U442-DOCK5-GY
U442-DOCK5-GY
    TRIPPLITE
    USB-C DOCK, 4K HDMI, 3X USB-A PO
U442-DOCK5-GY 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States USB-C Dock - 4K HDMI, USB 3.x (5Gbps), USBA/C Hub Ports, GbE, Memory Card, 100W PD Charging MODEL NUMBER: U442-DOCK5-GY Highlights ● Converts audio/video signals from laptops and other devices that support USB-C DisplayPort Alt Mode ● Supports 4K resolutions up to 3840 x 2160 (@ 30 Hz) for crystal-clear video ● Connect to a wired 10/100/1000 Mbps (Gigabit) Ethernet network when Wi-Fi is unavailable ● Charge the host laptop with up to 100 Watts (20V 5A) of PD Charging power output ● USB-C, USB-A and memory card ports allow connection of flash drives and other peripherals Applications ● Play video from your laptop or PC on an HDMI display, such as an HDTV or projector ● Save data to a USB-enabled thumb drive or external hard drive ● Access a wired Gigabit Ethernet network in a location with no or spotty Wi-Fi ● Charge your notebook or laptop by connecting its wall charger to the USB-C PD Charging port ● Connect a microphone/headset to record a podcast or listen to music USB-C docking station with PD Charging adds HDMI, USB-A, Ethernet and memory card ports to your Chromebook, Windows laptop or tablet. Features USB-C Docking Station Turns Your Device’s USB-C or Thunderbolt 3 Port into a WorkstationThis USB-C dock with PD Charging expands the potential of your Windows laptop, Chromebook, smartphone or PC’s USB-C or Thunderbolt 3 port. It’s ideal for transmitting true 4K video and digital audio to a large display, adding a thumb drive and other USB peripherals, powering and charging a PD Chargingcompliant mobile device, connecting to a Gigabit Ethernet network and a lot more—all at the same time. Supports USB-C DisplayPort Alternate Mode for Converting Audio/Video SignalsBy connecting the built-in USB-C cable to a source device that supports USB DisplayPort Alt Mode, you can output 4K video and digital audio to an HDMI monitor, television or projector without installing special software drivers. Transmits Crystal-Clear 4K Video and Digital Audio with True 4:4:4 ColorThe HDMI output supports 4K video resolutions up to 3840 x 2160 at 30 Hz with multi-channel sound and 4:4:4 chroma subsampling for top-level PC gaming or using your HDTV as a PC monitor. Connect the HDMI port to your display using an HDMI cable (sold separately). A DVI display may also be connected using an HDMI to DVI adapter (sold separately). USB Ports Connect Keyboards, Thumb Drives and Other PeripheralsThree USB-A hub ports accept USB peripherals, such as flash drives, mice, keyboards and printers. They support 5V 2A (10W) of charging power, when connected to a PD 3.0-compliant charger, and fast USB 3.2 Gen 1 data transfer rates up to 5 Gbps (10 times faster than USB 2.0). One port provides 5V 1.5A (7.5W) of power dedicated to fast-charging your mobile device. Note: Host must support USB OTG (On-the-Go). PD Charging Port Charges the Connected Notebook, Tablet or Other DeviceThe USB-C port supports Power Delivery (PD) 3.0 charging of connected PD Charging-compliant devices, such as laptops, Kindles, iPads and Android smartphones. Connect the device’s AC wall charger to the USB-C PD port, which supports power input up to 20V 5A (100W). This port, as mentioned above, can also be used for transferring data up to 5 Gbps. PD 3.0 Fast Role Swap technology ensures all data and power connections remain stable if the wall charger becomes accidentally dislodged. Note: USB-C PD port does not support Quick Charge (QC). 