GMX-N-88-50
GMX-N-88-50
    KYCON
    MODJACK LOW/PROF RT< 8P8C BLACK
GMX-N-88-50 数据手册
2D Drawing IGES STEP 3D PDF Solder Profile CofC RoHS Compliant CofC REACH Compliant UL Plastic File Certificate of Origin Check Stock Request a Sample Send Us An Email Generated Part Number GMX-N-44 Part Number Builder LR78160 MODULAR JACKS AND PLUGS: GMX Series Right Angle Modular Jack, Low Profile Product Features 0.45” Height Low Profile Design Suitable for PC Add-On Board Applications Snap in Board Retention Tabs Available in 4, 6, 8, and 10 Position Housings Available Fully Shielded for EMI/RFI Protection CSA/NRTL Certified File No. LR78160 Performance Specifications Materials and Finish Housing Material PBT Thermoplastic, UL 94V-0 Rated, Black Color Shield Material Copper Alloy, Nickel Plated Contact Material Phosphor Bronze Electrical Characteristics Insulation Resistance 500 Megohms Min. Dielectric Withstanding Voltage 1000V RMS, 60Hz Contact Resistance 20 milliohms Max. Current Rating 1.5A Voltage Rating 125V DC Operating Temperature -40°C to +85°C Durability 500 Mating Cycles Min. GMX N 44 Series Shield Option No. of Positions & Contacts Keyed Options Plating Options Series GMX - Right Angle, PCB Mount Shield Options N - Non-Shielded S - Fully Shielded (Available with 6 -10 Positions) S2 - Shielded with Grounding Tab (Available with only 8 Positions) S7 - Shielded with Side & Top Grounding (Available with only 8 Positions) Number of Positions / Contacts 44 - 4 Positions / 4 Contacts ( only with N Option) 64 - 6 Positions / 4 Contacts 66 - 6 Positions / 6 Contacts 88 - 8 Positions / 8 Contacts 1010 - 10 Positions / 10 Contacts Keyed Option Blank - Not Keyed Plating Option Blank - Gold Flash 50 - 50µ" Gold Plating Contact Kycon for Other Options GMX Series Dimensions in mm GMX-N-44-x Phone: +1.408.494.0330 l Fax: +1.408.494.0325 l WWW.KYCON.COM l 0417
GMX-N-88-50 价格&库存
很抱歉,暂时无法提供与“GMX-N-88-50”相匹配的价格&库存,您可以联系我们找货
