Wuxi I-CORE Electronics Co., Ltd.
Tab: 835-12
rev:B3
Number:AiP74LVC2G74-AX-LJ-B036EN
e
AiP74LVC2G74
or
Single D-type flip-flop with set and reset;
positive edge trigger
Specification
i-c
Product
Specification Revision History:
Version
Date
2017-05-A1
2017-05
2021-12-A2
2021-12
2022-02-A3
2022-02
2022-03-A4
2022-03
Description
New
Modify ordering information
Modify ambient temperature to -40℃~+105℃ and add electrical
characteristics of -40℃~+105℃
Modify ordering information note 1
Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province
http://www.i-core. cn
P.C.:214072
1/ 15
VER:2022-03-A4
Tab: 835-12
rev:B3
1、General Description
The AiP74LVC2G74 is a single positive-edge triggered D-type flip-flop with individual data (D) inputs,
clock (CP) inputs, set (SD) and reset (RD) inputs, and complementary Q and Q outputs.
This device is fully specified for partial power-down applications using IOFF. The IOFF circuitry disables the
output, preventing damaging backflow current through the device when it is powered down.
The set and reset are asynchronous active LOW inputs and operate independently of the clock input.
Information on the data input is transferred to the Q output on the LOW-to-HIGH transition of the clock
pulse. The D inputs must be stable, one set-up time prior to the LOW-to-HIGH clock transition for
predictable operation.
or
e
Features:
Wide supply voltage range from 1.65V to 5.5V
5 V tolerant outputs for interfacing with 5 V logic
±24mA output drive (VCC=3.0V)
CMOS low power consumption
Latch-up performance exceeds 250mA
Direct interface with TTL levels
Inputs accept voltages up to 5V
Specified from -40℃ to +105℃
Packaging information: TSSOP8/VSSOP8
Ordering Information:
Reel packing specifications:
Packaging
form
Marking
code
Reel
quantity
i-c
Part number
Boxed reel
quantity
AiP74LVC2G74TA8.TR
TSSOP8
ARXX
3000
PCS/reel
3000
PCS/box
AiP74LVC2G74YA8.TR
VSSOP8
ARXX
3000
PCS/reel
3000
PCS/box
Notes
Dimensions of
plastic enclosure:
3.0mm×3.0mm
Pin spacing:
0.65mm
Dimensions of
plastic enclosure:
2.0mm×2.3mm
Pin spacing:0.50mm
Note 1: “XX” refers to variable content, meaning year and package batch serial number.
Note 2: If the physical information is inconsistent with the ordering information, please refer to the actual
product.
P.C.:214072
2/ 15
VER:2022-03-A4
Tab: 835-12
rev:B3
2、Block Diagram And Pin Description
2.1、Block Diagram
or
e
Figure 1. Logic symbol
i-c
Figure 2. IEC logic symbol
Figure 3. Logic diagram
P.C.:214072
3/ 15
VER:2022-03-A4
Tab: 835-12
rev:B3
2.2、Pin Configurations
2.3、Pin Description
Pin Name
CP
D
Description
clock input (LOW-to-HIGH, edge-triggered)
data input
3
Q
4
5
GND
Q
6
RD
7
SD
asynchronous set-direct input (active LOW)
8
VCC
supply voltage
e
Pin No.
1
2
complement output
or
ground (0V)
true output
asynchronous reset-direct input (active LOW)
2.4、Function Table
Function table for asynchronous operation
i-c
Input
SD
RD
CP
Output
D
L
H
X
X
H
L
X
X
L
L
X
X
Note: H=HIGH voltage level; L=LOW voltage level; X=don’t care.
SD
RD
CP
Q
L
H
H
H
L
H
Function table for synchronous operation
Input
Q
Output
D
Qn+1
H
H
L
L
H
H
H
H
Note: H=HIGH voltage level; L=LOW voltage level; ↑=LOW-to-HIGH CP transition;
Qn+1=state after the next LOW-to-HIGH CP transition.
P.C.:214072
Qn+1
H
L
4/ 15
VER:2022-03-A4
Tab: 835-12
rev:B3
3、Electrical Parameter
3.1、Absolute Maximum Ratings
(Voltages are referenced to GND(ground=0V), unless otherwise specified.)
