ESP32-S2-SOLO-U-N4R2
    ESPRESSIF(乐鑫)
    SMD40模块
    WiFi 802.11b/g/n RF 收发器模块 2.4GHz 不含天线,U.FL 表面贴装型
ESP32-S2-SOLO-U-N4R2 数据手册
ESP32­S2­SOLO ESP32­S2­SOLO­U Datasheet 2.4 GHz Wi­Fi (802.11 b/g/n) module Built around ESP32­S2 series of SoC (chip revision v0.0), Xtensa® single­core 32­bit LX7 mi­ croprocessor Flash up to 16 MB, optional 2 MB PSRAM in chip package 36 GPIOs, rich set of peripherals On­board PCB antenna or external antenna connector ESP32­S2­SOLO ESP32­S2­SOLO­U Version 1.6 Espressif Systems Copyright © 2023 www.espressif.com 1 Module Overview 1 Module Overview Note: Check the link or the QR code to make sure that you use the latest version of this document: https://www.espressif.com/documentation/esp32-s2-solo_esp32-s2-solo-u_datasheet_en.pdf 1.1 Features CPU and On­Chip Memory Integrated Components on Module • ESP32-S2 or ESP32-S2R2 embedded, Xtensa® • 40 MHz crystal oscillator single-core 32-bit LX7 microprocessor, up to 240 • 4 MB SPI flash MHz • 128 KB ROM Antenna Options • 320 KB SRAM • On-board PCB antenna (ESP32-S2-SOLO) • 16 KB SRAM in RTC • External antenna via a connector • 2 MB embedded PSRAM (ESP32-S2R2 only) (ESP32-S2-SOLO-U) Wi­Fi Operating Conditions • 802.11 b/g/n • Operating voltage/Power supply: 3.0 ~ 3.6 V • Bit rate: 802.11n up to 150 Mbps • Operating ambient temperature: • A-MPDU and A-MSDU aggregation – 85 °C version: –40 ~ 85 °C • 0.4 µs guard interval support – 105 °C version: –40 ~ 105 °C • Operating frequency: 2412 ~ 2484 MHz (ESP32-S2-SOLO-H4 and ESP32-S2-SOLO-U-H4 only) Peripherals • GPIO, SPI, LCD, UART, I2C, I2S, Camera interface, IR, pulse counter, LED PWM, TWAI® (compatible with ISO 11898-1, i.e. CAN Specification 2.0), full-speed USB OTG, ADC, DAC, touch sensor, temperature sensor Certification • RF certification: See certificates • Green certification: RoHS/REACH Note: Test * Please refer to ESP32-S2 Series Datasheet for detailed information about the module peripherals. • HTOL/HTSL/uHAST/TCT/ESD 1.2 Description ESP32-S2-SOLO and ESP32-S2-SOLO-U are two powerful, generic Wi-Fi MCU modules that have a rich set of peripherals. They are an ideal choice for a wide variety of application scenarios relating to Internet of Things (IoT), wearable electronics and smart home. Espressif Systems 2 Submit Documentation Feedback ESP32-S2-SOLO & SOLO-U Datasheet v1.6 (Chip Revision v0.0) 1 Module Overview ESP32-S2-SOLO comes with a PCB antenna (ANT). ESP32-S2-SOLO-U comes with an external antenna connector (CONN). A wide selection of module variants are available for customers as shown in Table 1 and Table 2. Table 1: ESP32­S2­SOLO (ANT) Series Comparison1 Ordering Code PSRAM4 Flash 1 (°C) (mm) –40 ∼ 85 — –40 ∼ 105 2 MB (Quad SPI) –40 ∼ 85 4 MB (Quad SPI) ESP32-S2-SOLO-N4R2 Size3 — ESP32-S2-SOLO-N4 ESP32-S2-SOLO-H4 Ambient Temp.2 18.0 × 25.5 × 3.1 This table shares the same notes presented in Table 2 below. Table 2: ESP32­S2­SOLO­U (CONN) Series Comparison Ordering Code PSRAM4 Flash ESP32-S2-SOLO-U-N4 ESP32-S2-SOLO-U-H4 ESP32-S2-SOLO-U-N4R2 2 Ambient Temp.2 Size3 (°C) (mm) –40 ∼ 85 — –40 ∼ 105 — 4 MB (Quad SPI) 2 MB (Quad SPI) 4 18.0 × 19.2 × 3.2 –40 ∼ 85 Ambient temperature specifies the recommended temperature range of the environment immediately outside the Espressif module. 3 For details, refer to Section 7.1 Physical Dimensions. 4 The PSRAM is integrated in the chip’s package. In this datasheet unless otherwise stated, ESP32-S2-SOLO refers to all variants of ESP32-S2-SOLO, whereas ESP32-S2-SOLO-U refers to all variants of ESP32-S2-SOLO-U. The ESP32-S2 chip and the ESP32-S2R2 chip at the core of the two modules fall into the same category, namely ESP32-S2 series (chip revision v0.0). ESP32-S2 series of chips has an Xtensa® 32-bit LX7 CPU that operates at up to 240 MHz. It has a low-power co-processor that can be used instead of the CPU to save power while performing tasks that do not require much computing power, such as monitoring of peripherals. ESP32-S2 integrates a rich set of peripherals, ranging from SPI, I2S, UART, I2C, LED PWM, TWAI® , LCD, Camera interface, ADC, DAC, touch sensor, temperature sensor, as well as up to 43 GPIOs. It also includes a full-speed USB On-The-Go (OTG) interface to enable USB communication. The ESP32-S2 chip and the ESP32-S2R2 chip vary only in whether a PSRAM is embedded. For more information on ESP32-S2 series of SoCs, please refer to ESP32-S2 Series Datasheet and ESP32-S2 Series SoC Errata. Information about ESP-IDF release that supports a specific chip revision is provided in ESP Product Selector. Espressif Systems 3 Submit Documentation Feedback ESP32-S2-SOLO & SOLO-U Datasheet v1.6 (Chip Revision v0.0) 1 Module Overview 1.3 Applications • Generic Low-power IoT Sensor Hub • Smart Building • Generic Low-power IoT Data Loggers • Industrial Automation • Cameras for Video Streaming • Smart Agriculture • Over-the-top (OTT) Devices • Audio Applications • USB Devices • Health Care Applications • Speech Recognition • Wi-Fi-enabled Toys • Image Recognition • Wearable Electronics • Mesh Network • Home Automation • Retail & Catering Applications • Smart Home Control Panel • Smart POS Machines Espressif Systems 4 Submit Documentation Feedback ESP32-S2-SOLO & SOLO-U Datasheet v1.6 (Chip Revision v0.0) Contents Contents 1 Module Overview 2 1.1 Features 2 1.2 Description 2 1.3 Applications 4 2 Block Diagram 9 3 Pin Definitions 10 3.1 Pin Layout 10 3.2 Pin Description 10 3.3 Strapping Pins 12 4 Electrical Characteristics 14 4.1 Absolute Maximum Ratings 14 4.2 Recommended Operating Conditions 14 4.3 DC Characteristics (3.3 V, 25 °C) 14 4.4 Current Consumption Characteristics 15 4.4.1 Current Consumption in Active Mode 15 4.4.2 Current Consumption in Other Modes 15 4.5 Wi-Fi RF Characteristics 16 4.5.1 Wi-Fi RF Standards 16 4.5.2 Transmitter Characteristics 17 4.5.3 Receiver Characteristics 17 5 Module Schematics 19 6 Peripheral Schematics 21 7 Physical Dimensions and PCB Land Pattern 22 7.1 Physical Dimensions 22 7.2 Recommended PCB Land Pattern 23 7.3 Dimensions of External Antenna Connector 25 8 Product Handling 26 8.1 Storage Conditions 26 8.2 Electrostatic Discharge (ESD) 26 8.3 Soldering Profile 26 8.3.1 26 Reflow Profile 8.4 Ultrasonic Vibration 27 9 MAC Addresses and eFuse 28 10 Related Documentation and Resources Espressif Systems 5 Submit Documentation Feedback 29 ESP32-S2-SOLO & SOLO-U Datasheet v1.6 (Chip Revision v0.0) Contents Revision History Espressif Systems 30 6 Submit Documentation Feedback ESP32-S2-SOLO & SOLO-U Datasheet v1.6 (Chip Revision v0.0) List of Tables List of Tables 1 ESP32-S2-SOLO (ANT) Series Comparison 3 2 ESP32-S2-SOLO-U (CONN) Series Comparison 3 3 Pin Definitions 11 4 Strapping Pins 12 5 Absolute Maximum Ratings 14 6 Recommended Operating Conditions 14 7 DC Characteristics (3.3 V, 25 °C) 14 8 Current Consumption Depending on RF Modes 15 9 Current Consumption in Modem-sleep Mode 15 10 Current Consumption in Low-Power Modes 16 11 Wi-Fi RF Standards 16 12 TX Power 17 13 RX Sensitivity 17 14 Maximum RX Level 18 15 Adjacent Channel Rejection 18 Espressif Systems 7 Submit Documentation Feedback ESP32-S2-SOLO & SOLO-U Datasheet v1.6 (Chip Revision v0.0) List of Figures List of Figures 1 ESP32-S2-SOLO Block Diagram 9 2 ESP32-S2-SOLO-U Block Diagram 9 3 Pin Layout (Top View) 10 4 ESP32-S2-SOLO Schematics 19 5 ESP32-S2-SOLO-U Schematics 20 6 Peripheral Schematics 21 7 ESP32-S2-SOLO Physical Dimensions 22 8 ESP32-S2-SOLO-U Physical Dimensions 22 9 ESP32-S2-SOLO Recommended PCB Land Pattern 23 10 ESP32-S2-SOLO-U Recommended PCB Land Pattern 24 11 Dimensions of External Antenna Connector 25 12 Reflow Profile 26 Espressif Systems 8 Submit Documentation Feedback ESP32-S2-SOLO & SOLO-U Datasheet v1.6 (Chip Revision v0.0) SPI Flash 2 Block Diagram 2 Block Diagram 40 MHz Crystal 3V3 ESP32-S2-SOLO Antenna RF Matching EN ESP32-S2 ESP32-S2R2 GPIOs SPICS0 SPICLK SPID SPIQ SPIHD SPIWP VDD_SPI PSRAM(opt.) (QSPI) SPI Flash Figure 1: ESP32­S2­SOLO Block Diagram 40 MHz Crystal 3V3 ESP32-S2-SOLO-U Antenna RF Matching EN ESP32-S2 ESP32-S2R2 GPIOs SPICS0 SPICLK SPID SPIQ SPIHD SPIWP VDD_SPI PSRAM(opt.) (QSPI) SPI Flash Figure 2: ESP32­S2­SOLO­U Block Diagram 40 MHz Crystal 3V3 ESP32-S2-SOLO Antenna RF Matching EN ESP32-S2 ESP32-S2R2 GPIOs Espressif Systems SPICS0 SPICLK SPID SPIQ SPIHD SPIWP VDD_SPI PSRAM(opt.) (QSPI) 9 Submit Documentation Feedback SPI Flash ESP32-S2-SOLO & SOLO-U Datasheet v1.6 (Chip Revision v0.0) 3 Pin Definitions 3 Pin Definitions 3.1 Pin Layout The pin diagram below shows the approximate location of pins on the module. For the actual diagram drawn to scale, please refer to Figure 7.1 Physical Dimensions. Keepout Zone GND GND 35 IO42 IO7 7 GND 41 GND GND 34 IO41 IO15 8 GND GND GND 33 IO40 IO16 9 32 IO39 IO17 10 31 IO38 IO18 11 30 IO37 IO8 12 29 IO36 IO19 13 28 IO35 IO20 14 27 IO0 IO45 26 GND 25 6 IO34 IO6 24 RXD0 IO33 36 23 5 IO21 IO5 22 TXD0 IO14 37 21 4 IO13 IO4 20 IO2 IO12 38 19 3 IO11 EN 18 IO1 IO10 39 17 2 IO9 3V3 16 GND IO46 40 15 1 IO3 GND Figure 3: Pin Layout (Top View) The above pin layout is applicable for ESP32-S2-SOLO and ESP32-S2-SOLO-U, but the latter has no keepout zone. 3.2 Pin Description The module has 41 pins. See pin definitions in Table 3 Pin Definitions. For peripheral pin configurations, please refer to ESP32-S2 Series Datasheet > Section Peripheral Pin Configurations. Espressif Systems 10 Submit Documentation Feedback ESP32-S2-SOLO & SOLO-U Datasheet v1.6 (Chip Revision v0.0) 3 Pin Definitions Table 3: Pin Definitions Type1 Function Name No. GND 1 P Ground 3V3 2 P Power supply EN 3 I High: on, enables the chip. Low: off, the chip powers off. Note: Do not leave the EN pin floating. IO4 4 I/O/T RTC_GPIO4, GPIO4, TOUCH4, ADC1_CH3 IO5 5 I/O/T RTC_GPIO5, GPIO5, TOUCH5, ADC1_CH4 IO6 6 I/O/T RTC_GPIO6, GPIO6, TOUCH6, ADC1_CH5 IO7 7 I/O/T RTC_GPIO7, GPIO7, TOUCH7, ADC1_CH6 IO15 8 I/O/T RTC_GPIO15, GPIO15, U0RTS, ADC2_CH4, XTAL_32K_P IO16 9 I/O/T RTC_GPIO16, GPIO16, U0CTS, ADC2_CH5, XTAL_32K_N IO17 10 I/O/T