HSS06P03
P-Ch 30V Fast Switching MOSFETs
Description
Product Summary
The HSS06P03 is the high cell density trenched Pch MOSFETs, which provides excellent RDSON
and efficiency for most of the small power switching
and load switch applications.
The HSS06P03 meet the RoHS and Green Product
requirement, with full function reliability approved.
VDS
-30
V
RDS(ON),max
28
mΩ
ID
-6
A
SOT23 Pin Configuration
Green Device Available
Super Low Gate Charge
Excellent CdV/dt effect decline
Advanced high cell density Trench
technology
Absolute Maximum Ratings
Symbol
Parameter
Rating
Units
VDS
Drain-Source Voltage
-30
V
VGS
Gate-Source Voltage
±20
V
ID@TA=25℃
IDM
PD@TA=25℃
Continuous Drain Current, VGS @
-6
A
Current2
-24
A
Dissipation3
1.25
W
Pulsed Drain
Total Power
-10V1
TSTG
Storage Temperature Range
-55 to 150
TJ
Operating Junction Temperature Range
-55 to 150
Thermal Data
Symbol
Parameter
RθJA
Thermal Resistance Junction-Ambient
RθJC
Thermal Resistance Junction-Case1
www.hs-semi.cn
Ver 2.0
1
Typ.
Max.
Unit
100
℃/W
80
℃/W
1
HSS06P03
Electrical Characteristics (TJ=25 ℃, unless otherwise noted)
Symbol
Parameter
BVDSS
Drain-Source Breakdown Voltage
RDS(ON)
Static Drain-Source On-Resistance2
VGS(th)
Gate Threshold Voltage
△VGS(th)
VGS(th) Temperature Coefficient
IDSS
Drain-Source Leakage Current
IGSS
Gate-Source Leakage Current
Qg
Total Gate Charge
Qgs
Gate-Source Charge
Qgd
Gate-Drain Charge
Td(on)
Turn-On Delay Time
Conditions
Min.
Typ.
Max.
Unit
VGS=0V , ID=-250uA
-30
V
VGS=-10V , ID=-4.2A
23
28
VGS=-4.5V , ID=-4A
30
36
VGS=-2.5V , ID=-1A
38
48
-1
-1.5
-2
V
4
mV/℃
VDS=-24V , VGS=0V , TJ=25℃
-1
VDS=-24V , VGS=0V , TJ=55℃
-5
VGS=±20V , VDS=0V
±100
24.1
3.8
4.2
VGS=VDS , ID =-250uA
VDS=-15V , VGS=-10V , ID=-1A
m
uA
nA
nC
48
Rise Time
VDD=-15V , VGS=-4.5V , RG=10,
3.2
Turn-Off Delay Time
RL=15, ID=-1A
18
Fall Time
9
Ciss
Input Capacitance
1181
Coss
Output Capacitance
143
Crss
Reverse Transfer Capacitance
102
Min.
Typ.
Max.
Unit
VG=VD=0V , Force Current
-6
A
VGS=0V , IS=-1A , TJ=25℃
-1
V
Tr
Td(off)
Tf
VDS=-15V , VGS=0V , f=1MHz
ns
pF
Diode Characteristics
Symbol
IS
VSD
Parameter
Continuous Source
Diode Forward
Current1,4
Voltage2
Conditions
Note :
1.The data tested by surface mounted on a 1 inch2 FR-4 board with 2OZ copper.
2.The data tested by pulsed , pulse width ≦ 300us , duty cycle ≦ 2%
3.The power dissipation is limited by 150℃ junction temperature
4.The data is theoretically the same as ID and IDM , in real applications , should be limited by total power dissipation.
www.hs-semi.cn
Ver 2.0
2
HSS06P03
Typical Characteristics
www.hs-semi.cn
Ver 2.0
3
HSS06P03
www.hs-semi.cn
Ver 2.0
4
HSS06P03
Ordering Information
Part Number
HSS06P03
www.hs-semi.cn
Package code
SOT-23L
Ver 2.0
Packaging
3000/Tape&Reel
5
很抱歉,暂时无法提供与“HSS06P03”相匹配的价格&库存,您可以联系我们找货