Parameter
supply voltage
input clamping
current
input voltage
output clamping
current
Symbol
VCC
Conditions
Min.
-0.5
Max.
+6.5
Unit
V
IIK
VI < 0V
-50
mA
VI
-0.5
+6.5
V
IOK
VO > VCC or VO < 0V
±50
mA
output voltage
VO
Active mode
Power-down mode; VCC=0V
VO=0V to VCC
-0.5
-0.5
-100
VCC+0.5
+6.5
±50
100
V
V
mA
mA
mA
or
e
output current
IO
supply current
ICC
ground current
IGND
total power
Ptot
300
dissipation
storage
Tstg
-65
+150
temperature
Soldering
TL
10s
250
temperature
Note:
[1] For TSSOP8 package: above 55℃ the value of Ptot derates linearly with 2.5mW/K.
[2] For VSSOP8 package: above 110℃ the value of Ptot derates linearly at 8mW/K.
mW
3.2、Recommended Operating Conditions
Symbol
VCC
VI
Conditions
Active mode
Min.
1.65
Typ.
Max.
5.5
5.5
VCC
5.5
Unit
V
V
V
V
output voltage
VO
Tamb
-40
+105
Δt/ΔV
VCC=1.65V to 2.7V
VCC=2.7V to 5.5V
ns/V
ns/V
i-c
Parameter
supply voltage
input voltage
ambient
temperature
input transition
rise and fall rate
P.C.:214072
5/ 15
VER:2022-03-A4
Tab: 835-12
rev:B3
Unit
V
V
V
V
V
V
V
e
3.3、Electrical Characteristics
3.3.1、DC Characteristics 1
(Tamb=-40℃ to +85℃, voltages are referenced to GND (ground=0V), unless otherwise specified.)
Parameter
Symbol
Conditions
Min. Typ. Max.
0.65×
VCC=1.65V to 1.95V
VCC
VCC=2.3V to 2.7V
1.7
HIGH-level
VIH
input voltage
VCC=2.7V to 3.6V
2.0
0.7×
VCC=4.5V to 5.5V
VCC
0.35×
VCC=1.65V to 1.95V
VCC
V
=2.3V
to
2.7V
0.7
LOW-level
CC
VIL
input voltage
VCC=2.7V to 3.6V
0.8
0.3×
VCC=4.5V to 5.5V
VCC
IO=-100uA;
VCCVCC=1.65V to 5.5V
0.1
IO=-4mA; VCC=1.65V
1.2
1.54
HIGH-level
IO=-8mA; VCC=2.3V
1.9
2.15
VOH
VI = VIH or VIL
output voltage
IO=-12mA; VCC=2.7V
2.2
2.50
IO=-24mA; VCC=3.0V
2.3
2.62
IO=-32mA; VCC=4.5V
3.8
4.11
IO=100uA;
0.10
VCC=1.65V to 5.5V
IO=4mA; VCC=1.65V
0.07
0.45
LOW-level
IO=8mA; VCC=2.3V
0.12
0.30
VOL
VI = VIH or VIL
output voltage
IO=12mA; VCC=2.7V
0.17
0.40
IO=24mA; VCC=3.0V
0.33
0.55
IO=32mA; VCC=4.5V
0.39
0.55
input leakage
VI=5.5V or GND;
II
±0.1
±1
current
VCC=0V to 5.5V
power-off
IOFF
VI or VO=5.5V; VCC=0V
±0.1
±2
leakage current
VI=5.5V or GND; IO=0A;
supply current
ICC
0.1
4
VCC=1.65V to 5.5V
additional
per pin; VI=VCC-0.6V;
ΔICC
5
500
supply current
IO=0A; VCC=2.3V to 5.5V
input
CI
4.0
capacitance
Note: All typical values are measured at Tamb=25℃.
V
V
i-c
or
V
V
V
V
V
P.C.:214072
V
V
V
V
V
V
uA
uA
uA
uA
pF
6/ 15
VER:2022-03-A4
Tab: 835-12
rev:B3
Unit
V
V
V
V
V
V
V
V
e
3.3.2、DC Characteristics 2
(Tamb=-40℃ to +105℃, voltages are referenced to GND (ground=0V), unless otherwise specified.)
Parameter
Symbol
Conditions
Min. Typ. Max.