1/6 System Requirements ● Source device with USB-C or Thunderbolt 3 port that supports USB DisplayPort Alternate Mode ● Display device with HDMI or DVI* input *Requires adapter (sold separately) Package Includes ● U442-DOCK5-GY USB-C Dock, Gray ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Accesses a Wired Gigabit Ethernet NetworkThe RJ45 port offers access to a Gigabit Ethernet network when Wi-Fi is unavailable or when a wired connection offers faster speeds. Connect using a UTP cable (sold separately), and enjoy true 10/100/1000 Mbps Ethernet speeds for fast data transfers. Allows External Memory AccessThe memory card slots support Micro SD and SD/MMC cards for transferring data to and from your connected computer, laptop or tablet. Both slots may be used at the same time. Built-In USB-C Cable Attaches in Either DirectionUnlike traditional USB cables that connect in only one direction, the reversible USB-C male connector plugs into a USB-C or Thunderbolt 3 port in either direction for an instant connection every time. Ready to Use Right from the Package, So You Can Plug and Play ImmediatelyThe plug-and-play USB-C dock is specifically designed for use with Windows laptops and other notebooks, smartphones, tablets and devices equipped with a USB-C or Thunderbolt 3 port. It requires no extra software to be downloaded or installed. It’s about the size of a smartphone, making it easy to pack into a pocket, backpack or laptop bag for multiport convenience wherever you go. Specifications OVERVIEW UPC Code 037332241016 Product Type Docking Station Device Compatibility Chromebook; Computer; Laptop; Monitor/HDTV; Phone Technology Cat5/5e; Cat6; HDMI; USB 3.x Country/Region Global Host Connector USB C (MALE) VIDEO Video Input USB C (MALE) Video Output HDMI (FEMALE) Number of Monitors Supported 1 Video Ports HDMI (FEMALE) Video Ports Details HDMI 1.4; HDCP 1.4 Resolutions Supported 3840 x 2160 (4K x 2K) @ 30 Hz Supported Resolutions 3840x2160 (4K) Max Supported Video Resolution 3840 X 2160 (4K X 2K) @ 30HZ Recommended Cabling P568-Series High Speed 4K HDMI Cables Extended Mode Yes Extended Mode Details Extend your workspace to across a connected display at video resolutions up to 3840 x 2160 (4K x 2K) @ 30 Hz Mirror Mode Yes Mirror Mode Details Mirror video from the USB-C port on a laptop to a connected display at video resolutions up to 3840 x 2160 (4K x 2K) @ 30 Hz 2/6 1000 Eaton Boulevard Cleveland, OH 44122 United States Max Supported Color Depth 24-bit True Color HDR Support Yes 3D Video Supported Yes Chroma Sub Sampling 4:2:2; 4:4:4 EDID Support Yes Signal Transmission Unidirectional DisplayPort Alt Mode Yes DSC Support Yes DATA Data Ports (3) USB A (FEMALE); (1) USB C (FEMALE) Data Ports Details (3) USB-A - USB 3.2 Gen 1 (5 Gbps); (1) USB-C - USB 3.2 Gen 1 (5 Gbps) NETWORK Network Ports RJ45 (FEMALE) STORAGE Card Slots SD (FEMALE); MICRO SD (FEMALE) Card Slots Details SD 3.0 Memory Card slots (SD and MicroSD) can be used simultaneously INPUT Bus Powered Yes BATTERY Battery Charging (5V/1.5A Port) Yes POWER USB Power Delivery (PD) Charging