RTC_GPIO17, GPIO17, U1TXD, ADC2_CH6, DAC_1 IO18 11 I/O/T RTC_GPIO18, GPIO18, U1RXD, ADC2_CH7, DAC_2, CLK_OUT3 IO8 12 I/O/T RTC_GPIO8, GPIO8, TOUCH8, ADC1_CH7 IO19 13 I/O/T RTC_GPIO19, GPIO19, U1RTS, ADC2_CH8, CLK_OUT2, USB_D- IO20 14 I/O/T RTC_GPIO20, GPIO20, U1CTS, ADC2_CH9, CLK_OUT1, USB_D+ IO3 15 I/O/T RTC_GPIO3, GPIO3, TOUCH3, ADC1_CH2 IO46 16 I IO9 17 I/O/T RTC_GPIO9, GPIO9, TOUCH9, ADC1_CH8, FSPIHD IO10 18 I/O/T RTC_GPIO10, GPIO10, TOUCH10, ADC1_CH9, FSPICS0, FSPIIO4 IO11 19 I/O/T RTC_GPIO11, GPIO11, TOUCH11, ADC2_CH0, FSPID, FSPIIO5 IO12 20 I/O/T RTC_GPIO12, GPIO12, TOUCH12, ADC2_CH1, FSPICLK, FSPIIO6 IO13 21 I/O/T RTC_GPIO13, GPIO13, TOUCH13, ADC2_CH2, FSPIQ, FSPIIO7 IO14 22 I/O/T RTC_GPIO14, GPIO14, TOUCH14, ADC2_CH3, FSPIWP, FSPIDQS IO21 23 I/O/T RTC_GPIO21, GPIO21 IO33 24 I/O/T SPIIO4, GPIO33, FSPIHD IO34 25 I/O/T SPIIO5, GPIO34, FSPICS0 IO45 26 I/O/T GPIO45 IO0 27 I/O/T RTC_GPIO0, GPIO0 IO35 28 I/O/T SPIIO6, GPIO35, FSPID IO36 29 I/O/T SPIIO7, GPIO36, FSPICLK IO37 30 I/O/T SPIDQS, GPIO37, FSPIQ IO38 31 I/O/T GPIO38, FSPIWP IO39 32 I/O/T MTCK, GPIO39, CLK_OUT3 IO40 33 I/O/T MTDO, GPIO40, CLK_OUT2 IO41 34 I/O/T MTDI, GPIO41, CLK_OUT1 IO42 35 I/O/T MTMS, GPIO42 RXD0 36 I/O/T U0RXD, GPIO44, CLK_OUT2 TXD0 37 I/O/T U0TXD, GPIO43, CLK_OUT1 IO2 38 I/O/T RTC_GPIO2, GPIO2, TOUCH2, ADC1_CH1 IO1 39 I/O/T RTC_GPIO1, GPIO1, TOUCH1, ADC1_CH0 GPIO46 Cont’d on next page Espressif Systems 11 Submit Documentation Feedback ESP32-S2-SOLO & SOLO-U Datasheet v1.6 (Chip Revision v0.0) 3 Pin Definitions Table 3 – cont’d from previous page 1 Name No. Type GND 40 P Ground EPAD 41 P Ground 1 Function P: power supply; I: input; O: output; T: high impedance. 3.3 Strapping Pins Note: The content below is excerpted from Section Strapping Pins in ESP32-S2 Series Datasheet. For the strapping pin mapping between the chip and modules, please refer to Chapter 5 Module Schematics. ESP32-S2 has three strapping pins: • GPIO0 • GPIO45 • GPIO46 Software can read the values of corresponding bits from register ”GPIO_STRAPPING”. During the chip’s system reset (power-on-reset, RTC watchdog reset, brownout reset, analog super watchdog reset, and crystal clock glitch detection reset), the latches of the strapping pins sample the voltage level as strapping bits of ”0” or ”1”, and hold these bits until the chip is powered down or shut down. GPIO0, GPIO45 and GPIO46 are connected to the chip’s internal weak pull-up/pull-down during the chip reset. Consequently, if they are unconnected or the connected external circuit is high-impedance, the internal weak pull-up/pull-down will determine the default input level of these strapping pins. To change the strapping bit values, users can apply the external pull-down/pull-up resistances, or use the host MCU’s GPIOs to control the voltage level of these pins when powering on ESP32-S2. After reset, the strapping pins work as normal-function pins. Refer to Table 4 for a detailed boot-mode configuration of the strapping pins. Table 4: Strapping Pins VDD_SPI Voltage 1 Pin Default 3.3 V GPIO45 Pull-down 0 2 1.8 V 1 Booting Mode 3 Pin Default SPI Boot Download Boot GPIO0 Pull-up 1 0 GPIO46 Pull-down Don’t-care 0 Enabling/Disabling ROM Messages Print During Booting 4 5 Pin Default Enabled Disabled GPIO46 Pull-down See note 5 See note 5 Espressif Systems 12 Submit Documentation Feedback ESP32-S2-SOLO & SOLO-U Datasheet v1.6 (Chip Revision v0.0) 3 Pin Definitions Note: 1. The functionality of strapping pin GPIO45 to select VDD_SPI voltage may be disabled by setting VDD_SPI_FORCE eFuse to 1. In such a case the voltage is selected with eFuse bit VDD_SPI_TIEH. 2. Since ESP32-S2FH2, ESP32-S2FH4, ESP32-S2FN4R2, and ESP32-S2R2 come with both/either 3.3 V SPI flash and/or PSRAM, VDD_SPI must be configured to 3.3 V. 3. The strapping combination of GPIO46 = 1 and GPIO0 = 0 is invalid and will trigger unexpected behavior. 4. ROM code can be printed over U0TXD (by default) or DAC_1, depending on the eFuse bit. 5. When eFuse UART_PRINT_CONTROL value is: 0, print is normal during boot and not controlled by GPIO46. 1 and GPIO46 is 0, print is normal during boot; but if GPIO46 is 1, print is disabled. 2 and GPIO46 is 0, print is disabled; but if GPIO46 is 1, print is normal. 3, print is disabled and not controlled by GPIO46. Espressif Systems 13 Submit Documentation Feedback ESP32-S2-SOLO & SOLO-U Datasheet v1.6 (Chip Revision v0.0) 4 Electrical Characteristics 4 Electrical Characteristics 4.1 Absolute Maximum Ratings Stresses above those listed in Table 5 Absolute Maximum Ratings may cause permanent damage to the device. These are stress ratings only and functional operation of the device at these or any other conditions beyond those indicated under Table 6 Recommended Operating Conditions is not implied. