NSIP1042-DSWTR
NSIP1042-DSWTR
    NOVOSENSE(纳芯微)
    SOW20_300MIL
    CAN收发器 4.5V~5.5V 5Mbps SOW20_300MIL
NSIP1042-DSWTR 数据手册
NSiP1042 Signal Isolated CAN Transceiver With Integrated DC to DC Converter Datasheet (EN) 1.0 Product Overview NSiP1042 is a high reliability isolated controller area network(CAN) physical layer transceiver with integrated DC to DC converter. The isolated DC-DC converter provides output power using on-chip transformer. The feedback PWM signal is sent to primary side by a digital isolator based on Novosense capacitive isolation technology. Both devices are safety certified by UL1577, supporting 5kVrms insulation withstand voltage, while the high integrated solution can help to simplify system design and improve reliability. The Bus pins of NSiP1042 are protected from ±5kV system level ESD to GND2 on Bus side. The data rate of the NSiP1042 is up to 5Mbps. The NSiP1042 provides thermal protection and transmit data dominant time out function. Key Features Safety Regulatory Approvals  UL recognition: up to 5000Vrms for 1 minute per UL1577  CQC certification per GB4943.1-2022  CSA component notice 5A  DIN VDE V 0884-11:2017-01 Applications  Industrial automation system  Smart electric meter and water meter  Security and protection monitoring  Up to 5000Vrms Insulation voltage  Isopower integrated isolated DC-DC converter  Power supply voltage: VDD1:4.5V to 5.5V VDDL:1.8V to 5.5V  Over current and over temperature protection  High CMTI: ±150kV/us  Data rate: 5Mbps  Operation temperature: -40℃~105℃  RoHS-compliant packages: SOW20 Device Information Part Number NSiP1042-DSWTR Package SOW20 Body Size 12.80mm × 7.50mm Functional Block Diagrams Figure 1. NSiP1042 Block Diagrams Copyright © 2023, NOVOSENSE Page 1 NSiP1042 Datasheet (EN) 1.0 INDEX 1. PIN CONFIGURATION AND FUNCTIONS.................................................................................................................................... 3 2. ABSOLUTE MAXIMUM RATINGS................................................................................................................................................. 4 3. RECOMMENDED OPERATING CONDITIONS.............................................................................................................................. 4 4. THERMAL INFORMATION............................................................................................................................................................5 5. SPECIFICATIONS......................................................................................................................................................................... 5 5.1. 5.2. 5.3. DC ELECTRICAL CHARACTERISTICS............................................................................................................................... 5 SWITCHING ELECTRICAL CHARACTERISTICS................................................................................................................7 PARAMETER MEASUREMENT INFORMATION..................................................................................................................8 6. HIGH VOLTAGE FEATURE DESCRIPTION..................................................................................................................................11 6.1. INSULATION AND SAFETY RELATED SPECIFICATIONS................................................................................................11 6.2. 