1000 Eaton Boulevard
Cleveland, OH 44122
United States
U.2 to PCIe Adapter for 2.5" NVMe U.2 SSD, SFF8639, PCI Express (x4) Card
MODEL NUMBER: PCE-U2-PX4
Highlights
Supports U.2 SSDs and 2.5 in.
SATA I/II/III SSDs and HDDs
PCIe U.2 SSD speed provides
your computer with faster data
access
Compatible with P970-U2M2 for
installing an M.2 module
Works with PCIe 3.0
motherboards; backward
compatible with 2.0 and 1.0
Plug-and-play operation with no
software required for easy,
immediate installation
System Requirements
U.2 (SFF-8639) SSD and 2.5"
SATA I/II/III SSD/HDD
M.2 modules like B+M Key
SATA M.2 SSD and M-Key
NVMe M.2 SSD (2242, 2260
and 2280 SSD sizes) when
combined with P970-U2M2
Compatible PCIe motherboard
with open x4/x8/x16 slot
Windows 7 and above or
macOS High Sierra and above
(older macOS versions do not
support NVMe)
Mounts a NVMe U.2 SSD inside your PC or server to increase data transfer speed and internal storage.
Features
Improves Your Computer or Server’s Performance and Storage Capabilities
This U.2 to PCI Express (PCIe) adapter connects a U.2 SSD or a 2.5-inch SATA SSD or HDD to your
computer or server’s PCIe expansion slot. By converting a PCIe (SFF-8639) host interface, you can add
terabytes (TB) of internal storage space and enhance your PC’s read/write speeds. The adapter is
compatible with PCIe 3.0 motherboards. It is also backward compatible with earlier 2.0 and 1.0 versions.
Add an Optional M.2 Adapter for Expanded Functionality
The PCE-U2-PX4 is compatible with P970-U2M2 U.2 to M.2 NVMe adapter (sold separately) to convert
the PCIe expansion slot into an M.2 SSD module.
Just Plug and Play with No External Power Needed
Use the included 7-pin SATA cable to connect the PCE-U2-PX4 to the motherboard. No additional
software or power is needed. The adapter is compatible with Windows (7 and higher) and macOS (High
Sierra and higher).
Specifications
OVERVIEW
UPC Code
037332275349
Drives Supported
U.2 SSD/HDD
Device Compatibility
Computer
Technology
PCIe
INPUT
1/2
Package Includes
PCE-U2-PX4 U.2 to PCIe
Adapter
(2) Bracket screws
(4) SSD screws
Screwdriver
7-pin SATA cable
Quick Start Guide
Cleveland, OH 44122
United States
Bus Powered
Yes
PHYSICAL
Color
Black
Cable Length (ft.)
1.38
Cable Length (m)
0.42
Cable Length (in.)
16.5
Unit Dimensions (hwd / in.)
5.510 x 4.760 x 0.860
ENVIRONMENTAL
Operating Temperature Range
50° to 158°F (10° to 70°C)
Storage Temperature Range
32° to 149°F (0° to 65°C)
Relative Humidity
10% to 80% RH
CONNECTIONS
Number of Ports
2
Side A - Connector 1
SF-8639 (MALE)
Side B - Connector 1
7-PIN SATA (FEMALE)
STANDARDS & COMPLIANCE
Product Certifications
EN 55032
Product Compliance
CE (Europe); FCC (USA); REACH; RoHS3; UKCA
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
1-year limited warranty
© 2024 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
2/2
很抱歉,暂时无法提供与“PCE-U2-PX4”相匹配的价格&库存,您可以联系我们找货
