C45S1224M9SC350
C45S1224M9SC350
    FARATRONIC(法拉)
    CAP_26.5X8.5MM_TM
    安规电容 CAP_26.5X8.5MM_TM 220nF ±20% 440V
C45S1224M9SC350 数据手册
 MKP65 Version history Current version Date Author Change description Page 2 of 10  MKP65 Metallized polypropylene film interference suppression capacitor (Class X1, 440Vac/480Vac) ■ Outline Drawing W±0.4, H±0.4, T±0.4 4-pins Square-bottom 4pins W±0.4, H±0.4, T±0.4 Arc-bottom 4pins ■ Features ● Metallized polypropylene structure ● Compact size ● Withstanding overvoltage stressing ● Excellent active and passive flame resistant abilities ● Used in across-the-line, interference suppression circuit. ■ Safety Approvals ● CQC ● ENEC-VDE ● UL/CUL IEC 60384-14:2013, X1, 440Vac/480Vac, 0.0010F~10.0F, 40/110/56/B Certificate No.: CQC06001016942 EN 60384-14:2013, X1, 440Vac/480Vac, 0.0010F~10.0F, 40/110/56/B Certificate No.: 40021925 UL60384-14:2014, CSA E60384-14:09, X1, 440Vac/480Vac, 0.0010F ~ 10.0F, 40/110/56/B File No. : E186600,CCN: FOWX2/8 Page 3 of 10  MKP65 ■ Specifications Class Climatic Category / Passive Flammability Category Operating Temperature Range Class X1 40/110/56/B -40℃ ~ +110℃ Rated Voltage (UR) 440Vac/480Vac, 50/60Hz Maximum continuous DC voltage 1 000Vdc Capacitance Range 0.0010F~10.0F Capacitance Tolerance 10(K), 20(M) Between Terminals: Between Terminals To Case: R≥15 000M , CN≤0.33F Voltage Proof Insulation Resistance Dissipation Factor(tanδ) 4.3UR(dc), 2s 2560 (Vac), 1min (20℃, 100V ,1min) RCN≥5 000s, CN>0.33F 0.0010FCN≤0.010F 0.010FCN≤0.47F ≤2510-4(1kHz,20℃) ≤1510-4(1kHz,20℃) ≤2510-4(10kHz,20℃) ≤2010-4(10kHz,20℃) 0.47FCN≤1.0F ≤2010-4(1kHz,20℃) ≤4010-4(10kHz,20℃) 1.0FCN ≤3010-4(1kHz,20℃) ---------- Page 4 of 10  MKP65 ■ Part number system The 18 digits part number is formed as follow: 1 2 3 C 4 5 4 Digit 1 to 3 5 6 7 8 9 1 0 11 1 2 1 3 1 4 1 5 1 6 1 7 1 8 Series code C45=MKP65 Digit 4 to 5 A.C. rated voltage S1=440V S3=480V Digit 6 to 8 Rated capacitance value For example : 103=10×103 pF= 0.01μF Digit 9 Capacitance tolerance K=±10%, M=±20% Digit 10 Pitch 3=7.5 mm B=27.5mm 4=10.0mm 6=15.0mm 9=22.5mm F=37.5mm M=52.5mm Digit 11 Internal use Digit 12 to 15 Lead form and packaging code Digit 16 to 18 Internal use Table1 Lead form and packaging code Digit 12 code explanation Digit 13 explanation code explanation code F=10.0mm F=15.0mm 0 straight 5 P3=25.4mm;H=18.5mm (For pitch=10/15mm) 0 Length tolerance ±0.5mm Or standard length 2 Length tolerance ±0.3mm ammo-pack 4 6 C straight lead “C” in the figure above code 00 P1=20.3mm±0.5mm P1=20mm±0.5mm Digit 15 code A T 3 Digit 14 explanation 45 35 32 standard lead length (18mm~26mm) lead length 4.5mm lead length 3.5mm lead length 3.2mm 45 55 lead length 4.5mm lead length 5.5mm 0 Page 5 of 10 explanation Length tolerance ±0.5mm or standard length  MKP65 ■ Dimensions(mm) 440Vac/480Vac# CN (F) W 