ASDM30N90KQ
30V N-Channel MOSFET
Product Summary
General Features
● Low Gate Charge
● Advanced Trench Technology
VDS
30
V
● High Power and Current Handling Capability
RDS(on),Typ.@ VGS=10 V
3.0
mΩ
Application
ID
90
A
● Provide Excellent RDS(ON)
● Load Swtich
● PWM applications
● Power management
1
TO-252
N-channel
Absolute Maximum Ratings (TA =25ºC unless otherwise noted)
Parameter
Symbol
Drain-Source Voltage
Gate-Source Voltage
Continuous Drain Current
B
TC =100ºC
A
Avalanche Current
Single Pulse Avalanche Energy
C
L =0.3mH
Units
VDS
30
V
VGS
±20
V
ID
A
Pulsed Drain Current
Power Dissipation
TC =25ºC
Maximum
A
TC =25ºC
A
46
IDM
255
A
IS
90
A
EAS
135
mJ
65
W
32
W
TJ, TSTG
-55 to 175
ºC
Symbol
Maximum
Units
PD
TC =100ºC
Junction and Storage Temperature Range
90
Thermal Characteristics
Parameter
Maximum Junction-to-Case
Steady-State
RƟJC
2.3
Maximum Junction-to-Ambient
Steady-State
RƟJA
100
ºC/W
FEB 2019 Version2.0
1/7
www.ascendsemi.com
0755-86970486
ASDM30N90KQ
Electrical Characteristics(TJ =25ºC unless otherwise noted)
Value
Symbol
Parameter
Conditions
Units
Min
Typ
Max
30
TJ =25ºC
1
TJ =125ºC
25
STATIC PARAMETERS
BVDSS
Drain-Source Breakdown Voltage
ID =250µA,VGS =0V
IDSS
Zero Gate Voltage Drain Current
VDS =30V, VGS =0V
V
μA
IGSS
Gate-Body Leakage Current
VDS =0V, VGS =±20V
±100
nA
VGS(th)
Gate Threshold Voltage
VDS =VGS, ID =250µA
1
1.7
2.4
V
VGS =10V, ID =30A
3.0
4.5
mΩ
RDS(ON)
Static Drain-Source On-Resistance
VGS =4.5V, ID =30A
4.8
6.5
mΩ
gFS
Forward Transconductance
VDS =10V, ID =20A
16
S
VSD
Diode Forward Voltage
IS =30A, VGS =0V
1
V
IS
Maximum Body-Diode Continuous Current
90
A
2120
307
253
40
5.4
B
DYNAMIC PARAMETERS
Ciss
Input Capacitance
Coss
Output Capacitance
Crss
Reverse Transfer Capacitance
VGS =0V, VDS =15V, f =1MHZ
pF
SWITCHING PARAMETERS
Qg
Total Gate Charge
Qgs
Gate Source Charge
Qgd
Gate Drain Charge
9.6
tD(on)
Turn-On Delay Time
15
tr
Turn-On Rise Time
32
tD(off)
Turn-Off Delay Time
15
tf
Turn-Off Fall Time
12
trr
Body Diode Reverse Recovery Time
23
ns
Qrr
Body Diode Reverse Recovery Charge
48
nC
VGS =10V,VDS =15V, ID =30A
VGS =10V,VDS =15V, ID =20A,
RG =3Ω
IF =30A, di/dt =100A/μs
nC
ns
A. Single pulse width limited by maximum junction temperature.
B. The maximum current rating is package limited.
C. The power dissipation PD is based on TJ(MAX) =175ºC, using junction-to-case thermal resistance, and is more useful in setting
the upper dissipation limit for cases where additional heatsinking is used.
