AiP74LVC2G125TA8.TR
AiP74LVC2G125TA8.TR
    I-CORE(中微爱芯)
    TSSOP8_3X3MM
    缓冲器/驱动器 非反相 1.65V~5.5V TSSOP8_3X3MM
AiP74LVC2G125TA8.TR 数据手册
Wuxi I-CORE Electronics Co., Ltd. rev:B3 Number:AiP74LVC2G125-AX-LJ-B038EN e Tab: 835-12 or AiP74LVC2G125 Dual Buffer/Line Driver; 3-state Specification i-c Product Specification Revision History: Version Date 2017-05-A1 2021-12-A2 2017-05 2021-12 2022-02-A3 2022-02 2022-03-A4 2022-03 Description New Modify ordering information Modify ambient temperature to -40℃~+105℃ and add electrical characteristics of -40℃~+105℃ Modify ordering information note 1 Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 1/ 13 VER:2022-03-A4 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74LVC2G125-AX-LJ-B038EN 1、General Description The AiP74LVC2G125 provides a dual non-inverting buffer/line driver with 3-state output. The 3-state — — output is controlled by the output enable input (pin nOE). A HIGH-level at pin nOE causes the output to assume a high-impedance OFF-state. Inputs can be driven from either 3.3V or 5V devices. This feature allows the use of these devices as translators in a mixed 3.3V and 5V environment. This device is fully specified for partial power-down applications using IOFF. The IOFF circuitry disables the output, preventing a damaging backflow current through the device when it is powered down. or e Features:  Wide supply voltage range from 1.65V to 5.5V  5V tolerant input/output for interfacing with 5V logic  ±24mA output drive (VCC=3.0V)  CMOS low power consumption  Latch-up performance exceeds 250mA  Direct interface with TTL levels  Inputs accept voltages up to 5V  Specified from -40℃ to +105℃  Packaging information: TSSOP8/VSSOP8 Ordering Information: Reel packing specifications: Packaging form Marking code Reel quantity i-c Part number AiP74LVC2G125TA8.TR TSSOP8 BRXX 3000 PCS/reel AiP74LVC2G125YA8.TR VSSOP8 BRXX 3000 PCS/reel Boxed reel quantity 3000 PCS/box 3000 PCS/box Notes Dimensions of plastic enclosure: 3.0mm×3.0mm Pin spacing: 0.65mm Dimensions of plastic enclosure: 2.0mm×2.3mm Pin spacing: 0.50mm Note 1: “XX” refers to variable content, meaning year and package batch serial number. Note 2: If the physical information is inconsistent with the ordering information, please refer to the actual product. Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 2/ 13 VER:2022-03-A4 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74LVC2G125-AX-LJ-B038EN 2、Block Diagram And Pin Description 2.1、Block Diagram or e Figure 1. Logic symbol Figure 2. IEC logic symbol i-c 2.2、Pin Configurations 2.3、Pin Description Pin No. Pin Name — Description 1 1OE output enable input (active LOW) 2 3 4 5 6 1A 2Y GND 2A 1Y data input data output ground (0V) data input data output 7 2OE output enable input (active LOW) 8 VCC supply voltage — Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 3/ 13 VER:2022-03-A4 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74LVC2G125-AX-LJ-B038EN 2.4、Function Table Input Output — nA nOE nY L L L L H H H X Z Note: H=HIGH voltage level; L=LOW voltage level; X=don’t care; Z=high-impedance OFF-state. 