RS3007-5.0YE3
RS3007-5.0YE3
    RUNIC(润石)
    SOT89-3
    线性稳压器/LDO Vo=5V 72dB~60dB ±2% SOT89-3L
RS3007-5.0YE3 数据手册
RS3007 300mA, Low Power Consumption, High Voltage CMOS LDO Regulator 1 FEATURES 3 DESCRIPTIONS • Low Quiescent Current IQ: 3uA (TYP) • 300mA Nominal Output Current • Low Dropout Voltage • Low Temperature Coefficient • High Input Voltage (up to 45V) • Output Voltage Accuracy: ±1%/±2% • Fixed Output Voltage: 1.8V, 2.5V, 3.0V, 3.3V and 5.0V • Current Limit Protection • Over Temperature Protection • SOT23-3, SOT23-5, SOT89-3L and SOT223 and SOP8 Packages 2 APPLICATIONS • Smart Power Network Equipment • Portable Power Tools • BMS systems • Motor control system/Industrial control system • Power Meter/Instrument • White Goods • Vehicle-mounted system • Battery-Powered Equipment • Automotive Head Unit • Security Equipment • Communication Equipment The RS3007 series is a set of Low power high voltage regulators implemented in CMOS technology. Which can provide 300mA output current. The device allows input voltage as high as 45V.It is very suitable for multicell battery systems, bus voltage power supply systems and other high DC voltage systems. Wide input voltage can make it well withstand the impact of surge voltage and ensure the stability of output voltage. The RS3007 series only consume 3uA (typical), Which is particularly important in battery power system, can reduce the standby power consumption of the whole system. The RS3007 is available in Green SOT23-3, SOT23-5, SOT89-3L and SOT223 and SOP8 packages, for the different application’s requirements. Device Information (1) PART NUMBER RS3007 (1) PACKAGE BODY SIZE (NOM) SOT23-3(3) 1.60mm×2.92mm SOT23-5(5) 1.60mm×2.92mm SOT89-3L(3) 2.45mm×4.50mm SOT223(3) 3.50mm×7.00mm SOP8(8) 4.90mm×3.90mm For all available packages, see the orderable addendum at the next page of the data sheet. 4 Typical Application Schematic VIN VIN CIN 1uF VOUT VOUT RS3007 COUT 1uF GND REV A.4 1 / 20 www.run-ic.com RS3007 Table of Contents 1 FEATURES .......................................................................................................................................................1 2 APPLICATIONS ................................................................................................................................................1 3 DESCRIPTIONS ................................................................................................................................................1 4 Typical Application Schematic.......................................................................................................................1 5 Revision History ..............................................................................................................................................3 6 PACKAGE/ORDERING INFORMATION (1) ......................................................................................................4 7 Pin Configuration and Functions (Top View) ...............................................................................................6 8 Specifications ..................................................................................................................................................8 8.1 Absolute Maximum Ratings ........................................................................................................................8 8.2 ESD