RoHS Compliant
1GB DDR3 SDRAM UDIMM
Product Specifications
February 24, 2017
Version 1.2
Apacer Technology Inc.
1F., No.32, Zhongcheng Rd., Tucheng Dist., New Taipei City 236, Taiwan
Tel: +886-2-2267-8000
www.apacer.com
Fax: +886-2-2267-2261
Table of Contents
General Description ....................................................................................................... 2
Ordering Information ..................................................................................................... 2
Key Parameters .............................................................................................................. 2
Specifications: ................................................................................................................ 3
Features: ......................................................................................................................... 4
Pin Assignments ............................................................................................................. 5
Pin Descriptions ............................................................................................................. 7
Functional Block Diagram ............................................................................................. 8
Absolute Maximum Ratings .......................................................................................... 9
DRAM Component Operating Temperature Range..................................................... 10
Operating Conditions ................................................................................................... 11
Mechanical Drawing .................................................................................................... 12
©Apacer Technology Inc.
1
General Description
Apacer 78.01GJT.4000C is a 128M x 64 DDR3 SDRAM (Synchronous DRAM)
DIMM. This high-density memory module consists of 8 pieces 128M x 8 bits
with 8 banks DDR3 synchronous DRAMs in BGA packages and a 2K
EEPROM. The module is a 240-pins memory module and is intended for
mounting into a connector socket. Decoupling capacitors are mounted on the
printed circuit board for each DDR3 SDRAM. The following provides general
specifications of this module.
Part Number
Bandwidth
Speed Grade
Max Frequency
CAS Latency
78.01GJT.4000C
12.8 GB/sec
1600Mbps
800MHz
CL11
Density
Organization
Component
Rank
1GB
128M x 64
128M x8*8
1
Key Parameters
MT/s
DDR3-1066
DDR3-1333
DDR3-1600
Unit
Grade
-CL7
-CL9
-CL11
tCK (min)
1.875
1.5
1.25
ns
CAS latency
7
9
11
tCK
tRCD (min)
13.125
13.5
13.75
ns
tRP (min)
13.125
13.5
13.75
ns
tRAS (min)
37.5
36
35
ns
tRC (min)
50.625
49.5
48.75
ns
CL-tRCD-tRP
7-7-7
9-9-9
11-11-11
tCK
2
Specifications:
On-DIMM thermal sensor : No
Organization: 128 words x 64 bits, 1 rank
Integrating 8 pieces of 1G bits DDR3 SDRAM sealed FBGA
Package: 240-pin socket type dual in-line memory module (DIMM)
PCB: height 18.75 mm, lead pitch 1.0 mm (pin), lead-free (RoHS compliant)
Power supply VDD: 1.5V ± 0.075V
Serial Presence Detect (SPD)
Eight Internal banks for concurrent operation (Components)
Interface: SSTL_15
Burst lengths (BL): 8 and 4 with Burst Chop (BC)
/CAS Latency (CL): 6, 7, 8, 9, 10, 11
/CAS Write Latency (CWL): 5, 6, 7, 8
Supports auto pre-charge option for each burst access
Supports auto-refresh/self-refresh
Refresh cycles: 7.8 ㎲ at 0℃≤ TC ≤ +85℃
3
Features:
Double-date-rate architecture: 2 data transfers per clock cycle
The high-speed data transfer is realized by the 8-bits prefetch pipelined
architecture.
Bi-directional differential data strobe (DQS and /DQS) is transmitted /
received with data for capturing data at the receiver
DQS: edge-aligned with data for read; center aligned with data for write
Differential clock inputs (CK and /CK)
DLL aligns DQ and DQS transitions with CK transitions
Data mask (DM) for writing data
Posted /CAS by programmable additive latency for enhanced command
and data bus efficiency
On-Die-Termination (ODT) for improved signal quality: Synchronous
ODT/Dynamic ODT/Asynchronous ODT
Multi-Purpose Register (MPR) for temperature read out
ZQ calibration for DQ drive and ODT
Programmable Partial Array Self-Refresh (PASR)
/Reset pin for power-up sequence and reset function
SRT range: normal/extended, auto/manual self-refresh
Programmable output driver impedance control
Commands entered at each positive clock input, while data and data mask
are referenced to both edges of DQS
4
Pin Assignments
Pin No.
Pin name
Pin No.
Pin name
Pin No.
Pin name
Pin No.
