5D2-13LD
5D2-13LD
    SEMITEC
    NTC_D14.5X8MM_TM
    NTC热敏电阻 5Ω 5A ±15% 2900K NTC_D14.5X8MM_TM
5D2-13LD 数据手册
■ Inrush current limiter 16 5 211 D O A 5 11 D2 16 AO Power Thermistor 222 5 B V 3D 5 22 AE 6D 2 Power thermistors utilize the self heating characteristic of NTC thermistors which causes a significant decrease in resistance in a short time. Power thermistors can be used instead of inrush current limiting resistors. Power thermistors have the advantage that their resistance decreases through self heating which reduces power loss and results in energy savings. UL1434 File No. E92669 (1D2-22 excluded)  certified. ■ Product number explanation ■ Applications Switching power supplies, adapters, LCD TVs, plasma TVs, air conditioners, DVD players, audio equipment, LCD projectors, copiers, PCs, printers, office automation equipment, gaming machine power supplies 5 D2 -11 L C TR Packaging options TR: Tray Lead wire options (available for: D2-15, D2-18, D2-22) C: Clinched No marking: In plastic bag D: Straight CS: Short clinched Resistance tolerance L: ± 15% Element (head part) diameter Inrush current limiter series Rated zero-power resistance (Ω) at 25 ℃ 5 D2 - 11 L T3C Taping options T3C: Clinched taping T3D: Straight taping ■ Dimensions Color: Gray Tin plated soft copper wire (1) Straight (1) Clinched (1) Short clinched (Unit: mm) (1): Do not apply force to the lead wire legs from the side as this may damage the power thermistor. 1 Lead wire diameter D T H H0 d D2-05 8.5 max. 7.0 max. 11.5 max. 15.5 max. D2-07 11.0 max. 9.0 max. 13.0 max. 16.0 max. D2-08 10.0 max. 7.0 max. 13.0 max. 17.0 max. D2-10 13.0 max 9.0 max. 17.0 max. 19.5 max. D2-11 11.5 max. 8.0 max. 15.0 max. 18.5 max. D2-13 14.5 max. 8.0 max. 18.0 max. 21.5 max. 7.5 ± 1 D2-14 17.0 max. 9.0 max. 21.0 max. 22.5 max. D2-15 16.5 max. 8.0 max. 20.0 max. 23.0 max D2-18 19.5 max. 8.0 max. 23.0 max. 26.0 max. D2-22 8.5 max. 26.5 max. 23.0 max (8.0 max.1) 29.5 max. 5.0 ± 1 Φ 0.8 10 ± 1 : 1D2-22 Φ 1.0 (Φ 0.8) Unit: mm ■ Taping dimensions P P0 P1 W W0 W1 W2 H1 H2 L F1 Φ D0 t t1 ⊿h D2-05 D2-07 5.0 ± 0.7 D2-08 15.0 ± 1.0 D2-10 15.0 ± 0.3 5.0 ± 0.5 17.5 to 19.0 min. 5.0 9.0 ± 0.5 max.3.0 16.0 ± 0.5 19.0 to 21.5 max. 1.0 4.0 ± 0.2 0.6 ± 0.3 max. 1.5 0 ± 2.0 D2-11 D2-13 D2-14 30.0 ± 1.0 ◦ MOQ: 1000 pcs. 26 3.75 ± 0.7 7.5 ± 0.5 Unit: mm ■ Specifications Product number 5D2-05 10D2-05 20D2-05 5D2-07 8D2-07 10D2-07 