Ratings................................................................................................................................................8 8.3 Recommended Operating Conditions .........................................................................................................8 8.4 Thermal Information ....................................................................................................................................9 8.5 ELECTRICAL CHARACTERISTICS ........................................................................................................ 10 8.6 TYPICAL CHARACTERISTICS ............................................................................................................... 11 9 DETAILED DESCRIPTION ............................................................................................................................ 13 9.1 Overview .................................................................................................................................................. 13 9.2 Functional Block Diagram ........................................................................................................................ 13 9.3 Thermal Considerations ........................................................................................................................... 13 9.4 Applications Note: .................................................................................................................................... 13 10 PACKAGE OUTLINE DIMENSIONS ........................................................................................................... 14 11 TAPE AND REEL INFORMATION .............................................................................................................. 19 2 / 20 www.run-ic.com RS3007 5 Revision History Note: Page numbers for previous revisions may different from page numbers in the current version. VERSION Change Date A.1 2020/03/16 A.2 2020/06/03 A.3 2020/09/11 A.4 2023/05/29 Change Item Initial version completed 1) Added part-number to ordering information table 2) Added SOT223(L Type) package 1) Added part-number to ordering information table 2) Added SOT223 and SOP8 package 3) Added 3.0 and 5.0 VOUT Accuracy of 1% 1) Change SOT23-5, SOT23-3 and SOT89-3L (L-Type) Thermal Information on Page 6 @A.3 Version. 2) Added the TAPE AND REEL INFORMATION 3) Update RS3007-2.5YE3 PACKAGE OPTION on Page 5 @A.3 Version. 4) Delete RS3007-3.3AYD3 ORDERING NUMBER on Page 5 @A.3 Version. 3 / 20 www.run-ic.com RS3007 6 PACKAGE/ORDERING INFORMATION (1) PRODUCT ORDERING NUMBER VOUT(V) VOUT Accuracy PACKAGE LEAD PACKAGE MARKING(2) RS3007-1.8YF3 1.8 ±2% SOT23-3 SE18 Tape and Reel,3000 RS3007-1.8SYF5 1.8 ±2% SOT23-5 SE18 Tape and Reel,3000 SE18L Tape and Reel,1000 RS3007-1.8 PACKAGE OPTION RS3007-1.8YE3L 1.8 ±2% SOT89-3L L-Type RS3007-1.8YE3 1.8 ±2% SOT89-3L SE18 Tape and Reel,1000 RS3007-2.5YF3 2.5 ±2% SOT23-3 SE25 Tape and Reel,3000 RS3007-2.5SYF5 2.5 ±2% SOT23-5 SE25 Tape and Reel,3000 RS3007-2.5YE3L 2.5 ±2% SOT89-3L L-Type SE25L Tape and Reel,1000 RS3007-2.5YE3 2.5 ±2% SOT89-3L SE25 Tape and Reel,1000 RS3007-3.0YF3 3.0 ±2% SOT23-3 SE30 Tape and Reel,3000 RS3007-3.0SYF5 3.0 ±2% SOT23-5 SE30 Tape and Reel,3000 RS3007-3.0YE3L 3.0 ±2% SOT89-3L L-Type SE30L Tape and Reel,1000 RS3007-3.0YE3 3.0 ±2% SOT89-3L SE30 Tape and Reel,1000 RS3007-3.0YD3 3.0 ±2% SOT223 