LM358
Rev.J Oct.-2018
DATA SHEET
Descriptions
SOP-8 塑封封装 双通道放大器。Dual Operational Amplifiers in a SOP-8 Plastic Package.
特征
/ Features
内部单位增益频率补偿,有较大的直流电压增益:100dB,工作电压范围宽(VCC=3V~36V)
,输入共
模电压范围接近地电平,输出电压范围大:从 0~Vcc-1.5V,适用于电池工作时的电力消耗。
Internally frequency compensated for unity gain, Large DC voltage gain : 100dB, Wide operating
supply range (Vcc=3V~36V),Input common mode voltage includes ground, Large output voltage swing:
From 0 to Vcc-1.5V,Power drain suitable for battery operation.
用途
Applications
适用于传感器放大器,直流增益模块和所有传统的运算放大器电路。
Application areas include transducer amplifier, DC gain blocks and all the conventional OP amp
circuits.
内部等效电路 / Equivalent Circuit
引脚排列
/ Pinning
8
7
1
6
5
2
3
4
PIN 见内部等效电路 /PIN See Equivalent Circuit.
印章代码
/ Marking
见印章说明 / See Marking Instructions
http://www.fsbrec.com
1/8
LM358
Rev.J Oct.-2018
极限参数
DATA SHEET
Absolute Maximum Ratings(Ta=25℃)
参数
Parameter
Supply Voltage
符号
Symbol
VCC
数值
Rating
18
单位
Unit
V
Differential input voltage
VI(DIFF)
36
V
Input Voltage
VI
-0.3~36
V
Power Dissipation
Pd
570
mW
Operating Temperature
Topr
0 ~ 70
Storage Temperature
Tstg
-65 ~ 150
电性能参数
/ Electrical Characteristics(Ta=25℃)
参数
Parameter
符号
Symbol
最小值 典型值 最大值 单位
Min
Typ
Max
Unit
2.0
3.0
mV
IIO
2.0
30
nA
Ib
45
100
nA
Input offset voltage
VIO
Input offset current
Input Bias current
Input Commonmode
voltage range
VI(R)
Supply Current
Icc
Large signal Voltage Gain
GV
Output voltage Swing
测试条件
Test Conditions
VCM=0 to Vcc-1.5
Rs=0
Vo(p)=1.4V
V(OH)
V(OL)
Vcc=30V
RL=∞
Vcc=30V
Vcc=5V
RL>2kΩ
Vcc=15V
Vo(p)=1V to 11V
25
Vcc=30V
RL=2kΩ
26
Vcc=30V
RL=10kΩ
27
Vcc=5V
RL=10kΩ
V
VCC-1.5
0.8
2.0
mA
0.5
1.2
mA
100
V/mV
V
28
5
V
mV
Commonmode
rejection Ratio
CMRR
65
75
dB
Power supply rejection Ratio
PSRR
65
100
dB
Chanel Sepparation
CS
Short circuit to GND
Isc
Isource
Output current
Isink
VI(diff)
f=1kHz to 20kHz
VI(-)=0
VI(+)=1V
Vo(p)=2V
Vcc=15V
VI(+)=0V
VI(-)=1V
Vo(p)=2V
Vcc=15V
VI(+)=1V
VI(-)=0
Vcc=15V Vo(p)=200mV
5
mV
40
60
mA
mA
10
13
mA
12
45
μA
V
Vcc
2/8
LM358
Rev.J Oct.-2018
原理框图
DATA SHEET
Functional Block Diagram
3/8
LM358
Rev.J Oct.-2018
电参数曲线图
DATA SHEET
/ Electrical Characteristic Curve
4/8
LM358
Rev.J Oct.-2018
电参数曲线图
DATA SHEET
5/8
LM358
Rev.J Oct.-2018
外形尺寸图
DATA SHEET
/ Package Dimensions
6/8
LM358
Rev.J Oct.-2018
印章说明
DATA SHEET
BR
LM358
说明:
BR:
为公司代码
LM358:
为型号代码
为生产批号代码,随生产批号变化
Company Code.
Note:
BR:
LM358:
Product Type.
Lot No. Code, code change with Lot No.
7/8
LM358
Rev.J Oct.-2018
DATA SHEET
回流焊温度曲线图(无铅)
Temperature Profile for IR Reflow Soldering(Pb-Free)
说明:
Note:
1、预热温度 150~180℃,时间 60~90sec;
1.Preheating:150~180℃, Time:60~90sec.
2、峰值温度 245±5℃,时间持续为 5±0.5sec;
2.Peak Temp.:245±5℃, Duration:5±0.5sec.
3、焊接制程冷却速度为 2~10℃/sec.
3. Cooling Speed: 2~10℃/sec.
耐焊接热试验条件
Resistance to Soldering Heat Test Conditions
温度:260±5℃
包装规格
Time:10±1 sec
/ REEL
Package Type
封装形式
使用说明
Temp.:260±5℃
/ Packaging SPEC.
卷盘包装
SOP/ESOP-8
时间:10±1 sec.
Units 包装数量
Dimension
包装尺寸
3
(unit:mm )
Units/Reel
只/卷盘
Reels/Inner Box
卷盘/盒
Units/Inner Box
只/盒
Inner Boxes/Outer Box
盒/箱
Units/Outer Box
只/箱
Reel
Inner Box 盒
Outer Box 箱
4,000
2
8,000
6
48,000
13〞×12
360×360×50
380×335×366
/ Notices
8/8
很抱歉,暂时无法提供与“LM358”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.30240
- 30+0.29160
- 100+0.28080
- 500+0.25920
- 1000+0.24840
- 2000+0.24192
