SV40KM2P4B
SV40KM2P4B
    TRIPPLITE
    40KVA SMART ONLINE 3-PHASE UPS M
SV40KM2P4B 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States SmartOnline SV Series 40kVA Medium-Frame Modular Scalable 3-Phase On-Line DoubleConversion 208/120V 50/60 Hz UPS System, 4 Battery Modules MODEL NUMBER: SV40KM2P4B Highlights ● Scalable capacity up to 80kVA (or 60kVA with N+1 fault tolerance) ● Economy mode option helps reduce operating and cooling costs ● Pre-installed WEBCARDLX network interface for 24/7 remote access ● DSP/IGBT technology and 1% output voltage regulation ● Includes 4 internal battery modules ● For extended runtimes beyond those provided by internal battery modules, please review the suffix "0B" SV models without internal battery modules, which offer different external battery pack options. Package Includes 3-phase 40kVA UPS system offers network-grade power protection in a highly configurable, modular and scalable medium-chassis rack-width frame. Internal battery modules can support a full load up to 10 minutes. Description The SV40KM2P4B SmartOnline® SV Series 40kVA 3-Phase On-Line Double-Conversion UPS System delivers true scalability and offers the highest level of secure, uninterrupted power protection. Featuring a modular, scalable design with high-efficiency voltage and frequency independent (VFI) operation, this online UPS system is ideal for protecting a variety of critical IT systems. The SV40KM2P4B includes pre-installed input, bypass and output breakers, as well as a static transfer switch (STS), two 20kVA SV20PM power modules and four SVBM battery modules. Space is included for up to two additional user-installable SV20PM power modules. The Java-free HTML5-based WEBCARDLX interface enables full remote access for site power and UPS status monitoring, configuration, control and email notifications via secure web browser, SNMP, telnet or SSH. It supports 10/100 Mbps auto-sensing for optimum communication with an Ethernet network. With up to 92% efficiency in standard mode and up to 99% efficiency in optional economy mode, this 40kVA UPS system helps you reduce operating and cooling costs. Automatic and manual bypass options keep connected equipment operational during routine maintenance or critical power module failure. Frontpanel display offers full UPS condition and status reporting. Features 40kVA 36kW 3-Phase Medium-Chassis UPS SystemSupports 208/120V or 220/127V AC 50/60Hz Wye 4-wire plus Earth hardwire input and output wiringDual hardwire input design enables operation from up to 2 power sourcesNetwork-grade sine-wave AC output with 1% output voltage regulation and less than 1% output total harmonic distortionTested to UL 1778 (U.S.), CSA (Canada) and NOM (Mexico) standardsHigh 0.9 power factor for maximum power to the connected load Pre-Installed WEBCARDLX Network InterfaceAllows full remote access for power monitoring, configuration, control and email notifications via secure web browser, SNMP, telnet or SSHSupports 10/100 Mbps auto-sensing for communication with an Ethernet networkOptional EnviroSense2 sensors (sold separately) enable site monitoring of temperature, humidity and contact-closure statusNo Java required Modular, Scalable Design for Maximum FlexibilityModular configuration with hot-swappable power 1/6 ● SV40KM2P4B SmartOnline SV Series 40kVA 3-Phase On-Line Double-Conversion UPS System ● Pre-installed WEBCARDLX network interface ● (2) SV20PM 20kVA power modules (shipped separately) ● (4) SVBM battery modules (shipped separately) ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States modules and batteries enables easy, fast maintenance with zero downtimeOpen slots for up to 2 additional 20kVA SV20PM power modules accommodate increased capacity up to 80kVA (or 60kVA with N+1 fault tolerance) Optional Economy ModeUp to 99% efficient in optional economy mode to lower operating and cooling costs Wide Input/Narrow Output Voltage Operating RangeEnables full continuous online operation during brownouts as low as 121V and overvoltages up to 253VRegulates output voltage within 1% of the selected nominal output voltage in on-line double-conversion mode Advanced IGBT Inverter with Digital Signal Processor (DSP) TechnologyProvides for less than 2% input total harmonic distortion (THDi) to support 1:1 generator sizing and prevent the need to oversize generator systems relative to UPS capacity Automatic and Manual Bypass OptionsKeep connected equipment operational during routine maintenance or critical power module failure Specifications OVERVIEW UPC Code 037332213129 UPS Type On-Line INPUT Input Phase 3-Phase Rated input current (Maximum Load) SV40KM2P4B 40kVA Configuration: 120A; Maximum 80kVA Configuration: 240A; 314A maximum inrush current Nominal Input Voltage(s) Supported 120/208V 3-PH Wye; 127/220V 3-PH Wye Nominal Input Voltage Description Set of two hardwire input connections enables 3-Phase Wye, 4 wire (3P, N, G) inputs from two separate power sources UPS Input Connection Type Hardwire Input Circuit Breakers MAIN and ALTERNATE AC inputs are each protected by 300A 3 pole magnetic breakers Input Frequency 40 to 70Hz (online mode); 50/60Hz Auto-selectable Power Factor (Input) Greater than 0.99 (full load) THDi Less than 2% (full linear load) OUTPUT Output Capacity (VA) 40000 Output Capacity (kVA) 40 Output Capacity (Watts) 36000 Output Capacity (kW) 36 Output Capacity Details OVERLOAD CAPABILITY: Supports 105-110% load for 1 hour, 111-125% load for 10 minutes, 126-150% for 1 minute and Over 150% for 200ms before switching to Bypass; Online operation resumes when load is reduced to 100% or less 2/6 1000 Eaton Boulevard Cleveland, OH 44122 United States Power Factor 0.9 Crest Factor 3:1 Nominal Voltage Details Output THD full resistive load:
SV40KM2P4B 价格&库存
很抱歉,暂时无法提供与“SV40KM2P4B”相匹配的价格&库存,您可以联系我们找货
