SN74HC47N
SN74HC47N
    XBLW(芯伯乐)
    DIP16
    BCD转7段共阳极LED驱动电路,工作电压2-6V,静态电流13mA
SN74HC47N 数据手册
XBLW SN74HC/HCT47 BCD-to-Seven-Segment Common anode LED Decodes/Drivers General Description The SN74HC/HCT47 feature active-low outputs designed for driving common-anode LEDs or incandescent indicators directly. Display patterns for BCD input counts above 9 are unique symbols to authenticate input conditions. Features  Supply voltage range: SN74HC47: 2V to 6V SN74HCT47: 4.5V to 5.5V  Input levels: SN74HC47: CMOS level SN74HCT47: TTL level  Temperature range:-40℃ to +125℃  Packaging information: DIP16/SOP16/TSSOP16 Ordering Information Product Model XBLW SN74HC47N XBLW SN74HC47DTR XBLW SN74HC47TDTR XBLW SN74HCT47N XBLW SN74HCT47DTR XBLW SN74HCT47TDTR Package Type DIP-16 SOP-16 TSSOP-16 DIP-16 SOP-16 TSSOP-16 Marking 74HC47N 74HC47 74HC47 74HCT47N 74HCT47 74HCT47 Packing Tube Tape Tape Tube Tape Tape Packing Qty 1000Pcs/Box 2500Pcs/Reel 3000Pcs/Reel 1000Pcs/Box 2500Pcs/Reel 3000Pcs/Reel Block Diagram And Pin Description Block Diagram Pin Configurations XBLWversion1.0 www.xinboleic.com Technical Support:4009682003 1 / 12 XBLW SN74HC/HCT47 BCD-to-Seven-Segment Common anode LED Decodes/Drivers Pin Description Pin No. 1 Pin Name Description B data input 2 C data input 3 4 lamp test LT — — BI/RBO blanking input/ripple blanking output — 5 RBI ripple blanking input 6 D data input 7 A data input 8 GND ground (0V) 9 e data output 10 d data output 11 c data output 12 b data output 13 data output 14 a g 15 f data output VCC supply voltage 16 XBLWversion1.0 data output www.xinboleic.com Technical Support:4009682003 2 / 12 XBLW SN74HC/HCT47 BCD-to-Seven-Segment Common anode LED Decodes/Drivers Function Table Decimal or function LT 0 1 Input — RBI D C B A H H L L L L H X L L L H 2 H X L L H Output — BI/RBO a b c d e f g H on on on on on on off H off on on off off off off L H on on off on on off on on on on off off on 3 H X L L H H H on 4 H X L H L L H off on on off off on on 5 H X L H L H H on off on on off on on 6 H X L H H L H off off on on on on on 7 H X L H H H H on on on off off off off 8 H X H L L L H on on on on on on on off on on 9 H X H L L H H on on on off 10 H X H L H L H off off off on on off on 11 H X H L H H H off off on on off off on 12 H X H H L L H off on off off off on on 13 H X H H L H H on off off on off on on 14 H X H H H L H off off off on on on on 15 H X H H H H H off off off off off off off BI X X X X X X L off off off off off off off RBI H L L L L L L off off off off off off off LT L X X X X X H on on on on on on on Note: [1] H=HIGH voltage level; L=LOW voltage level; X=don’t care. — [2] The blanking input (BI) must be open or held at a high logic level when output functions 0 through 15 — are desired. The ripple-blanking input (RBI) must be open or high if blanking of a decimal zero is not desired. — [3] When a low logic level is applied directly to the blanking input (BI), all segment outputs are off regardless of the level of any other input. — [4] When ripple-blanking input (RBI) and inputs A, B, C, D are at a low level with the lamp test input high, — all segment outputs go off and the ripple-blanking output (RBO) goes to a low level (response condition). — — [5] When the blanking input/ripple blanking output (BI/RBO) is open or held high and a low is applied to the lamp test input, all segment outputs are on. Figure 3. Segment