Support Yes USB Power Delivery (PD) Charging Specification 3.0 USER INTERFACE, ALERTS & CONTROLS LED Indicators White (Connection to Power) and Orange (Activity) CHARGING Number of Charging Ports 4 Total Charging Amps 2 Total Charging Watts 100 3/6 1000 Eaton Boulevard Cleveland, OH 44122 United States Charging Port Type (3) USB A (FEMALE); USB C (FEMALE) Charging Ports USB-C: 100W (20V 5A) Power Delivery (PD 3.0); USB-A: 5V 1.5A (7.5W) Charging Ports Details One USB-A port supports 5V 1.5A (7.5W) for quickly charging mobile devicesAll three USB-A ports share 5V 2A (10W) when connected to a PD 3.0 compliant chargerThe USB-C PD Charging/Data port provides up to 20V 5A (100W) to charge the host laptop via a compatible wall charger Charging Ports / Amps 1.5A; 5A Compatible Devices Chromebook; Laptop; Smartphone; Tablet PHYSICAL Color Black Material of Construction Aluminum Connector Color Gray Cable Jacket Rating VW-1 Cable Outer Diameter (OD) 4.2mm Cable Length (ft.) 0.39 Cable Length (m) 0.12 Cable Length (in.) 4.72 Cable Length (cm) 12 Total Number of Ports 8 Shipping Dimensions (hwd / in.) 0.91 x 5.51 x 3.94 Shipping Dimensions (hwd / cm) 2.31 x 14.00 x 10.01 Shipping Weight (lbs.) 0.25 Shipping Weight (kg) 0.11 Unit Dimensions (hwd / in.) 0.500 x 4.100 x 1.900 Unit Dimensions (hwd / cm) 1.3 x 10.5 x 4.9 Unit Packaging Type Box Unit Weight (lbs.) 0.25 Unit Weight (kg) 0.11 ENVIRONMENTAL Operating Temperature Range 32° to 113°F (0° to 45°C) Storage Temperature Range 14° to 158°F (-10° to 70°C) Operating Humidity Range 10% to 85% RH, Non-Condensing Storage Humidity Range 5% to 90% RH, Non-Condensing Power Provided to Connected Device(s) USB-A: 5V/2A (10W), USB-C PD: 20V/5W (100W) COMMUNICATIONS 4/6 1000 Eaton Boulevard Cleveland, OH 44122 United States Network Compatibility 1 Gbps (Gigabit) EDID Compatible Yes IEEE Standards Supported 802.3; 802.3az; 802.3u; 802.3x CONNECTIONS Number of Ports 8 Ports 1 Ports Detail Connect to a wired Gigabit Ethernet network via the built-in RJ45 port on the dock. Dock Connectors USB-C PD Data/Charging, (3) USB-A 3.2 Gen 1, MICRO SD, SD, HDMI, RJ45 Side A - Connector 1 USB C (MALE) Side B - Connector 1 HDMI (FEMALE) Side B - Connector 2 RJ45 (FEMALE) Side B - Connector 3 (3) USB A (FEMALE) Side B - Connector 4 USB C (FEMALE) Side B - Connector 5 MICRO SD (FEMALE) Side B - Connector 6 SD (FEMALE) Connector Plating Nickel Connector Style Straight FEATURES & SPECIFICATIONS USB Hub Ports Yes Number of USB Hub Ports 3 USB Specification USB 3.0 (up to 5 Gbps); USB 3.1 Gen 1 (up to 5 Gbps); USB 3.2 Gen 1 (up to 5 Gbps) Data Transfer Rate 5 Gbps MST Support No Multi-Resolution Support No Network Speed Support 10 Mbps; 100 Mbps (Fast Ethernet); 1 Gbps (Gigabit) Ethernet Support Yes UASP Support No Auto MDIX Support Yes Full Duplex Support Yes Suspend Mode Support Yes Remote Wakeup Support Yes SD Card Specification SD; Micro SD HDCP Specification 1.4 Driver Required No 5/6 1000 Eaton Boulevard Cleveland, OH 44122 United States Recommended Category Cable Cat5/Cat5e/Cat6 Cables STANDARDS & COMPLIANCE TAA Compliant Option N Product Certifications ICES (Canada); NOM (Mexico) Product Compliance CE (Europe); FCC (USA); REACH; RoHS; UKCA WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 6/6
U442-DOCK5-GY 价格&库存
很抱歉,暂时无法提供与“U442-DOCK5-GY”相匹配的价格&库存,您可以联系我们找货