FEB 2019 Version2.0
2/7
www.ascendsemi.com
0755-86970486
ASDM30N90KQ
Typical Characteristics TJ = 25ºC, unless otherwise noted
120
80
100
ID (A)
100
ID (A)
120
10V
8V
6V
4.5V
4V
3.5V
60
80
60
40
40
2
3
4
VDS = 15V
TJ = 125ºC
TJ = 25ºC
2
VDS (Volts)
Figure 1: On-Region Characteristics
5
6
10000
9
TJ = 25ºC
Capacitance (pF)
RDS(on) (mΩ)
4
Figure 2: Transfer Characteristics
10
8
7
6
VGS = 4.5V
5
Ciss
1000
Coss
Crss
100
4
VGS = 10V
VGS = 0
f = 1MHz
3
10
2
10
15
ID (A)
Figure 3: On-Resistance vs. Drain Current
5
10
15
30
VDS (Volts)
Figure 4: Capacitance Characteristics
12
100
10
VDD = 15V
IS (A)
VGS (Volts)
3
VGS (Volts)
8
TJ = 125ºC
10
6
4
TJ = 25ºC
1
2
40
50
Qg (nC)
Figure 5: Gate Charge Characteristics
FEB 2019 Version2.0
3/7
0.1
0.2
0.4
0.6
0.8
1
VSD (Volts)
Figure 6: Body Diode Forward Voltage
www.ascendsemi.com
0755-86970486
1.2
ASDM30N90KQ
1.3
Normalized Vgs(th)
Normalized RDS(on)
1.6
VGS = 10V
ID = 30A
1.4
1.2
1.0
0.8
0.6
1.2
ID = 250µA
1.1
1.0
0.9
0.4
0.8
0.2
0.7
0.0
0.6
-50
-25
50
75
100
125
150
-50
-25
Temperature(ºC)
Figure 7: On-Resistance vs. Junction Temperature
50
75
100
125
150
Figure 8: Vgs(th) vs. Junction Temperature
1.15
VGS = 0
ID = 250uA
1.10
18
RDS(on) (mΩ)
Normalized BVDSS
25
Temperature(ºC)
1.05
VGS = 10V
ID = 30A
16
14
12
10
1.00
8
TJ = 125ºC
6
0.95
4
2
TJ = 25ºC
-25
50
75
100
125
150
2
TJ, Junction Temperature (ºC)
Figure 9: BVDSS vs. Junction Temperature
4
5
6
7
8
9
10
1000
10
1
RDS(on)
limited
100
10
D = 0.5
D = 0.2
D = 0.1
D = 0.05
D = 0.02
D = 0.01
Single Pulse
0.1
0.01
1E-05
3
VGS, Gate-to-Source Voltage (V)
Figure 10: On-Resistance vs. Gate-Source Voltage
ID (Amps)
Z Ɵ JC Normalized Transient Thermal Resistance
0.90
tp = 10us
tp = 100us
tp = 1ms
tp = 10ms
DC
1
0.1
0.0001
0.001
0.01
0.1
1
Pulse Width (s)
Figure 11: Normalized Transient Thermal Resistance
FEB 2019 Version2.0
4/7
0.1
1
10
100
1000
VDS (Volts)
Figure 12: Safe Operating Area
www.ascendsemi.com
0755-86970486
ASDM30N90KQ
Ordering and Marking Information
Ordering Device No.
Marking
Package
Packing
ASDM30N90KQ-R
30N90
TO-252
Tape&Reel
2500/Reel
MARKING
PACKAGE
TO-252
FEB 2019 Version2.0
Quantity
30N90
5/7
www.ascendsemi.com
0755-86970486
ASDM30N90KQ
TO-252 PACKAGE IN FORMATION
6\PERO
'LPHQVLRQVLQ0LOOLPHWHUV
'LPHQVLRQVLQ,QFKHV
0LQ
0D[
0LQ
0D[
E
E
F
F
7
很抱歉,暂时无法提供与“ASDM30N90KQ-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.91500
- 100+0.85400
- 300+0.79300
- 500+0.73200
- 2000+0.70150
- 5000+0.68320