identification XBLWversion1.0 www.xinboleic.com Technical Support:4009682003 3 / 12 XBLW SN74HC/HCT47 BCD-to-Seven-Segment Common anode LED Decodes/Drivers Electrical Parameter Absolute Maximum Ratings (Voltages are referenced to GND (ground=0V), unless otherwise specified.) Parameter Symbol Conditions supply voltage Min. -0.5 Max. +7 Unit VCC supply current ICC - -50 50 mA ground current IGND - mA input clamping current IIK VI < -0.5V or VI > VCC+0.5V - ±20 mA output clamping current IOK VO < -0.5V or VO > VCC+0.5V - ±20 mA -0.5V < VO < VCC+0.5V -65 ±25 mA +150 ℃ output current IO storage temperature Tstg soldering temperature TL - 10s DIP SOP/TSSOP 245 260 V ℃ Recommended Operating Conditions Parameter Symbol supply voltage VCC input voltage VI Conditions Min. Typ. Max. Unit 2.0 5.0 6.0 V 0 - VCC V VCC +125 ℃ 5.0 5.5 V - VCC V - VCC V - +125 ℃ SN74HC47 output voltage VO ambient temperature Tamb supply voltage VCC input voltage VI output voltage VO ambient temperature Tamb XBLWversion1.0 - 0 SN74HCT47 - www.xinboleic.com -40 4.5 0 0 -40 - Technical Support:4009682003 V 4 / 12 XBLW SN74HC/HCT47 BCD-to-Seven-Segment Common anode LED Decodes/Drivers Electrical Characteristics DC Characteristics 1 (Tamb=-40℃ to +85℃, voltages are referenced to GND (ground=0V), unless otherwise specified.) Parameter Symbol Min. Typ. Max. Unit 1.5 1.2 V 3.15 2.4 - - 4.2 3.2 - - - - 2.0V IO=20uA - 4.5V IO=20uA 6.0V - IO=20uA 4.5V - IO=4.0mA 6.0V - IO=5.2mA IIH 6.0V IIL(A/B/ C/D) VCC Conditions SN74HC47 HIGH-level input voltage 2.0V - V V 0.8 0.5 V 2.1 1.35 V 2.8 1.8 V 0 0.1 V 0 0.1 V 0 0.1 V 0.15 0.33 V - 0.16 0.33 V VI=VCC - - 20 uA 6.0V VI= GND - - -20 uA RBO/— RBI/LT) 6.0V VI= GND - - -1.2 mA ICC 6.0V VI=VCC or GND;IO=0A - - 13 mA - 6.0V 2.0V 4.5V VIL 6.0V VOL HIGH-level input current LOW-level input current 4.5V VIH LOW-level input voltage LOW-level output voltage - - IIL (BI/ — supply current SN74HCT47 HIGH-level input voltage VIH 4.5V to 5.5V - 2.0 1.6 - V LOW-level input voltage VIL 4.5V to 5.5V - - 1.2 0.8 V LOW-level output voltage VOL 4.5V IO=20uA - 0 0.1 V IO=4.0mA - 0.16 0.26 V HIGH-level input current IIH 6.0V VI=VCC - - 20 uA IIL(A/B/ C/D) 6.0V VI= GND - - -20 uA RBO/ 6.0V VI= GND - - -1.2 mA supply current RBI/LT) ICC 6.0V - - 13 mA additional supply current ΔICC 4.5V to 5.5V VI=VCC or GND;IO=0A One input at VI=VCC-2.1V; Other inputs at VCC or GND; IO=0A - - 500 uA LOW-level input current — IIL (BI/ — XBLWversion1.0 — www.xinboleic.com Technical Support:4009682003 5 / 12 XBLW SN74HC/HCT47 BCD-to-Seven-Segment Common anode LED Decodes/Drivers DC Characteristics 2 (Tamb=-40℃ to +125℃, voltages are referenced to GND (ground=0V), unless otherwise specified.) Parameter Symbol VCC Conditions Min. Typ. Max. Unit 1.5 - - V - - V - 0.5 V V 1.35 V 1.8 V 0.1 V 0.1 V 0.1 V 0.4 V V SN74HC47 HIGH-level input voltage 2.0V VIH VIL 4.2 - - - - - - IO=20uA - - - - 4.5V 6.0V VOL 3.15 - 2.0V 2.0V 4.5V IO=20uA 6.0V - - IO=20uA 4.5V - - IO=4.0mA - - 6.0V IO=5.2mA - - 0.4 IIH 6.0V VI=VCC - - 20 uA IIL(A/B/ C/D) 6.0V VI= GND - - -20 uA RBO/— RBI/LT) 6.0V VI= GND - - -1.2 mA ICC 6.0V VI=VCC or GND;IO=0A - - 13 mA HIGH-level input current LOW-level input current - 6.0V LOW-level input voltage LOW-level output voltage - 4.5V IIL (BI/ — supply current SN74HCT47 HIGH-level input voltage VIH 4.5V to 5.5V - 2.0 - - V LOW-level input voltage VIL 4.5V to 5.5V - - - 0.8 V LOW-level