440Vac/480Vac# Part number CN (F) H T P d T P d 0.0010 10.5 9.0 4.0 7.5 0.6 C45S1102-30****+++ 0.056M 17.5 12.0 6.0 15.0 0.6 C45S1563M6S****+++ ★1.0M 32.0 16.0 27.5 27.5 0.8 C45S1105MBC****+++ 0.0012 10.5 9.0 4.0 7.5 0.6 C45S1122-30****+++ 0.056K 17.5 12.0 7.0 15.0 0.6 C45S1563K6S****+++ ★1.0K 32.0 18.5 31.0 27.5 0.8 C45S1105KBC****+++ 0.0015 10.5 9.0 4.0 7.5 0.6 C45S1152-30****+++ 0.068 17.5 13.5 7.5 15.0 0.6 C45S1683-6S****+++ 1.0 32.0 28.0 17.0 27.5 0.8 C45S1105-BA****+++ 0.0018 10.5 9.0 4.0 7.5 0.6 C45S1182-30****+++ 0.068 17.5 12.0 13.0 15.0 0.8 C45S1683-6C****+++ 1.0 32.0 30.0 16.0 27.5 0.8 C45S1105-BS****+++ 0.0022 10.5 9.0 4.0 7.5 0.6 C45S1222-30****+++ 0.082 17.5 14.0 C45S1823-6S****+++ 1.2M 32.0 30.0 16.0 27.5 0.8 C45S1125MBS****+++ 0.0027 10.5 9.0 4.0 7.5 0.6 C45S1272-30****+++ 0.10M 17.5 14.0 8.0 15.0 0.6 C45S1104M6S****+++ 1.2M 32.0 28.0 17.0 27.5 0.8 C45S1125MBA****+++ 0.0033 10.5 9.0 4.0 7.5 0.6 C45S1332-30****+++ 0.10K 17.5 14.5 8.5 15.0 0.6 C45S1104K6S****+++ 1.2K 32.0 29.0 19.0 27.5 0.8 C45S1125KBA****+++ 0.0039 10.5 9.0 4.0 7.5 0.6 C45S1392-30****+++ 1.2K 32.0 33.0 18.0 27.5 0.8 C45S1125KBS****+++ 0.0047 10.5 9.0 4.0 7.5 0.6 C45S1472-30****+++ 0.15M 17.5 16.0 10.0 15.0 0.8 C45S1154M6S****+++ 0.0056 10.5 9.0 8.0 15.0 0.6 17.5 16.0 10.0 15.0 0.8 Part number CN (F) H 0.12 W 440Vac/480Vac# C45S1124-6S****+++ W H T P d Part number 1.5M 32.0 29.0 19.0 27.5 0.8 C45S1155MBA****+++ 4.0 7.5 0.6 C45S1562-30****+++ 0.15K 17.5 19.0 11.0 15.0 0.8 C45S1154K6S****+++ ★1.5M 32.0 18.5 31.0 27.5 0.8 C45S1155MBC****+++ 0.0068 10.5 11.0 5.0 7.5 0.6 C45S1682-30****+++ 0.18 C45S1184-6S****+++ 1.5 32.0 33.0 18.0 27.5 0.8 C45S1155-BS****+++ 0.0082 10.5 11.0 5.0 7.5 0.6 C45S1822-30****+++ 0.039 26.5 15.0 6.0 22.5 0.8 C45S1393-90****+++ 1.8 32.0 37.0 22.0 27.5 0.8 C45S1185-BS****+++ 0.010 10.5 11.0 5.0 7.5 0.6 C45S1103-30****+++ 0.047 26.5 15.0 6.0 22.5 0.8 C45S1473-90****+++ 2.2M 32.0 37.0 22.0 27.5 0.8 C45S1225MBS****+++ 0.012 10.5 12.0 6.0 7.5 0.6 C45S1123-30****+++ 0.056 26.5 15.0 6.0 22.5 0.8 C45S1563-90****+++ 0.33 41.0 22.0 11.0 37.5 1.0 C45S1334-F0****+++ 0.015M 10.5 12.0 6.0 7.5 0.6 C45S1153M30****+++ 0.068 26.5 15.0 6.0 22.5 0.8 0.39 41.0 22.0 11.0 37.5 1.0 C45S1394-F0****+++ 0.47 41.0 22.0 11.0 37.5 1.0 C45S1474-FS****+++ C45S1564-FS****+++ 17.5 19.0 11.0 15.0 0.8 0.0010 13.0 9.0 4.0 10.0 0.6 C45S1102-40****+++ 0.082 26.5 15.0 6.0 22.5 0.8 C45S1683-90****+++ C45S1823-9S****+++ 0.0012 13.0 9.0 4.0 10.0 0.6 C45S1122-40****+++ 0.10 26.5 15.0 6.0 22.5 0.8 C45S1104-9S****+++ 0.56 41.0 22.0 11.0 37.5 1.0 0.0015 13.0 9.0 4.0 10.0 0.6 C45S1152-40****+++ 0.12 26.5 15.0 6.0 22.5 0.8 C45S1124-9S****+++ 0.68 41.0 22.0 11.0 37.5 1.0 C45S1684-FS****+++ 0.0018 13.0 9.0 4.0 10.0 0.6 C45S1182-40****+++ 0.15 26.5 16.0 7.0 22.5 0.8 C45S1154-9S****+++ 0.82M 41.0 22.0 11.0 37.5 1.0 C45S1824MFS****+++ 