SURFACE MOUNT ALUMINUM ELECTROLYTIC CAPACITORS
TM
AIchip
Low ESR, 105℃
MZJ
Series
・Lower ESR, 2,000 hours at 105℃
・Rated voltage range : 6.3 to 35V
・Nominal capacitance range : 10 to 1,800μF
・Solvent resistant type (see PRECAUTIONS AND GUIDELINES)
・Vibration resistant structure
・RoHS Compliant
MZJ
Lower ESR
MZA P74
◆SPECIFICATIONS
Items
Category
Temperature Range
Rated Voltage Range
Capacitance Tolerance
Leakage Current
Dissipation Factor
(tanδ)
Low Temperature
Characteristics
(Max. Impedance Ratio)
Endurance
Shelf Life
Surge Voltage Test
Characteristics
-55 to +105℃
6.3 to 35Vdc
±20% (M)
(at 20℃, 120Hz)
I=0.01CV or 3µA, whichever is greater.
Where, I : Max. leakage current (µA), C : Nominal capacitance (µF), V : Rated voltage (V)
(at 20℃ after 2 minutes)
Rated voltage (Vdc)
35V
25V
16V
10V
6.3V
(at 20℃, 120Hz)
tanδ(Max.)
0.12
0.14
0.16
0.19
0.26
Rated voltage (Vdc)
35V
25V
16V
10V
6.3V
Z(-25℃)/Z(+20℃)
2
2
2
2
2
Z(-40℃)/Z(+20℃)
3
3
3
3
3
Z(-55℃)/Z(+20℃)
(at 120Hz)
3
3
4
4
4
The following specifications shall be satisfied when the capacitors are restored to 20℃ after the rated voltage is applied for 2,000 hours
at 105℃.
Capacitance change
≦±30% of the initial value
D.F. (tanδ)
≦200% of the initial specified value
Leakage current
≦The initial specified value
The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours at 105℃ without
voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to Item 4.1 of JIS C 5101-4.
Capacitance change
D.F. (tanδ)
Leakage current
The capacitors shall be subjected to 1,000 cycles each consisting of charging with the specified surge voltage for 30±5 seconds through
a protective resistor (as required for RC=0.1±0.05sec) and open-circuiting for 5.5 minutes at a room temperature of 15 to 35℃.
Rated voltage (Vdc)
6.3V
10V
16V
25V
35V
Surge voltage (Vdc)
7.2V
12V
18V
29V
40V
Appearance
Capacitance change
D.F. (tanδ)
No significant damage
≦±20% of the initial value
Leakage current
(Caution)
Surge Voltage Test intends to evaluate capacitors in durability of an exceptional excessive voltage under specific conditions.It does not
imply long-term use at all.
◆DIMENSIONS [mm]
● Terminal
● Terminal
● Size
● Size
0.3max.
L±0.3 (Note)
B±0.2
φD±0.5
P
C±0.2
W
W
0.3max.
Vent for JA0
B±0.2
φD±0.5
Vent for JA0
Code : G(Vibration resistant structure)
code : HA0 and JA0
Size code
D61
E61
F61
F80
HA0
JA0
D
4
5
6.3
6.3
8
10
C
B
A
L
5.8 4.3 4.3 5.1
5.8 5.3 5.3 5.9
5.8 6.6 6.6 7.2
7.7 6.6 6.6 7.2
10.0 8.3 8.3 9.0
10.0 10.3 10.3 11.0
W
0.5 to 0.8
0.5 to 0.8
0.5 to 0.8
0.5 to 0.8
0.7 to 1.1
0.7 to 1.1
P
1.0
1.4
1.9
1.9
3.1
4.5
A±0.2
L±0.5
A±0.2
P
C±0.2
Code : A
code : D61 to JA0
Note : L±0.5 for HA0 and JA0
: Dummy terminals
◆MARKING
EX) 35V10µF
9j
10
VZJ
● Rated
voltage symbol
Rated voltage (Vdc)
Symbol
6.3
j
10
A
16
C
25
E
35
V
Applying voltage over the rated voltages causes the capacitors to have short lifetime.
Besides, applying voltage over the specified surge voltages may cause to have short circuit failure. A protection
circuit should be used if applied voltage will exceed the rated voltages.
Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications.