Pin name
1
VREFDQ
31
DQ25
61
A2
91
DQ41
2
VSS
32
VSS
62
VDD
92
VSS
3
DQ0
33
/DQS3
63
CK1(NC)
93
/DQS5
4
DQ1
34
DQS3
64
/CK1(NC)
94
DQS5
5
VSS
35
VSS
65
VDD
95
VSS
6
/DQS0
36
DQ26
66
VDD
96
DQ42
7
DQS0
37
DQ27
67
VREFCA
97
DQ43
8
VSS
38
VSS
68
NC
98
VSS
9
DQ2
39
NC
69
VDD
99
DQ48
10
DQ3
40
NC
70
A10(AP)
100
DQ49
11
VSS
41
VSS
71
BA0
101
VSS
12
DQ8
42
NC
72
VDD
102
/DQS6
13
DQ9
43
NC
73
/WE
103
DQS6
14
VSS
44
VSS
74
/CAS
104
VSS
15
/DQS1
45
NC
75
VDD
105
DQ50
16
DQS1
46
NC
76
/CS1(NC)
106
DQ51
17
VSS
47
VSS
77
ODT1(NC)
107
VSS
18
DQ10
48
NC
78
VDD
108
DQ56
19
DQ11
49
NC
79
NC
109
DQ57
VSS
50
CKE0
80
VSS
110
VSS
21
DQ16
51
VDD
81
DQ32
111
/DQS7
22
DQ17
52
BA2
82
DQ33
112
DQS7
23
VSS
53
NC
83
VSS
113
VSS
24
/DQS2
54
VDD
84
/DQS4
114
DQ58
25
DQS2
55
A11
85
DQS4
115
DQ59
26
VSS
56
A7
86
VSS
116
VSS
27
DQ18
57
VDD
87
DQ34
117
SA0
28
DQ19
58
A5
88
DQ35
118
SCL
29
VSS
59
A4
89
VSS
119
SA2
30
DQ24
60
VDD
90
DQ40
120
VTT
5
Pin No.
Pin name
Pin No.
Pin name
Pin No.
Pin name
Pin No.
Pin name
121
VSS
151
VSS
181
A1
211
VSS
122
DQ4
152
DM3
182
VDD
212
DM5
123
DQ5
153
NC
183
VDD
213
NC
124
VSS
154
VSS
184
CK0
214
VSS
125
DM0
155
DQ30
185
/CK0
215
DQ46
126
NC
156
DQ31
186
VDD
216
DQ47
127
VSS
157
VSS
187
NC
217
VSS
128
DQ6
158
NC
188
A0
218
DQ52
129
DQ7
159
NC
189
VDD
219
DQ53
130
VSS
160
VSS
190
BA1
220
VSS
131
DQ12
161
NC
191
VDD
221
DM6
132
DQ13
162
NC
192
/RAS
222
NC
133
VSS
163
VSS
193
/CS0
223
VSS
134
DM1
164
NC
194
VDD
224
DQ54
135
NC
165
NC
195
ODT0
225
DQ55
136
VSS
166
VSS
196
A13
226
VSS
137
DQ14
167
NC
197
VDD
227
DQ60
138
DQ15
168
/RESET
198
NC
228
DQ61
139
VSS
169
CKE1(NC)
199
VSS
229
VSS
140
DQ20
170
VDD
200
DQ36
230
DM7
141
DQ21
171
A15(NC)
201
DQ37
231
NC
142
VSS
172
A14(NC)
202
VSS
232
VSS
143
DM2
173
VDD
203
DM4
233
DQ62
144
NC
174
A12
204
NC
234
DQ63
145
VSS
175
A9
205
VSS
235
VSS
146
DQ22
176
VDD
206
DQ38
236
VDDSPD
147
DQ23
177
A8
207
DQ39
237
SA1
148
VSS
178
A6
208
VSS
238
SDA
149
DQ28
179
VDD
209
DQ44
239
VSS
150
DQ29
180
A3
210
DQ45
240
VTT
*Note:
1.
CS1, ODT1, CKE1: Used for dual-rank UDIMMs; NC on single-rank UDIMMs
2.