0.0022 13.0 9.0 4.0 10.0 0.6 C45S1222-40****+++ 0.18 26.5 17.0 8.5 22.5 0.8 C45S1184-9S****+++ 0.82K 41.0 24.0 13.0 37.5 1.0 C45S1824KFS****+++ 0.0027 13.0 9.0 4.0 10.0 0.6 C45S1272-40****+++ 0.22 26.5 17.0 8.5 22.5 0.8 C45S1224-9S****+++ 1.0 41.0 24.0 13.0 37.5 1.0 C45S1105-FS****+++ 0.0033 13.0 9.0 4.0 10.0 0.6 C45S1332-40****+++ 0.27 26.5 18.5 10.0 22.5 0.8 C45S1274-9S****+++ 1.0 42.0 15.0 24.0 37.5 1.0 C45S1105-FC****+++ 0.0039 13.0 9.0 4.0 10.0 0.6 C45S1392-40****+++ 0.33 26.5 20.0 11.0 22.5 0.8 C45S1334-9S****+++ 1.2 41.0 26.0 15.0 37.5 1.0 C45S1125-FA****+++ 0.0047 13.0 9.0 4.0 10.0 0.6 C45S1472-4S****+++ 0.39 26.5 20.0 11.0 22.5 0.8 C45S1394-9S****+++ 1.2 42.0 28.0 14.0 37.5 1.0 C45S1125-FS****+++ 0.0056 13.0 9.0 4.0 10.0 0.6 C45S1562-4S****+++ 0.47M 26.5 22.0 12.0 22.5 0.8 C45S1474M9S****+++ 1.5M 41.0 26.0 15.0 37.5 1.0 C45S1155MFA****+++ 0.0068 13.0 9.0 4.0 10.0 0.6 C45S1682-4S****+++ 0.47K 26.5 23.0 13.5 22.5 0.8 C45S1474K9S****+++ 1.5M 42.0 28.0 14.0 37.5 1.0 C45S1155MFS****+++ 0.0082 13.0 9.0 4.0 10.0 0.6 C45S1822-4S****+++ 0.56M 26.5 23.0 13.5 22.5 0.8 C45S1564M9S****+++ 1.5K 41.0 30.0 16.0 37.5 1.0 C45S1155KFS****+++ 0.010 13.0 9.0 4.0 10.0 0.6 C45S1103-4S****+++ 0.56K 26.5 24.5 15.5 22.5 0.8 C45S1564K9S****+++ 0.012 13.0 11.0 5.0 10.0 0.6 C45S1123-4S****+++ 0.68M 26.5 24.5 15.5 22.5 0.8 C45S1684M9S****+++ 0.015 13.0 11.0 5.0 10.0 0.6 C45S1153-4S****+++ 0.15 32.0 18.0 9.0 27.5 0.8 C45S1154-B0****+++ 1.8K 41.0 32.0 17.0 37.5 1.0 C45S1185KFS****+++ 0.018 13.0 11.0 5.0 10.0 0.6 C45S1183-4S****+++ 0.18 32.0 18.0 9.0 27.5 0.8 C45S1184-B0****+++ 2.2M 41.0 32.0 17.0 37.5 1.0 C45S1225MFA****+++ 0.022 13.0 11.0 5.0 10.0 0.6 C45S1223-4S****+++ 0.22 32.0 18.0 9.0 27.5 0.8 C45S1224-B0****+++ 2.2 41.0 33.5 18.5 37.5 1.0 C45S1225-FS****+++ 0.027 13.0 12.0 6.0 10.0 0.6 C45S1273-4S****+++ 0.27 32.0 18.0 9.0 27.5 0.8 C45S1274-BS****+++ 2.7 41.0 37.0 22.0 37.5 1.0 C45S1275-FS****+++ 0.033 13.0 12.0 6.0 10.0 0.6 C45S1333-4S****+++ 0.33 32.0 18.0 9.0 27.5 0.8 C45S1334-BS****+++ 3.3M 41.0 37.0 22.0 37.5 1.0 C45S1335MFS****+++ 0.039 13.0 13.0 7.0 10.0 0.6 C45S1393-4S****+++ 0.33 32.0 12.0 18.0 27.5 0.8 C45S1334-BC****+++ 3.3K 41.0 41.0 26.0 37.5 1.0 C45S1335KFS****+++ 0.047M 13.0 13.0 7.0 10.0 0.6 C45S1473M4S****+++ 0.39 32.0 20.0 11.0 27.5 0.8 C45S1394-BS****+++ 3.3K 41.5 37.5 27.5 37.5 1.0 C45S1335KFA****+++ 0.047K 13.0 14.0 8.0 10.0 0.6 C45S1473K4S****+++ 0.47 1.5 42.0 19.0 24.0 37.5 1.0 C45S1155-FC****+++ 1.8M 41.0 30.0 16.0 37.5 1.0 C45S1185MFS****+++ 32.0 20.0 11.0 27.5 0.8 C45S1474-BS****+++ 3.9 41.0 41.0 26.0 37.5 1.0 C45S1395-FS****+++ 0.056 13.0 14.0 8.0 10.0 0.6 C45S1563-4S****+++ ★0.47 32.0 12.0 22.0 27.5 0.8 C45S1474-BC****+++ 3.9 41.5 37.5 27.5 37.5 1.0 C45S1395-FA****+++ 0.010 17.5 9.5 5.0 15.0 0.6 C45S1103-6S****+++ 32.0 22.0 13.0 27.5 0.8 C45S1564-BS****+++ 4.7M 41.0 43.0 