6.3. DIN VDE V 0884-11(VDE V 0884-11):2017-01 INSULATION CHARATERISTICS.....................................................11 REGULATORY INFORMATION........................................................................................................................................ 13 7. FUNCTION DESCRIPTION......................................................................................................................................................... 13 7.1. 7.2. 7.3. 7.4. DEVICE FUNCTIONAL MODES....................................................................................................................................... 13 TXD DOMINANT TIME-OUT FUNCTION........................................................................................................................ 14 CURRENT PROTECTION.................................................................................................................................................14 OVER TEMPERATURE PROTECTION............................................................................................................................. 14 8. APPLICATION NOTE.................................................................................................................................................................. 15 8.1. 8.2. LAYOUT CONSIDERATIONS........................................................................................................................................... 15 TYPICAL APPLICATION...................................................................................................................................................15 9. PACKAGE INFORMATION.......................................................................................................................................................... 16 10. ORDER INFORMATION............................................................................................................................................................ 16 11. DOCUMENTATION SUPPORT..................................................................................................................................................16 12. TAPE AND REEL INFORMATION..............................................................................................................................................17 13. REVISION HISTORY................................................................................................................................................................. 17 Copyright © 2023, NOVOSENSE Page 2 NSiP1042 Datasheet (EN) 1.0 1. Pin Configuration and Functions Figure 1.1 NSiP1042 Package Table1.1 NSiP1042 Pin Configuration and Description NSiP1042 PIN NO. SYMBOL FUNCTION 1 GND1 Ground 1, the ground reference for Isolator Side 1 2 VDD1 Power Supply for Isolator Side 1 3 GND1 Ground 1, the ground reference for Isolator Side 1 4 RXD Receiver output 5 TXD Driver transmit data input 6 VDDL I/O Power Supply input. Side1 I/O logic level. 7 GND1 Ground 1, the ground reference for Isolator Side 1 8 NC Not connected 9 GND1 Ground 1, the ground reference for Isolator Side 1 10 GND1 Ground 1, the ground reference for Isolator Side 1 11 GND2 Ground 2, the ground reference for Isolator Side 2 12 VISOIN Isolated power supply input. This pin must be connected externally to VISOOUT. It is recommended this pin have a 0.1 μF capacitor to GND2 (Pin11). Connect this pin through a ferrite bead and short trace length to VISOOUT for operation. 