CK1,NC and CK1,NC : Used for dual-rank UDIMMs; not used on single-rank UDIMMs, but terminated
6
Pin Descriptions
Pin Name
Description
Ax*
SDRAM address bus
BAx
SDRAM bank select
DQx
DIMM memory data bus
/RAS
SDRAM row address strobe
/CAS
SDRAM column address strobe
/WE
SDRAM write enable
/CSx
SDRAM Chip select lines
CKEx
SDRAM clock enable lines
CKx
SDRAM clock input
/CKx
SDRAM Differential clock input
DQSx
SDRAM data strobes(positive line of differential pair)
/DQSx
SDRAM data strobes(negative line of differential pair)
DMx
SDRAM input mask
SCL
Clock input for serial PD
SDA
Data input/output for serial PD
SAx
Serial address input
VDD
Power for internal circuit
VDDSPD
Serial EEPROM positive power supply
VREFDQ
SDRAM I/O reference supply
VREFCA
SDRAM command/address reference supply
VSS
Power supply return(ground)
VTT
SDRAM I/O termination supply
/RESET
ODTx
NC
*IC Component Composition:
Set DRAM to known state
On-die termination control lines
Spare pins(no connect)
128Mx8
256Mx8
512Mx8
1024Mx8
A0~A13
A0~A14
A0~A15
A0~A15
7
Rs1
DM3
8 Rs1
DQ24
to DQ31
DQ0
to DQ7
/RESET
VTT
VDDSPD
VREFCA
VREFDQ
VDD
VSS
/DQS4
ZQ
DM4
DQ32
to DQ39
Rs3
Rs3
Rs4
/CK
Rs4
/CK
ZQ
CK
DQ0
to DQ7
/CS
ODT
CKE
Address
BA
Command
DM
CK
/CS
ODT
CKE
Address
BA
Command
D6
/DQS
Rs1
Rs1
Rs1
8 Rs1
DM
DQ0
to DQ7
DQS
D4
/DQS
DM
DQ0
to DQ7
ZQ
Rs4
D5
/DQS
/CK
Rs1
DQS
CK
Rs1
ZQ
Serial PD
/RESET:SDRAMs (D0 to D7)
SPD
SDRAMs (D0 to D7)
SDRAMs (D0 to D7)
SDRAMs (D0 to D7)
SCL
SCL
SA0
A0
SA1
SA2
A1
A2
SDA
U0
WP
SDRAMs (D0 to D7), SPD
Notes :
1. DQ wiring may be changed within a byte.
2. DQ, DQS, /DQS, ODT, DM, CKE, /CS relationships
must be maintained as shown.
DQS
ZQ
Rs1
DM5
8 Rs1
DQ40
to DQ47
DQS4
DQ0
to DQ7
/CS
ODT
CKE
Address
BA
Command
/CK
CK
Rs4
Rs4
/CK
CK
/DQS5
D3
/DQS
Rs1
Rs2
Rs2
Rs2
Rs2
Rs2
DQS
DM
DQS5
ZQ
Rs1
DM
Rs4
Rs1
DQ0
to DQ7
Rs1
D7
/DQS
/CK
/DQS3
Rs1
DM
8 Rs1
DM6
8 Rs1
DQ48
to DQ55
D2
/DQS
Rs1
DQS
CK
DQS3
Rs1
8 Rs1
DQS
ZQ
Rs1
Rs1
/CS
ODT
CKE
Address
BA
Command
DQ16
to DQ23
Rs1
DQ0
to DQ7
/DQS6
Rs4
DM2
Rs1
/DQS
DM
DQ56
to DQ63
D1
Rs4
/DQS2
8 Rs1
DM7
DQS6
/CK
DQS2
Rs1
DQS
CK
DM1
DQ8
to DQ15
Rs1
DQ0
to DQ7
ZQ
/CK
/DQS1
Rs1
DM
/DQS7
CK
DQS1
8 Rs1
/DQS
/CS
ODT
CKE
Address
BA
Command
DQ0
to DQ7
Rs1
DQS7
D0
/CS
ODT
CKE
Address
BA
Command
DM0
DQS
/CS
ODT
CKE
Address
BA
Command
/DQS0
Rs1
VDD
VTT
/CS
ODT
CKE
Address
BA
Command
/CK0
CK0
3
Command
17
Address, BA
/CS0
ODT0
CKE0
Rs1
DQS0
* D0 to D7: 1G bits DDR3 SDRAM
Address, BA: A0 to A13, BA0 to BA2
Command: /RAS, /CAS, /WE
U0: 256 bytes EEPROM
Rs1: 15Ω
Rs2: 39Ω
Rs3: 36Ω
Rs4: 240Ω
8
SDA
Parameter
Symbol
Description
Units
Voltage on VDD pin relative to Vss
VDD
- 0.4 V ~ 1.975 V
V
Voltage on VDDQ pin relative to Vss
VDDQ
- 0.4 V ~ 1.975 V
V
Voltage on any pin relative to Vss
VIN, VOUT
- 0.4 V ~ 1.975 V
V
Storage Temperature
TSTG
-55 to +100
Notes:
1.