28.0 37.5 1.0 C45S1475MFS****+++ 0.012 17.5 9.5 5.0 15.0 0.6 C45S1123-6S****+++ 0.68M 32.0 22.0 13.0 27.5 0.8 C45S1684MBS****+++ 4.7K 42.0 45.0 30.0 37.5 1.0 C45S1475KFS****+++ 0.015 17.5 9.5 5.0 15.0 0.6 C45S1153-6S****+++ 0.68K 32.0 25.0 13.0 27.5 0.8 C45S1684KBA****+++ ★4.7 57.0 38.0 24.0 52.5 1.2 C45S1475-MST***+++ 0.018 17.5 9.5 5.0 15.0 0.6 C45S1183-6S****+++ 0.68K 32.0 24.5 15.0 27.5 0.8 C45S1684KBS****+++ 5.6 57.0 45.0 30.0 52.5 1.2 C45S1565-MST***+++ 0.022 17.5 9.5 5.0 15.0 0.6 C45S1223-6S****+++ ★0.68 32.0 16.0 22.0 27.5 0.8 C45S1684-BC****+++ 6.8 57.0 45.0 30.0 52.5 1.2 C45S1685-MST***+++ 0.027 17.5 11.0 5.0 15.0 0.6 C45S1273-6S****+++ 0.82M 32.0 25.0 13.0 27.5 0.8 C45S1824MBS****+++ 6.8 57.0 30.0 44.0 52.5 1.2 C45S1685-MCT***+++ 0.033 17.5 11.0 5.0 15.0 0.6 C45S1333-6S****+++ 0.82K 32.0 24.5 15.0 27.5 0.8 C45S1824KBS****+++ 8.2 57.0 50.0 35.0 52.5 1.2 C45S1825-MST***+++ 0.039 17.5 12.0 6.0 15.0 0.6 C45S1393-6S****+++ 0.82K 32.0 28.0 14.0 27.5 0.8 C45S1824KBA****+++ 10.0 57.0 50.0 35.0 52.5 1.2 C45S1106-MST***+++ 0.047 17.5 12.0 6.0 15.0 0.6 C45S1473-6S****+++ 0.56 Note: 1. “-”=capacitance tolerance code, M=±20%,K=±10% 2. “****”=lead form and packaging code (refer to table 1) 3. “#”when the rated voltage is 480Vac,the digit 4~5 is S3. 4. “★” = Arc bottom of the outer shell Page 6 of 10  MKP65 ■ Maximum permissible voltage change per unit of time Rated Voltage (Vac) P=10mm P=15mm P=22.5mm P=27.5mm P=37.5mm 440 750 600 300 225 150 dV/dt(V/us) at 680 Vdc Note: 1. Rated voltage pulse slope (dV/dt)R at rated voltage. 2. If the working voltage(U) is lower than the rated voltage(UR),the capacitor can be worked at a higher dV/dt. In this case, the maximum allowed dV/dt is obtain by multiplying the right value with UR/U. ■ Test Method And Performance No. Item 1 4.5 Solderability Good quality of tinning 2 4.3 Terminal strength There shall be no visible damage 3 4.4 Resistance to solder heat 4 4.20 Solvent resistance of the marking The marking shall be legible 4.2 Initial measurement 4.6 Rapid change of temperature Capacitance, Tg There shall be no evidence of deterioration. 4.7 Vibration There shall be no evidence of deterioration. 5 4.8 Bump Final measurement 6 4.11 Climate sequence There shall be no visible damage C/C 5(relative to the initial value) There shall be no evidence of deterioration. There shall be no visible damage C/C 5(relative to the initial value) Initial measurement Dry heat Damp heat, Cyclic Cold Damp heat, cyclic other Final measurement Test Method (IEC 60384-14) Performance Solder temperature: 245˚C 5˚C Immersion time: 2.0s0.5s Tense: 0.50d≤0.80, 10N 0.80d≤1.25, 20N Bend: 0.50d≤0.80, 5N 0.80d≤1.25, 10N The terminals shall be bent 2 times in each direction Solder temperature:260˚C5˚C Immersion time: 10s1s Solvent: Industrial isopropanol. Solvent temperature:23˚C±5˚C