SE30 Tape and Reel,2500 RS3007-3.0YD3L 3.0 ±2% SOT223 L-Type SE30L Tape and Reel,2500 RS3007-3.3YF3 3.3 ±2% SOT23-3 SE33 Tape and Reel,3000 RS3007-3.3SYF5 3.3 ±2% SOT23-5 SE33 Tape and Reel,3000 RS3007-3.3YE3L 3.3 ±2% SOT89-3L L-Type SE33L Tape and Reel,1000 RS3007-3.3YE3 3.3 ±2% SOT89-3L SE33 Tape and Reel,1000 RS3007-3.3YD3 3.3 ±2% SOT223 SE33 Tape and Reel,2500 RS3007-3.3YD3L 3.3 ±2% SOT223 L-Type SE33L Tape and Reel,2500 RS3007-5.0YF3 5.0 ±2% SOT23-3 SE50 Tape and Reel,3000 RS3007-5.0SYF5 5.0 ±2% SOT23-5 SE50 Tape and Reel,3000 RS3007-5.0YE3L 5.0 ±2% SOT89-3L L-Type SE50L Tape and Reel,1000 RS3007-5.0YE3 5.0 ±2% SOT89-3L SE50 Tape and Reel,1000 RS3007-5.0YD3 5.0 ±2% SOT223 SE50 Tape and Reel,2500 ±2% SOT223 L-Type SE50L Tape and Reel,2500 RS3007-2.5 RS3007-3.0 RS3007-3.3 RS3007-5.0 RS3007-5.0YD3L 5.0 4 / 20 www.run-ic.com RS3007 PRODUCT RS3007-3.0 RS3007-3.3 RS3007-5.0 ORDERING NUMBER VOUT(V) VOUT Accuracy PACKAGE LEAD PACKAGE MARKING(2) PACKAGE OPTION RS3007-3.0AYF3 3.0 ±1% SOT23-3 SE30 Tape and Reel,3000 RS3007-3.0ASYF5 3.0 ±1% SOT23-5 SE30 Tape and Reel,3000 RS3007-3.0AYK 3.0 ±1% SOP-8 SE30 Tape and Reel,4000 RS3007-3.3AYF3 3.3 ±1% SOT23-3 SE33 Tape and Reel,3000 RS3007-3.3ASYF5 3.3 ±1% SOT23-5 SE33 Tape and Reel,3000 RS3007-3.3AYK 3.3 ±1% SOP-8 SE33 Tape and Reel,4000 RS3007-5.0AYF3 5.0 ±1% SOT23-3 SE50 Tape and Reel,3000 RS3007-5.0ASYF5 5.0 ±1% SOT23-5 SE50 Tape and Reel,3000 RS3007-5.0AYK 5.0 ±1% SOP-8 SE50 Tape and Reel,4000 NOTE: (1) This information is the most current data available for the designated devices. This data is subject to change without notice and revision of this document. For browser-based versions of this data sheet, refer to the right-hand navigation. (2) There may be additional marking, which relates to the lot trace code information (data code and vendor code), the logo or the environmental category on the device. 5 / 20 www.run-ic.com RS3007 7 Pin Configuration and Functions (Top View) VIN VOUT NC 3 5 4 SEXX SEXX 1 GND 2 1 2 VOUT VIN GND SOT23-3 SOT23-5 VIN GND SEXXL SEXX 3 1 EN VIN 3 GND VOUT SOT223 SEXXL 1 2 3 1 2 3 GND VIN VOUT VOUT GND VIN SOT89-3L(L-Type) 2 SOT89-3L 1 2 3 GND VOUT VIN SOT223(L-Type) NOTE: XX indicate Output Voltage, xx indicate Date Code For example: SE33(VOUT=3.3V) PIN DESCRIPTION PIN NAME SOT23-3 SOT23-5 GND 1 2 SOT89-3L (L-Type) 1 VOUT 2 5 VIN 3 EN NC FUNCTION 2 SOT223 (L-Type) 1 3 1 2 3 1 2 3 3 1 / 3 / / / / / 4 / / / / SOT89-3L 6 / 20 SOT223 2 Ground Regulator Output. Recommended output capacitor range: 1μF to 10μF. Regulator Input. Up to 45V input voltage. At least 1μF supply bypass capacitor is recommended. Enable pin. Drive this pin high to enable the device, Low to put the device into low current shutdown. No internal connection www.run-ic.com RS3007 Pin Configuration and Functions (Top View) EN 1 8 GND VIN 2 7 GND VOUT 3 6 GND NC 4 5 GND SOIC-8(SOP8) PIN DESCRIPTION PIN NAME FUNCTION SOIC-8(SOP8) EN 1 VIN 2 VOUT 3 Enable pin. Drive this pin high to enable the device, Low to put the device into low current shutdown. Regulator Input. Up to 45V input voltage. At least 1μF supply bypass capacitor is recommended. Regulator Output. Recommended output capacitor range: 1μF to 10μF. NC 4 No internal connection GND 5, 6, 7, 8 Ground 7 / 20 www.run-ic.com RS3007 8 Specifications 8.1 Absolute Maximum Ratings over operating free-air temperature range (unless otherwise noted) (1) (2) MIN MAX UNIT V VIN Input voltage -0.3 55 VEN VEN voltage range -0.3 VIN V TJ PN Junction temperature (3) 175 °C PD Continuous power dissipation (4) Tstg Storage temperature range (1) (2) (3) (4) -40 W Internally limited -65 °C 150 Stresses beyond those listed under Absolute Maximum Ratings may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated under Recommended Operating Conditions is not implied. