER SYMBOL MIN. MAX. UNIT nAUTOFD Valid to nSTROBE Asserted t1 0 60 nS PD Valid to nSTROBE Asserted t2 0 60 nS BUSY Deasserted to nAUTOFD Changed t3 80 180 nS BUSY Deasserted to PD Changed t4 80 180 nS nSTROBE Deasserted to BUSY Deasserted t5 0 BUSY Deasserted to nSTROBE Asserted t6 80 nSTROBE Asserted to BUSY Asserted t7 0 BUSY Asserted to nSTROBE Deasserted t8 80 22.4.11.11. nS 200 nS nS 180 nS ECP Parallel Port Forward Timing t3 nAUTOFD t4 PD t1 t2 t8 t6 STB# t5 t5 t7 BUSY -266- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 22.4.11.12. ECP Parallel Port Reverse Timing Parameters PARAMETER SYMBOL MIN. PD Valid to nACK Asserted t1 0 nS nAUTOFD Deasserted to PD Changed t2 0 nS nAUTOFD Asserted to nACK Asserted t3 0 nS nAUTOFD Deasserted to nACK Deasserted t4 0 nS nACK Deasserted to nAUTOFD Asserted t5 80 200 nS PD Changed to nAUTOFD Deasserted t6 80 200 nS 22.4.11.13. MAX. UNIT ECP Parallel Port Reverse Timing t2 PD t1 t4 t3 nACK t5 t6 t5 nAUTOFD 22.4.12 KBC Timing Parameters SYMBOL DESCRIPTION MIN. MAX. UNIT T1 Address Setup Time from WRB 0 nS T2 Address Setup Time from RDB 0 nS T3 WRB Strobe Width 20 nS T4 RDB Strobe Width 20 nS T5 Address Hold Time from WRB 0 nS T6 Address Hold Time from RDB 0 nS T7 Data Setup Time 50 nS T8 Data Hold Time 0 nS T9 Gate Delay Time from WRB 10 T10 RDB to Drive Data Delay -267- 30 nS 40 nS Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT SYMBOL DESCRIPTION MIN. MAX. UNIT 0 20 nS 4 μS T11 RDB to Floating Data Delay T12 Data Valid After Clock Falling (SEND) T13 K/B Clock Period 20 μS T14 K/B Clock Pulse Width 10 μS T15 Data Valid Before Clock Falling (RECEIVE) 4 μS T16 K/B ACK After Finish Receiving 20 μS T19 Transmit Timeout T20 Data Valid Hold Time 0 T21 Input Clock Period (6−16 Mhz) 63 167 nS T22 Duration of CLK inactive 30 50 μS T23 Duration of CLK active 30 50 μS T24 Time from inactive CLK transition, used to time when the auxiliary device sample DATA 5 25 μS T25 Time of inhibit mode 100 300 μS T26 Time from rising edge of CLK to DATA transition 5 T28-5 μS T27 Duration of CLK inactive 30 50 μS T28 Duration of CLK active 30 50 μS T29 Time from DATA transition to falling edge of CLK 5 25 μS 22.4.12.1. 2 mS μS Writing Cycle Timing A2, CSB T1 WRB T3 T5 ACTIVE T7 D0 ~ D7 T8 DATA IN T9 GA20 OUTPUT PORT -268- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 22.4.12.2. Read Cycle Timing A2, CSB AEN T2 T6 T4 RDB ACTIVE T11 T10 D0 ~ D7 22.4.12.3. DATA OUT Send Data to K/B CLOCK (KCLK) T14 T12 SERIAL DATA (KDAT) 22.4.12.4. START D0 D1 D2 D3 T13 D4 T26 D5 D6 D7 P STOP Receive Data from K/B CLOCK (KCLK) T14 T15 SERIAL DATA (T1) START D0 D1 D2 D3 T13 D4 D5 D6 D7 P STOP T20 -269- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 22.4.12.5. Input Clock CLOCK T21 22.4.12.6. Send Data to Mouse MCLK T25 MDAT 22.4.12.7. START Bit T23 T22 D0 D1 D2 D3 D4 T24 D5 D6 D7 P STOP Bit D5 D6 D7 P STOP Bit Receive Data from Mouse MCLK T27 T26 T29 MDAT T28 START D0 D1 D2 D3 D4 22.4.13 GPIO Timing Parameters SYMBOL PARAMETER tWGO Write data to GPIO update tSWP SWITCH pulse width MIN. 16 MAX. UNIT 300(Note 1) ns msec Note: Refer to Microprocessor Interface Timing for Read Timing. -270- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 22.4.13.1. GPIO Write Timing GPIO Write Timing diagram A0 – A15 VALID IOW D0-7 VALID GPIO 10-17 VALID PREVIOUS STATE GPIO 20-25 tWGO -271- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 22.5 LPC Timing