ORPC-814SA-TP-C
ORPC-814SA-TP-C
    ORIENT(奥伦德)
    SOP-4-300mil-2.54mm
    输入电压类型:AC;输出通道数:1;正向电压:1.2V;反向电压:6V;输出电流:50mA;接收端电压:80V;集射极饱和电压(Vce(sat)@Ic,IF):100mV@1mA,20mA;隔离电压(...
ORPC-814SA-TP-C 数据手册
Shenzhen Orient Components Co ., Ltd ORPC-814 ORIENT Photocoupler Product Data Sheet Name: ORPC-814 Customer:_________________ Date: _________________ SHENZHEN ORIENT COMPONENTS CO ., LTD Block A 3rd Floor No.4 Building,Tian’an Cyber Park,Huangge Rd,LongGang Dist,Shenzhen,GD TEL:0755-29681816 FAX:0755-29681200 www.orient-opto.com Copyright© 2019 Orient .All rights Reserved 1 A1 Shenzhen Orient Components Co ., Ltd ORPC-814 1. Features (1) (2) (3) (4) (5) AC input response. Current transfer ratio ( CTR : MIN. 20% at IF = ±1mA, VCE = 5V ) Wide Operating temperature range -55~110ºC High input-output isolation voltage ( Viso = 5,000Vrms ) Response time ( tr : TYP. 4us at VCE = 2V, IC = 2mA, RL = 100) (6) High collector-emitter voltage (VCE≧80V) (7) Safety approval UL approved (No.E323844) VDE approved (No.40029733) CQC approved (No.CQC09001029446 CQC13001086898) CE approved (No.AC/0431008) State Grid approved (No.SGCM013420170152 ) 2. Description (1) The ORPC-814 series of devices each consist of two infrared emitting diodes, connected in inverse parallel, optically coupled to a phototransistor detector. (2) They are packaged in a 4-pin DIP package and available in side-lead spacing and SMD option. 3. Applications (1) AC line monitor (3)Telephone line interface 4. Absolute Maximum Ratings at Ta=25℃ Parameter Input (2)Programmable controllers (4)Unknown polarity DC sensor Symbol Rated Value Unit Forward Current Peak forward current (100μs pulse, 100Hz frequency) Reverse Voltage IF ±50 mA IFP 1 A VR 6 V Consume Power P 70 mW VCEO VECO IC PC 80 6 50 150 200 5,000 -50 to + 110 -55 to + 125 260 Collector and emitter Voltage Emitter and collector Voltage Output Collector Current Consume Power Total Power Dissipation *1 Isolation Voltage Operating Temperature Storage Temperature *2 Soldering Temperature Ptot Viso Topr Tstg Tsol V mA mW mW Vrms ℃ 1. AC For 1 Minute, R.H. = 40 ~ 60% Isolation voltage shall be measured using the following method. (1) Short between anode and cathode on the primary side and between collector and emitter on the secondary side. (2) The isolation voltage tester with zero-cross circuit shall be used. (3) The waveform of applied voltage shall be a sine wave. 2. For 10 Seconds Copyright© 2019 Orient .All rights Reserved 2 A1 Shenzhen Orient Components Co ., Ltd ORPC-814 5. Electro-Optical Characteristics (Ta=25℃ unless specified otherwise) Parameter Input Output Symbol Condition Min Typ.* Max Forward Current VF IF=±20mA --- 1.2 1.4 V Collector capacitance Ct V=0, f=1KHz --- 30 250 pF Collector to emitter Current ICEO VCE=20V, IF=0mA --- --- 100 nA Collector and Emitter attenuation Voltage BV CEO 80 --- --- V Emitter and Collector attenuation Voltage BV ECO 6 --- --- V *1 Current conversion ratio CTR 20 --- 300 % 0.2 --- 3 mA --- 0.1 0.2 V --- 1×1012 --- Ω IC=0.1mA IF=0mA IE=10uA IF=0mA Unit IF=±1mA Transforming Characteristics Collector Current IC Collector and Emitter Saturation Voltage VCE(sat) Insulation Impedance R iso Floating Capacitance Cf V=0, f=1MHz --- 0.6 1.0 pF Cut-off Frequency fc V CE=5V, IC=2mA RL=100Ω, -3dB --- 80 --- kHz Rise Time tr --- 4 18 μs Descend Time tf --- 3 18 μs VCE=5V IF=±20mA IC= 1mA DC500V 40~60%R.H. VCE=2V, IC=2mA RL=100Ω *1 Current Conversion Ratio = IC / IF × 100%, CTR Tolerance:±3%. Copyright© 2019 Orient .All rights Reserved 3 A1 Shenzhen Orient Components