13 GND2 Ground 2, the ground reference for Isolator Side 2 14 NC Not connected 15 CANL Low-level CAN bus line, when VDD is powered down, Pin CANL is put into a high impedance state to avoid overloading the bus 16 GND2 Ground 2, the ground reference for Isolator Side 2 17 CANH High-level CAN bus line, when VDD is powered down, Pin CANH is put into a high impedance Copyright © 2023, NOVOSENSE Page 3 NSiP1042 Datasheet (EN) 1.0 state to avoid overloading the bus 18 NC Not connected 19 VISOOUT Isolated Power Supply Output. This pin must be connected externally to VISOIN. It is recommended this pin have a 0.1 μF and 10uF capacitor to GND2 (Pin20). Connect this pin through a ferrite bead and short trace length to VISOIN for operation. 20 GND2 Ground 2, the ground reference for Isolator Side 2 2. Absolute Maximum Ratings Parameters Symbol Min Power Supply Voltage VDD1 -0.5 6 V Maximum Input Voltage TXD -0.4 VDDL+0.4 V CANH, CANL -70 70 V RXD Output current IO -15 15 mA Ambient Temperature Ta -40 105 ℃ Storage Temperature Tstg -40 150 ℃ HBM ±8000 V CDM ±2000 V Driver Output/Receiver Input Voltage Electrostatic discharge Typ Max Unit Comments 3. Recommended Operating Conditions Parameters Symbol Min VDD 4.5 5.5 V VDDL 1.8 5.5 V Operating Temperature Topr -40 105 ℃ High Level Input Voltage VIH 0.7*VDDL Low Level Input Voltage VIL 0.3*VDDL Data rate DR 5 Power Supply Voltage Copyright © 2023, NOVOSENSE Typ Max Unit V V Mbps Page 4 NSiP1042 Datasheet (EN) 1.0 4. Thermal Information Parameters Symbol Value Unit IC Junction-to-Air Thermal Resistance θJA 68.5 °C/W Junction-to-top characterization parameter ψJT 17.1 °C/W Junction-to-board characterization parameter ψJB 50.9 °C/W 5. Specifications 5.1. DC Electrical Characteristics (VDD=4.5V~5.5V, VDDL=1.8~5.5V,Ta=-40℃ to 105℃. Unless otherwise noted, Typical values are at VDD=VDDL = 5V, Ta = 25℃) Parameters Power supply voltage Symbol Min VDD 4.5 5.5 V VDDL 1.8 5.5 V 100 180 mA VDD=5V, TXD=0,Rload=60Ω 12.9 25 mA VDD=5V, TXD=VDD 153 1000 uA VDD=VDDL=5V, RL=60Ω TXD=0 57 500 uA VDD=VDDL=5V, RL=60Ω TXD=VDD IDD Supply current IDDL IDDL Thermal-Shutdown Threshold Typ Max Unit TTS 165 ℃ Isolated supply voltage VISOOUT 5 V Common Mode Transient Immunity CMTI ±100 High level input voltage VIH 0.7*VDDL Low level input voltage VIL High level input current IIH -1 Low level input current IIL Output Voltage High VOH Output Voltage Low VOL Input Capacitance CIN Comments kV/us See Fig 5.3.10 V TXD pin 0.3*VDDL V TXD pin 1 uA TXD pin -15 uA TXD pin VDDL-0.4 V IOH = -4mA, RXD pin V IOL = 4mA, RXD pin pF TXD pin ±150 Logic Side 0.4 2 Driver CANH output voltage (Dominant) VOH(D) 2.8 3.44 4 V VI=0V, RLoad =60Ω,see Figure 5.3.1 and Figure 5.3.2 CANL output voltage VOL(D) 0.8 1.33 2 V VI=0V, RLoad =60Ω,see Figure Copyright © 2023, NOVOSENSE Page 5 NSiP1042 Datasheet (EN) 1.0 (Dominant) 5.3.1 and Figure 5.3.2 CAN bus output voltage (Recessive) VO(R) 2 Differential output voltage (Dominant) VOD(D) Differential output voltage (Recessive) Common-mode output voltage Peak-to-peak Common-mode output voltage VOD(R) VOC 3 V TXD=VDD1, RLoad =60Ω,see Figure 5.3.1 and Figure 5.3.2 1.5 3 V TXD=0, RLoad =60Ω, see Figure 5.3.1 and Figure 5.3.2 1 3 V TXD=0, RLoad =45Ω, -0.12 0.12 V TXD=VDD1, RLoad =60Ω -0.5 0.5 V TXD=VDD1, NO Load 3 V 2 VOC(PP) -105 Short- circuit output current IOS 2.5 2.5 250 mV See Fig 5.3.6 -44.1 mA CANH=-30V, CANL open, see Figure 5.3.9 0 10 mA CANH=30V, CANL open, see Figure 5.3.9 -5 0 mA CANL=-30V, CANH open, see Figure 5.3.9 42.5 105 mA CANL=30V, CANH open, see Figure 5.3.9 750 900 mV VIC=0 see Figure 5.3.4 650 mV VIC=0 see Figure 5.3.4 Receiver Positive-going differential bus input threshold voltage VTH+ Negative-going differential bus input threshold voltage VTH- Bus Differential input threshold Hysteresis VHYS 100 