1000 Eaton Boulevard
Cleveland, OH 44122
United States
SmartOnline SV Series 20kVA Medium-Frame
Modular Scalable 3-Phase On-Line DoubleConversion 208/120V 50/60 Hz UPS System, 1
Battery Module
MODEL NUMBER: SV20KM1P1B
Highlights
Scalable capacity up to 80kVA
(or 60kVA with N+1 fault
tolerance)
Economy mode option helps
reduce operating and cooling
costs
Pre-installed WEBCARDLX
network interface for 24/7
remote access
DSP/IGBT technology and 1%
output voltage regulation
Includes one internal battery
module; supports up to 3 more
For extended runtimes beyond
those provided by internal
battery modules, please review
the suffix "0B" SV models
without internal battery modules,
which offer different external
battery pack options.
Package Includes
3-phase 20kVA UPS system offers network-grade power protection in a highly configurable, modular and
scalable medium-chassis rack-width frame. Internal battery module can support a full load up to 3.9
minutes.
Description
The SV20KM1P1B SmartOnline® SV Series 20kVA 3-Phase On-Line Double-Conversion UPS System
delivers true scalability and offers the highest level of secure, uninterrupted power protection. Featuring a
modular, scalable design with high-efficiency voltage and frequency independent (VFI) operation, this online UPS system is ideal for protecting a variety of critical IT systems.
The SV20KM1P1B includes pre-installed input, bypass and output breakers, as well as a static transfer
switch (STS), one 20kVA SV20PM power module and one SVBM battery module. Space is included for
up to three additional user-installable SV20PM power modules and three SVBM internal battery modules.
The Java-free HTML5-based WEBCARDLX interface enables full remote access for site power and UPS
status monitoring, configuration, control and email notifications via secure web browser, SNMP, telnet or
SSH. It supports 10/100 Mbps auto-sensing for optimum communication with an Ethernet network.
With up to 92% efficiency in standard mode and up to 99% efficiency in optional economy mode, this
20kVA UPS system helps you reduce operating and cooling costs. Automatic and manual bypass options
keep connected equipment operational during routine maintenance or critical power module failure. Frontpanel display offers full UPS condition and status reporting.
Features
20kVA 18kW 3-Phase Medium-Chassis UPS System
● Supports 208/120V or 220/127V AC 50/60Hz Wye 4-wire plus Earth hardwire input and output wiring
Dual hardwire input design enables operation from up to 2 power sources
Network-grade sine-wave AC output with 1% output voltage regulation and less than 1% output total
harmonic distortion
Tested to UL 1778 (U.S.), CSA (Canada) and NOM (Mexico) standards
High 0.9 power factor for maximum power to the connected load
Pre-Installed WEBCARDLX Network Interface
● Allows full remote access for power monitoring, configuration, control and email notifications via secure
1/6
SV20KM1P1B SmartOnline SV
System
network interface
(1) SV20PM 20kVA power
module (shipped separately)
(1) SVBM battery module
Owner’s manual
Cleveland, OH 44122
United States
web browser, SNMP, telnet or SSH
Supports 10/100 Mbps auto-sensing for communication with an Ethernet network
Optional EnviroSense2 sensors (sold separately) enable site monitoring of temperature, humidity and
contact-closure status
No Java required
Modular, Scalable Design for Maximum Flexibility
● Modular configuration with hot-swappable power modules and batteries enables easy, fast maintenance
with zero downtime
Open slots for up to 3 additional 20kVA SV20PM power modules accommodate increased capacity up
to 80kVA (or 60kVA with N+1 fault tolerance)
Open slots for up to 3 additional SVBM internal batteries for extended runtime
Optional Economy Mode
● Up to 99% efficient in optional economy mode to lower operating and cooling costs
Wide Input/Narrow Output Voltage Operating Range
● Enables full continuous online operation during brownouts as low as 121V and overvoltages up to 253V
Regulates output voltage within 1% of the selected nominal output voltage in on-line double-conversion
mode
Advanced IGBT Inverter with Digital Signal Processor (DSP) Technology
● Provides for less than 2% input total harmonic distortion (THDi) to support 1:1 generator sizing and
prevent the need to oversize generator systems relative to UPS capacity
Automatic and Manual Bypass Options
● Keep connected equipment operational during routine maintenance or critical power module failure
Specifications
OVERVIEW
UPC Code
037332213815
UPS Type
On-Line
INPUT
Input Phase
3-Phase
Rated input current (Maximum Load)
SV20KM1P1B 20kVA Configuration: 60A; Maximum 80kVA Configuration: 240A; 133A maximum inrush current
Nominal Input Voltage(s) Supported
120/208V 3-PH Wye; 127/220V 3-PH Wye
Nominal Input Voltage Description
Set of two hardwire input connections enables 3-Phase Wye, 4 wire (3P, N, E) inputs from two separate power
sources
UPS Input Connection Type
Hardwire
Input Circuit Breakers
MAIN and ALTERNATE AC inputs are each protected by 300A 3 pole magnetic breakers
Input Frequency
40 to 70Hz (online mode); 50/60Hz Auto-selectable
2/6
Cleveland, OH 44122
United States
Power Factor (Input)
Greater than 0.99 (full load)
THDi
Less than 2% (full linear load)
OUTPUT
Output Capacity (VA)
20000
Output Capacity (kVA)
Output Capacity (Watts)
18000
Output Capacity (kW)
18
Output Capacity Details
OVERLOAD CAPABILITY: Supports 105-110% load for 1 hour, 111-125% load for 10 minutes, 126-150% for 1
minute and Over 150% for 200ms before switching to Bypass; Online operation resumes when load is reduced to
100% or less
Power Factor
0.9
Crest Factor
3:1
Nominal Voltage Details
Output THD full resistive load:
很抱歉,暂时无法提供与“SV20KM1P1B”相匹配的价格&库存,您可以联系我们找货