0.65×
VCC=1.65V to 1.95V
VCC
VCC=2.3V to 2.7V
1.7
HIGH-level
VIH
input voltage
VCC=2.7V to 3.6V
2.0
0.7×
VCC=4.5V to 5.5V
VCC
0.35×
VCC=1.65V to 1.95V
VCC
VCC=2.3V to 2.7V
0.7
LOW-level
VIL
input voltage
VCC=2.7V to 3.6V
0.8
0.3×
VCC=4.5V to 5.5V
VCC
IO=-100uA;
0.1
IO=-4mA; VCC=1.65V
0.95
HIGH-level
IO=-8mA; VCC=2.3V
1.7
VOH
VI = VIH or VIL
output voltage
IO=-12mA; VCC=2.7V
1.9
IO=-24mA; VCC=3.0V
2.0
IO=-32mA; VCC=4.5V
3.4
IO=100uA;
0.10
VCC=1.65V to 5.5V
IO=4mA; VCC=1.65V
0.70
LOW-level
IO=8mA; VCC=2.3V
0.45
VOL
VI = VIH or VIL
output voltage
IO=12mA; VCC=2.7V
0.60
IO=24mA; VCC=3.0V
0.80
IO=32mA; VCC=4.5V
0.80
input leakage
VI=5.5V or GND;
II
±1
current
VCC=0V to 5.5V
power-off
IOFF
±2
leakage current
supply current
ICC
4
VCC=1.65V to 5.5V
additional
ΔICC
500
supply current
V
i-c
or
V
V
V
V
V
P.C.:214072
V
V
V
V
V
V
uA
uA
uA
uA
7/ 15
VER:2022-03-A4
Tab: 835-12
rev:B3
3.3.3、AC Characteristics 1
Parameter
Symbol
CP to Q, Q;
see Figure 5
tpd
SD to Q, Q;
see Figure 6
Min.
1.5
1.0
1.0
1.0
1.0
1.5
1.0
1.0
1.0
1.0
1.5
1.0
1.0
1.0
1.0
6.2
2.7
2.7
2.7
2.0
6.2
2.7
2.7
2.7
2.0
1.9
1.4
1.3
+1.2
1.0
2.9
1.7
1.7
1.3
1.1
1.5
1.0
1.0
1.0
1.0
80
175
Typ.
6.0
3.5
3.5
3.5
2.5
6.0
3.5
3.5
3.0
2.5
5.0
3.5
3.5
3.0
2.5
1.3
1.6
-3.0
0.5
0.6
or
RD to Q, Q;
see Figure 6
CP HIGH or
LOW;
see Figure 5
pulse width
tW
i-c
SD and RD
LOW;
see Figure 6
Max.
13.4
7.1
7.1
5.9
4.1
12.9
7.0
7.0
5.9
4.1
12.9
7.0
7.0
5.9
4.1
Unit
ns
ns
ns
ns
ns
ns
ns
ns
ns
ns
ns
ns
ns
ns
ns
ns
ns
ns
ns
ns
ns
ns
ns
ns
ns
ns
ns
ns
ns
ns
ns
ns
ns
ns
ns
ns
ns
ns
ns
ns
MHz
MHz
e
propagation
delay
Conditions
VCC=1.65V to 1.95V
VCC=2.3V to 2.7V
VCC=2.7V
VCC=3.0V to 3.6V
VCC=4.5V to 5.5V
VCC=1.65V to 1.95V
VCC=2.3V to 2.7V
VCC=2.7V
VCC=3.0V to 3.6V
VCC=4.5V to 5.5V
VCC=1.65V to 1.95V
VCC=2.3V to 2.7V
VCC=2.7V
VCC=3.0V to 3.6V
VCC=4.5V to 5.5V
VCC=1.65V to 1.95V
VCC=2.3V to 2.7V
VCC=2.7V
VCC=3.0V to 3.6V
VCC=4.5V to 5.5V
VCC=1.65V to 1.95V
VCC=2.3V to 2.7V
VCC=2.7V
VCC=3.0V to 3.6V
VCC=4.5V to 5.5V
VCC=1.65V to 1.95V
VCC=2.3V to 2.7V
VCC=2.7V
VCC=3.0V to 3.6V
VCC=4.5V to 5.5V
VCC=1.65V to 1.95V
VCC=2.3V to 2.7V
VCC=2.7V
VCC=3.0V to 3.6V
VCC=4.5V to 5.5V
VCC=1.65V to 1.95V
VCC=2.3V to 2.7V
VCC=2.7V
VCC=3.0V to 3.6V
VCC=4.5V to 5.5V
VCC=1.65V to 1.95V
VCC=2.3V to 2.7V
recovery time
trec
SD or RD;
see Figure 6
set-up time
tsu
D to CP;
see Figure 5
hold time
th
D to CP;
see Figure 5
maximum
frequency
fmax
CP;
see Figure 5
P.C.:214072
8/ 15
VER:2022-03-A4
Tab: 835-12
rev:B3
VCC=2.7V
VCC=3.0V to 3.6V
VCC=4.5V to 5.5V
175
175
200
280
pF
or
e
Power
dissipation
CPD
VCC=3.3V; VI=GND to VCC
15
capacitance
Note:
[1] Typical values are measured at Tamb=25℃ and VCC=1.8V, 2.5V, 2.7V, 3.3V and 5.0V respectively.