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability. Table 5: Absolute Maximum Ratings Symbol Parameter Min Max Unit VDD33 Power supply voltage –0.3 3.6 V TST ORE Storage temperature –40 105 °C 4.2 Recommended Operating Conditions Table 6: Recommended Operating Conditions Symbol Parameter Min Typ Max Unit VDD33 Power supply voltage 3.0 3.3 3.6 V IV DD Current delivered by external power supply 0.5 — — A TA Operating ambient temperature –40 — 85 °C version 105 °C version 85 °C 105 4.3 DC Characteristics (3.3 V, 25 °C) Table 7: DC Characteristics (3.3 V, 25 °C) Symbol Parameter CIN Pin capacitance VIH Min — High-level input voltage 0.75 × VDD 1 Typ Max Unit 2 — pF — 1 VDD + 0.3 V 1 VIL Low-level input voltage –0.3 — 0.25 × VDD IIH High-level input current — — 50 nA Low-level input current — — 50 nA — — IIL VOH VOL 2 2 High-level output voltage 0.8 × VDD Low-level output voltage 1 V V 1 — — 0.1 × VDD V — 40 — mA — 28 — mA 45 — kΩ 45 — kΩ — 1 1 IOH IOL High-level source current (VDD = 3.3 V, VOH >= 2.64 V, PAD_DRIVER = 3) Low-level sink current (VDD1 = 3.3 V, VOL = 0.495 V, PAD_DRIVER = 3) RP U Pull-up resistor — RP D Pull-down resistor — VIH_nRST VIL_nRST Chip reset release voltage 0.75 × VDD Chip reset voltage Espressif Systems –0.3 14 Submit Documentation Feedback 1 — VDD + 0.3 0.25 × VDD V 1 V ESP32-S2-SOLO & SOLO-U Datasheet v1.6 (Chip Revision v0.0) 4 Electrical Characteristics 1 VDD is the I/O voltage for pins of a particular power domain. 2 VOH and VOL are measured using high-impedance load. 4.4 Current Consumption Characteristics Owing to the use of advanced power-management technologies, the module can switch between different power modes. For details on different power modes, please refer to Section RTC and Low-Power Management in ESP32-S2 Series Datasheet. 4.4.1 Current Consumption in Active Mode Table 8: Current Consumption Depending on RF Modes Work mode Description TX Active (RF working) RX 2 1 Peak (mA) 802.11b, 20 MHz, 1 Mbps, @19.5 dBm 310 802.11g, 20 MHz, 54 Mbps, @15 dBm 220 802.11n, 20 MHz, MCS7, @13.5 dBm 205 802.11n, 40 MHz, MCS7, @13.5 dBm 165 802.11b/g/n, 20 MHz 71 802.11n, 40 MHz 75 The current consumption measurements are taken with a 3.3 V supply at 25 °C of ambient temperature at the RF port. All transmitters’ measurements are based on 100% duty cycle. 2 The current consumption figures in RX mode are for cases where the peripherals are disabled and the CPU idle. Note: The content below is excerpted from Section Power Consumption in Other Modes in ESP32-S2 Series Datasheet. 4.4.2 Current Consumption in Other Modes The measurements below are applicable to ESP32-S2, ESP32-S2FH2, and ESP32-S2FH4. Since ESP32-S2FN4R2 and ESP32-S2R2 are embedded with PSRAM, their current consumption might be higher. Table 9: Current Consumption in Modem­sleep Mode Mode CPU Frequency (MHz) 240 Modem-sleep2,3 160 80 Espressif Systems Typ Description All Peripherals Clocks All Peripherals Clocks Disabled (mA) Enabled (mA)1 CPU is idle 20.0 28.0 CPU is running 23.0 32.0 CPU is idle 14.0 21.0 CPU is running 16.0 24.0 CPU is idle 10.5 18.4 CPU is running 12.0 20.0 15 Submit Documentation Feedback ESP32-S2-SOLO & SOLO-U Datasheet v1.6 (Chip Revision v0.0) 4 Electrical Characteristics 1 In practice, the current consumption might be different depending on which peripherals are enabled. 2 In Modem-sleep mode, Wi-Fi is clock gated. 3 In Modem-sleep mode, the consumption might be higher when accessing flash. For a flash rated at 80 Mbit/s, in SPI 2-line mode the consumption is 10 mA. Table 10: Current Consumption in Low­Power Modes Mode Description 1 Light-sleep VDD_SPI and Wi-Fi are powered down, and all GPIOs are high-impedance 750 The ULP co-processor ULP-FSM 170 ULP-RISC-V 190 is powered on Deep-sleep Power off 1 Typ (µA) 2 ULP sensor-monitored pattern 3 22 RTC timer + RTC memory 25 RTC timer only 20 CHIP_PU is set to low level, the chip is powered off 1 In Light-sleep mode, with all related SPI pins pulled up, the current consumption of the embedded PSRAM is 140 µA. Chip variants with embedded PSRAM include ESP32-S2FN4R2 and ESP32-S2R2. 2 During Deep-sleep, when the ULP co-processor is powered on, peripherals such as GPIO and I2C are able to operate. 3 The “ULP sensor-monitored pattern” refers to the mode where the ULP coprocessor or the sensor works periodically. When touch sensors work with a duty cycle of 1%, the typical current consumption is 22 µA. 4.5 Wi­Fi RF Characteristics 4.5.1 Wi­Fi RF Standards Table 11: Wi­Fi RF Standards Name Description Center frequency range of operating channel 1 2412 ~ 2484 MHz Wi-Fi wireless standard IEEE 802.11b/g/n 802.11b: 1, 2, 5.5 and 11 Mbps Data rate 20 MHz 802.11g: 6, 9, 12, 18, 24, 36, 48, 54 Mbps 802.11n: MCS0-7, 72.2 Mbps (Max) 40 MHz 802.11n: MCS0-7, 150 Mbps (Max) Antenna type 1 PCB antenna, external antenna connector Device should operate in the center frequency range allocated by regional regulatory authorities. Target center frequency range is configurable by software. 