1000 Eaton Boulevard
Cleveland, OH 44122
United States
UPS Maintenance Bypass Panel for Select
210KW (400V) 3-Phase UPS Systems - 3 Breakers
MODEL NUMBER: SU210KMBPKX
Highlights
Isolates UPS from connected
loads for maintenance without
losing network availability
Maintenance bypass panel
mounts to wall next to UPS for
convenient access
400A 10 kAIC unit has 3 built-in
circuit breakers connected to
heavy-duty buswork
Secure Kirk-key interlock
system prevents unauthorized
access to power
Compatible with SVX210KL7P,
SVX210KL8P and S3M200KX
3-phase UPS systems
Applications
UPS bypass panel reroutes power to keep essential equipment operational while the UPS is inoperative
or under maintenance.
System Requirements
Features
UPS Maintenance Bypass Panel Keeps Equipment Powered During UPS MaintenanceThis wallmount three-breaker maintenance bypass panel is compatible with SVX210KL7P, SVX210KL8P and
S3M200KX 3-phase 200kVA and 210kVA UPS systems. It allows you to reroute power around the UPS,
providing an alternate path for electricity that keeps the connected load operational while the UPS is
offline for maintenance or repairs.
Features 3 Built-In Circuit Breakers to Isolate LoadsThree circuit breakers – an AC input breaker, a
maintenance bypass breaker and a maintenance isolation breaker – are connected to heavy-duty buswork
and isolate the UPS system from its connected load with no loss of network availability. This allows the
load to remain continuously powered without costly downtime. A Kirk-key interlock system enhances
safety and security. Removable handles allow the panel’s trim cover to be removed for internal access.
The 400A unit has a kAIC rating of 10K.
Switching Between Normal and Bypass Modes Is EasyWhen a UPS needs maintenance, this UPS
bypass panel keeps power supplied to components via its mechanical interlock system by switching
power to the external bypass breaker. Simply unscrew the interlock switch, rotate the switch from the UPS
AC input breaker (SW1) to the bypass breaker (SW2), then turn on the bypass breaker and turn off the
UPS and isolation breaker (SW3) to perform UPS maintenance without service interruption.
Convenient Wall-Mount InstallationMade of galvanized steel, the service bypass panel has rear
mounting holes for installation on a smooth, solid wall (mounting hardware not included).
Specifications
OVERVIEW
UPC Code
037332241146
Accessory Type
Bypass Panel
1/2
Bypass a compatible offline 3phase UPS system to continue
powering mission-critical
equipment without interruption
and S3M200KX 3-phase UPS
system
Package Includes
SU210KMBPKX UPS
Maintenance Bypass Panel - 3
Breakers
Installation and Operation
Manual
Cleveland, OH 44122
United States
Accessory Class
UPS Accessories
INPUT
Nominal Input Voltage(s) Supported
480V AC
Voltage Compatibility (VAC)
480
PHYSICAL
Form Factors Supported
Wallmount
Shipping Dimensions (hwd / in.)
36.00 x 42.00 x 14.00
Shipping Dimensions (hwd / cm)
91.44 x 106.68 x 35.56
Shipping Weight (lbs.)
158.00
Shipping Weight (kg)
71.67
Unit Dimensions (hwd / in.)
31.000 x 38.500 x 7.800
Unit Dimensions (hwd / cm)
78.74 x 97.79 x 19.61
Unit Weight (lbs.)
105
Unit Weight (kg)
47.63
STANDARDS & COMPLIANCE
Product Compliance
UKCA
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
1-year limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
2/2
很抱歉,暂时无法提供与“SU210KMBPKX”相匹配的价格&库存,您可以联系我们找货
