Crystal Unit
YSX211SL
Applications
‧Mobile phone,
Bluetooth, WLAN
ISM band radio.
Small Size
Features
‧Dimensions: 2.05 x 1.65 x 0.50mm.
‧High precision and high frequency stability.
‧Standard Frequency: 16~54MHz
‧Excellent heat resistance and environmental
characteristics.
Specifications(规格参数)
Item
Nominal Frequency Range(额定频率范围)
Vibration Mode(震动模式)
Load Capacitance(负载电容)
Frequency Tolerance(频率偏差) (at 25℃ )
Frequency Versus Temperature Characteristics(频率-温度特性)
Operating Temperature(工作温度)
Storage Temperature(储存温度)
Shunt Capacitance(静态电容)
Level of Drive(激励电平)
Aging (老化)(at 25℃ )
Symbol
Specifications
f_nom
16~54MHz or 96MHZ
AT Fundamental
CL
8pF, 9pF, 12pF, or specify
f_tol
±10ppm, or specify
f_tem
±20ppm, or specify
T_use
-40~+85℃ or specify
T_stg
-55~+125℃
C0
3pF Max.
DL
10~200μW Max.(100μW typical)
f_age
±3ppm/year Max.
Equivalent Series Resistance(等效串联电阻(ESR))
YSX211SL
16 ~ 30MHz
100 Ω Max.
31 ~ 54MHz
80 Ω Max.
Dimensions and Recommended land pattern(外观尺寸及推荐焊盘)
Dimensions (Unit: mm)
Recommended land pattern(Unit: mm)
www.yxc.hk
1
很抱歉,暂时无法提供与“XL7LI-111-16M”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.33000
- 100+0.30800
- 300+0.28600
- 500+0.26400
- 2000+0.25300
- 5000+0.24640