72
CAT. No. E1001N
MZJSeries
TM
AIchip
Low ESR, 105℃
◆PART NUMBERING SYSTEM
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
E MZ J AAA A DA AAA M AAA G
Supplement code
Size code
Capacitance tolerance code
Capacitance code (ex. 10µF:100, 1,000µF:102)
Taping code
Terminal code
Voltage code (ex. 6.3V:6R3, 10V:100, 35V:350)
Series code
Category
Please refer to "Product code guide (surface mount type)"
◆STANDARD RATINGS
WV(Vdc)
6.3
10
16
25
35
Cap(µF)
Size code
tanδ
47
100
220
330
1,000
1,500
1,800
33
150
680
1,000
1,200
22
47
100
150
220
470
680
820
10
22
33
33
47
68
100
330
470
560
10
22
33
47
68
100
100
150
220
330
390
D61
E61
F61
F80
HA0
JA0
JA0
D61
F61
HA0
JA0
JA0
D61
E61
F61
F80
F80
HA0
JA0
JA0
D61
E61
E61
F61
F61
F61
F80
HA0
JA0
JA0
D61
E61
F61
F61
F61
F80
HA0
HA0
HA0
JA0
JA0
0.26
0.26
0.26
0.26
0.26
0.26
0.26
0.19
0.19
0.19
0.19
0.19
0.16
0.16
0.16
0.16
0.16
0.16
0.16
0.16
0.14
0.14
0.14
0.14
0.14
0.14
0.14
0.14
0.14
0.14
0.12
0.12
0.12
0.12
0.12
0.12
0.12
0.12
0.12
0.12
0.12
ESR
(Ωmax/20℃, 100kHz)
0.85
0.36
0.26
0.16
0.08
0.06
0.06
0.85
0.26
0.08
0.06
0.06
0.85
0.36
0.26
0.16
0.16
0.08
0.06
0.06
0.85
0.36
0.36
0.26
0.26
0.26
0.16
0.08
0.06
0.06
0.85
0.36
0.26
0.26
0.26
0.16
0.08
0.08
0.08
0.06
0.06
Rated ripple current
(mArms/105℃, 100kHz)
160
240
300
600
850
1,190
1,190
160
300
850
1,190
1,190
160
240
300
600
600
850
1,190
1,190
160
240
240
300
300
300
600
850
1,190
1,190
160
240
300
300
300
600
850
850
850
1,190
1,190
Part No.
EMZJ6R3ADA470MD61G
EMZJ6R3ADA101ME61G
EMZJ6R3ADA221MF61G
EMZJ6R3ADA331MF80G
EMZJ6R3ADA102MHA0G
EMZJ6R3ADA152MJA0G
EMZJ6R3ADA182MJA0G
EMZJ100ADA330MD61G
EMZJ100ADA151MF61G
EMZJ100ADA681MHA0G
EMZJ100ADA102MJA0G
EMZJ100ADA122MJA0G
EMZJ160ADA220MD61G
EMZJ160ADA470ME61G
EMZJ160ADA101MF61G
EMZJ160ADA151MF80G
EMZJ160ADA221MF80G
EMZJ160ADA471MHA0G
EMZJ160ADA681MJA0G
EMZJ160ADA821MJA0G
EMZJ250ADA100MD61G
EMZJ250ADA220ME61G
EMZJ250ADA330ME61G
EMZJ250ADA330MF61G
EMZJ250ADA470MF61G
EMZJ250ADA680MF61G
EMZJ250ADA101MF80G
EMZJ250ADA331MHA0G
EMZJ250ADA471MJA0G
EMZJ250ADA561MJA0G
EMZJ350ADA100MD61G
EMZJ350ADA220ME61G
EMZJ350ADA330MF61G
EMZJ350ADA470MF61G
EMZJ350ADA680MF61G
EMZJ350ADA101MF80G
EMZJ350ADA101MHA0G
EMZJ350ADA151MHA0G
EMZJ350ADA221MHA0G
EMZJ350ADA331MJA0G
EMZJ350ADA391MJA0G
◆RATED RIPPLE CURRENT MULTIPLIERS
・Frequency Multipliers
Frequency(Hz)
Capacitance(μF)
10 to 150
220 to 560
680 to 1,800
120
1k
10k
100k
0.40
0.50
0.60
0.75
0.85
0.87
0.90
0.94
0.95
1.00
1.00
1.00
The endurance of capacitors is reduced with internal heating produced by ripple current at the rate of halving the lifetime with every 5℃ rise.
When long life performance is required in actual use, the rms ripple current has to be reduced.
73
CAT. No. E1001N
很抱歉,暂时无法提供与“EMZJ160ARA470ME61G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1000+1.067471000+0.12959
- 2000+1.004712000+0.12197
- 5000+0.941905000+0.11435
- 10000+0.8791110000+0.10672
- 25000+0.8477025000+0.10291
- 50000+0.8163150000+0.09910
- 100000+0.78491100000+0.09529
- 国内价格 香港价格
- 1+3.662111+0.44457
- 10+2.4441810+0.29671
- 50+1.9468450+0.23634
- 100+1.60708100+0.19510
- 500+1.25587500+0.15246
