RS
RE
SI
ARX SERIES
ST
O
APPROVAL SHEET
IO
N
ANTI-SURGE
C
IS
WIREWOUND RESISTORS
ER
PR
E
ARX6J0B200
CHECK AND APPROVE
ACCEPTED BY
CE
HONORABLE CUSTOMER
D
PRODUCE
TH
UN
EM
Edison Chen
Charles Chen
Jan. 03, 2024
Jan. 03, 2024
www.thunder-resistor.com
sales@thunder-resistor.com
Page 1 of 6
1. PRODUCT:
PRECISION WIRE WOUND RESISTORS
FEATURES
RS
· Advanced Germany alloy technology
· Very low TCR: lower than ±10ppm/℃.
· Excellent overall stability: Class 0.25
· Very low noise and voltage coefficient
· Non-inductance winding available under request
RE
· Perfect pulse loading capability
SI
ST
O
· Tolerance up to ±0.05%
· Anti-surge performance
IO
N
· Compliant to RoHS directive 2011/65/EU
IS
· Compliant to REACH (EC No. 1907/2006)) (last updated: 27/06/2018)
C
APPLICATIONS
Current sensor for test and measuring instruments
Power supply with high reliability
Components burn-in devices
Pulse load and in rush current protector
Medical equipment
Military electronics
TH
UN
D
ER
PR
E
Page 2 of 6
2. PART NUMBER: Part number is identified by the series name, power rating,
J
Tolerance
Temperature
Coefficient
T
Packing
Style
200
Resistance
Value
(1) Series name:
ARX series Anti-surge wire wound resistors
(2) Power Rating:
6=6.0W at 25℃
ST
O
Example:
ARX6
6
Series Power
Name
rating
RS
tolerance, temperature coefficient, packing style and resistance value.
(3) Tolerance: W±0.05%; B=±0.1%; C=±0.25%; D=±0.50%; F=±1.0%; J=±5.0%
6 = 10ppm/℃; 5 = 15ppm/℃;
(5) Packaging Style:
1 = 100ppm/℃; 0=250ppm/℃
RE
3 = 25ppm/℃; 2 = 50ppm/℃;
4 = 20ppm/℃;
SI
7 = 5ppm/℃;
(4) T.C.R.:
B = Blister/Box; T = Tape/Box of Tape/Reel
IO
N
(6) Resistance Value for tighten tolerance: R470,1R00=1R,10R0=10R,1000=100R,1001=1k
(7) Resistance Value for normal tolerance: R47、1R0=1R、100=10R、101=100R、102=1k
C
Digital marking with full part number.
IS
3. MARKING:
Derating curve
Temperature rising curve
TH
UN
D
ER
PR
E
4. Derating curve and temperature rising curve
The power dissipation on the resistor generates a temperature rise against the local
ambient, depending on the heat flow support of the printed-circuit board (thermal
resistance). These resistors do not feature a limited lifetime when operated within the
permissible limits. However, resistance value drift increasing over operating time may
result in exceeding a limit acceptable to the specific application, thereby establishing
a functional lifetime.
For high precision resistors working at an ambiance temperature of 25℃ or above,
the power rating shall be derated in accordance with the derating curve.
Page 3 of 6
RS
5. ELECTRICAL CHARACTERISTICS
Unless otherwise specified, all values are tested at the following condition:
Temperature: 21℃ to 25℃; Relative humidity: 45% to 70%;
Rated Continuous Working Voltage (RCWV) =
Resistance out of range is available upon request.
High insulating requirement is available upon request.
Non-inductance wound is available on request.
The working temperature range is from -55℃ to 175℃
ST
O
IS
IO
N
RE
SI
Power Rating Resistance Value
TH
UN
D
ER
PR
E
C
6. DIMENSION
Page 4 of 6
7.
ENVIRONMENTAL CHARACTERISTICS
(1)
Insulation Resistance
Dielectric Withstanding Voltage
ST
O
(2)
RS
IEC 60115-1, 4.6: in V-block for 60 seconds, the test resistance should be high than
10,000 M Ohm.
IEC 60115-1 4.7: Place resistors in V-block and applied 700V for 60 Seconds, no
breakdown or flashover.
Temperature Coefficient Test
SI
(3)
Short Time Overload Test
PR
E
(4)
C
IS
IO
N
RE
IEC 60115-1, 4.8: Test of resistors at room temperature and 60°C or 100°C on
request above room temperature. Temperature Coefficient is calculated by the
following equation and its value should be within the range requested.
R R0
1
10 6
Re sistor Temperature Coefficient
R0
t t0
R
= Resistance value under the testing temperature
R0 = Resistance value at the room temperature
t
= the 2nd testing temperature
t0 = Room temperature
Solderability
D
(5)
ER
IEC60115-1 4.13: At 10 times rated voltage or 2 times the maximum working voltage
whichever is lower for 5 seconds, the resistor should be free from defects. The
change of the resistance value should be within ±(0.1%+0.05 Ω) for precision type
and ±(0.5%+0.05 Ω) for commercial type as compared with the value before the test.
TH
UN
IEC 60115-1, 4.17: 235±5°C for 3±0.5 Seconds, there are at least 95% solder
coverage on the termination.
(6) Resistance to soldering heat:
IEC 60115-1, 4.18: 260±3°C for 10±1 Seconds, immersed to a point 3±0.5mm from
the body. The change of the resistance value should be within ±(0.1%+0.05 Ω) for
precision type and ±(0.25%+0.05 Ω) for commercial type as compared with the value
before the test.
Page 5 of 6
(7) Climatic sequence
RS
IEC 60115-1, 4.19: -55°C to Room Temp. to +155°C to Room Temp. (5 cycles).
The change of the resistance value shall be within ±(0.25%+0.05 Ω) for precision
type and ±(1.0%+0.05 Ω) for commercial type as compared with the value before
the test.
(8) Damp Heat Steady State
SI
ST
O
IEC 60115-1, 4.24: 40±2°C, 90-95% RH for 56 days, loaded with 0.1 times RCWV
or the maximum working voltage whichever is lower. The change of the resistance
value should be within ±(0.50%+0.05 Ω) for precision type and ±(5.0%+0.05 Ω) for
RE
(9) Load Life Test
IO
N
IEC 60115-1, 4.25: 25±2°C at RCWV or the maximum working voltage whichever
is lower for 1,000+48/-0 Hr. (1.5Hr. on, 0.5Hr. off). The resistors shall be arranged
not much effected mutually by the temperature of others and the excessive
ventilation shall not be performed. The change of the resistance value should be
within ±(1%+0.05 Ω) for precision type and ±(5.0%+0.05 Ω) for commercial type as
4 times RCWV for 1 Minute. No evidence of flaming or arcing
PR
E
(11) Resistance to Solvent
C
IEC 60115-1, 4.26:
IS
(10) Accidental Overload Test
IEC 60115-1, 4.30: IPA for 5±0.5 Min. with ultrasonic. No deterioration of coating and
marking occurred.
ER
(12) High voltage high pulse overload
D
Apply 100 pulses with 4000V to the resistor, the pulses parameter is 1.2/50μs. The
change of the resistance shall be within ±(0.25%+0.05 Ω) for precision type and
±(1.0%+0.05 Ω) for commercial type as compared with the value before the load.
TH
UN
Apply 10 pulses with 4000V to the resistor, the pulses parameter is 10μs/700μs. The
Page 6 of 6
很抱歉,暂时无法提供与“ARX6J0B800”相匹配的价格&库存,您可以联系我们找货