12D2-07 16D2-07 22D2-07 5D2-08 10D2-08 15D2-08 20D2-08 2D2-10 3D2-10 5D2-10 8D2-10 10D2-10 12D2-10 16D2-10 2D2-11 3D2-11 4D2-11 5D2-11 8D2-11 10D2-11 12D2-11 15D2-11 16D2-11 20D2-11 1D2-13 2D2-13 4D2-13 4.7D2-13 5D2-13 8D2-13 10D2-13 12D2-13 15D2-13 16D2-13 2D2-14 3D2-14 4D2-14 5D2-14 8D2-14 10D2-14 12D2-14 16D2-14 1D2-15 1.5D2-15 2D2-15 3D2-15 4D2-15 4.7D2-15 5D2-15 8D2-15 10D2-15 12D2-15 15D2-15 16D2-15 4D2-18 5D2-18 8D2-18 10D2-18 47D2-18 1D2-22 3D2-22 4D2-22 6D2-22 Zero-power B value1 resistance B25/85 at 25 ℃ (± 15%) (± 5%) (Ω) (K) 5.0 2650 10.0 2700 20.0 2800 5.0 2800 8.0 2800 10.0 2800 12.0 2900 16.0 2900 22.0 2900 5.0 2700 10.0 2800 15.0 2800 20.0 2900 2.0 2800 3.0 2800 5.0 2900 8.0 2900 10.0 2900 12.0 3000 16.0 3000 2.0 2650 3.0 2650 4.0 2700 5.0 2700 8.0 2800 10.0 2800 12.0 2800 15.0 2950 16.0 2950 20.0 3000 1.0 2650 2.0 2700 4.0 2800 4.7 2900 5.0 2900 8.0 3000 10.0 3050 12.0 3000 15.0 3050 16.0 3050 2.0 2800 3.0 2900 4.0 2900 5.0 2900 8.0 3000 10.0 3000 12.0 3000 16.0 3000 1.0 2650 1.5 2650 2.0 2700 3.0 2800 4.0 2800 4.7 2900 5.0 2900 8.0 3000 10.0 3000 12.0 3050 15.0 3100 16.0 3100 4.0 2900 5.0 2950 8.0 3050 10.0 3100 47.0 3450 1.0 2900 3.0 2800 4.0 2900 6.0 3000 : In part reference values 1 2 Max. current at 25 ℃ (A) 2.0 1.0 0.3 3.0 2.0 2.0 1.7 2.0 1.0 3.0 2.0 2.0 1.0 5.0 4.0 4.0 3.0 3.0 1.8 1.6 5.0 4.0 4.0 4.0 3.0 3.1 2.0 2.5 2.5 2.0 6.0 6.0 5.0 5.0 5.0 4.0 4.0 4.0 3.0 3.0 5.0 5.0 5.0 4.0 2.5 2.2 2.0 1.8 8.0 8.0 8.0 7.0 7.0 6.0 6.0 5.0 5.0 5.0 4.0 4.0 8.0 8.0 6.0 6.0 2.0 12.0 8.0 8.0 6.0 Residual resistance (Ω) 0.48 0.91 1.66 0.36 0.58 0.72 0.78 1.04 1.43 0.35 0.63 0.94 1.13 0.15 0.22 0.33 0.52 0.65 0.71 0.94 0.15 0.22 0.28 0.35 0.50 0.63 0.75 0.80 0.86 1.02 0.06 0.10 0.18 0.18 0.19 0.27 0.32 0.41 0.48 0.51 0.15 0.20 0.26 0.33 0.47 0.59 0.71 0.94 0.06 0.08 0.10 0.13 0.18 0.18 0.19 0.27 0.34 0.39 0.45 0.48 0.16 0.18 0.26 0.30 0.94 0.04 0.13 0.16 0.21 Thermal time constant2 Dissipation Operating factor temp. range AC AC AC AC (s) 20 20 20 35 41 45 41 45 50 35 35 35 35 50 53 53 70 75 53 70 40 40 40 40 40 40 40 40 40 40 55 55 55 55 55 25 55 55 55 55 90 80 95 110 80 95 105 115 70 70 70 70 70 70 70 70 70 70 70 70 90 90 90 90 90 125 130 130 130 (mW / ℃) (℃) 15 - 50 to 150 7 - 50 to 150 1 - 50 to 150 30 - 40 to 160 30 - 40 to 160 30 - 40 to 160 30 - 40 to 160 30 - 40 to 160 30 - 40 to 160 22 - 50 to 170 17 - 50 to 170 26 - 50 to 170 8 - 50 to 170 32 - 40 to 160 32 - 40 to 160 32 - 40 to 160 32 - 40 to 160 32 - 40 to 160 32 - 40 to 160 32 - 40 to 160 26 - 50 to 170 24 - 50 to 170 31 - 50 to 170 39 - 50 to 170 31 - 50 to 170 42 - 50 to 170 21 - 50 to 170 34 - 50 to 170 37 - 50 to 170 28 - 50 to 170 12 - 50 to 200 21 - 50 to 200 24 - 50 to 200 26 - 50 to 200 27 - 50 to 200 25 - 50 to 200 29 - 50 to 200 37 - 50 to 200 25 - 50 to 200 26 - 50 to 200 36 - 40 to 160 36 - 40 to 160 36 - 40 to 160 36 - 40 to 160 36 - 40 to 160 36 - 40 to 160 36 - 40 to 160 36 - 40 to 160 22 - 50 to 200 29 - 50 to 200 37 - 50 to 200 36 - 50 to 200 48 - 50 to 200 37 - 50 to 200 39 - 50 to 200 39 - 50 to 200 49 - 50 to 200 54 - 50 to 200 41 - 50 to 200 44 - 50 to 200 59 - 50 to 200 66 - 50 to 200 53 - 50 to 200 62 - 50 to 200 21 - 50 to 200 32 - 50 to 200 48 - 50 to 200 59 - 50 to 200 43 - 50 to 200 100 V (µF) 860 860 860 400 560 680 380 800 960 1260 1260 2880 2880 640 720 440 560 1640 830 830 2700 4830 2880 2700 2700 2880 4030 2880 2880 2880 860 860 860 2700 2700 2880 2880 4830 4830 4830 4200 3080 3400 3600 1390 1790 2190 2790 6910 6910 6910 4030 4030 4030 4030 4030 5760 5760 5760 5760 6910 6910 6910 6910 6910 8200 12600 12600 12600 120 V (µF) 600 600 600 260 360 470 260 530 630 880 880 2000 2000 1100 1170 970 1070 1100 580 580 1880 3360 2000 1880 1880 2000 2800 2000 2000 2000 600 600 600 1880 1880 2000 2000 3360 3360 3360 2890 2110 2350 2480 970 1240 1520 1940 4800 4800 4800 2800 2800 2800 2800 2800 4000 4000 4000 4000 4800 4800 4800 4800 4800 8800 8800 8800 220 V (µF) 170 170 170 80 110 140 80 160 190 260 260 590 590 330 350 290 320 330 170 170 550 990 590 550 550 590 830 590 590 590 170 170 170 550 550 590 590 990 990 990 860 630 700 740 280 370 450 570 1420 1420 1420 830 830 830 830 830 1190 1190 1190 1190 1420 1420 1420 1420 1420 1700 2610 2610 2610 240 V (µF) 150 150 150 60 90 110 60 130 150 220 220 500 500 270 290 240 260 270 140 140 470 840 500 470 470 500 700 500 500 500 150 150 150 470 470 500 500 840 840 840 720 520 580 620 240 310 380 480 1200 1200 1200 700 700 700 700 700 1000 1000 1000 1000 1200 1200 1200 1200 1200 2200 2200 2200 Max. capacitance : Reference values Item Solderability Tensile strength (lead wire) Voltage proof Insulation resistance Dry heat Damp heat Temperature cycle (thermal shock) Electrical load Test conditions 10 s at 260 ℃ 5 s at 350 ℃ 3 s at 245 ℃ Flux material: Rosin 25%, ethyl alcohol 75% A load of 10 N is applied to the wire terminations in vertical direction for 10 s. 1000 V AC for one minute 500 V DC 1000 hours at max. operating temperature for each product number 1000 hours at 40 ℃ and 90% humidity 10 cycles as below: 1. - 40 ℃ for 30 minutes 2. Room temperature for 5 minutes 3. 