PCICLK t1 LAD0~3,LDRQ# (Output) t2 PCICLK Hold Time Setup Time LPC Input Signals SYMBOL DESCRIPTION MIN. MAX. UNIT t1 Output Valid Delay 4 11 nS t2 Float Delay 4 11 nS t3 LAD[3:0] Setup Time 14 nS t4 LAD[3:0] Hold Time 0 nS t5 LFRAME# Setup Time 12 nS t6 LFRAME# Hold Time 0 nS -272- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 23. TOP MARKING SPECIFICATIONS inbond W83627DHG-P 806G9C28201234FA 1st line: Nuvoton logo 2nd line: part number: W83627DHG-P (Pb-free package) 806G9C28201234FA 3rd line: tracking code 806: packages made in ‘08, week 06 G: assembly house ID; G means GR, A means ASE, etc. 9: code version; 9 means code 009 C: IC revision; A means version A; B means version B, and C means version C 28201234: wafer production series lot number FA: Nuvoton internal use. inbond W83627DHG-PT 806G9C28201234FA 1st line: Nuvoton logo 2nd line: part number: W83627DHG-PT (Pb-free package) 806G9C28201234FA 3rd line: tracking code 806: packages made in ‘08, week 06 G: assembly house ID; G means GR, A means ASE, etc. 9: code version; 9 means code 009 C: IC revision; A means version A; B means version B, and C means version C 28201234: wafer production series lot number FA: Nuvoton internal use. -273- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 24. ORDERING INFORMATION PART NUMBER PACKAGE TYPE PRODUCTION FLOW W83627DHG-P 128Pin QFP (PB-free package) Commercial, 0°C to +70°C W83627DHG-PT 128Pin QFP (PB-free package) Industrial standard, -40°C to 85°C -274- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 25. PACKAGE SPECIFICATION HD D 128 103 1 102 E HE 38 65 39 64 b e c A A2 Symbol A A1 A2 b c D E e HD HE L L1 y 0 L A1 See Detail F Seating Plane y L1 Dimension in inch Min Nom Max Dimension in mm Min Nom 0.134 0.004 Max 3.40 0.10 0.101 0.107 0.113 2.57 2.72 2.87 0.006 0.008 0.010 0.15 0.20 0.25 0.004 0.006 0.010 0.10 0.15 0.25 0.547 0.551 0.555 13.90 14.00 14.10 0.787 0.791 19.90 20.00 20.10 0.783 0.50 0.020 0.669 0.677 0.685 17.00 17.20 17.40 0.905 0.913 0.921 23.00 23.20 23.40 0.023 0.031 0.039 0.60 0.80 1.00 0.055 0.063 0.071 1.40 1.60 1.80 0.004 0 Detail F 12 0.10 0 12 128-pin (QFP, 14x20x2.75mm foot print 3.2mm) -275- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT 26. REVISION HISTORY VERSION DATE PAGE 1.0 12/04/2007 N.A. DESCRIPTION 1. First published version. 1. Add section 7.6.3.4 SMART FAN III+ and the descriptions of Shut-down Mode in section 7.7.1.3 Add the register descriptions of SMART FANTM TM III+, SMART FAN III+-2, and Shut-down Mode in Chapter 8 Hardware Monitor Register Set Update the descriptions of 21.1 Absolute Maximum Ratings and 21.2 DC Characteristics. Add the block diagram for PECI 1.1a to section 7.5 PECI. Correct the data in 20.8 Logical Device 7 (GPIO6), 20.9 Logical Device 8 (WDTO&PLED), 20.10 Logical Device 9 (GPIO2, GPIO3, GPIO4, GPIO5), and 20.13 Logical Device C (PECI, SST). 2. 1.1 01/28/2008 3. N.A. 4. 5. 1.2 02/19/2008 1. 2. 6, 38, 173 3. 1.3 1.4 02/25/2008 04/14/2008 216-222 23-25, 40, 41, 55, 9799, 105-107, 116121, 244, 226 05/14/2008. 6, 16, 38-41, 82, 120121, 156, 232 Correct the pin names in Chapter 4 Pin Layout. Update the PECI 1.1a diagram in section 7.5 PECI. Correct the information in Table 15.1 SERIRQ Sampling Periods. 1. Correct 20.13 Logical Device C (PECI, SST). 