BC848C
BC848C
    MDD(辰达半导体)
    SOT23-3
    晶体管 - 双极 (BJT) - 单 NPN 30 V 100 mA 100MHz 200 mW 表面贴装型 SOT-23
BC848C 数据手册
PART CODE: SOT23BC848CS1L SPECIFICATION SHEET SPECIFICATION SHEET NO. P0610- SOT23BC848CS1L DATE June 10, 2022 REVISION A0 DESCRIPITION SMD Plastic-Encapsulate Transistors, SOT-23 series, 3 pads BC848C Type, NPN, Collector-Emitter Voltage 30V. Collector Current 100mA Max. Operating Temp. Range -65°C ~+150°C, Package in Tape/Reel, 3000pcs/Reel RoHS/RoHS III compliant CUSTOMER CUSTOMER PART NUMBER CROSS REF. PART NUMBER ORIGINAL PART NUMBER MDD BC848C PART CODE SOT23BC848CS1L VENDOR APPROVE Issued/Checked/Approved DATE: June 10, 2022 CUSTOMER APPROVE DATE: 6/13/2022 NextGen Components, Inc. 1 sales@NextGenComponent.com www.NextGenComponent.com PART CODE: SOT23BC848CS1L SMD PLASTIC-ENCCAPULATE TRANSISTORS SOT23 SERIES MAIN FEATURE • Ideally suited for automatic insertion APPLICATION • For Switching and AF Amplifier Applications RFQ Request For Quotation PART CODE GUIDE SOT23 BC848C S 1L 1 2 3 4 1) SOT23: SMD Plastic-Encapsulate Transistors, 3 pads SOT-23 series Code 2) BC848C: Type code for BC848C Type 3) S: Package code, Package in Tape/Reel, 3000pcs/Reel 4) 1L: Marking code for “1L” on the case surface, Different Marking for different specification MORE ITEMS LIST SOT23BC846AS1A SOT23BC846BS1B SOT23BC847AS1E SOT23BC847BS1F SOT23BC847CS1G SOT23BC848AS1J SOT23BC848BS1K SOT23BC848CS1L 2 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: SOT23BC848CS1L SMD PLASTIC-ENCCAPULATE TRANSISTORS SOT23 SERIES DIMENSION (Unit: Inch/mm) Image for reference Marking: 1L Symbol Value ( mm) Min. A Typ. 1.00 1.40 A1 SOT-23 Max. 0.10 b 0.35 0.50 c 0.10 0.20 D 2.70 E 1.40 1.60 E1 2.40 2.80 e 2.90 3.10 1.90 L 0.10 L1 0.40 Ɵ 0° 0.30 10° Recommend Pad Layout 1.Base 2.Emitter 3.Collector NextGen Components, Inc. sales@NextGenComponent.com 3 www.NextGenComponent.com PART CODE: SOT23BC848CS1L SMD PLASTIC-ENCCAPULATE TRANSISTORS SOT23 SERIES MECHANICAL DATA Case Terminals Polarity Mounting Position Weight per piece JEDEC SOT-23 molded plastic body Solder plated, Solderable per MIL-STD-750, Method 2026 Polarity symbol marking on case Any 0.00019 Ounce, 0.00591 grams MAX. RATINGS AT Ta=25 °C Parameter SYMBOLS VALUE UNITS LIMIT Collector-base Voltage V CBO 30 Volts Collector-emitter Voltage V CEO 30 Volts Emitter-base Voltage V EBO 6 Volts Collector Current - Continuous IC 0.10 A Collector Power Dissipation PC 200 mW Junction Temperature TJ +150 °C T STG -65 ~ +150 °C Storage Temperature Range 4 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com SOT23BC848CS1L PART CODE: SMD PLASTIC-ENCCAPULATE TRANSISTORS SOT23 SERIES ELECTRICAL CHARACTERISTICS AT Ta= 25 °C Parameter SYMBOLS VALUE Min. Typ. UNIT Condition Max. Collector-base Breakdown Voltage V CBO 30 V Ic= 10 μA, IE=0 Collector-emitter Breakdown Voltage V CEO 30 V I c= 10mA, IB=0 Emitter-base Breakdown Voltage V EBO 6 V I E= 10 μA, IC=0 Collector Cut-off Current I CBO 0.1 µA VCB=30V, IE=0 Collector Cut-off Current I CEO 0.1 µA VCB=30V, I B=0 Emitter Cut-off Current I EBO 0.1 µA VEB= 5V, IC=0 DC Current Gain h FE 420 800 VCE=5V, I C=2 mA Collector-emitter Saturation Voltage V CE(sat) 0.5 V I C=100mA, I B=5 mA Base-emitter Saturation Voltage V BE(sat) 1.1 V I C=100mA, I B=5 mA MHz V CE=5 V, I C=10mA f= 100 MHz pF VCB=10 V, f=1 MHz Transition Frequency Collector Output Capacitance fT 100 C ob 4.5 5 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: SOT23BC848CS1L SMD PLASTIC-ENCCAPULATE TRANSISTORS SOT23 SERIES RELIABILITY Number Experiment Items