output voltage VOL 4.5V IO=20uA - - 0.1 V IO=4.0mA - - 0.4 V HIGH-level input current IIH 6.0V VI=VCC - - 20 uA IIL(A/B/ C/D) 6.0V VI= GND - - -20 uA RBO/ — RBI/LT) 6.0V VI= GND - - -1.2 mA supply current ICC 6.0V - - 13 mA additional supply current ΔICC 4.5V to 5.5V VI=VCC or GND;IO=0A One input at VI=VCC-2.1V; Other inputs at VCC or GND; IO=0A - - 500 uA LOW-level input current IIL (BI/ — XBLWversion1.0 www.xinboleic.com Technical Support:4009682003 6 / 12 XBLW SN74HC/HCT47 BCD-to-Seven-Segment Common anode LED Decodes/Drivers AC Characteristics (Tamb=25℃, voltages are referenced to GND (ground=0V), unless otherwise specified.) Parameter Symbol Conditions Min. Typ. Max. Unit from A input - - 100 ns from RBI input, outputs (a-f only) - - 100 ns from A input - - 100 ns from RBI input, outputs (a-f only) - - 100 ns - - 100 ns from RBI input, outputs (a-f only) - - 100 ns from A input - - 100 ns - - 100 ns SN74HC47 Turn-on time Turn-off time tON tOFF VCC=5.0V; CL=15pF; RL=665Ω VCC=5.0V; CL=15pF; RL=665Ω SN74HCT47 Turn-on time Turn-off time XBLWversion1.0 tON tOFF VCC=5.0V; CL=15pF; RL=665Ω VCC=5.0V; CL=15pF; RL=665Ω from A input — — from RBI input, outputs (a-f only) www.xinboleic.com Technical Support:4009682003 7 / 12 XBLW SN74HC/HCT47 BCD-to-Seven-Segment Common anode LED Decodes/Drivers Testing Circuit AC Testing Circuit Figure 4. Test circuit for measuring switching times CL includes probe and jig capacitance. Test Data Input Type VI SN74HC47 SN74HCT47 VCC 3.0V Load VEXT tr = tf 3.0ns CL 15pF RL 665Ω tON/tOFF 3.0ns 15pF 665Ω VCC VCC AC Testing Waveforms Measurement Points Type SN74HC47 SN74HCT47 XBLWversion1.0 Input Output VM VM 0.5×VCC 1.3V 0.5×VCC 1.3V www.xinboleic.com Technical Support:4009682003 8 / 12 XBLW SN74HC/HCT47 BCD-to-Seven-Segment Common anode LED Decodes/Drivers Package Information DIP16 XBLWversion1.0 www.xinboleic.com Technical Support:4009682003 9 / 12 XBLW SN74HC/HCT47 BCD-to-Seven-Segment Common anode LED Decodes/Drivers SOP16 XBLWversion1.0 www.xinboleic.com Technical Support:4009682003 10 / 12 XBLW SN74HC/HCT47 BCD-to-Seven-Segment Common anode LED Decodes/Drivers TSSOP16 XBLWversion1.0 www.xinboleic.com Technical Support:4009682003 11 / 12 XBLW SN74HC/HCT47 BCD-to-Seven-Segment Common anode LED Decodes/Drivers Statement:  Shenzhen xinbole electronics co., ltd. reserves the right to change the product specifications, without notice! Before placing an order, the customer needs to confirm whether the information obtained is the latest version, and verify the integrity of the relevant information.  Any semiconductor product is liable to fail or malfunction under certain conditions, and the buyer shall be responsible for complying with safety standards in the system design and whole machine manufacturing using Shenzhen xinbole electronics co., ltd products, and take appropriate security measures to avoid the potential risk of failure may result in personal injury or property losses of the situation occurred!  This document is for referenceonly,and the actual use should be based on the application test results.  Product performance is never ending, Shenzhen xinbole electronics co., ltd will be dedicated to provide customers with better performance, better quality of integrated circuit products. XBLWversion1.0 www.xinboleic.com Technical Support:4009682003 12 / 12
SN74HC47N 价格&库存
很抱歉,暂时无法提供与“SN74HC47N”相匹配的价格&库存,您可以联系我们找货