1. Add Chapter 6 ACPI Glue Logical Application Notice. Update the descriptions in 8.5 PECI. Correct the table of Display Registers – in SMART FANTM III+ Mode in 8.6.3.4 SMART TM FAN III+. Update register descriptions of Chapter 9 Hardware Monitor Register Set. Add 22.3.1 Power On/Off Timing. Update the description of CR[E5h] bit3 in 21.13 Logical Device C. 2. 3. 4. 5. 6. 1.41 TM 1. 2. 3. 4. 5. 6. -276- Update Chapter 4 Pin Layout. Remove all descriptions of “PECI_AVL”. Update 8.5 PECI descriptions. Correct the descriptions of 9.39, and 9.130 to 9.134. Correct Table 13-1. Update 22.2 DC Characteristics. Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT VERSION DATE PAGE DESCRIPTION 1. 1.42 08/19/2008 22-24, 36, 82, 224, 228, 232, 251 2. 3. 4. 5. 6. 7. 8. 1. 1.43 1.5 09/16/2008 10/14/2008 109 1.7 Correct the description of bit 3-1 of 9.98 FANCTRL6 SMART FANTM III+ input source & output FAN select Register – Index 5Eh (Bank 1). 89, 91, 216, 218, 219, 220, 245, 246, 247 1. 2. 3. 1.6 Update the figures and the title of Chapter 6 ACPI Glue Logic. Update Figure 8-7. Correct the description in 9.39. Update CR[F0h] of 21.12 Logical Device B (Hardware Monitor). Update CR[E5h] and CR[E8h] of 21.13 Logical Device C (PECI, SST). Update 22.1 Absolute Maximum Ratings. Correct 22.3.4 Clock Input Timing. Change Winbond logo to Nuvoton. Update the descriptions of 9.50 and 9.53. Modify the descriptions of CR30h, bit 7 of CRE4h, bit 1 of CRE5h, bits 3-1 of CRE6h, and bit 4 of CRE7h of 21.11 Logical Device A (ACPI). Update the descriptions of 22.3.1 AC Power Failure Resume Timing. 1. Define SMBus Interface in Chapter 5.11; GPIO in Chapter 5.12 2. Add Hardware Monitor Ratings in Chapter 22.2 11/10/2008 17, 232 02/23/2009 3, 9, 10, 11, 12, 84, 106, 111, 112, 194, 201, 203 1. Remove KBC clock rate selection. 2. Add LPT support FDD function, include pin description and register setting. 3. Add / modify the function description in Chapter 9.39, 9.85, 9.86, 9.99 and 9.100. 1. Add part number W83627DHG-PT, supporting 40℃ ~ 85℃ operation temperature. 1.8 04/02/2009 N.A. 1.9 04/27/2009 82,92 1.91 05/21/2009 252 1.92 06/11/2009 178, 247 203, 204 123 ~ 125 1.93 06/25 252 1. Correct Clock input timing data. 1.94 07/09/2009 2, 158, 203, 204 Reserve one UART source clock. 2. Add Chapter 24, Ordering Information. 3. Update Chapter 25, Package Specification. 1. Modify Bank0 CR46[2.1] name. 2. Modify Bank0 CR59 description. 1. Modify clock cycle time and add t3. 1. Correct ACPI power sequence timing. 2. Correct UART A & UART B registers. 3. Correct Hardware Monitor registers. -277- Publication Release Date: July 09, 2009 Version 1.94 W83627DHG-P/W83627DHG-PT Important Notice Nuvoton products are not designed, intended, authorized or warranted for use as components in systems or equipment intended for surgical implantation, atomic energy control instruments, airplane or spaceship instruments, transportation instruments, traffic signal instruments, combustion control instruments, or for other applications intended to support or sustain life. Furthermore, Nuvoton products are not intended for applications wherein failure of Nuvoton products could result or lead to a situation wherein personal injury, death or severe property or environmental damage could occur. Nuvoton customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify Nuvoton for any damages resulting from such improper use or sales. -278- Publication Release Date: July 09, 2009 Version 1.94
W83627DHG-P(FA5B07D) 价格&库存
很抱歉,暂时无法提供与“W83627DHG-P(FA5B07D)”相匹配的价格&库存,您可以联系我们找货