mV Input capacitance to ground CI 13 pF Differential input capacitance CID 6.5 pF Differential input resistance RID 30 Input resistance RIN 15 RImatch VIC Input resistance matching Common-mode voltage range Copyright © 2023, NOVOSENSE 500 80 kΩ 40 kΩ -3 +3 % -30 +30 V 30 CANH or CANL CANH=CANL Page 6 NSiP1042 Datasheet (EN) 1.0 5.2. Switching Electrical Characteristics (VDD=4.5V~5.5V, VDDL=1.8~5.5V,Ta=-40℃ to 105℃. Unless otherwise noted, Typical values are at VDD=VDDL = 5V, Ta = 25℃) Parameters Symbol Min Typ Max Unit Comments Loop delay1 TLoop1 104 180 ns Driver input to receiver output, Recessive to Dominant,see Figure 5.3.7 Loop delay2 TLoop2 122 210 ns Driver input to receiver output, Dominant to Recessive,see Figure 5.3.7 Propagation delay time, recessive -to- dominant output tPLHD 77 ns Figure 5.3.3 Propagation delay time, dominant -to- recessive output tPHLD 72 ns Figure 5.3.3 Differential output signal rise time trD 26 ns Figure 5.3.3 Differential output signal fall time tfD 40 ns Figure 5.3.3 Bus dominant time-out time tTXD_DTO us See Figure 5.3.8 Driver 600 2000 4000 Receiver Propagation delay time, low-tohigh-level output tPLHR 50 ns Figure 5.3.5 Propagation delay time, highto-low-level output tPHLR 27 ns Figure 5.3.5 RXD signal rise time trR 3 ns Figure 5.3.5 RXD signal fall time trF 3 ns Figure 5.3.5 Copyright © 2023, NOVOSENSE Page 7 NSiP1042 Datasheet (EN) 1.0 5.3. Parameter Measurement Information IO(CANH) CANH 0 or Vcc1 II VOD TXD V1 GND1 VO(CANL)+VO(CANH) 2 CANL IO(CANL) GND2 VO(CANL) GND1 RL VOC VO(CANH) GND2 Figure 5.3.1. Driver Voltage, Current and Test Definitions Figure 5.3.2. Bus Logic State Voltage Definitions Note:A. The input pulse is supplied by a generator having the following characteristics: Pulse Repeat Rate ≤ 125 kHz, 50% duty cycle tr ≤ 6 ns, tf ≤ 6 ns, ZO = 50 Ω. B. CL includes instrumentation and fixture capacitance within ±20%. Figure 5.3.3. Driver Test Circuit and Voltage Waveform Copyright © 2023, NOVOSENSE Page 8 NSiP1042 Datasheet (EN) 1.0 Figure 5.3.4. Receiver Voltage and Current Definitions CANH IO RXD CANL VI (SEE NOTE A ) VO 1.5 V GND2 CL = 15 pF ±20% (SEE NOTE B ) GND1 Note: A. The input pulse is supplied by a generator having the following characteristics: Pulse Repeat Rate ≤ 125 kHz, 50% duty cycle, tr ≤ 6 ns, tf ≤ 6 ns, ZO = 50 Ω. B. CL includes instrumentation and fixture capacitance within ±20%. Figure 5.3.5. Receiver Test Circuit and Voltage Waveform CANH 27Ω±1% TXD CANL VI GND1 27Ω±1% VO(CANH)+ VO(CANL) 47nF V = ±20% OC 2 GND2 Figure 5.3.6. Peak-to-Peak Output Voltage Test Circuit and Waveform Copyright © 2023, NOVOSENSE Page 9 NSiP1042 Datasheet (EN) 1.0 Figure 5.3.7. tLOOP Test Circuit and Voltage Waveform A. The input pulse is supplied by a generator having the following characteristics: PRR ≤ 125 kHz, 50% duty cycle, tr ≤ 6 ns, tf ≤ 6 ns, ZO = 50 Ω. B. CL includes instrumentation and fixture capacitance within ±20%. Figure 5.3.8. Dominant Time-out Test Circuit and Voltage Waveform Figure 5.3.9. Driver Short-Circuit Current Test Circuit and Waveform Figure5.3.10 Common-Mode Transient Immunity Test Circuit Copyright © 2023, NOVOSENSE Page 10 NSiP1042 Datasheet (EN) 1.0 6. High Voltage Feature Description 6.1. Insulation And Safety Related Specifications Parameters Symbol Value Unit Comments Minimum External Air Gap (Clearance) CLR 8.0 mm Shortest terminal-to-terminal distance through air Minimum External Tracking (Creepage) CPG 8.0 mm Shortest terminal-to-terminal distance across the package surface 16 um Minimum internal gap (internal clearance – capacitive signal isolation) 