SB1045
THRU
SB10100
10.0 AMP SCHOTTKY BARRIER RECTIFIERS
VOLTAGE RANGE
45 -100 Volts
CURRENT
10.0 Ampere
0.264 (6.70)
0.248 (6.30)
• Low forward voltage drop.
• Excellent high temperature stability.
• Fast switching capability.
• Suffix "G" indicates Halogen-free part, ex.CP10S45SG.
• Lead-free parts meet environmental standards of
MIL-STD-19500 /228
1
0.073 (1.85)
0.069 (1.75)
2
3
0.028 (0.71)
0.016 (0.41)
0.216 (5.48)
0.208 (5.28)
■ Mechanical data
• Epoxy : UL94-V0 rated flame retardant.
• Case : Molded plastic, TO-277 .
• Lead : Solder plated, solderable per MIL-STD-750,
Method 2026.
• Polarity: Indicated by cathode band .
• Mounting Position : Any.
• Weight : Approximated 0.093 grams .
PIN 1
PIN 3
PIN 2
0.163 (4.13)
0.151 (3.83)
TO-277
■ Features
0.077 (1.96)
0.069 (1.76)
0.028 (0.71)
0.016 (0.41)
0.037 (0.95)
0.033 (0.85)
0.124 (3.15)
0.112 (2.85)
0.037 (0.95)
0.033 (0.85)
0.145 (3.69)
0.133 (3.39)
0.014 (0.35)
0.010 (0.25)
0.069 (1.74)
0.057 (1.44)
0.049 (1.25)
0.037 (0.95)
Dimensions in inches and (millimeters)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Rating 25 C ambient temperature uniess otherwies specified.
Single phase half wave, 60Hz, resistive or inductive load.
For capacitive load, derate current by 20%.
TYPE NUMBER
Maximum Recurrent Peak Reverse Voltage
Maximum RMS Voltage
Maximum DC Blocking Voltage
Maximum Average Forward Rectified Current
SB 104 5
SB 1060
45
32
45
60
42
60
See Fig. 1
Peak Forward Surge Current, 8.3 ms single half sine-wave
superimposed on rated load (JEDEC method)
Maximum Instantaneous Forward Voltage at 10.0A
Maximum DC Reverse Current
Ta=25 C
at Rated DC Blocking Voltage
Ta=125 C
Typical Junction Capacitance (Note1)
Typical Thermal Resistance R JA (Note 2)
Operating Temperature Range TJ
Storage Temperature Range TSTG
SB 10100
100
70
100
150
0. 7
150
0.70
0.85
50
0.85
50
0.70
0.85
250
60
to10+150
-55
-55 to +150
V
V
V
A
10.0
0.55
UNITS
A
V
A
mA
pF
C/W
C
C
Note : 1.FR-4 PCB, 2oz.Copper.
2.Polymide PCB, 2oz.Copper.Cathode pad dimensions 18.8mm x 14.4mm.Anode pad dimensions 5.6mm x 14.4mm.
REV 1.0 2017 JAN
PAGE:1/2
RATING AND VHARACTERISTIC CURVES(SB1045 THRU SB10100)
FIG.1-TYPICAL FORWARD CURRENT DERATING CURVE
FIG.2-TYPICAL FORWARD
50
6
4
2
60
80
100
120
140
160
180
200
CASE TEMPERATURE,( C)
FIG.3-MAXIMUM NON-REPETITIVE FORWARD
SURGE CURRENT
10
5.0
SB
106
SB
101
00
8
SB
10
45
10
INSTANTANEOUS FORWARD CURRENT,(A)
AVERAGE FORWARD CURRENT,(A)
CHARACTERISTICS
12
1.0
Tj=25 C
Pulse Width 300us
1% Duty Cycle
0.1
PEAK FORWARD SURGE CURRENT,(A)
250
.01
200
.1
.3
.5
.7
.9
1.1
1.3
1.5
FORWARD VOLTAGE,(V)
150
8.3ms Single Half
Tj=25 C
Sine Wave
100
JEDEC method
50
FIG.5 - TYPICAL REVERSE
CHARACTERISTICS
5
50
10
100
100
NUMBER OF CYCLES AT 60Hz
REVERSE LEAKAGE CURRENT, (mA)
FIG.4-TYPICAL JUNCTION CAPACITANCE
JUNCTION CAPACITANCE,(pF)
1400
1200
1000
800
600
400
10
Tj=100 C
1.0
Tj=75 C
.1
Tj=25 C
200
.05
.1
.5
1
REVERSE VOLTAGE,(V)
5
10
50
100
.01
60
80
100 120 140
PERCENT OF RATED PEAK REVERSE VOLTAGE,(%)
REV 1.0 2017 JAN
PAGE:2/2
很抱歉,暂时无法提供与“SB10100”相匹配的价格&库存,您可以联系我们找货
