LM358 (YW)
DUAL OPERATIONAL AMPLIFIER
DESCRIPTION
The LM358 consists of two independent high gain,
internally frequency compensated operational amplifier. It can
be operated from a single power supply and also split power
supplies.
SOP-8
FEATURES
JS
MI
*Internally frequency compensated for unity gain.
*Wide power supply range 3V - 32V.
*Input common-mode voltage range include ground.
*Large DC voltage gain.
APPLICATIONS
DIP-8
CR
*General purpose amplifier.
*Transducer amplifier.
O
PIN CONFIGURATIONS
VEE / GND 4
7 OUTPUT2
6 INPUT2(-)
r
to
uc
nd
INPUT1(+) 3
8 Vcc
co
INPUT1(-) 2
mi
Se
OUTPUT 1 1
5 INPUT2(+)
www.jsmsemi.com
第1/5页
LM358 (YW)
BLOCK DIAGRAM
For one channel
Vcc
T21
T20
T18
T17
T16
INPUT (-)
T2
T1
T4
T15
T3
JS
C1
T9
R1
T12
OUTPUT
T14
MI
INPUT (+)
R2
T7
T5
T8
T6
T10
T11
T13
CR
Vee
O
ABSOLUTE MAXIMUM RATINGS
PARAMETER
Differential Input Voltage
Output Short to Ground
Operating Temperature
Storage Temperature Range
VI(DIFF)
VI
TOPR
TSTG
UNIT
+-16 or 32
32
-0.3 ~ +32
V
V
V
Continuous
0 ~ +70
co
Range
VALUE
Vcc
mi
Input Voltage
SYMBOL
Se
Supply Voltage
-65 ~ +150
°C
°C
r
to
uc
nd
www.jsmsemi.com
第2/5页
LM358 (YW)
ELECTRICAL CHARACTERISTICS(Vcc=5.0V,VEE=GND,TA=25°C, unless otherwise specified£
PARAMETER
Input Offset Voltage
SYMBOL
TEST CONDITION
VIO
VCM=0V toVCC-1.5V
MIN
TYP
MAX
UNIT
2.9
7.0
mV
VO(P)=1.4V,RS=0Ω
Input Offset Current
5
50
nA
IBIAS
45
250
nA
Input Common Mode Voltage
VI(R)
VCC=30V
Power Supply Current
ICC
RL=∝,VCC=30V
RL=∝,Full Temperature
JS
IIO
Input Bias Current
VCC-1.5
V
0.8
2.0
mA
0.5
1.2
mA
Range
Large Signal Voltage Gain
GV
VCC=15V,RL>=2KΩ
VO(H)
V/mV
V
VCC=30V,RL=2KΩ
26
27
28
CMRR
65
80
dB
65
100
dB
CR
Power Supply Rejection
100
VCC=30V,RL=10KΩ
VO(L)
Common Mode Rejection
25
VO(P)=1V to 11V
O
MI
Output Voltage Swing
Ratio
VCC=5V,RL>=10KΩ
V
5
PSRR
mV
Ratio
CS
Short Circuit Current to
ISC
Ground
120
VI(+)=1V,VI(-)=0V
dB
60
mA
mA
10
15
mA
co
ISOURCE
40
100
mA
mi
Output Current
f=1KHZ to 20KHZ
Se
Channel Separation
VCC=15V,VO(P)=2V
VI(+)=0V,VI(-)=1V
ISINK
VCC=15V,VO(P)=2V
VI(+)=0V,VI(-)=1V
12
VCC=15V,VO(P)=200mV
VI(DIFF)
r
to
uc
nd
www.jsmsemi.com
VCC
V
第3/5页
LM358 (YW)
TYPICAL PERFORMANCE CHARACTERISTICS
Fig.2 Input Current vs Temperature
Fig.1 Input Voltage Range
100
Input Current (mA)
Negative
Input
10
Positive
Input
JS
Input Voltage
15
80
Vcc=+30V
60
Vcc=+15V
40
5
Vcc=+5V
MI
10
Power Supply Voltage
15
CR
25
50
75
100
Fig. 4 Voltage Gain vs Supply Voltage
160
Vcc
RL=20kΩ
Ic
10
Ta= 0~+85¢XC
Ta= -40¢XC
10
Common Mode Rejection Ratio (dB)
(dB)
Vcc
100M Ω
0.1 µF
Vin
Vcc/2
60
40
Vcc=30V
Vcc=15V
101
2
10
103
104
15
22.5
30
Supply Voltage (V)
Fig. 6 Common Mode Rejection Ratio vs Frequency
120
100
Vcc=+7.5V
Vee=-7.5V
80
60
105
106
10 7
+7.5V
100k Ω
100 Ω
40
100 Ω
Vin
100k Ω
r
to
uc
nd
Voltage Gain
40
co
Fig. 5 Open Loop Gain vs Frequency
120
80
80
40
Supply Voltage (V)
100
RL=2kΩ
mi
Se
Voltage Gain æ
30
(dB)
O
Input Current (mA)
Temperature(¢XC)
Fig.3 Input Current vs Supply Voltage
40
-25
2
10
10 3
Frequency (Hz)
-7.5V
10 4
105
106
Frequency (Hz)
www.jsmsemi.com
第4/5页
LM358 (YW)
Fig. 8 Voltage Follower Response (Small Signal)
Output Voltage¹ (V) Input Voltage (V)
Fig. 7 Voltage Follower Pulse Response
450
3
RL=2kΩ
Vcc=15V
Output Voltage (V)
2
1
400
350
JS
2
1
MI
30
Time (uS)
40
O
+7V
2k
5
6
7
8
9
5
Ta=25¢XC
6
Vcc
Vcc/
2
5
Vo
Io
4
3
mi
Se
10
Output Voltage Vo(V)
7
1k
Vi
4
Timeä (µs)
8
+15V
100k
3
2
Fig. 10 Output Current Sinking vs Output Voltage
CR
Output Voltage Gain (Vp-p)
Fig. 9 Gain vs Large Signal Frequency
15
1
2
10
3
10
4
10
5
10
6
-3
10
Output Current Io (mA)
Output Voltage (V)
40
Vcc=+5V
Vcc=+15V
Vcc
Vcc/
2
Vo
Io
-2
10
-1
10
10
2
r
to
uc
nd
1
10
10
Fig.12 Current Limiting vs Temperature
60
Vcc=+30V
1
co
Fig. 11 Output Sink Current vs Output Voltage
10
-1
-1
10
Output Source Current (mA)
Frequency (Hz)
10
-2
10
1
Output Sink Current (mA)
10
10
2
-50
-25
25
50
TemperatureÈ (¢XC)
www.jsmsemi.com
75
100
第5/5页
很抱歉,暂时无法提供与“LM358”相匹配的价格&库存,您可以联系我们找货
