AOPS150 Series
150 Watt AC/DC Power Supply
Universal Input
Inrush current protection
Over Voltage Protection
Over Current Protection
CE recognized
2 year Warranty
UNIT
INPUT
Voltage/Freq
V
Current Typ. 110V
220V
Power Fac 110V
220V
Inrush Current
Leakage
A
A
mA
UNIT
OUTPUT
AC100V - 240V (AC85V ~ 264V or DC125V~ 370V), 50 / 60Hz (47 ~ 440Hz) Universal
Input voltage
1.3
2.0
0.65 @ 3.3 VDC
1.0
0.98
0.99
0.91 @ 3.3VDC
0.95 all other voltages
110V 20 ( Ta=25 , Io=100% at cold Start ); 220V 40 ( Ta=25 , Io=100% at cold Start )
110V=0.4
220V=0.75
AOPS150-3.3
AOPS150-5
AOPS150-9
AOPS150-12
Nominal Voltage
VDC
3.3
5
9
12
Efficiency typ
Current
Line Regulation
Load Regulation
Ripple
Ripple Noise
maximum
Temperature
Drift [0-+50C]
Rise Time
Hold up Time
A
mV
mV
mVp-p
mVp-p
77
80
30
25
50
80
120
80
82
30
25
50
80
120
83
85
16.7
45
90
90
140
82
86
12.5
60
120
120
170
mV
50
75
135
180
mS
mS
500 max [AC IN 85 I0 =100%]
17 typ [AC IN 85V,I0 =100%]
10.3-12.6
18.3-43.5
13.8-16.8
13.7-18.1
OVP
OCP
Remote ON OFF
Remote Sensing
Power Fail Signal
Parallel/Series Operation
Cooling OTP
3.8-4.6
5.7-7.0
33.0-43.5
33.0-43.5
Series operation possible
Convection Cooling
UNIT
OUTPUT
AOPS150-48
15
24
48
Efficiency typ
Current
Line Regulation
Load Regulation
Ripple
Ripple Noise
maximum
Temperature
Drift [0-+50C]
Rise Time
Hold up Time
A
mV
mV
mVp-p
mVp-p
83
87
10
75
150
150
200
85
88
6.3
120
240
240
290
87
89
3.2
240
480
480
530
mV
225
360
720
mS
mS
Isolation
Environment
Size
AOPS150-24
VDC
OVP
OCP
Remote ON OFF
Remote Sensing
Power Fail Signal
Cooling OTP
Safety
AOPS150-15
Nominal Voltage
Input-Output
Input-Case
Output-Case
Operating temp/hum
Storage temp/hum
Vibration
Impact
RU/CE
Line Emission
MM/G
17.2-21.
27.6-33.6
11.0-14.5
6.9-9.1
Convection Cooling
55.2-67.2
3.5-4.7
AC 3,000V 1 minute current 20mA, DC 500V 50MΩ (At room temperature & Humidity)
AC 2,000V 1 minute current 20mA, DC 500V 50MΩ (At room temperature & Humidity)
AC 500V 1 minute current 100mA, DC 500V 50MΩ (At room temperature & Humidity)
-10 ~ +70 , 20 ~ 90% RH(Non condensing)
-20 ~ +75 , 20 ~ 90% RH(Non condensing)
10 ~ 55Hz at 1G, 3 minutes period, 30 minutes along X, Y and Z axis
10G for 20ms once on each X, Y and Z axis
RU
EN55022-A
82x45x175
560 grams
BLOCK DIAGRAM
Terminal Output
DIMENSIONAL DRAWING (mm)
OUTPUT DERATING CURVE AND RECCOMENDED MOUNTING
DIAGRAM
AOPS150-5
AOPS150-12
AOPS150-24
SERIES WIRING DIAGRAM
很抱歉,暂时无法提供与“AOPS150-12”相匹配的价格&库存,您可以联系我们找货