3、Electrical Parameter 3.1、Absolute Maximum Ratings (Voltages are referenced to GND(ground=0V), unless otherwise specified.) Symbol VCC output voltage VO IIK VI Min. -0.5 Max. +6.5 Unit V VI < 0V -50 - mA - -0.5 +6.5 V VO > VCC or VO < 0V - ±50 mA Enable mode Disable mode Power-down mode; VCC=0V VO=0V to VCC - -0.5 -0.5 -0.5 -100 VCC+0.5 +6.5 +6.5 ±50 100 - V V V mA mA mA or IOK Conditions - e Parameter supply voltage input clamping current input voltage Output clamping current i-c output current IO supply current ICC ground current IGND storage Tstg -65 +150 temperature total power Ptot 300 dissipation Soldering TL 10s 250 temperature Note: [1] For TSSOP8 package: above 55℃ the value of Ptot derates linearly with 2.5mW/K. [2] For VSSOP8 package: above 110℃ the value of Ptot derates linearly at 8mW/K. ℃ mW ℃ 3.2、Recommended Operating Conditions Parameter supply voltage input voltage Symbol VCC VI output voltage VO ambient temperature input transition rise and fall rate Conditions VCC=1.65V to 5.5V; Enable mode VCC=1.65V to 5.5V; Disable mode VCC=0V; Power-down mode Min. 1.65 0 0 0 0 Typ. - Max. 5.5 5.5 VCC 5.5 5.5 Unit V V V V V Tamb - -40 - +105 ℃ Δt/ΔV VCC=1.65V to 2.7V VCC=2.7V to 5.5V - - 20 10 ns/V ns/V Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 4/ 13 VER:2022-03-A4 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74LVC2G125-AX-LJ-B038EN Unit V V V V V V V e 3.3、Electrical Characteristics 3.3.1、DC Characteristics 1 (Tamb=-40℃ to +85℃, voltages are referenced to GND (ground=0V), unless otherwise specified.) Parameter Symbol Conditions Min. Typ. Max. 0.65× VCC=1.65V to 1.95V VCC VCC=2.3V to 2.7V 1.7 HIGH-level VIH input voltage VCC=2.7V to 3.6V 2.0 0.7× VCC=4.5V to 5.5V VCC 0.35× VCC=1.65V to 1.95V VCC V =2.3V to 2.7V 0.7 LOW-level CC VIL input voltage VCC=2.7V to 3.6V 0.8 0.3× VCC=4.5V to 5.5V VCC IO=-100uA; VCCVCC=1.65V to 5.5V 0.1 IO=-4mA; VCC=1.65V 1.2 HIGH-level IO=-8mA; VCC=2.3V 1.9 VOH VI = VIH or VIL output voltage IO=-12mA; VCC=2.7V 2.2 IO=-24mA; VCC=3.0V 2.3 IO=-32mA; VCC=4.5V 3.8 IO=100uA; 0.10 VCC=1.65V to 5.5V IO=4mA; VCC=1.65V 0.45 LOW-level IO=8mA; VCC=2.3V 0.30 VOL VI = VIH or VIL output voltage IO=12mA; VCC=2.7V 0.40 IO=24mA; VCC=3.0V 0.55 IO=32mA; VCC=4.5V 0.55 input leakage VI=5.5V or GND; II ±0.1 ±1 current VCC=0V to 5.5V OFF-state VI=VIH or VIL; IOZ ±0.1 ±2 output current VO=5.5V or GND; VCC=3.6V power-off IOFF VI or VO=5.5V; VCC=0V ±0.1 ±2 leakage current VI=5.5V or GND; supply current ICC 0.1 4 VCC=1.65V to 5.5V; IO=0A additional per pin; VI=VCC-0.6V; ΔICC 5 500 supply current IO=0A; VCC=2.3V to 5.5V input CI 2 capacitance Note: All typical values are measured at VCC=3.3V and Tamb=25℃. V V i-c or V V V V V Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 V V V V V V uA uA uA uA uA pF 5/ 13 VER:2022-03-A4 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74LVC2G125-AX-LJ-B038EN Unit V V V V V V V V e 3.3.2、DC Characteristics 2 (Tamb=-40℃ to +105℃, voltages are referenced to GND (ground=0V), unless otherwise specified.) Parameter Symbol Conditions Min. Typ. Max. 0.65× VCC=1.65V to 1.95V VCC VCC=2.3V to 2.7V 1.7 HIGH-level VIH input voltage VCC=2.7V to 3.6V 2.0 0.7× VCC=4.5V to 5.5V VCC 0.35× VCC=1.65V to 1.95V VCC VCC=2.3V to 2.7V 0.7 LOW-level VIL input voltage VCC=2.7V to 3.6V 0.8 0.3× VCC=4.5V to 5.5V VCC IO=-100uA; VCCVCC=1.65V to 5.5V 0.1 IO=-4mA; VCC=1.65V 0.95 HIGH-level IO=-8mA; VCC=2.3V 1.7 VOH VI = VIH or VIL output voltage IO=-12mA; VCC=2.7V 1.9 IO=-24mA; VCC=3.0V 2.0 IO=-32mA; VCC=4.5V 3.4 IO=100uA; 0.10 VCC=1.65V