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability. All voltages are with respect to the GND pin. The maximum power dissipation is a function of TJ(MAX), RθJA, and TA. The maximum allowable power dissipation at any ambient temperature is PD = (T J(MAX) - TA) / RθJA. All numbers apply for packages soldered directly onto a PCB. Internal thermal shutdown circuitry protects the device from permanent damage. The actual chip output current is subject to the inputoutput voltage difference, ambient temperature and PCB heat dissipation design. 8.2 ESD Ratings The following ESD information is provided for handling of ESD-sensitive devices in an ESD protected area only. V(ESD) Electrostatic discharge VALUE UNIT Human-body model (HBM) ±4000 V Charge device model (CDM) ±1500 V ESD SENSITIVITY CAUTION ESD damage can range from subtle performance degradation to complete device failure. Precision integrated circuits may be more susceptible to damage because very small parametric changes could cause the device not to meet its published specifications. 8.3 Recommended Operating Conditions over operating free-air temperature range (unless otherwise noted) (1) MIN MAX UNIT VIN Input supply voltage 2.5 45 V IOUT Output current 0 300 mA CIN Capacitor of VIN pin 1 10 uF COUT Capacitor of VOUT pin 1 10 uF ESR Equivalent series resistance 5 100 mΩ TA Operating temperature -40 +85 (2) °C (1) All voltages are with respect to the GND pin. (2) The chip’s operating temperature is determined by the junction temperature (TJ), the relationship between TA and TJ, please refer to the application note as below. The larger the TA, the smaller the space left for the chip temperature rise. 8 / 20 www.run-ic.com RS3007 8.4 Thermal Information RS3007 THERMAL METRIC SOT233 SOT2 3-5 5 PINS SOT893L SOT89-3L (L-Type) SOT223 (L-Type) SOT223 SOIC-8 3 PINS 3 PINS 3 PINS 3 PINS 8 PINS 312.5 250 75 208.3 120 84.5 110 °C/W 0.4 0.5 1.7 0.6 1.1 1.5 1.2 W 3 PINS RθJA PD Junction-to-ambient thermal resistance Power Dissipation (1) UNIT (1) Internal thermal shutdown circuitry protects the device from permanent damage. The actual chip output current is subject to the inputoutput voltage difference, ambient temperature and PCB heat dissipation design. 9 / 20 www.run-ic.com RS3007 8.5 ELECTRICAL CHARACTERISTICS (VIN = VOUT + 2V, CIN = COUT = 1μF, VOUT = 3.3V, Full = -40°C to +85°C, typical values are at TA = +25°C, unless otherwise noted.) PARAMETER Input Voltage SYMBOL TEMP MIN MAX UNITS +25°C 2.5(1) 45 V IOUT = 10mA +25°C -2.0 2.0 % IOUT = 10mA, A Type +25°C -1.0 1.0 % IQ No load +25°C 3.0 4.0 uA IQ-OFF VEN =0V +25°C 0.1 1.0 uA 300 350 - mA VOUT =1.8V - 450 550 VOUT =2.5V - 385 485 - 350 450 VOUT =3.3V - 335 435 VOUT =5.0V - 300 400 +25°C - 0.05 0.2 %/V VIN Output Voltage Accuracy (2) Ground Pin Current Shutdown Current Max Output Current CONDITIONS (3) Dropout Voltage (4) Line Regulation +25°C VDROP IOUT= 100mA VOUT =3.0V +25°C ΔVOUT VIN = VOUT + 2V to 36V, IOUT = 1mA ΔVIN × VOUT TYP mV Load Regulation ΔVOUT VIN =VOUT+1V, IOUT = 1mA to 50mA +25°C - 5 20 mV Output Current Limit I_LMT VIN =VOUT+1V +25°C 300 450 - mA Short-Circuit Current Ishort VOUT = 0 +25°C - 100 - mA - 72 - - 77 - - 60 - 1.2 - - V - - 0.4 V - 100 - ppm/°C - 100 - uVrms - 170 - °C - 20 - °C Power Supply Rejection Ratio EN Input Threshold PSRR f = 217Hz VOUT = 3.3V, f = 1KHz IOUT = 10mA f = 10KHz VENH VENL ΔVOUT Output Voltage Temperature IOUT = 1mA Coefficient (5) ΔTA × VOUT VIN =VOUT+1V, IOUT = 1mA, VOUT=3.0V Output Noise Voltage en f = 10Hz to 100KHz Thermal Shutdown TSHDN Temperature Thermal Shutdown TSDH Hysteresis Temperature +25°C +25°C FULL dB NOTES: 1. VIN >= VOUT (NOMINAL), whichever is greater. 2. Option ±1% output voltage accuracy. 3. Maximum output current is affected by the PCB layout, size of metal trace, the thermal conduction path between metal layers, ambient temperature and the other environment factors of system. Attention should be paid to the dropout voltage when V IN < VOUT + VDROP. 4. The dropout voltage is defined as VIN - VOUT, when VOUT is 100mV below the value of VOUT for VIN = VOUT (NOMINAL) + 2V. 5. Output voltage temperature coefficient is defined as the worst-case voltage change divided by the total temperature range. 10 / 20 www.run-ic.com RS3007 8.6 TYPICAL CHARACTERISTICS NOTE: The graphs and tables provided following this note are a statistical summary based on a limited number of samples and are provided for informational purposes only. (VIN = VOUT + 2V, CIN = COUT = 1μF, VOUT = 3.3V, Full = -40°C to +85°C, typical values are at TA = +25°C, unless otherwise noted.) VIN=5.3V to 6.3V,IOUT=50mA VIN=0V to 5.3V,I OUT=50mA 2V/div VOUT 2V/div VIN 50mV/div VOUT 1V/div VIN Time(100us/div) Time(1ms/div) Figure 1. Line Transient Response Figure 2. Power-Up/Power-Down Output Waveform VOUT=3.3V VOUT=3.3V VOUT 50mA/div 100mA/div IOUT 20mV/div 50mV/div VOUT IOUT IOUT=10mA to 50mA IOUT=1mA to 100mA Time(500us/div) Time(500us/div) Figure 4. Load Transient Response Figure 3. Load Transient Response 3.31 3.31 VOUT=3.3V Output Voltage(V) Output Voltage(V) VOUT=3.3V 3.305 3.3 3.295 3.3 3.29 3.28 3.27 3.29 4 14 24 34 44 0 54 50 100 150 200 250 300 Output Current(mA) Input Voltage(V) Figure 5. Line Regulation Figure 6. Load Regulation 11 / 20 www.run-ic.com RS3007 TYPICAL CHARACTERISTICS 3.33 1400 3.32 1200 3.31 1000 VDROP(mV) Output voltage(V) NOTE: The graphs and tables provided following this note are a statistical summary based on a limited number of samples and are provided for informational purposes only. (VIN = VOUT + 2V, CIN = COUT = 1μF, VOUT = 3.3V, Full = -40°C to +85°C, typical values are at TA = +25°C, unless otherwise noted.) 3.3 3.29 3.28 800 600 400 3.27 1# 2# 3# 3.26 3.25 -40 -20 0 20 40 60 Temperature(℃) 1# 2# 3# 200 0 80 100 120 0 100 150 200 250 300 350 IOUT(mA) Figure 7. VOUT vs Temperature Figure 8. VDROP vs IOUT 5 1800 4.5 1600 4 1400 3.5 VDROP(mV) 1200 3 IQ(uA) 50 1000 2.5 2 800 600 1.5 1 0.5 0 -40 -20 0 20 40 60 -40℃ 25℃ 85℃ 125℃ 400 1# 2# 3# 200 0 80 100 120 0 Temperature(℃) 50 100 150 200 250 300 350 IOUT(mA) Figure 9. IQ vs Temperature Figure 10. VDROP - IOUT vs Temperature 3.35 3.33 3.34 3.32 3.33 3.32 VOUT(V) VOUT(V) 3.31 3.31 3.3 3.29 3.29 -40℃ 25℃ 85℃ 125℃ 3.28 3.27 0 50 100 150 200 250 3.3 -40℃ 25℃ 85℃ 125℃ 3.28 3.27 IOUT=10mA 3.26 300 5 IOUT(mA) 10 15 20 25 VIN(V) 30 35 40 Figure 12. VOUT - VIN vs Temperature Figure 11. VOUT - IOUT vs Temperature 12 / 20 www.run-ic.com RS3007 9 DETAILED DESCRIPTION 9.1 Overview The RS3007 low-dropout regulators (LDO) consumes only 3µA of quiescent current at light load and delivers excellent line and load transient performance. These characteristics, combined with low noise and good PSRR with low dropout voltage, make this device ideal for portable consumer applications. 