XBLW L293D-L293WS
PUSH-PULL FOUR CHANNEL DRIVER WITH DIODES
General Description
The Device is a monolithic integrated high volt-age, high
current four channel driver designed to accept standard DTL or
TTL logic levels and drive inductive loads (such as relays
solenoides, DC and stepping motors) and switching power transistors.
To simplify use as two bridges each pair of chan- nels is
equipped with an enable input. A separate supply input is
provided for the logic, allowing op- eration at a lower voltage
and internal clamp di- odes are included.
This device is suitable for use in switching appli- cations at
frequencies up to 5 kHz.
The L293D is assembled in a 16 lead plastic packaage which has 4 center pins connected to- gether and used for
heatsinking The L293WS is assembled in a 20 lead surface mount which has 8 center pins connected to- gether and
used for heatsinking.
Features
600mA OUTPUT CURRENT CAPABILITY PER CHANNEL
1.2A PEAK OUTPUT CURRENT (non repetitive) PER CHANNEL
ENABLE FACILITY
OVERTEMPERATURE PROTECTION
LOGICAL "0" INPUT VOLTAGE UP TO 1.5 V (HIGH NOISE IMMUNITY)
INTERNAL CLAMP DIODES
ORDERING INFORMATION
DEVICE
Package Type
MARKING
Packing
Packing QTY
L293D
L293WS
DIP-16
SOP-20
L293D
L293WS
Tube
Tape
1000/Box
1000/Reel
XBLW version 1.0
文档仅供参考,实际应用测试为准
www.xinboleic.com 技术支持热线:4009682003
第1页共8页
XBLW L293D-L293WS
Block Diagram
ABSOLUTE MAXIMUM RATINGS
Symbol
VS
VSS
Vi
Ven
Io
Ptot
Tstg,Tj
Parameter
Supply Voltage
Logic Supply Voltage
Input Voltage
Enable Voltage
Peak Output Current (100 μs non repetitive)
Total Power Dissipation at Tpins = 90℃
Storage and Junction Temperature
XBLW version 1.0
文档仅供参考,实际应用测试为准
Value
Unit
36
36
7
7
1.2
4
-40 to 150
V
V
V
V
A
W
第2页共8页
XBLW L293D-L293WS
PIN CONNECTIONS(Top view)
Thermal Data
Symbol
Decription
Rthj-pins
Thermal Resistance Junction-pins
Rthj-amb
Thermal Resistance junction-ambient
Rth j-case
Thermal Resistance Junction-case
(*) With 6sq. cm on board heatsink.
XBLW version 1.0
max.
max.
max.
文档仅供参考,实际应用测试为准
DIP
SO
Unit
80
14
14
50(*)
℃/W
℃/W
第3页共8页
XBLW L293D-L293WS
Electrical Characteristics
(for each channel,VS=24V,VSS=5V,Tamb=25℃,unless otherwise specified)
Symbol
Parameter
Test Conditions
VS
Supply Voltage (pin 10)
VSS
Logic Supply Voltage (pin 20)
Vi=L;lO=0;Ven=H
Total Quiescent Supply Current
IS
Vi=H;lO=0;Ven =H
(pin 10)
Ven = L
Vi=L;lO=0;Ven=H
Total Quiescent Logic Supply
Vi=H;lO =0;Ven=H
ISS
Current (pin 20)
Ven = L
VIL
Input Low Voltage (pin 2,9,12,19)
VSS≤7 V
Input High Voltage (pin 2, 9,12, 19)
VIH
VSS>7V
Low Voltage Input Current (pin
IIL
2,9,12,19)
VIL= 1.5V
High Voltage Input Current (pin
IIH
2.3V≤VIH≤Vss-0.6V
2.9,12,19)
VenL
Enable Low Voltage (pin 1,11)
VSS≤7 V
Enable High Voltage (pin 1,11)
VenH
VSS>7V
Low Voltage Enable Current
IenL
Ven L= 1.5V
(pin 1,11)
High Voltage Enable Current
IenH
2.3V≤Ven H≤VSS-0.6 V
(pin 1,11)
Source Output Saturation
VCE(sat)H
IO =-0.6 A
Voltage (pins 3, 8,13,18)
Sink Output Saturation Voltage
VCE(sat)L
IO =+0.6 A
(pins 3, 8,13, 18)
VF
Clamp Diode Forward Voltage
IO = 600nA
tr
Rise Time(*)
0.1 to 0.9 VO
tf
Fall Time(*)
0.9 to 0.1 VO
ton
Turn-on Delay(*)
0.5 Vi to 0.5 VO
toff
Turn-off Delay(*)
0.5 Vi to 0.5 VO
(*) See fig. 1.
