Crystal Unit
YSX221SL
Small Size
Applications
Features
‧Smart Wearable
IOT Communication
‧Dimensions: 2.55 x 2.05 x 0.55mm.
‧High precision and high frequency stability.
‧Standard Frequency: 12~54MHz
‧Excellent heat resistance and environmental
characteristics.
Specifications(规格参数)
Item
Symbol
Specifications
f_nom
12~54MHz or specify
AT Fundamental
CL
8pF, 10pF, 20pF, or specify
Frequency Tolerance(频率偏差) (at 25℃ )
f_tol
±10ppm, ±20ppm, or specify
Frequency Versus Temperature Characteristics(频率-温度特性)
f_tem
±20ppm, or specify
Operating Temperature(工作温度)
T_use
-40~+85℃, or specify
Storage Temperature(储存温度)
T_stg
-55~125℃
Shunt Capacitance(静态电容)
C0
3pF Max.
Level of Drive(激励电平)
DL
10~200μW Max.(100μW typical)
f_age
±3ppm/year Max.
Nominal Frequency Range(额定频率范围)
Vibration Mode(震动模式)
Load Capacitance(负载电容)
Aging (老化)(at 25℃ )
Equivalent Series Resistance(等效串联电阻(ESR))
YSX221SL
12 ~ 14MHz
150 Ω Max.
14 ~ 30MHz
100 Ω Max.
30 ~ 48MHz
60 Ω Max
48 ~ 54MHz
50 Ω Max
Dimensions and Recommended land pattern(外观尺寸及推荐焊盘)
Dimensions (Unit: mm)
Recommended land pattern(Unit: mm)
www.yxc.hk
1
很抱歉,暂时无法提供与“XL3LI-111-16M”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.42000
- 100+0.39200
- 300+0.36400
- 500+0.33600
- 2000+0.32200
- 5000+0.31360