[2] tpd is the same as tPLH and tPHL.
[3] CPD is used to determine the dynamic power dissipation (PD in uW).
PD=(CPD×VCC2×fi×N)+∑(CL×VCC2×fo) where:
fi=input frequency in MHz;
fo=output frequency in MHz;
CL=output load capacitance in pF;
VCC=supply voltage in V;
N=number of inputs switching;
∑(CL×VCC2×fo)=sum of outputs.
MHz
MHz
MHz
3.3.4、AC Characteristics 2
Parameter
Symbol
i-c
CP to Q, Q;
see Figure 5
Conditions
VCC=1.65V to 1.95V
VCC=2.3V to 2.7V
VCC=2.7V
VCC=3.0V to 3.6V
VCC=4.5V to 5.5V
VCC=1.65V to 1.95V
VCC=2.3V to 2.7V
VCC=2.7V
VCC=3.0V to 3.6V
VCC=4.5V to 5.5V
VCC=1.65V to 1.95V
VCC=2.3V to 2.7V
VCC=2.7V
VCC=3.0V to 3.6V
VCC=4.5V to 5.5V
VCC=1.65V to 1.95V
VCC=2.3V to 2.7V
VCC=2.7V
VCC=3.0V to 3.6V
VCC=4.5V to 5.5V
VCC=1.65V to 1.95V
VCC=2.3V to 2.7V
VCC=2.7V
VCC=3.0V to 3.6V
propagation
delay
tpd
SD to Q, Q;
see Figure 6
RD to Q, Q;
see Figure 6
CP HIGH or
LOW;
see Figure 5
pulse width
tW
SD and RD
LOW;
see Figure 6
P.C.:214072
Min.
1.5
1.0
1.0
1.0
1.0
1.5
1.0
1.0
1.0
1.0
1.5
1.0
1.0
1.0
1.0
6.2
2.7
2.7
2.7
2.0
6.2
2.7
2.7
2.7
Typ.
Max.
13.4
7.1
7.1
5.9
4.1
12.9
7.0
7.0
5.9
4.1
12.9
7.0
7.0
5.9
4.1
Unit
ns
ns
ns
ns
ns
ns
ns
ns
ns
ns
ns
ns
ns
ns
ns
ns
ns
ns
ns
ns
ns
ns
ns
ns
9/ 15
VER:2022-03-A4
Tab: 835-12
rev:B3
trec
SD or RD;
see Figure 6
set-up time
tsu
D to CP;
see Figure 5
hold time
th
D to CP;
see Figure 5
maximum
frequency
fmax
VCC=4.5V to 5.5V
VCC=1.65V to 1.95V
VCC=2.3V to 2.7V
VCC=2.7V
VCC=3.0V to 3.6V
VCC=4.5V to 5.5V
VCC=1.65V to 1.95V
VCC=2.3V to 2.7V
VCC=2.7V
VCC=3.0V to 3.6V
VCC=4.5V to 5.5V
VCC=1.65V to 1.95V
VCC=2.3V to 2.7V
VCC=2.7V
VCC=3.0V to 3.6V
VCC=4.5V to 5.5V
VCC=1.65V to 1.95V
VCC=2.3V to 2.7V
VCC=2.7V
VCC=3.0V to 3.6V
VCC=4.5V to 5.5V
2.0
1.9
1.4
1.3
+1.2
1.0
2.9
1.7
1.7
1.3
1.1
1.5
1.0
1.0
1.0
1.0
80
175
175
175
200
ns
ns
ns
ns
ns
ns
ns
ns
ns
ns
ns
ns
ns
ns
ns
ns
MHz
MHz
MHz
MHz
MHz
e
recovery time
or
CP;
see Figure 5
Note:
4、Testing Circuit
i-c
4.1、AC Testing Circuit
Figure 4. Test circuit for measuring switching times
Definitions for test circuit:
RL=Load resistance.
