AC Output Buffered Modules
• Compatible with 5 & 15
Volt Logic Systems
• Buffered Inverting and
Non-Inverting Modules
• Zero Voltage AC Switching
INPUT SPECIFICATIONS
Buffered output modules contain additional internal amplification to reduce
drive requirements to a level suitable for
the MOS devices used in many microprocessor systems. To further reduce
the need for additional interface components, they are available with both
inverting and non-inverting inputs, for
5 volt or 15 volt logic.
6411
6421
6412
6422
Nominal Input Voltage [Vdc]
Output Module Type
Must Turn On Voltage Range @ pin 4 [Vdc]
5
Non-Inverting
0.0 - 0.8
5
Inverting
2.4 - 6.0
5
Non-Inverting
0.0 - 0.8
5
Inverting
2.4 - 6.0
Must Turn Off Voltage Range @ pin 4 [Vdc]
Max. Input On-Current (Sink) @ pin 4 [µA]
2.4 - 6.0
75 @ 0.8V
100 @ 0.0V
10
3.5 - 6.0
0.0 - 0.8
75 @ 2.4V
250 @ 6.0V
10
3.5 - 6.0
2.4 - 6.0
75 @ 0.8V
100 @ 0.0V
10
3.5 - 6.0
0.0 - 0.8
75 @ 2.4V
250 @ 6.0V
10
3.5 - 6.0
6441
6451
6442
6452
15
Non-Inverting
0.0 - 2.0
8.0 - 18
175 @ 2.0V
250 @ 0.0V
10
10 - 18
25
22
15
Inverting
8.0 - 18
0.0 - 2.0
75 @ 8.0V
200 @ 18V
10
10 - 18
25
22
15
Non-Inverting
0.0 - 2.0
8.0 - 18
175 @ 2.0V
250 @ 0.0V
10
10 -18
25
22
15
Inverting
8.0 - 18
0.0 - 2.0
75 @ 8.0V
200 @ 18V
10
10 -18
25
22
0.02 - 3.5
12 - 140
80
1.5
5.0
1/2 Cycle
1/2 Cycle
400
0.02 - 3.5
12 - 140
80
1.5
5.0
1/2 Cycle
1/2 Cycle
400
0.02 - 3.5
24 - 280
80
1.5
5.0
1/2 Cycle
1/2 Cycle
600
0.02 - 3.5
24 - 280
80
1.5
5.0
1/2 Cycle
1/2 Cycle
600
(All voltages referenced to pin 5)
Max. Input On-Current (Source) @ pin 4 [µA]
Max. Output Off-State Input Current @ pin 4 [µA] ➁
Logic Supply Voltage Range [Vdc]
Max. Logic Supply Current @ 5Vdc (w/o LED) [mA] ➀
Max. Logic Supply Current @ 5Vdc (w/ LED) [mA] ➀
Output Module Type
Max. Input Current for Output Off-State @ pin 4 [µA] ➁
OUTPUT SPECIFICATIONS
Load Current Range @ 45˚ C [A]
Load Voltage Range [Vdc]
Max. Surge Current 1 Cycle (Non-Rep) [Apk]
Max. On-State Voltage [Vdc]
Max. Off-State Leakage [mA]
Max. Turn On Time
Max. Turn Off Time
Transient Overvoltage [Vpk]
GENERAL NOTES
➀ LED optional. Placed in series with pin 3 for
status indication.
➁ Max. allowable leakage current from driver
maintain output off-state.
FastFax Document No. 308
081398, PAGE 1 OF 2
©1998 CRYDOM CORP Specifications subject to change without notice.
For recommended applications and more information contact:
USA: (800) 8 CRYDOM • (800) 827-9366 • (619) 715-7200 • fax (619) 715-7280
Crydom Corp, 9525 Chesapeake Drive, San Diego, CA 92123 • e-mail: sales@crydom.com
WEB SITE: http://www.crydom.com FASTFAX Product Information: (888) 267-9191
UK: (44)1202 812300 • fax (44)1202 812340 Crydom International Ltd., 85, Condor Close,
Woolsbridge Industrial Estate, Three-Legged Cross. Wimborne, Dorset, England BH21 6SU
GERMANY: (49) (0)6874 182580 • fax (49)(0)6874 182585 Crydom GmbH,
Gewerbegebiet Im Schachen, D-66687 Nunkirchen, Germany • e-mail: vertrieb@crydom.com
9002
GENERAL SPECIFICATIONS
Min. Dielectric Input/Output (1 Minute)
4,000 VRMS
Min. Isolation Resistance Input/Output (@ 500V)
1010 Ohms
Capacitance input to output
8 pF
Temperature Range — Operating
-40˚ C to 80˚ C
Temperature Range — Storage
-40˚ C to 125˚ C
C U R R E N T D E R AT I N G C U RV E
WIRING & MECHANICAL DIAGRAMS
LOAD CURRENT (AMPS)
3.5
DC LOGIC
SUPPLY
STATUS
LED
①
AC
OUTPUT
3
1
LOAD
3.0
DC LOGIC INPUT
2.5
INV or
NON-INV
LOGIC
4
Zero
Switch
2.0
2
5
COM (-)
1.5
1.0
BOTTOM VIEW
60
80
.30
(7.6)
AMBIENT TEMPERATURE (ºC)
Max. Load Current vs. Temp.
CAPTIVE
#4-40. PHILLIPS
HEAD HOLD
DOWN SCREW
BUFFERED OUTPUT MODULES
A buffered non-inverting module turns on when pin 4 is held in the
low state (logic 0), the same as standard modules driven in the sink
mode. A buffered inverting module conversely turns on when pin 4
is held high (logic 1). In the absence of an input signal and/or logic
supply (open Circuit), all models will be in the off-state.
Buffered modules may be used with standard 5 pin PB or MS
mounting boards. However, the 3.3K pull-up resistor will add to the
logic drive current of a non-inverting module and may be removed.
For an inverting module, the resistor must be removed to avoid a
false “on” command, unless a “normally closed” condition is desirable for use with a ground seeking (logic 0) signal source.
1.70
(43.1)
.60
(15.2)
.100
(2.5)
1.00
(25.4)
1.25
(31.7)
.25
(6.3)
5
4
3
2
1
.30
(7.6)
.040 (1.0) DIA.
(5 PLACES)
.70
(17.8)
1.20
(30.5)
1.40
(35.5)
1.60
(40.6)
All dimensions are in inches (millimeters)
081398, PAGE 2 OF 2
9002
很抱歉,暂时无法提供与“6422”相匹配的价格&库存,您可以联系我们找货
