S EM ICOND UCTOR
500 mW LL-34 Hermetically
Sealed Glass Zener Voltage
Regulators
SURFACE MOUNT
LL34
Absolute Maximum Ratings
TA = 25°C unless otherwise noted
Parameter
Power Dissipation
Storage Temperature Range
Operating Junction Temperature
Value
Units
500
mW
-65 to +175
°C
+175
°C
DEVICE MARKING DIAGRAM
Cathode Band Color : Blue
These ratings are limiting values above which the serviceability of the diode may be impaired.
Specification Features:
Zener Voltage Range 2.0 to 75 Volts
LL-34 (Mini-MELF) Package
Surface Device Type Mounting
Hermetically Sealed Glass
Cathode
Compression Bonded Construction
Anode
All External Surfaces Are Corrosion Resistant And Terminals Are Readily Solderable
RoHS Compliant
ELECTRICAL SYMBOL
Matte Tin (Sn) Terminal Finish
Color band Indicates Negative Polarity
Electrical Characteristics
Device Type
V Z @ IZT
(Volts)
Nominal
IZT
(mA)
ZZT @ IZT
Max
IR @ V R
(A)
Max
VR
(Volts)
TCLLZ2V0
TCLLZ2V2
TCLLZ2V4
TCLLZ2V7
TCLLZ3V0
TCLLZ3V3
TCLLZ3V6
TCLLZ3V9
TCLLZ4V3
TCLLZ4V7
TCLLZ5V1
TCLLZ5V6
TCLLZ6V2
TCLLZ6V8
TCLLZ7V5
TCLLZ8V2
TCLLZ9V1
TCLLZ10V
TCLLZ11V
TCLLZ12V
2.0
2.2
2.4
2.7
3.0
3.3
3.6
3.9
4.3
4.7
5.1
5.6
6.2
6.8
7.5
8.2
9.1
10
11
12
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
100
100
100
110
120
120
100
100
100
80
80
60
60
30
30
30
120
120
120
100
50
5
5
5
5
5
5
2
0.5
0.5
0.5
0.2
0.2
0.2
0.5
0.7
1
1
1
1
1
1
1
1
1.5
2.5
3
3.5
4
5
6
7
8
9
Number: DB-059
Jan.2011/ F
Page 1
TCLLZ2V0 through TCLLZ75V
TAK CHEONG
TAK CHEONG
S EM ICOND UCTOR
Device Type
V Z @ IZT
(Volts)
Nominal
IZT
(mA)
TCLLZ13V
13
5
TCLLZ15V
15
5
TCLLZ16V
16
5
TCLLZ18V
18
5
TCLLZ20V
TCLLZ22V
22
5
TCLLZ24V
24
5
TCLLZ27V
27
2
TCLLZ30V
30
2
TCLLZ33V
33
2
TCLLZ36V
36
2
TCLLZ39V
39
2
TCLLZ43V
43
2
TCLLZ47V
47
2
TCLLZ51V
51
2
TCLLZ56V
56
2
TCLLZ62V
62
2
TCLLZ68V
68
2
TCLLZ75V
75
2
VF Forward Voltage = 1.2 V Maximum @ IF = 200 mA for all types
Notes:
1.
2.
3.
ZZT @ IZT
Max
IR @ V R
(A)
Max
VR
(Volts)
35
40
40
45
45
30
35
45
55
65
75
85
90
90
110
110
201
230
240
0.2
0.2
0.2
0.2
0.2
0.2
0.2
0.2
0.2
0.2
0.2
0.2
0.2
0.2
0.2
0.2
0.2
0.2
0.2
10
11
12
13
15
17
19
21
23
25
27
30
33
36
39
43
47
51
56
The type numbers listed have zener voltage min/max limits as shown and have a standard tolerance on the nominal zener
voltage of 5%.
For detailed information on price, availability and delivery of nominal zener voltages between the voltages shown and tighter
voltage tolerances, contact your nearest Tak Cheong Electronics representative.
The zener impedance is derived from the 60-cycle ac voltage, which results when an ac current having an rms value equal to
10% of the dc zener current (IZT or IZK) is superimposed to IZT or IZK.
Number: DB-059
Jan.2011/ F
Page 2
TAK CHEONG
S EM ICOND UCTOR
Typical Characteristics
1000
Total Capacitance [pF]
PD-Power Passipation [mW]
600
500
400
300
200
f = 1MHz
Ta = 25℃
VR = 0V
100
VR = 2V
100
VR = 30V
1
80
120
160
VZ - Reverse Voltage [V]
Temperature [℃ ]
Figure 1. Power Dissipation vs Ambient Temperature
60
80
Figure 2. Total Capacitance
Valid provided leads at a distance of 0.8mm from case are kept at
ambient temperature
1000
1000
Iz=1mA
Ta = 25℃
Ta = 25℃
Iz=2mA
100
Forward Current [mA]
Differential Zener Impedance [Ω]
VR = 20V
10
Iz=5mA
Iz=10mA
10
1
100
10
1
0.1
0.1
1
10
0.2
0.4
0.6
0.8
VF - Forw ard Voltage [mV]
1
1.2
Figure 4. Forward Current vs. Forward Voltage
Figure 3. Differential Impedance vs. Zener Voltage
300
100
PD = 500mW
Ta = 25℃
Reverse Current [mA]
PD = 500mW
Ta = 25℃
250
VR = 5V
200
150
100
50
10
1
0.1
0.01
4
6
8
Figure 5. Reverse Current vs. Reverse Voltage
10
15
25
35
45
55
65
75
Figure 6. Reverse Current vs. Reverse Voltage
Number: DB-059
Jan.2011/ F
Page 3
TAK CHEONG
S EM ICOND UCTOR
Package Outline
Package
Case Outline
B
LL-34
DIM
Inches
Min
Max
Min
Max
A
3.30
3.60
0.130
0.142
B
1.40
1.50
0.055
0.059
C
0.35
0.50
0.014
0.020
A
LL34
Millimeters
C
Notes:
1.
2.
All dimensions are within DO213AC JEDEC standard.
LL-34 polarity denoted by cathode band.
Number: DB-059
Jan.2011/ F
Page 4
TAK CHEONG
DISC LA I MER NOTIC E
NOTICE
The information presented in this document is for reference only. Tak Cheong reserves the right to make
changes without notice for the specification of the products displayed herein.
The product listed herein is designed to be used with ordinary electronic equipment or devices, and not
designed to be used with equipment or devices which require high level of reliability and the malfunction of with
would directly endanger human life (such as medical instruments, transportation equipment, aerospace
machinery, nuclear-reactor controllers, fuel controllers and other safety devices), Tak Cheong Semiconductor
Co., Ltd., or anyone on its behalf, assumes no responsibility or liability for any damagers resulting from such
improper use of sale.
This publication supersedes & replaces all information reviously supplied. For additional information, please visit
our website http://www.takcheong.com, or consult your nearest Tak Cheong’s sales office for further assistance.
Number: DB-100
April 14, 2008 / A
很抱歉,暂时无法提供与“TCLLZ6V8TR”相匹配的价格&库存,您可以联系我们找货