9.2 Functional Block Diagram 9.3 Thermal Considerations When the junction temperature is too high, the thermal protection circuitry sends a signal to the control logic that will shut down the IC. The IC will restart when the temperature has sufficiently cooled down. The maximum power dissipation is dependent on the thermal resistance of the case and the circuit board, the temperature difference between the die junction and the ambient air, and the rate of air flow. The GND pin must be connected to the ground plane for proper dissipation. 9.4 Applications Note: 1) The phase compensation circuit and ESR of the output capacitor are used inside the circuit to compensate, so a capacitor larger than 1.0uF must be connected to the ground. 2) It is recommended to use 1uF polar capacitors for input and output, and to keep the capacitors as close to the VIN and VOUT pins of LDO as possible. 3) Pay attention to the use conditions of input and output voltages and load currents to avoid the power consumption (PD) inside the IC exceeding the maximum power consumption allowed by the package. PD = (VIN - VOUT) × IOUT TPN = PD × RθJA +T TPN is junction temperature T is ambient temperature。 4) When the input voltage VIN is greater than 2.5V, if VIN is also higher than the output set value plus the device dropout voltage, VOUT is equal to the set value. Otherwise, VOUT is equal to VIN minus the dropout voltage. If VIN lower than 2.5V, the VOUT is: VOUT = VIN - VDropout 13 / 20 www.run-ic.com RS3007 10 PACKAGE OUTLINE DIMENSIONS SOT23-3 D 1.90 b 2.59 E1 E 0.99 0.95 0.69 e e1 RECOMMENDED LAND PATTERN (Unit: mm) 0.2 A A2 c θ L A1 Dimensions In Millimeters Dimensions In Inches Symbol Min Max Min Max A 1.050 1.250 0.041 0.049 A1 0.000 0.100 0.000 0.004 A2 1.050 1.150 0.041 0.045 b 0.300 0.500 0.012 0.020 c 0.100 0.200 0.004 0.008 D 2.820 3.020 0.111 0.119 E 1.500 1.700 0.059 0.067 E1 2.650 2.950 0.104 0.116 e 0.950(BSC) 0.037(BSC) e1 1.800 2.000 0.071 0.079 L 0.300 0.600 0.012 0.024 θ 0° 8° 0° 8° 14 / 20 www.run-ic.com RS3007 SOT23-5 D 1.90 b 2.59 E1 E 0.99 0.95 0.69 e e1 RECOMMENDED LAND PATTERN (Unit: mm) 0.2 A A2 c θ L A1 Dimensions In Millimeters Dimensions In Inches Symbol Min Max Min Max A 1.050 1.250 0.041 0.049 A1 0.000 0.100 0.000 0.004 A2 1.050 1.150 0.041 0.045 b 0.300 0.500 0.012 0.020 c 0.100 0.200 0.004 0.008 D 2.820 3.020 0.111 0.119 E 1.500 1.700 0.059 0.067 E1 2.650 2.950 0.104 0.116 e 0.950(BSC) 0.037(BSC) e1 1.800 2.000 0.071 0.079 L 0.300 0.600 0.012 0.024 θ 0° 8° 0° 8° 15 / 20 www.run-ic.com RS3007 SOT89-3L Dimensions In Millimeters Dimensions In Inches Symbol Min Max Min Max A 1.400 1.600 0.055 0.063 b 0.320 0.520 0.013 0.020 b1 0.400 0.580 0.016 0.023 c 0.350 0.440 0.014 0.017 D 4.400 4.600 0.173 0.181 D1 1.550 REF 0.061 REF E 2.300 2.600 0.091 0.102 E1 3.940 4.250 0.155 0.167 e 1.500 BSC 0.060 BSC e1 3.000 BSC 0.118 BSC L 0.900 1.200 16 / 20 0.035 0.047 www.run-ic.com RS3007 SOT223 D b2 E E1 A VIEW B 0.25 L SEE VIEW B A e e1 b WITH PLATING A2 c A BASE METAL A1 SECTION A-A Dimensions In Millimeters