160 ℃ for 30 minutes 4. Room temperature for 5 minutes Max. current for 1000 h at 25 ℃ room temperature (J) 4.3 4.3 4.3 1.9 2.6 3.3 1.9 3.8 4.5 6.3 6.3 14.0 14.0 7.9 8.4 7.0 7.7 7.9 4.1 4.1 13.0 24.0 14.0 13.0 13.0 14.0 20.0 14.0 14.0 14.0 4.3 4.3 4.3 13.0 13.0 14.0 14.0 24.0 24.0 24.0 20.8 15.2 16.9 17.9 6.9 8.9 10.9 13.9 34.0 34.0 34.0 20.0 20.0 20.0 20.0 20.0 28.0 28.0 28.0 28.0 34.0 34.0 34.0 34.0 34.0 41.0 63.0 63.0 63.0 ■ Caution ■ Reliability data Resistance to soldering heat Energy surge capacity Criteria ΔR ± 15% More than 95% soldered ΔR ± 15% Less than 1 mA Over 100 MΩ ΔR ± 20% ΔR ± 15% ΔR ± 20% • When force is applied to the lead wire the leg connections may break or chipping may occur. • May get hot during use. When designing the environment around the power thermistor be especially careful with lead wire connections, materials used in the direct vicinity and the layout of other electrical components. • Do not use two or more power thermistors in a row. 27 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Semitec: 1.5D2-15LC 1.5D2-15LCS 1.5D2-15LD 10D2-07LC 10D2-08LCS 10D2-08LD 10D2-11LC 10D2-11LCS 10D211LD 10D2-13LC 10D2-13LCS 10D2-13LD 10D2-15LC 10D2-15LCS 10D2-15LD 10D2-18LC 10D2-18LCS 10D2-18LD 12D2-11LC 12D2-11LCS 12D2-11LD 12D2-13LC 12D2-13LCS 12D2-13LD 12D2-15LCS 15D2-08LC 15D2-08LCS 15D2-08LD 15D2-11LC 15D2-11LCS 15D2-11LD 15D2-13LC 15D2-13LCS 15D2-13LD 15D215LC 15D2-15LCS 15D2-15LD 16D2-11LC 16D2-11LCS 16D2-11LD 16D2-13LC 16D2-13LD 16D2-15LC 16D215LCS 16D2-15LD 1D2-13LC 1D2-13LCS 1D2-13LD 1D2-15LC 1D2-15LCS 1D2-15LD 20D2-05LC 20D2-05LCS 20D2-05LD 20D2-08LC 20D2-08LCS 20D2-08LD 20D2-11LC 20D2-11LCS 20D2-11LD 2D2-11LC 2D2-11LCS 2D2-11LD 2D2-13LC 2D2-13LCS 2D2-13LD 2D2-15LC 2D2-15LCS 2D2-15LD 3D2-11LC 3D2-11LCS 3D2-11LD 3D2-15LC 3D2-15LCS 3D2-15LD 3D2-22LC 3D2-22LCS 3D2-22LD 4.7D2-13LCS 4.7D2-13LD 4.7D2-15LC 4.7D2-15LCS 4.7D2-15LD 47D2-18LC 47D2-18LCS 47D2-18LD 4D2-11LC 4D2-11LCS 4D2-11LD 4D2-13LC 4D2-13LCS 4D2-13LD 4D2-15LC 4D2-15LCS 4D2-15LD 4D2-18LC 4D2-18LCS 4D2-18LD 4D2-22LC 4D222LCS
5D2-13LD 价格&库存
很抱歉,暂时无法提供与“5D2-13LD”相匹配的价格&库存,您可以联系我们找货