100 um Minimum internal gap (internal clearance – transformer power isolation) >600 V DIN EN 60112 (VDE 0303-11); IEC 60112 Minimum internal gap Tracking Resistance (Comparative Tracking Index) DTI CTI Material Group I 6.2. DIN VDE V 0884-11(VDE V 0884-11):2017-01 INSULATION CHARATERISTICS Description Test Condition Symbol Value Unit Installation Classification per DIN VDE 0110 For Rated Mains Voltage ≤ 150Vrms Ⅰto Ⅳ For Rated Mains Voltage ≤ 600Vrms Ⅰto Ⅲ For Rated Mains Voltage ≤ 300Vrms Ⅰto Ⅳ Climatic Classification 40/105/21 Pollution Degree per DIN VDE 0110, Table 1 Maximum repetitive isolation voltage Maximum working isolation voltage Input to Output Test Voltage, Method B1 2 AC voltage(bipolar) VIORM 1166 Vpeak AC Voltage (TDDB) test VIOWM 824 Vrms DC Voltage VIOWM 1166 VDC Vpd (m) 1749 Vpeak Vpd (m) 1399 Vpeak V IORM × 1.5 = V pd (m) , 100% production test, t ini = t m = 1 sec, partial discharge < 5 pC Input to Output Test Voltage, Method A After Environmental Tests Subgroup 1 Copyright © 2023, NOVOSENSE V IORM × 1.2 = V pd (m) , t ini = 60 sec, t m = 10 sec, partial Page 11 NSiP1042 Datasheet (EN) 1.0 discharge < 5 pC After Input and /or Safety Test Subgroup 2 and Subgroup 3 V IORM × 1.2= V pd (m) , t ini = 60 sec, t m = 10 sec, partial discharge < 5 pC Vpd (m) 1399 Vpeak Maximum transient isolation voltage VTEST = VIOTM; t = 60 s (qualification); VIOTM 7000 Vpeak VIOSM 5384 Vpeak VTEST = 1.2 × VIOTM; t = 1 s (100% production) Maximum Surge Isolation Voltage Test method per IEC60065,1.2/50us waveform, VTEST=1.3×VIOSM Isolation resistance VIO =500V RIO >109 Ω Isolation capacitance f = 1MHz CIO 0.6 pF Ps 1459 mW Is 265 mA Ts 125 ℃ Total Power Dissipation at 25℃ Safety input, output, or supply current Maximum safety temperature θJA = 68.5°C/W, V I = 5.5 V, T J = 125 °C, TA = 25 °C Figure 6.1 NSiP1042 Thermal Derating Curve, Dependence of Safety Limiting Values with Case Temperature per DIN VDE V 0884-11 Copyright © 2023, NOVOSENSE Page 12 NSiP1042 Datasheet (EN) 1.0 6.3. Regulatory Information The NSiP1042 are approved or pending approval by the organizations listed in table. CUL VDE CQC Approved under CSA Component Acceptance Notice 5A DIN VDE V 0884-11(VDE V 0884-11):2017-012 Certified by CQC11471543-2022 Single Protection, 5000VRMS Isolation voltage Single Protection, 5000VRMS Isolation voltage Basic Insulation 1166VPEAK, VIOSM=5384VPEAK Basic insulation File (pending) File (pending) File (pending) File (pending) UL 1577 Component Recognition Program1 GB4943.1-2022 7. Function Description The NSiP1042 is an isolated CAN transceiver which is fully compatible with the ISO11898-2 standard. The NSiP1042 is a high reliability isolated controller area network(CAN) physical layer transceiver with integrated DC to DC converter. The digital isolator is SiO2 isolation based on Novosense capacity isolation technology. The high integrated solution can help to simplify system design and improve reliability. The NSiP1042 device is safety certified by UL1577, supporting 5kVrms insulation withstand voltages. The NSiP1042 provides high electromagnetic immunity and low emission. The data rate of the NSiP1042 is up to 5Mbps. The NSiP1042 provides thermal protection and transmit data dominant time out function. 7.1. Device Functional Modes 1 TXD CANH CANL BUS STATE L H L Dominant H Z Z Recessive Open Z Z Recessive H= high level; L=low level; Z= common mode(recessive) bias to VISOIN/2 Table 7.1. Driver Function Table 1 VID=CANH-CANL RXD BUS STATE VID ≥0.9V L Dominant 0.5< VID
NSIP1042-DSWTR 价格&库存
很抱歉,暂时无法提供与“NSIP1042-DSWTR”相匹配的价格&库存,您可以联系我们找货