CL=Load capacitance including jig and probe capacitance.
RT=Termination resistance; should be equal to the output impedance Zo of the pulse generator.
VEXT=External voltage for measuring switching times.
P.C.:214072
10/ 15
VER:2022-03-A4
Tab: 835-12
rev:B3
or
e
4.2、AC Testing Waveforms
Figure 5. The clock input (CP) to output (Q, Q) propagation delays, the clock pulse width, the D to CP
i-c
set-up, the CP to D hold times and the maximum frequency
Figure 6. The set (SD) and reset (RD) input to output (Q, Q) propagation delays, the set and reset pulse
widths and the RD to CP recovery time
P.C.:214072
11/ 15
VER:2022-03-A4
Tab: 835-12
rev:B3
4.3、Measurement Points
Supply voltage
VCC
1.65V to 1.95V
2.3V to 2.7V
2.7V
3.0V to 3.6V
4.5V to 5.5V
4.4、Test Data
Supply voltage
Input
Output
VM
0.5×VCC
0.5×VCC
1.5V
1.5V
0.5×VCC
VM
0.5×VCC
0.5×VCC
1.5V
1.5V
0.5×VCC
Input
Load
VI
tr = tf
1.65V to 1.95V
2.3V to 2.7V
2.7V
3.0V to 3.6V
4.5V to 5.5V
VCC
VCC
2.7V
2.7V
VCC
≤ 2.0ns
≤ 2.0ns
≤ 2.5ns
≤ 2.5ns
≤ 2.5ns
CL
RL
tPLH,
tPHL
open
open
open
open
open
tPZL,
tPLZ
2×VCC
2×VCC
6V
6V
2×VCC
e
VCC
VEXT
tPZH,
tPHZ
GND
GND
GND
GND
GND
1kΩ
500Ω
500Ω
500Ω
500Ω
i-c
or
30pF
30pF
50pF
50pF
50pF
P.C.:214072
12/ 15
VER:2022-03-A4
Tab: 835-12
rev:B3
5、Package Information
i-c
or
e
5.1、TSSOP8
P.C.:214072
13/ 15
VER:2022-03-A4
Tab: 835-12
rev:B3
i-c
or
e
5.2、VSSOP8
P.C.:214072
14/ 15
VER:2022-03-A4
Tab: 835-12
rev:B3
6、Statements And Notes
6.1、The name and content of Hazardous substances or Elements in the product
Part name
Lead
and
lead
compo
unds
Mercur
y and
mercur
y
compo
unds
Cadm
ium
and
cadmi
um
comp
ounds
Hexaval
ent
chromiu
m
compoun
ds
Polybro
minated
biphenyl
s
Polybro
minate
d
biphen
yl
ethers
Dibutyl
phthala
te
Butylbe
nzyl
phthala
te
Di-2-et
hylhex
yl
phthala
te
Diisobu
tyl
phthala
te
Plastic resin
Chip
The lead
Plastic sheet
installed
e
Lead frame
○:Indicates that the content of hazardous substances or elements in the detection limit
of
the following the SJ/T11363-2006 standard.
×:Indicates that the content of hazardous substances or elements exceeding the SJ/T11363-2006
Standard limit requirements.
or
explanation
6.2、Notion
Recommended carefully reading this information before the use of this product;
The information in this document are subject to change without notice;
i-c
This information is using to the reference only, the company is not responsible for any loss;
The company is not responsible for the any infringement of the third party patents or other rights of
the responsibility.
P.C.:214072
15/ 15
VER:2022-03-A4
