1000 Eaton Boulevard
Cleveland, OH 44122
United States
Safe-IT Cat6a 10G Snagless Antibacterial UTP
Ethernet Cable (RJ45 M/M), PoE, White, 20 ft.
(6.09 m)
Highlights
Premium Cat6a cable rated for
high-speed 10 Gbps home/office
communications
Made with antibacterial material
proven effective in inhibiting the
growth of E. coli and staph
Snagless RJ45 connectors
protect locking tabs against
damage during installation
24 AWG copper wire and 3 µm
gold-plated contacts allow
superior signal transfer
White jacket permits fast, easy
identification in a crowded
switch or patch panel
MODEL NUMBER: N261AB-020-WH
Applications
Connects critical components, such as switches and servers, in 10G Ethernet networks, while also
providing extra protection against bacteria.
Features
Cat6a Cable Ideal for Connecting Equipment in Your 10G Ethernet Network
This Cat6a Ethernet cable (M/M) with RJ45 connectors transmits 10 Gbps data, voice and video through
high-speed 10G equipment, including network switches, modems, servers, routers, adapters, hubs and
patch panels, in high-density data centers. Designed for fast transmission and excellent signal quality, this
Cat6a cable ensures peak performance throughout your local area network (LAN).
Provides Extra Protection Against Certain Bacteria
The connectors and PVC jacket are constructed using an antibacterial material that is effective in
inhibiting the growth of Escherichia coli (E. coli) and Staphylococcus aureus (staph). This added
protection makes this cable an ideal solution for medical facilities, schools, businnts/kitchens and
anywhere else that wants extra protection against bacteria.
Snagless RJ45 Male Connectors Keep Tabs Intact During Installation
The RJ45 connectors’ snagless design protects the locking tabs from being damaged or broken off during
installation. Integral strain relief gives the cable extra flexibility, reduces stress and helps the cable move
freely without cracking or breaking loose from the connector.
Premium Construction for Superior Performance
Manufactured from 24 AWG copper wire, the four-pair stranded cable is rated for speeds up to 10 Gbps.
The RJ45 connectors improve near-end crosstalk (NEXT) performance to 500 MHz and feature 3-micron
gold plating to help ensure the most accurate signal transfer possible.
White Jacket Helps Avoid Misidentification That Can Cause Costly Downtime
The cable has a white PVC jacket, which is easy to identify quickly in a crowded patch panel or switch and
helps prevent the cable from becoming accidentally disconnected.
Specifications
1/3
Connect a computer and its
peripherals to a home or office
Connect switches, modems and
servers in a high-density data
center
Provide extra protection against
bacteria to give cable installers
and IT personnel peace of mind
during installation
Package Includes
N261AB-020-WH Cat6a 10G
Certified Snagless Antibacterial
UTP Ethernet Cable (RJ45 M/M),
White, 20-ft. (6.09 m)
Cleveland, OH 44122
United States
OVERVIEW
UPC Code
037332259820
Technology
Cat6a
PHYSICAL
Cable Jacket Color
White
Cable Jacket Material
PVC
Cable Jacket Rating
CMX
Cable Shielding
UTP
Cable Outer Diameter (OD)
6.2 mm
Number of Conductors
4 Pair
Conductor Material
Stranded Copper
Conductor Gauge
24 AWG
Cable Length (ft.)
Cable Length (m)
6.10
Cable Length (in.)
240
Shipping Dimensions (hwd / in.)
10.00 x 8.00 x 0.50
Shipping Weight (kg)
0.25
ENVIRONMENTAL
Operating Temperature Range
14° to 122°F (-10° to 50°C)
Storage Temperature Range
5° to 140°F (-15° to 60°C)
Operating Humidity Range
0% to 90% RH, Non-Condensing
Storage Humidity Range
COMMUNICATIONS
Bandwidth per TIA Standard
500 MHz
Maximum Bandwidth as Tested
600 MHz
Network Compatibility
10 Gbps
IEEE Standards Supported
802.3an; 802.3at
CONNECTIONS
PoE Capability
30W (802.3at)
Side A - Connector 1
RJ45 (MALE)
Side B - Connector 1
RJ45 (MALE)
Crossover Wiring
No
2/3
Cleveland, OH 44122
United States
Contact Plating
Gold
PoE Type
Type 2 PoE+ (30W, IEEE 802.3at)
Connector Type
Molded; Snagless
Wiring Configuration
EIA/TIA 568B
Angled Connector
No
FEATURES & SPECIFICATIONS
Antimicrobial
No
Antibacterial
Yes
IP68 Rated
No
Snagless Connector
Yes
STANDARDS & COMPLIANCE
Product Certifications
UL Listed; cUL Listed
Product Compliance
CE (Europe); RoHS; IEEE 802.3an 10GBase-T; IEEE 802.3at PoE+; REACH; UKCA; Trade Agreements Act (TAA)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“N261AB-020-WH”相匹配的价格&库存,您可以联系我们找货