2 For the modules that use external antenna connectors, the output impedance is 50 Ω. For other modules without external antenna connectors, the output impedance is irrelevant. Espressif Systems 16 Submit Documentation Feedback ESP32-S2-SOLO & SOLO-U Datasheet v1.6 (Chip Revision v0.0) 4 Electrical Characteristics 4.5.2 Transmitter Characteristics Target TX power is configurable based on device or certification requirements. The default characteristics are provided in Table 12. Table 12: TX Power Min Typ Max (dBm) (dBm) (dBm) 802.11b, 1 Mbps — 19.5 — 802.11b, 11 Mbps — 19.5 — 802.11g, 6 Mbps — 18.0 — 802.11g, 54 Mbps — 15.0 — 802.11n, HT20, MCS0 — 18.0 — 802.11n, HT20, MCS7 — 13.5 — 802.11n, HT40, MCS0 — 18.0 — 802.11n, HT40, MCS7 — 13.5 — Rate 4.5.3 Receiver Characteristics Table 13: RX Sensitivity Min Typ Max (dBm) (dBm) (dBm) 802.11b, 1 Mbps — –97 — 802.11b, 2 Mbps — –95 — 802.11b, 5.5 Mbps — –93 — 802.11b, 11 Mbps — –88 — 802.11g, 6 Mbps — –92 — 802.11g, 9 Mbps — –91 — 802.11g, 12 Mbps — –89 — 802.11g, 18 Mbps — –86 — 802.11g, 24 Mbps — –83 — 802.11g, 36 Mbps — –80 — 802.11g, 48 Mbps — –76 — 802.11g, 54 Mbps — –75 — 802.11n, HT20, MCS0 — –92 — 802.11n, HT20, MCS1 — –88 — 802.11n, HT20, MCS2 — –85 — 802.11n, HT20, MCS3 — –83 — 802.11n, HT20, MCS4 — –79 — 802.11n, HT20, MCS5 — –75 — 802.11n, HT20, MCS6 — –73 — 802.11n, HT20, MCS7 — –72 — 802.11n, HT40, MCS0 — –89 — 802.11n, HT40, MCS1 — –85 — Rate Cont’d on next page Espressif Systems 17 Submit Documentation Feedback ESP32-S2-SOLO & SOLO-U Datasheet v1.6 (Chip Revision v0.0) 4 Electrical Characteristics Table 13 – cont’d from previous page Min Typ Max (dBm) (dBm) (dBm) 802.11n, HT40, MCS2 — –83 — 802.11n, HT40, MCS3 — –79 — 802.11n, HT40, MCS4 — –76 — 802.11n, HT40, MCS5 — –72 — 802.11n, HT40, MCS6 — –70 — 802.11n, HT40, MCS7 — –68 — Rate Table 14: Maximum RX Level Min Typ Max (dBm) (dBm) (dBm) 802.11b, 1 Mbps — 5 — 802.11b, 11 Mbps — 5 — 802.11b, 6 Mbps — 5 — 802.11b, 54 Mbps — 0 — 802.11n, HT20, MCS0 — 5 — 802.11n, HT20, MCS7 — 0 — 802.11n, HT40, MCS0 — 5 — 802.11n, HT40, MCS7 — 0 — Rate Table 15: Adjacent Channel Rejection Rate Espressif Systems Min Typ Max (dB) (dB) (dB) 802.11b, 11 Mbps — 35 — 802.11b, 6 Mbps — 31 — 802.11b, 54 Mbps — 14 — 802.11n, HT20, MCS0 — 31 — 802.11n, HT20, MCS7 — 13 — 802.11n, HT40, MCS0 — 19 — 802.11n, HT40, MCS7 — 8 — 18 Submit Documentation Feedback ESP32-S2-SOLO & SOLO-U Datasheet v1.6 (Chip Revision v0.0) 5 Module Schematics This is the reference design of the module. 5 4 3 2 1 TBD VDD33 10K(NC) 1uF GND 0 R3 C5 10uF 1uF 0.1uF NC GND ANT1 GND GND RF_ANT 1 2 L2 GND TBD C11 C12 TBD TBD PCB_ANT GND GND C10 GND The values of C11, L2 and C12 vary with the actual PCB board. NC: No component. GPIO0 GPIO1 GPIO2 GPIO3 GPIO4 GPIO5 GPIO6 GPIO7 GPIO8 GPIO9 VDDA LNA_IN VDD3P3 VDD3P3 GPIO0 GPIO1 GPIO2 GPIO3 GPIO4 GPIO5 GPIO6 GPIO7 GPIO8 GPIO9 15 16 17 18 19 20 21 22 23 24 25 26 27 28 U1 VDD33 0.1uF GPIO21 GND C GPIO38 GPIO37 GPIO36 GPIO35 GPIO34 GPIO33 SPID SPIQ SPICLK SPICS0 SPIWP SPIHD VDD_SPI SPICS1 42 41 40 39 38 37 36 35 34 33 32 31 30 29 R10 VDD_SPI GPIO38 GPIO37 GPIO36 GPIO35 GPIO34 GPIO33 SPID SPIQ SPICLK SPICS0 SPIWP SPIHD 0 C13 C14 0.1uF 1uF R8 10K(NC) SPICS0 1 SPICLK 6 SPIHD 7 /CS /HOLD U2 VDD_SPI DI CLK DO /WP 5 SPID 2 SPIQ 3 SPIWP FLASH-3V3 GND GND ESP32-S2 ESP32-S2R2 GND VDD33 0.1uF A GND Figure 4: ESP32­S2­SOLO Schematics 5 4 B C16 GPIO15 GPIO16 GPIO17 GPIO18 GPIO19 GPIO20 A D ESP32-S2-SOLO(pin-out) GND C15 0.1uF GPIO10 GPIO11 GPIO12 GPIO13 GPIO14 ESP32-S2-SOLO & SOLO-U Datasheet v1.6 (Chip Revision v0.0) B LNA_IN 1 2 3 4 5 6 7 8 9 10 11 12 13 14 GPIO1 GPIO2 U0TXD U0RXD GPIO42 GPIO41 GPIO40 GPIO39 GPIO38 GPIO37 GPIO36 GPIO35 GPIO0 VDD33 56 55 54 53 52 51 50 49 48 47 46 45 44 43 C9 CHIP_PU GPIO46 VDDA XTAL_P XTAL_N VDDA GPIO45 U0RXD U0TXD MTMS MTDI VDD3P3_CPU MTDO MTCK C8 GPIO10 GPIO11 GPIO12 GPIO13 GPIO14 VDD3P3_RTC XTAL_32K_P XTAL_32K_N DAC_1 DAC_2 GPIO19 GPIO20 VDD3P3_RTC_IO GPIO21 C7 57 C6 GND L1 GND 2.0nH 41 40 39 38 37 36 35 34 33 32 31 30 29 28 27 8 GND VDD33 R4 0.1uF C CHIP_PU GPIO46 GPIO45 U0RXD 499 U0TXD GPIO42 GPIO41 GPIO40 GPIO39 EPAD GND IO1 IO2 TXD0 RXD0 IO42 IO41 IO40 IO39 IO38 IO37 IO36 IO35 IO0 GND 3V3 EN IO4 IO5 IO6 IO7 IO15 IO16 IO17 IO18 IO8 IO19 IO20 VDD GND 19 Submit Documentation Feedback VDD33 1 2 3 4 5 6 7 8 9 10 11 12 13 14 GND 100pF GND 40MHz(±10ppm) CHIP_PU GPIO4 GPIO5 D1 GPIO6 ESD GPIO7 GPIO15 GPIO16 GPIO17 GPIO18 GPIO8 GND GPIO19 GPIO20 4 3 C4 ESP32-S2-SOLO IO3 IO46 IO9 IO10 IO11 IO12 IO13 IO14 IO21 IO33 IO34 IO45 C3 GND U3 R1 C2 GND 15 16 17 18 19 20 21 22 23 24 25 26 1 The value of R4 varies with the actual PCB board. VDD33 VDD33 GPIO3 GPIO46 GPIO9 GPIO10 GPIO11 GPIO12 GPIO13 GPIO14 GPIO21 GPIO33 GPIO34 GPIO45 TBD GND GND XOUT C1 The values of C1 and C4 vary with the selection of the crystal. Y1 2 D GND GND 4 GND XIN Espressif Systems 5 Module Schematics 3 2 1 5 4 3 2 1 VDD33 VDD33 10K(NC) 1uF VDD33 GND 0 R3 C5 1uF 0.1uF NC GND GND 3 2 1 GND RF_ANT L2 GND TBD ANT1 C11 C12 IPEX TBD TBD GND GND GND B The values of C11, L2 and C12 vary with the actual PCB board. NC: No component. LNA_IN GPIO0 GPIO1 GPIO2 GPIO3 GPIO4 GPIO5 GPIO6 GPIO7 GPIO8 GPIO9 1 2 3 4 5 6 7 8 9 10 11 12 13 14 VDDA LNA_IN VDD3P3 