Experiment Method And Conditions Reference Documents 1 Solder Resistance Test Test 260°C± 5°C for 10 ± 2 sec. Immerse body into solder 1/16” ± 1/32" MIL-STD-750D METHOD-2031.2 2 Solderability Test 230°C ±5°C for 5 sec. MIL-STD-750D METHOD-2026.1 0 3 Pull Test 1 kg in axial lead direction for 10 sec. MIL-STD-750D METHOD-2036.4 4 Bend Test 0.5Kg Weight Applied To Each Lead, Bending Arcs 90 °C ± 5 °C For 3 Times MIL-STD-750D METHOD-2036.4 5 High Temperature Reverse Bias Test TA=100°C for 1000 Hours at VR=80% Rated VR MIL-STD-750D METHOD-1038.4 6 Forward Operation Life Test TA=25°C Rated Average Rectified Current MIL-STD-750D METHOD-1027.3 7 Intermittent Operation Life Test On state: 5 min with rated IRMS Power Off state: 5 min with Cool Forced Air. On and off for 1000 cycles. MIL-STD-750D METHOD-1036.3 8 Pressure Cooker Test 15 PSIG, TA=121°C, 4 hours MIL-S-19500 APPENOIXC 9 Temperature Cycling Test -55°C~+125°C; 30 Minutes For Dwelled Time 5 minutes for transferred time. Total: 10 cycles. MIL-STD-750D METHOD-1051.7 10 Thermal Shock Test 0°C for 5 minutes., 100°C for 5minutes, Total: 10 cycles MIL-STD-750D METHOD-1056.7 11 Forward Surge Test 8.3ms Single Sale Sine-wave One Surge. MIL-STD-750D METHOD-4066.4 12 Humidity Test TA=65°C, RH=98% for 1000 hours. MIL-STD-750D METHOD-1021.3 13 High Temperature Storage life Test 150°C for 1000 Hours MIL-STD-750D METHOD-1031.5 6 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: SOT23BC848CS1L SMD PLASTIC-ENCCAPULATE TRANSISTORS SOT23 SERIES SUGGESTED REFLOW PROFILE (For Reference Only) • Recommended peak temperature is over 245℃, If peak temperature is below 245 ℃, you may adjust the following parameters; time length of peak temperature (longer), time length of soldering (longer), thickness of solder paste (thicker) • Welding shall not exceed 2 times • Remark: lead free solder paste (96.5 sn/3.0 Ag/0.5Cu) 7 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: SOT23BC848CS1L SMD PLASTIC-ENCCAPULATE TRANSISTORS SOT23 SERIES RATINGS AND CHARACTERISTIC CURVES (For Reference Only) 8 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: SOT23BC848CS1L SMD PLASTIC-ENCCAPULATE TRANSISTORS SOT23 SERIES RATINGS AND CHARACTERISTIC CURVES (For Reference Only) 9 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: SOT23BC848CS1L SMD PLASTIC-ENCCAPULATE TRANSISTORS SOT23 SERIES TAPE/REEL (Unit: mm) All Devices are packed in accordance with EIA standard RS-481-A and specifications. Item Symbol Tolerance SOT-23 Carrier width A 0.1 3.15 Carrier Length B 0.1 2.77 Carrier Depth C 0.1 1.22 Sprocket hole d 0.05 1.55 7”Reel outside diameter D 2.0 178.00 7”Reel inner diameter D1 Min. 54.4 Feed hole diameter D2 0.5 13.00 Sprocket hole position E 0.1 1.75 Punch hole position F 0.1 3.50 Punch hole pitch P 0.1 4.00 Sprocket hole pitch P0 0.1 4.00 Embossment center P1 0.1 2.00 Overall tape thickness T 0.1 0.25 Tape width W 0.3 8.00 Reel width W1 1.0 19.50 10 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: SOT23BC848CS1L SMD PLASTIC-ENCCAPULATE TRANSISTORS SOT23 SERIES PACKAGE Case Code SOT-23 Reel Size 7” Reel Size 178 mm MPQ/Reel 3000 pcs Qty. /Box 6000 pcs G.W/Box 1 LBS DISCLAIMER NextGen Component, Inc. reserves the right to make changes to the product(s) and or information contained herein without notice. No liability is assumed as a result of their use or application. No rights under any patent accompany the sale of any such product(s) or information 11 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com
BC848C 价格&库存
很抱歉,暂时无法提供与“BC848C”相匹配的价格&库存,您可以联系我们找货