to 5.5V IO=4mA; VCC=1.65V 0.70 LOW-level IO=8mA; VCC=2.3V 0.45 VOL VI = VIH or VIL output voltage IO=12mA; VCC=2.7V 0.60 IO=24mA; VCC=3.0V 0.80 IO=32mA; VCC=4.5V 0.80 input leakage VI=5.5V or GND; II ±1 current VCC=0V to 5.5V OFF-state VI=VIH or VIL; IOZ ±2 output current VO=5.5V or GND; VCC=3.6V power-off IOFF VI or VO=5.5V; VCC=0V ±2 leakage current VI=5.5V or GND; supply current ICC 4 VCC=1.65V to 5.5V; IO=0A additional per pin; VI=VCC-0.6V; ΔICC 500 supply current IO=0A; VCC=2.3V to 5.5V Note: All typical values are measured at VCC=3.3V and Tamb=25℃. V i-c or V V V V V Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 V V V V V V uA uA uA uA uA 6/ 13 VER:2022-03-A4 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74LVC2G125-AX-LJ-B038EN Unit ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns pF pF i-c or e 3.3.3、AC Characteristics 1 (Tamb=-40℃ to +85℃, voltages are referenced to GND (ground=0V), unless otherwise specified.) Parameter Symbol Conditions Min. Typ. Max. VCC=1.65V to 1.95V 1.0 3.7 9.1 VCC=2.3V to 2.7V 0.5 2.5 4.8 nA to nY propagation tpd see Figure 4 VCC=2.7V 1.0 2.7 4.8 delay VCC=3.0V to 3.6V 0.5 2.3 4.3 VCC=4.5V to 5.5V 0.5 1.9 3.7 VCC=1.65V to 1.95V 1.5 4.3 9.9 VCC=2.3V to 2.7V 1.0 2.8 5.6 — nOE to nY ten see Figure 5 VCC=2.7V 1.5 3.3 5.7 enable time VCC=3.0V to 3.6V 0.5 2.4 4.7 VCC=4.5V to 5.5V 0.5 2.0 3.8 VCC=1.65V to 1.95V 1.0 3.5 11.6 V =2.3V to 2.7V 0.5 1.8 5.8 — CC nOE to nY tdis see Figure 5 VCC=2.7V 1.0 2.7 4.8 disable time VCC=3.0V to 3.6V 1.0 2.7 4.6 VCC=4.5V to 5.5V 0.5 1.8 3.4 Power per buffer; output enabled 18 dissipation CPD VI= GND to output disabled 5 capacitance VCC Note: [1] Typical values are measured at nominal VCC and at Tamb=25℃. [2] tpd is the same as tPLH and tPHL. [3] ten is the same as tPZH and tPZL. [4] tdis is the same as tPLZ and tPHZ. [3] CPD is used to determine the dynamic power dissipation (PD in uW). PD=(CPD×VCC2×fi×N)+∑(CL×VCC2×fo) where: fi=input frequency in MHz; fo=output frequency in MHz; CL=output load capacitance in pF; VCC=supply voltage in V; N=number of inputs switching; ∑(CL×VCC2×fo)=sum of outputs. Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 7/ 13 VER:2022-03-A4 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74LVC2G125-AX-LJ-B038EN Unit ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns i-c or e 3.3.4、AC Characteristics 2 (Tamb=-40℃ to +105℃, voltages are referenced to GND (ground=0V), unless otherwise specified.) Parameter Symbol Conditions Min. Typ. Max. VCC=1.65V to 1.95V 1.0 11.4 VCC=2.3V to 2.7V 0.5 6.0 nA to nY propagation tpd see Figure 4 VCC=2.7V 1.0 6.0 delay VCC=3.0V to 3.6V 0.5 5.5 VCC=4.5V to 5.5V 0.5 4.6 VCC=1.65V to 1.95V 1.5 12.4 VCC=2.3V to 2.7V 1.0 7.0 — nOE to nY ten see Figure 5 VCC=2.7V 1.5 7.1 enable time VCC=3.0V to 3.6V 0.5 5.9 VCC=4.5V to 5.5V 0.5 4.8 VCC=1.65V to 1.95V 1.0 14.1 V =2.3V to 2.7V 0.5 7.6 — CC nOE to nY tdis see Figure 5 VCC=2.7V 1.0 6.2 disable time VCC=3.0V to 3.6V 1.0 5.9 VCC=4.5V to 5.5V 0.5 4.6 Note: [1] Typical values are measured at nominal VCC and at Tamb=25℃. [2] tpd is the same as tPLH and tPHL. [3] ten is the same as tPZH and tPZL. [4] tdis is the same as tPLZ and tPHZ. Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 8/ 13 VER:2022-03-A4 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74LVC2G125-AX-LJ-B038EN 4、Testing Circuit or e 4.1、AC Testing Circuit Figure 3. Test circuit for measuring switching times i-c Definitions for test circuit: RL=Load resistance. CL=Load capacitance including jig and probe capacitance. RT=Termination resistance; should be equal to the output impedance Zo of the pulse generator. VEXT=External voltage for measuring switching times. 4.2、AC Testing Waveforms Figure 4. The input (nA) to output (nY) propagation delay times Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 9/ 13 VER:2022-03-A4 Wuxi I-CORE Electronics Co., Ltd. rev:B3 Number:AiP74LVC2G125-AX-LJ-B038EN e Tab: 835-12 or Figure 5. 3-state enable and disable times Input Output VM 0.5×VCC 0.5×VCC 1.5V 1.5V 0.5×VCC VM 0.5×VCC 0.5×VCC 1.5V 1.5V 0.5×VCC i-c 4.3、Measurement Points Supply voltage VCC 1.65V to 1.95V 2.3V to 2.7V 2.7V 3.0V to 3.6V 4.5V to 5.5V 4.4、Test Data Supply voltage Input VX VOL+0.15V VOL+0.15V VOL+0.3V VOL+0.3V VOL+0.3V Load VCC VI tr = tf CL RL 1.65V to 1.95V 2.3V to 2.7V 2.7V 3.0V to 3.6V 4.5V to 5.5V VCC VCC 2.7V 2.7V VCC ≤ 2.0ns ≤ 2.0ns ≤ 2.5ns ≤ 2.5ns ≤ 2.5ns 30pF 30pF 50pF 50pF 50pF 1kΩ 500Ω 500Ω 500Ω 500Ω tPLH, tPHL open open open open open Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 VY VOH-0.15V VOH-0.15V VOH-0.3V VOH-0.3V VOH-0.3V VEXT tPZH, tPHZ GND GND GND GND GND tPZL, tPLZ 2×VCC 2×VCC 6V 6V 2×VCC 10/ 13 VER:2022-03-A4 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74LVC2G125-AX-LJ-B038EN 5、Package Information i-c or e 5.1、TSSOP8 Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 11/ 13 VER:2022-03-A4 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74LVC2G125-AX-LJ-B038EN i-c or e 5.2、VSSOP8 Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 12/ 13 VER:2022-03-A4 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74LVC2G125-AX-LJ-B038EN 6、Statements And Notes 6.1、The name and content of Hazardous substances or Elements in the product Hazardous substances or Elements Part name Lead and lead compo unds Mercur y and mercur y compo unds Cadm ium and cadmi um comp ounds Hexaval ent chromiu m compoun ds Polybro minated biphenyl s Polybro minate d biphen yl ethers Dibutyl phthala te Butylbe nzyl phthala te Di-2-et hylhex yl phthala te Diisobu tyl phthala te ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ Plastic resin ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ Chip ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ The lead ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ Plastic sheet installed ○ ○ ○ e Lead frame ○ ○ ○ ○ ○ ○ ○ ○:Indicates that the content of hazardous substances or elements in the detection limit of the following the SJ/T11363-2006 standard. ×:Indicates that the content of hazardous substances or elements exceeding the SJ/T11363-2006 Standard limit requirements. or explanation 6.2、Notion Recommended carefully reading this information before the use of this product; The information in this document are subject to change without notice; i-c This information is using to the reference only, the company is not responsible for any loss; The company is not responsible for the any infringement of the third party patents or other rights of the responsibility. Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 13/ 13 VER:2022-03-A4
AiP74LVC2G125TA8.TR 价格&库存
很抱歉,暂时无法提供与“AiP74LVC2G125TA8.TR”相匹配的价格&库存,您可以联系我们找货