Co ., Ltd ORPC-814 6. Rank Table of Current Transfer Ratio CTR Rank Min Max Condition A 50 150 IF =± 1mA B 100 300 VCE =5V A or B or No mark 20 300 Ta=25 ℃ ORPC-814 7. Naming Rule (1)ORPC denotes Shenzhen Orient Tech Ltd . Co ., Ltd. (2) denotes Shape Code. (3) denotes Rank code. (4) denotes Week code. (5) denotes Device Part Number. (6) denotes Year Code (7) Anode. (8) Unit:mm Copyright© 2019 Orient .All rights Reserved 4 A1 Shenzhen Orient Components Co ., Ltd ORPC-814 8. Package Dimension (Unit:mm) 1. ORPC-814 2. ORPC-814M Copyright© 2019 Orient .All rights Reserved 5 A1 Shenzhen Orient Components Co ., Ltd ORPC-814 3. ORPC-814S 9. Taping Dimensions (1) ORPC-814S-TA Copyright© 2019 Orient .All rights Reserved 6 A1 Shenzhen Orient Components Co ., Ltd ORPC-814 (2) ORPC-814S-TA1 Description Symbol Dimension in mm (inch) Tape wide W 16±0.3 (.63) Pitch of sprocket holes P0 4±0.1 (.15) F 7.5±0.1 (.295) P2 2±0.1 (.0079) P1 12±0.1 (.472) Distance of compartment Distance of compartment to compartment Copyright© 2019 Orient .All rights Reserved Package Type TA/TA1 Quantities(pcs) 1000 7 A1 Shenzhen Orient Components Co ., Ltd ORPC-814 (3) ORPC-814S-TP Description Symbol Dimension in mm (inch) Tape wide W 16±0.3 (.63) Pitch of sprocket holes P0 4±0.1 (.15) Distance of compartment F P2 7.5±0.1 (.295) Distance of compartment to compartment P1 8±0.1 (.472) 2±0.1 (.0079) Package Type Quantities(pcs) TP 2000 10. Recommended Foot Print Patterns (Mount Pad) Copyright© 2019 Orient .All rights Reserved 8 (Unit:mm) A1 Shenzhen Orient Components Co ., Ltd ORPC-814 11. Temperature Profile Of Soldering (1).IR Reflow soldering (JEDEC-STD-020C compliant) One time soldering reflow is recommended within the condition of temperature and time profile shown below. Do not solder more than three times. Profile item Conditions Preheat - Temperature Min (TSmin ) 150˚C - Temperature Max (TSmax ) 200˚C - Time (min to max) (ts) 90±30 sec Soldering zone - Temperature (TL ) 217˚C - Time (tL ) 60 sec Peak Temperature(TP) 260˚C Ramp-up rate 3˚C / sec max. Ramp-down rate Copyright© 2019 Orient .All rights Reserved 3~6˚C / sec 9 A1 Shenzhen Orient Components Co ., Ltd ORPC-814 (2).Wave soldering (JEDEC22A111 compliant) One time soldering is recommended within the condition of temperature. Temperature 260+0/-5˚C Time 10 sec Preheat temperature 25 to 140˚C Preheat time 30 to 80 sec (3).Hand soldering by soldering iron Allow single lead soldering in every single process. One time soldering is recommended. Copyright© 2019 Orient .All rights Reserved Temperature 380+0/-5˚C Time 3 sec max 10 A1 Shenzhen Orient Components Co ., Ltd ORPC-814 12. Characteristics Curves Copyright© 2019 Orient .All rights Reserved 11 A1 Shenzhen Orient Components Co ., Ltd Copyright© 2019 Orient .All rights Reserved 12 ORPC-814 A1 Shenzhen Orient Components Co ., Ltd ORPC-814 ► Notes: ①ORIENT is continually improving the quality, reliability, function or design and ORIENT reserves the right to make changes without further notices. ②When using this product, please observe the absolute maximum ratings and the instructions for use as outlined in this datasheet . ORIENT assumes no responsibility for any damage resulting from use of the product which does not comply with the absolute maximum ratings and the instructions included in this datasheet. ③ If there are any questions about the contents of this publication, please contact us at your convenience. Copyright© 2019 Orient .All rights Reserved 13 A1
ORPC-814SA-TP-C 价格&库存
很抱歉,暂时无法提供与“ORPC-814SA-TP-C”相匹配的价格&库存,您可以联系我们找货
