Product information
79 12 125 ESD
Precision Electronics Side Cutter ESD
DIN ISO 9654 DIN EN 61 340-5
● electrically discharging handles - dissipative
● the assortment for highest standard of performance and results
● precision pliers for ultra fine cutting work, e. g. in electronics and fine
mechanics
● very precisely ground and sharp cutting edges with very small bevels
for exact cutting on delicate electronic components; also available
without bevel for flush cutting
● cutting edges additionally induction hardened, cutting edge hardness
approx. 64 HRC
● bolted joint: precise, zero backlash operation of pliers
● precisely finished joint surfaces for smooth, low friction movement
along the complete opening range
● low-friction double spring for gentle and even opening
● non-reflective finish
● low weight
● ergonomically shaped, two-colour dual component ESD handles,
black/grey
● specially for cutting through hard wire and piano wire
● Ball bearing chrome steel, forged, multi stage oil-hardened
Allgemein
Article No.
79 12 125 ESD
EAN
4003773071389
Pliers
burnished
Head
polished
Handles
with multi-component grips
weight
61 g
Dimensions
125 x 60 x 20 mm
Technische Attribute
Ø 1.3
Cutting capacities soft wire (diameter)
Ø 0.3 – 1.7 mm
10 mm
6.5 mm
Head width
11 mm
ESD
yes
Klassifikation
eCl@ss 5.1.4
21040302
ETIM 5.0
EC000165
ETIM 6.0
EC000165
proficl@ss 6.0
AAA949c004
technical change and errors excepted
KNIPEX Werk - C. Gustav Putsch KG - 42337 Wuppertal
26.03.2019 | page 1 1
很抱歉,暂时无法提供与“79 12 125 ESD”相匹配的价格&库存,您可以联系我们找货
