HSS4P06
P-Ch 60V Fast Switching MOSFETs
Description
Product Summary
The HSS4P06 is the high cell density trenched Pch MOSFETs, which provides excellent RDSON
and efficiency for most of the small power switching
and load switch applications.
The HSS4P06 meet the RoHS and Green Product
requirement with full function reliability approved.
100% EAS Guaranteed
Green Device Available
Super Low Gate Charge
Excellent CdV/dt effect decline
Advanced high cell density Trench
technology
VDS
-60
V
RDS(ON),TYP
75
mΩ
ID
-4
A
SOT23 Pin Configuration
Absolute Maximum Ratings
Symbol
Parameter
Rating
Units
VDS
Drain-Source Voltage
-60
V
VGS
Gate-Source Voltage
ID@TC=25℃
ID@TC=70℃
IDM
PD@TC=25℃
±20
V
Continuous Drain Current, VGS @
-10V1
-4
A
-10V1
-3.5
A
Current2
-16
A
Dissipation3
1.4
W
Pulsed Drain
Total Power
TSTG
Storage Temperature Range
-55 to 150
TJ
Operating Junction Temperature Range
-55 to 150
Thermal Data
Symbol
Parameter
RθJA
Thermal Resistance Junction-Ambient
RθJC
Junction-Case1
www.hs-semi.cn
Thermal Resistance
Ver 2.0
1
Typ.
Max.
Unit
100
℃/W
62
℃/W
1
HSS4P06
Electrical Characteristics (TJ=25 ℃, unless otherwise noted)
Symbol
Parameter
BVDSS
Drain-Source Breakdown Voltage
RDS(ON)
Static Drain-Source On-Resistance2
VGS(th)
IDSS
Gate Threshold Voltage
Drain-Source Leakage Current
Conditions
Min.
Typ.
Max.
Unit
VGS=0V , ID=-250uA
-60
V
VGS=-10V , ID=-4A
75
90
VGS=-4.5V , ID=-3A
90
110
VGS=VDS , ID =-250uA
-1.0
-1.5
-2.5
VDS=-60V , VGS=0V , TJ=25℃
-1
VDS=-60V , VGS=0V , TJ=55℃
5
m
V
uA
IGSS
Gate-Source Leakage Current
VGS=±20V , VDS=0V
±100
nA
gfs
Forward Transconductance
VDS=-30V , ID=-4A
11
S
Qg
Total Gate Charge
Qgs
Gate-Source Charge
3.4
Qgd
Gate-Drain Charge
3.62
Td(on)
Turn-On Delay Time
VDS=-30V , VGS=-10V , ID=-4A
nC
7.4
Rise Time
VDS=-30V , VGS=-10V , RG=1,
5.4
Turn-Off Delay Time
ID=-3A
37.2
Fall Time
16
Ciss
Input Capacitance
831
Coss
Output Capacitance
89
Crss
Reverse Transfer Capacitance
63
Min.
Typ.
Max.
Unit
-4
A
-16
A
-1.2
V
Tr
Td(off)
Tf
VDS=-30V , VGS=0V , f=1MHz
ns
pF
Diode Characteristics
Symbol
IS
ISM
VSD
Parameter
Continuous Source Current1,4
Pulsed Source
Current2,4
Diode Forward
Voltage2
Conditions
VG=VD=0V , Force Current
VGS=0V , IS=-1A , TJ=25℃
Note :
1.The data tested by surface mounted on a 1 inch2 FR-4 board with 2OZ copper.
2.The data tested by pulsed , pulse width ≦ 300us , duty cycle ≦ 2%
3.The power dissipation is limited by 150℃ junction temperature
4.The data is theoretically the same as ID and IDM , in real applications , should be limited by total power dissipation.
www.hs-semi.cn
Ver 2.0
2
HSS4P06
Typical Characteristics
www.hs-semi.cn
Ver 2.0
3
HSS4P06
www.hs-semi.cn
Ver 2.0
4
HSS4P06
Ordering Information
Part Number
HSS4P06
Package code
SOT-23L
Packaging
3000/Tape&Reel
c
www.hs-semi.cn
Ver 2.0
5
很抱歉,暂时无法提供与“HSS4P06”相匹配的价格&库存,您可以联系我们找货
