SU160KMBPKX
SU160KMBPKX
    TRIPPLITE
    UPS MAINTENANCE BYPASS PANEL FOR
SU160KMBPKX 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States UPS Maintenance Bypass Panel for Select 400V 3-Phase UPS Systems - 3 Breakers MODEL NUMBER: SU160KMBPKX Highlights ● Isolates UPS from connected loads for maintenance without losing network availability ● Maintenance bypass panel mounts to wall next to UPS for convenient access ● 300A 10 kAIC unit has 3 built-in circuit breakers connected to heavy-duty buswork ● Secure Kirk-key interlock system prevents unauthorized access to power ● Compatible with SVX150KL and S3M160KX 3-phase UPS systems Applications ● UPS bypass panel reroutes power to keep essential equipment operational while the UPS is inoperative or under maintenance. System Requirements ● Features UPS Maintenance Bypass Panel Keeps Equipment Powered During UPS MaintenanceThis wallmount three-breaker maintenance bypass panel is compatible with SVX150KL and S3M160KX 3-phase UPS systems. It allows you to reroute power around the UPS, providing an alternate path for electricity that keeps the connected load operational while the UPS is offline for maintenance or repairs. Features 3 Built-In Circuit Breakers to Isolate LoadsThree circuit breakers – an AC input breaker, a maintenance bypass breaker and a maintenance isolation breaker – are connected to heavy-duty buswork and isolate the UPS system from its connected load with no loss of network availability. This allows the load to remain continuously powered without costly downtime. A Kirk-key interlock system enhances safety and security. Removable handles allow the panel’s trim cover to be removed for internal access. The 300A unit has a kAIC rating of 10K. Switching Between Normal and Bypass Modes Is EasyWhen a UPS needs maintenance, this UPS bypass panel keeps power supplied to components via its mechanical interlock system by switching power to the external bypass breaker. Simply unscrew the interlock switch, rotate the switch from the UPS AC input breaker (SW1) to the bypass breaker (SW2), then turn on the bypass breaker and turn off the UPS and isolation breaker (SW3) to perform UPS maintenance without service interruption. Convenient Wall-Mount InstallationMade of galvanized steel, the service bypass panel has rear mounting holes for installation on a smooth, solid wall (mounting hardware not included). Specifications OVERVIEW UPC Code 037332241122 Accessory Type Bypass Panel Accessory Class UPS Accessories 1/2 Bypass a compatible offline 3phase UPS system to continue powering mission-critical equipment without interruption SVX150KL and S3M160KX 3phase UPS system Package Includes ● SU160KMBPKX UPS Maintenance Bypass Panel - 3 Breakers ● Installation and Operation Manual 1000 Eaton Boulevard Cleveland, OH 44122 United States INPUT Nominal Input Voltage(s) Supported 480V AC Voltage Compatibility (VAC) 480 PHYSICAL Form Factors Supported Wallmount Shipping Dimensions (hwd / in.) 36.00 x 42.00 x 14.00 Shipping Dimensions (hwd / cm) 91.44 x 106.68 x 35.56 Shipping Weight (lbs.) 158.00 Shipping Weight (kg) 71.67 Unit Dimensions (hwd / in.) 31.000 x 38.500 x 7.800 Unit Dimensions (hwd / cm) 78.74 x 97.79 x 19.81 Unit Weight (lbs.) 105 Unit Weight (kg) 47.63 STANDARDS & COMPLIANCE Product Compliance UKCA WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
SU160KMBPKX 价格&库存
很抱歉,暂时无法提供与“SU160KMBPKX”相匹配的价格&库存,您可以联系我们找货
