XBLW SN74HC/HCT390
Dual Decade Ripple Counter
General Description
The SN74HC/HCT390 is a dual 4-bit decade ripple counter divided into four separately clocked sections. The
counters have two divide-by-2 sections and two divide-by-5 sections. These sections share an asynchronous
master reset input (nMR) and can be used in a BCD decade or bi-quinary configuration. If master reset inputs 1MR
and 2MR are used to clear all 8 bits of the counter simultaneously, numerous counting configurations are possible
within one package. Section clocks n CP 0 and n CP 1 , allow ripple counter or frequency division applications of
divide-by-2, 4, 5, 10, 20, 25, 50 or 100.
The HIGH to LOW transition of the clock inputs n CP 0 and n CP 1 trigger each section. For BCD decade operation,
the nQ0 output is connected to the n CP 1 input of the divide-by-5 section. For bi-quinary decade operation, thenQ3
output is connected to the n CP 0 input and nQ0 becomes the decade output. A HIGH on the nMR input overrides the
clocks and sets the four outputs LOW. Inputs include clamp diodes. It enables the use of current limiting resistors to
interface inputs to voltages in excess of VCC.
Features
Input levels:
For SN74HC390: CMOS level
For SN74HCT390: TTL level
Two BCD decade or bi-quinary counters
One device can be configured to divide-by-2, 4, 5, 10, 20, 25, 50 or 100
Two master reset inputs to clear each decade counter individually
Specified from -40℃ to +125℃
Packaging information: DIP16/SOP16/TSSOP16
Ordering Information
Product Model
XBLW SN74HC390N
XBLW SN74HC390DTR
XBLW SN74HC390TDTR
XBLW SN74HCT390N
XBLW SN74HCT390DTR
XBLW SN74HCT390TDTR
Package Type
DIP-16
SOP-16
TSSOP-16
DIP-16
SOP-16
TSSOP-16
Marking
74HC390N
74HC390
74HC390
74HCT390N
74HCT390
74HCT390
Packing
Tube
Tape
Tape
Tube
Tape
Tape
Packing Qty
1000Pcs/Box
2500Pcs/Reel
3000Pcs/Reel
1000Pcs/Box
2500Pcs/Reel
3000Pcs/Reel
Block Diagram And Pin Description
Block Diagram
XBLWversion1.0
www.xinboleic.com
Technical Support:4009682003
1 / 17
XBLW SN74HC/HCT390
Figure 1. Logic symbol
Figure 2. Logic diagram (one counter)
Pin Configurations
XBLWversion1.0
www.xinboleic.com
2 / 17
XBLW SN74HC/HCT390
Pin Description
Pin No.
1
Pin Name
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
1CP 0
1MR
1Q0
Description
clock input divide-by-2 section (HIGH-to-LOW; edge-triggered)
asynchronous master reset input (active HIGH)
flip-flop outputs
1CP1
1Q1
1Q2
1Q3
GND
2Q3
2Q2
2Q1
clock input divide-by-5 section (HIGH-to-LOW; edge-triggered)
flip-flop outputs
flip-flop outputs
flip-flop outputs
ground (0V)
flip-flop outputs
flip-flop outputs
flip-flop outputs
2CP1
2Q0
2MR
flip-flop outputs
2CP 0
VCC
supply voltage
Function Table
1
BCD Count Sequence
Output
nQ0
nQ1
L
L
1
H
L
2
L
H
3
H
H
4
L
L
5
H
L
6
L
H
7
H
H
8
L
L
9
H
L
Note: Output nQ0 connected to n CP1 ; counter input on n CP 0 .
Count
nQ2
L
L
L
L
H
H
H
H
L
L
nQ3
L
L
L
L
L
L
L
L
H
H
nQ2
L
L
H
H
L
L
L
H
H
L
nQ3
L
L
L
L
H
L
L
L
L
H
H=HIGH voltage level;
L=LOW voltage level;
.2
Bi-quinary Count Sequence
Output
nQ0
nQ1
L
L
1
L
H
2
L
L
3
L
H
4
L
L
5
H
H
6
H
L
7
H
H
8
H
L
9
H
H
Note: Output nQ3 connected to n CP 0 ; counter input on n CP 1 .
Count
XBLWversion1.0
www.xinboleic.com
3 / 17
XBLW SN74HC/HCT390
Electrical Parameter
Absolute Maximum Ratings
(Tamb=25℃, voltages are referenced to GND (ground=0V), unless otherwise specified)
Characteristic
supply voltage
Symbol
VCC
Conditions
input clamping current
IIK
VIVCC+0.5V
output clamping current
IOK
VIVCC+0.5V
output current
supply current
ICC
ground current
IGND
IO
storage temperature
0.5V
很抱歉,暂时无法提供与“SN74HC390N”相匹配的价格&库存,您可以联系我们找货