VDD3P3 GPIO0 GPIO1 GPIO2 GPIO3 GPIO4 GPIO5 GPIO6 GPIO7 GPIO8 GPIO9 0.1uF GPIO38 GPIO37 GPIO36 GPIO35 GPIO34 GPIO33 SPID SPIQ SPICLK SPICS0 SPIWP SPIHD VDD_SPI SPICS1 GPIO21 GND 42 41 40 39 38 37 36 35 34 33 32 31 30 29 R10 VDD_SPI GPIO38 GPIO37 GPIO36 GPIO35 GPIO34 GPIO33 SPID SPIQ SPICLK SPICS0 SPIWP SPIHD 0 C13 C14 0.1uF 1uF R8 10K(NC) SPICS0 1 SPICLK 6 SPIHD 7 /CS CLK /HOLD U2 VDD_SPI DI DO /WP 5 SPID 2 SPIQ 3 SPIWP FLASH-3V3 GND GND ESP32-S2 ESP32-S2R2 GND VDD33 0.1uF A GND Figure 5: ESP32­S2­SOLO­U Schematics 5 4 B C16 GPIO15 GPIO16 GPIO17 GPIO18 GPIO19 GPIO20 A C ESP32-S2-SOLO-U(pin-out) GND C15 0.1uF GPIO10 GPIO11 GPIO12 GPIO13 GPIO14 ESP32-S2-SOLO & SOLO-U Datasheet v1.6 (Chip Revision v0.0) 15 16 17 18 19 20 21 22 23 24 25 26 27 28 U1 VDD33 D VDD33 56 55 54 53 52 51 50 49 48 47 46 45 44 43 10uF C10 CHIP_PU GPIO46 VDDA XTAL_P XTAL_N VDDA GPIO45 U0RXD U0TXD MTMS MTDI VDD3P3_CPU MTDO MTCK C9 GPIO10 GPIO11 GPIO12 GPIO13 GPIO14 VDD3P3_RTC XTAL_32K_P XTAL_32K_N DAC_1 DAC_2 GPIO19 GPIO20 VDD3P3_RTC_IO GPIO21 C8 57 C7 20 Submit Documentation Feedback C6 GND L1 GND 2.0nH GPIO1 GPIO2 U0TXD U0RXD GPIO42 GPIO41 GPIO40 GPIO39 GPIO38 GPIO37 GPIO36 GPIO35 GPIO0 8 GND VDD33 R4 0.1uF C CHIP_PU GPIO46 GPIO45 U0RXD 499 U0TXD GPIO42 GPIO41 GPIO40 GPIO39 VDD GND EPAD GND IO1 IO2 TXD0 RXD0 IO42 IO41 IO40 IO39 IO38 IO37 IO36 IO35 IO0 GND 3V3 EN IO4 IO5 IO6 IO7 IO15 IO16 IO17 IO18 IO8 IO19 IO20 GND 100pF GND 40MHz(±10ppm) 1 2 3 4 5 6 7 8 9 10 11 12 13 14 IO3 IO46 IO9 IO10 IO11 IO12 IO13 IO14 IO21 IO33 IO34 IO45 TBD CHIP_PU GPIO4 GPIO5 D1 GPIO6 ESD GPIO7 GPIO15 GPIO16 GPIO17 GPIO18 GPIO8 GND GPIO19 GPIO20 41 40 39 38 37 36 35 34 33 32 31 30 29 28 27 15 16 17 18 19 20 21 22 23 24 25 26 C4 ESP32-S2-SOLO-U GPIO3 GPIO46 GPIO9 GPIO10 GPIO11 GPIO12 GPIO13 GPIO14 GPIO21 GPIO33 GPIO34 GPIO45 C3 GND U3 R1 C2 GND 4 3 4 1 The value of R4 varies with the actual PCB board. VDD33 GND GND XOUT TBD Y1 2 C1 The values of C1 and C4 vary with the selection of the crystal. GND D XIN GND 3 2 1 5 Module Schematics Espressif Systems GND 6 Peripheral Schematics 6 Peripheral Schematics This is the typical application circuit of the module connected with peripheral components (for example, power supply, antenna, reset button, JTAG interface, and UART interface). VDD33 GND GND VDD33 JP1 1 2 3 4 ESP32-S2-SOLO/ESP32-S2-SOLO-U R1 22uF 0.1uF C2 TBD C6 TBD C5 NC: No component. GND 3V3 EN IO4 IO5 IO6 IO7 IO15 IO16 IO17 IO18 IO8 IO19 IO20 EPAD GND IO1 IO2 TXD0 RXD0 IO42 IO41 IO40 IO39 IO38 IO37 IO36 IO35 IO0 41 40 39 38 37 36 35 34 33 32 31 30 29 28 27 IO1 IO2 RXD0 TXD0 IO42 IO41 IO40 IO39 IO38 IO37 IO36 IO35 IO0 UART JP2 GND TMS TDI TDO TCK 1 2 3 4 GND 1 2 3 4 JTAG JP4 2 1 2 1 SW1 U1 R7 C8 GNDGND 1 2 3 4 Boot Option TBD IO3 IO46 IO9 IO10 IO11 IO12 IO13 IO14 IO21 IO33 IO34 IO45 1 2 NC USB OTG R2 EN GND IO4 IO5 GND GND IO6 C4 12pF(NC) GND X1: ESR = Max. 70 KΩ IO7 IO15 R3 0(NC) X1 IO16 R5 0(NC) 32.768KHz(NC) IO17 IO18 R8 10K GND IO8 C7 12pF(NC) IO19 VDD33 IO20 JP3 USB_D2 R6 0 2 1 USB_D+ R4 0 1 TBD 1 2 3 4 5 6 7 8 9 10 11 12 13 14 IO3 IO46 IO9 IO10 IO11 IO12 IO13 IO14 IO21 IO33 IO34 IO45 C3 15 16 17 18 19 20 21 22 23 24 25 26 C1 0 EN 0.1uF GND Figure 6: Peripheral Schematics • Soldering the EPAD to the ground of the base board is not a must, however, it can optimize thermal performance. If you choose to solder it, please apply the correct amount of soldering paste. Too much soldering paste may increase the gap between the module and the baseboard. As a result, the adhesion between other pins and the baseboard may be poor. • To ensure that the power supply to the ESP32-S2 chip is stable during power-up, it is advised to add an RC delay circuit at the EN pin. The recommended setting for the RC delay circuit is usually R = 10 kΩ and C = 1 µF. However, specific parameters should be adjusted based on the power-up timing of the module and the power-up and reset sequence timing of the chip. For ESP32-S2’s power-up and reset sequence timing diagram, please refer to ESP32-S2 Series Datasheet > Section Power Scheme. • GPIO18 works as U1RXD and is in floating state when the chip is powered on, which may affect the chip’s entry into download boot mode. To solve this issue, add an external pull-up resistor. 5 4 Espressif Systems 3 21 Submit Documentation Feedback 2 ESP32-S2-SOLO & SOLO-U Datasheet v1.6 (Chip Revision v0.0) 7 Physical Dimensions and PCB Land Pattern 7 Physical Dimensions and PCB Land Pattern 7.1 Physical Dimensions Unit: mm 3.1±0.15 0.8 15.8 0.9 0.5 1.05 Ø 1.5 13.97 40 x 0.45 0.9 3.7 3.7 10.5 10.29 5 40 x 0.9 17.6 40 x Ø0.55 0. 