V12
CFM41S SERIES
40 WATT SINGLE OUTPUT
AC-DC OPEN FRAME
Features
* Universal Input 90~264VAC
* EN55032 Class B and CISPR/FCC Class B
* IEC/EN/UL62368-1
* Meets IEC/EN60335-1
* Continuous Short Circuit Protection
* Over Voltage Protection
* No Load Power Consumption < 0.15W
* Peak Load (2 times of rated current)
* Class II
Ordering information
CFM41SXXX-
X
Blank: PCB mount
E: Encapsulated
T: WAFER
MODEL
Output
Voltage
Output
Current
PEAK
Current
NOTE6
Ripple
(mV p-p)
NOTE1
Voltage
Accuracy
N O TE 2
Line
Regulation
N O TE 3
Load
Regulation
N O TE 4
% EFF.
(typ.)
N O TE 5
CFM41S050
5V
6A
12 A
100mV
±2%
±0.5%
±1%
87%
CFM41S120
12 V
3.34 A
6.66 A
120mV
±1%
±0.5%
±1%
90%
CFM41S150
15 V
2.67 A
5.34 A
150mV
±1%
±0.5%
±1%
90%
CFM41S240
24 V
1.67 A
3.34 A
240mV
±1%
±0.5%
±1%
90%
CFM41S360
36 V
1.11 A
2.22 A
360mV
±1%
±0.5%
±1%
90%
CFM41S480
48 V
0.83 A
1.66 A
480mV
±1%
±0.5%
±1%
90%
Typical at 25˚C, nominal line and 75% load, unless otherwise Specified
1
V12
Specifications
CFM41S Series De-rating Curve
INPUT SPECIFICATIONS:
CFM41SXXX、CFM41SXXX-E
Voltage .....…….…...………………….…..……………………… 90~264Vac
120~370Vdc
Frequency ………………………………………….……………..... 47 to 63Hz
Inrush Current ……..…………...…. 70A max. @240Vac, Cold Start @25℃
Leakage Current ……………………….………….. 0.25mA max. @ 264Vac
Input Current ………..……………… 100Vac/1A max., 240Vac/0.55A max.
OUTPUT SPECIFICATIONS:
Holdup Time ………………………..…………………… 10ms typ. @115Vac
Short Circuit Protection ………………..…… Hiccup Mode (Auto Recovery)
CFM41SXXX-T
Temperature Coefficient .…………………….............................… ±0.05%/℃
Over Voltage Protection ……….……………..… TVS Component to Clamp
Startup time ……………………….…….….. 115Vac
很抱歉,暂时无法提供与“CFM41S050”相匹配的价格&库存,您可以联系我们找货