Dipping time: 5min0.5min Condition: scrub Scrub material: absorbent cotton Reverting time: No A=-40˚C, B =+110˚C 5 cycles Duration: t=30min Amplitude 0.75mm or acceleration 98m/s2 (whichever is the smaller severity), f: 10Hz to 500Hz. Three directions, 2h for each direction,total 6h. 4 000 times, Acceleration: 400m/s2, Pulse duration, 6ms +110℃, 16h Test Db, Severity: b, the first cycle -40℃, 2h Test Db, Severity b, the other cycles There shall be no visible damage, legible marking C/C 5(relative to the initial value) Increase of tg: CN1F: 0.008 (10kHz) CN1F: 0.005 (1kHz) Dielectric strength : there shall be no permanent breakdown or flashover I.R.:  50 of the rated value Page 7 of 10  MKP65 No. 7 8 Item Performance 4.12 Damp heat steady state There shall be no visible damage, legible marking C/C 5(relative to the initial value) Increase of tg: CN1F: 0.008 (10kHz) CN1F: 0.005 (1kHz) Dielectric strength : there shall be no permanent breakdown or flashover I.R.:  50 of the rated value 4.13 Impulse voltage There are three or more waveforms which indicate that no self-heating breakdown have occurred when it is monitored by the monitor Test Method (IEC 60384-14) Temperature: 40˚C 2˚C 2 Humidity: 93  3 %RH Duration: 56 days Each individual capacitor shall be subjected to 24 impulses of the same polarity (when any three successive impulses are shown by the monitor to have a wave form indicating that no self-healing breakdown have taken place the impulses can be stopped), the time between impulses shall not be less than 10s, and the peak value of the voltage impulse: 4.0kV ( suitable for CN1F; When CN1F, the capacitor can endure pulse voltage value is 4.0 / CN kV) 9 4.14 Endurance There shall be no visible damage, legible marking C/C10(relative to the initial value) Increase of tg: CN1F: 0.008 (10kHz) CN1F: 0.005 (1kHz) Dielectric strength : There shall be no breakdown or flashover I.R. :  50 of the rated value +110˚C, 1.25URVa.c., 1 000h The voltage shall be subjected to 1000Vrms for 0.1s every one hour during test. Times: 10 000 Duration of charging: 0.5s Duration of discharging: 0.5s 10 11 4.15 Charging and discharging 4.17 Passive flammability C/C10(relative to the initial value) Increase of tg: CN1F: 0.008 (10kHz) CN1F: 0.005 (1kHz) I.R.:  50 of the rated value The flaming time of each capacitor shall not go beyond 10s after it is taken apart from the flame. Drop of each capacitor caused by flame shall not fire the tissue below. Page 8 of 10 Charging voltage: 2 UR Vd.c. Charging resistance: 220/CN() or the current ≤1.0A (whichever is the minor) Discharging resistance: 2UR R () dU CN  dt CN: Capacitance (F) Needle flame test The category of flammability: B Expose time: 1 time Capacitor Volume Exposing time 250
C45S1224M9SC350 价格&库存
很抱歉,暂时无法提供与“C45S1224M9SC350”相匹配的价格&库存,您可以联系我们找货
