LM358
LINEAR INTEGRATED CIRCUIT
DUAL OPERATIONAL AMPLIFIER
DESCRIPTION
The LM358 consists of two independent high gain,
internally frequency compensated operational amplifier. It can
be operated from a single power supply and also split power
supplies.
SOP-8
FEATURES
*Internally frequency compensated for unity gain.
*Wide power supply range 3V - 30V.
*Input common-mode voltage range include ground.
*Large DC voltage gain.
APPLICATIONS
DIP-8
*General purpose amplifier.
*Transducer amplifier.
PIN CONFIGURATIONS
1
OUTPUT 1 1
8 Vcc
INPUT1(-) 2
7 OUTPUT2
INPUT1(+) 3
6 INPUT2(-)
VEE / GND 4
5 INPUT2(+)
LM358
BLOCK DIAGRAM
For one channel
Vcc
T21
T20
T18
T17
T16
INPUT (-)
T1
T2
T4
T15
T3
C1
T9
INPUT (+)
R2
R1
T12
OUTPUT
T14
T7
T5
T6
T8
T10
T11
T13
Vee
ABSOLUTE MAXIMUM RATINGS
PARAMETER
Supply Voltage
Differential Input Voltage
Input Voltage
SYMBOL
VALUE
Vcc
+-15 or 30
VI(DIFF)
VI
Output Short to Ground
Operating Temperature
30
-0.3 ~ +30
UNIT
V
V
V
Continuous
TOPR
0 ~ +70
°C
TSTG
-65 ~ +150
°C
Range
Storage Temperature Range
2
LM358
ELECTRICAL CHARACTERISTICS(Vcc=5.0V,VEE=GND,TA=25°C, unless otherwise specified£
PARAMETER
Input Offset Voltage
SYMBOL
TEST CONDITION
VIO
VCM=0V toVCC-1.5V
MIN
TYP
MAX
UNIT
2.9
6.0
mV
VO(P)=1.4V,RS=0Ω
Input Offset Current
IIO
5
50
nA
Input Bias Current
IBIAS
45
250
nA
Input Common Mode Voltage
VI(R)
VCC=30V
VCC-1.5
V
Power Supply Current
ICC
RL=∝,VCC=30V
0.8
2.0
mA
RL=∝,Full Temperature
0.5
1.2
mA
Range
Large Signal Voltage Gain
GV
VCC=15V,RL>=2KΩ
25
100
V/mV
VO(P)=1V to 11V
Output Voltage Swing
VO(H)
VO(L)
Common Mode Rejection
VCC=30V,RL=2KΩ
24
V
VCC=30V,RL=10KΩ
25
V
VCC=5V,RL>=10KΩ
5
mV
CMRR
65
80
dB
PSRR
65
100
dB
Ratio
Power Supply Rejection
Ratio
Channel Separation
CS
Short Circuit Current to
ISC
f=1KHZ to 20KHZ
120
40
dB
60
mA
Ground
Output Current
ISOURCE
VI(+)=1V,VI(-)=0V
mA
5
mA
VCC=15V,VO(P)=2V
VI(+)=0V,VI(-)=1V
ISINK
3
VI(DIFF)
VCC=15V,VO(P)=2V
VCC
V
LM358
TYPICAL PERFORMANCE CHARACTERISTICS
Fig.2 Input Current vs Temperature
Fig.1 Input Voltage Range
100
Input Current (mA)
Input Voltage
15
Negative
Input
10
Positive
Input
80
Vcc=+30V
60
Vcc=+15V
40
5
Vcc=+5V
10
Power Supply Voltage
15
-25
75
100
Fig. 4 Voltage Gain vs Supply Voltage
Fig.3 Input Current vs Supply Voltage
160
40
Vcc
RL=20kΩ
(dB)
Ic
30
Voltage Gain æ
Input Current (mA)
50
Temperature(¢XC)
Ta= 0~+85¢XC
Ta= -40¢XC
10
RL=2kΩ
80
40
7.5
15
22.5
30
Supply Voltage (V)
Supply Voltage (V)
Common Mode Rejection Ratio (dB)
Fig. 5 Open Loop Gain vs Frequency
(dB)
100
Voltage Gain
120
80
Vcc
100M Ω
0.1 µF
Vin
Vcc/2
60
40
Vcc=30V
Vcc=15V
Fig. 6 Common Mode Rejection Ratio vs Frequency
120
100
Vcc=+7.5V
Vee=-7.5V
80
+7.5V
60
100k Ω
100 Ω
40
100 Ω
Vin
100k Ω
-7.5V
101
2
10
103
104
105
Frequency (Hz)
4
106
10 7
2
10
10 3
10 4
Frequency (Hz)
105
106
LM358
Fig. 8 Voltage Follower Response (Small Signal)
Output Voltage¹ (V) Input Voltage (V)
Fig. 7 Voltage Follower Pulse Response
3
450
RL=2kΩ
Vcc=15V
Output Voltage (V)
2
1
400
350
2
1
300
30
Time (uS)
40
1
Fig. 9 Gain vs Large Signal Frequency
3
2
4
5
6
Timeä (µs)
7
8
9
Fig. 10 Output Current Sinking vs Output Voltage
Output Voltage Gain (Vp-p)
8
Output Voltage Vo(V)
7
15
+15V
100k
1k
Vi
+7V
2k
10
5
Ta=25¢XC
6
Vcc
Vcc/
2
5
Vo
Io
4
3
2
10
3
10
4
10
5
10
6
-3
10
-2
10
-1
10
1
10
10
2
Output Source Current (mA)
Frequency (Hz)
Fig. 11 Output Sink Current vs Output Voltage
Fig.12 Current Limiting vs Temperature
10
Output Current Io (mA)
Output Voltage (V)
60
1
40
Vcc=+5V
Vcc=+15V
-1
Vcc
10
Vcc/
2
Vcc=+30V
Vo
Io
-2
10
10
-1
10
1
Output Sink Current (mA)
5
10
10
2
-50
-25
25
50
TemperatureÈ (¢XC)
75
100
很抱歉,暂时无法提供与“LM358”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.24787
- 20+0.22600
- 100+0.20413
- 500+0.18226
- 1000+0.17205
- 2000+0.16476