Min.
Vss
4.5
Typ.
Max.
36
36
6
24
4
60
22
24
1.5
VSS
7
Unit
V
V
mA
mA
mA
mA
mA
mA
V
V
V
-10
μA
100
μA
1.5
VSS
7
V
V
V
-100
μA
±10
μA
1.4
1.8
V
1.2
1.8
V
2
16
44
16
16
-0.3
2.3
2.3
30
-0.3
2.3
2.3
-30
1.3
250
250
750
200
V
ns
ns
ns
ns
Truth Table(one channel)
Input
H
L
H
L
XBLW version 1.0
Enable(*)
H
H
L
L
Output
H
L
Z
Z
文档仅供参考,实际应用测试为准
第4页共8页
XBLW L293D-L293WS
Figure 1: Switching Times
Figure 2: Junction to ambient thermal resistance vs. area on board heatsink (SO12+4+4 package)
XBLW version 1.0
文档仅供参考,实际应用测试为准
第5页共8页
XBLW L293D-L293WS
Package Information
Powerdip 16
DIM.
a1
B
b
b1
D
E
e
e3
F
I
L
Z
XBLW version 1.0
MIN.
mm
TYP.
0.51
0.85
MAX.
MIN.
1.40
0.020
0.033
0.50
0.38
inch
TYP.
MAX.
0.055
0.020
0.50
20.0
0.015
8.80
2.54
17.78
0.020
0.787
0.346
0.100
0.700
7.10
5.10
3.30
0.280
0.201
0.130
1.27
文档仅供参考,实际应用测试为准
0.050
第6页共8页
XBLW L293D-L293WS
SO20
DIM.
A
A1
B
C
D
E
e
H
h
L
K
XBLW version 1.0
MIN.
mm
TYP.
2.35
0.1
0.33
0.23
12.6
7.4
MAX.
MIN.
2.65
0.3
0.51
0.32
13
7.6
0.093
0.004
0.013
0.009
0.496
0.291
1.27
10
0.25
0.4
inch
TYP.
MAX.
0.104
0.012
0.020
0.013
0.512
0.299
0.050
10.65
0.394
0.75
0.010
1.27
0.016
0°(min.)8°(max.)
文档仅供参考,实际应用测试为准
0.419
0.030
0.050
第7页共8页
XBLW L293D-L293WS
Statement:
Shenzhen xinbole electronics co., ltd. reserves the right to change the product specifications, without notice!
Before placing an order, the customer needs to confirm whether the information obtained is the latest version,
and verify the integrity of the relevant information.
Any semiconductor product is liable to fail or malfunction under certain conditions, and the buyer shall be
responsible for complying with safety standards in the system design and whole machine manufacturing using
Shenzhen xinbole electronics co., ltd products, and take appropriate security measures to avoid the potential risk
of failure may result in personal injury or property losses of the situation occurred!
Product performance is never ending, Shenzhen xinbole electronics co., ltd will be dedicated to provide
customers with better performance, better quality of integrated circuit products.
XBLW version 1.0
文档仅供参考,实际应用测试为准
第8页共8页
很抱歉,暂时无法提供与“L293WS”相匹配的价格&库存,您可以联系我们找货
