AOPS150-24
AOPS150-24
    ETA-USA
    UNIVERSAL, SINGLE OUTPUT, ENCLOS
AOPS150-24 数据手册
AOPS150 Series 150 Watt AC/DC Power Supply Universal Input Inrush current protection Over Voltage Protection Over Current Protection CE recognized 2 year Warranty UNIT INPUT Voltage/Freq V Current Typ. 110V 220V Power Fac 110V 220V Inrush Current Leakage A A mA UNIT OUTPUT AC100V - 240V (AC85V ~ 264V or DC125V~ 370V), 50 / 60Hz (47 ~ 440Hz) Universal Input voltage 1.3 2.0 0.65 @ 3.3 VDC 1.0 0.98 0.99 0.91 @ 3.3VDC 0.95 all other voltages 110V 20 ( Ta=25 , Io=100% at cold Start ); 220V 40 ( Ta=25 , Io=100% at cold Start ) 110V=0.4 220V=0.75 AOPS150-3.3 AOPS150-5 AOPS150-9 AOPS150-12 Nominal Voltage VDC 3.3 5 9 12 Efficiency typ % Current Line Regulation Load Regulation Ripple Ripple Noise maximum Temperature Drift [0-+50C] Rise Time Hold up Time A mV mV mVp-p mVp-p 77 80 30 25 50 80 120 80 82 30 25 50 80 120 83 85 16.7 45 90 90 140 82 86 12.5 60 120 120 170 mV 50 75 135 180 mS mS 500 max [AC IN 85 I0 =100%] 17 typ [AC IN 85V,I0 =100%] 10.3-12.6 18.3-43.5 - 13.8-16.8 13.7-18.1 - OVP OCP Remote ON OFF Remote Sensing Power Fail Signal Parallel/Series Operation Cooling OTP 3.8-4.6 5.7-7.0 33.0-43.5 33.0-43.5 Series operation possible Convection Cooling UNIT OUTPUT AOPS150-48 15 24 48 Efficiency typ % Current Line Regulation Load Regulation Ripple Ripple Noise maximum Temperature Drift [0-+50C] Rise Time Hold up Time A mV mV mVp-p mVp-p 83 87 10 75 150 150 200 85 88 6.3 120 240 240 290 87 89 3.2 240 480 480 530 mV 225 360 720 mS mS 500 max [AC IN 85 I0 =100%] 17 typ [AC IN 85V,I0 =100%] Isolation Environment Size AOPS150-24 VDC OVP OCP Remote ON OFF Remote Sensing Power Fail Signal Parallel/Series Operation Cooling OTP Safety AOPS150-15 Nominal Voltage Input-Output Input-Case Output-Case Operating temp/hum Storage temp/hum Vibration Impact RU/CE Line Emission MM/G 17.2-21. 27.6-33.6 11.0-14.5 6.9-9.1 Series operation possible Convection Cooling 55.2-67.2 3.5-4.7 - AC 3,000V 1 minute current 20mA, DC 500V 50MΩ (At room temperature & Humidity) AC 2,000V 1 minute current 20mA, DC 500V 50MΩ (At room temperature & Humidity) AC 500V 1 minute current 100mA, DC 500V 50MΩ (At room temperature & Humidity) -10 ~ +70 , 20 ~ 90% RH(Non condensing) -20 ~ +75 , 20 ~ 90% RH(Non condensing) 10 ~ 55Hz at 1G, 3 minutes period, 30 minutes along X, Y and Z axis 10G for 20ms once on each X, Y and Z axis RU EN55022-A 82x45x175 560 grams BLOCK DIAGRAM Terminal Output DIMENSIONAL DRAWING (mm) OUTPUT DERATING CURVE AND RECCOMENDED MOUNTING DIAGRAM AOPS150-5 AOPS150-12 AOPS150-24 SERIES WIRING DIAGRAM
AOPS150-24 价格&库存
很抱歉,暂时无法提供与“AOPS150-24”相匹配的价格&库存,您可以联系我们找货