25.5±0.15 16.51 40 x 0.9 1.27 6 18±0.15 1.27 2.015 40 x 0.85 1 Top View Bottom View Side View Figure 7: ESP32­S2­SOLO Physical Dimensions Unit: mm 3.2±0.15 0.8 0.9 0.5 13.1 40 x 0.9 15.65 1.1 3.7 10.5 1.27 2.015 40 x 0.85 13.97 1.08 40 x 0.45 Top View 0.9 2.46 40 x Ø0.55 17.5 19.2±0.15 16.51 1.5 40 x 0.9 1.27 10.75 10.29 3 3.7 18±0.15 Bottom View Side View Figure 8: ESP32­S2­SOLO­U Physical Dimensions Note: For information about tape, reel, and product marking, please refer to Espressif Module Packaging Information. Espressif Systems 22 Submit Documentation Feedback ESP32-S2-SOLO & SOLO-U Datasheet v1.6 (Chip Revision v0.0) 7 Physical Dimensions and PCB Land Pattern 7.2 Recommended PCB Land Pattern This section provides the following resources for your reference: • Figures for recommended PCB land patterns with all the dimensions needed for PCB design. See Figure 9 ESP32-S2-SOLO Recommended PCB Land Pattern and Figure 10 ESP32-S2-SOLO-U Recommended PCB Land Pattern. • Source files of recommended PCB land patterns to measure dimensions not covered in Figure 9. You can view the source files for ESP32-S2-SOLO and ESP32-S2-SOLO-U with Autodesk Viewer. • 3D models of ESP32-S2-SOLO and ESP32-S2-SOLO-U. Please make sure that you download the 3D model file in .STEP format (beware that some browsers might add .txt). Unit: mm Via for thermal pad Copper Antenna Area 40 x1.5 40 25.5 0.9 0.5 7.5 15 0.5 1.27 10.29 1.5 0.5 3.7 0.9 3.7 40 x0.9 1 16.51 6 7.49 18 26 1.27 2.015 2.015 17.5 Figure 9: ESP32­S2­SOLO Recommended PCB Land Pattern Espressif Systems 23 Submit Documentation Feedback ESP32-S2-SOLO & SOLO-U Datasheet v1.6 (Chip Revision v0.0) 7 Physical Dimensions and PCB Land Pattern Unit: mm Via for thermal pad Copper 18 40 x1.5 40 1.19 15 0.5 1.27 19.2 10.29 7.5 0.9 3.7 40 x0.9 0.9 0.5 3.7 1.5 0.5 16.51 1 26 1.27 2.015 2.015 17.5 Figure 10: ESP32­S2­SOLO­U Recommended PCB Land Pattern Espressif Systems 24 Submit Documentation Feedback ESP32-S2-SOLO & SOLO-U Datasheet v1.6 (Chip Revision v0.0) 7 Physical Dimensions and PCB Land Pattern 7.3 Dimensions of External Antenna Connector ESP32-S2-SOLO-U uses the first generation external antenna connector as shown in Figure 11 Dimensions of External Antenna Connector. This connector is compatible with the following connectors: • U.FL Series connector from Hirose • MHF I connector from I-PEX • AMC connector from Amphenol Unit: mm Figure 11: Dimensions of External Antenna Connector Espressif Systems 25 Submit Documentation Feedback ESP32-S2-SOLO & SOLO-U Datasheet v1.6 (Chip Revision v0.0) 8 Product Handling 8 Product Handling 8.1 Storage Conditions The products sealed in moisture barrier bags (MBB) should be stored in a non-condensing atmospheric environment of < 40 °C and 90%RH. The module is rated at the moisture sensitivity level (MSL) of 3. After unpacking, the module must be soldered within 168 hours with the factory conditions 25±5 °C and 60%RH. If the above conditions are not met, the module needs to be baked. 8.2 Electrostatic Discharge (ESD) • Human body model (HBM): ±2000 V • Charged-device model (CDM): ±500 V 8.3 Soldering Profile 8.3.1 Reflow Profile Temperature (℃) Solder the module in a single reflow. Peak Temp. 235 ~ 250 ℃ 250 Preheating zone 150 ~ 200 ℃ 60 ~ 120 s 217 200 Reflow zone 217 ℃ 60 ~ 90 s Cooling zone –1 ~ –5 ℃/s Soldering time > 30 s Ramp-up zone 1 ~ 3 ℃/s 100 50 25 Time (sec.) 0 0 50 100 150 200 250 Ramp-up zone — Temp.: 25 ~ 150 ℃ Time: 60 ~ 90 s Ramp-up rate: 1 ~ 3 ℃/s Preheating zone — Temp.: 150 ~ 200 ℃ Time: 60 ~ 120 s Reflow zone — Temp.: >217 ℃ 60 ~ 90 s; Peak Temp.: 235 ~ 250 ℃ Time: 30 ~ 70 s Cooling zone — Peak Temp. ~ 180 ℃ Ramp-down rate: –1 ~ –5 ℃/s Solder — Sn-Ag-Cu (SAC305) lead-free solder alloy Figure 12: Reflow Profile Espressif Systems 26 Submit Documentation Feedback ESP32-S2-SOLO & SOLO-U Datasheet v1.6 (Chip Revision v0.0) 8 Product Handling 8.4 Ultrasonic Vibration Avoid exposing Espressif modules to vibration from ultrasonic equipment, such as ultrasonic welders or ultrasonic cleaners. This vibration may induce resonance in the in-module crystal and lead to its malfunction or even failure. As a consequence, the module may stop working or its performance may deteriorate. Espressif Systems 27 Submit Documentation Feedback ESP32-S2-SOLO & SOLO-U Datasheet v1.6 (Chip Revision v0.0) 9 MAC Addresses and eFuse 9 MAC Addresses and eFuse The eFuse in ESP32-S2 series of chips has been burnt into 48-bit mac_address. The actual addresses the chip uses in station or AP modes correspond to mac_address in the following way: • Station mode: mac_address • AP mode: mac_address + 1 There are seven blocks in eFuse for users to use. Each block is 256 bits in size and has independent write/read disable controller. Six of them can be used to store encrypted key or user data, and the remaining one is only used to store user data. Espressif Systems 28 Submit Documentation Feedback ESP32-S2-SOLO & SOLO-U Datasheet v1.6 (Chip Revision v0.0) 10 Related Documentation and Resources 10 Related Documentation and Resources Related Documentation • ESP32-S2 Series Datasheet – Specifications of the ESP32-S2 hardware. • ESP32-S2 Technical Reference Manual – Detailed information on how to use the ESP32-S2 memory and peripherals. • ESP32-S2 Hardware Design Guidelines – Guidelines on how to integrate the ESP32-S2 into your hardware product. • ESP32-S2 Series SoC Errata – Descriptions of known