Stresses greater than those listed under “Absolute Maximum Ratings” may cause permanent damage to the
device. This is a stress rating only and functional operation of the device at these or any other conditions above
those indicated in the operational sections of this specification is not implied. Exposure to absolute maximum
rating conditions for extended periods may affect reliability.
2.
Storage Temperature is the case surface temperature on the center/top side of the DRAM. For the measurement
conditions, please refer to JESD51-2 standard.
3.
VDD and VDDQ must be within 300mV of each other at all times; and VREF must not be greater than 0.6 x VDDQ,
when VDD and VDDQ are less than 500mV; VREF may be equal to or less than 300mV.
9
Range
Symbol
TOPER
Parameter
Rating
Units
Notes
Normal Operating Temperature Range
0 to 85
1,2
Extended Temperature Range
85 to 95
1,3
Notes:
1.
Operating Temperature TOPER is the case surface temperature on the center / top side of the DRAM. For
measurement conditions please refer to the JEDEC document JESD51-2.
2.
The Normal Temperature Range specifies the temperatures where all DRAM specifications will be supported
during operation, the DRAM case temperature must be maintained between 0℃ - 85℃ under all operating
conditions.
3.
Some applications require operation of the DRAM in the Extended Temperature Range between 85℃ and 95℃
case temperature. Full specifications are guaranteed in this range, but the following additional conditions apply:
a.
Refresh commands must be doubled in frequency, therefore reducing the Refresh interval tREFI to 3.9 µs.
b.
If Self-Refresh operation is required in the Extended Temperature Range, then it is mandatory to either
use the Manual Self-Refresh mode with
Extended Temperature Range capability (MR2 A6 = 0b and
MR2 A7 = 1b), in this case IDD6 current can be increased around 10~20% than normal Temperature
range.
10
Recommended DC Operating Conditions - DDR3 (1.5V) operation
Symbol
VDD
Rating
Parameter
Supply Voltage
VDDQ Supply Voltage for Output
Typ.
Max.
1.425
1.5
1.575
V
1.425
1.5
1.575
V
Notes:
1.
Under all conditions VDDQ must be less than or equal to VDD..
2.
VDDQ tracks with VDD. AC parameters are measured with VDD and VDDQ tied together.
11
Units
Min.
Mechanical Drawing
Unit: mm
(All dimensions are in millimeters with ±0.15mm tolerance unless specified otherwise.)
12
Revision History
Revision
Date
Description
0.9
08/28/2012
Official release
1.0
08/29/2012
release
1.1
07/23/2013
Changed headquarters address
1.2
05/08/2015
Updated Mechanical Drawing
Remark
13
Global Presence
Taiwan (Headquarters)
New Taipei City 236, Taiwan R.O.C.
amtsales@apacer.com
U.S.A.
Apacer Memory America, Inc.
46732 Lakeview Blvd., Fremont, CA 94538
Tel: 1-408-518-8699
Fax: 1-510-249-9568
sa@apacerus.com
Japan
Apacer Technology Corp.
5F, Matsura Bldg., Shiba, Minato-Ku
Tokyo, 105-0014, Japan
Tel: 81-3-5419-2668
Fax: 81-3-5419-0018
jpservices@apacer.com
Europe
Apacer Technology B.V.
Science Park Eindhoven 5051 5692 EB Son,
The Netherlands
Tel: 31-40-267-0000
Fax: 31-40-290-0686
sales@apacer.nl
China
Apacer Electronic (Shanghai) Co., Ltd.
Room D, 22/FL, No.2, Lane 600, JieyunPlaza,
Tianshan RD , Shanghai , 200051, China
Tel: 86-21-6228-9939
Fax:86-21-6228-9936
sales@apacer.com.cn
India
Apacer Technologies Pvt Ltd.
Unit No.201, "Brigade Corner", 7th Block Jayanagar,
Yediyur Circle, Bangalore – 560082, India
Tel: 91-80-4152-9061
Fax: 91-80-4170-0215
sales_india@apacer.com
14