Dimensions In Inches Symbol Min Max Min Max A - 1.800 - 0.071 A1 0.02 0.10 0.001 0.004 A2 1.55 1.65 0.061 0.065 b 0.66 0.84 0.026 0.033 b2 2.90 3.10 0.114 0.122 c 0.23 0.33 0.009 0.013 D 6.30 6.70 0.248 0.263 E 6.70 7.30 0.263 0.287 E1 3.30 3.70 0.130 0.145 e 2.30 BSC 0.090 BSC e1 4.60 BSC 0.181 BSC L 0.90 - 17 / 20 0.035 - www.run-ic.com RS3007 SOIC-8(SOP8) b e 5.2 E E1 2.2 D 1.27 0.6 RECOMMENDED LAND PATTERN (Unit: mm) A2 c A A1 L Dimensions In Millimeters θ Dimensions In Inches Symbol Min Max Min Max A 1.350 1.750 0.053 0.069 A1 0.100 0.250 0.004 0.010 A2 1.350 1.550 0.053 0.061 b 0.330 0.510 0.013 0.020 c 0.170 0.250 0.007 0.010 D 4.800 5.000 0.189 0.197 e 1.270(BSC) 0.050(BSC) E 5.800 6.200 0.228 0.244 E1 3.800 4.000 0.150 0.157 L 0.400 1.270 0.016 0.050 θ 0° 8° 0° 8° NOTE: A. All linear dimension is in millimeters. B. This drawing is subject to change without notice. C. Body dimensions do not include mold flash or protrusion. Mold flash and protrusion shall not exceed 0.15 per side. D. BSC: Basic Dimension. Theoretically exact value shown without tolerances. E. REF: Reference Dimension, usually without tolerance, for information purposes only. 18 / 20 www.run-ic.com RS3007 11 TAPE AND REEL INFORMATION REEL DIMENSIONS TAPE DIMENSION Reel Diameter Reel Width(W1) DIRECTION OF FEED NOTE: The picture is only for reference. Please make the object as the standard. KEY PARAMETER LIST OF TAPE AND REEL SOT23-3 Reel Diameter 7’’ Reel Width(mm) 9.0 A0 (mm) 3.20 B0 (mm) 3.30 K0 (mm) 1.30 P0 (mm) 4.0 P1 (mm) 4.0 P2 (mm) 2.0 W (mm) 8.0 Pin1 Quadrant Q3 SOT23-5 7’’ 9.5 3.20 3.20 1.40 4.0 4.0 2.0 8.0 Q3 SOT89-3L 7’’ 13.2 4.85 4.45 1.85 4.0 8.0 2.0 12.0 Q3 SOT223 13’’ 12.4 6.765 7.335 1.88 4.0 8.0 2.0 12.0 Q3 SOIC-8(SOP8) 13’’ 12.4 6.40 5.40 2.10 4.0 8.0 2.0 12.0 Q1 Package Type NOTE: 1. All dimensions are nominal. 2. Plastic or metal protrusions of 0.15mm maximum per side are not included. 19 / 20 www.run-ic.com RS3007 IMPORTANT NOTICE AND DISCLAIMER Jiangsu RUNIC Technology Co., Ltd. will accurately and reliably provide technical and reliability data (including data sheets), design resources (including reference designs), application or other design advice, WEB tools, safety information and other resources, without warranty of any defect, and will not make any express or implied warranty, including but not limited to the warranty of merchantability Implied warranty that it is suitable for a specific purpose or does not infringe the intellectual property rights of any third party. These resources are intended for skilled developers designing with RUNIC products You will be solely responsible for: (1) Selecting the appropriate products for your application; (2) Designing, validating and testing your application; (3) Ensuring your application meets applicable standards and any other safety, security or other requirements; (4) RUNIC and the RUNIC logo are registered trademarks of RUNIC INCORPORATED. All trademarks are the property of their respective owners; (5) For change details, review the revision history included in any revised document. The resources are subject to change without notice. Our company will not be liable for the use of this product and the infringement of patents or third-party intellectual property rights due to its use. 20 / 20 www.run-ic.com
RS3007-5.0YE3 价格&库存
很抱歉,暂时无法提供与“RS3007-5.0YE3”相匹配的价格&库存,您可以联系我们找货
RS3007-5.0YE3
    • 60+1.60325