errors in ESP32-S2 series of SoCs. • Certificates https://espressif.com/en/support/documents/certificates • ESP32-S2 Product/Process Change Notifications (PCN) https://espressif.com/en/support/documents/pcns?keys=ESP32-S2 • ESP32-S2 Advisories – Information on security, bugs, compatibility, component reliability. https://espressif.com/en/support/documents/advisories?keys=ESP32-S2 • Documentation Updates and Update Notification Subscription https://espressif.com/en/support/download/documents Developer Zone • ESP-IDF Programming Guide for ESP32-S2 – Extensive documentation for the ESP-IDF development framework. • ESP-IDF and other development frameworks on GitHub. https://github.com/espressif • ESP32 BBS Forum – Engineer-to-Engineer (E2E) Community for Espressif products where you can post questions, share knowledge, explore ideas, and help solve problems with fellow engineers. https://esp32.com/ • The ESP Journal – Best Practices, Articles, and Notes from Espressif folks. https://blog.espressif.com/ • See the tabs SDKs and Demos, Apps, Tools, AT Firmware. https://espressif.com/en/support/download/sdks-demos Products • ESP32-S2 Series SoCs – Browse through all ESP32-S2 SoCs. https://espressif.com/en/products/socs?id=ESP32-S2 • ESP32-S2 Series Modules – Browse through all ESP32-S2-based modules. https://espressif.com/en/products/modules?id=ESP32-S2 • ESP32-S2 Series DevKits – Browse through all ESP32-S2-based devkits. https://espressif.com/en/products/devkits?id=ESP32-S2 • ESP Product Selector – Find an Espressif hardware product suitable for your needs by comparing or applying filters. https://products.espressif.com/#/product-selector?language=en Contact Us • See the tabs Sales Questions, Technical Enquiries, Circuit Schematic & PCB Design Review, Get Samples (Online stores), Become Our Supplier, Comments & Suggestions. https://espressif.com/en/contact-us/sales-questions Espressif Systems 29 Submit Documentation Feedback ESP32-S2-SOLO & SOLO-U Datasheet v1.6 (Chip Revision v0.0) Revision History Revision History Date Version Release notes • Changed Table Ordering Information to Table ESP32-S2-SOLO (ANT) Series Comparison and Table ESP32-S2-SOLO-U (CONN) Series Comparison 2023-05-25 v1.6 • Added links to some reference documents in Section 1 Module Overview • Updated EPAD descriptions in Section 6 Peripheral Schematics • Added descriptions in Section 7.2 Recommended PCB Land Pattern • Other formatting updates 2022-09-23 v1.5 • Added Section 8.4 Ultrasonic Vibration • Removed NRND watermark • Added module pictures on the title page • Added NRND watermark • Updated Section ”Learning Resources” and renamed to ”Related Docu2022-03-01 v1.4 mentation and Resources” • Added a note with a link and QR code to the latest version of the document • Updated Table 9 Current Consumption in Modem-sleep Mode and Table 10 Current Consumption in Low-Power Modes • Added module variants embedded with the ESP32-S2R2 chip • Added module description to the title page • Updated Chapter 1 Module Overview 2021-06-21 v1.3 • Updated Pin Layout (Top View), in which IO3, IO46 and IO45 are newly added • Updated Figure 9 ESP32-S2-SOLO Recommended PCB Land Pattern • Added description in Section 7.3 Dimensions of External Antenna Connector • Replaced ”chip family” with ”chip series” following Espressif’s taxonomy • Added TWAI to Chapter 1 Module Overview • Updated Table 8 Current Consumption Depending on RF Modes 2020-12-17 v1.2 • Updated the capacitance value of RC delay circuit to 1 µF in Chapter 6 Peripheral Schematics • Updated note in Section 8.3.1 Reflow Profile 2020-07-31 v1.1 Updated notes in Table Ordering Information 2020-07-22 v1.0 Official release 2020-05-19 v0.1 Preliminary release Espressif Systems 30 Submit Documentation Feedback ESP32-S2-SOLO & SOLO-U Datasheet v1.6 (Chip Revision v0.0) Disclaimer and Copyright Notice Information in this document, including URL references, is subject to change without notice. ALL THIRD PARTY’S INFORMATION IN THIS DOCUMENT IS PROVIDED AS IS WITH NO WARRANTIES TO ITS AUTHENTICITY AND ACCURACY. NO WARRANTY IS PROVIDED TO THIS DOCUMENT FOR ITS MERCHANTABILITY, NONINFRINGEMENT, FITNESS FOR ANY PARTICULAR PURPOSE, NOR DOES ANY WARRANTY OTHERWISE ARISING OUT OF ANY PROPOSAL, SPECIFICATION OR SAMPLE. All liability, including liability for infringement of any proprietary rights, relating to use of information in this document is disclaimed. No licenses express or implied, by estoppel or otherwise, to any intellectual property rights are granted herein. The Wi-Fi Alliance Member logo is a trademark of the Wi-Fi Alliance. The Bluetooth logo is a registered trademark of Bluetooth SIG. www.espressif.com All trade names, trademarks and registered trademarks mentioned in this document are property of their respective owners, and are hereby acknowledged. Copyright © 2023 Espressif Systems (Shanghai) Co., Ltd. All rights reserved.
ESP32-S2-SOLO-U-N4R2 价格&库存
很抱歉,暂时无法提供与“ESP32-S2-SOLO-U-N4R2”相匹配的价格&库存,您可以联系我们找货
